[PATCH v2 0/8] arm: kirkwood: Add support for Pogoplug V4
Pogoplug V4 specifications:
Kirkwood 88F6192 SoC 800 MHz CPU 1Gbs Ethernet 128 MB RAM 128 MB NAND 1x USB 2.0 2x USB 3.0 (on PCIe bus) 1 SDHC slot 1x External SATA port (USM enclosure form factor slot)
Thanks to all v1 reviewers, all their comments were incorporated in this v2 patch series.
Changes in v2: - Use mainline Linux DTS version - Use canonical format for defconfig file - Merge all constants into the pogo_v4.c file, remove pogo_v4.h Merge constants from header file.
Tony Dinh (8): arm: kirkwood: Pogoplug-V4 : Add DTS files arm: kirkwood: Pogoplug V4 : Add board defconfig file arm: kirkwood: Pogoplug-V4 : Add Kconfig files arm: kirkwood: Pogoplug-V4 : Add board include configs file arm: kirkwood: Pogoplug-V4 : Add board kwbimage file arm: kirkwood: Pogoplug-V4 : Add board Make file arm: kirkwood: Pogoplug-V4 : Add board implementation arm: kirkwood: Pogoplug-V4 : Add board maintainer
arch/arm/dts/Makefile | 1 + arch/arm/dts/kirkwood-pogoplug-series-4.dts | 180 ++++++++++++++++ arch/arm/mach-kirkwood/Kconfig | 4 + board/cloudengines/pogo_v4/Kconfig | 16 ++ board/cloudengines/pogo_v4/MAINTAINERS | 6 + board/cloudengines/pogo_v4/Makefile | 10 + board/cloudengines/pogo_v4/kwbimage.cfg | 148 +++++++++++++ board/cloudengines/pogo_v4/pogo_v4.c | 220 ++++++++++++++++++++ configs/pogo_v4_defconfig | 73 +++++++ include/configs/pogo_v4.h | 94 +++++++++ 10 files changed, 752 insertions(+) create mode 100644 arch/arm/dts/kirkwood-pogoplug-series-4.dts create mode 100644 board/cloudengines/pogo_v4/Kconfig create mode 100644 board/cloudengines/pogo_v4/MAINTAINERS create mode 100644 board/cloudengines/pogo_v4/Makefile create mode 100644 board/cloudengines/pogo_v4/kwbimage.cfg create mode 100644 board/cloudengines/pogo_v4/pogo_v4.c create mode 100644 configs/pogo_v4_defconfig create mode 100644 include/configs/pogo_v4.h
Add DTS files for Pogoplug V4 board
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
arch/arm/dts/Makefile | 1 + arch/arm/dts/kirkwood-pogoplug-series-4.dts | 180 ++++++++++++++++++++ 2 files changed, 181 insertions(+) create mode 100644 arch/arm/dts/kirkwood-pogoplug-series-4.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7f622fedbd..c8be5b8ae5 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -68,6 +68,7 @@ dtb-$(CONFIG_ARCH_KIRKWOOD) += \ kirkwood-openrd-client.dtb \ kirkwood-openrd-ultimate.dtb \ kirkwood-pogo_e02.dtb \ + kirkwood-pogoplug-series-4.dtb \ kirkwood-sheevaplug.dtb
dtb-$(CONFIG_MACH_S900) += \ diff --git a/arch/arm/dts/kirkwood-pogoplug-series-4.dts b/arch/arm/dts/kirkwood-pogoplug-series-4.dts new file mode 100644 index 0000000000..5aa4669ae2 --- /dev/null +++ b/arch/arm/dts/kirkwood-pogoplug-series-4.dts @@ -0,0 +1,180 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * kirkwood-pogoplug-series-4.dts - Device tree file for PogoPlug Series 4 + * inspired by the board files made by Kevin Mihelich for ArchLinux, + * and their DTS file. + * + * Copyright (C) 2015 Linus Walleij linus.walleij@linaro.org + */ + +/dts-v1/; + +#include "kirkwood.dtsi" +#include "kirkwood-6192.dtsi" +#include <dt-bindings/input/linux-event-codes.h> + +/ { + model = "Cloud Engines PogoPlug Series 4"; + compatible = "cloudengines,pogoplugv4", "marvell,kirkwood-88f6192", + "marvell,kirkwood"; + + memory { + device_type = "memory"; + reg = <0x00000000 0x08000000>; + }; + + chosen { + stdout-path = "uart0:115200n8"; + }; + + gpio_keys { + compatible = "gpio-keys"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-0 = <&pmx_button_eject>; + pinctrl-names = "default"; + + eject { + debounce-interval = <50>; + wakeup-source; + linux,code = <KEY_EJECTCD>; + label = "Eject Button"; + gpios = <&gpio0 29 