[U-Boot] [PATCH v1] cpu: Add Intel Tangier support
Add Intel Tangier SoC support.
Intel Tangier SoC is a core part of Intel Merrifield platform. For example, Intel Edison board is based on such platform.
The patch is based on work done by the following people (in alphabetical order): Aiden Park aiden.park@intel.com Dukjoon Jeon dukjoon.jeon@intel.com eric.park eric.park@intel.com Fabien Chereau fabien.chereau@intel.com Scott D Phillips scott.d.phillips@intel.com Sebastien Colleur sebastienx.colleur@intel.com Steve Sakoman steve.sakoman@intel.com Vincent Tinelli vincent.tinelli@intel.com
Signed-off-by: Vincent Tinelli vincent.tinelli@intel.com Signed-off-by: Felipe Balbi felipe.balbi@linux.intel.com Signed-off-by: Andy Shevchenko andriy.shevchenko@linux.intel.com --- arch/x86/Kconfig | 1 + arch/x86/cpu/Makefile | 1 + arch/x86/cpu/tangier/Kconfig | 20 ++++ arch/x86/cpu/tangier/Makefile | 1 + arch/x86/cpu/tangier/car.S | 13 +++ arch/x86/cpu/tangier/sdram.c | 234 +++++++++++++++++++++++++++++++++++++ arch/x86/cpu/tangier/tangier.c | 36 ++++++ arch/x86/include/asm/dma-mapping.h | 41 +++++++ 8 files changed, 347 insertions(+) create mode 100644 arch/x86/cpu/tangier/Kconfig create mode 100644 arch/x86/cpu/tangier/Makefile create mode 100644 arch/x86/cpu/tangier/car.S create mode 100644 arch/x86/cpu/tangier/sdram.c create mode 100644 arch/x86/cpu/tangier/tangier.c create mode 100644 arch/x86/include/asm/dma-mapping.h
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 9ead3ebccf..31f2d154d4 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -114,6 +114,7 @@ source "arch/x86/cpu/ivybridge/Kconfig" source "arch/x86/cpu/qemu/Kconfig" source "arch/x86/cpu/quark/Kconfig" source "arch/x86/cpu/queensbay/Kconfig" +source "arch/x86/cpu/tangier/Kconfig"
# architecture-specific options below
diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index 92a9023b0b..6f3535d216 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -34,6 +34,7 @@ obj-$(CONFIG_QEMU) += qemu/ obj-$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE) += ivybridge/ obj-$(CONFIG_INTEL_QUARK) += quark/ obj-$(CONFIG_INTEL_QUEENSBAY) += queensbay/ +obj-$(CONFIG_INTEL_TANGIER) += tangier/ obj-y += lapic.o ioapic.o obj-y += irq.o ifndef CONFIG_$(SPL_)X86_64 diff --git a/arch/x86/cpu/tangier/Kconfig b/arch/x86/cpu/tangier/Kconfig new file mode 100644 index 0000000000..3545886a65 --- /dev/null +++ b/arch/x86/cpu/tangier/Kconfig @@ -0,0 +1,20 @@ +# +# Copyright (C) 2015 Intel, Inc +# +# SPDX-License-Identifier: GPL-2.0+ +# + +config INTEL_TANGIER + bool + depends on INTEL_MID + +config SYS_CAR_ADDR + hex + default 0x19200000 + +config SYS_CAR_SIZE + hex + default 0x4000 + help + Space in bytes in eSRAM used as Cache-As-RAM (CAR). + Note this size must not exceed eSRAM's total size. diff --git a/arch/x86/cpu/tangier/Makefile b/arch/x86/cpu/tangier/Makefile new file mode 100644 index 0000000000..d937737057 --- /dev/null +++ b/arch/x86/cpu/tangier/Makefile @@ -0,0 +1 @@ +obj-y += car.o tangier.o sdram.o diff --git a/arch/x86/cpu/tangier/car.S b/arch/x86/cpu/tangier/car.S new file mode 100644 index 0000000000..6982106c19 --- /dev/null +++ b/arch/x86/cpu/tangier/car.S @@ -0,0 +1,13 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * (C) Copyright 2010-2011 + * Graeme Russ, graeme.russ@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +.section .text + +.globl car_init +car_init: + jmp car_init_ret diff --git a/arch/x86/cpu/tangier/sdram.c b/arch/x86/cpu/tangier/sdram.c new file mode 100644 index 0000000000..da046559a1 --- /dev/null +++ b/arch/x86/cpu/tangier/sdram.c @@ -0,0 +1,234 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * (C) Copyright 2010,2011 + * Graeme Russ, graeme.russ@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <malloc.h> +#include <asm/bootparam.h> +#include <asm/e820.h> +#include <asm/global_data.h> +#include <asm/processor.h> +#include <asm/sections.h> +#include <asm/sfi.h> +#include <asm/u-boot-x86.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* Memory type definitions */ +enum sfi_mem_type { + SFI_MEM_RESERVED, + SFI_LOADER_CODE, + SFI_LOADER_DATA, + SFI_BOOT_SERVICE_CODE, + SFI_BOOT_SERVICE_DATA, + SFI_RUNTIME_SERVICE_CODE, + SFI_RUNTIME_SERVICE_DATA, + SFI_MEM_CONV, + SFI_MEM_UNUSABLE, + SFI_ACPI_RECLAIM, + SFI_ACPI_NVS, + SFI_MEM_MMIO, + SFI_MEM_IOPORT, + SFI_PAL_CODE, + SFI_MEM_TYPEMAX, +}; + +#define SFI_BASE_ADDR 0x000E0000 +#define SFI_LENGTH 0x00020000 +#define SFI_TABLE_LENGTH 16 + +static int sfi_table_check(struct sfi_table_header *sbh) +{ + char chksum = 0; + char *pos = (char *)sbh; + int i; + + if (sbh->len < SFI_TABLE_LENGTH) + return -1; + + if (sbh->len > SFI_LENGTH) + return -1; + + for (i = 0; i < sbh->len; i++) + chksum += *pos++; + + if (chksum) + error("sfi: Invalid checksum\n"); + + /* Checksum is OK if zero */ + return chksum; +} + +static int sfi_table_is_type(struct sfi_table_header *sbh, const char *signature) +{ + return !strncmp(sbh->sig, signature, SFI_SIGNATURE_SIZE) && + !sfi_table_check(sbh); +} + +static struct sfi_table_simple *sfi_get_table_by_sig(unsigned long addr, + const char *signature) +{ + struct sfi_table_simple *sb = NULL; + int i; + + for (i = 0; i < SFI_LENGTH; i += SFI_TABLE_LENGTH) { + sb = (struct sfi_table_simple *)(addr + i); + if (sfi_table_is_type(&sb->header, signature)) + break; + } + + if (i >= SFI_LENGTH || !sb) + return NULL; + + return sb; +} + +static struct sfi_table_simple *sfi_search_mmap(void) +{ + struct sfi_table_header *sbh; + struct sfi_table_simple *sb; + u32 sys_entry_cnt; + u32 i; + + /* Find SYST table */ + sb = sfi_get_table_by_sig(SFI_BASE_ADDR, SFI_SIG_SYST); + if (!sb) { + error("failed to locate SYST table\n"); + return NULL; + } + + sys_entry_cnt = (sb->header.len - sizeof(*sbh)) / 8; + + /* Search through each SYST entry for MMAP table */ + for (i = 0; i < sys_entry_cnt; i++) { + sbh = (struct sfi_table_header *)(unsigned long)sb->pentry[i]; + + if (sfi_table_is_type(sbh, SFI_SIG_MMAP)) + return (struct sfi_table_simple *) sbh; + } + + error("failed to locate SFI MMAP table\n"); + return NULL; +} + +#define sfi_for_each_mentry(i, sb, mentry) \ + for (i = 0, mentry = (struct sfi_mem_entry *)sb->pentry; \ + i < SFI_GET_NUM_ENTRIES(sb, struct sfi_mem_entry); \ + i++, mentry++) \ + +static unsigned sfi_setup_e820(unsigned max_entries, struct e820entry *entries) +{ + struct sfi_table_simple *sb; + struct sfi_mem_entry *mentry; + unsigned long long start, end, size; + int type, total = 0; + int i; + + sb = sfi_search_mmap(); + if (!sb) + return 0; + + sfi_for_each_mentry(i, sb, mentry) { + start = mentry->phys_start; + size = mentry->pages << 12; + end = start + size; + + if (start > end) + continue; + + /* translate SFI mmap type to E820 map type */ + switch (mentry->type) { + case