[PATCH] arm64: zynqmp: Support semhosting boot method
Currently, when we boot from JTAG we try to boot U-Boot from RAM. However, this is a bit tricky to time, since the debugger has to wait for SPL to initialize RAM before it can load U-Boot. This can result in long waits, since occasionally initializing RAM (and other things in psu_init) takes a long time to complete and the debugger must wait for this worst case.
Support semihosting if it is enabled, as it lets U-Boot tell the debugger when we are ready for the image. This means we don't have to wait any more than necessary. We don't change the default config to ensure we don't break compatibility with existing debuggers that don't expect us to hit semihosting breakpoints.
Signed-off-by: Sean Anderson sean.anderson@seco.com ---
arch/arm/mach-zynqmp/spl.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-zynqmp/spl.c b/arch/arm/mach-zynqmp/spl.c index a0f35f36faa..5af735aa5ce 100644 --- a/arch/arm/mach-zynqmp/spl.c +++ b/arch/arm/mach-zynqmp/spl.c @@ -9,6 +9,7 @@ #include <image.h> #include <init.h> #include <log.h> +#include <semihosting.h> #include <spl.h> #include <linux/delay.h>
@@ -66,6 +67,11 @@ void spl_board_init(void) } #endif
+static u32 jtag_boot_device(void) +{ + return semihosting_enabled() ? BOOT_DEVICE_SMH : BOOT_DEVICE_RAM; +} + void board_boot_order(u32 *spl_boot_list) { spl_boot_list[0] = spl_boot_device(); @@ -75,7 +81,7 @@ void board_boot_order(u32 *spl_boot_list) if (spl_boot_list[0] == BOOT_DEVICE_MMC2) spl_boot_list[1] = BOOT_DEVICE_MMC1;
- spl_boot_list[2] = BOOT_DEVICE_RAM; + spl_boot_list[2] = jtag_boot_device(); }
u32 spl_boot_device(void) @@ -97,7 +103,7 @@ u32 spl_boot_device(void)
switch (bootmode) { case JTAG_MODE: - return BOOT_DEVICE_RAM; + return jtag_boot_device(); #ifdef CONFIG_SPL_MMC case SD_MODE1: case SD1_LSHFT_MODE: /* not working on silicon v1 */ -- 2.35.1.1320.gc452695387.dirty
[Embedded World 2024, SECO SpA]https://www.messe-ticket.de/Nuernberg/embeddedworld2024/Register/ew24517689
- void board_boot_order(u32 *spl_boot_list) { spl_boot_list[0] = spl_boot_device();
#ifdef CONFIG_SPL_MMC case SD_MODE1: case SD1_LSHFT_MODE: /* not working on silicon v1 */return jtag_boot_device();
Good timing. Can you please tell me how to test this? What's the setup? Which debugger are you using?
Also curious if semihosting serial can be used in your setup.
Thanks, Michal
I am using OpenOCD with the patches at https://review.openocd.org/c/openocd/+/8133
My boot flow is
SPL -> ATF -> U-Boot (no FSBL)
This allows me to use a FIT which saves some time since I can compress the bitstream. Right now I am using xilinx_zynqmp_virt_defconfig with the following modifications:
CONFIG_SYS_LOAD_ADDR=0x30000000 # CONFIG_SPL_OS_BOOT is not set CONFIG_SPL_SEMIHOSTING=y
I also have CONFIG_XILINX_PS_INIT_FILE, CONFIG_ZYNQMP_SPL_PM_CFG_OBJ_FILE, and CONFIG_PMUFW_INIT_FILE defined as appropriate. I use the following FIT for U-Boot:
/dts-v1/;
/ { description = "U-Boot and ATF"; #address-cells = <1>;
images { atf { description = "Arm Trusted Firmware"; data = /incbin/("arm-trusted-firmware.bin"); type = "firmware"; os = "arm-trusted-firmware"; arch = "arm64"; compression = "none"; load = <0xfffea000>; entry = <0xfffea000>; };
fpga { description = "PL Bitstream"; data = /incbin/("system.bit.gz"); type = "fpga"; arch = "arm64"; compression = "gzip"; load = <0x7c000000>; compatible = "u-boot,fpga-legacy"; };
u-boot { description = "U-Boot"; data = /incbin/("u-boot-nodtb.bin"); type = "firmware"; os = "u-boot"; arch = "arm64"; compression = "none"; load = <0x00080000>; entry = <0x00080000>; };
fdt { description = "U-Boot FDT"; data = /incbin/("u-boot.dtb"); type = "flat_dt"; arch = "arm64"; compression = "none"; hash-1 { algo = "crc32"; }; }; };
configurations { default = "conf"; conf { description = "Boot ATF and U-Boot"; firmware = "atf"; loadables = "u-boot", "fpga"; fdt = "fdt"; }; }; };
Boot output looks like
U-Boot SPL 2024.01 (Feb 15 2024 - 17:03:10 +0000) Loading new PMUFW cfg obj (1848 bytes) PMUFW: v1.1 Silicon version: 3 EL Level: EL3 Secure Boot: not authenticated, not encrypted Multiboot: 0 Trying to boot from MMC1 FPGA image loaded from FIT NOTICE: BL31: v2.6(release):xlnx_rebase_v2.6_2022.2 NOTICE: BL31: Built : 03:55:03, Sep 9 2022
U-Boot 2024.01 (Feb 15 2024 - 17:03:10 +0000)
CPU: ZynqMP Silicon: v3 Chip: zu4 Board: Xilinx ZynqMP DRAM: 2 GiB (effective 4 GiB) PMUFW: v1.1 EL Level: EL2 Secure Boot: not authenticated, not encrypted Core: 67 devices, 29 uclasses, devicetree: board Warning: Device tree includes old 'u-boot,dm-' tags: please fix by 2023.07! NAND: 0 MiB MMC: PMUFW: No permission to change config object arasan_sdhci mmc@ff170000: Sdhci card detect state not stable arasan_sdhci mmc@ff170000: Sdhci card detect state not stable mmc@ff170000 - probe failed: -110 mmc@ff160000: 0arasan_sdhci mmc@ff170000: Sdhci card detect state not stable
Loading Environment from nowhere... OK In: serial Out: serial,vidconsole Err: serial,vidconsole Bootmode: JTAG_MODE Reset reason: EXTERNAL Net: zynq_gem ethernet@ff0b0000: failed to get tx_clock zynq_gem ethernet@ff0c0000: failed to get tx_clock zynq_gem ethernet@ff0d0000: failed to get tx_clock zynq_gem ethernet@ff0e0000: failed to get tx_clock No ethernet found.
scanning bus for devices... SATA link 0 timeout. SATA link 1 timeout. AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode flags: 64bit ncq pm clo only pmp fbss pio slum part ccc apst starting USB... Bus usb@fe300000: Register 2000440 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus usb@fe300000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0
I haven't tested it.
