[U-Boot] [PATCH] Remove nowhere used symbol CONFIG_SYS_CLKS_IN_HZ
Compile tested using 'MAKEALL arm' shown few errors, but none related to this patch. I'll address them in separate patches.
Signed-off-by: Ladislav Michl ladis@linux-mips.org
diff --git a/include/configs/ADNPESC1.h b/include/configs/ADNPESC1.h index 0977bee..b8afc17 100644 --- a/include/configs/ADNPESC1.h +++ b/include/configs/ADNPESC1.h @@ -44,7 +44,6 @@ #define CONFIG_ADNPESC1 1 /* SSV ADNP/ESC1 board */ #define CONFIG_SYS_CLK_FREQ CONFIG_SYS_NIOS_CPU_CLK/* 50 MHz core clock */ #define CONFIG_SYS_HZ 1000 /* 1 msec time tick */ -#undef CONFIG_SYS_CLKS_IN_HZ #define CONFIG_BOARD_EARLY_INIT_F 1 /* enable early board-spec. init*/
/*------------------------------------------------------------------------ diff --git a/include/configs/B2.h b/include/configs/B2.h index c77ea1f..340b847 100644 --- a/include/configs/B2.h +++ b/include/configs/B2.h @@ -116,8 +116,6 @@ #define CONFIG_SYS_MEMTEST_START 0x0C400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x0C800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x0c700000 /* default load address */
#define CONFIG_SYS_HZ 1000 /* 1 kHz */ diff --git a/include/configs/DK1C20.h b/include/configs/DK1C20.h index db9c17d..45ff2f7 100644 --- a/include/configs/DK1C20.h +++ b/include/configs/DK1C20.h @@ -50,7 +50,6 @@ #define CONFIG_DK1C20 1 /* Cyclone DK-1C20 board*/ #define CONFIG_SYS_CLK_FREQ CONFIG_SYS_NIOS_CPU_CLK/* 50 MHz core clock */ #define CONFIG_SYS_HZ 1000 /* 1 msec time tick */ -#undef CONFIG_SYS_CLKS_IN_HZ #define CONFIG_BOARD_EARLY_INIT_F 1 /* enable early board-spec. init*/
/*------------------------------------------------------------------------ diff --git a/include/configs/DK1S10.h b/include/configs/DK1S10.h index 3bd270c..ae567a3 100644 --- a/include/configs/DK1S10.h +++ b/include/configs/DK1S10.h @@ -48,7 +48,6 @@ #define CONFIG_DK1S10 1 /* Stratix DK-1S10 board*/ #define CONFIG_SYS_CLK_FREQ CONFIG_SYS_NIOS_CPU_CLK/* 50 MHz core clock */ #define CONFIG_SYS_HZ 1000 /* 1 msec time tick */ -#undef CONFIG_SYS_CLKS_IN_HZ #define CONFIG_BOARD_EARLY_INIT_F 1 /* enable early board-spec. init*/
/*------------------------------------------------------------------------ diff --git a/include/configs/EXBITGEN.h b/include/configs/EXBITGEN.h index 1dd6e57..4729464 100644 --- a/include/configs/EXBITGEN.h +++ b/include/configs/EXBITGEN.h @@ -129,8 +129,6 @@ { 300, 600, 1200, 2400, 4800, 9600, 19200, 38400, \ 57600, 115200, 230400, 460800, 921600 }
-#define CONFIG_SYS_CLKS_IN_HZ 1 /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ #define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */
diff --git a/include/configs/SMN42.h b/include/configs/SMN42.h index 45e6a58..d6f41f9 100644 --- a/include/configs/SMN42.h +++ b/include/configs/SMN42.h @@ -139,8 +139,6 @@ #define CONFIG_SYS_MEMTEST_START 0x81800000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x83000000 /* 24 MB in SRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x81000000 /* default load address */ /* for uClinux img is here*/
diff --git a/include/configs/SX1.h b/include/configs/SX1.h index 78c5152..ebc8236 100644 --- a/include/configs/SX1.h +++ b/include/configs/SX1.h @@ -133,8 +133,6 @@ #define CONFIG_SYS_MEMTEST_START 0x10000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x12000000 /* 32 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x10000000 /* default load address */
/* The 1510 has 3 timers, they can be driven by the RefClk (12Mhz) or by DPLL1. diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index d9bcf6b..8550223 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -172,9 +172,6 @@ #define CONFIG_SYS_ALT_MEMTEST #define CONFIG_SYS_LOAD_ADDR 0x30800000 /* default load address */