GPIO_ACTIVE_LOW>; + }; + }; + + gpio-leds { + compatible = "gpio-leds"; + pinctrl-0 = <&pmx_led_green &pmx_led_red>; + pinctrl-names = "default"; + + health { + label = "pogoplugv4:green:health"; + gpios = <&gpio0 22 GPIO_ACTIVE_LOW>; + default-state = "on"; + }; + fault { + label = "pogoplugv4:red:fault"; + gpios = <&gpio0 24 GPIO_ACTIVE_LOW>; + }; + }; +}; + +&pinctrl { + pmx_sata0: pmx-sata0 { + marvell,pins = "mpp21"; + marvell,function = "sata0"; + }; + + pmx_sata1: pmx-sata1 { + marvell,pins = "mpp20"; + marvell,function = "sata1"; + }; + + pmx_sdio_cd: pmx-sdio-cd { + marvell,pins = "mpp27"; + marvell,function = "gpio"; + }; + + pmx_sdio_wp: pmx-sdio-wp { + marvell,pins = "mpp28"; + marvell,function = "gpio"; + }; + + pmx_button_eject: pmx-button-eject { + marvell,pins = "mpp29"; + marvell,function = "gpio"; + }; + + pmx_led_green: pmx-led-green { + marvell,pins = "mpp22"; + marvell,function = "gpio"; + }; + + pmx_led_red: pmx-led-red { + marvell,pins = "mpp24"; + marvell,function = "gpio"; + }; +}; + +&uart0 { + status = "okay"; +}; + +/* + * This PCIE controller has a USB 3.0 XHCI controller at 1,0 + */ +&pciec { + status = "okay"; +}; + +&pcie0 { + status = "okay"; +}; + +&sata { + status = "okay"; + pinctrl-0 = <&pmx_sata0 &pmx_sata1>; + pinctrl-names = "default"; + nr-ports = <1>; +}; + +&sdio { + status = "okay"; + pinctrl-0 = <&pmx_sdio &pmx_sdio_cd &pmx_sdio_wp>; + pinctrl-names = "default"; + cd-gpios = <&gpio0 27 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio0 28 GPIO_ACTIVE_HIGH>; +}; + +&nand { + /* 128 MiB of NAND flash */ + chip-delay = <40>; + status = "okay"; + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "u-boot"; + reg = <0x00000000 0x200000>; + read-only; + }; + + partition@200000 { + label = "uImage"; + reg = <0x00200000 0x300000>; + }; + + partition@500000 { + label = "uImage2"; + reg = <0x00500000 0x300000>; + }; + + partition@800000 { + label = "failsafe"; + reg = <0x00800000 0x800000>; + }; + + partition@1000000 { + label = "root"; + reg = <0x01000000 0x7000000>; + }; + }; +}; + +&mdio { + status = "okay"; + + ethphy0: ethernet-phy@0 { + reg = <0>; + }; +}; + +ð0 { + status = "okay"; + ethernet0-port@0 { + phy-handle = <ðphy0>; + }; +};
Thanks, Stefan
Changes in v2:
- kirkwood-pogoplug-series-4.dts - Device tree file for PogoPlug Series 4
- inspired by the board files made by Kevin Mihelich for ArchLinux,
- and their DTS file.
- Copyright (C) 2015 Linus Walleij linus.walleij@linaro.org
+/dts-v1/;
- model = "Cloud Engines PogoPlug Series 4";
- compatible = "cloudengines,pogoplugv4", "marvell,kirkwood-88f6192",
"marvell,kirkwood";
- memory {
- chosen {
- gpio_keys {
#size-cells = <0>;
eject {
wakeup-source;
- gpio-leds {
health {
fault {
+&pinctrl {
- pmx_sata0: pmx-sata0 {
- pmx_sata1: pmx-sata1 {
- pmx_sdio_cd: pmx-sdio-cd {
- pmx_sdio_wp: pmx-sdio-wp {
- pmx_button_eject: pmx-button-eject {
- pmx_led_green: pmx-led-green {
- pmx_led_red: pmx-led-red {
+&uart0 {
- status = "okay";
- This PCIE controller has a USB 3.0 XHCI controller at 1,0
+&pciec {
- status = "okay";
+&pcie0 {
- status = "okay";
+&sata {
- status = "okay";
- pinctrl-0 = <&pmx_sata0 &pmx_sata1>;
- pinctrl-names = "default";
- nr-ports = <1>;
+&sdio {
- status = "okay";
- pinctrl-0 = <&pmx_sdio &pmx_sdio_cd &pmx_sdio_wp>;
- cd-gpios = <&gpio0 27 GPIO_ACTIVE_LOW>;
- wp-gpios = <&gpio0 28 GPIO_ACTIVE_HIGH>;
+&nand {
- /* 128 MiB of NAND flash */
- chip-delay = <40>;
- status = "okay";
- partitions {
#size-cells = <1>;
partition@0 {
label = "u-boot";
read-only;
partition@200000 {
label = "uImage";
partition@500000 {
label = "uImage2";
partition@800000 {
label = "failsafe";
partition@1000000 {
label = "root";
+&mdio {
- status = "okay";
- ethphy0: ethernet-phy@0 {