Hope that helps. Unfortunately, I don't think all of the above is documented in one place.
--Sean
I am using OpenOCD with the patches at https://cas5-0-urlprotect.trendmicro.com:443/wis/clicktime/v1/query?url=http...
My boot flow is
/dts-v1/;
images { atf { description = "Arm Trusted Firmware"; data = /incbin/("arm-trusted-firmware.bin"); type = "firmware"; os = "arm-trusted-firmware"; arch = "arm64"; compression = "none"; load = <0xfffea000>; entry = <0xfffea000>; }; fpga { description = "PL Bitstream"; data = /incbin/("system.bit.gz"); type = "fpga"; arch = "arm64"; compression = "gzip"; load = <0x7c000000>; compatible = "u-boot,fpga-legacy"; }; u-boot { description = "U-Boot"; data = /incbin/("u-boot-nodtb.bin"); type = "firmware"; os = "u-boot"; arch = "arm64"; compression = "none"; load = <0x00080000>; entry = <0x00080000>; }; fdt { description = "U-Boot FDT"; data = /incbin/("u-boot.dtb"); type = "flat_dt"; arch = "arm64"; compression = "none"; hash-1 { algo = "crc32"; }; }; }; configurations { default = "conf"; conf { description = "Boot ATF and U-Boot"; firmware = "atf"; loadables = "u-boot", "fpga"; fdt = "fdt"; }; };
Whoops, I attached a regular boot log. Semihosting looks pretty much the same:
U-Boot SPL 2024.01 (Feb 15 2024 - 17:03:10 +0000) Loading new PMUFW cfg obj (1848 bytes) PMUFW: v1.1 Silicon version: 3 EL Level: EL3 Secure Boot: not authenticated, not encrypted Multiboot: 0 Trying to boot from SEMIHOSTING FPGA image loaded from FIT NOTICE: BL31: v2.6(release):xlnx_rebase_v2.6_2022.2 NOTICE: BL31: Built : 03:55:03, Sep 9 2022
--Sean
I am trying it on the top of the latest git but getting issue with event block and no idea how to fix it.
# sudo openocd -f /usr/local/share/openocd/scripts/interface/ftdi/digilent_jtag_hs3.cfg -f /usr/local/share/openocd/scripts/target/xilinx_zynqmp.cfg Open On-Chip Debugger 0.12.0+dev-01509-g6d288937cb2d (2024-02-16-12:22) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'. wrong # args: should be "-event <event-name> <event-body>"
Do you know how to fix it?
Thanks, Michal
I actually bisect it and found that it is caused by jtag: rewrite jim_jtag_configure() as COMMAND_HANDLER ea2e26f7d521f5755b4bfda7bf12d99650277421
# sudo openocd -f /usr/local/share/openocd/scripts/interface/ftdi/digilent_jtag_smt2_nc.cfg -f /usr/local/share/openocd/scripts/target/xilinx_zynqmp.cfg Open On-Chip Debugger 0.12.0+dev-01512-g214206ebb972 (2024-02-16-15:38) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html none separate Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'. Info : Hardware thread awareness created boot_apu Info : Listening on port 6666 for tcl connections Info : Listening on port 4444 for telnet connections Warn : An adapter speed is not selected in the init scripts. OpenOCD will try to run the adapter at very low speed (100 kHz). Warn : To remove this warnings and achieve reasonable communication speed with the target, set "adapter speed" or "jtag_rclk" in the init scripts. Info : clock speed 100 kHz Info : TAP uscale.tap does not have valid IDCODE (idcode=0x48e70126) Info : JTAG tap: uscale.ps tap/device found: 0x24738093 (mfg: 0x049 (Xilinx), part: 0x4738, ver: 0x2) Info : JTAG tap: uscale.tap tap/device found: 0x5ba00477 (mfg: 0x23b (ARM Ltd), part: 0xba00, ver: 0x5) Info : JTAG tap: uscale.ps tap/device found: 0x24738093 (mfg: 0x049 (Xilinx), part: 0x4738, ver: 0x2) Error: JTAG-DP STICKY ERROR Error: [uscale.a53.0] Examination failed Warn : target uscale.a53.0 examination failed Info : [uscale.axi] Examination succeed Info : starting gdb server for uscale.a53.0 on 3333 Info : Listening on port 3333 for gdb connections Info : gdb port disabled
but with zcu102 I am still not able to connect because error above. The same behavior with recording SOM IDs I see on kv260 (via hs3 cable). It looks like that not everything is working for zynqmp.
And no issue with xsdb.
Thanks, Michal
# sudo openocd -f /usr/local/share/openocd/scripts/interface/ftdi/digilent_jtag_hs3.cfg -f /usr/local/share/openocd/scripts/target/xilinx_zynqmp.cfg Open On-Chip Debugger 0.12.0+dev-01509-g6d288937cb2d (2024-02-16-12:22) Licensed under GNU GPL v2 For bug reports, read https://cas5-0-urlprotect.trendmicro.com:443/wis/clicktime/v1/query?url=http... Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'. wrong # args: should be "-event <event-name> <event-body>"
Interesting. I have been testing with 0.12.
