[PATCH v4 0/8] usb: dwc2: Refactor and update USB DWC2 driver
This series improves the USB DWC2 driver by extracting register definitions into a common file for better readability and updating the reset method to reflect changes in version 4.20a, including the new GRSTCTL_CSFTRST_DONE bit for reset completion indication.
This series has been tested on two platforms: - MK808 with RK3066 SoC and dwc2 v2.91a, tested with USB flash drive and connected the board to the PC through the rockusb command. Test log [1]. - K230-CanMV with K230 SoC [2] and dwc2 v4.30a, tested with the onboard rtl8152 USB to net chip and an external rtl8152 adapter connected to the onboard USB-C interface via USB hub. Test log [3].
[1] https://gist.github.com/Judehahh/878ace2607d201dc49211f2c655f0fe0#file-mk808... [2] https://developer.canaan-creative.com/k230/en/dev/CanMV_K230_Tutorial.html [3] https://gist.github.com/Judehahh/878ace2607d201dc49211f2c655f0fe0#file-k230-...
--- Changes in v4: - Fixed typo from dwc2_core_reg to dwc2_core_regs in patch 1&5. - Restored `struct dwc2_usbotg_phy` definition that was incorrectly removed in patch 6. - Updated copyright headers to include 2025 in patch 7. - Expanded comments to clarify PHY clock delay in patch 7. - Link to v3: https://lore.kernel.org/r/20250104-dwc2-dev-v3-0-d4b2bc1996e4@pigmoral.tech
Changes in v3: - Handled warnings from checkpatch.pl (add spaces around '<<' and replace 'x' with '(x)' for macro argument). - Add return ret; when timeout happens. - Link to v2: https://lore.kernel.org/r/20241230-dwc2-dev-v2-3-12cd9b8a2358@outlook.com
Changes in v2: - Reorganized structures, renamed macros, and moved code for better clarity and maintainability. - Added a fix for the incorrect ULPI_UTMI_SEL bit setting. - Added a fix for incorrectly calculating HBstLen for external DMA mode. - Extend the changes that replace uint32 with u32 to also include u8 and u16. - Link to v1: https://lore.kernel.org/r/20240522142311.17351-1-seashell11234455@gmail.com
--- Junhui Liu (1): usb: dwc2: Fix incorrect ULPI_UTMI_SEL bit setting
Kongyang Liu (7): usb: dwc2: Extract register definitions to common header file usb: dwc2: Fix HBstLen setting for external DMA mode usb: dwc2: Clean up with bitfield macros usb: dwc2: Align macros with Linux kernel definitions usb: dwc2: Extract macro definitions to common header usb: dwc2: Unify flush and reset logic with v4.20a support usb: dwc2: Replace uint<x>_t types with u<x>
drivers/usb/common/Makefile | 2 + drivers/usb/common/dwc2_core.c | 131 +++++ drivers/usb/common/dwc2_core.h | 560 +++++++++++++++++++++ drivers/usb/gadget/dwc2_udc_otg.c | 125 ++--- drivers/usb/gadget/dwc2_udc_otg_regs.h | 289 ++--------- drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c | 306 ++++++------ drivers/usb/host/dwc2.c | 494 ++++++++----------- drivers/usb/host/dwc2.h | 750 +---------------------------- 8 files changed, 1154 insertions(+), 1503 deletions(-) --- base-commit: 38a371110308ebeb277e20531a7b698b7981bbfa change-id: 20241218-dwc2-dev-955c21a81118
The same registers are accessed in both the otg and gatet drivers of dwc2, and these registers are repeatedly defined in these two parts. Extract register definitions into a common header file to reduce redundancy and make the code more maintainable.
Signed-off-by: Kongyang Liu seashell11234455@gmail.com Reviewed-by: Marek Vasut marex@denx.de Tested-by: Peter Robinson pbrobinson@gmail.com Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Junhui Liu junhui.liu@pigmoral.tech --- drivers/usb/common/dwc2_core.h | 126 ++++++++++++++++++ drivers/usb/gadget/dwc2_udc_otg.c | 94 +++++++------- drivers/usb/gadget/dwc2_udc_otg_regs.h | 68 +--------- drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c | 201 +++++++++++++++-------------- drivers/usb/host/dwc2.c | 102 ++++++++------- drivers/usb/host/dwc2.h | 58 --------- 6 files changed, 332 insertions(+), 317 deletions(-)
diff --git a/drivers/usb/common/dwc2_core.h b/drivers/usb/common/dwc2_core.h new file mode 100644 index 0000000000000000000000000000000000000000..26483a57e7df58e2b9fe820367e1680b9251af8d --- /dev/null +++ b/drivers/usb/common/dwc2_core.h @@ -0,0 +1,126 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com + * + */ + +#ifndef __DWC2_CORE_H_ +#define __DWC2_CORE_H_ + +struct dwc2_global_regs { + u32 gotgctl; /* 0x000 */ + u32 gotgint; + u32 gahbcfg; + u32 gusbcfg; + u32 grstctl; /* 0x010 */ + u32 gintsts; + u32 gintmsk; + u32 grxstsr; + u32 grxstsp; /* 0x020 */ + u32 grxfsiz; + u32 gnptxfsiz; + u32 gnptxsts; + u32 gi2cctl; /* 0x030 */ + u32 gpvndctl; + u32 ggpio; + u32 guid; + u32 gsnpsid; /* 0x040 */ + u32 ghwcfg1; + u32 ghwcfg2; + u32 ghwcfg3; + u32 ghwcfg4; /* 0x050 */ + u32 glpmcfg; + u32 gpwrdn; + u32 gdfifocfg; + u32 gadpctl; /* 0x060 */ + u32 grefclk; + u32 