[U-Boot] [PATCH 0/8 v11] Add TMU support for Exynos5250 based SMDK5250
This patch series adds support for TMU driver using device tree for Exynos5250 based SMDK5250 board.
Changes since v10: - Patch-1: Renamed asm/arch/exynos-tmu.h to asm/arch/tmu.h. - Patch-2: None. - Patch-3: None. - Patch-4: None. - Patch-5: None. - Patch-6: None. - Patch-7: None. - Patch-8: None.
Akshay Saraswat (8): Exynos5: TMU: Add driver for Thermal Management Unit Exynos5: FDT: Add TMU device node values Exynos5: TMU: Add TMU init and status check Exynos5: Config: Enable support for Exynos TMU driver TMU: Add TMU support in dtt command Exynos5: Config: Enable dtt command for TMU Exynos5: TMU: Add hardware tripping Exynos5: FDT: Add a H/W-trip member to TMU node
arch/arm/cpu/armv7/exynos/power.c | 12 ++ arch/arm/dts/exynos5250.dtsi | 5 + arch/arm/include/asm/arch-exynos/power.h | 4 + arch/arm/include/asm/arch-exynos/tmu.h | 58 ++++++ board/samsung/dts/exynos5250-smdk5250.dts | 13 ++ board/samsung/smdk5250/smdk5250.c | 39 ++++ common/cmd_dtt.c | 32 ++- doc/device-tree-bindings/exynos/tmu.txt | 44 +++++ drivers/power/Makefile | 1 + drivers/power/exynos-tmu.c | 319 ++++++++++++++++++++++++++++++ include/configs/exynos5250-dt.h | 5 + include/fdtdec.h | 1 + include/tmu.h | 46 +++++ lib/fdtdec.c | 1 + 14 files changed, 579 insertions(+), 1 deletion(-) create mode 100644 arch/arm/include/asm/arch-exynos/tmu.h create mode 100644 doc/device-tree-bindings/exynos/tmu.txt create mode 100644 drivers/power/exynos-tmu.c create mode 100644 include/tmu.h
Adding Exynos Thermal Management Unit driver to monitor SOC temperature and take actions corresponding to states of TMU.
Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes since v10: - Renamed as/asch/exynos-tmu.h to asm/arch/tmu.h.
arch/arm/include/asm/arch-exynos/tmu.h | 58 +++++++ drivers/power/Makefile | 1 + drivers/power/exynos-tmu.c | 304 +++++++++++++++++++++++++++++++++ include/tmu.h | 46 +++++ 4 files changed, 409 insertions(+) create mode 100644 arch/arm/include/asm/arch-exynos/tmu.h create mode 100644 drivers/power/exynos-tmu.c create mode 100644 include/tmu.h
diff --git a/arch/arm/include/asm/arch-exynos/tmu.h b/arch/arm/include/asm/arch-exynos/tmu.h new file mode 100644 index 0000000..31399b0 --- /dev/null +++ b/arch/arm/include/asm/arch-exynos/tmu.h @@ -0,0 +1,58 @@ +/* + * Copyright (c) 2012 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * Akshay Saraswat akshay.s@samsung.com + * + * EXYNOS - Thermal Management Unit + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_ARCH_TMU_H +#define __ASM_ARCH_TMU_H + +struct exynos5_tmu_reg { + unsigned triminfo; + unsigned rsvd1; + unsigned rsvd2; + unsigned rsvd3; + unsigned rsvd4; + unsigned triminfo_control; + unsigned rsvd5; + unsigned rsvd6; + unsigned tmu_control; + unsigned rsvd7; + unsigned tmu_status; + unsigned sampling_internal; + unsigned counter_value0; + unsigned counter_value1; + unsigned rsvd8; + unsigned rsvd9; + unsigned current_temp; + unsigned rsvd10; + unsigned rsvd11; + unsigned rsvd12; + unsigned threshold_temp_rise; + unsigned threshold_temp_fall; + unsigned rsvd13; + unsigned rsvd14; + unsigned past_temp3_0; + unsigned past_temp7_4; + unsigned past_temp11_8; + unsigned past_temp15_12; + unsigned inten; + unsigned intstat; + unsigned intclear; + unsigned rsvd15; + unsigned emul_con; +}; +#endif /* __ASM_ARCH_TMU_H */ diff --git a/drivers/power/Makefile b/drivers/power/Makefile index 8c71901..1dac16a 100644 --- a/drivers/power/Makefile +++ b/drivers/power/Makefile @@ -25,6 +25,7 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libpower.o