SFI_MEM_CONV: + type = E820_RAM; + break; + case SFI_MEM_UNUSABLE: + case SFI_RUNTIME_SERVICE_DATA: + continue; + default: + type = E820_RESERVED; + } + + if (total == E820MAX) + break; + entries[total].addr = start; + entries[total].size = size; + entries[total].type = type; + + total++; + } + + return total; +} + +static int sfi_get_bank_size(void) +{ + struct sfi_table_simple *sb; + struct sfi_mem_entry *mentry; + int bank = 0; + int i; + + sb = sfi_search_mmap(); + if (!sb) + return -ENXIO; + + sfi_for_each_mentry(i, sb, mentry) { + if (mentry->type != SFI_MEM_CONV) + continue; + + gd->bd->bi_dram[bank].start = mentry->phys_start; + gd->bd->bi_dram[bank].size = mentry->pages << 12; + bank++; + } + + return bank; +} + +static phys_size_t sfi_get_ram_size(void) +{ + struct sfi_table_simple *sb; + struct sfi_mem_entry *mentry; + phys_size_t ram = 0; + int i; + + sb = sfi_search_mmap(); + if (!sb) + return 0; + + sfi_for_each_mentry(i, sb, mentry) { + if (mentry->type != SFI_MEM_CONV) + continue; + + ram += (mentry->pages << 12); + } + + debug("RAM size %llu\n", ram); + + return ram; +} + +unsigned install_e820_map(unsigned max_entries, struct e820entry *entries) +{ + return sfi_setup_e820(max_entries, entries); +} + +int dram_init_banksize(void) +{ + int ret; + + ret = sfi_get_bank_size(); + if (ret < 0) + return ret; + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = sfi_get_ram_size(); + + return 0; +} diff --git a/arch/x86/cpu/tangier/tangier.c b/arch/x86/cpu/tangier/tangier.c new file mode 100644 index 0000000000..c06767b915 --- /dev/null +++ b/arch/x86/cpu/tangier/tangier.c @@ -0,0 +1,36 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * (C) Copyright 2008 + * Graeme Russ, graeme.russ@gmail.com. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/scu.h> +#include <asm/u-boot-x86.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscellaneous platform dependent initializations + */ +int arch_cpu_init(void) +{ + return x86_cpu_init_f(); +} + +int checkcpu(void) +{ + return 0; +} + +int print_cpuinfo(void) +{ + return default_print_cpuinfo(); +} + +void reset_cpu(ulong addr) +{ + scu_ipc_simple_command(IPCMSG_COLD_RESET, 0); +} diff --git a/arch/x86/include/asm/dma-mapping.h b/arch/x86/include/asm/dma-mapping.h new file mode 100644 index 0000000000..7de4c08e36 --- /dev/null +++ b/arch/x86/include/asm/dma-mapping.h @@ -0,0 +1,41 @@ +/* + * (C) Copyright 2007 + * Stelian Pop stelian@popies.net + * Lead Tech Design <www.leadtechdesign.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __ASM_X86_DMA_MAPPING_H +#define __ASM_X86_DMA_MAPPING_H + +#define dma_mapping_error(x, y) 0 + +enum dma_data_direction { + DMA_BIDIRECTIONAL = 0, + DMA_TO_DEVICE = 1, + DMA_FROM_DEVICE = 2, +}; + +static inline void *dma_alloc_coherent(size_t len, unsigned long *handle) +{ + *handle = (unsigned long)memalign(ARCH_DMA_MINALIGN, len); + return (void *)*handle; +} + +static inline void dma_free_coherent(void *addr) +{ + free(addr); +} + +static inline unsigned long dma_map_single(volatile void *vaddr, size_t len, + enum dma_data_direction dir) +{ + return (unsigned long)vaddr; +} + +static inline void dma_unmap_single(volatile void *vaddr, size_t len, + unsigned long paddr) +{ +} + +#endif /* __ASM_X86_DMA_MAPPING_H */
On 18 April 2017 at 08:21, Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
Please check the chromium copyright though.