gintmsk2; + u32 gintsts2; + u8 _pad_from_0x70_to_0x100[0x100 - 0x70]; + u32 hptxfsiz; /* 0x100 */ + u32 dptxfsizn[15]; + u8 _pad_from_0x140_to_0x400[0x400 - 0x140]; +}; + +struct dwc2_hc_regs { + u32 hcchar; /* 0x500 + 0x20 * ch */ + u32 hcsplt; + u32 hcint; + u32 hcintmsk; + u32 hctsiz; + u32 hcdma; + u32 reserved; + u32 hcdmab; +}; + +struct dwc2_host_regs { + u32 hcfg; /* 0x400 */ + u32 hfir; + u32 hfnum; + u32 _pad_0x40c; + u32 hptxsts; /* 0x410 */ + u32 haint; + u32 haintmsk; + u32 hflbaddr; + u8 _pad_from_0x420_to_0x440[0x440 - 0x420]; + u32 hprt0; /* 0x440 */ + u8 _pad_from_0x444_to_0x500[0x500 - 0x444]; + struct dwc2_hc_regs hc[16]; /* 0x500 */ + u8 _pad_from_0x700_to_0x800[0x800 - 0x700]; +}; + +/* Device Logical IN Endpoint-Specific Registers */ +struct dwc2_dev_in_endp { + u32 diepctl; /* 0x900 + 0x20 * ep */ + u32 reserved0; + u32 diepint; + u32 reserved1; + u32 dieptsiz; + u32 diepdma; + u32 reserved2; + u32 diepdmab; +}; + +/* Device Logical OUT Endpoint-Specific Registers */ +struct dwc2_dev_out_endp { + u32 doepctl; /* 0xB00 + 0x20 * ep */ + u32 reserved0; + u32 doepint; + u32 reserved1; + u32 doeptsiz; + u32 doepdma; + u32 reserved2; + u32 doepdmab; +}; + +struct dwc2_device_regs { + u32 dcfg; /* 0x800 */ + u32 dctl; + u32 dsts; + u32 _pad_0x80c; + u32 diepmsk; /* 0x810 */ + u32 doepmsk; + u32 daint; + u32 daintmsk; + u32 dtknqr1; /* 0x820 */ + u32 dtknqr2; + u32 dvbusdis; + u32 dvbuspulse; + u32 dtknqr3; /* 0x830 */ + u32 dtknqr4; + u8 _pad_from_0x838_to_0x900[0x900 - 0x838]; + struct dwc2_dev_in_endp in_endp[16]; /* 0x900 */ + struct dwc2_dev_out_endp out_endp[16]; /* 0xB00 */ +}; + +struct dwc2_core_regs { + struct dwc2_global_regs global_regs; /* 0x000 */ + struct dwc2_host_regs host_regs; /* 0x400 */ + struct dwc2_device_regs device_regs; /* 0x800 */ + u8 _pad_from_0xd00_to_0xe00[0xe00 - 0xd00]; + u32 pcgcctl; /* 0xe00 */ + u8 _pad_from_0xe04_to_0x1000[0x1000 - 0xe04]; + u8 ep_fifo[16][0x1000]; /* 0x1000 */ +}; + +#endif /* __DWC2_CORE_H_ */ diff --git a/drivers/usb/gadget/dwc2_udc_otg.c b/drivers/usb/gadget/dwc2_udc_otg.c index 7e9dd6f4268d3d80bf0572d71e267fbd26ce1516..fde1a6af6b0e79c9bd8d24b0849c4030bd22012b 100644 --- a/drivers/usb/gadget/dwc2_udc_otg.c +++ b/drivers/usb/gadget/dwc2_udc_otg.c @@ -45,6 +45,7 @@
#include <power/regulator.h>
+#include "../common/dwc2_core.h" #include "dwc2_udc_otg_regs.h" #include "dwc2_udc_otg_priv.h"
@@ -154,11 +155,11 @@ static struct usb_ep_ops dwc2_ep_ops = {
-struct dwc2_usbotg_reg *reg; +struct dwc2_core_regs *reg;
bool dfu_usb_get_reset(void) { - return !!(readl(®->gintsts) & INT_RESET); + return !!(readl(®->global_regs.gintsts) & INT_RESET); }
__weak void otg_phy_init(struct dwc2_udc *dev) {} @@ -229,7 +230,7 @@ static int udc_enable(struct dwc2_udc *dev)
debug_cond(DEBUG_SETUP != 0, "DWC2 USB 2.0 OTG Controller Core Initialized : 0x%x\n", - readl(®->gintmsk)); + readl(®->global_regs.gintmsk));
dev->gadget.speed = USB_SPEED_UNKNOWN;
@@ -238,7 +239,7 @@ static int udc_enable(struct dwc2_udc *dev)
static int dwc2_gadget_pullup(struct usb_gadget *g, int is_on) { - clrsetbits_le32(®->dctl, SOFT_DISCONNECT, + clrsetbits_le32(®->device_regs.dctl, SOFT_DISCONNECT, is_on ? 0 : SOFT_DISCONNECT);
return 0; @@ -463,12 +464,14 @@ static void reconfig_usbd(struct dwc2_udc *dev) { /* 2. Soft-reset OTG Core and then unreset again. */ int i; - unsigned int uTemp = writel(CORE_SOFT_RESET, ®->grstctl); + unsigned int uTemp; uint32_t dflt_gusbcfg; uint32_t rx_fifo_sz, tx_fifo_sz, np_tx_fifo_sz; u32 max_hw_ep; int pdata_hw_ep;
+ writel(CORE_SOFT_RESET, ®->global_regs.grstctl); + debug("Resetting OTG controller\n");
dflt_gusbcfg = @@ -490,47 +493,47 @@ static void reconfig_usbd(struct dwc2_udc *dev) if (dev->pdata->usb_gusbcfg) dflt_gusbcfg = dev->pdata->usb_gusbcfg;
- writel(dflt_gusbcfg, ®->gusbcfg); + writel(dflt_gusbcfg, ®->global_regs.gusbcfg);
/* 3. Put the OTG device core in the disconnected state.*/ - uTemp = readl(®->dctl); + uTemp = readl(®->device_regs.dctl); uTemp |= SOFT_DISCONNECT; - writel(uTemp, ®->dctl); + writel(uTemp, ®->device_regs.dctl);
udelay(20);
/* 4. Make the OTG device core exit from the disconnected state.*/ - uTemp = readl(®->dctl); + uTemp = readl(®->device_regs.dctl); uTemp = uTemp & ~SOFT_DISCONNECT; - writel(uTemp, ®->dctl); + writel(uTemp, ®->device_regs.dctl);
/* 5. Configure OTG Core to initial settings of device mode.*/ /* [][1: full speed(30Mhz) 0:high speed]*/ - writel(EP_MISS_CNT(1) | DEV_SPEED_HIGH_SPEED_20, ®->dcfg); + writel(EP_MISS_CNT(1) | DEV_SPEED_HIGH_SPEED_20, ®->device_regs.dcfg);
mdelay(1);
/* 6. Unmask the core interrupts*/ - writel(GINTMSK_INIT, ®->gintmsk); + writel(GINTMSK_INIT, ®->global_regs.gintmsk);