FWIW after installing the udev rules I do not need sudo
Open On-Chip Debugger 0.12.0+dev-01512-g214206ebb972 (2024-02-16-15:38) Licensed under GNU GPL v2 For bug reports, read https://cas5-0-urlprotect.trendmicro.com:443/wis/clicktime/v1/query?url=http... none separate Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'. Info : Hardware thread awareness created boot_apu Info : Listening on port 6666 for tcl connections Info : Listening on port 4444 for telnet connections Warn : An adapter speed is not selected in the init scripts. OpenOCD will try to run the adapter at very low speed (100 kHz). Warn : To remove this warnings and achieve reasonable communication speed with the target, set "adapter speed" or "jtag_rclk" in the init scripts. Info : clock speed 100 kHz Info : TAP uscale.tap does not have valid IDCODE (idcode=0x48e70126) Info : JTAG tap: uscale.ps tap/device found: 0x24738093 (mfg: 0x049 (Xilinx), part: 0x4738, ver: 0x2) Info : JTAG tap: uscale.tap tap/device found: 0x5ba00477 (mfg: 0x23b (ARM Ltd), part: 0xba00, ver: 0x5) Info : JTAG tap: uscale.ps tap/device found: 0x24738093 (mfg: 0x049 (Xilinx), part: 0x4738, ver: 0x2) Error: JTAG-DP STICKY ERROR Error: [uscale.a53.0] Examination failed Warn : target uscale.a53.0 examination failed Info : [uscale.axi] Examination succeed Info : starting gdb server for uscale.a53.0 on 3333 Info : Listening on port 3333 for gdb connections Info : gdb port disabled
Is this with the boot mode set to JTAG? If so, you will not be able to examine any of the CPUs until you have released them from reset. So you should be able to run
targets uscale.axi boot_pmu /path/to/pmu-firmware.bin boot_apu /path/to/u-boot-spl.bin
to boot a CPU. If you want to silence the above error, you can add
uscale.a53.0 configure -defer-examine
to your config. So the full command would be
$ openocd -f interface/ftdi/digilent_jtag_smt2_nc.cfg \ -f target/xilinx_zynqmp.cfg \ -c 'uscale.a53.o configure -defer-examine' \ -c init -c 'targets uscale.axi' \ -c 'boot_pmu /path/to/pmu-firmware.bin' \ -c 'boot_apu /path/to/boot.bin'
Let me know if that works for you.
--Sean
Oh, and I forgot to mention, but if you are testing semihosting then you will need to add
-c 'uscale.a53.0 arm semihosting enable'
to the end of that. I also find setting the semihosting base directory with
-c 'uscale.a53.0 arm semihosting_basedir $IMAGEDIR'
to be helpful.
As you can imagine this is a long command line, so I have a config which looks like
source [find interface/ftdi/digilent_jtag_smt2_nc.cfg] adapter speed 25000 source [find target/xilinx_zynqmp.cfg] uscale.a53.0 configure -defer-examine
proc boot {imagedir machine} { targets uscale.axi boot_pmu "${imagedir}/pmu-firmware-${machine}.bin" boot_apu "${imagedir}/u-boot-spl.bin" uscale.a53.0 arm semihosting enable uscale.a53.0 arm semihosting_basedir $imagedir }
which I invoke like
$ openocd -f my_config.cfg -c init -c 'boot /path/to/images my-machine'
--Sean
On 2/15/24 18:19, Sean Anderson wrote: > Currently, when we boot from JTAG we try to boot U-Boot from RAM. > However, this is a bit tricky to time, since the debugger has to wait > for SPL to initialize RAM before it can load U-Boot. This can result in > long waits, since occasionally initializing RAM (and other things in > psu_init) takes a long time to complete and the debugger must wait for > this worst case. > > Support semihosting if it is enabled, as it lets U-Boot tell the > debugger when we are ready for the image. This means we don't have to > wait any more than necessary. We don't change the default config to > ensure we don't break compatibility with existing debuggers that don't > expect us to hit semihosting breakpoints. > > Signed-off-by: Sean Anderson sean.anderson@seco.com > --- > > arch/arm/mach-zynqmp/spl.c | 10 ++++++++-- > 1 file changed, 8 insertions(+), 2 deletions(-) > > diff --git a/arch/arm/mach-zynqmp/spl.c b/arch/arm/mach-zynqmp/spl.c > index a0f35f36faa..5af735aa5ce 100644 > --- a/arch/arm/mach-zynqmp/spl.c > +++ b/arch/arm/mach-zynqmp/spl.c > @@ -9,6 +9,7 @@ > #include <image.h> > #include <init.h> > #include <log.h> > +#include <semihosting.h> > #include <spl.h> > #include <linux/delay.h> > > @@ -66,6 +67,11 @@ void spl_board_init(void) > } > #endif > > +static u32 jtag_boot_device(void) > +{ > + return semihosting_enabled() ? BOOT_DEVICE_SMH : BOOT_DEVICE_RAM; > +} > + > void board_boot_order(u32 *spl_boot_list) > { > spl_boot_list[0] = spl_boot_device(); > @@ -75,7 +81,7 @@ void board_boot_order(u32 *spl_boot_list) > if (spl_boot_list[0] == BOOT_DEVICE_MMC2) > spl_boot_list[1] = BOOT_DEVICE_MMC1; > > - spl_boot_list[2] = BOOT_DEVICE_RAM; > + spl_boot_list[2] = jtag_boot_device(); > } > > u32 spl_boot_device(void) > @@ -97,7 +103,7 @@ u32 spl_boot_device(void) > > switch (bootmode) { > case JTAG_MODE: > - return BOOT_DEVICE_RAM; > + return jtag_boot_device(); > #ifdef CONFIG_SPL_MMC > case SD_MODE1: > case SD1_LSHFT_MODE: /* not working on silicon v1 */
to be helpful.
which I invoke like
ok. 0.12.0 version is working better. I am able to load firmware to APU but I was not able to load pmufw. It was saying timeout like this.
boot_pmu /mnt/disk/som/pmu_obj.bin
/usr/local/bin/../share/openocd/scripts/target/xilinx_zynqmp.cfg:173: Error: Timed out waiting for PMU firmware in procedure 'boot_pmu' in procedure 'resume_pmu' called at file "/usr/local/bin/../share/openocd/scripts/target/xilinx_zynqmp.cfg", line 232 at file "/usr/local/bin/../share/openocd/scripts/target/xilinx_zynqmp.cfg", line 173
Then I looked at pmu and use below snipset which I use on xsdb to make it visible for debugger and also small waiting time.
