[U-Boot] [PATCH][v2] powerpc/mpc85xx:Avoid fix clk groups for Cluster & HW accelerator
CHASSIS2 architecture never fix clock groups for Cluster and hardware accelerator like PME, FMA. These are SoC defined. SoC defines :- - NUM of PLLs present in the system - Clusters and their Clock group - hardware accelerator and their clock group if no clock group, then platform clock divider for FMAN, PME
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Changes for v2: Rebased with respect to below patch "[PATCH][v2] powerpc/mpc85xx:Update processor defines for T1040"
arch/powerpc/cpu/mpc85xx/speed.c | 114 +++++++++++++++++------------ arch/powerpc/include/asm/config_mpc85xx.h | 14 ++++ arch/powerpc/include/asm/immap_85xx.h | 21 ++---- 3 files changed, 89 insertions(+), 60 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/speed.c b/arch/powerpc/cpu/mpc85xx/speed.c index 07690f9..c7054c8 100644 --- a/arch/powerpc/cpu/mpc85xx/speed.c +++ b/arch/powerpc/cpu/mpc85xx/speed.c @@ -18,6 +18,10 @@
DECLARE_GLOBAL_DATA_PTR;
+ +#ifndef CONFIG_SYS_FSL_NUM_CC_PLLS +#define CONFIG_SYS_FSL_NUM_CC_PLLS 6 +#endif /* --------------------------------------------------------------- */
void get_sys_info(sys_info_t *sys_info) @@ -30,6 +34,9 @@ void get_sys_info(sys_info_t *sys_info) #ifdef CONFIG_FSL_CORENET volatile ccsr_clk_t *clk = (void *)(CONFIG_SYS_FSL_CORENET_CLK_ADDR); unsigned int cpu; +#ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 + int cc_group[12] = CONFIG_SYS_FSL_CLUSTER_CLOCKS; +#endif
const u8 core_cplx_PLL[16] = { [ 0] = 0, /* CC1 PPL / 1 */ @@ -60,8 +67,11 @@ void get_sys_info(sys_info_t *sys_info) [13] = 2, /* CC4 PPL / 2 */ [14] = 4, /* CC4 PPL / 4 */ }; - uint i, freq_cc_pll[6], rcw_tmp; - uint ratio[6]; + uint i, freq_c_pll[CONFIG_SYS_FSL_NUM_CC_PLLS]; +#if !defined(CONFIG_FM_PLAT_CLK_DIV) || !defined(CONFIG_PME_PLAT_CLK_DIV) + uint rcw_tmp; +#endif + uint ratio[CONFIG_SYS_FSL_NUM_CC_PLLS]; unsigned long sysclk = CONFIG_SYS_CLK_FREQ; uint mem_pll_rat;
@@ -81,37 +91,36 @@ void get_sys_info(sys_info_t *sys_info) else sys_info->freq_ddrbus = sys_info->freq_systembus * mem_pll_rat;
- ratio[0] = (in_be32(&clk->pllc1gsr) >> 1) & 0x3f; - ratio[1] = (in_be32(&clk->pllc2gsr) >> 1) & 0x3f; - ratio[2] = (in_be32(&clk->pllc3gsr) >> 1) & 0x3f; - ratio[3] = (in_be32(&clk->pllc4gsr) >> 1) & 0x3f; - ratio[4] = (in_be32(&clk->pllc5gsr) >> 1) & 0x3f; - ratio[5] = (in_be32(&clk->pllc6gsr) >> 1) & 0x3f; - for (i = 0; i < 6; i++) { + for (i = 0; i < CONFIG_SYS_FSL_NUM_CC_PLLS; i++) { + ratio[i] = (in_be32(&clk->pllcgsr[i].pllcngsr) >> 1) & 0x3f; if (ratio[i] > 4) - freq_cc_pll[i] = sysclk * ratio[i]; + freq_c_pll[i] = sysclk * ratio[i]; else - freq_cc_pll[i] = sys_info->freq_systembus * ratio[i]; + freq_c_pll[i] = sys_info->freq_systembus * ratio[i]; } #ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 /* + * As per CHASSIS2 architeture total 12 clusters are posible and * Each cluster has up to 4 cores, sharing the same PLL selection. - * The cluster assignment is fixed per SoC. PLL1, PLL2, PLL3 are - * cluster group A, feeding cores on cluster 1 and cluster 2. - * PLL4, PLL5, PLL6 are cluster group B, feeding cores on cluster 3 - * and cluster 4 if existing. + * The cluster clock assignment is SoC defined. + * + * Total 4 clock groups are possible with 3 PLLs each. + * as per array indices, clock group A has 0, 1, 2 numbered PLLs & + * clock group B has 3, 4, 6 and so on. + * + * Clock group A having PLL1, PLL2, PLL3, feeding cores of any cluster + * depends upon the SoC architeture. Same applies to other + * clock groups and clusters. + * */ for_each_cpu(i, cpu, cpu_numcores(), cpu_mask()) { int cluster = fsl_qoriq_core_to_cluster(cpu); u32 c_pll_sel = (in_be32(&clk->clkcsr[cluster].clkcncsr) >> 27) & 0xf; u32 cplx_pll = core_cplx_PLL[c_pll_sel]; - if (cplx_pll > 3) - printf("Unsupported architecture configuration" - " in function %s\n", __func__); - cplx_pll += (cluster / 2) * 3; + cplx_pll += cc_group[cluster] - 1; sys_info->freq_processor[cpu] = - freq_cc_pll[cplx_pll] / core_cplx_pll_div[c_pll_sel]; + freq_c_pll[cplx_pll] / core_cplx_pll_div[c_pll_sel]; } #ifdef CONFIG_PPC_B4860 #define FM1_CLK_SEL 0xe0000000 @@ -122,27 +131,30 @@ void get_sys_info(sys_info_t *sys_info) #define FM1_CLK_SEL 0x1c000000 #define FM1_CLK_SHIFT 26 #endif +#if !defined(CONFIG_FM_PLAT_CLK_DIV) || !defined(CONFIG_PME_PLAT_CLK_DIV) rcw_tmp = in_be32(&gur->rcwsr[7]); +#endif
#ifdef CONFIG_SYS_DPAA_PME +#ifndef CONFIG_PME_PLAT_CLK_DIV switch ((rcw_tmp & PME_CLK_SEL) >> PME_CLK_SHIFT) { case 1: - sys_info->freq_pme = freq_cc_pll[0]; + sys_info->freq_pme = freq_c_pll[CONFIG_SYS_PME_CLK]; break; case 2: - sys_info->freq_pme = freq_cc_pll[0] / 2; + sys_info->freq_pme = freq_c_pll[CONFIG_SYS_PME_CLK] / 2; break; case 3: - sys_info->freq_pme = freq_cc_pll[0] / 3; + sys_info->freq_pme = freq_c_pll[CONFIG_SYS_PME_CLK] / 3; break; case 4: - sys_info->freq_pme = freq_cc_pll[0] / 4; + sys_info->freq_pme = freq_c_pll[CONFIG_SYS_PME_CLK] / 4; break; case 6: - sys_info->freq_pme = freq_cc_pll[1] / 2; + sys_info->freq_pme = freq_c_pll[CONFIG_SYS_PME_CLK + 1] / 2; break; case 7: - sys_info->freq_pme = freq_cc_pll[1] / 3; + sys_info->freq_pme = freq_c_pll[CONFIG_SYS_PME_CLK + 1] / 3; break; default: printf("Error: Unknown PME clock select!\n"); @@ -151,6 +163,10 @@ void get_sys_info(sys_info_t *sys_info) break;
