[U-Boot] [PATCH] ARM: sama5d2: Implement boot device autodetection
Implement support for saving ARM register R4 early during boot using save_boot_params . Implement support for decoding the stored register R4 value in spl_boot_device() to obtain boot device from which the SoC booted. This way, the SPL will always load U-Boot from the same device from which the SPL itself booted instead of using hard-coded boot device.
This functionality is useful for example when booting sama5d2-xplained from SD card, where by default the SPL would try loading the U-Boot from eMMC and fail. This is because eMMC is on SDHCI0 (BOOT_DEVICE_MMC1), while SD slot is on SDHCI1 (BOOT_DEVICE_MMC2) and the SPL was hard-wired to always boot from BOOT_DEVICE_MMC1.
Signed-off-by: Marek Vasut marex@denx.de Cc: Andreas Bießmann andreas.devel@googlemail.com Cc: Wenyou Yang wenyou.yang@atmel.com --- arch/arm/mach-at91/Makefile | 2 +- arch/arm/mach-at91/bootparams_atmel.S | 18 ++++++++++++++++ arch/arm/mach-at91/include/mach/sama5d2.h | 12 +++++++++++ arch/arm/mach-at91/spl.c | 36 +++++++++++++++++++++++++++++++ 4 files changed, 67 insertions(+), 1 deletion(-) create mode 100644 arch/arm/mach-at91/bootparams_atmel.S
diff --git a/arch/arm/mach-at91/Makefile b/arch/arm/mach-at91/Makefile index 4424523..d2abf31 100644 --- a/arch/arm/mach-at91/Makefile +++ b/arch/arm/mach-at91/Makefile @@ -9,7 +9,7 @@ obj-$(CONFIG_AT91SAM9G20) += sdram.o spl_at91.o obj-$(CONFIG_AT91SAM9M10G45) += mpddrc.o spl_at91.o obj-$(CONFIG_AT91SAM9N12) += mpddrc.o spl_at91.o obj-$(CONFIG_AT91SAM9X5) += mpddrc.o spl_at91.o -obj-$(CONFIG_SAMA5D2) += mpddrc.o spl_atmel.o matrix.o atmel_sfr.o +obj-$(CONFIG_SAMA5D2) += bootparams_atmel.o mpddrc.o spl_atmel.o matrix.o atmel_sfr.o obj-$(CONFIG_SAMA5D3) += mpddrc.o spl_atmel.o obj-$(CONFIG_SAMA5D4) += mpddrc.o spl_atmel.o matrix.o atmel_sfr.o obj-y += spl.o diff --git a/arch/arm/mach-at91/bootparams_atmel.S b/arch/arm/mach-at91/bootparams_atmel.S new file mode 100644 index 0000000..568094b --- /dev/null +++ b/arch/arm/mach-at91/bootparams_atmel.S @@ -0,0 +1,18 @@ +/* + * Atmel SAMA5Dx boot parameter handling + * + * Copyright (c) 2016 Marek Vasut marex@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm-offsets.h> +#include <config.h> +#include <asm/system.h> +#include <linux/linkage.h> + +ENTRY(save_boot_params) + ldr r0, =bootrom_stash + str r4, [r0, #0] + b save_boot_params_ret +ENDPROC(save_boot_params) diff --git a/arch/arm/mach-at91/include/mach/sama5d2.h b/arch/arm/mach-at91/include/mach/sama5d2.h index dd5a2a7..e6d498c 100644 --- a/arch/arm/mach-at91/include/mach/sama5d2.h +++ b/arch/arm/mach-at91/include/mach/sama5d2.h @@ -225,6 +225,18 @@ /* No PMECC Galois table in ROM */ #define NO_GALOIS_TABLE_IN_ROM
+/* Boot modes stored by BootROM in r4 */ +#define ATMEL_SAMA5D2_BOOT_FROM_OFF 0 +#define ATMEL_SAMA5D2_BOOT_FROM_MASK 0xf +#define ATMEL_SAMA5D2_BOOT_FROM_SPI (0 << 0) +#define ATMEL_SAMA5D2_BOOT_FROM_MCI (1 << 0) +#define ATMEL_SAMA5D2_BOOT_FROM_SMC (2 << 0) +#define ATMEL_SAMA5D2_BOOT_FROM_TWI (3 << 0) +#define ATMEL_SAMA5D2_BOOT_FROM_QSPI (4 << 0) + +#define ATMEL_SAMA5D2_BOOT_DEV_ID_OFF 4 +#define ATMEL_SAMA5D2_BOOT_DEV_ID_MASK 0xf + #ifndef __ASSEMBLY__ unsigned int get_chip_id(void); unsigned int get_extension_chip_id(void); diff --git a/arch/arm/mach-at91/spl.c b/arch/arm/mach-at91/spl.c index 27a405a..c4ed224 100644 --- a/arch/arm/mach-at91/spl.c +++ b/arch/arm/mach-at91/spl.c @@ -23,6 +23,40 @@ void at91_disable_wdt(void) } #endif
+#if defined(CONFIG_SAMA5D2) +struct { + u32 r4; +} bootrom_stash __attribute__((section(".data"))); + +u32 spl_boot_device(void) +{ + u32 dev = (bootrom_stash.r4 >> ATMEL_SAMA5D2_BOOT_FROM_OFF) & + ATMEL_SAMA5D2_BOOT_FROM_MASK; + u32 off = (bootrom_stash.r4 >> ATMEL_SAMA5D2_BOOT_DEV_ID_OFF) & + ATMEL_SAMA5D2_BOOT_DEV_ID_MASK; + +#if defined(CONFIG_SYS_USE_MMC) + if (dev == ATMEL_SAMA5D2_BOOT_FROM_MCI) { + if (off == 0) + return BOOT_DEVICE_MMC1; + if (off == 1) + return BOOT_DEVICE_MMC2; + printf("ERROR: MMC controller %i not present!\n", dev); + hang(); + } +#endif + +#if defined(CONFIG_SYS_USE_SERIALFLASH) || defined(CONFIG_SYS_USE_SPIFLASH) + if (dev == ATMEL_SAMA5D2_BOOT_FROM_SPI) + return BOOT_DEVICE_SPI; +#endif + + printf("ERROR: SMC/TWI/QSPI boot device not supported!\n" + " Boot device %i, controller number %i\n", dev, off); + + return BOOT_DEVICE_NONE; +} +#else u32 spl_boot_device(void) { #ifdef CONFIG_SYS_USE_MMC @@ -34,12 +68,14 @@ u32 spl_boot_device(void) #endif return BOOT_DEVICE_NONE; } +#endif
u32 spl_boot_mode(void) { switch (spl_boot_device()) { #ifdef CONFIG_SYS_USE_MMC case BOOT_DEVICE_MMC1: + case BOOT_DEVICE_MMC2: return MMCSD_MODE_FS; break; #endif
Reviewed-by: Andreas Bießmann andreas@biessmann.org
I will eventually extend this to SAMA5Dx as this is quite helpful on upcoming board.
Hi Marek,
Let's do it for the next release. Hopefully this gets in with 2016.05 ... as always I'm really late for my pull request.
Andreas
On 05/03/2016 01:43 PM, Andreas Bießmann wrote:
Hi Marek,
This one is for next release (2016.07) too :) But it's not like it breaks anything, so this release is fine as well.
Andreas
Andreas Bießmann