- -#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - /* we configure PWM Timer 4 to 1us ~ 1MHz */ /*#define CONFIG_SYS_HZ 1000000 */ #define CONFIG_SYS_HZ 1562500 diff --git a/include/configs/W7OLMC.h b/include/configs/W7OLMC.h index 51d0a0a..ceef76e 100644 --- a/include/configs/W7OLMC.h +++ b/include/configs/W7OLMC.h @@ -131,8 +131,6 @@ /* The following table includes the supported baudrates */ #define CONFIG_SYS_BAUDRATE_TABLE {9600}
-#define CONFIG_SYS_CLKS_IN_HZ 1 /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ #define CONFIG_SYS_EXTBDINFO 1 /* use extended board_info (bd_t) */
diff --git a/include/configs/W7OLMG.h b/include/configs/W7OLMG.h index ca1a9d4..11e0630 100644 --- a/include/configs/W7OLMG.h +++ b/include/configs/W7OLMG.h @@ -139,8 +139,6 @@ /* The following table includes the supported baudrates */ #define CONFIG_SYS_BAUDRATE_TABLE {9600}
diff --git a/include/configs/actux1.h b/include/configs/actux1.h index adbc399..91f6ff0 100644 --- a/include/configs/actux1.h +++ b/include/configs/actux1.h @@ -95,8 +95,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00400000 #define CONFIG_SYS_MEMTEST_END 0x00800000
-/* everything, incl board info, in Hz */ -#undef CONFIG_SYS_CLKS_IN_HZ /* spec says 66.666 MHz, but it appears to be 33 */ #define CONFIG_SYS_HZ 3333333
diff --git a/include/configs/actux2.h b/include/configs/actux2.h index 4c579eb..b936938 100644 --- a/include/configs/actux2.h +++ b/include/configs/actux2.h @@ -86,8 +86,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00400000 #define CONFIG_SYS_MEMTEST_END 0x00800000
diff --git a/include/configs/actux3.h b/include/configs/actux3.h index 694f522..f5ee899 100644 --- a/include/configs/actux3.h +++ b/include/configs/actux3.h @@ -84,8 +84,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00400000 #define CONFIG_SYS_MEMTEST_END 0x00800000
diff --git a/include/configs/actux4.h b/include/configs/actux4.h index cdc9956..8d70a26 100644 --- a/include/configs/actux4.h +++ b/include/configs/actux4.h @@ -83,8 +83,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00400000 #define CONFIG_SYS_MEMTEST_END 0x00800000
diff --git a/include/configs/apollon.h b/include/configs/apollon.h index f83dd9c..97c8806 100644 --- a/include/configs/apollon.h +++ b/include/configs/apollon.h @@ -196,7 +196,6 @@ #define CONFIG_SYS_MEMTEST_START (OMAP2420_SDRC_CS0) #define CONFIG_SYS_MEMTEST_END (OMAP2420_SDRC_CS0+SZ_31M)
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ /* default load address */ #define CONFIG_SYS_LOAD_ADDR (OMAP2420_SDRC_CS0)
diff --git a/include/configs/armadillo.h b/include/configs/armadillo.h index 5a4ceaf..ef6ce22 100644 --- a/include/configs/armadillo.h +++ b/include/configs/armadillo.h @@ -105,8 +105,6 @@ #define CONFIG_SYS_MEMTEST_START 0xc0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xc0800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x00040000 /* default load address for armadillo: kernel img is here*/
#define CONFIG_SYS_HZ 2000 /* decrementer freq: 2 kHz */ diff --git a/include/configs/assabet.h b/include/configs/assabet.h index 024fa20..4da68b3 100644 --- a/include/configs/assabet.h +++ b/include/configs/assabet.h @@ -105,8 +105,6 @@ #define CONFIG_SYS_MEMTEST_START 0xc0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xc0800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ - #define CONFIG_SYS_LOAD_ADDR 0xc0000000 /* default load address */
#define CONFIG_SYS_HZ 3686400 /* incrementer freq: 3.6864 MHz */ diff --git a/include/configs/cerf250.h b/include/configs/cerf250.h index f19374e..751e03c 100644 --- a/include/configs/cerf250.h +++ b/include/configs/cerf250.h @@ -113,8 +113,6 @@ #define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ - #define CONFIG_SYS_LOAD_ADDR 0xa2000000 /* default load address */