reg = <0>;
+ð0 {
- status = "okay";
- ethernet0-port@0 {
Viele Grüße, Stefan Roese
Add board defconfig file for Pogoplug V4 board
Changes in v2: - Use canonical format for defconfig file
configs/pogo_v4_defconfig | 73 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 73 insertions(+) create mode 100644 configs/pogo_v4_defconfig
diff --git a/configs/pogo_v4_defconfig b/configs/pogo_v4_defconfig new file mode 100644 index 0000000000..ab78dbcea2 --- /dev/null +++ b/configs/pogo_v4_defconfig @@ -0,0 +1,73 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SYS_DCACHE_OFF=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_SYS_THUMB_BUILD=y +CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_TEXT_BASE=0x600000 +CONFIG_TARGET_POGO_V4=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xC0000 +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-pogoplug-series-4" +CONFIG_IDENT_STRING="\nPogoplug V4" +CONFIG_SYS_LOAD_ADDR=0x800000 +CONFIG_BOOTSTAGE=y +CONFIG_SHOW_BOOT_PROGRESS=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_PREBOOT=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="Pogo_V4> " +CONFIG_CMD_BOOTZ=y +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set +# CONFIG_BOOTM_VXWORKS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SATA=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_JFFS2=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nand0=orion_nand" +CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:2M(u-boot),3M(uImage),3M(uImage2),8M(failsafe),112M(root)" +CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_NAND=y +CONFIG_VERSION_VARIABLE=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y +CONFIG_DM=y +CONFIG_SATA_MV=y +# CONFIG_MMC_HW_PARTITIONING is not set +CONFIG_MVEBU_MMC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_DM_ETH=y +CONFIG_MVGBE=y +CONFIG_MII=y +CONFIG_PCI=y +CONFIG_PCI_MVEBU=y +CONFIG_DM_RTC=y +CONFIG_RTC_EMULATION=y +CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_PCI=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y
There are very likely things missing here. Please see me comment to patch 4/8 on this.
Thanks, Stefan
Changes in v2:
Add Kconfig files for Pogoplug V4 board
(no changes since v1)
arch/arm/mach-kirkwood/Kconfig | 4 ++++ board/cloudengines/pogo_v4/Kconfig | 16 ++++++++++++++++ 2 files changed, 20 insertions(+) create mode 100644 board/cloudengines/pogo_v4/Kconfig
diff --git a/arch/arm/mach-kirkwood/Kconfig b/arch/arm/mach-kirkwood/Kconfig index cb4e9f29ef..e8ea4a9956 100644 --- a/arch/arm/mach-kirkwood/Kconfig +++ b/arch/arm/mach-kirkwood/Kconfig @@ -25,6 +25,9 @@ config TARGET_LSXL config TARGET_POGO_E02 bool "pogo_e02 Board"
+config TARGET_POGO_V4 + bool "Pogoplug V4 Board" + config TARGET_DNS325 bool "dns325 Board"
@@ -74,6 +77,7 @@ source "board/Marvell/guruplug/Kconfig" source "board/Marvell/sheevaplug/Kconfig" source "board/buffalo/lsxl/Kconfig" source "board/cloudengines/pogo_e02/Kconfig" +source "board/cloudengines/pogo_v4/Kconfig" source "board/d-link/dns325/Kconfig" source "board/iomega/iconnect/Kconfig" source "board/keymile/Kconfig" diff --git a/board/cloudengines/pogo_v4/Kconfig b/board/cloudengines/pogo_v4/Kconfig new file mode 100644 index 0000000000..db3b76b4d4 --- /dev/null +++ b/board/cloudengines/pogo_v4/Kconfig @@ -0,0 +1,16 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2014-2021 Tony Dinh mibodhi@gmail.com +# +if TARGET_POGO_V4 + +config SYS_BOARD + default "pogo_v4" + +config SYS_VENDOR + default "cloudengines" + +config SYS_CONFIG_NAME + default "pogo_v4" + +endif
- bool "Pogoplug V4 Board"
I now see, that the KW88F6281 Kconfig support was just recently added to this file by Tom. Please re-base your patchset on top of latest master.