/* 7. Set NAK bit of EP0, EP1, EP2*/ - writel(DEPCTL_EPDIS|DEPCTL_SNAK, ®->out_endp[EP0_CON].doepctl); - writel(DEPCTL_EPDIS|DEPCTL_SNAK, ®->in_endp[EP0_CON].diepctl); + writel(DEPCTL_EPDIS | DEPCTL_SNAK, ®->device_regs.out_endp[EP0_CON].doepctl); + writel(DEPCTL_EPDIS | DEPCTL_SNAK, ®->device_regs.in_endp[EP0_CON].diepctl);
for (i = 1; i < DWC2_MAX_ENDPOINTS; i++) { - writel(DEPCTL_EPDIS|DEPCTL_SNAK, ®->out_endp[i].doepctl); - writel(DEPCTL_EPDIS|DEPCTL_SNAK, ®->in_endp[i].diepctl); + writel(DEPCTL_EPDIS | DEPCTL_SNAK, ®->device_regs.out_endp[i].doepctl); + writel(DEPCTL_EPDIS | DEPCTL_SNAK, ®->device_regs.in_endp[i].diepctl); }
/* 8. Unmask EPO interrupts*/ writel(((1 << EP0_CON) << DAINT_OUT_BIT) - | (1 << EP0_CON), ®->daintmsk); + | (1 << EP0_CON), ®->device_regs.daintmsk);
/* 9. Unmask device OUT EP common interrupts*/ - writel(DOEPMSK_INIT, ®->doepmsk); + writel(DOEPMSK_INIT, ®->device_regs.doepmsk);
/* 10. Unmask device IN EP common interrupts*/ - writel(DIEPMSK_INIT, ®->diepmsk); + writel(DIEPMSK_INIT, ®->device_regs.diepmsk);
rx_fifo_sz = RX_FIFO_SIZE; np_tx_fifo_sz = NPTX_FIFO_SIZE; @@ -544,14 +547,14 @@ static void reconfig_usbd(struct dwc2_udc *dev) tx_fifo_sz = dev->pdata->tx_fifo_sz;
/* 11. Set Rx FIFO Size (in 32-bit words) */ - writel(rx_fifo_sz, ®->grxfsiz); + writel(rx_fifo_sz, ®->global_regs.grxfsiz);
/* 12. Set Non Periodic Tx FIFO Size */ writel((np_tx_fifo_sz << 16) | rx_fifo_sz, - ®->gnptxfsiz); + ®->global_regs.gnptxfsiz);
/* retrieve the number of IN Endpoints (excluding ep0) */ - max_hw_ep = (readl(®->ghwcfg4) & GHWCFG4_NUM_IN_EPS_MASK) >> + max_hw_ep = (readl(®->global_regs.ghwcfg4) & GHWCFG4_NUM_IN_EPS_MASK) >> GHWCFG4_NUM_IN_EPS_SHIFT; pdata_hw_ep = dev->pdata->tx_fifo_sz_nb;
@@ -565,27 +568,27 @@ static void reconfig_usbd(struct dwc2_udc *dev) tx_fifo_sz = dev->pdata->tx_fifo_sz_array[i];
writel((rx_fifo_sz + np_tx_fifo_sz + (tx_fifo_sz * i)) | - tx_fifo_sz << 16, ®->dieptxf[i]); + tx_fifo_sz << 16, ®->global_regs.dptxfsizn[i]); } /* Flush the RX FIFO */ - writel(RX_FIFO_FLUSH, ®->grstctl); - while (readl(®->grstctl) & RX_FIFO_FLUSH) + writel(RX_FIFO_FLUSH, ®->global_regs.grstctl); + while (readl(®->global_regs.grstctl) & RX_FIFO_FLUSH) debug("%s: waiting for DWC2_UDC_OTG_GRSTCTL\n", __func__);
/* Flush all the Tx FIFO's */ - writel(TX_FIFO_FLUSH_ALL, ®->grstctl); - writel(TX_FIFO_FLUSH_ALL | TX_FIFO_FLUSH, ®->grstctl); - while (readl(®->grstctl) & TX_FIFO_FLUSH) + writel(TX_FIFO_FLUSH_ALL, ®->global_regs.grstctl); + writel(TX_FIFO_FLUSH_ALL | TX_FIFO_FLUSH, ®->global_regs.grstctl); + while (readl(®->global_regs.grstctl) & TX_FIFO_FLUSH) debug("%s: waiting for DWC2_UDC_OTG_GRSTCTL\n", __func__);
/* 13. Clear NAK bit of EP0, EP1, EP2*/ /* For Slave mode*/ /* EP0: Control OUT */ writel(DEPCTL_EPDIS | DEPCTL_CNAK, - ®->out_endp[EP0_CON].doepctl); + ®->device_regs.out_endp[EP0_CON].doepctl);
/* 14. Initialize OTG Link Core.*/ - writel(GAHBCFG_INIT, ®->gahbcfg); + writel(GAHBCFG_INIT, ®->global_regs.gahbcfg); }
static void set_max_pktsize(struct dwc2_udc *dev, enum usb_device_speed speed) @@ -610,12 +613,12 @@ static void set_max_pktsize(struct dwc2_udc *dev, enum usb_device_speed speed) dev->ep[i].ep.maxpacket = ep_fifo_size;
/* EP0 - Control IN (64 bytes)*/ - ep_ctrl = readl(®->in_endp[EP0_CON].diepctl); - writel(ep_ctrl|(0<<0), ®->in_endp[EP0_CON].diepctl); + ep_ctrl = readl(®->device_regs.in_endp[EP0_CON].diepctl); + writel(ep_ctrl | (0 << 0), ®->device_regs.in_endp[EP0_CON].diepctl);
/* EP0 - Control OUT (64 bytes)*/ - ep_ctrl = readl(®->out_endp[EP0_CON].doepctl); - writel(ep_ctrl|(0<<0), ®->out_endp[EP0_CON].doepctl); + ep_ctrl = readl(®->device_regs.out_endp[EP0_CON].doepctl); + writel(ep_ctrl | (0 << 0), ®->device_regs.out_endp[EP0_CON].doepctl); }
static int dwc2_ep_enable(struct usb_ep *_ep, @@ -904,7 +907,7 @@ int dwc2_udc_probe(struct dwc2_plat_otg_data *pdata)
dev->pdata = pdata;
- reg = (struct dwc2_usbotg_reg *)pdata->regs_otg; + reg = (struct dwc2_core_regs *)pdata->regs_otg;
dev->gadget.is_dualspeed = 1; /* Hack only*/ dev->gadget.is_otg = 0; @@ -932,8 +935,8 @@ int dwc2_udc_probe(struct dwc2_plat_otg_data *pdata)
int dwc2_udc_handle_interrupt(void) { - u32 intr_status = readl(®->gintsts); - u32 gintmsk = readl(®->gintmsk); + u32 intr_status = readl(®->global_regs.gintsts); + u32 gintmsk = readl(®->global_regs.gintmsk);
if (intr_status & gintmsk) return dwc2_udc_irq(1, (void *)the_controller); @@ -1087,8 +1090,8 @@ static int dwc2_udc_otg_probe(struct udevice *dev) { struct dwc2_plat_otg_data *plat = dev_get_plat(dev); struct dwc2_priv_data *priv = dev_get_priv(dev); - struct dwc2_usbotg_reg *usbotg_reg = - (struct dwc2_usbotg_reg *)plat->regs_otg; + struct dwc2_core_regs *usbotg_reg = + (struct dwc2_core_regs *)plat->regs_otg; int ret;