@@ -141,6 +146,13 @@ add_help_text halt_pmu "Halt the PMU in preparation for loading new firmware.\ This should be matched with a call to resume_pmu." proc halt_pmu {} { set axi $::_CHIPNAME.axi + + puts "Enable PMU target" + set val [$axi read_memory 0xFFCA0038 32 1] + $axi write_memory 0xFFCA0038 32 [expr {$val | 0x1C0}] + sleep 5 + puts "PMU target should be enabled" + set val [$axi read_memory $::IPI_PMU_0_IER 32 1] $axi write_memory $::IPI_PMU_0_IER 32 [expr {$val | $::IPI_PMU_0}]
With that I am able to test your patch but it is kind of slow. Max freq I am able to use on zcu102 is 2MHz which is far from 15MHz used by xsdb.
After some time I am seeing
Error: Invalid ACK (4) in DAP response Polling target uscale.a53.0 failed, trying to reexamine Error: Invalid ACK (0) in DAP response Error: Could not initialize the APB-AP Examination failed, GDB will be halted. Polling again in 100ms Error: Invalid ACK (0) in DAP response Polling target uscale.a53.0 failed, trying to reexamine Error: Invalid ACK (0) in DAP response Error: Could not initialize the APB-AP Examination failed, GDB will be halted. Polling again in 300ms Error: Invalid ACK (0) in DAP response Polling target uscale.a53.0 failed, trying to reexamine Error: Invalid ACK (0) in DAP response Error: Could not initialize the APB-AP Examination failed, GDB will be halted. Polling again in 700ms Error: Invalid ACK (0) in DAP response
OpenOCD is far from stable but it does something.
Thanks, Michal
On 2/15/24 14:08, Michal Simek wrote: > > > On 2/15/24 18:19, Sean Anderson wrote: >> Currently, when we boot from JTAG we try to boot U-Boot from RAM. >> However, this is a bit tricky to time, since the debugger has to wait >> for SPL to initialize RAM before it can load U-Boot. This can result in >> long waits, since occasionally initializing RAM (and other things in >> psu_init) takes a long time to complete and the debugger must wait for >> this worst case. >> >> Support semihosting if it is enabled, as it lets U-Boot tell the >> debugger when we are ready for the image. This means we don't have to >> wait any more than necessary. We don't change the default config to >> ensure we don't break compatibility with existing debuggers that don't >> expect us to hit semihosting breakpoints. >> >> Signed-off-by: Sean Anderson sean.anderson@seco.com >> --- >> >> arch/arm/mach-zynqmp/spl.c | 10 ++++++++-- >> 1 file changed, 8 insertions(+), 2 deletions(-) >> >> diff --git a/arch/arm/mach-zynqmp/spl.c b/arch/arm/mach-zynqmp/spl.c >> index a0f35f36faa..5af735aa5ce 100644 >> --- a/arch/arm/mach-zynqmp/spl.c >> +++ b/arch/arm/mach-zynqmp/spl.c >> @@ -9,6 +9,7 @@ >> #include <image.h> >> #include <init.h> >> #include <log.h> >> +#include <semihosting.h> >> #include <spl.h> >> #include <linux/delay.h> >> >> @@ -66,6 +67,11 @@ void spl_board_init(void) >> } >> #endif >> >> +static u32 jtag_boot_device(void) >> +{ >> + return semihosting_enabled() ? BOOT_DEVICE_SMH : BOOT_DEVICE_RAM; >> +} >> + >> void board_boot_order(u32 *spl_boot_list) >> { >> spl_boot_list[0] = spl_boot_device(); >> @@ -75,7 +81,7 @@ void board_boot_order(u32 *spl_boot_list) >> if (spl_boot_list[0] == BOOT_DEVICE_MMC2) >> spl_boot_list[1] = BOOT_DEVICE_MMC1; >> >> - spl_boot_list[2] = BOOT_DEVICE_RAM; >> + spl_boot_list[2] = jtag_boot_device(); >> } >> >> u32 spl_boot_device(void) >> @@ -97,7 +103,7 @@ u32 spl_boot_device(void) >> >> switch (bootmode) { >> case JTAG_MODE: >> - return BOOT_DEVICE_RAM; >> + return jtag_boot_device(); >> #ifdef CONFIG_SPL_MMC >> case SD_MODE1: >> case SD1_LSHFT_MODE: /* not working on silicon v1 */ > > Good timing. Can you please tell me how to test this? What's the setup? > Which debugger are you using?
to be helpful.
which I invoke like
These should already be set. See table 39-3 in UG1085. Although I seem to have a combination of 39-2 and 39-3:
> targets uscale.axi > # BOOT_MODE_USER BOOT_MODE_POR > mdw 0xff5e0200 2 0xff5e0200: 00000000 00000000 > # jtag_chain_cfg jtag_chain_status jtag_sec jtag_dap_cfg > mdw 0xffca0030 4 0xffca0030: 00000000 00000003 0000003f 000000ff
Do you see these values in the JTAG boot mode?
sleep 5
Part of my goal here is to remove "magic" sleeps like this so the boot process goes faster.
puts "PMU target should be enabled"> set val [$axi read_memory $::IPI_PMU_0_IER 32 1] $axi write_memory $::IPI_PMU_0_IER 32 [expr {$val | $::IPI_PMU_0}]
I have been using the maximum 25 MHz speed without issue.
So this indicates the APU is either inaccessable or still in reset. To confirm, you get this after running boot_pmu and then boot_apu?