Thanks, Stefan
+config SYS_BOARD
- default "pogo_v4"
+config SYS_VENDOR
- default "cloudengines"
- default "pogo_v4"
+endif
Add include configs file for Pogoplug V4 board
include/configs/pogo_v4.h | 94 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 94 insertions(+) create mode 100644 include/configs/pogo_v4.h
diff --git a/include/configs/pogo_v4.h b/include/configs/pogo_v4.h new file mode 100644 index 0000000000..b449986e8c --- /dev/null +++ b/include/configs/pogo_v4.h @@ -0,0 +1,94 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2014-2021 Tony Dinh mibodhi@gmail.com + * + * Based on + * Copyright (C) 2012 + * David Purdy david.c.purdy@gmail.com + * + * Based on Kirkwood support: + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + */ + +#ifndef _CONFIG_POGO_V4_H +#define _CONFIG_POGO_V4_H + +/* + * Machine type definition and ID + */ +#define MACH_TYPE_POGO_V4 3960 +#define CONFIG_MACH_TYPE MACH_TYPE_POGO_V4 + +/* + * High Level Configuration Options (easy to change) + */ +#define CONFIG_FEROCEON_88FR131 /* #define CPU Core subversion */ +#define CONFIG_KW88F6192 /* SOC Name */ + +/* + * Commands configuration + */ +#define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-common.h" + +/* + * Default environment variables + */ +#define CONFIG_BOOTCOMMAND \ + "setenv bootargs $(bootargs_console); " \ + "run bootcmd_usb; " \ + "bootm 0x00800000 0x01100000 0x2c00000" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "dtb_file=/boot/dts/" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ + "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0"\ + "mtdids=nand0=orion_nand\0"\ + "bootargs_console=console=ttyS0,115200\0" \ + "bootcmd_usb=usb start; load usb 0:1 0x00800000 /boot/uImage; " \ + "load usb 0:1 0x01100000 /boot/uInitrd; " \ + "load usb 0:1 0x2c00000 $dtb_file\0" + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_FEATURE_COMMAND_EDITING /* for netconsole */ +#define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ +#define CONFIG_PHY_BASE_ADR 0 +#endif /* CONFIG_CMD_NET */ + +/* + * File system + */ +#ifdef CONFIG_CMD_JFFS2 +#define CONFIG_JFFS2_NAND +#define CONFIG_JFFS2_LZO +#endif /* CONFIG_CMD_JFFS2 */ + +/* + * SATA Driver configuration + */ +#ifdef CONFIG_SATA +#define CONFIG_SYS_SATA_MAX_DEVICE 1 +#endif /* CONFIG_SATA */ + +/* + * Support large disk for SATA and USB + */ +#define CONFIG_SYS_64BIT_LBA +#define CONFIG_LBA48 + +/* + * Kirkwood GPIO + */ +#define CONFIG_KIRKWOOD_GPIO + +#endif /* _CONFIG_POGO_V4_H */
- Copyright (C) 2014-2021 Tony Dinh mibodhi@gmail.com
- Based on
- Copyright (C) 2012
- David Purdy david.c.purdy@gmail.com
- Based on Kirkwood support:
- (C) Copyright 2009
- Marvell Semiconductor <www.marvell.com>
- Written-by: Prafulla Wadaskar prafulla@marvell.com
- Machine type definition and ID
Are you really using the pretty old CONFIG_MACH_TYPE to boot Linux on this device?
- High Level Configuration Options (easy to change)
At least CONFIG_FEROCEON_88FR131 is available in Kconfig (arch/arm/mach-kirkwood/Kconfig), so there should be no need to add it via some header.
Please double-check other macros in this header as well for availability in Kconfig.
- Commands configuration
- mv-common.h should be defined after CMD configs since it used them
- to enable certain macros
- Default environment variables
- "setenv bootargs $(bootargs_console); " \
- "run bootcmd_usb; " \
- "bootm 0x00800000 0x01100000 0x2c00000"
- "dtb_file=/boot/dts/" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \
- "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0"\
- "mtdids=nand0=orion_nand\0"\
- "bootargs_console=console=ttyS0,115200\0" \
- "bootcmd_usb=usb start; load usb 0:1 0x00800000 /boot/uImage; " \
- "load usb 0:1 0x01100000 /boot/uInitrd; " \
- "load usb 0:1 0x2c00000 $dtb_file\0"
- Ethernet Driver configuration
- File system
- SATA Driver configuration
This is also in Kconfig. Please make sure to not add any ad-hoc macros here that are Kconfig options now.
Also, please drop the "#ifdef CONFIG_SATA" (and other similar ones) if it's not really select-able.
Thanks, Stefan
- Support large disk for SATA and USB
- Kirkwood GPIO
- Based on
At this point you can now make CI do this for you as we have a test that will fail if there's unmigrated symbols in your board header file. The logic can also be copy/pasted out to a script to run by yourself too.
Hi Tom,
- Based on
I have not used CI before (not sure how). But I used a script copied from your post:
https://lists.denx.de/pipermail/u-boot/2021-September/460085.html
./check-migrated-symbols.sh include/configs/pogo_v4.h
That should be enough to see which ones to migrate, right?
Thanks, Tony
-- Tom
On Thu, Jan 13, 2022 at 04:50:20PM -0800, Tony Dinh wrote:
Hi Tom,
- Based on
Yup, that'll do it.