#define CONFIG_SYS_HZ 1000 diff --git a/include/configs/cm4008.h b/include/configs/cm4008.h index ce36a24..124fad7 100644 --- a/include/configs/cm4008.h +++ b/include/configs/cm4008.h @@ -93,8 +93,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00800000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x01000000 /* 16 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x00008000 /* default load address */
#define CONFIG_SYS_HZ (1000) /* 1ms resolution ticks */ diff --git a/include/configs/cm41xx.h b/include/configs/cm41xx.h index 02cb1ef..5c255ce 100644 --- a/include/configs/cm41xx.h +++ b/include/configs/cm41xx.h @@ -93,8 +93,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00800000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x01000000 /* 16 MB in DRAM */
#define CONFIG_SYS_HZ (1000) /* 1ms resolution ticks */ diff --git a/include/configs/cradle.h b/include/configs/cradle.h index 5131175..850d93b 100644 --- a/include/configs/cradle.h +++ b/include/configs/cradle.h @@ -99,8 +99,6 @@ #define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0xa2000000 /* default load address */
#define CONFIG_SYS_HZ 1000 diff --git a/include/configs/csb226.h b/include/configs/csb226.h index d65c14a..d9f85f0 100644 --- a/include/configs/csb226.h +++ b/include/configs/csb226.h @@ -124,8 +124,6 @@ #define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0xa3000000 /* default load address */ /* RS: where is this documented? */ /* RS: is this where U-Boot is */ diff --git a/include/configs/csb272.h b/include/configs/csb272.h index 5d3b09a..204aea0 100644 --- a/include/configs/csb272.h +++ b/include/configs/csb272.h @@ -140,7 +140,6 @@ #define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */
#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ -#define CONFIG_SYS_CLKS_IN_HZ 1 /* everything, incl board info, in Hz */ #define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_info (bd_t) */ #define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */
diff --git a/include/configs/csb472.h b/include/configs/csb472.h index a33efde..9b3a11c 100644 --- a/include/configs/csb472.h +++ b/include/configs/csb472.h @@ -139,7 +139,6 @@ #define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */
diff --git a/include/configs/delta.h b/include/configs/delta.h index 001b48a..f5508b7 100644 --- a/include/configs/delta.h +++ b/include/configs/delta.h @@ -166,8 +166,6 @@ #define CONFIG_SYS_MEMTEST_START 0x80400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x80800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_DRAM_BASE + 0x8000) /* default load address */
#define CONFIG_SYS_HZ 1000 diff --git a/include/configs/dnp1110.h b/include/configs/dnp1110.h index e329fd3..3f658a7 100644 --- a/include/configs/dnp1110.h +++ b/include/configs/dnp1110.h @@ -109,8 +109,6 @@ #define CONFIG_SYS_MEMTEST_START 0xc0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xc0800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0xc0200000 /* default load address */
#define CONFIG_SYS_HZ 3686400 /* incrementer freq: 3.6864 MHz */ diff --git a/include/configs/eNET.h b/include/configs/eNET.h index 84e1aef..f7e6608 100644 --- a/include/configs/eNET.h +++ b/include/configs/eNET.h @@ -116,8 +116,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x01000000 /* 1 ... 16 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */
#define CONFIG_SYS_HZ 1024 /* incrementer freq: 1kHz */ diff --git a/include/configs/ep7312.h b/include/configs/ep7312.h index 322a3ca..d12b13f 100644 --- a/include/configs/ep7312.h +++ b/include/configs/ep7312.h @@ -107,8 +107,6 @@ #define CONFIG_SYS_MEMTEST_START 0xc0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xc0800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0xc0500000 /* default load address */
