[U-Boot] [PATCH] Fix OneNAND ipl to read 256KB
Currently OneNAND initial program loader (ipl) reads only block 0. However, u-boot image for apollon board is 195KB making the board unbootable with OneNAND. Fix ipl to read 256KB.
Signed-off-by: Rohit Hagargundgi h.rohit@samsung.com --- onenand_ipl/onenand_ipl.h | 1 + onenand_ipl/onenand_read.c | 29 +++++++++++++++++++++-------- 2 files changed, 22 insertions(+), 8 deletions(-)
diff --git a/onenand_ipl/onenand_ipl.h b/onenand_ipl/onenand_ipl.h index 3387998..f96e88a 100644 --- a/onenand_ipl/onenand_ipl.h +++ b/onenand_ipl/onenand_ipl.h @@ -24,6 +24,7 @@ #include <linux/mtd/onenand_regs.h>
#define ONENAND_BLOCK_SIZE 2048 +#define ONENAND_BOOTLOADER_SIZE 0x40000
#ifndef CONFIG_SYS_PRINTF #define printf(format, args...) diff --git a/onenand_ipl/onenand_read.c b/onenand_ipl/onenand_read.c index 6d04943..33c66ff 100644 --- a/onenand_ipl/onenand_read.c +++ b/onenand_ipl/onenand_read.c @@ -72,6 +72,13 @@ static inline int onenand_read_page(ulong block, ulong page, while (!(READ_INTERRUPT() & ONENAND_INT_READ)) continue;
+ /* Check for invalid block mark*/ + if (page < 2) { + unsigned int mark = onenand_readw(THIS_ONENAND(ONENAND_SPARERAM)); + if (mark != 0xffff) + return 1; + } + #ifdef __HAVE_ARCH_MEMCPY32 /* 32 bytes boundary memory copy */ memcpy32(buf, base, pagesize); @@ -94,21 +101,27 @@ static inline int onenand_read_page(ulong block, ulong page, */ int onenand_read_block0(unsigned char *buf) { - int page, offset = 0; + int block = 0, page, offset = 0; int pagesize = ONENAND_PAGE_SIZE; + int nblocks = ONENAND_BOOTLOADER_SIZE / (ONENAND_PAGES_PER_BLOCK * ONENAND_PAGE_SIZE);
/* MLC OneNAND has 4KiB page size */ - if (onenand_readw(THIS_ONENAND(ONENAND_REG_TECHNOLOGY))) + if (onenand_readw(THIS_ONENAND(ONENAND_REG_TECHNOLOGY))) { pagesize <<= 1; + nblocks >>= 1; + }
/* NOTE: you must read page from page 1 of block 0 */ /* read the block page by page*/ - for (page = ONENAND_START_PAGE; - page < ONENAND_PAGES_PER_BLOCK; page++) { - - onenand_read_page(0, page, buf + offset, pagesize); - offset += pagesize; - } + for (page = ONENAND_START_PAGE; block < nblocks; page = 0, block++) + for (; page < ONENAND_PAGES_PER_BLOCK; page++) { + if (onenand_read_page(block, page, buf + offset, pagesize)) { + /* This block is bad. Skip it and read next block */ + nblocks++; + break; + } + offset += pagesize; + }
return 0; }
why hardcoded value?
- /* Check for invalid block mark*/
- if (page < 2) {
please add a empty line
and why not do this if (page < 2 && (onenand_readw(THIS_ONENAND(ONENAND_SPARERAM)) != 0xffff)) return 1;
if (mark != 0xffff)
return 1;
- #ifdef __HAVE_ARCH_MEMCPY32 /* 32 bytes boundary memory copy */ memcpy32(buf, base, pagesize);
nblocks >>= 1;
offset += pagesize;
- for (page = ONENAND_START_PAGE; block < nblocks; page = 0, block++)
please add the {} and move the page = 0 to the second 'for' it will be easier to read and understand
nblocks++;
break;
offset += pagesize;
Best Regards, J.
Is it possible to get image size instead of hard value. Then we can read exactly u-boot image size on boot up.
- if (page < 2) {
okay.
offset += pagesize;
okay.
Thanks, Rohit
as point out Wolfgang you can use the MONITOR_LEN.
If you really need the u-boot.bin size you will need to built it first and then on the host calculate it and genereate a .h with its size.
But IMHO the MONITOR_LEN will give enough information evenif it's not the real size to copy u-boot in memory
Best Regards, J.
Dear Rohit Hagargundgi,
Use CONFIG_SYS_MONITOR_LEN as I suggested in my previous message.
What if there is a board that enables additional features and the size grows above 256 kB?
Why do we need a new #define here. CONFIG_SYS_MONITOR_LEN already contains the U-Boot image size, and is configurable for each board.
