[U-Boot] FW: [STATUS] Patch status update
Hi everybody,
here is a list of e-mail messages / patches, which I have marked as "open" in my folder. It would we be really helpful if both submitters and responsible custodians could take a look at these and provide feedback if these patches are still to be applied, or have been rejected or obsoleted or are queued in some repo to be pulled soon or whatever.
Thanks in advance.
The list is chronologically sorted (oldes entries first) and consist of
1) Index (only meaningful to me, but for me this is the key information I need) 2) date 3) Subject 4) Link to gmane mailing list archive
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/57219 33 04/18 Jean-Christophe P [U-Boot] [PATCH] omap2420h4: move arch pre lowlevel init to board Never seen this patch. It is 10 months old and before I started custodianship of u-boot-ti.
4452 11/15 Dirk Behme [U-Boot] [PATCH] OMAP3: BeagleBoard: Add expansion board auto detection There is a patch from Khasim and the author is actually Dirk. Tom had some comments.
4702 11/20 Ajay Kumar Gupta [U-Boot] [PATCH] omap3evm: Add board revision function
It had comments and waiting for a new patch 5446 12/10 Nick Thompson [U-Boot] [PATCH] da830evm: Use table driven pin mux configuration
Applied to u-boot-ti and part of a pull request to Tom 5589 12/15 Sanjeev Premi [U-Boot] [PATCH 1/2] omap3: Identify the CPU in arch_cpu_init() http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72707 5590 12/15 Sanjeev Premi [U-Boot] [PATCH 2/2] omap3: Identify cpu in s_init() http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72709 5608 12/16 Sanjeev Premi [U-Boot] [PATCH 1/4] AM35x: Introduce support for AM35x processors http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72727 5611 12/16 Sanjeev Premi [U-Boot] [PATCH 4/4] OMAP3, AM35x: Update the checks for CPU revision
There were comments against these
5668 12/16 Dirk Behme [U-Boot] [PATCH] OMAP3: Beagle: Update revision detection
I believe Khasim is submitting on Dirk's behalf as mentioned above.
5809 12/18 Nick Thompson [U-Boot] [PATCH v3] TI: DaVinci: Updating EMAC driver for DM365, DM646x and DA8XX
I think Ben said that he is going to apply this http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72929 5811 12/18 Sudhakar Rajashek [U-Boot] [PATCH v2 1/3] TI: DaVinci: Prepare for da850 support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72932 5812 12/18 Sudhakar Rajashek [U-Boot] [PATCH v2 2/3] TI: DaVinci: Add board specific code for da850 EVM http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72933 5813 12/18 Sudhakar Rajashek [U-Boot] [PATCH v2 3/3] TI: DaVinci: Create configuration file for da850 EVM
Waiting for next set. Nick Thompson had some comments 5951 12/23 Sanjeev Premi [U-Boot] [PATCH 0/2] omap3: Remove extern declarations from headers http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73072 5952 12/23 Sanjeev Premi [U-Boot] [PATCH 1/2] omap3: Remove externs from config files http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73073 5953 12/23 Sanjeev Premi [U-Boot] [PATCH 2/2] omap3: Remove multiple extern decls for gpmc_cfg
Tom has a pcth for this which I am going to apply provided it applies clean.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73074 5957 12/23 Vaibhav Hiremath [U-Boot] [PATCH 3/3] AM35x: Add support for EMIF4
Waiting for the next revision as there were comments against this.
6126 01/05 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 4/4] Enable I2C bus switching http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73260
6154 01/06 Khasim Syed Moham [U-Boot] TI:OMAP:[PATCH 2/4] Support 720Mhz configuration for OMAP35xx
He has a more recent version of the patches which have received commenst from Tom.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73288
6183 01/07 Sudhakar Rajashek [U-Boot] [PATCH v5] TI DaVinci: Driver for the davinci SPI controller http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73317 applied to u-boot-ti
6244 01/08 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 1/4] OMAP3 Beagle Update revision detection http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73380 6264 01/09 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH] Add support for 720Mhz http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73401 6265 01/09 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH] Add DSS driver for OMAP3 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73402 6267 01/09 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH] Enable DSS driver for Beagle
These are obsolete as there are newer versions
6301 01/11 Sudhakar Rajashek [U-Boot] [PATCH v6] TI DaVinci: Driver for the davinci SPI controller
V7 was applied.
6393 01/13 Khasim Syed Moham [U-Boot] TI:OMAP: Re-submitting Beagle REV C4, 720 Mhz and DSS patches Obsolete.
6399 01/13 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 3/7] API to set twl4030 voltage and dev group 6400 01/13 Khasim Syed Moham [U-Boot] TI:OMAP:[PATCH 4/7] Add support for 720Mhz 6401 01/13 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 5/7] Add DSS driver for OMAP3 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73550 6402 01/13 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 6/7] Enable DSS driver for Beagle
6765 01/18 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 2/7] Enable I2C bus switching http://article.gmane.org/gmane.comp.boot-loaders.u-boot/0 6766 01/18 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 3/7] API to set twl4030 voltage and dev group http://article.gmane.org/gmane.comp.boot-loaders.u-boot/0 6767 01/18 Khasim Syed Moham [U-Boot] TI:OMAP:[PATCH 4/7] Add support for 720Mhz http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73914 6768 01/18 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 5/7] Add DSS driver for OMAP3 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/0 6769 01/18 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 6/7] Enable DSS driver for Beagle http://article.gmane.org/gmane.comp.hardware.beagleboard.user/0 6770 01/18 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 7/7] Add 720Mhz support for Beagle Rev C4 http://article.gmane.org/gmane.comp.hardware.beagleboard.user/0 6774 01/18 Richard Retanubun [U-Boot] [PATCH V2] PPC: Record uboot's relocated address in RAM and show in bdinfo. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73925 6783 01/18 Nick Thompson [U-Boot] [PATCH v2] da830evm: Use table driven pin mux configuration
Obsolete. I applied an updated version
7166 01/25 Khasim Syed Moham [U-Boot] Fwd: TI:OMAP: [PATCH 6/7] Enable DSS driver for Beagle http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74300 7167 01/25 Khasim Syed Moham [U-Boot] Fwd: TI:OMAP: [PATCH 5/7] Add DSS driver for OMAP3
Khasim's patches have received comments from Tom.
Thanks, Sandeep
Dear Sandeep,
In message 0554BEF07D437848AF01B9C9B5F0BC5D9856D5DA@dlee01.ent.ti.com you wrote:
I know. Maybe you have some spare cycles to have a look at it.
Thanks.
Has this been posted on the mailing list yet?
Thanks a lot for the review and the comments.
Paulraj, Sandeep
