device that supports both usb host & usb device modes?
Hi all,
I am searching for HW that supports both USB host & USB device/gadget mode, on the same USB port, capable of switching between these modes at runtime.
Preferably supported in upstream kernel.
Has anyone done this for example with Raspberry Pi?
Thanks.
Marek
Hi Marek,
On 10/10/24 9:31 AM, Marek Behún wrote:
Hi all,
I'm doing a very simple test on our (formerly known as Theobroma Systems) RK3399 Puma with Haikou devkit and it seems to work fine (insert USB stick into microUSB, detect the stick was connected, remove USB stick, loop microUSB to USB, configure as ACM, send test123test123test one way and then the other) as I have not commented out the test for our internal releases :)
I believe that our RK3588 Tiger with Haikou devkit also supports it (same test) but I am not the one who upstreamed nor tested that part (and it doesn't work on our devices in peripheral mode on Rockchip BSP kernel 5.10/6.1).
I don't think we do anything crazy here on the HW level, so I would say anything based on RK3399 and RK3588(S) which advertises an USB OTG port should be able to work. For RK3588(S) maybe check if it's on USB-C, as I am not entirely sure whether we (upstream kernel) support FUSB302 (used in the reference design from Rockchip I believe, so most manufacturers do use them to limit risks) USB-C connector for OTG just yet (about to though if I remember correctly). Maybe have a look on the side of RK356x (RK3566/RK3568) as well, I've seen a few with ROCKUSB enabled in U-Boot, which means OTG (at least in peripheral mode) is supported in U-Boot.
For reference, this is the test I run: """ #!/bin/sh # Change UDC environment variable according to USB controller connected to USB OTG port
set -eu
UDC=${UDC:-"fc000000.usb"}
cleanup_usb_otg() { echo "" > "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/UDC" rm "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/configs/conf.1/acm.1" rmdir "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/configs/conf.1/strings/0x409/" rmdir "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/configs/conf.1/" rmdir "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/functions/acm.1/" rmdir "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/strings/0x409/" rmdir "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/" }
run_cmd() { set -x "$@" set +x }
test_serial() { TX=$1 RX=$2 RXPROOF=$(mktemp) ORIG=$(mktemp)
(cat "$RX" > "$RXPROOF")& PID=$!
printf "test123test123test\n" > "$ORIG" # NOTE: \r instead of \n # The message is sent only if \r or \n is passed, however the receiving # end adds an additional newline. Therefore, to check data integrity the # last character is different in the reference file and the message # being sent. printf "test123test123test\r" > "$TX"
# Give some time for the message to make it to the other side of the # communication before killing the process. sleep 1
kill $PID wait $PID || true
diff "$ORIG" "$RXPROOF"
rm -rf "$ORIG" "$RXPROOF" }
CONFIGFS_HOME=$(findmnt --noheadings --types configfs -o target)
if [ -z "$CONFIGFS_HOME" ]; then CONFIGFS_HOME=$(mktemp --directory) run_cmd mount none -t configfs "$CONFIGFS_HOME" fi
if [ -e "$CONFIGFS_HOME/usb_gadget/q7-usb-p2" ]; then set +e run_cmd cleanup_usb_otg set -e fi
run_cmd mkdir "$CONFIGFS_HOME/usb_gadget/q7-usb-p2"
run_cmd echo 0xabcd > "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/idVendor" run_cmd echo 0xef01 > "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/idProduct" run_cmd mkdir "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/strings/0x409" run_cmd echo SN1234567890 > "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/strings/0x409/serialnumber" run_cmd echo Theobroma > "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/strings/0x409/manufacturer" run_cmd echo Tiger-Haikou > "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/strings/0x409/product"
run_cmd mkdir "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/configs/conf.1/" run_cmd mkdir "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/configs/conf.1/strings/0x409" run_cmd echo "USB ACM test" > "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/configs/conf.1/strings/0x409/configuration"
run_cmd mkdir "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/functions/acm.1"
run_cmd ln -s "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/functions/acm.1" "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/configs/conf.1"
run_cmd echo "$UDC" > "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/UDC"
# Give some time for the ACM device to be probed by the kernel sleep 2
ACM="/dev/ttyACM0" GS="/dev/ttyGS$(cat "$CONFIGFS_HOME/usb_gadget/q7-usb-p2/functions/acm.1/port_num")"
run_cmd test_serial "$ACM" "$GS" run_cmd test_serial "$GS" "$ACM" echo "All good!" """
Once run, connect a USB stick to the port, it should be detected.
Cheers, Quentin
On 10/10/2024 09:31, Marek Behún wrote:
Hi all,
The following commercial dev boards support dual and runtime switch on mainline U-Boot and Mainline Linux: - Khadas VIM3/L (with external supply) - Odroid-N2(+) https://www.hardkernel.com/shop/odroid-n2-with-4gbyte-ram-2/ - Odroid-N2L https://www.hardkernel.com/shop/odroid-n2l-with-2gbyte-ram/ - Odroid-HC4 https://www.hardkernel.com/shop/odroid-hc4/ - Libre Computer AML-A311D-CC https://libre.computer/products/aml-a311d-cc/ (with external supply) - Libre Computer AML-S905D3-CC https://libre.computer/products/aml-s905d3-cc/ (with external supply) - BananaPi M5 https://wiki.banana-pi.org/Banana_Pi_BPI-M5 (with external supply) - BananaPi M2S hhttps://wiki.banana-pi.org/Banana_Pi_BPI-M2S (with external supply)
Neil
Thanks.
Marek
Marek Behún
neil.armstrong@linaro.org
Quentin Schulz
