[U-Boot] [PATCH] mtd: nand: denali: Nuke unbounded loop
This particular unbounded loop in the Denali NAND reset routine can lead to a system hang in case neither of the Timeout and Completed bits get set.
Refactor the code a bit so it's readable and implement timer so the loop is bounded instead. This way the complete hang can be prevented even if the NAND fails to reset.
Signed-off-by: Marek Vasut marex@denx.de Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Scott Wood scottwood@freescale.com --- drivers/mtd/nand/denali.c | 26 ++++++++++++++++++++------ 1 file changed, 20 insertions(+), 6 deletions(-)
diff --git a/drivers/mtd/nand/denali.c b/drivers/mtd/nand/denali.c index 192be7d..8a8cca9 100644 --- a/drivers/mtd/nand/denali.c +++ b/drivers/mtd/nand/denali.c @@ -199,6 +199,7 @@ static void reset_bank(struct denali_nand_info *denali) static uint32_t denali_nand_reset(struct denali_nand_info *denali) { int i; + u32 start, reg;
for (i = 0; i < denali->max_banks; i++) writel(INTR_STATUS__RST_COMP | INTR_STATUS__TIME_OUT, @@ -206,12 +207,25 @@ static uint32_t denali_nand_reset(struct denali_nand_info *denali)
for (i = 0; i < denali->max_banks; i++) { writel(1 << i, denali->flash_reg + DEVICE_RESET); - while (!(readl(denali->flash_reg + INTR_STATUS(i)) & - (INTR_STATUS__RST_COMP | INTR_STATUS__TIME_OUT))) - if (readl(denali->flash_reg + INTR_STATUS(i)) & - INTR_STATUS__TIME_OUT) - debug("NAND Reset operation timed out on bank" - " %d\n", i); + + start = get_timer(0); + while (1) { + reg = readl(denali->flash_reg + INTR_STATUS(i)); + if (reg & INTR_STATUS__TIME_OUT) { + debug("NAND Reset operation timed out on bank %d\n", + i); + break; + } + + /* Reset completed and did not time out, all good. */ + if (reg & INTR_STATUS__RST_COMP) + break; + + if (get_timer(start) > (CONFIG_SYS_HZ / 1000)) { + debug("%s: Reset timed out!\n", __func__); + break; + } + } }
Hi Marek,
2015-12-20 11:59 GMT+09:00 Marek Vasut marex@denx.de:
u32 start, reg; for (i = 0; i < denali->max_banks; i++) writel(INTR_STATUS__RST_COMP | INTR_STATUS__TIME_OUT,
" %d\n", i);
while (1) {
i);
break;
break;
break;
I feel it is too much here about using get_timer() & CONFIG_SYS_HZ.
How about iterating udelay(1) up to reasonable times?
See the wait_for_irq() function in this file.
On Monday, December 21, 2015 at 09:40:16 AM, Masahiro Yamada wrote:
Hi Marek,
int i;
while (1) {
bank %d\n", + i);
break;
break;
__func__); + break;
The get_timer() provides more precise delay , in this case, it's 1 sec . Using just udelay() doesn't provide such precise control over the delay. Moreover, I believe the get_timer() method is the one agreed upon for implementing delays.
I'd like to convert this one to wait_for_bit() once that hits mainline.
Hi Marek,
2015-12-21 19:16 GMT+09:00 Marek Vasut marex@denx.de:
Hi Marek,
int i;
while (1) {
bank %d\n", + i);
break;
break;
__func__); + break;
OK. Why do you want to wait precisely 1 sec. Rationale for "1 sec", please?
You do not have to use CONFIG_SYS_HZ.
As commented in lib/timer.c, get_timer() returns time in milliseconds.
No justice for the conversion.
This function just waits long enough, 1 sec, 2 sec, or whatever.
On Monday, December 21, 2015 at 11:32:09 AM, Masahiro Yamada wrote:
Hi Marek,
Hi Marek,
int i;
while (1) {
break;
break;
There isn't any, 1 second sounds about right for a timeout in my mind.
Ah, so you'd prefer just 1000 in there instead ?
It'd better to have one timeout function than multiple implementation of the same thing in multiple drivers, that's all.
Hi Marek,
2015-12-21 19:45 GMT+09:00 Marek Vasut marex@denx.de:
Hi Marek,
Hi Marek,
int i;
while (1) {
break;
break;
Yes.
I noticed one thing I had missed.
While the CPU is stuck in udelay() function, it cannot check the register flag that might have been already set. This possibly wastes a small piece of time slice.
So, I am OK with your way (and also with your next patch for the wait_for_bit() conversion, if you like).
Go ahead!
On Monday, December 21, 2015 at 11:56:30 AM, Masahiro Yamada wrote:
Hi Marek,
Hi!
Hi Marek,
Hi Marek,
int i;
while (1) {
break;
Yes.
Roger, makes sense, will do.
Well yeah, but that's such a small timeslice that it's not very important.
Go ahead!
THanks ;-)
Masahiro Yamada
