[U-Boot] [PATCH] drivers/power/regulator/max77686.c: Don't use switch() on bools
With gcc-5.3 we get a warning for using switch() on a bool type. Rewrite these sections as if/else and update the one section that was using 1/0 instead of true/false.
Cc: Simon Glass sjg@chromium.org Cc: Przemyslaw Marczak p.marczak@samsung.com Signed-off-by: Tom Rini trini@konsulko.com --- drivers/power/regulator/max77686.c | 28 ++++++++-------------------- 1 file changed, 8 insertions(+), 20 deletions(-)
diff --git a/drivers/power/regulator/max77686.c b/drivers/power/regulator/max77686.c index 71678b6..7479af7 100644 --- a/drivers/power/regulator/max77686.c +++ b/drivers/power/regulator/max77686.c @@ -515,25 +515,19 @@ static int max77686_ldo_enable(struct udevice *dev, int op, bool *enable)
switch (on_off) { case OPMODE_OFF: - *enable = 0; + *enable = false; break; case OPMODE_ON: - *enable = 1; + *enable = true; break; default: return -EINVAL; } } else if (op == PMIC_OP_SET) { - switch (*enable) { - case 0: - on_off = OPMODE_OFF; - break; - case 1: + if (*enable) on_off = OPMODE_ON; - break; - default: - return -EINVAL; - } + else + on_off = OPMODE_OFF;
ret = max77686_ldo_mode(dev, op, &on_off); if (ret) @@ -651,16 +645,10 @@ static int max77686_buck_enable(struct udevice *dev, int op, bool *enable) return -EINVAL; } } else if (op == PMIC_OP_SET) { - switch (*enable) { - case 0: - on_off = OPMODE_OFF; - break; - case 1: + if (*enable) on_off = OPMODE_ON; - break; - default: - return -EINVAL; - } + else + on_off = OPMODE_OFF;
ret = max77686_buck_mode(dev, op, &on_off); if (ret)
Hello Tom,
*enable = 0;
case OPMODE_ON:*enable = false; break;
*enable = 1;
default: return -EINVAL; } } else if (op == PMIC_OP_SET) {*enable = true; break;
switch (*enable) {
case 0:
break;
case 1:
break;
default:
return -EINVAL;
else
switch (*enable) {
case 0:
break;
case 1:
break;
default:
return -EINVAL;
else
Thank you for pointing that:)
Acked-by: Przemyslaw Marczak p.marczak@samsung.com
Hi
I never seen subject that contains the path of a driver.
Michael
*enable = 0;
*enable = 1;
switch (*enable) {
case 0:
break;
case 1:
break;
default:
return -EINVAL;
else
on_off = OPMODE_OFF; ret = max77686_ldo_mode(dev, op, &on_off); if (ret)
switch (*enable) {
case 0:
break;
case 1:
break;
default:
return -EINVAL;
else
on_off = OPMODE_OFF; ret = max77686_buck_mode(dev, op, &on_off); if (ret)
-- 2.7.0.rc3
On Mon, Jan 18, 2016 at 09:23:54AM +0100, Michael Trimarchi wrote:
Hi
Uncommon but done sometimes.
Michael
*enable = 0;
*enable = 1;
switch (*enable) {
case 0:
break;
case 1:
break;
default:
return -EINVAL;
else
switch (*enable) {
case 0:
break;
case 1:
break;
default:
return -EINVAL;
else
-- 2.7.0.rc3
-- | Michael Nazzareno Trimarchi Amarula Solutions BV | | COO - Founder Cruquiuskade 47 | | +31(0)851119172 Amsterdam 1018 AM NL | | [`as] http://www.amarulasolutions.com |
Hi
Hi
Can you just fix it up and make more common? I think that patchwork in general organize better the emails too
Michael
Michael
*enable = 0;
*enable = 1;
switch (*enable) {
case 0:
break;
case 1:
break;
default:
return -EINVAL;
else
switch (*enable) {
case 0:
break;
case 1:
break;
default:
return -EINVAL;
else
-- 2.7.0.rc3
-- Tom
Cc: Simon Glass sjg@chromium.org Cc: Przemyslaw Marczak p.marczak@samsung.com Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Acked-by: Przemyslaw Marczak p.marczak@samsung.com
Reworded the subject and applied to u-boot/master, thanks!
Bin Meng
Michael Trimarchi
Przemyslaw Marczak