} +#else + sys_info->freq_pme = sys_info->freq_systembus / CONFIG_SYS_PME_CLK; + +#endif #endif
#ifdef CONFIG_SYS_DPAA_QBMAN @@ -158,27 +174,28 @@ void get_sys_info(sys_info_t *sys_info) #endif
#ifdef CONFIG_SYS_DPAA_FMAN +#ifndef CONFIG_FM_PLAT_CLK_DIV switch ((rcw_tmp & FM1_CLK_SEL) >> FM1_CLK_SHIFT) { case 1: - sys_info->freq_fman[0] = freq_cc_pll[3]; + sys_info->freq_fman[0] = freq_c_pll[CONFIG_SYS_FM1_CLK]; break; case 2: - sys_info->freq_fman[0] = freq_cc_pll[3] / 2; + sys_info->freq_fman[0] = freq_c_pll[CONFIG_SYS_FM1_CLK] / 2; break; case 3: - sys_info->freq_fman[0] = freq_cc_pll[3] / 3; + sys_info->freq_fman[0] = freq_c_pll[CONFIG_SYS_FM1_CLK] / 3; break; case 4: - sys_info->freq_fman[0] = freq_cc_pll[3] / 4; + sys_info->freq_fman[0] = freq_c_pll[CONFIG_SYS_FM1_CLK] / 4; break; case 5: sys_info->freq_fman[0] = sys_info->freq_systembus; break; case 6: - sys_info->freq_fman[0] = freq_cc_pll[4] / 2; + sys_info->freq_fman[0] = freq_c_pll[CONFIG_SYS_FM1_CLK + 1] / 2; break; case 7: - sys_info->freq_fman[0] = freq_cc_pll[4] / 3; + sys_info->freq_fman[0] = freq_c_pll[CONFIG_SYS_FM1_CLK + 1] / 3; break; default: printf("Error: Unknown FMan1 clock select!\n"); @@ -187,27 +204,28 @@ void get_sys_info(sys_info_t *sys_info) break; } #if (CONFIG_SYS_NUM_FMAN) == 2 +#ifdef CONFIG_SYS_FM2_CLK #define FM2_CLK_SEL 0x00000038 #define FM2_CLK_SHIFT 3 rcw_tmp = in_be32(&gur->rcwsr[15]); switch ((rcw_tmp & FM2_CLK_SEL) >> FM2_CLK_SHIFT) { case 1: - sys_info->freq_fman[1] = freq_cc_pll[4]; + sys_info->freq_fman[1] = freq_c_pll[CONFIG_SYS_FM2_CLK + 1]; break; case 2: - sys_info->freq_fman[1] = freq_cc_pll[4] / 2; + sys_info->freq_fman[1] = freq_c_pll[CONFIG_SYS_FM2_CLK + 1] / 2; break; case 3: - sys_info->freq_fman[1] = freq_cc_pll[4] / 3; + sys_info->freq_fman[1] = freq_c_pll[CONFIG_SYS_FM2_CLK + 1] / 3; break; case 4: - sys_info->freq_fman[1] = freq_cc_pll[4] / 4; + sys_info->freq_fman[1] = freq_c_pll[CONFIG_SYS_FM2_CLK + 1] / 4; break; case 6: - sys_info->freq_fman[1] = freq_cc_pll[3] / 2; + sys_info->freq_fman[1] = freq_c_pll[CONFIG_SYS_FM2_CLK] / 2; break; case 7: - sys_info->freq_fman[1] = freq_cc_pll[3] / 3; + sys_info->freq_fman[1] = freq_c_pll[CONFIG_SYS_FM2_CLK] / 3; break; default: printf("Error: Unknown FMan2 clock select!\n"); @@ -215,8 +233,12 @@ void get_sys_info(sys_info_t *sys_info) sys_info->freq_fman[1] = sys_info->freq_systembus / 2; break; } +#endif #endif /* CONFIG_SYS_NUM_FMAN == 2 */ -#endif /* CONFIG_SYS_DPAA_FMAN */ +#else + sys_info->freq_fman[0] = sys_info->freq_systembus / CONFIG_SYS_FM1_CLK; +#endif +#endif
#else /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */
@@ -226,7 +248,7 @@ void get_sys_info(sys_info_t *sys_info) u32 cplx_pll = core_cplx_PLL[c_pll_sel];
