Re: [DNX#2006040142001392] [U-Boot-Users] Re: Re: Rx-buffer overlow
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006040142001392] was created:
<snip>
In message 20060228081735.GA4849@false you wrote:
=20 fec_recv[249] err: 802 fec_recv[249] err: 2802 fec_recv[249] err: 802 =20 According to the Rx-buffer-status bits, an overlow takes place. So ping just works if there is less network traffic. But why ? - is the receiv=
e
buffer to small, the CPU to slow ?=20
At which clock frequency are you running your CPU?
the MPC875 is running at 40MHz!
Btw, ethernet just works in 10MB half duplex mode (probably failure in hardware). Maybe this is also related to that problem!
U-Boot 1.1.3 (Feb 28 2006 - 09:27:50)
CPU: MPC885ZPnn at 40 MHz [40.0...50.0 MHz] 8 kB I-Cache 8 kB D-Cache FEC present You made sure it's an ESM this is running on, right? DRAM: 64 MB FLASH: 16 MB In: serial Out: serial Err: serial Net: FEC ETHERNET
Best regards, Wolfgang Denk
Best regards, Josef
This SF.Net email is sponsored by xPML, a groundbreaking scripting language that extends applications into web and mobile media. Attend the live webcast and join the prime developer group breaking into this new coding territory! http://sel.as-us.falkag.net/sel?cmd=lnk&kid=110944&bid=241720&da... _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
</snip>
Your U-Boot support team
DENX Support System
