[PATCH 1/2] ARM: uniphier: set gd->ram_base correctly
gd->ram_base is not set at all if the end address of the DRAM ch0 exceeds 4GB.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/dram_init.c | 7 +------ 1 file changed, 1 insertion(+), 6 deletions(-)
diff --git a/arch/arm/mach-uniphier/dram_init.c b/arch/arm/mach-uniphier/dram_init.c index 13821a928831..5f9d90fe6dc0 100644 --- a/arch/arm/mach-uniphier/dram_init.c +++ b/arch/arm/mach-uniphier/dram_init.c @@ -248,12 +248,7 @@ int dram_init(void)
max_size = (1ULL << 32) - dram_map[i].base;
- if (dram_map[i].size > max_size) { - gd->ram_size += max_size; - break; - } - - gd->ram_size += dram_map[i].size; + gd->ram_size = min(dram_map[i].size, max_size);
if (!valid_bank_found) gd->ram_base = dram_map[i].base;
If the "source" command is not given the address, it uses CONFIG_SYS_LOAD_ADDR, which is compile-time determined.
Using the "loadaddr" environment variable is handier because it is relocated according to the memory base when CONFIG_POSITION_INDEPENDENT is enabled.
include/configs/uniphier.h | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 29866668c491..b95fb9c93fa9 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -169,17 +169,17 @@ "ubi part UBI && " \ "ubifsmount ubi0:boot && " \ "ubifsload ${loadaddr} ${script} && " \ - "source\0" \ + "source $loadaddr\0" \ "norscript=echo Running ${script} from tftp ... && " \ "tftpboot ${script} &&" \ - "source\0" \ + "source $loadaddr\0" \ "usbscript=usb start && " \ "setenv devtype usb && " \ "setenv devnum 0 && " \ "run loadscript_fat\0" \ "loadscript_fat=echo Running ${script} from ${devtype}${devnum} ... && " \ "load ${devtype} ${devnum}:1 ${loadaddr} ${script} && " \ - "source\0" \ + "source $loadaddr\0" \ "sramupdate=setexpr tmp_addr $nor_base + 0x50000 &&" \ "tftpboot $tmp_addr $second_image && " \ "setexpr tmp_addr $nor_base + 0x70000 && " \
On Thu, Jan 30, 2020 at 10:21 PM Masahiro Yamada yamada.masahiro@socionext.com wrote:
Applied to u-boot-uniphier.
"source\0" \
"source\0" \
"source\0" \
-- 2.17.1
break;
gd->ram_size = min(dram_map[i].size, max_size); if (!valid_bank_found) gd->ram_base = dram_map[i].base;
-- 2.17.1
Masahiro Yamada
Masahiro Yamada