sys_info->freq_processor[cpu] = - freq_cc_pll[cplx_pll] / core_cplx_pll_div[c_pll_sel]; + freq_c_pll[cplx_pll] / core_cplx_pll_div[c_pll_sel]; } #define PME_CLK_SEL 0x80000000 #define FM1_CLK_SEL 0x40000000 @@ -246,9 +268,9 @@ void get_sys_info(sys_info_t *sys_info) #ifdef CONFIG_SYS_DPAA_PME if (rcw_tmp & PME_CLK_SEL) { if (rcw_tmp & HWA_ASYNC_DIV) - sys_info->freq_pme = freq_cc_pll[HWA_CC_PLL] / 4; + sys_info->freq_pme = freq_c_pll[HWA_CC_PLL] / 4; else - sys_info->freq_pme = freq_cc_pll[HWA_CC_PLL] / 2; + sys_info->freq_pme = freq_c_pll[HWA_CC_PLL] / 2; } else { sys_info->freq_pme = sys_info->freq_systembus / 2; } @@ -257,18 +279,18 @@ void get_sys_info(sys_info_t *sys_info) #ifdef CONFIG_SYS_DPAA_FMAN if (rcw_tmp & FM1_CLK_SEL) { if (rcw_tmp & HWA_ASYNC_DIV) - sys_info->freq_fman[0] = freq_cc_pll[HWA_CC_PLL] / 4; + sys_info->freq_fman[0] = freq_c_pll[HWA_CC_PLL] / 4; else - sys_info->freq_fman[0] = freq_cc_pll[HWA_CC_PLL] / 2; + sys_info->freq_fman[0] = freq_c_pll[HWA_CC_PLL] / 2; } else { sys_info->freq_fman[0] = sys_info->freq_systembus / 2; } #if (CONFIG_SYS_NUM_FMAN) == 2 if (rcw_tmp & FM2_CLK_SEL) { if (rcw_tmp & HWA_ASYNC_DIV) - sys_info->freq_fman[1] = freq_cc_pll[HWA_CC_PLL] / 4; + sys_info->freq_fman[1] = freq_c_pll[HWA_CC_PLL] / 4; else - sys_info->freq_fman[1] = freq_cc_pll[HWA_CC_PLL] / 2; + sys_info->freq_fman[1] = freq_c_pll[HWA_CC_PLL] / 2; } else { sys_info->freq_fman[1] = sys_info->freq_systembus / 2; } diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index b744049..5adee17 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -538,6 +538,7 @@ #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ #ifdef CONFIG_PPC_T4240 #define CONFIG_MAX_CPUS 12 +#define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1, 4 } #define CONFIG_SYS_NUM_FM1_DTSEC 8 #define CONFIG_SYS_NUM_FM1_10GEC 2 #define CONFIG_SYS_NUM_FM2_DTSEC 8 @@ -545,6 +546,7 @@ #define CONFIG_NUM_DDR_CONTROLLERS 3 #else #define CONFIG_MAX_CPUS 8 +#define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1 } #define CONFIG_SYS_NUM_FM1_DTSEC 7 #define CONFIG_SYS_NUM_FM1_10GEC 1 #define CONFIG_SYS_NUM_FM2_DTSEC 7 @@ -559,9 +561,12 @@ #define CONFIG_SYS_FSL_SRDS_4 #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_SYS_NUM_FMAN 2 +#define CONFIG_SYS_PME_CLK 0 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_SYS_FMAN_V3 +#define CONFIG_SYS_FM1_CLK 3 +#define CONFIG_SYS_FM2_CLK 3 #define CONFIG_SYS_FM_MURAM_SIZE 0x60000 #define CONFIG_SYS_FSL_TBCLK_DIV 16 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v3.0" @@ -589,6 +594,7 @@ #define CONFIG_SYS_FSL_SRDS_2 #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_SYS_NUM_FMAN 