[U-Boot] [PATCH v2 4/8] x86: slimbootloader: Add serial driver
- Get serial port information from the serial port info hob - Leverage ns16550 driver with slimbootloader specific platform data
Signed-off-by: Aiden Park aiden.park@intel.com --- arch/x86/cpu/slimbootloader/Makefile | 2 +- arch/x86/cpu/slimbootloader/serial.c | 62 +++++++++++++++++++ .../asm/arch-slimbootloader/slimbootloader.h | 33 ++++++++++ 3 files changed, 96 insertions(+), 1 deletion(-) create mode 100644 arch/x86/cpu/slimbootloader/serial.c
diff --git a/arch/x86/cpu/slimbootloader/Makefile b/arch/x86/cpu/slimbootloader/Makefile index 4b0b3e71c9..3e62f564cd 100644 --- a/arch/x86/cpu/slimbootloader/Makefile +++ b/arch/x86/cpu/slimbootloader/Makefile @@ -2,4 +2,4 @@ # # Copyright (C) 2019 Intel Corporation <www.intel.com>
-obj-y += car.o slimbootloader.o hob.o dram.o +obj-y += car.o slimbootloader.o hob.o dram.o serial.o diff --git a/arch/x86/cpu/slimbootloader/serial.c b/arch/x86/cpu/slimbootloader/serial.c new file mode 100644 index 0000000000..186c7a79ef --- /dev/null +++ b/arch/x86/cpu/slimbootloader/serial.c @@ -0,0 +1,62 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Intel Corporation <www.intel.com> + */ + +#include <common.h> +#include <dm.h> +#include <ns16550.h> +#include <serial.h> +#include <asm/arch/slimbootloader.h> + +int slimbootloader_serial_ofdata_to_platdata(struct udevice *dev) +{ + const struct efi_guid guid = LOADER_SERIAL_PORT_INFO_GUID; + struct serial_port_info *serial_info = NULL; + struct ns16550_platdata *plat = dev->platdata; + + serial_info = (struct serial_port_info *) + get_next_guid_hob_data(&guid, gd->arch.hob_list); + + if (!serial_info) { + debug("failed to get serial port information\n"); + return -ENOENT; + } + debug("type:%d base=0x%08x baudrate=%d stride=%d clk=%d\n", + serial_info->type, + serial_info->base, + serial_info->baud, + serial_info->stride, + serial_info->clk); + + /* + * The serial_info->type provides port io or mmio access type info, + * but the access type will be controlled by + * CONFIG_SYS_NS16550_PORT_MAPPED or CONFIG_SYS_NS16550_MEM32. + * + * TBD: ns16550 access type configuration in runtime. + * ex) plat->access_type = serial_info->type + */ + plat->base = serial_info->base; + /* ns16550 uses reg_shift, then covert stride to shift */ + plat->reg_shift = (serial_info->stride >> 1); + plat->clock = serial_info->clk; + + return 0; +} + +static const struct udevice_id slimbootloader_serial_ids[] = { + { .compatible = "intel,slimbootloader-uart" }, + {} +}; + +U_BOOT_DRIVER(serial_slimbootloader) = { + .name = "serial_slimbootloader", + .id = UCLASS_SERIAL, + .of_match = slimbootloader_serial_ids, + .ofdata_to_platdata = slimbootloader_serial_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct ns16550_platdata), + .priv_auto_alloc_size = sizeof(struct NS16550), + .probe = ns16550_serial_probe, + .ops = &ns16550_serial_ops, +}; diff --git a/arch/x86/include/asm/arch-slimbootloader/slimbootloader.h b/arch/x86/include/asm/arch-slimbootloader/slimbootloader.h index c85201e711..b05e527148 100644 --- a/arch/x86/include/asm/arch-slimbootloader/slimbootloader.h +++ b/arch/x86/include/asm/arch-slimbootloader/slimbootloader.h @@ -16,6 +16,12 @@ { 0xa9, 0xe4, 0x92, 0xf3, 0x57, 0xd1, 0x28, 0x32 } \ }
+#define LOADER_SERIAL_PORT_INFO_GUID \ + { \ + 0x6c6872fe, 0x56a9, 0x4403, \ + { 0xbb, 0x98, 0x95, 0x8d, 0x62, 0xde, 0x87, 0xf1 } \ + } + /** * A single entry of memory map information * @@ -48,6 +54,33 @@ struct memory_map_info { struct memory_map_entry entry[0]; } __packed;