#define CONFIG_SYS_HZ 2000 /* decrementer freq: 2 kHz */ diff --git a/include/configs/evb4510.h b/include/configs/evb4510.h index cbaae62..ffc9408 100644 --- a/include/configs/evb4510.h +++ b/include/configs/evb4510.h @@ -122,8 +122,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00780000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x00000000 /* default load address */
#define CONFIG_SYS_SYS_CLK_FREQ 50000000 /* CPU freq: 50 MHz */ diff --git a/include/configs/gcplus.h b/include/configs/gcplus.h index c0b3ab9..81ee05f 100644 --- a/include/configs/gcplus.h +++ b/include/configs/gcplus.h @@ -118,8 +118,6 @@ #define CONFIG_SYS_MEMTEST_START 0xc0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xc0800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0xc0000000 /* default load address */
#define CONFIG_SYS_HZ 3686400 /* incrementer freq: 3.6864 MHz */ diff --git a/include/configs/hymod.h b/include/configs/hymod.h index 2dacfb6..284672b 100644 --- a/include/configs/hymod.h +++ b/include/configs/hymod.h @@ -271,8 +271,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x03c00000 /* 4 ... 60 MB in DRAM */
#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ diff --git a/include/configs/impa7.h b/include/configs/impa7.h index a3d023f..efd4214 100644 --- a/include/configs/impa7.h +++ b/include/configs/impa7.h @@ -106,8 +106,6 @@ #define CONFIG_SYS_MEMTEST_START 0xc0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xc0800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0xc1000000 /* default load address */
#define CONFIG_SYS_HZ 2000 /* decrementer freq: 2 kHz */ diff --git a/include/configs/innokom.h b/include/configs/innokom.h index 043ae2f..895998a 100644 --- a/include/configs/innokom.h +++ b/include/configs/innokom.h @@ -115,8 +115,6 @@ #define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0xa3000000 /* load kernel to this address */
#define CONFIG_SYS_HZ 1000 diff --git a/include/configs/integratorap.h b/include/configs/integratorap.h index 6ce3b4d..9231e64 100644 --- a/include/configs/integratorap.h +++ b/include/configs/integratorap.h @@ -102,7 +102,6 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ #define CONFIG_SYS_LOAD_ADDR 0x7fc0 /* default load address */
/*----------------------------------------------------------------------- diff --git a/include/configs/integratorcp.h b/include/configs/integratorcp.h index 5b4747a..b4219d0 100644 --- a/include/configs/integratorcp.h +++ b/include/configs/integratorcp.h @@ -121,7 +121,6 @@ SIB at Block62 End Block62 address 0x24f80000 #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size*/
/*----------------------------------------------------------------------- diff --git a/include/configs/ixdp425.h b/include/configs/ixdp425.h index 70f3987..768e836 100644 --- a/include/configs/ixdp425.h +++ b/include/configs/ixdp425.h @@ -104,8 +104,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x00010000 /* default load address */
#define CONFIG_SYS_HZ 3333333 /* spec says 66.666 MHz, but it appears to be 33 */ diff --git a/include/configs/ixdpg425.h b/include/configs/ixdpg425.h index 193008e..75707e5 100644 --- a/include/configs/ixdpg425.h +++ b/include/configs/ixdpg425.h @@ -115,7 +115,6 @@ #define CONFIG_SYS_MEMTEST_END 0x00800000 /* 4 ... 8 MB in DRAM */ #define CONFIG_SYS_LOAD_ADDR 0x00010000 /* default load address */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ #define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */
/* valid baudrates */ diff --git a/include/configs/lart.h b/include/configs/lart.h index 38b8e75..877d5c7 100644 --- a/include/configs/lart.h +++ b/include/configs/lart.h @@ -102,8 +102,6 @@ #define CONFIG_SYS_MEMTEST_START 0xc0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xc0800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0xc8000000 /* default load address */
