[U-Boot] [PATCH 1/2] armv8: ls2085aqds: DSPI pin muxing configure through QIXIS
DSPI has pin muxing with SDHC and other IPs, this patch check the value of RCW SPI_PCS_BASE and SPI_BASE_BASE fields, it also check the "hwconfig" configuration, if those pins are configured to DSPI and "hwconfig" enable DSPI, set the BRDCFG5 of QIXIS FPGA to configure the SPI routing to on-board SPI memory. Otherwise will configure to SDHC. Enable DSPI in u-boot "hwconfig" using below command: setenv hwconfig "$hwconfig;dspi"
Signed-off-by: Haikun Wang haikun.wang@freescale.com --- arch/arm/include/asm/arch-fsl-lsch3/config.h | 2 ++ board/freescale/ls2085aqds/ls2085aqds.c | 48 ++++++++++++++++++++++++++++ 2 files changed, 50 insertions(+)
diff --git a/arch/arm/include/asm/arch-fsl-lsch3/config.h b/arch/arm/include/asm/arch-fsl-lsch3/config.h index ca8d38c..8675e91 100644 --- a/arch/arm/include/asm/arch-fsl-lsch3/config.h +++ b/arch/arm/include/asm/arch-fsl-lsch3/config.h @@ -137,6 +137,8 @@ #define DCFG_PORSR1 0x000 #define DCFG_PORSR1_RCW_SRC 0xff800000 #define DCFG_PORSR1_RCW_SRC_NOR 0x12f00000 +#define DCFG_RCWSR13 0x130 +#define DCFG_RCWSR13_DSPI (0 << 8)
#define DCFG_DCSR_BASE 0X700100000ULL #define DCFG_DCSR_PORCR1 0x000 diff --git a/board/freescale/ls2085aqds/ls2085aqds.c b/board/freescale/ls2085aqds/ls2085aqds.c index c492c7e..08906a6 100644 --- a/board/freescale/ls2085aqds/ls2085aqds.c +++ b/board/freescale/ls2085aqds/ls2085aqds.c @@ -17,12 +17,23 @@ #include <environment.h> #include <i2c.h> #include <asm/arch-fsl-lsch3/soc.h> +#include <hwconfig.h>
#include "../common/qixis.h" #include "ls2085aqds_qixis.h"
+#define PIN_MUX_SEL_SDHC 0x00 +#define PIN_MUX_SEL_DSPI 0x0a + +#define SET_SDHC_MUX_SEL(reg, value) ((reg & 0xf0) | value) + DECLARE_GLOBAL_DATA_PTR;
+enum { + MUX_TYPE_SDHC, + MUX_TYPE_DSPI, +}; + unsigned long long get_qixis_addr(void) { unsigned long long addr; @@ -153,10 +164,47 @@ int select_i2c_ch_pca9547(u8 ch) return 0; }
+int config_board_mux(int ctrl_type) +{ + u8 reg5; + + reg5 = QIXIS_READ(brdcfg[5]); + + switch (ctrl_type) { + case MUX_TYPE_SDHC: + reg5 = SET_SDHC_MUX_SEL(reg5, PIN_MUX_SEL_SDHC); + break; + case MUX_TYPE_DSPI: + reg5 = SET_SDHC_MUX_SEL(reg5, PIN_MUX_SEL_DSPI); + break; + default: + printf("Wrong mux interface type\n"); + return -1; + } + + QIXIS_WRITE(brdcfg[5], reg5); + + return 0; +} + int board_init(void) { + char *env_hwconfig; + u32 __iomem *dcfg_ccsr = (u32 __iomem *)DCFG_BASE; + u32 val; + init_final_memctl_regs();
+ val = in_le32(dcfg_ccsr + DCFG_RCWSR13 / 4); + + env_hwconfig = getenv("hwconfig"); + + if (hwconfig_f("dspi", env_hwconfig) && + DCFG_RCWSR13_DSPI == (val & (u32)(0xf << 8))) + config_board_mux(MUX_TYPE_DSPI); + else + config_board_mux(MUX_TYPE_SDHC); + #ifdef CONFIG_ENV_IS_NOWHERE gd->env_addr = (ulong)&default_environment[0]; #endif
This set is applied to u-boot-fsl-qoriq master branch with subject fix.
York
Haikun Wang
York Sun