ret = dwc2_udc_otg_clk_init(dev, &priv->clks); @@ -1123,21 +1126,22 @@ static int dwc2_udc_otg_probe(struct udevice *dev) if (plat->force_b_session_valid && !plat->force_vbus_detection) { /* Override VBUS detection: enable then value*/ - setbits_le32(&usbotg_reg->gotgctl, VB_VALOEN); - setbits_le32(&usbotg_reg->gotgctl, VB_VALOVAL); + setbits_le32(&usbotg_reg->global_regs.gotgctl, VB_VALOEN); + setbits_le32(&usbotg_reg->global_regs.gotgctl, VB_VALOVAL); } else { /* Enable VBUS sensing */ - setbits_le32(&usbotg_reg->ggpio, + setbits_le32(&usbotg_reg->global_regs.ggpio, GGPIO_STM32_OTG_GCCFG_VBDEN); } if (plat->force_b_session_valid) { /* Override B session bits: enable then value */ - setbits_le32(&usbotg_reg->gotgctl, A_VALOEN | B_VALOEN); - setbits_le32(&usbotg_reg->gotgctl, + setbits_le32(&usbotg_reg->global_regs.gotgctl, + A_VALOEN | B_VALOEN); + setbits_le32(&usbotg_reg->global_regs.gotgctl, A_VALOVAL | B_VALOVAL); } else { /* Enable ID detection */ - setbits_le32(&usbotg_reg->ggpio, + setbits_le32(&usbotg_reg->global_regs.ggpio, GGPIO_STM32_OTG_GCCFG_IDEN); } } diff --git a/drivers/usb/gadget/dwc2_udc_otg_regs.h b/drivers/usb/gadget/dwc2_udc_otg_regs.h index 01056fab1c21a136fcf75d9b89f397df1aa869f3..198ba7a7c37d05dca084ef017534265f5fb5fd70 100644 --- a/drivers/usb/gadget/dwc2_udc_otg_regs.h +++ b/drivers/usb/gadget/dwc2_udc_otg_regs.h @@ -10,80 +10,14 @@ #ifndef __ASM_ARCH_REGS_USB_OTG_HS_H #define __ASM_ARCH_REGS_USB_OTG_HS_H
-/* USB2.0 OTG Controller register */ #include <linux/bitops.h> + struct dwc2_usbotg_phy { u32 phypwr; u32 phyclk; u32 rstcon; };
-/* Device Logical IN Endpoint-Specific Registers */ -struct dwc2_dev_in_endp { - u32 diepctl; - u8 res1[4]; - u32 diepint; - u8 res2[4]; - u32 dieptsiz; - u32 diepdma; - u8 res3[4]; - u32 diepdmab; -}; - -/* Device Logical OUT Endpoint-Specific Registers */ -struct dwc2_dev_out_endp { - u32 doepctl; - u8 res1[4]; - u32 doepint; - u8 res2[4]; - u32 doeptsiz; - u32 doepdma; - u8 res3[4]; - u32 doepdmab; -}; - -struct ep_fifo { - u32 fifo; - u8 res[4092]; -}; - -/* USB2.0 OTG Controller register */ -struct dwc2_usbotg_reg { - /* Core Global Registers */ - u32 gotgctl; /* OTG Control & Status */ - u32 gotgint; /* OTG Interrupt */ - u32 gahbcfg; /* Core AHB Configuration */ - u32 gusbcfg; /* Core USB Configuration */ - u32 grstctl; /* Core Reset */ - u32 gintsts; /* Core Interrupt */ - u32 gintmsk; /* Core Interrupt Mask */ - u32 grxstsr; /* Receive Status Debug Read/Status Read */ - u32 grxstsp; /* Receive Status Debug Pop/Status Pop */ - u32 grxfsiz; /* Receive FIFO Size */ - u32 gnptxfsiz; /* Non-Periodic Transmit FIFO Size */ - u8 res0[12]; - u32 ggpio; /* 0x038 */ - u8 res1[20]; - u32 ghwcfg4; /* User HW Config4 */ - u8 res2[176]; - u32 dieptxf[15]; /* Device Periodic Transmit FIFO size register */ - u8 res3[1728]; - /* Device Configuration */ - u32 dcfg; /* Device Configuration Register */ - u32 dctl; /* Device Control */ - u32 dsts; /* Device Status */ - u8 res4[4]; - u32 diepmsk; /* Device IN Endpoint Common Interrupt Mask */ - u32 doepmsk; /* Device OUT Endpoint Common Interrupt Mask */ - u32 daint; /* Device All Endpoints Interrupt */ - u32 daintmsk; /* Device All Endpoints Interrupt Mask */ - u8 res5[224]; - struct dwc2_dev_in_endp in_endp[16]; - struct dwc2_dev_out_endp out_endp[16]; - u8 res6[768]; - struct ep_fifo ep[16]; -}; - /*===================================================================== */ /*definitions related to CSR setting */
diff --git a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c index c0408bae0768cd81fa50de946dee4aa08c1059f8..81ced055f02ac1b6775527099a21cd39326d93cc 100644 --- a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c +++ b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c @@ -32,15 +32,16 @@ static inline void dwc2_udc_ep0_zlp(struct dwc2_udc *dev) { u32 ep_ctrl;
- writel(phys_to_bus((unsigned long)usb_ctrl_dma_addr), ®->in_endp[EP0_CON].diepdma); - writel(DIEPT_SIZ_PKT_CNT(1), ®->in_endp[EP0_CON].dieptsiz); + writel(phys_to_bus((unsigned long)usb_ctrl_dma_addr), + ®->device_regs.in_endp[EP0_CON].diepdma); + writel(DIEPT_SIZ_PKT_CNT(1), ®->device_regs.in_endp[EP0_CON].dieptsiz);
- ep_ctrl = readl(®->in_endp[EP0_CON].diepctl); - writel(ep_ctrl|DEPCTL_EPENA|DEPCTL_CNAK, - ®->in_endp[EP0_CON].diepctl); + ep_ctrl = readl(®->device_regs.in_endp[EP0_CON].diepctl); + writel(ep_ctrl | DEPCTL_EPENA | DEPCTL_CNAK, + ®->device_regs.in_endp[EP0_CON].diepctl);
debug_cond(DEBUG_EP0 != 0, "%s:EP0 ZLP DIEPCTL0 = 0x%x\n", - __func__, readl(®->in_endp[EP0_CON].diepctl)); + __func__, readl(®->device_regs.in_endp[EP0_CON].diepctl)); dev->ep0state = WAIT_FOR_IN_COMPLETE; }
@@ -52,16 +53,17 @@ static void dwc2_udc_pre_setup(void) "%s : Prepare Setup packets.\n", __func__);