Thanks for review.
Actually if you can give an advice what better to do here.
The code is based somehow on some code (origin of which I have never saw since I have no clue what was the tree and version of it) from coreboot, but Felipe and me rewrote a major part of it (I can evaluate that about 90% is rewritten / refactored).
So, would it be better to update copyrights, if yes, what could they look like?
Hi Andy,
On Tue, Apr 18, 2017 at 10:21 PM, Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
bool
hex
default 0x19200000
hex
default 0x4000
help
- Copyright (c) 2011 The Chromium OS Authors.
- (C) Copyright 2010-2011
- Graeme Russ, graeme.russ@gmail.com
+.section .text
jmp car_init_ret
- (C) Copyright 2010,2011
Can you double check if all these header files are needed here?
SFI_MEM_RESERVED,
SFI_LOADER_CODE,
SFI_LOADER_DATA,
SFI_MEM_CONV,
SFI_MEM_UNUSABLE,
SFI_ACPI_RECLAIM,
SFI_ACPI_NVS,
SFI_MEM_MMIO,
SFI_MEM_IOPORT,
SFI_PAL_CODE,
SFI_MEM_TYPEMAX,
Should this be moved to sfi.h?
Can you add some comments here? I guess U-Boot on tangier is not the 1st stage bootloader. It boots from the 1st stage bootloader and get memory information via SFI table which 1st stage bootloader provides?
char chksum = 0;
int i;
return -1;
return -1;
chksum += *pos++;
if (chksum)
return chksum;
int i;
break;
return NULL;
return sb;
u32 sys_entry_cnt;
u32 i;
if (!sb) {
return NULL;
return NULL;
i++, mentry++) \
int i;
if (!sb)
end = start + size;
if (start > end)
continue;
case SFI_MEM_CONV:
type = E820_RAM;
break;
continue;
default:
break;
total++;
return total;
int bank = 0;
int i;
if (!sb)
return -ENXIO;
continue;
bank++;
return bank;
int i;
if (!sb)
continue;
return ram;
int ret;
if (ret < 0)
return ret;
- (C) Copyright 2008
- Graeme Russ, graeme.russ@gmail.com.
- Miscellaneous platform dependent initializations
- (C) Copyright 2007
- Stelian Pop stelian@popies.net
- Lead Tech Design <www.leadtechdesign.com>
DMA_TO_DEVICE = 1,
free(addr);
Why is this dma-mapping.h file needed? For x86, all memory are coherent, which is indicated in your implementation as well (malloc/free are used)
Regards, Bin
On Thu, Apr 20, 2017 at 5:59 AM, Bin Meng bmeng.cn@gmail.com wrote:
Hi Andy,
Will do.
SFI_MEM_RESERVED,
SFI_LOADER_CODE,
SFI_LOADER_DATA,
SFI_MEM_CONV,
SFI_MEM_UNUSABLE,
SFI_ACPI_RECLAIM,
SFI_ACPI_NVS,
SFI_MEM_MMIO,
SFI_MEM_IOPORT,
SFI_PAL_CODE,
SFI_MEM_TYPEMAX,
If no one objects, I would do this.