+COBJS-$(CONFIG_EXYNOS_TMU) += exynos-tmu.o COBJS-$(CONFIG_FTPMU010_POWER) += ftpmu010.o COBJS-$(CONFIG_TPS6586X_POWER) += tps6586x.o COBJS-$(CONFIG_TWL4030_POWER) += twl4030.o diff --git a/drivers/power/exynos-tmu.c b/drivers/power/exynos-tmu.c new file mode 100644 index 0000000..cc5ffee --- /dev/null +++ b/drivers/power/exynos-tmu.c @@ -0,0 +1,304 @@ +/* + * Copyright (c) 2012 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * Akshay Saraswat akshay.s@samsung.com + * + * EXYNOS - Thermal Management Unit + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <errno.h> +#include <fdtdec.h> +#include <tmu.h> +#include <asm/arch/tmu.h> + +#define TRIMINFO_RELOAD 1 +#define CORE_EN 1 + +#define INTEN_RISE0 1 +#define INTEN_RISE1 (1 << 4) +#define INTEN_RISE2 (1 << 8) +#define INTEN_FALL0 (1 << 16) +#define INTEN_FALL1 (1 << 20) +#define INTEN_FALL2 (1 << 24) + +#define TRIM_INFO_MASK 0xff + +#define INTCLEAR_RISE0 1 +#define INTCLEAR_RISE1 (1 << 4) +#define INTCLEAR_RISE2 (1 << 8) +#define INTCLEAR_FALL0 (1 << 16) +#define INTCLEAR_FALL1 (1 << 20) +#define INTCLEAR_FALL2 (1 << 24) +#define INTCLEARALL (INTCLEAR_RISE0 | INTCLEAR_RISE1 | \ + INTCLEAR_RISE2 | INTCLEAR_FALL0 | \ + INTCLEAR_FALL1 | INTCLEAR_FALL2) + +/* Tmeperature threshold values for various thermal events */ +struct temperature_params { + /* minimum value in temperature code range */ + unsigned int min_val; + /* maximum value in temperature code range */ + unsigned int max_val; + /* temperature threshold to start warning */ + unsigned int start_warning; + /* temperature threshold CPU tripping */ + unsigned int start_tripping; +}; + +/* Pre-defined values and thresholds for calibration of current temperature */ +struct tmu_data { + /* pre-defined temperature thresholds */ + struct temperature_params ts; + /* pre-defined efuse range minimum value */ + unsigned int efuse_min_value; + /* pre-defined efuse value for temperature calibration */ + unsigned int efuse_value; + /* pre-defined efuse range maximum value */ + unsigned int efuse_max_value; + /* current temperature sensing slope */ + unsigned int slope; +}; + +/* TMU device specific details and status */ +struct tmu_info { + /* base Address for the TMU */ + unsigned tmu_base; + /* pre-defined values for calibration and thresholds */ + struct tmu_data data; + /* value required for triminfo_25 calibration */ + unsigned int te1; + /* value required for triminfo_85 calibration */ + unsigned int te2; + /* Value for measured data calibration */ + int dc_value; + /* enum value indicating status of the TMU */ + int tmu_state; +}; + +/* Global struct tmu_info variable to store init values */ +static struct tmu_info gbl_info; + +/* + * Get current temperature code from register, + * then calculate and calibrate it's value + * in degree celsius. + * + * @return current temperature of the chip as sensed by TMU + */ +static int get_cur_temp(struct tmu_info *info) +{ + int cur_temp; + struct exynos5_tmu_reg *reg = (struct exynos5_tmu_reg *)info->tmu_base; + + /* + * Temperature code range between min 25 and max 