#define CONFIG_SYS_HZ 3686400 /* incrementer freq: 3.6864 MHz */ diff --git a/include/configs/logodl.h b/include/configs/logodl.h index cd105da..9afa800 100644 --- a/include/configs/logodl.h +++ b/include/configs/logodl.h @@ -108,8 +108,6 @@ #define CONFIG_SYS_MEMTEST_START 0x08000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x0800ffff /* 64 KiB */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x08000000 /* load kernel to this address */
#define CONFIG_SYS_HZ 1000 diff --git a/include/configs/lpc2292sodimm.h b/include/configs/lpc2292sodimm.h index 563d35b..fa2917e 100644 --- a/include/configs/lpc2292sodimm.h +++ b/include/configs/lpc2292sodimm.h @@ -106,8 +106,6 @@ #define CONFIG_SYS_MEMTEST_START 0x40000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x40000000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x00040000 /* default load address for */ /* armadillo: kernel img is here*/
diff --git a/include/configs/lpd7a400.h b/include/configs/lpd7a400.h index 575f2a1..b1bd74f 100644 --- a/include/configs/lpd7a400.h +++ b/include/configs/lpd7a400.h @@ -99,8 +99,6 @@ #define CONFIG_SYS_MEMTEST_START 0xc0300000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xc0500000 /* 2 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0xc0f00000 /* default load address */
/* valid baudrates */ diff --git a/include/configs/lpd7a404.h b/include/configs/lpd7a404.h index 3e726a0..b197674 100644 --- a/include/configs/lpd7a404.h +++ b/include/configs/lpd7a404.h @@ -99,8 +99,6 @@ #define CONFIG_SYS_MEMTEST_START 0xc0300000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xc0500000 /* 2 MB in DRAM */
/* valid baudrates */ diff --git a/include/configs/lubbock.h b/include/configs/lubbock.h index 69774d7..a4b430b 100644 --- a/include/configs/lubbock.h +++ b/include/configs/lubbock.h @@ -122,8 +122,6 @@ #define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */
#define CONFIG_SYS_HZ 1000 diff --git a/include/configs/modnet50.h b/include/configs/modnet50.h index 27213a8..b8ae018 100644 --- a/include/configs/modnet50.h +++ b/include/configs/modnet50.h @@ -111,8 +111,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x00500000 /* default load address */
#define CONFIG_SYS_HZ 900 /* decrementer freq: 2 kHz */ diff --git a/include/configs/mx1ads.h b/include/configs/mx1ads.h index f136b0c..c3812e6 100644 --- a/include/configs/mx1ads.h +++ b/include/configs/mx1ads.h @@ -133,7 +133,6 @@ #define CONFIG_SYS_MEMTEST_START 0x09000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x0AF00000 /* 63 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ #define CONFIG_SYS_LOAD_ADDR 0x08800000 /* default load address */ /*#define CONFIG_SYS_HZ 1000 */ #define CONFIG_SYS_HZ 3686400 diff --git a/include/configs/mx1fs2.h b/include/configs/mx1fs2.h index a19eb78..b174b5f 100644 --- a/include/configs/mx1fs2.h +++ b/include/configs/mx1fs2.h @@ -80,8 +80,6 @@ #define CONFIG_SYS_MEMTEST_START 0x08100000 /* memtest test area */ #define CONFIG_SYS_MEMTEST_END 0x08F00000
-#undef CONFIG_SYS_CLKS_IN_HZ /* use HZ for freq. display */ - #define CONFIG_SYS_HZ 3686400 /* incrementer freq: 3.6864 MHz */ #define CONFIG_SYS_CPUSPEED 0x141 /* core clock - register value */
diff --git a/include/configs/netstar.h b/include/configs/netstar.h index 0b38549..37450d4 100644 --- a/include/configs/netstar.h +++ b/include/configs/netstar.h @@ -211,8 +211,6 @@ #define CONFIG_SYS_MEMTEST_END PHYS_SDRAM_1 + PHYS_SDRAM_1_SIZE - \ (CONFIG_SYS_MONITOR_LEN + CONFIG_SYS_MALLOC_LEN + CONFIG_STACKSIZE)
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR PHYS_SDRAM_1 + 0x400000 /* default load address */
/* The 1510 has 3 timers, they can be driven by the RefClk (12Mhz) or by DPLL1. diff --git a/include/configs/nmdk8815.h b/include/configs/nmdk8815.h index 543780d..6d7b94f 100644 --- a/include/configs/nmdk8815.h +++ b/include/configs/nmdk8815.h @@ -96,7 +96,6 @@ /* timing informazion */ #define CONFIG_SYS_HZ (2400000 / 256) /* Timer0: 2.4Mhz + divider */ #define CONFIG_SYS_TIMERBASE 0x101E2000 -#undef CONFIG_SYS_CLKS_IN_HZ