writel(DOEPT_SIZ_PKT_CNT(1) | sizeof(struct usb_ctrlrequest), - ®->out_endp[EP0_CON].doeptsiz); - writel(phys_to_bus((unsigned long)usb_ctrl_dma_addr), ®->out_endp[EP0_CON].doepdma); + ®->device_regs.out_endp[EP0_CON].doeptsiz); + writel(phys_to_bus((unsigned long)usb_ctrl_dma_addr), + ®->device_regs.out_endp[EP0_CON].doepdma);
- ep_ctrl = readl(®->out_endp[EP0_CON].doepctl); - writel(ep_ctrl|DEPCTL_EPENA, ®->out_endp[EP0_CON].doepctl); + ep_ctrl = readl(®->device_regs.out_endp[EP0_CON].doepctl); + writel(ep_ctrl | DEPCTL_EPENA, ®->device_regs.out_endp[EP0_CON].doepctl);
debug_cond(DEBUG_EP0 != 0, "%s:EP0 ZLP DIEPCTL0 = 0x%x\n", - __func__, readl(®->in_endp[EP0_CON].diepctl)); + __func__, readl(®->device_regs.in_endp[EP0_CON].diepctl)); debug_cond(DEBUG_EP0 != 0, "%s:EP0 ZLP DOEPCTL0 = 0x%x\n", - __func__, readl(®->out_endp[EP0_CON].doepctl)); + __func__, readl(®->device_regs.out_endp[EP0_CON].doepctl));
@@ -70,25 +72,26 @@ static inline void dwc2_ep0_complete_out(void) u32 ep_ctrl;
debug_cond(DEBUG_IN_EP, "%s : Prepare Complete Out packet.\n", __func__);
- ep_ctrl = readl(®->out_endp[EP0_CON].doepctl); - writel(ep_ctrl|DEPCTL_EPENA|DEPCTL_CNAK, - ®->out_endp[EP0_CON].doepctl); + ep_ctrl = readl(®->device_regs.out_endp[EP0_CON].doepctl); + writel(ep_ctrl | DEPCTL_EPENA | DEPCTL_CNAK, + ®->device_regs.out_endp[EP0_CON].doepctl);
@@ -110,25 +113,25 @@ static int setdma_rx(struct dwc2_ep *ep, struct dwc2_request *req) else pktcnt = (length - 1)/(ep->ep.maxpacket) + 1;
- ctrl = readl(®->out_endp[ep_num].doepctl); + ctrl = readl(®->device_regs.out_endp[ep_num].doepctl);
invalidate_dcache_range((unsigned long) ep->dma_buf, (unsigned long) ep->dma_buf + ROUND(ep->len, CONFIG_SYS_CACHELINE_SIZE));
- writel(phys_to_bus((unsigned long)ep->dma_buf), ®->out_endp[ep_num].doepdma); + writel(phys_to_bus((unsigned long)ep->dma_buf), ®->device_regs.out_endp[ep_num].doepdma); writel(DOEPT_SIZ_PKT_CNT(pktcnt) | DOEPT_SIZ_XFER_SIZE(length), - ®->out_endp[ep_num].doeptsiz); - writel(DEPCTL_EPENA|DEPCTL_CNAK|ctrl, ®->out_endp[ep_num].doepctl); + ®->device_regs.out_endp[ep_num].doeptsiz); + writel(DEPCTL_EPENA | DEPCTL_CNAK | ctrl, ®->device_regs.out_endp[ep_num].doepctl);
debug_cond(DEBUG_OUT_EP != 0, "%s: EP%d RX DMA start : DOEPDMA = 0x%x," "DOEPTSIZ = 0x%x, DOEPCTL = 0x%x\n" "\tbuf = 0x%p, pktcnt = %d, xfersize = %d\n", __func__, ep_num, - readl(®->out_endp[ep_num].doepdma), - readl(®->out_endp[ep_num].doeptsiz), - readl(®->out_endp[ep_num].doepctl), + readl(®->device_regs.out_endp[ep_num].doepdma), + readl(®->device_regs.out_endp[ep_num].doeptsiz), + readl(®->device_regs.out_endp[ep_num].doepctl), buf, pktcnt, length); return 0;
@@ -159,16 +162,16 @@ static int setdma_tx(struct dwc2_ep *ep, struct dwc2_request *req) pktcnt = (length - 1)/(ep->ep.maxpacket) + 1;
/* Flush the endpoint's Tx FIFO */ - writel(TX_FIFO_NUMBER(ep->fifo_num), ®->grstctl); - writel(TX_FIFO_NUMBER(ep->fifo_num) | TX_FIFO_FLUSH, ®->grstctl); - while (readl(®->grstctl) & TX_FIFO_FLUSH) + writel(TX_FIFO_NUMBER(ep->fifo_num), ®->global_regs.grstctl); + writel(TX_FIFO_NUMBER(ep->fifo_num) | TX_FIFO_FLUSH, ®->global_regs.grstctl); + while (readl(®->global_regs.grstctl) & TX_FIFO_FLUSH) ;
- writel(phys_to_bus((unsigned long)ep->dma_buf), ®->in_endp[ep_num].diepdma); + writel(phys_to_bus((unsigned long)ep->dma_buf), ®->device_regs.in_endp[ep_num].diepdma); writel(DIEPT_SIZ_PKT_CNT(pktcnt) | DIEPT_SIZ_XFER_SIZE(length), - ®->in_endp[ep_num].dieptsiz); + ®->device_regs.in_endp[ep_num].dieptsiz);
- ctrl = readl(®->in_endp[ep_num].diepctl); + ctrl = readl(®->device_regs.in_endp[ep_num].diepctl);
/* Write the FIFO number to be used for this endpoint */ ctrl &= DIEPCTL_TX_FIFO_NUM_MASK; @@ -177,16 +180,16 @@ static int setdma_tx(struct dwc2_ep *ep, struct dwc2_request *req) /* Clear reserved (Next EP) bits */ ctrl = (ctrl&~(EP_MASK<<DEPCTL_NEXT_EP_BIT));
- writel(DEPCTL_EPENA|DEPCTL_CNAK|ctrl, ®->in_endp[ep_num].diepctl); + writel(DEPCTL_EPENA | DEPCTL_CNAK | ctrl, ®->device_regs.in_endp[ep_num].diepctl);
debug_cond(DEBUG_IN_EP, "%s:EP%d TX DMA start : DIEPDMA0 = 0x%x," "DIEPTSIZ0 = 0x%x, DIEPCTL0 = 0x%x\n" "\tbuf = 0x%p, pktcnt = %d, xfersize = %d\n", __func__, ep_num, - readl(®->in_endp[ep_num].diepdma), - readl(®->in_endp[ep_num].dieptsiz), - readl(®->in_endp[ep_num].diepctl), + readl(®->device_regs.in_endp[ep_num].diepdma), + readl(®->device_regs.in_endp[ep_num].dieptsiz), + readl(®->device_regs.in_endp[ep_num].diepctl), buf, pktcnt, length);
return length; @@ -207,7 +210,7 @@ static void complete_rx(struct dwc2_udc *dev, u8 ep_num) }
req = list_entry(ep->queue.next, struct dwc2_request, queue); - ep_tsr = readl(®->out_endp[ep_num].doeptsiz); + ep_tsr = readl(®->device_regs.out_endp[ep_num].doeptsiz);
if (ep_num == EP0_CON) xfer_size = (ep_tsr & DOEPT_SIZ_XFER_SIZE_MAX_EP0); @@ -288,7 +291,7 @@ static void complete_tx(struct dwc2_udc *dev, u8 ep_num)
- ep_tsr = readl(®->in_endp[ep_num].dieptsiz); + ep_tsr = readl(®->device_regs.in_endp[ep_num].dieptsiz);