125. + * May run more than once for first call as initial sensing + * has not yet happened. + */ + do { + cur_temp = readl(®->current_temp) & 0xff; + } while (cur_temp == 0 && info->tmu_state == TMU_STATUS_NORMAL); + + /* Calibrate current temperature */ + cur_temp = cur_temp - info->te1 + info->dc_value; + + return cur_temp; +} + +/* + * Monitors status of the TMU device and exynos temperature + * + * @param temp pointer to the current temperature value + * @return enum tmu_status_t value, code indicating event to execute + */ +enum tmu_status_t tmu_monitor(int *temp) +{ + int cur_temp; + struct tmu_data *data = &gbl_info.data; + + if (gbl_info.tmu_state == TMU_STATUS_INIT) + return TMU_STATUS_INIT; + + /* Read current temperature of the SOC */ + cur_temp = get_cur_temp(&gbl_info); + *temp = cur_temp; + + /* Temperature code lies between min 25 and max 125 */ + if (cur_temp >= data->ts.start_tripping && + cur_temp <= data->ts.max_val) { + return TMU_STATUS_TRIPPED; + } else if (cur_temp >= data->ts.start_warning) { + return TMU_STATUS_WARNING; + } else if (cur_temp < data->ts.start_warning && + cur_temp >= data->ts.min_val) { + return TMU_STATUS_NORMAL; + } else { + /* Temperature code does not lie between min 25 and max 125 */ + gbl_info.tmu_state = TMU_STATUS_INIT; + debug("EXYNOS_TMU: Thermal reading failed\n"); + return TMU_STATUS_INIT; + } +} + +/* + * Get TMU specific pre-defined values from FDT + * + * @param info pointer to the tmu_info struct + * @param blob FDT blob + * @return int value, 0 for success + */ +static int get_tmu_fdt_values(struct tmu_info *info, const void *blob) +{ +#ifdef CONFIG_OF_CONTROL + int node; + int error = 0; + + /* Get the node from FDT for TMU */ + node = fdtdec_next_compatible(blob, 0, + COMPAT_SAMSUNG_EXYNOS_TMU); + if (node < 0) { + debug("EXYNOS_TMU: No node for tmu in device tree\n"); + return -1; + } + + /* + * Get the pre-defined TMU specific values from FDT. + * All of these are expected to be correct otherwise + * miscalculation of register values in tmu_setup_parameters + * may result in misleading current temperature. + */ + info->tmu_base = fdtdec_get_addr(blob, node, "reg"); + if (info->tmu_base == FDT_ADDR_T_NONE) { + debug("%s: Missing tmu-base\n", __func__); + return -1; + } + info->data.ts.min_val = fdtdec_get_int(blob, + node, "samsung,min-temp", -1); + error |= info->data.ts.min_val; + info->data.ts.max_val = fdtdec_get_int(blob, + node, "samsung,max-temp", -1); + error |= info->data.ts.max_val; + info->data.ts.start_warning = fdtdec_get_int(blob, + node, "samsung,start-warning", -1); + error |= info->data.ts.start_warning; + info->data.ts.start_tripping = fdtdec_get_int(blob, + node, "samsung,start-tripping", -1); + error |= info->data.ts.start_tripping; + info->data.efuse_min_value = fdtdec_get_int(blob, + node, "samsung,efuse-min-value", -1); + error |= info->data.efuse_min_value; + info->data.efuse_value = fdtdec_get_int(blob, + node, "samsung,efuse-value", -1); + error |= info->data.efuse_value; + info->data.efuse_max_value = fdtdec_get_int(blob, + node, "samsung,efuse-max-value", -1); + error |= info->data.efuse_max_value; + info->data.slope = fdtdec_get_int(blob, + node, "samsung,slope", -1); + error |= info->data.slope; + info->dc_value = fdtdec_get_int(blob, + node, "samsung,dc-value", -1); + error |= info->dc_value; + + if (error == -1) { + debug("fail to get tmu node properties\n"); + return -1; + } +#endif + + return 0; +} + +/* + * Calibrate and calculate threshold values and + * enable interrupt levels + * + * @param info pointer to the tmu_info struct + */ +static void tmu_setup_parameters(struct tmu_info *info) +{ + unsigned int te_code, con; + unsigned int warning_code, trip_code; + unsigned int cooling_temp; + unsigned int rising_value; + struct tmu_data *data = &info->data; + struct exynos5_tmu_reg *reg = (struct exynos5_tmu_reg *)info->tmu_base; + + /* Must reload for reading efuse value from triminfo register */ + writel(TRIMINFO_RELOAD, ®->triminfo_control); + + /* Get the compensation parameter */ + te_code = readl(®->triminfo); + info->te1 = te_code & TRIM_INFO_MASK; + info->te2 = ((te_code >> 8) & TRIM_INFO_MASK); + + if ((data->efuse_min_value > info->te1) || + (info->te1 > data->efuse_max_value) + || (info->te2 != 0)) + info->te1 = data->efuse_value; + + /* Get RISING & FALLING Threshold value */ + warning_code = data->ts.start_warning + + info->te1 - info->dc_value; + trip_code = data->ts.start_tripping + + info->te1 - info->dc_value; + cooling_temp = 0; + + rising_value = ((warning_code << 8) | (trip_code << 16)); + + /* Set interrupt level */ + writel(rising_value, ®->threshold_temp_rise); + writel(cooling_temp, ®->threshold_temp_fall); + + /* + * Init TMU control tuning parameters + * [28:24] VREF - Voltage reference + * [15:13] THERM_TRIP_MODE - Tripping mode + * [12] THERM_TRIP_EN - Thermal tripping enable + * [11:8] BUF_SLOPE_SEL - Gain of amplifier + * [6] THERM_TRIP_BY_TQ_EN - Tripping by TQ pin + */ + writel(data->slope, ®->tmu_control); + + writel(INTCLEARALL, ®->intclear); + + /* TMU core enable */ + con = readl(®->tmu_control); + con |= CORE_EN; + + writel(con, ®->tmu_control); + + /* LEV0 LEV1 LEV2 interrupt enable */ + writel(INTEN_RISE0 | INTEN_RISE1 | INTEN_RISE2, ®->inten); +} + +/* + * Initialize TMU device + * + * @param blob FDT blob + * @return int value, 0 for success + */ +int tmu_init(const void *blob) +{ + gbl_info.tmu_state = TMU_STATUS_INIT; + if (get_tmu_fdt_values(&gbl_info, blob) < 0) + goto ret; + + tmu_setup_parameters(&gbl_info); + gbl_info.tmu_state = TMU_STATUS_NORMAL; +ret: + + return gbl_info.tmu_state; +} diff --git a/include/tmu.h b/include/tmu.h new file mode 100644 index 0000000..da07a22 --- /dev/null +++ b/include/tmu.h @@ -0,0 +1,46 @@ +/* + * Copyright (c) 2012 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * Akshay Saraswat akshay.s@samsung.com + * + * Thermal Management Unit + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _TMU_H +#define _TMU_H + +enum tmu_status_t { + TMU_STATUS_INIT = -1, + TMU_STATUS_NORMAL = 0, + TMU_STATUS_WARNING, + TMU_STATUS_TRIPPED, +}; + +/* + * Monitors status of the TMU device and exynos temperature + * + * @param temp pointer to the current temperature value + * @return enum tmu_status_t value, code indicating event to execute + * and -1 on error + */ +enum tmu_status_t tmu_monitor(int *temp); + +/* + * Initialize TMU device + * + * @param blob FDT blob + * @return int value, 0 for success + */ +int tmu_init(const void *blob); +#endif /* _THERMAL_H_ */
Fdt entry for Exynos TMU driver specific pre-defined values used for calibration of current temperature and defining threshold values.
Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes since v10: - None.
arch/arm/dts/exynos5250.dtsi | 5 ++++ board/samsung/dts/exynos5250-smdk5250.dts | 12 +++++++++ doc/device-tree-bindings/exynos/tmu.txt | 41 +++++++++++++++++++++++++++++++ include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 5 files changed, 60 insertions(+) create mode 100644 doc/device-tree-bindings/exynos/tmu.txt
diff --git a/arch/arm/dts/exynos5250.dtsi b/arch/arm/dts/exynos5250.dtsi index ed8c8dd..61d35a8 100644 --- a/arch/arm/dts/exynos5250.dtsi +++ b/arch/arm/dts/exynos5250.dtsi @@ -151,4 +151,9 @@ }; };
+ tmu@10060000 { + compatible = "samsung,exynos-tmu"; + reg = <0x10060000 0x10000>; + }; + }; diff --git a/board/samsung/dts/exynos5250-smdk5250.dts b/board/samsung/dts/exynos5250-smdk5250.dts index cbfab6f..00dac40 100644 --- a/board/samsung/dts/exynos5250-smdk5250.dts +++ b/board/samsung/dts/exynos5250-smdk5250.dts @@ -66,4 +66,16 @@ compatible = "maxim,max77686_pmic"; }; }; + + tmu@10060000 { + samsung,min-temp = <25>; + samsung,max-temp = <125>; + samsung,start-warning = <95>; + samsung,start-tripping = <105>; + samsung,efuse-min-value = <40>; + samsung,efuse-value = <55>; + samsung,efuse-max-value = <100>; + samsung,slope = <274761730>; + samsung,dc-value = <25>; + }; }; diff --git a/doc/device-tree-bindings/exynos/tmu.txt b/doc/device-tree-bindings/exynos/tmu.txt new file mode 100644 index 0000000..bb734dc --- /dev/null +++ b/doc/device-tree-bindings/exynos/tmu.txt @@ -0,0 +1,41 @@ +Exynos Thermal management Unit + +Required properties: + + - compatible : Should be "samsung,exynos-tmu" for TMU + - samsung,min-temp : Minimum temperature value (25 degree celsius) + - Current temperature of SoC should be more than this value. + - samsung,max-temp : Maximum temperature value (125 degree celsius) + - Current temperature of SoC should be less than this value. + - samsung,start-warning : Temperature at which TMU starts giving warning (degree celsius) + - samsung,start-tripping : Temperature at which system will trip and shutdown (degree celsius) + - samsung,efuse-min-value : SOC efuse min value (Constant 40) + - efuse-value should be more than this value. + - samsung,efuse-value : SOC actual efuse value (Literal value) + - This is the data trimming info. + - This value is used to calculate measuring error. + - samsung,efuse-max-value : SoC max efuse value (Constant 100) + - efuse-value should be less than this value. + - samsung,slope : Default value 274761730 (Constant 0x1060_8802). + - This is the default value for TMU_CONTROL register. + - It sets the gain of amplifier to the positive-tc generator block. + - It selects thermal tripping mode and enables thermal tripping. + - samsung,dc-value : Measured data calibration value (Constant 25) + - Used for tempearture calculation. + - This is 25 because temperature measured is always above 25 degrees. + + +Example: + +tmu@10060000 { + compatible = "samsung,exynos-tmu" + samsung,min-temp = <25>; + samsung,max-temp = <125>; + samsung,start-warning = <95>; + samsung,start-tripping = <105>; + samsung,efuse-min-value = <40>; + samsung,efuse-value = <55>; + samsung,efuse-max-value = <100>; + samsung,slope = <274761730>; + samsung,dc-value = <25>; +}; diff --git a/include/fdtdec.h b/include/fdtdec.h index 77f244f..b9301c8 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -81,6 +81,7 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS_EHCI, /* Exynos EHCI controller */ COMPAT_SAMSUNG_EXYNOS_USB_PHY, /* Exynos phy controller for usb2.0 */ COMPAT_MAXIM_MAX77686_PMIC, /* MAX77686 PMIC */ + COMPAT_SAMSUNG_EXYNOS_TMU, /* Exynos TMU */
COMPAT_COUNT, }; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 3ae348d..5c427ff 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -56,6 +56,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS_EHCI, "samsung,exynos-ehci"), COMPAT(SAMSUNG_EXYNOS_USB_PHY, "samsung,exynos-usb-phy"), COMPAT(MAXIM_MAX77686_PMIC, "maxim,max77686_pmic"), + COMPAT(SAMSUNG_EXYNOS_TMU, "samsung,exynos-tmu"), };
const char *fdtdec_get_compatible(enum fdt_compat_id id)
This adds call to tmu_init() and TMU boot time analysis for the SoC temperature threshold breach.
