[U-Boot] [PATCH] drivers: mtd :spi: Enable 4B opcodes for SPANSION s25fl512s
s25fs512s and s25fl512s which has same JEDEC ID but only varies in operating volatge so s25fs512s shares same command set as mentioned below – Serial Command subset and footprint compatible with S25FL-A, S25FL-K, S25FL-P, and S25FL-S SPI families – Multi I/O Command subset and footprint compatible with S25FL-P, and S25FL-S SPI families
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- drivers/mtd/spi/spi-nor-ids.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index ec92976..a89c191 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -177,7 +177,7 @@ const struct flash_info spi_nor_ids[] = { { INFO("s25sl064p", 0x010216, 0x4d00, 64 * 1024, 128, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("s25fl256s0", 0x010219, 0x4d00, 256 * 1024, 128, USE_CLSR) }, { INFO("s25fl256s1", 0x010219, 0x4d01, 64 * 1024, 512, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, - { INFO6("s25fl512s", 0x010220, 0x4d0081, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { INFO6("s25fl512s", 0x010220, 0x4d0081, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR | SPI_NOR_4B_OPCODES) }, { INFO("s25fl512s_256k", 0x010220, 0x4d00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, { INFO("s25fl512s_64k", 0x010220, 0x4d01, 64 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, { INFO("s25fl512s_512k", 0x010220, 0x4f00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) },
Sorry, I can see the same patches on ML w/o the versioning number that indeed difficult the diff from previous one.
Would you please send all the 3 patches again with next version with change log.
-----Original Message----- From: Jagan Teki jagan@amarulasolutions.com Sent: Tuesday, July 16, 2019 5:25 PM To: Ashish Kumar ashish.kumar@nxp.com Cc: U-Boot-Denx u-boot@lists.denx.de Subject: [EXT] Re: [PATCH] drivers: mtd :spi: Enable 4B opcodes for SPANSION s25fl512s
Caution: EXT Email
Thanks Jagan for the feedback. I have posted the v3 of the same with version info and change log http://patchwork.ozlabs.org/patch/1133132/ http://patchwork.ozlabs.org/patch/1133133/ http://patchwork.ozlabs.org/patch/1133134/
Regards Ashish
Ashish Kumar
Ashish Kumar
Jagan Teki