/* serial port (PL011) configuration */ #define CONFIG_PL011_SERIAL diff --git a/include/configs/ns9750dev.h b/include/configs/ns9750dev.h index b22c33c..79dcd64 100644 --- a/include/configs/ns9750dev.h +++ b/include/configs/ns9750dev.h @@ -122,8 +122,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00780000 /* 7,5 MB in DRAM */ /* @TODO */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x00600000 /* default load address */ /* @TODO */
#define CONFIG_SYS_HZ (CPU_CLK_FREQ/64) diff --git a/include/configs/omap1510inn.h b/include/configs/omap1510inn.h index c7d1b6c..ac5040a 100644 --- a/include/configs/omap1510inn.h +++ b/include/configs/omap1510inn.h @@ -130,8 +130,6 @@ #define CONFIG_SYS_MEMTEST_START 0x10000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x12000000 /* 32 MB in DRAM */
/* The 1510 has 3 timers, they can be driven by the RefClk (12Mhz) or by DPLL1. diff --git a/include/configs/omap1610h2.h b/include/configs/omap1610h2.h index e2a6360..79cf608 100644 --- a/include/configs/omap1610h2.h +++ b/include/configs/omap1610h2.h @@ -125,8 +125,6 @@ #define CONFIG_SYS_MEMTEST_START 0x10000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x12000000 /* 32 MB in DRAM */
/* The 1610 has 6 timers, they can be driven by the RefClk (12Mhz) or by diff --git a/include/configs/omap1610inn.h b/include/configs/omap1610inn.h index 5dcfce1..ce30f55 100644 --- a/include/configs/omap1610inn.h +++ b/include/configs/omap1610inn.h @@ -130,8 +130,6 @@ #define CONFIG_SYS_MEMTEST_START 0x10000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x12000000 /* 32 MB in DRAM */
/* The 1610 has 6 timers, they can be driven by the RefClk (12Mhz) or by diff --git a/include/configs/omap2420h4.h b/include/configs/omap2420h4.h index 983b5f2..aa82326 100644 --- a/include/configs/omap2420h4.h +++ b/include/configs/omap2420h4.h @@ -216,8 +216,6 @@ #define CONFIG_SYS_MEMTEST_START (OMAP2420_SDRC_CS0) /* memtest works on */ #define CONFIG_SYS_MEMTEST_END (OMAP2420_SDRC_CS0+SZ_31M)
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR (OMAP2420_SDRC_CS0) /* default load address */
/* The 2420 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 9057606..62c7479 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -214,8 +214,6 @@ #define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ 0x01F00000) /* 31MB */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default */ /* load address */
diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index f4498a9..baf71f4 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -212,9 +212,6 @@ #define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ 0x01F00000) /* 31MB */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, */ - /* in Hz */ - #define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default load */ /* address */
diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index dee0417..02d4fbc 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -206,9 +206,6 @@ #define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ 0x01F00000) /* 31MB */
diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 00c0374..9a32452 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -208,9 +208,6 @@ #define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ 0x01F00000) /* 31MB */
diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index f8ae163..b544ea1 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -216,8 +216,6 @@ #define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ 0x01F00000) /* 31MB */
diff --git a/include/configs/omap5912osk.h b/include/configs/omap5912osk.h index 63cd9c6..2bc5383 100644 --- a/include/configs/omap5912osk.h +++ b/include/configs/omap5912osk.h @@ -134,8 +134,6 @@ #define CONFIG_SYS_MEMTEST_START 0x10000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x12000000 /* 32 MB in DRAM */