board/samsung/smdk5250/smdk5250.c | 39 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 39 insertions(+)
diff --git a/board/samsung/smdk5250/smdk5250.c b/board/samsung/smdk5250/smdk5250.c index ffc5ee5..89247d9 100644 --- a/board/samsung/smdk5250/smdk5250.c +++ b/board/samsung/smdk5250/smdk5250.c @@ -37,9 +37,39 @@ #include <asm/arch/dp_info.h> #include <power/pmic.h> #include <power/max77686_pmic.h> +#include <tmu.h>
DECLARE_GLOBAL_DATA_PTR;
+#if defined CONFIG_EXYNOS_TMU +/* + * Boot Time Thermal Analysis for SoC temperature threshold breach + */ +static void boot_temp_check(void) +{ + int temp; + + switch (tmu_monitor(&temp)) { + /* Status TRIPPED ans WARNING means corresponding threshold breach */ + case TMU_STATUS_TRIPPED: + puts("EXYNOS_TMU: TRIPPING! Device power going down ...\n"); + set_ps_hold_ctrl(); + hang(); + break; + case TMU_STATUS_WARNING: + puts("EXYNOS_TMU: WARNING! Temperature very high\n"); + break; + /* + * TMU_STATUS_INIT means something is wrong with temperature sensing + * and TMU status was changed back from NORMAL to INIT. + */ + case TMU_STATUS_INIT: + default: + debug("EXYNOS_TMU: Unknown TMU state\n"); + } +} +#endif + #ifdef CONFIG_USB_EHCI_EXYNOS int board_usb_vbus_init(void) { @@ -59,6 +89,15 @@ int board_usb_vbus_init(void) int board_init(void) { gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); + +#if defined CONFIG_EXYNOS_TMU + if (tmu_init(gd->fdt_blob) != TMU_STATUS_NORMAL) { + debug("%s: Failed to init TMU\n", __func__); + return -1; + } + boot_temp_check(); +#endif + #ifdef CONFIG_EXYNOS_SPI spi_init(); #endif
Enables TMU driver support for exynos5250
include/configs/exynos5250-dt.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index cabd2f2..53ca41f 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -117,6 +117,9 @@ #define CONFIG_BOOTDELAY 3 #define CONFIG_ZERO_BOOTDELAY_CHECK
+/* Thermal Management Unit */ +#define CONFIG_EXYNOS_TMU + /* USB */ #define CONFIG_CMD_USB #define CONFIG_USB_EHCI
Add generic TMU support alongwith i2c sensors in dtt command to enable temperature reading in cases where TMU is present along-with/instead-of i2c sensors.
common/cmd_dtt.c | 32 +++++++++++++++++++++++++++++++- 1 file changed, 31 insertions(+), 1 deletion(-)
diff --git a/common/cmd_dtt.c b/common/cmd_dtt.c index cd94423..edbd4a8 100644 --- a/common/cmd_dtt.c +++ b/common/cmd_dtt.c @@ -27,7 +27,9 @@
#include <dtt.h> #include <i2c.h> +#include <tmu.h>
+#if defined CONFIG_DTT_SENSORS static unsigned long sensor_initialized;
static void _initialize_dtt(void) @@ -59,9 +61,11 @@ void dtt_init(void) /* switch back to original I2C bus */ I2C_SET_BUS(old_bus); } +#endif
-int do_dtt (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) +int dtt_i2c(void) { +#if defined CONFIG_DTT_SENSORS int i; unsigned char sensors[] = CONFIG_DTT_SENSORS; int old_bus; @@ -83,8 +87,34 @@ int do_dtt (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[])
/* switch back to original I2C bus */ I2C_SET_BUS(old_bus); +#endif
return 0; +} + +int dtt_tmu(void) +{ +#if defined CONFIG_TMU_CMD_DTT + int cur_temp; + + /* Sense and return latest thermal info */ + if (tmu_monitor(&cur_temp) == TMU_STATUS_INIT) { + puts("TMU is in unknown state, temperature is invalid\n"); + return -1; + } + printf("Current temperature: %u degrees Celsius\n", cur_temp); +#endif + return 0; +} + +int do_dtt(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + int err = 0; + + err |= dtt_i2c(); + err |= dtt_tmu(); + + return err; } /* do_dtt() */
This enables the dtt command to read the current SOC temperature with the help of TMU
include/configs/exynos5250-dt.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index 53ca41f..8a8e9fe 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -119,6 +119,8 @@
/* Thermal Management Unit */ #define CONFIG_EXYNOS_TMU +#define CONFIG_CMD_DTT +#define CONFIG_TMU_CMD_DTT
This adds hardware tripping at 110 degrees celsius which must enable forced system shutdown in case TMU fails to power off.