Add board kwbimage file for Pogoplug V4 board
board/cloudengines/pogo_v4/kwbimage.cfg | 148 ++++++++++++++++++++++++ 1 file changed, 148 insertions(+) create mode 100644 board/cloudengines/pogo_v4/kwbimage.cfg
diff --git a/board/cloudengines/pogo_v4/kwbimage.cfg b/board/cloudengines/pogo_v4/kwbimage.cfg new file mode 100644 index 0000000000..f6294fe313 --- /dev/null +++ b/board/cloudengines/pogo_v4/kwbimage.cfg @@ -0,0 +1,148 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2012 +# David Purdy david.c.purdy@gmail.com +# +# Based on Kirkwood support: +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Written-by: Prafulla Wadaskar <prafulla <at> marvell.com> + +# Boot Media configurations (DONE) +BOOT_FROM nand +NAND_ECC_MODE default +NAND_PAGE_SIZE 0x0800 + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +# Configure RGMII-0 interface pad voltage to 1.8V (SHOULD BE SAME) +DATA 0xffd100e0 0x1b1b1b9b + +#Dram initalization for SINGLE x16 CL=3 @ 200MHz (need CL=3 @ 200MHz?) +DATA 0xffd01400 0x43000618 # DDR Configuration register +# bit13-0: 0x200 (200 DDR2 clks refresh rate) +# bit23-14: zero +# bit24: 1= enable exit self refresh mode on DDR access +# bit25: 1 required +# bit29-26: zero +# bit31-30: 01 + +DATA 0xffd01404 0x34143000 # DDR Controller Control Low +# bit 4: 0=addr/cmd in smame cycle +# bit 5: 0=clk is driven during self refresh, we don't care for APX +# bit 6: 0=use recommended falling edge of clk for addr/cmd +# bit14: 0=input buffer always powered up +# bit18: 1=cpu lock transaction enabled +# bit23-20: 3=recommended value for CL=3 and STARTBURST_DEL disabled bit31=0 +# bit27-24: 6= CL+3, STARTBURST sample stages, for freqs 400MHz, unbuffered DIMM +# bit30-28: 3 required +# bit31: 0=no additional STARTBURST delay + +DATA 0xffd01408 0x11012227 # DDR Timing (Low) (active cycles value +1) +# bit3-0: TRAS lsbs +# bit7-4: TRCD +# bit11- 8: TRP +# bit15-12: TWR +# bit19-16: TWTR +# bit20: TRAS msb +# bit23-21: 0x0 +# bit27-24: TRRD +# bit31-28: TRTP + +DATA 0xffd0140c 0x00000819 # DDR Timing (High) +# bit6-0: TRFC +# bit8-7: TR2R +# bit10-9: TR2W +# bit12-11: TW2W +# bit31-13: zero required + +DATA 0xffd01410 0x00000001 # DDR Address Control (changed to Dockstar vals) +# bit1-0: 00, Cs0width=x16 +# bit3-2: 10, Cs0size=512Mb +# bit5-4: 00, Cs2width=nonexistent +# bit7-6: 00, Cs1size =nonexistent +# bit9-8: 00, Cs2width=nonexistent +# bit11-10: 00, Cs2size =nonexistent +# bit13-12: 00, Cs3width=nonexistent +# bit15-14: 00, Cs3size =nonexistent +# bit16: 0, Cs0AddrSel +# bit17: 0, Cs1AddrSel +# bit18: 0, Cs2AddrSel +# bit19: 0, Cs3AddrSel +# bit31-20: 0 required + +DATA 0xffd01414 0x00000000 # DDR Open Pages Control +# bit0: 0, OpenPage enabled +# bit31-1: 0 required + +DATA 0xffd01418 0x00000000 # DDR Operation +# bit3-0: 0x0, DDR cmd +# bit31-4: 0 required + +DATA 0xffd0141c 0x00000632 # DDR Mode +# bit2-0: 2, BurstLen=2 required +# bit3: 0, BurstType=0 required +# bit6-4: 4, CL=5 (<===== change to CL=3 ?) +# bit7: 0, TestMode=0 normal +# bit8: 0, DLL reset=0 normal +# bit11-9: 6, auto-precharge write recovery ???????????? +# bit12: 0, PD must be zero +# bit31-13: 0 required + +DATA 0xffd01420 0x00000040 # DDR Extended Mode +# bit0: 0, DDR DLL enabled +# bit1: 0, DDR drive strenght normal +# bit2: 0, DDR ODT control lsd (disabled) +# bit5-3: 000, required +# bit6: 1, DDR ODT control msb, (disabled) +# bit9-7: 000, required +# bit10: 0, differential DQS enabled +# bit11: 0, required +# bit12: 0, DDR output buffer enabled +# bit31-13: 0 required + +DATA 0xffd01424 0x0000F07F # DDR Controller Control High +# bit2-0: 111, required +# bit3 : 1 , MBUS Burst Chop disabled +# bit6-4: 111, required +# bit7 : 0 +# bit8 : 0 , no sample stage +# bit9 : 0 , no half clock cycle addition to dataout +# bit10 : 0 , 1/4 clock cycle skew enabled for addr/ctl signals +# bit11 : 0 , 1/4 clock cycle skew disabled for write mesh +# bit15-12: 1111 required +# bit31-16: 0 required + +DATA 0xffd01428 0x00085520 # DDR2 