For reference I get
Open On-Chip Debugger 0.12.0 (2023-08-14-15:03) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'. boot Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi tdo_sample_edge falling" Info : clock speed 25000 kHz Info : JTAG tap: uscale.tap tap/device found: 0x5ba00477 (mfg: 0x23b (ARM Ltd), part: 0xba00, ver: 0x5) Info : JTAG tap: uscale.ps tap/device found: 0x04721093 (mfg: 0x049 (Xilinx), part: 0x4721, ver: 0x0) Info : JTAG tap: uscale.tap tap/device found: 0x5ba00477 (mfg: 0x23b (ARM Ltd), part: 0xba00, ver: 0x5) Info : JTAG tap: uscale.ps tap/device found: 0x04721093 (mfg: 0x049 (Xilinx), part: 0x4721, ver: 0x0) Info : starting gdb server for uscale.a53.0 on 3333 Info : Listening on port 3333 for gdb connections Info : gdb port disabled Info : Loading PMU firmware /path/to/pmu-firmware.bin to 0xffdc0000 Info : uscale.a53.0: hardware has 6 breakpoints, 4 watchpoints Info : uscale.a53.0 cluster 0 core 0 multi core uscale.a53.0 halted in AArch64 state due to debug-request, current mode: EL3H cpsr: 0x200002cd pc: 0xfffc64fc MMU: disabled, D-Cache: disabled, I-Cache: disabled Info : Loading APU0 firmware /path/to/u-boot-spl.bin to 0xfffc0000 semihosting base dir: /path/to/u-boot/
Info : Listening on port 6666 for tcl connections Info : Listening on port 4444 for telnet connections Info : accepting 'gdb' connection on tcp/3333
--Sean
On 2/15/24 20:31, Sean Anderson wrote: > On 2/15/24 14:08, Michal Simek wrote: >> >> >> On 2/15/24 18:19, Sean Anderson wrote: >>> Currently, when we boot from JTAG we try to boot U-Boot from RAM. >>> However, this is a bit tricky to time, since the debugger has to wait >>> for SPL to initialize RAM before it can load U-Boot. This can result in >>> long waits, since occasionally initializing RAM (and other things in >>> psu_init) takes a long time to complete and the debugger must wait for >>> this worst case. >>> >>> Support semihosting if it is enabled, as it lets U-Boot tell the >>> debugger when we are ready for the image. This means we don't have to >>> wait any more than necessary. We don't change the default config to >>> ensure we don't break compatibility with existing debuggers that don't >>> expect us to hit semihosting breakpoints. >>> >>> Signed-off-by: Sean Anderson sean.anderson@seco.com >>> --- >>> >>> arch/arm/mach-zynqmp/spl.c | 10 ++++++++-- >>> 1 file changed, 8 insertions(+), 2 deletions(-) >>> >>> diff --git a/arch/arm/mach-zynqmp/spl.c b/arch/arm/mach-zynqmp/spl.c >>> index a0f35f36faa..5af735aa5ce 100644 >>> --- a/arch/arm/mach-zynqmp/spl.c >>> +++ b/arch/arm/mach-zynqmp/spl.c >>> @@ -9,6 +9,7 @@ >>> #include <image.h> >>> #include <init.h> >>> #include <log.h> >>> +#include <semihosting.h> >>> #include <spl.h> >>> #include <linux/delay.h> >>> >>> @@ -66,6 +67,11 @@ void spl_board_init(void) >>> } >>> #endif >>> >>> +static u32 jtag_boot_device(void) >>> +{ >>> + return semihosting_enabled() ? BOOT_DEVICE_SMH : BOOT_DEVICE_RAM; >>> +} >>> + >>> void board_boot_order(u32 *spl_boot_list) >>> { >>> spl_boot_list[0] = spl_boot_device(); >>> @@ -75,7 +81,7 @@ void board_boot_order(u32 *spl_boot_list) >>> if (spl_boot_list[0] == BOOT_DEVICE_MMC2) >>> spl_boot_list[1] = BOOT_DEVICE_MMC1; >>> >>> - spl_boot_list[2] = BOOT_DEVICE_RAM; >>> + spl_boot_list[2] = jtag_boot_device(); >>> } >>> >>> u32 spl_boot_device(void) >>> @@ -97,7 +103,7 @@ u32 spl_boot_device(void) >>> >>> switch (bootmode) { >>> case JTAG_MODE: >>> - return BOOT_DEVICE_RAM; >>> + return jtag_boot_device(); >>> #ifdef CONFIG_SPL_MMC >>> case SD_MODE1: >>> case SD1_LSHFT_MODE: /* not working on silicon v1 */ >> >> Good timing. Can you please tell me how to test this? What's the setup? >> Which debugger are you using? > > I am using OpenOCD with the patches at https://cas5-0-urlprotect.trendmicro.com:443/wis/clicktime/v1/query?url=http... >
to be helpful.
which I invoke like
That 0x1c bit are "Setting these bits disables the security gate for the PMU MDM and allows the PS TAP to connect to the PMU. All bits must be set to 1 for the security gate to be released. (POR reset only)"
This is enabled to see PMU microblaze MDM. But I expect microblaze is not supported by OpenOCD but this makes it work for me.
sleep 5
I get it. 5s is likely too much and didn't try to minimalize.
Can you provide more details about board you use? I can switch to different cable or different board but based on your config you are also using digilent smt2 NC module (without USB on it) that's why it is quite scary that I am not able to run it at higher freq.
I will try different board or different cables. Do you know if standard xilinx cables are supported? This one https://www.xilinx.com/products/boards-and-kits/hw-usb-ii-g.html or black version?