/* The 1610 has 6 timers, they can be driven by the RefClk (12Mhz) or by diff --git a/include/configs/omap730p2.h b/include/configs/omap730p2.h index 166d592..0b0d8b6 100644 --- a/include/configs/omap730p2.h +++ b/include/configs/omap730p2.h @@ -142,8 +142,6 @@ #define CONFIG_SYS_MEMTEST_START 0x10000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x12000000 /* 32 MB in DRAM */
/* The OMAP730 has 3 general purpose MPU timers, they can be driven by diff --git a/include/configs/pdnb3.h b/include/configs/pdnb3.h index 4da401f..edaa81b 100644 --- a/include/configs/pdnb3.h +++ b/include/configs/pdnb3.h @@ -117,7 +117,6 @@ #define CONFIG_SYS_MEMTEST_END 0x00800000 /* 4 ... 8 MB in DRAM */ #define CONFIG_SYS_LOAD_ADDR 0x00010000 /* default load address */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ #define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ /* valid baudrates */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } diff --git a/include/configs/pleb2.h b/include/configs/pleb2.h index 59741a9..ab9ea4f 100644 --- a/include/configs/pleb2.h +++ b/include/configs/pleb2.h @@ -122,8 +122,6 @@ #define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */
#define CONFIG_SYS_HZ 1000 diff --git a/include/configs/pxa255_idp.h b/include/configs/pxa255_idp.h index d1c2c65..5e2e7cf 100644 --- a/include/configs/pxa255_idp.h +++ b/include/configs/pxa255_idp.h @@ -236,8 +236,6 @@ #define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0xa0800000 /* default load address */
#define CONFIG_SYS_HZ 1000 diff --git a/include/configs/sbc2410x.h b/include/configs/sbc2410x.h index bf4a14e..102c45a 100644 --- a/include/configs/sbc2410x.h +++ b/include/configs/sbc2410x.h @@ -135,8 +135,6 @@ #define CONFIG_SYS_MEMTEST_START 0x30000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x33F00000 /* 63 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x33000000 /* default load address */
/* the PWM TImer 4 uses a counter of 15625 for 10 ms, so we need */ diff --git a/include/configs/sc520_cdp.h b/include/configs/sc520_cdp.h index 960350c..3e2bb02 100644 --- a/include/configs/sc520_cdp.h +++ b/include/configs/sc520_cdp.h @@ -116,8 +116,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x01000000 /* 1 ... 16 MB in DRAM */
#define CONFIG_SYS_HZ 1024 /* incrementer freq: 1kHz */ diff --git a/include/configs/sc520_spunk.h b/include/configs/sc520_spunk.h index 2445a34..d42ef84 100644 --- a/include/configs/sc520_spunk.h +++ b/include/configs/sc520_spunk.h @@ -117,8 +117,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x01000000 /* 1 ... 16 MB in DRAM */
#define CONFIG_SYS_HZ 1024 /* incrementer freq: 1kHz */ diff --git a/include/configs/scb9328.h b/include/configs/scb9328.h index 5971df7..10db535 100644 --- a/include/configs/scb9328.h +++ b/include/configs/scb9328.h @@ -86,8 +86,6 @@ #define CONFIG_SYS_MEMTEST_START 0x08100000 /* memtest test area */ #define CONFIG_SYS_MEMTEST_END 0x08F00000
diff --git a/include/configs/shannon.h b/include/configs/shannon.h index 75ba34c..717036c 100644 --- a/include/configs/shannon.h +++ b/include/configs/shannon.h @@ -105,8 +105,6 @@ #define CONFIG_SYS_MEMTEST_START 0xc0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xc0800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0xd0000000 /* default load address */
#define CONFIG_SYS_HZ 3686400 /* incrementer freq: 3.6864 MHz */ diff --git a/include/configs/smdk2400.h b/include/configs/smdk2400.h index 6388be4..856d1fb 100644 --- a/include/configs/smdk2400.h +++ b/include/configs/smdk2400.h @@ -137,8 +137,6 @@ #define CONFIG_SYS_MEMTEST_START 0x0c000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x0e000000 /* 32 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x0cf00000 /* default load address */