ODT Read Timing (default values) +DATA 0xffd0147c 0x00008552 # DDR2 ODT Write Timing (default values) + +DATA 0xFFD01500 0x00000000 # CS[0]n Base address to 0x0 +DATA 0xFFD01504 0x07FFFFF1 # CS[0]n Size +# bit0: 1, Window enabled +# bit1: 0, Write Protect disabled +# bit3-2: 00, CS0 hit selected +# bit23-4: ones, required +# bit31-24: 0x07, Size (i.e. 128MB) + +DATA 0xFFD0150C 0x00000000 # CS[1]n Size, window disabled +DATA 0xFFD01514 0x00000000 # CS[2]n Size, window disabled +DATA 0xFFD0151C 0x00000000 # CS[3]n Size, window disabled + +DATA 0xffd01494 0x00030000 # DDR ODT Control (Low) (DONE) +# bit3-0: 2, ODT0Rd, MODT[0] asserted during read from DRAM CS1 +# bit7-4: 1, ODT0Rd, MODT[0] asserted during read from DRAM CS0 +# bit19-16:2, ODT0Wr, MODT[0] asserted during write to DRAM CS1 +# bit23-20:1, ODT0Wr, MODT[0] asserted during write to DRAM CS0 + +DATA 0xffd01498 0x00000000 # DDR ODT Control (High) (DONE) +# bit1-0: 00, ODT0 controlled by ODT Control (low) register above +# bit3-2: 01, ODT1 active NEVER! +# bit31-4: zero, required + +DATA 0xffd0149c 0x0000e803 # CPU ODT Control (DONE) +DATA 0xffd01480 0x00000001 # DDR Initialization Control (DONE) +#bit0=1, enable DDR init upon this register write + +# End of Header extension +DATA 0x0 0x0
Thanks, Stefan
Add board Makefile for Pogoplug V4
Changes in v2: - Merge all constants into the pogo_v4.c file, remove pogo_v4.h
board/cloudengines/pogo_v4/Makefile | 10 ++++++++++ 1 file changed, 10 insertions(+) create mode 100644 board/cloudengines/pogo_v4/Makefile
diff --git a/board/cloudengines/pogo_v4/Makefile b/board/cloudengines/pogo_v4/Makefile new file mode 100644 index 0000000000..511bf5ff7e --- /dev/null +++ b/board/cloudengines/pogo_v4/Makefile @@ -0,0 +1,10 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2014-2021 Tony Dinh mibodhi@gmail.com +# +# Based on +# Marvell Semiconductor <www.marvell.com> +# Written-by: Prafulla Wadaskar prafulla@marvell.com +# + +obj-y := pogo_v4.o
Nitpicking: In the subject you write "Make file". Please change this to "Makefile" there as well.
Other than this:
Thanks, Stefan
Changes in v2:
+obj-y := pogo_v4.o
Add board implementation for Pogoplug V4
Note: currently the fdt_get_phy_addr function in this file is duplicate in this board and many other Kirkwood boards (eg. Sheevaplug, GoFlex Home, etc.). This function is being factored out into common area by another patch. And because it was written for flattree only, the patch is being rewritten to use livetree calls.
Changes in v2: Merge constants from header file.
board/cloudengines/pogo_v4/pogo_v4.c | 220 +++++++++++++++++++++++++++ 1 file changed, 220 insertions(+) create mode 100644 board/cloudengines/pogo_v4/pogo_v4.c
diff --git a/board/cloudengines/pogo_v4/pogo_v4.c b/board/cloudengines/pogo_v4/pogo_v4.c new file mode 100644 index 0000000000..c85de0b22e --- /dev/null +++ b/board/cloudengines/pogo_v4/pogo_v4.c @@ -0,0 +1,220 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2014-2021 Tony Dinh mibodhi@gmail.com + * + * Based on + * Copyright (C) 2012 David Purdy david.c.purdy@gmail.com + * + * Based on Kirkwood support: + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + */ + +#include <common.h> +#include <miiphy.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> +#include <asm/arch/mpp.h> +#include <asm/io.h> +#include <asm/arch/gpio.h> +#include <asm/mach-types.h> +#include <bootstage.h> +#include <command.h> +#include <init.h> +#include <linux/bitops.