arch/arm/cpu/armv7/exynos/power.c | 12 ++++++++++++ arch/arm/include/asm/arch-exynos/power.h | 4 ++++ drivers/power/exynos-tmu.c | 25 ++++++++++++++++++++----- 3 files changed, 36 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/power.c b/arch/arm/cpu/armv7/exynos/power.c index 400c8bc..363c20a 100644 --- a/arch/arm/cpu/armv7/exynos/power.c +++ b/arch/arm/cpu/armv7/exynos/power.c @@ -111,3 +111,15 @@ void set_ps_hold_ctrl(void) if (cpu_is_exynos5()) exynos5_set_ps_hold_ctrl(); } + +/* Enables hardware tripping to power off the system when TMU fails */ +void set_hw_thermal_trip(void) +{ + if (cpu_is_exynos5()) { + struct exynos5_power *power = + (struct exynos5_power *)samsung_get_base_power(); + + /* PS_HOLD_CONTROL register ENABLE_HW_TRIP bit*/ + setbits_le32(&power->ps_hold_control, POWER_ENABLE_HW_TRIP); + } +} diff --git a/arch/arm/include/asm/arch-exynos/power.h b/arch/arm/include/asm/arch-exynos/power.h index f2f73fa..e409b24 100644 --- a/arch/arm/include/asm/arch-exynos/power.h +++ b/arch/arm/include/asm/arch-exynos/power.h @@ -857,6 +857,9 @@ void set_mipi_phy_ctrl(unsigned int dev_index, unsigned int enable);
void set_usbhost_phy_ctrl(unsigned int enable);
+/* Enables hardware tripping to power off the system when TMU fails */ +void set_hw_thermal_trip(void); + #define POWER_USB_HOST_PHY_CTRL_EN (1 << 0) #define POWER_USB_HOST_PHY_CTRL_DISABLE (0 << 0)
@@ -865,6 +868,7 @@ void set_dp_phy_ctrl(unsigned int enable); #define EXYNOS_DP_PHY_ENABLE (1 << 0)
#define EXYNOS_PS_HOLD_CONTROL_DATA_HIGH (1 << 8) +#define POWER_ENABLE_HW_TRIP (1UL << 31)
/* * Set ps_hold data driving value high diff --git a/drivers/power/exynos-tmu.c b/drivers/power/exynos-tmu.c index cc5ffee..f4fa9e1 100644 --- a/drivers/power/exynos-tmu.c +++ b/drivers/power/exynos-tmu.c @@ -22,9 +22,11 @@ #include <fdtdec.h> #include <tmu.h> #include <asm/arch/tmu.h> +#include <asm/arch/power.h>
#define TRIMINFO_RELOAD 1 #define CORE_EN 1 +#define THERM_TRIP_EN (1 << 12)
#define INTEN_RISE0 1 #define INTEN_RISE1 (1 << 4) @@ -55,6 +57,8 @@ struct temperature_params { unsigned int start_warning; /* temperature threshold CPU tripping */ unsigned int start_tripping; + /* temperature threshold for HW tripping */ + unsigned int hardware_tripping; };
/* Pre-defined values and thresholds for calibration of current temperature */ @@ -196,6 +200,9 @@ static int get_tmu_fdt_values(struct tmu_info *info, const void *blob) info->data.ts.start_tripping = fdtdec_get_int(blob, node, "samsung,start-tripping", -1); error |= info->data.ts.start_tripping; + info->data.ts.hardware_tripping = fdtdec_get_int(blob, + node, "samsung,hw-tripping", -1); + error |= info->data.ts.hardware_tripping; info->data.efuse_min_value = fdtdec_get_int(blob, node, "samsung,efuse-min-value", -1); error |= info->data.efuse_min_value; @@ -230,7 +237,7 @@ static int get_tmu_fdt_values(struct tmu_info *info, const void *blob) static void tmu_setup_parameters(struct tmu_info *info) { unsigned int te_code, con; - unsigned int warning_code, trip_code; + unsigned int warning_code, trip_code, hwtrip_code; unsigned int cooling_temp; unsigned int rising_value; struct tmu_data *data = &info->data; @@ -254,9 +261,14 @@ static void tmu_setup_parameters(struct tmu_info *info) + info->te1 - info->dc_value; trip_code = data->ts.start_tripping + info->te1 - info->dc_value; + hwtrip_code = data->ts.hardware_tripping + + info->te1 - info->dc_value; + cooling_temp = 0;