xfer_size = ep->len; is_short = (xfer_size < ep->ep.maxpacket); @@ -373,7 +376,7 @@ static void process_ep_in_intr(struct dwc2_udc *dev) u32 ep_intr, ep_intr_status; u8 ep_num = 0;
- ep_intr = readl(®->daint); + ep_intr = readl(®->device_regs.daint); debug_cond(DEBUG_IN_EP, "*** %s: EP In interrupt : DAINT = 0x%x\n", __func__, ep_intr);
@@ -381,13 +384,13 @@ static void process_ep_in_intr(struct dwc2_udc *dev)
while (ep_intr) { if (ep_intr & DAINT_IN_EP_INT(1)) { - ep_intr_status = readl(®->in_endp[ep_num].diepint); + ep_intr_status = readl(®->device_regs.in_endp[ep_num].diepint); debug_cond(DEBUG_IN_EP, "\tEP%d-IN : DIEPINT = 0x%x\n", ep_num, ep_intr_status);
/* Interrupt Clear */ - writel(ep_intr_status, ®->in_endp[ep_num].diepint); + writel(ep_intr_status, ®->device_regs.in_endp[ep_num].diepint);
if (ep_intr_status & TRANSFER_DONE) { complete_tx(dev, ep_num); @@ -420,10 +423,10 @@ static void process_ep_out_intr(struct dwc2_udc *dev) u32 ep_intr, ep_intr_status; u8 ep_num = 0; u32 ep_tsr = 0, xfer_size = 0; - u32 epsiz_reg = reg->out_endp[ep_num].doeptsiz; + u32 epsiz_reg = reg->device_regs.out_endp[ep_num].doeptsiz; u32 req_size = sizeof(struct usb_ctrlrequest);
- ep_intr = readl(®->daint); + ep_intr = readl(®->device_regs.daint); debug_cond(DEBUG_OUT_EP != 0, "*** %s: EP OUT interrupt : DAINT = 0x%x\n", __func__, ep_intr); @@ -432,13 +435,13 @@ static void process_ep_out_intr(struct dwc2_udc *dev)
while (ep_intr) { if (ep_intr & 0x1) { - ep_intr_status = readl(®->out_endp[ep_num].doepint); + ep_intr_status = readl(®->device_regs.out_endp[ep_num].doepint); debug_cond(DEBUG_OUT_EP != 0, "\tEP%d-OUT : DOEPINT = 0x%x\n", ep_num, ep_intr_status);
/* Interrupt Clear */ - writel(ep_intr_status, ®->out_endp[ep_num].doepint); + writel(ep_intr_status, ®->device_regs.out_endp[ep_num].doepint);
if (ep_num == 0) { if (ep_intr_status & TRANSFER_DONE) { @@ -486,14 +489,14 @@ static int dwc2_udc_irq(int irq, void *_dev)
spin_lock_irqsave(&dev->lock, flags);
- intr_status = readl(®->gintsts); - gintmsk = readl(®->gintmsk); + intr_status = readl(®->global_regs.gintsts); + gintmsk = readl(®->global_regs.gintmsk);
debug_cond(DEBUG_ISR, "\n*** %s : GINTSTS=0x%x(on state %s), GINTMSK : 0x%x," "DAINT : 0x%x, DAINTMSK : 0x%x\n", __func__, intr_status, state_names[dev->ep0state], gintmsk, - readl(®->daint), readl(®->daintmsk)); + readl(®->device_regs.daint), readl(®->device_regs.daintmsk));
if (!intr_status) { spin_unlock_irqrestore(&dev->lock, flags); @@ -503,8 +506,8 @@ static int dwc2_udc_irq(int irq, void *_dev) if (intr_status & INT_ENUMDONE) { debug_cond(DEBUG_ISR, "\tSpeed Detection interrupt\n");
- writel(INT_ENUMDONE, ®->gintsts); - usb_status = (readl(®->dsts) & 0x6); + writel(INT_ENUMDONE, ®->global_regs.gintsts); + usb_status = (readl(®->device_regs.dsts) & 0x6);
if (usb_status & (USB_FULL_30_60MHZ | USB_FULL_48MHZ)) { debug_cond(DEBUG_ISR, @@ -521,14 +524,14 @@ static int dwc2_udc_irq(int irq, void *_dev)
if (intr_status & INT_EARLY_SUSPEND) { debug_cond(DEBUG_ISR, "\tEarly suspend interrupt\n"); - writel(INT_EARLY_SUSPEND, ®->gintsts); + writel(INT_EARLY_SUSPEND, ®->global_regs.gintsts); }
if (intr_status & INT_SUSPEND) { - usb_status = readl(®->dsts); + usb_status = readl(®->device_regs.dsts); debug_cond(DEBUG_ISR, "\tSuspend interrupt :(DSTS):0x%x\n", usb_status); - writel(INT_SUSPEND, ®->gintsts); + writel(INT_SUSPEND, ®->global_regs.gintsts);
if (dev->gadget.speed != USB_SPEED_UNKNOWN && dev->driver) { @@ -538,7 +541,7 @@ static int dwc2_udc_irq(int irq, void *_dev) }
if (intr_status & INT_OTG) { - gotgint = readl(®->gotgint); + gotgint = readl(®->global_regs.gotgint); debug_cond(DEBUG_ISR, "\tOTG interrupt: (GOTGINT):0x%x\n", gotgint);
@@ -551,12 +554,12 @@ static int dwc2_udc_irq(int irq, void *_dev) spin_lock_irqsave(&dev->lock, flags); } } - writel(gotgint, ®->gotgint); + writel(gotgint, ®->global_regs.gotgint); }
if (intr_status & INT_RESUME) { debug_cond(DEBUG_ISR, "\tResume interrupt\n"); - writel(INT_RESUME, ®->gintsts); + writel(INT_RESUME, ®->global_regs.gintsts);
if (dev->gadget.speed != USB_SPEED_UNKNOWN && dev->driver @@ -567,10 +570,10 @@ static int dwc2_udc_irq(int irq, void *_dev) }
if (intr_status & INT_RESET) { - usb_status = readl(®->gotgctl); + usb_status = readl(®->global_regs.gotgctl); debug_cond(DEBUG_ISR, "\tReset interrupt - (GOTGCTL):0x%x\n", usb_status); - writel(INT_RESET, ®->gintsts); + writel(INT_RESET, ®->global_regs.gintsts);
if ((usb_status & 0xc0000) == (0x3 << 18)) { if (reset_available) { @@ -676,14 +679,14 @@ static int dwc2_queue(struct usb_ep *_ep, struct usb_request *_req, req = 0;
} else if (ep_is_in(ep)) { - gintsts = readl(®->gintsts); + gintsts = readl(®->global_regs.gintsts); debug_cond(DEBUG_IN_EP, "%s: ep_is_in, DWC2_UDC_OTG_GINTSTS=0x%x\n", __func__, gintsts);