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* GPIO configuration */ +#define POGO_V4_OE_LOW (~(0)) +#define POGO_V4_OE_HIGH (~(0)) +#define POGO_V4_OE_VAL_LOW BIT(29) +#define POGO_V4_OE_VAL_HIGH 0 + +/* PHY related */ +#define MV88E1116_LED_FCTRL_REG 10 +#define MV88E1116_CPRSP_CR3_REG 21 +#define MV88E1116_MAC_CTRL_REG 21 +#define MV88E1116_PGADR_REG 22 +#define MV88E1116_RGMII_TXTM_CTRL BIT(4) +#define MV88E1116_RGMII_RXTM_CTRL BIT(5) + +/* button */ +#define BTN_EJECT 29 + +int board_early_init_f(void) +{ + /* + * default gpio configuration + * There are maximum 64 gpios controlled through 2 sets of registers + * the below configuration configures mainly initial LED status + */ + mvebu_config_gpio(POGO_V4_OE_VAL_LOW, + POGO_V4_OE_VAL_HIGH, + POGO_V4_OE_LOW, POGO_V4_OE_HIGH); + + /* Multi-Purpose Pins Functionality configuration */ + u32 kwmpp_config[] = { + MPP0_NF_IO2, + MPP1_NF_IO3, + MPP2_NF_IO4, + MPP3_NF_IO5, + MPP4_NF_IO6, + MPP5_NF_IO7, + MPP6_SYSRST_OUTn, + MPP7_GPO, + MPP8_TW_SDA, + MPP9_TW_SCK, + MPP10_UART0_TXD, + MPP11_UART0_RXD, + MPP12_SD_CLK, + MPP13_SD_CMD, + MPP14_SD_D0, + MPP15_SD_D1, + MPP16_SD_D2, + MPP17_SD_D3, + MPP18_NF_IO0, + MPP19_NF_IO1, + MPP20_SATA1_ACTn, + MPP21_SATA0_ACTn, + MPP22_GPIO, /* Green LED */ + MPP23_GPIO, + MPP24_GPIO, /* Red LED */ + MPP25_GPIO, + MPP26_GPIO, + MPP27_GPIO, + MPP28_GPIO, + MPP29_GPIO, /* Eject button */ + MPP30_GPIO, + MPP31_GPIO, + MPP32_GPIO, + MPP33_GPIO, + MPP34_GPIO, + MPP35_GPIO, /* FR6192 has only 36 GPIOs */ + 0 + }; + kirkwood_mpp_conf(kwmpp_config, NULL); + + return 0; +} + +int board_late_init(void) +{ + /* Do late init to ensure successful enumeration of XHCI devices */ + pci_init(); + return 0; +} + +int board_init(void) +{ + /* Boot parameters address */ + gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100; + + return 0; +} + +int fdt_get_phy_addr(const char *path) +{ + const void *fdt = gd->fdt_blob; + const u32 *reg; + const u32 *val; + int node, phandle, addr; + + /* Find the node by its full path */ + node = fdt_path_offset(fdt, path); + if (node >= 0) { + /* Look up phy-handle */ + val = fdt_getprop(fdt, node, "phy-handle", NULL); + if (!val) { + /* Look up phy (deprecated property for phy handle) */ + val = fdt_getprop(fdt, node, "phy", NULL); + } + if (val) { + phandle = fdt32_to_cpu(*val); + if (!phandle) + return -FDT_ERR_NOTFOUND; + + /* Follow it to its node */ + node = fdt_node_offset_by_phandle(fdt, phandle); + if (node) { + /* Look up reg */ + reg = fdt_getprop(fdt, node, "reg", NULL); + if (reg) { + addr = fdt32_to_cpu(*reg); + return addr; + } + } + } + } + return -FDT_ERR_NOTFOUND; +} + +#if defined(CONFIG_RESET_PHY_R) +/* Configure and initialize PHY */ +void reset_phy(void) +{ + u16 reg; + int phyaddr; + char *name = "ethernet-controller@72000"; + char *eth0_path = "/ocp@f1000000/ethernet-controller@72000"; + + if (miiphy_set_current_dev(name)) + return; + + phyaddr = fdt_get_phy_addr(eth0_path); + if (phyaddr < 0) + return; + + /* + * Enable RGMII delay on Tx and Rx for CPU port + * Ref: sec 4.7.2 of chip datasheet + */ + miiphy_write(name, phyaddr, MV88E1116_PGADR_REG, 2); + miiphy_read(name, phyaddr, MV88E1116_MAC_CTRL_REG, ®); + reg |= (MV88E1116_RGMII_RXTM_CTRL | MV88E1116_RGMII_TXTM_CTRL); + miiphy_write(name, phyaddr, MV88E1116_MAC_CTRL_REG, reg); + miiphy_write(name, phyaddr, MV88E1116_PGADR_REG, 0); + + /* reset the phy */ + miiphy_reset(name, phyaddr); + + printf("88E1116 Initialized on %s\n", name); +} +#endif /* CONFIG_RESET_PHY_R */ + +#if CONFIG_IS_ENABLED(BOOTSTAGE) +#define GREEN_LED BIT(22) +#define RED_LED BIT(24) +#define BOTH_LEDS (GREEN_LED | RED_LED) +#define NEITHER_LED 0 + +static void set_leds(u32 leds, u32 blinking) +{ + struct kwgpio_registers *r; + u32 oe; + u32 bl; + + r = (struct kwgpio_registers *)MVEBU_GPIO0_BASE; + oe = readl(&r->oe) | BOTH_LEDS; + writel(oe & ~leds, &r->oe); /* active low */ + bl = readl(&r->blink_en) & ~BOTH_LEDS; + writel(bl | blinking, &r->blink_en); +} + +void show_boot_progress(int val) +{ + switch (val) { + case BOOTSTAGE_ID_RUN_OS: /* booting Linux */ + set_leds(BOTH_LEDS, NEITHER_LED); + break; + case BOOTSTAGE_ID_NET_ETH_START: /* Ethernet initialization */ + set_leds(GREEN_LED, GREEN_LED); + break; + default: + if (val < 0) /* error */ + set_leds(RED_LED, RED_LED); + break; + } +} +#endif
Ups. And now you bring in the C file for the Makefile from patch 6/8? This will make problems with git bi-secting. Please squash both patches into one instead.
