[U-Boot] [PATCH V2 1/8] led: add initial support for bcm6858
The driver add the support of the led IP on bcm6858. This led IP can drive up to 32 leds, and can handle blinking.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- Changelog: v2: - use const for array bcm6858_flash_rate (thanks Daniel) - use int for array bcm6858_flash_rate (thanks Daniel)
doc/device-tree-bindings/leds/leds-bcm6858.txt | 51 +++++ drivers/led/Kconfig | 7 + drivers/led/Makefile | 1 + drivers/led/led_bcm6858.c | 250 +++++++++++++++++++++++++ 4 files changed, 309 insertions(+) create mode 100644 doc/device-tree-bindings/leds/leds-bcm6858.txt create mode 100644 drivers/led/led_bcm6858.c
diff --git a/doc/device-tree-bindings/leds/leds-bcm6858.txt b/doc/device-tree-bindings/leds/leds-bcm6858.txt new file mode 100644 index 0000000..ea2fe23 --- /dev/null +++ b/doc/device-tree-bindings/leds/leds-bcm6858.txt @@ -0,0 +1,51 @@ +LEDs connected to Broadcom BCM6858 controller + +This controller is present on BCM6858, BCM6328, BCM6362 and BCM63268. +In these SoCs it's possible to control LEDs both as GPIOs or by hardware. + +Required properties: + - compatible : should be "brcm,bcm6858-leds". + - #address-cells : must be 1. + - #size-cells : must be 0. + - reg : BCM6858 LED controller address and size. + +Optional properties: + - brcm,serial-led-msb-first : Boolean, msb data come out first on serial data pin + Default : false + - brcm,serial-led-en-pol : Boolean, serial led polarity (true => active high) + Default : false + - brcm,serial-led-clk-pol : Boolean, serial clock polarity (true => active high) + Default : false + - brcm,serial-led-data-ppol : Boolean, serial data polarity (true => active high) + Default : false + - brcm,serial-shift-inv : Boolean, led test mode + Default : false + +Each LED is represented as a sub-node of the brcm,bcm6858-leds device. + +LED sub-node required properties: + - reg : LED pin number (only LEDs 0 to 32 are valid). + +LED sub-node optional properties: + - label : see Documentation/devicetree/bindings/leds/common.txt + - active-low : Boolean, makes LED active low. + Default : false + +Examples: +BCM6328 with 2 GPIO LEDs + leds0: led-controller@ff800800 { + compatible = "brcm,bcm6858-leds"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0xff800800 0x0 0xe4>; + + led@2 { + reg = <2>; + label = "green:inet"; + }; + + led@5 { + reg = <5>; + label = "red:alarm"; + }; + }; diff --git a/drivers/led/Kconfig b/drivers/led/Kconfig index 5da5c4a..4c8582d 100644 --- a/drivers/led/Kconfig +++ b/drivers/led/Kconfig @@ -28,6 +28,13 @@ config LED_BCM6358 LED HW controller accessed via MMIO registers. HW has no blinking capabilities and up to 32 LEDs can be controlled.
+config LED_BCM6858 + bool "LED Support for BCM6858" + depends on LED && ARCH_BCM6858 + help + This option enables support for LEDs connected to the BCM6858 + HW has blinking capabilities and up to 32 LEDs can be controlled. + config LED_BLINK bool "Support LED blinking" depends on LED diff --git a/drivers/led/Makefile b/drivers/led/Makefile index 160a8f3..3654dd3 100644 --- a/drivers/led/Makefile +++ b/drivers/led/Makefile @@ -6,4 +6,5 @@ obj-y += led-uclass.o obj-$(CONFIG_LED_BCM6328) += led_bcm6328.o obj-$(CONFIG_LED_BCM6358) += led_bcm6358.o +obj-$(CONFIG_LED_BCM6858) += led_bcm6858.o obj-$(CONFIG_$(SPL_)LED_GPIO) += led_gpio.o diff --git a/drivers/led/led_bcm6858.c b/drivers/led/led_bcm6858.c new file mode 100644 index 0000000..27a76fc --- /dev/null +++ b/drivers/led/led_bcm6858.c @@ -0,0 +1,250 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Philippe Reynes philippe.reynes@softathome.com + * + * based on: + * drivers/led/led_bcm6328.c + * drivers/led/led_bcm6358.c + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <led.h> +#include <asm/io.h> +#include <dm/lists.h> + +#define LEDS_MAX 32 +#define LEDS_WAIT 100 + +/* LED Mode register */ +#define LED_MODE_REG 0x0 +#define LED_MODE_OFF 0 +#define LED_MODE_ON 1 +#define LED_MODE_MASK 1 + +/* LED Controller Global settings register */ +#define LED_CTRL_REG 0x00 +#define LED_CTRL_MASK 0x1f +#define LED_CTRL_LED_TEST_MODE BIT(0) +#define LED_CTRL_SERIAL_LED_DATA_PPOL BIT(1) +#define LED_CTRL_SERIAL_LED_CLK_POL BIT(2) +#define LED_CTRL_SERIAL_LED_EN_POL BIT(3) +#define LED_CTRL_SERIAL_LED_MSB_FIRST BIT(4) + +/* LED Controller IP LED source select register */ +#define LED_HW_LED_EN_REG 0x08 +/* LED Flash control register0 */ +#define LED_FLASH_RATE_CONTROL_REG0 0x10 +/* Soft LED input register */ +#define LED_SW_LED_IP_REG 0xb8 +/* Soft LED input polarity register */ +#define LED_SW_LED_IP_PPOL_REG 0xbc + +struct bcm6858_led_priv { + void __iomem *regs; + u8 pin; +}; + +#ifdef CONFIG_LED_BLINK +/* + * The value for flash rate are: + * 0 : no blinking + * 1 : rate is 25 Hz => 40 ms (period) + * 2 : rate is 12.5 Hz => 80 ms (period) + * 3 : rate is 6.25 Hz => 160 ms (period) + * 4 : rate is 3.125 Hz => 320 ms (period) + * 5 : rate is 1.5625 Hz => 640 ms (period) + * 6 : rate is 0.7815 Hz => 1280 ms (period) + * 7 : rate is 0.390625 Hz => 2560 ms (period) + */ +static const int bcm6858_flash_rate[8] = { + 0, 40, 80, 160, 320, 640, 1280, 2560 +}; + +static u32 bcm6858_flash_rate_value(int period_ms) +{ + unsigned long value = 7; + int i; + + for (i = 0; i < ARRAY_SIZE(bcm6858_flash_rate); i++) { + if (period_ms <= bcm6858_flash_rate[i]) { + value = i; + break; + } + } + + return value; +} + +static int bcm6858_led_set_period(struct udevice *dev, int period_ms) +{ + struct bcm6858_led_priv *priv = dev_get_priv(dev); + u32 offset, shift, mask, value; + + offset = (priv->pin / 8) * 4; + shift = (priv->pin % 8) * 4; + mask = 0x7 << shift; + value = bcm6858_flash_rate_value(period_ms) << shift; + + clrbits_32(priv->regs + LED_FLASH_RATE_CONTROL_REG0 + offset, mask); + setbits_32(priv->regs + LED_FLASH_RATE_CONTROL_REG0 + offset, value); + + return 0; +} +#endif + +static enum led_state_t bcm6858_led_get_state(struct udevice *dev) +{ + struct bcm6858_led_priv *priv = dev_get_priv(dev); + enum led_state_t state = LEDST_OFF; + u32 sw_led_ip; + + sw_led_ip = readl(priv->regs + LED_SW_LED_IP_REG); + if (sw_led_ip & (1 << priv->pin)) + state = LEDST_ON; + + return state; +} + +static int bcm6858_led_set_state(struct udevice *dev, enum led_state_t state) +{ + struct bcm6858_led_priv *priv = dev_get_priv(dev); + + switch (state) { + case LEDST_OFF: + clrbits_32(priv->regs + LED_SW_LED_IP_REG, (1 << priv->pin)); +#ifdef CONFIG_LED_BLINK + bcm6858_led_set_period(dev, 0); +#endif + break; + case LEDST_ON: + setbits_32(priv->regs + LED_SW_LED_IP_REG, (1 << priv->pin)); +#ifdef CONFIG_LED_BLINK + bcm6858_led_set_period(dev, 0); +#endif + break; + case LEDST_TOGGLE: + if (bcm6858_led_get_state(dev) == LEDST_OFF) + return bcm6858_led_set_state(dev, LEDST_ON); + else + return bcm6858_led_set_state(dev, LEDST_OFF); + break; +#ifdef CONFIG_LED_BLINK + case LEDST_BLINK: + setbits_32(priv->regs + LED_SW_LED_IP_REG, (1 << priv->pin)); + break; +#endif + default: + return -EINVAL; + } + + return 0; +} + +static const struct led_ops bcm6858_led_ops = { + .get_state = bcm6858_led_get_state, + .set_state = bcm6858_led_set_state, +#ifdef CONFIG_LED_BLINK + .set_period = bcm6858_led_set_period, +#endif +}; + +static int bcm6858_led_probe(struct udevice *dev) +{ + struct led_uc_plat *uc_plat = dev_get_uclass_platdata(dev); + + /* Top-level LED node */ + if (!uc_plat->label) { + void __iomem *regs; + u32 set_bits = 0; + + regs = dev_remap_addr(dev); + if (!regs) + return -EINVAL; + + if (dev_read_bool(dev, "brcm,serial-led-msb-first")) + set_bits |= LED_CTRL_SERIAL_LED_MSB_FIRST; + if (dev_read_bool(dev, "brcm,serial-led-en-pol")) + set_bits |= LED_CTRL_SERIAL_LED_EN_POL; + if (dev_read_bool(dev, "brcm,serial-led-clk-pol")) + set_bits |= LED_CTRL_SERIAL_LED_CLK_POL; + if (dev_read_bool(dev, "brcm,serial-led-data-ppol")) + set_bits |= LED_CTRL_SERIAL_LED_DATA_PPOL; + if (dev_read_bool(dev, "brcm,led-test-mode")) + set_bits |= LED_CTRL_LED_TEST_MODE; + + clrsetbits_32(regs + LED_CTRL_REG, ~0, set_bits); + } else { + struct bcm6858_led_priv *priv = dev_get_priv(dev); + void __iomem *regs; + unsigned int pin; + + regs = dev_remap_addr(dev_get_parent(dev)); + if (!regs) + return -EINVAL; + + pin = dev_read_u32_default(dev, "reg", LEDS_MAX); + if (pin >= LEDS_MAX) + return -EINVAL; + + priv->regs = regs; + priv->pin = pin; + + /* this led is managed by software */ + clrbits_32(regs + LED_HW_LED_EN_REG, 1 << pin); + + /* configure the polarity */ + if (dev_read_bool(dev, "active-low")) + clrbits_32(regs + LED_SW_LED_IP_PPOL_REG, 1 << pin); + else + setbits_32(regs + LED_SW_LED_IP_PPOL_REG, 1 << pin); + } + + return 0; +} + +static int bcm6858_led_bind(struct udevice *parent) +{ + ofnode node; + + dev_for_each_subnode(node, parent) { + struct led_uc_plat *uc_plat; + struct udevice *dev; + const char *label; + int ret; + + label = ofnode_read_string(node, "label"); + if (!label) { + debug("%s: node %s has no label\n", __func__, + ofnode_get_name(node)); + return -EINVAL; + } + + ret = device_bind_driver_to_node(parent, "bcm6858-led", + ofnode_get_name(node), + node, &dev); + if (ret) + return ret; + + uc_plat = dev_get_uclass_platdata(dev); + uc_plat->label = label; + } + + return 0; +} + +static const struct udevice_id bcm6858_led_ids[] = { + { .compatible = "brcm,bcm6858-leds" }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(bcm6858_led) = { + .name = "bcm6858-led", + .id = UCLASS_LED, + .of_match = bcm6858_led_ids, + .bind = bcm6858_led_bind, + .probe = bcm6858_led_probe, + .priv_auto_alloc_size = sizeof(struct bcm6858_led_priv), + .ops = &bcm6858_led_ops, +};
Add the led controller in the bcm6858 device tree.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- Changelog: v2: - no change
arch/arm/dts/bcm6858.dtsi | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/dts/bcm6858.dtsi b/arch/arm/dts/bcm6858.dtsi index 23b80c6..0359417 100644 --- a/arch/arm/dts/bcm6858.dtsi +++ b/arch/arm/dts/bcm6858.dtsi @@ -82,6 +82,13 @@ status = "disabled"; };
+ leds: led-controller@ff800800 { + compatible = "brcm,bcm6858-leds"; + reg = <0x0 0xff800800 0x0 0xe4>; + + status = "disabled"; + }; + wdt1: watchdog@ff802780 { compatible = "brcm,bcm6345-wdt"; reg = <0x0 0xff802780 0x0 0x14>;
Enable the led controller in the device tree of the board bcm968580xref.
arch/arm/dts/bcm968580xref.dts | 48 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+)
diff --git a/arch/arm/dts/bcm968580xref.dts b/arch/arm/dts/bcm968580xref.dts index 0c59f94..c11246a 100644 --- a/arch/arm/dts/bcm968580xref.dts +++ b/arch/arm/dts/bcm968580xref.dts @@ -29,3 +29,51 @@ u-boot,dm-pre-reloc; status = "okay"; }; + +&leds { + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + brcm,serial-led-en-pol; + brcm,serial-led-data-ppol; + + led@2 { + reg = <2>; + label = "green:inet"; + }; + + led@5 { + reg = <5>; + label = "red:alarm"; + }; + + led@8 { + reg = <8>; + label = "green:wlan_link"; + }; + + led@11 { + reg = <11>; + label = "green:fxs1"; + }; + + led@14 { + reg = <14>; + label = "green:fxs2"; + }; + + led@15 { + reg = <15>; + label = "green:usb0"; + }; + + led@16 { + reg = <16>; + label = "green:usb1"; + }; + + led@17 { + reg = <17>; + label = "green:wps"; + }; +};
Enable the led support in the configuration of the board bcm968580xref.