Please drop this #define here and substitute ONENAND_BOOTLOADER_SIZE by CONFIG_SYS_MONITOR_LEN in the rest of the patch.
Thanks.
In the previous mail, I also solve this issue. multi-block read for IPL
http://www.mail-archive.com/u-boot@lists.denx.de/msg04641.html
Of course, it's not consider the Flex-OneNAND, please apply this one first and then fix it for Flex-OneNAND.
How do you think?
Thank you, Kyungmin Park
Thanks.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de It's not an optical illusion, it just looks like one. -- Phil White _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
oh, okay. So this merge first.
To Scott, Wolfgang - can you please apply this patch.
Also environment block is affected by larger ipl size. I will repost as per comments.
Thanks and regards, Rohit
Here is the updated patch.
Thanks, Rohit
Signed-off-by: Rohit Hagargundgi h.rohit@samsung.com --- include/configs/apollon.h | 1 + onenand_ipl/onenand_read.c | 27 ++++++++++++++++++++------- 2 files changed, 21 insertions(+), 7 deletions(-)
diff --git a/include/configs/apollon.h b/include/configs/apollon.h index dff47fc..2e8198f 100644 --- a/include/configs/apollon.h +++ b/include/configs/apollon.h @@ -254,6 +254,7 @@
/* OneNAND boot, OneNAND has CS0, NOR boot ONeNAND has CS2 */ #define CONFIG_SYS_ONENAND_BASE 0x00000000 +#define CONFIG_SYS_MONITOR_LEN SZ_256K /* U-Boot image size */ #define CONFIG_ENV_IS_IN_ONENAND 1 #define CONFIG_ENV_ADDR 0x00020000
diff --git a/onenand_ipl/onenand_read.c b/onenand_ipl/onenand_read.c index 6d04943..6782eac 100644 --- a/onenand_ipl/onenand_read.c +++ b/onenand_ipl/onenand_read.c @@ -72,6 +72,10 @@ static inline int onenand_read_page(ulong block, ulong page, while (!(READ_INTERRUPT() & ONENAND_INT_READ)) continue;
+ /* Check for invalid block mark*/ + if (page < 2 && (onenand_readw(THIS_ONENAND(ONENAND_SPARERAM)) != 0xffff)) + return 1; + #ifdef __HAVE_ARCH_MEMCPY32 /* 32 bytes boundary memory copy */ memcpy32(buf, base, pagesize); @@ -94,20 +98,29 @@ static inline int onenand_read_page(ulong block, ulong page, */ int onenand_read_block0(unsigned char *buf) { - int page, offset = 0; + int block = 0, page, offset = 0; int pagesize = ONENAND_PAGE_SIZE; + int nblocks = CONFIG_SYS_MONITOR_LEN / (ONENAND_PAGES_PER_BLOCK * ONENAND_PAGE_SIZE);
/* MLC OneNAND has 4KiB page size */ - if (onenand_readw(THIS_ONENAND(ONENAND_REG_TECHNOLOGY))) + if (onenand_readw(THIS_ONENAND(ONENAND_REG_TECHNOLOGY))) { pagesize <<= 1; + nblocks = (nblocks + 1) >> 1; + }
/* NOTE: you must read page from page 1 of block 0 */ /* read the block page by page*/ - for (page = ONENAND_START_PAGE; - page < ONENAND_PAGES_PER_BLOCK; page++) { - - onenand_read_page(0, page, buf + offset, pagesize); - offset += pagesize; + page = ONENAND_START_PAGE; + for (; block < nblocks; block++) { + for (; page < ONENAND_PAGES_PER_BLOCK; page++) { + if (onenand_read_page(block, page, buf + offset, pagesize)) { + /* This block is bad. Skip it and read next block */ + nblocks++; + break; + } + offset += pagesize; + } + page = 0; }
On Thu, Mar 5, 2009 at 12:09 AM, Rohit Hagargundgi h.rohit@samsung.com wrote:
Thanks, Rohit
- if (page < 2 && (onenand_readw(THIS_ONENAND(ONENAND_SPARERAM)) != 0xffff))
- return 1;
No need to check invalid block. Note that block 0 is always good block. no exception. Now you assume block 1 can be invalid block. If true just skip it. when update bootloader at u-boot or kernel. there's bad block at block 1. it will skip write. it means bootloader are located at block 0 and block 2.