setdma_tx(ep, req); } else { - gintsts = readl(®->gintsts); + gintsts = readl(®->global_regs.gintsts); debug_cond(DEBUG_OUT_EP != 0, "%s:ep_is_out, DWC2_UDC_OTG_GINTSTS=0x%x\n", __func__, gintsts); @@ -765,14 +768,14 @@ static int dwc2_fifo_read(struct dwc2_ep *ep, void *cp, int max) */ static void udc_set_address(struct dwc2_udc *dev, unsigned char address) { - u32 ctrl = readl(®->dcfg); - writel(DEVICE_ADDRESS(address) | ctrl, ®->dcfg); + u32 ctrl = readl(®->device_regs.dcfg); + writel(DEVICE_ADDRESS(address) | ctrl, ®->device_regs.dcfg);
dwc2_udc_ep0_zlp(dev);
debug_cond(DEBUG_EP0 != 0, "%s: USB OTG 2.0 Device address=%d, DCFG=0x%x\n", - __func__, address, readl(®->dcfg)); + __func__, address, readl(®->device_regs.dcfg));
dev->usb_address = address; } @@ -783,7 +786,7 @@ static inline void dwc2_udc_ep0_set_stall(struct dwc2_ep *ep) u32 ep_ctrl = 0;
dev = ep->dev; - ep_ctrl = readl(®->in_endp[EP0_CON].diepctl); + ep_ctrl = readl(®->device_regs.in_endp[EP0_CON].diepctl);
/* set the disable and stall bits */ if (ep_ctrl & DEPCTL_EPENA) @@ -791,11 +794,11 @@ static inline void dwc2_udc_ep0_set_stall(struct dwc2_ep *ep)
ep_ctrl |= DEPCTL_STALL;
- writel(ep_ctrl, ®->in_endp[EP0_CON].diepctl); + writel(ep_ctrl, ®->device_regs.in_endp[EP0_CON].diepctl);
debug_cond(DEBUG_EP0 != 0, "%s: set ep%d stall, DIEPCTL0 = 0x%p\n", - __func__, ep_index(ep), ®->in_endp[EP0_CON].diepctl); + __func__, ep_index(ep), ®->device_regs.in_endp[EP0_CON].diepctl); /* * The application can only set this bit, and the core clears it, * when a SETUP token is received for this endpoint @@ -934,13 +937,13 @@ static int dwc2_udc_get_status(struct dwc2_udc *dev, (unsigned long) usb_ctrl + ROUND(sizeof(g_status), CONFIG_SYS_CACHELINE_SIZE));
- writel(phys_to_bus(usb_ctrl_dma_addr), ®->in_endp[EP0_CON].diepdma); + writel(phys_to_bus(usb_ctrl_dma_addr), ®->device_regs.in_endp[EP0_CON].diepdma); writel(DIEPT_SIZ_PKT_CNT(1) | DIEPT_SIZ_XFER_SIZE(2), - ®->in_endp[EP0_CON].dieptsiz); + ®->device_regs.in_endp[EP0_CON].dieptsiz);
- ep_ctrl = readl(®->in_endp[EP0_CON].diepctl); - writel(ep_ctrl|DEPCTL_EPENA|DEPCTL_CNAK, - ®->in_endp[EP0_CON].diepctl); + ep_ctrl = readl(®->device_regs.in_endp[EP0_CON].diepctl); + writel(ep_ctrl | DEPCTL_EPENA | DEPCTL_CNAK, + ®->device_regs.in_endp[EP0_CON].diepctl); dev->ep0state = WAIT_FOR_NULL_COMPLETE;
return 0; @@ -955,17 +958,17 @@ static void dwc2_udc_set_nak(struct dwc2_ep *ep) debug("%s: ep_num = %d, ep_type = %d\n", __func__, ep_num, ep->ep_type);
if (ep_is_in(ep)) { - ep_ctrl = readl(®->in_endp[ep_num].diepctl); + ep_ctrl = readl(®->device_regs.in_endp[ep_num].diepctl); ep_ctrl |= DEPCTL_SNAK; - writel(ep_ctrl, ®->in_endp[ep_num].diepctl); + writel(ep_ctrl, ®->device_regs.in_endp[ep_num].diepctl); debug("%s: set NAK, DIEPCTL%d = 0x%x\n", - __func__, ep_num, readl(®->in_endp[ep_num].diepctl)); + __func__, ep_num, readl(®->device_regs.in_endp[ep_num].diepctl)); } else { - ep_ctrl = readl(®->out_endp[ep_num].doepctl); + ep_ctrl = readl(®->device_regs.out_endp[ep_num].doepctl); ep_ctrl |= DEPCTL_SNAK; - writel(ep_ctrl, ®->out_endp[ep_num].doepctl); + writel(ep_ctrl, ®->device_regs.out_endp[ep_num].doepctl); debug("%s: set NAK, DOEPCTL%d = 0x%x\n", - __func__, ep_num, readl(®->out_endp[ep_num].doepctl)); + __func__, ep_num, readl(®->device_regs.out_endp[ep_num].doepctl)); }
return; @@ -980,7 +983,7 @@ static void dwc2_udc_ep_set_stall(struct dwc2_ep *ep) debug("%s: ep_num = %d, ep_type = %d\n", __func__, ep_num, ep->ep_type);
/* set the disable and stall bits */ if (ep_ctrl & DEPCTL_EPENA) @@ -988,19 +991,19 @@ static void dwc2_udc_ep_set_stall(struct dwc2_ep *ep)
- writel(ep_ctrl, ®->in_endp[ep_num].diepctl); + writel(ep_ctrl, ®->device_regs.in_endp[ep_num].diepctl); debug("%s: set stall, DIEPCTL%d = 0x%x\n", - __func__, ep_num, readl(®->in_endp[ep_num].diepctl)); + __func__, ep_num, readl(®->device_regs.in_endp[ep_num].diepctl));
/* set the stall bit */ ep_ctrl |= DEPCTL_STALL;
- writel(ep_ctrl, ®->out_endp[ep_num].doepctl); + writel(ep_ctrl, ®->device_regs.out_endp[ep_num].doepctl); debug("%s: set stall, DOEPCTL%d = 0x%x\n", - __func__, ep_num, readl(®->out_endp[ep_num].doepctl)); + __func__, ep_num, readl(®->device_regs.out_endp[ep_num].doepctl)); }
return; @@ -1015,7 +1018,7 @@ static void dwc2_udc_ep_clear_stall(struct dwc2_ep *ep) debug("%s: ep_num = %d, ep_type = %d\n", __func__, ep_num, ep->ep_type);
/* clear stall bit */ ep_ctrl &= ~DEPCTL_STALL; @@ -1031,12 +1034,12 @@ static void dwc2_udc_ep_clear_stall(struct dwc2_ep *ep) ep_ctrl |= DEPCTL_SETD0PID; /* DATA0 */ }
- writel(ep_ctrl, ®->in_endp[ep_num].diepctl); + writel(ep_ctrl, ®->device_regs.in_endp[ep_num].diepctl); debug("%s: cleared stall, DIEPCTL%d = 0x%x\n", - __func__, ep_num, readl(®->in_endp[ep_num].diepctl)); + __func__, ep_num, readl(®->device_regs.in_endp[ep_num].diepctl));