/* the PWM TImer 4 uses a counter of 15625 for 10 ms, so we need */ diff --git a/include/configs/smdk2410.h b/include/configs/smdk2410.h index ecd958b..797a596 100644 --- a/include/configs/smdk2410.h +++ b/include/configs/smdk2410.h @@ -120,8 +120,6 @@ #define CONFIG_SYS_MEMTEST_START 0x30000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x33F00000 /* 63 MB in DRAM */
/* the PWM TImer 4 uses a counter of 15625 for 10 ms, so we need */ diff --git a/include/configs/trab.h b/include/configs/trab.h index 8f13c35..625d8ee 100644 --- a/include/configs/trab.h +++ b/include/configs/trab.h @@ -316,8 +316,6 @@ #define CONFIG_SYS_MEMTEST_START 0x0C000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x0D000000 /* 16 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0x0CF00000 /* default load address */
#ifdef CONFIG_TRAB_50MHZ diff --git a/include/configs/trizepsiv.h b/include/configs/trizepsiv.h index 70e5ce9..c2744b5 100644 --- a/include/configs/trizepsiv.h +++ b/include/configs/trizepsiv.h @@ -163,8 +163,6 @@ #define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR 0xa1000000 /* default load address */
#define CONFIG_SYS_HZ 1000 diff --git a/include/configs/versatile.h b/include/configs/versatile.h index 852becb..8f6383b 100644 --- a/include/configs/versatile.h +++ b/include/configs/versatile.h @@ -144,7 +144,6 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */
/*----------------------------------------------------------------------- diff --git a/include/configs/voiceblue.h b/include/configs/voiceblue.h index cadd906..b76c794 100644 --- a/include/configs/voiceblue.h +++ b/include/configs/voiceblue.h @@ -210,8 +210,6 @@ #define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 #define CONFIG_SYS_MEMTEST_END PHYS_SDRAM_1 + PHYS_SDRAM_1_SIZE - PHYS_SDRAM_1_RESERVED
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - /* The 1510 has 3 timers, they can be driven by the RefClk (12Mhz) or by DPLL1. * This time is further subdivided by a local divisor. */ diff --git a/include/configs/wepep250.h b/include/configs/wepep250.h index d0afd29..717577f 100644 --- a/include/configs/wepep250.h +++ b/include/configs/wepep250.h @@ -79,8 +79,6 @@ #define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest test area */ #define CONFIG_SYS_MEMTEST_END 0xa0800000
-#undef CONFIG_SYS_CLKS_IN_HZ /* use HZ for freq. display */ - #define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_CPUSPEED 0x141 /* core clock - register value */
diff --git a/include/configs/xaeniax.h b/include/configs/xaeniax.h index 250247c..086ca69 100644 --- a/include/configs/xaeniax.h +++ b/include/configs/xaeniax.h @@ -134,8 +134,6 @@ #define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */
#define CONFIG_SYS_HZ 1000 diff --git a/include/configs/xm250.h b/include/configs/xm250.h index 8e9d5ab..922eb2c 100644 --- a/include/configs/xm250.h +++ b/include/configs/xm250.h @@ -117,8 +117,6 @@ #define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */
#define CONFIG_SYS_HZ 1000 diff --git a/include/configs/xsengine.h b/include/configs/xsengine.h index 5d13f96..cad414c 100644 --- a/include/configs/xsengine.h +++ b/include/configs/xsengine.h @@ -139,7 +139,6 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ #define CONFIG_SYS_MEMTEST_START 0xA0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xA0800000 /* 4 ... 8 MB in DRAM */ -#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } /* valid baudrates */ #define CONFIG_SYS_LOAD_ADDR 0xA0000000 /* load kernel to this address */
diff --git a/include/configs/zylonite.h b/include/configs/zylonite.h index 6febeea..064740d 100644 --- a/include/configs/zylonite.h +++ b/include/configs/zylonite.h @@ -139,8 +139,6 @@ #define CONFIG_SYS_MEMTEST_START 0x9c000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x9c400000 /* 4 ... 8 MB in DRAM */
Ladislav Michl