1 +#define CONFIG_SYS_FM1_CLK 0 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 4 #define CONFIG_SYS_FMAN_V3 @@ -605,6 +611,7 @@ #define CONFIG_SYS_FSL_CORES_PER_CLUSTER 4 #define CONFIG_MAX_CPUS 4 #define CONFIG_SYS_FSL_NUM_CC_PLLS 4 +#define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 4, 4, 4 } #define CONFIG_SYS_NUM_FM1_DTSEC 6 #define CONFIG_SYS_NUM_FM1_10GEC 2 #define CONFIG_NUM_DDR_CONTROLLERS 2 @@ -616,6 +623,7 @@ #define CONFIG_MAX_CPUS 2 #define CONFIG_SYS_FSL_CORES_PER_CLUSTER 2 #define CONFIG_SYS_FSL_NUM_CC_PLLS 4 +#define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 4 } #define CONFIG_SYS_NUM_FM1_DTSEC 4 #define CONFIG_SYS_NUM_FM1_10GEC 0 #define CONFIG_NUM_DDR_CONTROLLERS 1 @@ -633,15 +641,21 @@ #define CONFIG_MAX_CPUS 2 #endif #define CONFIG_SYS_FSL_NUM_CC_PLLS 2 +#define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1, 1, 1 } +#define CONFIG_SYS_SDHC_CLOCK 0 #define CONFIG_SYS_FSL_NUM_LAWS 16 #define CONFIG_SYS_FSL_SRDS_1 #define CONFIG_SYS_FSL_SEC_COMPAT 5 #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 5 #define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_PME_PLAT_CLK_DIV 2 +#define CONFIG_SYS_PME_CLK CONFIG_PME_PLAT_CLK_DIV #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_5_0 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_SYS_FMAN_V3 +#define CONFIG_FM_PLAT_CLK_DIV 1 +#define CONFIG_SYS_FM1_CLK CONFIG_FM_PLAT_CLK_DIV #define CONFIG_SYS_FM_MURAM_SIZE 0x30000 #define CONFIG_SYS_FSL_TBCLK_DIV 32 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.4" diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 3a10d77..00f17b6 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -2016,20 +2016,13 @@ typedef struct ccsr_clk { u8 res_004[0x0c]; u32 clkcgnhwacsr;/* clock generator n hardware accelerator */ u8 res_014[0x0c]; - } clkcsr[8]; - u8 res_100[0x700]; /* 0x100 */ - u32 pllc1gsr; /* 0x800 Cluster PLL 1 General Status */ - u8 res10[0x1c]; - u32 pllc2gsr; /* 0x820 Cluster PLL 2 General Status */ - u8 res11[0x1c]; - u32 pllc3gsr; /* 0x840 Cluster PLL 3 General Status */ - u8 res12[0x1c]; - u32 pllc4gsr; /* 0x860 Cluster PLL 4 General Status */ - u8 res13[0x1c]; - u32 pllc5gsr; /* 0x880 Cluster PLL 5 General Status */ - u8 res14[0x1c]; - u32 pllc6gsr; /* 0x8a0 Cluster PLL 6 General Status */ - u8 res15[0x35c]; + } clkcsr[12]; + u8 res_100[0x680]; /* 0x100 */ + struct { + u32 pllcngsr; + u8 res10[0x1c]; + } pllcgsr[12]; + u8 res21[0x280]; u32 pllpgsr; /* 0xc00 Platform PLL General Status */ u8 res16[0x1c]; u32 plldgsr; /* 0xc20 DDR PLL General Status */
Applied to u-boot-mpc85xx/next, pending merging to u-boot-mpc85xx/master branch.
York
Prabhakar Kushwaha
York Sun