- rising_value = ((warning_code << 8) | (trip_code << 16)); + rising_value = ((warning_code << 8) | + (trip_code << 16) | + (hwtrip_code << 24));
/* Set interrupt level */ writel(rising_value, ®->threshold_temp_rise); @@ -276,12 +288,15 @@ static void tmu_setup_parameters(struct tmu_info *info)
/* TMU core enable */ con = readl(®->tmu_control); - con |= CORE_EN; + con |= THERM_TRIP_EN | CORE_EN;
- /* LEV0 LEV1 LEV2 interrupt enable */ - writel(INTEN_RISE0 | INTEN_RISE1 | INTEN_RISE2, ®->inten); + /* Enable HW thermal trip */ + set_hw_thermal_trip(); + + /* LEV1 LEV2 interrupt enable */ + writel(INTEN_RISE1 | INTEN_RISE2, ®->inten); }
This adds a member to TMU FDT node for providing hardware tripping temperature threshold.
board/samsung/dts/exynos5250-smdk5250.dts | 1 + doc/device-tree-bindings/exynos/tmu.txt | 5 ++++- 2 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/board/samsung/dts/exynos5250-smdk5250.dts b/board/samsung/dts/exynos5250-smdk5250.dts index 00dac40..1c2d52d 100644 --- a/board/samsung/dts/exynos5250-smdk5250.dts +++ b/board/samsung/dts/exynos5250-smdk5250.dts @@ -72,6 +72,7 @@ samsung,max-temp = <125>; samsung,start-warning = <95>; samsung,start-tripping = <105>; + samsung,hw-tripping = <110>; samsung,efuse-min-value = <40>; samsung,efuse-value = <55>; samsung,efuse-max-value = <100>; diff --git a/doc/device-tree-bindings/exynos/tmu.txt b/doc/device-tree-bindings/exynos/tmu.txt index bb734dc..89d3bf0 100644 --- a/doc/device-tree-bindings/exynos/tmu.txt +++ b/doc/device-tree-bindings/exynos/tmu.txt @@ -8,7 +8,9 @@ Required properties: - samsung,max-temp : Maximum temperature value (125 degree celsius) - Current temperature of SoC should be less than this value. - samsung,start-warning : Temperature at which TMU starts giving warning (degree celsius) - - samsung,start-tripping : Temperature at which system will trip and shutdown (degree celsius) + - samsung,start-tripping : Temperature at which TMU shuts down the system (degree celsius) + - samsung,hw-tripping : Temperature at which hardware tripping should happen + in case TMU fails to power off (degree celsius) - samsung,efuse-min-value : SOC efuse min value (Constant 40) - efuse-value should be more than this value. - samsung,efuse-value : SOC actual efuse value (Literal value) @@ -33,6 +35,7 @@ tmu@10060000 { samsung,max-temp = <125>; samsung,start-warning = <95>; samsung,start-tripping = <105>; + samsung,hw-tripping = <110>; samsung,efuse-min-value = <40>; samsung,efuse-value = <55>; samsung,efuse-max-value = <100>;
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Akshay Saraswat
Minkyu Kang