+/** + * This includes serial port info which has already been initialized in previous + * Slim Bootloader stage. + * The Slim Bootloader initializes serial port regardless of debug/release build + * modes, and it passes the information to a payload thru hob. So, a payload can + * re-use the serial information without re-initializing serial port. + * + * @rev : revision of serial_port_info structure. currently 1. + * @rsvd : padding for alignment + * @type : port io: 1, mmio: 2 + * @base : io base address. ex) 0x3f8, 0x80001000 + * @baud : uart baud rate + * @stride: register stride in Bytes + * @clk : uart frequency in Hz + * @rsvd1 : reserved + */ +struct serial_port_info { + u8 rev; + u8 rsvd[3]; + u32 type; + u32 base; + u32 baud; + u32 stride; + u32 clk; + u32 rsvd1; +} __packed; + /** * This returns a pointer to hob data buffer if the given guid hob is found. *
Hi Aiden,
Again, the same question: does this serial port info hob apply to FSP based board? (eg: newer FSP produces such hob for bootloader to use?) If yes, we probably need rename the driver to something more generic, like "intel,hob-uart"?
- Copyright (C) 2019 Intel Corporation <www.intel.com>
if (!serial_info) {
return -ENOENT;
serial_info->type,
serial_info->base,
serial_info->baud,
serial_info->clk);
- A single entry of memory map information
- This includes serial port info which has already been initialized in previous
- Slim Bootloader stage.
- The Slim Bootloader initializes serial port regardless of debug/release build
- modes, and it passes the information to a payload thru hob. So, a payload can
- re-use the serial information without re-initializing serial port.
- @rev : revision of serial_port_info structure. currently 1.
- @rsvd : padding for alignment
- @type : port io: 1, mmio: 2
- @base : io base address. ex) 0x3f8, 0x80001000
- @baud : uart baud rate
- @stride: register stride in Bytes
- @clk : uart frequency in Hz
- @rsvd1 : reserved
u8 rev;
u8 rsvd[3];
u32 type;
u32 base;
u32 baud;
u32 stride;
u32 clk;
u32 rsvd1;
+} __packed;
- This returns a pointer to hob data buffer if the given guid hob is found.
-- 2.20.1
Hi Bin,
-----Original Message----- From: Bin Meng [mailto:bmeng.cn@gmail.com] Sent: Tuesday, July 2, 2019 7:14 AM To: Park, Aiden aiden.park@intel.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Simon Glass sjg@chromium.org Subject: Re: [PATCH v2 4/8] x86: slimbootloader: Add serial driver
Hi Aiden,
Again, the same question: does this serial port info hob apply to FSP based board? (eg: newer FSP produces such hob for bootloader to use?) If yes, we probably need rename the driver to something more generic, like "intel,hob- uart"?
These HOB is provided from Slim Bootloader, not from FSP. Slim Bootloader consumes FSP HOB, but it's removed before loading a Payload. Instead of FSP HOB, Slim Bootloader generates some new HOBs for Payload usages only. This serial port info hob also is only generated from Slim Bootloader. Let me add a brief description in next patch.
- Copyright (C) 2019 Intel Corporation <www.intel.com> */
+int slimbootloader_serial_ofdata_to_platdata(struct udevice *dev) {
if (!serial_info) {
return -ENOENT;
serial_info->type,
serial_info->base,
serial_info->baud,
serial_info->clk);
+in previous
+debug/release build
+payload can
- @rsvd1 : reserved
u8 rev;
u8 rsvd[3];
u32 type;
u32 base;
u32 baud;
u32 stride;
u32 clk;
u32 rsvd1;
+} __packed;
-- 2.20.1
Best Regards, Aiden
Bin Meng
Park, Aiden