configs/bcm968580xref_ram_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/bcm968580xref_ram_defconfig b/configs/bcm968580xref_ram_defconfig index e8cb3a0..887ccb8 100644 --- a/configs/bcm968580xref_ram_defconfig +++ b/configs/bcm968580xref_ram_defconfig @@ -22,6 +22,9 @@ CONFIG_DEFAULT_DEVICE_TREE="bcm968580xref" # CONFIG_NET is not set CONFIG_BLK=y CONFIG_CLK=y +CONFIG_LED=y +CONFIG_LED_BCM6858=y +CONFIG_LED_BLINK=y # CONFIG_MMC is not set CONFIG_SPECIFY_CONSOLE_INDEX=y # CONFIG_SPL_SERIAL_PRESENT is not set
Allow the led bcm6858 driver to be used on bcm63158. They have the same led controller.
drivers/led/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/led/Kconfig b/drivers/led/Kconfig index 4c8582d..5643939 100644 --- a/drivers/led/Kconfig +++ b/drivers/led/Kconfig @@ -30,7 +30,7 @@ config LED_BCM6358
config LED_BCM6858 bool "LED Support for BCM6858" - depends on LED && ARCH_BCM6858 + depends on LED && (ARCH_BCM6858 || ARCH_BCM63158) help This option enables support for LEDs connected to the BCM6858 HW has blinking capabilities and up to 32 LEDs can be controlled.
Add the led controller in the bcm63158 device tree.
arch/arm/dts/bcm63158.dtsi | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/dts/bcm63158.dtsi b/arch/arm/dts/bcm63158.dtsi index 6a3fbc9..0967a3d 100644 --- a/arch/arm/dts/bcm63158.dtsi +++ b/arch/arm/dts/bcm63158.dtsi @@ -82,6 +82,13 @@ status = "disabled"; };
+ leds: led-controller@ff800800 { + compatible = "brcm,bcm6858-leds"; + reg = <0x0 0xff800800 0x0 0xe4>; + + status = "disabled"; + }; + wdt1: watchdog@ff800480 { compatible = "brcm,bcm6345-wdt"; reg = <0x0 0xff800480 0x0 0x14>;
Enable the led controller in the device tree of the board bcm963158.
arch/arm/dts/bcm963158.dts | 49 ++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 49 insertions(+)
diff --git a/arch/arm/dts/bcm963158.dts b/arch/arm/dts/bcm963158.dts index dc5afb5..15e87de 100644 --- a/arch/arm/dts/bcm963158.dts +++ b/arch/arm/dts/bcm963158.dts @@ -29,3 +29,52 @@ u-boot,dm-pre-reloc; status = "okay"; }; + +&leds { + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + brcm,serial-led-en-pol; + brcm,serial-led-data-ppol; + + led@16 { + reg = <16>; + label = "red:dsl2"; + }; + + led@17 { + reg = <17>; + label = "green:dsl1"; + }; + + led@18 { + reg = <18>; + label = "green:fxs2"; + }; + + led@19 { + reg = <19>; + label = "green:fxs1"; + }; + + led@26 { + reg = <26>; + label = "green:wan1_act"; + }; + + led@27 { + reg = <27>; + label = "green:wps"; + }; + + led@28 { + reg = <28>; + active-low; + label = "green:aggregate_act"; + }; + + led@29 { + reg = <29>; + label = "green:aggregate_link"; + }; +};
Enable the led support in the configuration of the board bcm963158.
configs/bcm963158_ram_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/bcm963158_ram_defconfig b/configs/bcm963158_ram_defconfig index fc55e98..c93a8f6 100644 --- a/configs/bcm963158_ram_defconfig +++ b/configs/bcm963158_ram_defconfig @@ -28,6 +28,9 @@ CONFIG_DEFAULT_DEVICE_TREE="bcm963158" # CONFIG_NET is not set CONFIG_BLK=y CONFIG_CLK=y +CONFIG_LED=y +CONFIG_LED_BCM6858=y +CONFIG_LED_BLINK=y # CONFIG_MMC is not set CONFIG_SPECIFY_CONSOLE_INDEX=y # CONFIG_SPL_SERIAL_PRESENT is not set
Am 22.03.19 um 17:02 schrieb Philippe Reynes:
Changelog: v2:
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
Daniel Schwierzeck
Philippe Reynes