- int block = 0, page, offset = 0;
- int nblocks = CONFIG_SYS_MONITOR_LEN / (ONENAND_PAGES_PER_BLOCK * ONENAND_PAGE_SIZE);
- if (onenand_readw(THIS_ONENAND(ONENAND_REG_TECHNOLOGY))) {
pagesize <<= 1;
- nblocks = (nblocks + 1) >> 1;
- page = ONENAND_START_PAGE;
- for (; block < nblocks; block++) {
- for (; page < ONENAND_PAGES_PER_BLOCK; page++) {
- if (onenand_read_page(block, page, buf + offset, pagesize)) {
- /* This block is bad. Skip it and read next block */
- nblocks++;
- break;
- page = 0;
NAK, please use previous one as I sent. In Flex-OneNAND block 0 has 256KiB. need to handle at here how many blocks are needed. I also want to use CONFIG_ONENAND_END_BLOCK since we don't know which OneNAND or Flex-OneNAND are attached to apollon board.
return 1;
Correct. block 0 is guaranteed to be good.
yes, block 1 is invalid so block 0 and block 2 store bootloader. so in ipl, we need to check invalid mark. block 1 is detected bad. block 1 is skipped and block 2 is read for bootloader.
int nblocks = CONFIG_SYS_MONITOR_LEN / (ONENAND_PAGES_PER_BLOCK * ONENAND_PAGE_SIZE); /* MLC OneNAND has 4KiB page size */
assuming page size of 2KB, nblocks is initialised to 2. for 4KB paged devices (like Flex-OneNAND), nblocks gets halved ie 1.
offset += pagesize;
nblocks++;
break;
offset += pagesize;
page = 0; } return 0;
this is taken care above.
okay. but why not use a variable instead.
Thanks, Rohit
Thanks, Rohit
This is not an acceptable commit message.
Please include a reasonable commit message that explains what you are doinbg and why.
Comments must go below this "---" line, not above.
Your patch is white-space corrupted. Please fix your mailer settings.
Please don;t mix uninitialized and initialized variables on one line.
Line too long.
nblocks++;
break;
offset += pagesize;
page = 0;
I always consider it a design problem when the loop limits get changed within the loop. While legal C, it always gives me the creeps.
Signed-off-by: Rohit Hagargundgi <h.rohit at samsung.com> --- include/configs/apollon.h | 1 + onenand_ipl/onenand_read.c | 27 ++++++++++++++++++++------- 2 files changed, 21 insertions(+), 7 deletions(-)
diff --git a/onenand_ipl/onenand_read.c b/onenand_ipl/onenand_read.c index 6d04943..c3b63ed 100644 --- a/onenand_ipl/onenand_read.c +++ b/onenand_ipl/onenand_read.c @@ -72,6 +72,10 @@ static inline int onenand_read_page(ulong block, ulong page, while (!(READ_INTERRUPT() & ONENAND_INT_READ)) continue;
+ /* Check for invalid block mark*/ + if (page < 2 && (onenand_readw(THIS_ONENAND(ONENAND_SPARERAM)) != 0xffff)) + return 1; + #ifdef __HAVE_ARCH_MEMCPY32 /* 32 bytes boundary memory copy */ memcpy32(buf, base, pagesize); @@ -87,6 +91,7 @@ static inline int onenand_read_page(ulong block, ulong page,
#define ONENAND_START_PAGE 1 #define ONENAND_PAGES_PER_BLOCK 64 +#define ONENAND_BLOCK_SIZE (ONENAND_PAGES_PER_BLOCK * ONENAND_PAGE_SIZE)
/** * onenand_read_block - Read a block data to buf @@ -94,20 +99,28 @@ static inline int onenand_read_page(ulong block, ulong page, */ int onenand_read_block0(unsigned char *buf) { - int page, offset = 0; + int block = 0, page = ONENAND_START_PAGE, offset = 0; int pagesize = ONENAND_PAGE_SIZE; + int nblocks = CONFIG_SYS_MONITOR_LEN / ONENAND_BLOCK_SIZE;
/* NOTE: you must read page from page 1 of block 0 */ /* read the block page by page*/ - for (page = ONENAND_START_PAGE; - page < ONENAND_PAGES_PER_BLOCK; page++) { - - onenand_read_page(0, page, buf + offset, pagesize); - offset += pagesize; + for (; block < nblocks; block++) { + for (; page < ONENAND_PAGES_PER_BLOCK; page++) { + if (onenand_read_page(block, page, buf + offset, pagesize)) { + /* This block is bad. Skip it and read next block */ + nblocks++; + break; + } + offset += pagesize; + } + page = 0; }
NAK.
The description is wrong:
The code was not changed to read 256 KB (fixed), but to read whetever there is defined by the CONFIG_SYS_MONITOR_LEN definition.
Please change the commit messages accordingly.
Also, please split this into two separate patches: the first to implement the feature (changes to onenand_ipl/onenand_read.c), and a second one to fix the apollon board (changes to include/configs/apollon.h).
Thanks.
participants (5)
Kyungmin Park
Kyungmin Park
Rohit Hagargundgi