DMA_TO_DEVICE = 1,
free(addr);
dwc3 is used on many platforms and SoCs, so, it's irrelevant to x86. Other option is to uglify dwc3 driver. I dunno it would be a good idea.
Hi Andy,
On Thu, Apr 20, 2017 at 3:23 PM, Andy Shevchenko andy.shevchenko@gmail.com wrote:
Hi Andy,
Will do.
SFI_MEM_RESERVED,
SFI_LOADER_CODE,
SFI_LOADER_DATA,
SFI_MEM_CONV,
SFI_MEM_UNUSABLE,
SFI_ACPI_RECLAIM,
SFI_ACPI_NVS,
SFI_MEM_MMIO,
SFI_MEM_IOPORT,
SFI_PAL_CODE,
SFI_MEM_TYPEMAX,
Can you confirm if my above comments are correct? If so, please add some comments.
DMA_TO_DEVICE = 1,
free(addr);
OK, so please split this patch into two, Leave the adding of dma-mapping.h file to a single patch, and state that this is required on some cross-platform drivers.
Regards, Bin
Hi Andy,
On 20 April 2017 at 03:41, Bin Meng bmeng.cn@gmail.com wrote:
Hi Andy,
Hi Andy,
Will do.
SFI_MEM_RESERVED,
SFI_LOADER_CODE,
SFI_LOADER_DATA,
SFI_MEM_CONV,
SFI_MEM_UNUSABLE,
SFI_ACPI_RECLAIM,
SFI_ACPI_NVS,
SFI_MEM_MMIO,
SFI_MEM_IOPORT,
SFI_PAL_CODE,
SFI_MEM_TYPEMAX,
DMA_TO_DEVICE = 1,
free(addr);
Andy, any update on this please? Is it still in progress?
Hi, yes, it is still in progress. The issue is I have not much time to look at it.
Can you remind me what is the summary regarding power suppliers?
From hardware point of view there no regulators wrt SDHCI host
controllers, only some let's say magic bits that needs to be set or clear.
Hi Andy,
OK thanks.
From hardware point of view there no regulators wrt SDHCI host controllers, only some let's say magic bits that needs to be set or clear.
The issue is just that we cannot call from drivers into board code. If you don't want to model it as a regulator perhaps you could call into code in arch/arm/cpu/... to flip the bits?
On Tue, 2017-06-20 at 13:35 -0600, Simon Glass wrote:
Hi Andy,
On 20 April 2017 at 03:41, Bin Meng bmeng.cn@gmail.com wrote: Andy, any update on this please? Is it still in progress?
OK thanks.
I'm about to send new version. Though, there is one thing to be clear of...
Okay, meaning there is no consensus, U-Boot (as I see currently) is broken in few ways, one of them is ignoring hardware and proposing to emulate something which certain board doesn't have. That's not how things work.
Linux kernel is not the same in terms of DM in this case. In Linux this board (and SDHCI controllers) is represented differently (by emulating PCI programming interface). And there the PM code is much more complicated than here.
(x86)
It was at very beginning like that, but since SCU and PMU are represented as system controllers (which they indeed are), the calling to them from CPU code would be hackish.
So, the only way I see now is to disable SD card slot on that board blaming U-Boot upstream DM design for that.
Hi Andy,
On 5 July 2017 at 13:27, Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
Hi Andy,
OK thanks.
(x86)
I don't think this is a super-hard problem. We have resolved much more tricky ones, so don't despair!
I suggest you send the driver (but disabled) with a comment indicating where the problem is. We can get it applied and then we can discuss separately what new infrastructure is needed to resolve this. It has come up on several threads and I have a few ideas on what we could do.
I didn't get what you are expecting to see here, what kind of comments?
SFI tables are located in first stage boot ROM / "BIOS" (not exactly, but it's a good approximation for U-Boot). Above is just a range in a memory to search for them (like some one may do using /dev/mem in Linux).
Andy Shevchenko
Andy Shevchenko
Bin Meng