Thanks, Michal
On 2/16/24 14:48, Michal Simek wrote: > > > On 2/15/24 20:31, Sean Anderson wrote: >> On 2/15/24 14:08, Michal Simek wrote: >>> >>> >>> On 2/15/24 18:19, Sean Anderson wrote: >>>> Currently, when we boot from JTAG we try to boot U-Boot from RAM. >>>> However, this is a bit tricky to time, since the debugger has to wait >>>> for SPL to initialize RAM before it can load U-Boot. This can result in >>>> long waits, since occasionally initializing RAM (and other things in >>>> psu_init) takes a long time to complete and the debugger must wait for >>>> this worst case. >>>> >>>> Support semihosting if it is enabled, as it lets U-Boot tell the >>>> debugger when we are ready for the image. This means we don't have to >>>> wait any more than necessary. We don't change the default config to >>>> ensure we don't break compatibility with existing debuggers that don't >>>> expect us to hit semihosting breakpoints. >>>> >>>> Signed-off-by: Sean Anderson sean.anderson@seco.com >>>> --- >>>> >>>> arch/arm/mach-zynqmp/spl.c | 10 ++++++++-- >>>> 1 file changed, 8 insertions(+), 2 deletions(-) >>>> >>>> diff --git a/arch/arm/mach-zynqmp/spl.c b/arch/arm/mach-zynqmp/spl.c >>>> index a0f35f36faa..5af735aa5ce 100644 >>>> --- a/arch/arm/mach-zynqmp/spl.c >>>> +++ b/arch/arm/mach-zynqmp/spl.c >>>> @@ -9,6 +9,7 @@ >>>> #include <image.h> >>>> #include <init.h> >>>> #include <log.h> >>>> +#include <semihosting.h> >>>> #include <spl.h> >>>> #include <linux/delay.h> >>>> >>>> @@ -66,6 +67,11 @@ void spl_board_init(void) >>>> } >>>> #endif >>>> >>>> +static u32 jtag_boot_device(void) >>>> +{ >>>> + return semihosting_enabled() ? BOOT_DEVICE_SMH : BOOT_DEVICE_RAM; >>>> +} >>>> + >>>> void board_boot_order(u32 *spl_boot_list) >>>> { >>>> spl_boot_list[0] = spl_boot_device(); >>>> @@ -75,7 +81,7 @@ void board_boot_order(u32 *spl_boot_list) >>>> if (spl_boot_list[0] == BOOT_DEVICE_MMC2) >>>> spl_boot_list[1] = BOOT_DEVICE_MMC1; >>>> >>>> - spl_boot_list[2] = BOOT_DEVICE_RAM; >>>> + spl_boot_list[2] = jtag_boot_device(); >>>> } >>>> >>>> u32 spl_boot_device(void) >>>> @@ -97,7 +103,7 @@ u32 spl_boot_device(void) >>>> >>>> switch (bootmode) { >>>> case JTAG_MODE: >>>> - return BOOT_DEVICE_RAM; >>>> + return jtag_boot_device(); >>>> #ifdef CONFIG_SPL_MMC >>>> case SD_MODE1: >>>> case SD1_LSHFT_MODE: /* not working on silicon v1 */ >>> >>> Good timing. Can you please tell me how to test this? What's the setup? >>> Which debugger are you using? >> >> I am using OpenOCD with the patches at https://cas5-0-urlprotect.trendmicro.com:443/wis/clicktime/v1/query?url=http... >> > > I am trying it on the top of the latest git but getting issue with event block and no idea how to fix it. > > # sudo openocd -f /usr/local/share/openocd/scripts/interface/ftdi/digilent_jtag_hs3.cfg -f /usr/local/share/openocd/scripts/target/xilinx_zynqmp.cfg > Open On-Chip Debugger 0.12.0+dev-01509-g6d288937cb2d (2024-02-16-12:22) > Licensed under GNU GPL v2 > For bug reports, read > https://cas5-0-urlprotect.trendmicro.com:443/wis/clicktime/v1/query?url=http... > Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'. > wrong # args: should be "-event <event-name> <event-body>" > > > Do you know how to fix it?
to be helpful.
which I invoke like
Yes, I know why you set these bits. But they should all be set already (see e.g. my output above). So I am curious if they are not set for you. If you have different values for the above registers, then there is likely something different about your setup which could also cause your below error.
sleep 5
It's a custom design based on [1]. The carrier has a smt2 module on it which is connected to the ZynqMP via the card edge connector.
Regarding the clock speed, the datasheet for the smt2 [2] module says the maximum speed is 30 MHz, but I use 25 MHz since DS925 says that is the maximum speed for the ZynqMP (table 40). Maybe you are using a lower VCCINT?
I will try different board or different cables. Do you know if standard xilinx cables are supported? This one https://cas5-0-urlprotect.trendmicro.com:443/wis/clicktime/v1/query?url=http... or black version?
I have not tried those cables (nor do I have them on hand). I have used the smt2 as well as the hs3 dongle. I also have a J-LINK, but I do not have an adapter cable made.
--Sean
[1] https://edge.seco.com/usa/som-smarc-zu.html [2] https://digilent.com/reference/_media/programmers/jtag-smt2-nc/jtag-smt2-nc_...
On 2/16/24 10:06, Michal Simek wrote: > > > On 2/16/24 14:48, Michal Simek wrote: >> >> >> On 2/15/24 20:31, Sean Anderson wrote: >>> On 2/15/24 14:08, Michal Simek wrote: >>>> >>>> >>>> On 2/15/24 18:19, Sean Anderson wrote: >>>>> Currently, when we boot from JTAG we try to boot U-Boot from RAM. >>>>> However, this is a bit tricky to time, since the debugger has to wait >>>>> for SPL to initialize RAM before it can load U-Boot. This can result in >>>>> long waits, since occasionally initializing RAM (and other things in >>>>> psu_init) takes a long time to complete and the debugger must wait for >>>>> this worst case. >>>>> >>>>> Support semihosting if it is enabled, as it lets U-Boot tell the >>>>> debugger when we are ready for the image. This means we don't have to >>>>> wait any more than necessary. We don't change the default config to >>>>> ensure we don't break compatibility with existing debuggers that don't >>>>> expect us to hit semihosting breakpoints. >>>>> >>>>> Signed-off-by: Sean Anderson sean.anderson@seco.com >>>>> --- >>>>> >>>>> arch/arm/mach-zynqmp/spl.c | 10 ++++++++-- >>>>> 1 file changed, 8 insertions(+), 2 deletions(-) >>>>> >>>>> diff --git a/arch/arm/mach-zynqmp/spl.c b/arch/arm/mach-zynqmp/spl.c >>>>> index a0f35f36faa..5af735aa5ce 100644 >>>>> --- a/arch/arm/mach-zynqmp/spl.c >>>>> +++ b/arch/arm/mach-zynqmp/spl.c >>>>> @@ -9,6 +9,7 @@ >>>>> #include <image.h> >>>>> #include <init.h> >>>>> #include <log.h> >>>>> +#include <semihosting.h> >>>>> #include <spl.h> >>>>> #include <linux/delay.h> >>>>> >>>>> @@ -66,6 +67,11 @@ void spl_board_init(void) >>>>> } >>>>> #endif >>>>> >>>>> +static u32 jtag_boot_device(void) >>>>> +{ >>>>> + return semihosting_enabled() ? BOOT_DEVICE_SMH : BOOT_DEVICE_RAM; >>>>> +} >>>>> + >>>>> void board_boot_order(u32 *spl_boot_list) >>>>> { >>>>> spl_boot_list[0] = spl_boot_device(); >>>>> @@ -75,7 +81,7 @@ void board_boot_order(u32 *spl_boot_list) >>>>> if (spl_boot_list[0] == BOOT_DEVICE_MMC2) >>>>> spl_boot_list[1] = BOOT_DEVICE_MMC1; >>>>> >>>>> - spl_boot_list[2] = BOOT_DEVICE_RAM; >>>>> + spl_boot_list[2] = jtag_boot_device(); >>>>> } >>>>> >>>>> u32 spl_boot_device(void) >>>>> @@ -97,7 +103,7 @@ u32 spl_boot_device(void) >>>>> >>>>> switch (bootmode) { >>>>> case JTAG_MODE: >>>>> - return BOOT_DEVICE_RAM; >>>>> + return jtag_boot_device(); >>>>> #ifdef CONFIG_SPL_MMC >>>>> case SD_MODE1: >>>>> case SD1_LSHFT_MODE: /* not working on silicon v1 */ >>>> >>>> Good timing. Can you please tell me how to test this? What's the setup? >>>> Which debugger are you using? >>> >>> I am using OpenOCD with the patches at https://cas5-0-urlprotect.trendmicro.com:443/wis/clicktime/v1/query?url=http... >>> >> >> I am trying it on the top of the latest git but getting issue with event block and no idea how to fix it. >> >> # sudo openocd -f /usr/local/share/openocd/scripts/interface/ftdi/digilent_jtag_hs3.cfg -f /usr/local/share/openocd/scripts/target/xilinx_zynqmp.cfg >> Open On-Chip Debugger 0.12.0+dev-01509-g6d288937cb2d (2024-02-16-12:22) >> Licensed under GNU GPL v2 >> For bug reports, read >> https://cas5-0-urlprotect.trendmicro.com:443/wis/clicktime/v1/query?url=http... >> Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'. >> wrong # args: should be "-event <event-name> <event-body>" >> >> >> Do you know how to fix it? > > > I actually bisect it and found that it is caused by > jtag: rewrite jim_jtag_configure() as COMMAND_HANDLER > ea2e26f7d521f5755b4bfda7bf12d99650277421
> Open On-Chip Debugger 0.12.0+dev-01512-g214206ebb972 (2024-02-16-15:38) > Licensed under GNU GPL v2 > For bug reports, read > https://cas5-0-urlprotect.trendmicro.com:443/wis/clicktime/v1/query?url=http... > none separate > Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'. > Info : Hardware thread awareness created > boot_apu > Info : Listening on port 6666 for tcl connections > Info : Listening on port 4444 for telnet connections > Warn : An adapter speed is not selected in the init scripts. OpenOCD will try to run the adapter at very low speed (100 kHz). > Warn : To remove this warnings and achieve reasonable communication speed with the target, set "adapter speed" or "jtag_rclk" in the init scripts. > Info : clock speed 100 kHz > Info : TAP uscale.tap does not have valid IDCODE (idcode=0x48e70126) > Info : JTAG tap: uscale.ps tap/device found: 0x24738093 (mfg: 0x049 (Xilinx), part: 0x4738, ver: 0x2) > Info : JTAG tap: uscale.tap tap/device found: 0x5ba00477 (mfg: 0x23b (ARM Ltd), part: 0xba00, ver: 0x5) > Info : JTAG tap: uscale.ps tap/device found: 0x24738093 (mfg: 0x049 (Xilinx), part: 0x4738, ver: 0x2) > Error: JTAG-DP STICKY ERROR > Error: [uscale.a53.0] Examination failed > Warn : target uscale.a53.0 examination failed > Info : [uscale.axi] Examination succeed > Info : starting gdb server for uscale.a53.0 on 3333 > Info : Listening on port 3333 for gdb connections > Info : gdb port disabled > > but with zcu102 I am still not able to connect because error above. > The same behavior with recording SOM IDs I see on kv260 (via hs3 cable). > It looks like that not everything is working for zynqmp.
to be helpful.
which I invoke like
I tried on different zcu102 rev1.0 and I need to have it there.
sleep 5
I have seen it working at 25MHz once but it is not stable with the same digilent module.
Anyway please fix typo in subject and rebase it on the top of current master branch because it can't be applied and patch is ready to be merged.
Thanks, Michal
On 2/16/24 11:03, Sean Anderson wrote: > On 2/16/24 10:06, Michal Simek wrote: >> >> >> On 2/16/24 14:48, Michal Simek wrote: >>> >>> >>> On 2/15/24 20:31, Sean Anderson wrote: >>>> On 2/15/24 14:08, Michal Simek wrote: >>>>> >>>>> >>>>> On 2/15/24 18:19, Sean Anderson wrote: >>>>>> Currently, when we boot from JTAG we try to boot U-Boot from RAM. >>>>>> However, this is a bit tricky to time, since the debugger has to wait >>>>>> for SPL to initialize RAM before it can load U-Boot. This can result in >>>>>> long waits, since occasionally initializing RAM (and other things in >>>>>> psu_init) takes a long time to complete and the debugger must wait for >>>>>> this worst case. >>>>>> >>>>>> Support semihosting if it is enabled, as it lets U-Boot tell the >>>>>> debugger when we are ready for the image. This means we don't have to >>>>>> wait any more than necessary. We don't change the default config to >>>>>> ensure we don't break compatibility with existing debuggers that don't >>>>>> expect us to hit semihosting breakpoints. >>>>>> >>>>>> Signed-off-by: Sean Anderson sean.anderson@seco.com >>>>>> --- >>>>>> >>>>>> arch/arm/mach-zynqmp/spl.c | 10 ++++++++-- >>>>>> 1 file changed, 8 insertions(+), 2 deletions(-) >>>>>> >>>>>> diff --git a/arch/arm/mach-zynqmp/spl.c b/arch/arm/mach-zynqmp/spl.c >>>>>> index a0f35f36faa..5af735aa5ce 100644 >>>>>> --- a/arch/arm/mach-zynqmp/spl.c >>>>>> +++ b/arch/arm/mach-zynqmp/spl.c >>>>>> @@ -9,6 +9,7 @@ >>>>>> #include <image.h> >>>>>> #include <init.h> >>>>>> #include <log.h> >>>>>> +#include <semihosting.h> >>>>>> #include <spl.h> >>>>>> #include <linux/delay.h> >>>>>> >>>>>> @@ -66,6 +67,11 @@ void spl_board_init(void) >>>>>> } >>>>>> #endif >>>>>> >>>>>> +static u32 jtag_boot_device(void) >>>>>> +{ >>>>>> + return semihosting_enabled() ? BOOT_DEVICE_SMH : BOOT_DEVICE_RAM; >>>>>> +} >>>>>> + >>>>>> void board_boot_order(u32 *spl_boot_list) >>>>>> { >>>>>> spl_boot_list[0] = spl_boot_device(); >>>>>> @@ -75,7 +81,7 @@ void board_boot_order(u32 *spl_boot_list) >>>>>> if (spl_boot_list[0] == BOOT_DEVICE_MMC2) >>>>>> spl_boot_list[1] = BOOT_DEVICE_MMC1; >>>>>> >>>>>> - spl_boot_list[2] = BOOT_DEVICE_RAM; >>>>>> + spl_boot_list[2] = jtag_boot_device(); >>>>>> } >>>>>> >>>>>> u32 spl_boot_device(void) >>>>>> @@ -97,7 +103,7 @@ u32 spl_boot_device(void) >>>>>> >>>>>> switch (bootmode) { >>>>>> case JTAG_MODE: >>>>>> - return BOOT_DEVICE_RAM; >>>>>> + return jtag_boot_device(); >>>>>> #ifdef CONFIG_SPL_MMC >>>>>> case SD_MODE1: >>>>>> case SD1_LSHFT_MODE: /* not working on silicon v1 */ >>>>> >>>>> Good timing. Can you please tell me how to test this? What's the setup? >>>>> Which debugger are you using? >>>> >>>> I am using OpenOCD with the patches at https://cas5-0-urlprotect.trendmicro.com:443/wis/clicktime/v1/query?url=http... >>>> >>> >>> I am trying it on the top of the latest git but getting issue with event block and no idea how to fix it. >>> >>> # sudo openocd -f /usr/local/share/openocd/scripts/interface/ftdi/digilent_jtag_hs3.cfg -f /usr/local/share/openocd/scripts/target/xilinx_zynqmp.cfg >>> Open On-Chip Debugger 0.12.0+dev-01509-g6d288937cb2d (2024-02-16-12:22) >>> Licensed under GNU GPL v2 >>> For bug reports, read >>> https://cas5-0-urlprotect.trendmicro.com:443/wis/clicktime/v1/query?url=http... >>> Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'. >>> wrong # args: should be "-event <event-name> <event-body>" >>> >>> >>> Do you know how to fix it? >> >> >> I actually bisect it and found that it is caused by >> jtag: rewrite jim_jtag_configure() as COMMAND_HANDLER >> ea2e26f7d521f5755b4bfda7bf12d99650277421 > > Interesting. I have been testing with 0.12. > >> # sudo openocd -f /usr/local/share/openocd/scripts/interface/ftdi/digilent_jtag_smt2_nc.cfg -f /usr/local/share/openocd/scripts/target/xilinx_zynqmp.cfg > > FWIW after installing the udev rules I do not need sudo > >> Open On-Chip Debugger 0.12.0+dev-01512-g214206ebb972 (2024-02-16-15:38) >> Licensed under GNU GPL v2 >> For bug reports, read >> https://cas5-0-urlprotect.trendmicro.com:443/wis/clicktime/v1/query?url=http... >> none separate >> Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'. >> Info : Hardware thread awareness created >> boot_apu >> Info : Listening on port 6666 for tcl connections >> Info : Listening on port 4444 for telnet connections >> Warn : An adapter speed is not selected in the init scripts. OpenOCD will try to run the adapter at very low speed (100 kHz). >> Warn : To remove this warnings and achieve reasonable communication speed with the target, set "adapter speed" or "jtag_rclk" in the init scripts. >> Info : clock speed 100 kHz >> Info : TAP uscale.tap does not have valid IDCODE (idcode=0x48e70126) >> Info : JTAG tap: uscale.ps tap/device found: 0x24738093 (mfg: 0x049 (Xilinx), part: 0x4738, ver: 0x2) >> Info : JTAG tap: uscale.tap tap/device found: 0x5ba00477 (mfg: 0x23b (ARM Ltd), part: 0xba00, ver: 0x5) >> Info : JTAG tap: uscale.ps tap/device found: 0x24738093 (mfg: 0x049 (Xilinx), part: 0x4738, ver: 0x2) >> Error: JTAG-DP STICKY ERROR >> Error: [uscale.a53.0] Examination failed >> Warn : target uscale.a53.0 examination failed >> Info : [uscale.axi] Examination succeed >> Info : starting gdb server for uscale.a53.0 on 3333 >> Info : Listening on port 3333 for gdb connections >> Info : gdb port disabled >> >> but with zcu102 I am still not able to connect because error above. >> The same behavior with recording SOM IDs I see on kv260 (via hs3 cable). >> It looks like that not everything is working for zynqmp. > > Is this with the boot mode set to JTAG? If so, you will not be able to > examine any of the CPUs until you have released them from reset. So you > should be able to run > > targets uscale.axi > boot_pmu /path/to/pmu-firmware.bin > boot_apu /path/to/u-boot-spl.bin > > to boot a CPU. If you want to silence the above error, you can add > > uscale.a53.0 configure -defer-examine > > to your config. So the full command would be > > $ openocd -f interface/ftdi/digilent_jtag_smt2_nc.cfg \ > -f target/xilinx_zynqmp.cfg \ > -c 'uscale.a53.o configure -defer-examine' \ > -c init -c 'targets uscale.axi' \ > -c 'boot_pmu /path/to/pmu-firmware.bin' \ > -c 'boot_apu /path/to/boot.bin' > > Let me know if that works for you.
to be helpful.
which I invoke like
Hm, maybe you can try https://review.openocd.org/c/openocd/+/5578
It has a different approach for this sort of thing.
sleep 5
https://lore.kernel.org/u-boot/20240222165230.2600974-1-sean.anderson@linux....
--Sean
Michal Simek
Sean Anderson