Thanks, Stefan
- Based on
- Copyright (C) 2012 David Purdy david.c.purdy@gmail.com
- mvebu_config_gpio(POGO_V4_OE_VAL_LOW,
- /* Multi-Purpose Pins Functionality configuration */
- u32 kwmpp_config[] = {
MPP0_NF_IO2,
MPP1_NF_IO3,
MPP2_NF_IO4,
MPP3_NF_IO5,
MPP4_NF_IO6,
MPP5_NF_IO7,
MPP6_SYSRST_OUTn,
MPP7_GPO,
MPP8_TW_SDA,
MPP9_TW_SCK,
MPP10_UART0_TXD,
MPP11_UART0_RXD,
MPP12_SD_CLK,
MPP13_SD_CMD,
MPP14_SD_D0,
MPP15_SD_D1,
MPP16_SD_D2,
MPP17_SD_D3,
MPP18_NF_IO0,
MPP19_NF_IO1,
MPP20_SATA1_ACTn,
MPP21_SATA0_ACTn,
MPP23_GPIO,
MPP25_GPIO,
MPP26_GPIO,
MPP27_GPIO,
MPP28_GPIO,
MPP30_GPIO,
MPP31_GPIO,
MPP32_GPIO,
MPP33_GPIO,
MPP34_GPIO,
0
- kirkwood_mpp_conf(kwmpp_config, NULL);
- /* Do late init to ensure successful enumeration of XHCI devices */
- pci_init();
- /* Boot parameters address */
- gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100;
- const void *fdt = gd->fdt_blob;
- const u32 *reg;
- const u32 *val;
- int node, phandle, addr;
- /* Find the node by its full path */
- node = fdt_path_offset(fdt, path);
- if (node >= 0) {
if (!val) {
if (val) {
if (!phandle)
if (node) {
/* Look up reg */
if (reg) {
return addr;
- return -FDT_ERR_NOTFOUND;
- u16 reg;
- int phyaddr;
- char *name = "ethernet-controller@72000";
- char *eth0_path = "/ocp@f1000000/ethernet-controller@72000";
- if (miiphy_set_current_dev(name))
return;
- phyaddr = fdt_get_phy_addr(eth0_path);
- if (phyaddr < 0)
return;
- miiphy_write(name, phyaddr, MV88E1116_PGADR_REG, 2);
- miiphy_read(name, phyaddr, MV88E1116_MAC_CTRL_REG, ®);
- reg |= (MV88E1116_RGMII_RXTM_CTRL | MV88E1116_RGMII_TXTM_CTRL);
- miiphy_write(name, phyaddr, MV88E1116_MAC_CTRL_REG, reg);
- miiphy_write(name, phyaddr, MV88E1116_PGADR_REG, 0);
- /* reset the phy */
- miiphy_reset(name, phyaddr);
- printf("88E1116 Initialized on %s\n", name);
- struct kwgpio_registers *r;
- u32 oe;
- u32 bl;
- r = (struct kwgpio_registers *)MVEBU_GPIO0_BASE;
- oe = readl(&r->oe) | BOTH_LEDS;
- writel(oe & ~leds, &r->oe); /* active low */
- bl = readl(&r->blink_en) & ~BOTH_LEDS;
- writel(bl | blinking, &r->blink_en);
- switch (val) {
- case BOOTSTAGE_ID_RUN_OS: /* booting Linux */
break;
- case BOOTSTAGE_ID_NET_ETH_START: /* Ethernet initialization */
break;
- default:
break;
+} +#endif
Add board maintainer for Pogoplug V4 board
board/cloudengines/pogo_v4/MAINTAINERS | 6 ++++++ 1 file changed, 6 insertions(+) create mode 100644 board/cloudengines/pogo_v4/MAINTAINERS
diff --git a/board/cloudengines/pogo_v4/MAINTAINERS b/board/cloudengines/pogo_v4/MAINTAINERS new file mode 100644 index 0000000000..35fd7858b7 --- /dev/null +++ b/board/cloudengines/pogo_v4/MAINTAINERS @@ -0,0 +1,6 @@ +POGO_V4 BOARD +M: Tony Dinh mibodhi@gmail.com +S: Maintained +F: board/cloudengines/pogo_v4/ +F: include/configs/pogo_v4.h +F: configs/pogo_v4_defconfig
Hmm, just this one file?
I would prefer to not have this many patches in this series and squash at least all files in the board directory into one. Or also integrate the defconfig and include/configs header. This is my personal taste, other might have different preferences here.
Thanks, Stefan
Hi Stefan & Tom,
Agreed. I'd prefer less patches, too :) And will rebase to the latest master to take care of the defconfig/header issue (I think I had this v2 series done before Tom did the move for some). And will remove the obsolete MACH_TYPE (that was remnant of when we still wanted to boot old kernels).
I will send in v3 series.
Thanks, Tony
Thanks, Stefan
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de
Stefan Roese
Tony Dinh