/* clear stall bit */ ep_ctrl &= ~DEPCTL_STALL; @@ -1046,9 +1049,9 @@ static void dwc2_udc_ep_clear_stall(struct dwc2_ep *ep) ep_ctrl |= DEPCTL_SETD0PID; /* DATA0 */ }
- writel(ep_ctrl, ®->out_endp[ep_num].doepctl); + writel(ep_ctrl, ®->device_regs.out_endp[ep_num].doepctl); debug("%s: cleared stall, DOEPCTL%d = 0x%x\n", - __func__, ep_num, readl(®->out_endp[ep_num].doepctl)); + __func__, ep_num, readl(®->device_regs.out_endp[ep_num].doepctl)); }
return; @@ -1110,10 +1113,10 @@ static void dwc2_udc_ep_activate(struct dwc2_ep *ep)
/* Read DEPCTLn register */ if (ep_is_in(ep)) { - ep_ctrl = readl(®->in_endp[ep_num].diepctl); + ep_ctrl = readl(®->device_regs.in_endp[ep_num].diepctl); daintmsk = 1 << ep_num; } else { - ep_ctrl = readl(®->out_endp[ep_num].doepctl); + ep_ctrl = readl(®->device_regs.out_endp[ep_num].doepctl); daintmsk = (1 << ep_num) << DAINT_OUT_BIT; }
@@ -1130,21 +1133,21 @@ static void dwc2_udc_ep_activate(struct dwc2_ep *ep) ep_ctrl |= (DEPCTL_SETD0PID | DEPCTL_USBACTEP | DEPCTL_SNAK);
if (ep_is_in(ep)) { - writel(ep_ctrl, ®->in_endp[ep_num].diepctl); + writel(ep_ctrl, ®->device_regs.in_endp[ep_num].diepctl); debug("%s: USB Ative EP%d, DIEPCTRL%d = 0x%x\n", __func__, ep_num, ep_num, - readl(®->in_endp[ep_num].diepctl)); + readl(®->device_regs.in_endp[ep_num].diepctl)); } else { - writel(ep_ctrl, ®->out_endp[ep_num].doepctl); + writel(ep_ctrl, ®->device_regs.out_endp[ep_num].doepctl); debug("%s: USB Ative EP%d, DOEPCTRL%d = 0x%x\n", __func__, ep_num, ep_num, - readl(®->out_endp[ep_num].doepctl)); + readl(®->device_regs.out_endp[ep_num].doepctl)); } }
/* Unmask EP Interrtupt */ - writel(readl(®->daintmsk)|daintmsk, ®->daintmsk); - debug("%s: DAINTMSK = 0x%x\n", __func__, readl(®->daintmsk)); + writel(readl(®->device_regs.daintmsk) | daintmsk, ®->device_regs.daintmsk); + debug("%s: DAINTMSK = 0x%x\n", __func__, readl(®->device_regs.daintmsk));
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index a9dbb85f4e6c5a9122108eb64f77e99758b840e8..b6c8b3d5a6bdf375f1adeb106d4832d92307f0db 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -24,6 +24,7 @@ #include <power/regulator.h> #include <reset.h>
+#include "../common/dwc2_core.h" #include "dwc2.h"
/* Use only HC channel 0. */ @@ -93,7 +94,7 @@ static void init_fslspclksel(struct dwc2_core_regs *regs) #endif
#ifdef DWC2_ULPI_FS_LS - uint32_t hwcfg2 = readl(®s->ghwcfg2); + uint32_t hwcfg2 = readl(®s->global_regs.ghwcfg2); uint32_t hval = (ghwcfg2 & DWC2_HWCFG2_HS_PHY_TYPE_MASK) >> DWC2_HWCFG2_HS_PHY_TYPE_OFFSET; uint32_t fval = (ghwcfg2 & DWC2_HWCFG2_FS_PHY_TYPE_MASK) >> @@ -120,8 +121,8 @@ static void dwc_otg_flush_tx_fifo(struct udevice *dev, int ret;
writel(DWC2_GRSTCTL_TXFFLSH | (num << DWC2_GRSTCTL_TXFNUM_OFFSET), - ®s->grstctl); - ret = wait_for_bit_le32(®s->grstctl, DWC2_GRSTCTL_TXFFLSH, + ®s->global_regs.grstctl); + ret = wait_for_bit_le32(®s->global_regs.grstctl, DWC2_GRSTCTL_TXFFLSH, false, 1000, false); if (ret) dev_info(dev, "%s: Timeout!\n", __func__); @@ -140,8 +141,8 @@ static void dwc_otg_flush_rx_fifo(struct udevice *dev, { int ret;
- writel(DWC2_GRSTCTL_RXFFLSH, ®s->grstctl); - ret = wait_for_bit_le32(®s->grstctl, DWC2_GRSTCTL_RXFFLSH, + writel(DWC2_GRSTCTL_RXFFLSH, ®s->global_regs.grstctl); + ret = wait_for_bit_le32(®s->global_regs.grstctl, DWC2_GRSTCTL_RXFFLSH, false, 1000, false); if (ret) dev_info(dev, "%s: Timeout!\n", __func__); @@ -160,14 +161,14 @@ static void dwc_otg_core_reset(struct udevice *dev, int ret;
/* Wait for AHB master IDLE state. */ - ret = wait_for_bit_le32(®s->grstctl, DWC2_GRSTCTL_AHBIDLE, + ret = wait_for_bit_le32(®s->global_regs.grstctl, DWC2_GRSTCTL_AHBIDLE, true, 1000, false); if (ret) dev_info(dev, "%s: Timeout!\n", __func__);
/* Core Soft Reset */ - writel(DWC2_GRSTCTL_CSFTRST, ®s->grstctl); - ret = wait_for_bit_le32(®s->grstctl, DWC2_GRSTCTL_CSFTRST, + writel(DWC2_GRSTCTL_CSFTRST, ®s->global_regs.grstctl); + ret = wait_for_bit_le32(®s->global_regs.grstctl, DWC2_GRSTCTL_CSFTRST, false, 1000, false); if (ret) dev_info(dev, "%s: Timeout!\n", __func__); @@ -260,16 +261,16 @@ static void dwc_otg_core_host_init(struct udevice *dev,
/* Configure data FIFO sizes */ #ifdef DWC2_ENABLE_DYNAMIC_FIFO - if (readl(®s->ghwcfg2) & DWC2_HWCFG2_DYNAMIC_FIFO) { + if (readl(®s->global_regs.ghwcfg2) & DWC2_HWCFG2_DYNAMIC_FIFO) { /* Rx FIFO */ - writel(DWC2_HOST_RX_FIFO_SIZE, ®s->grxfsiz); + writel(DWC2_HOST_RX_FIFO_SIZE, ®s->global_regs.grxfsiz);
/* Non-periodic Tx FIFO */ nptxfifosize |= DWC2_HOST_NPERIO_TX_FIFO_SIZE << DWC2_FIFOSIZE_DEPTH_OFFSET; nptxfifosize |= DWC2_HOST_RX_FIFO_SIZE << DWC2_FIFOSIZE_STARTADDR_OFFSET; - writel(nptxfifosize, ®s->gnptxfsiz); + writel(nptxfifosize, ®s->global_regs.gnptxfsiz);
/* Periodic Tx FIFO */ ptxfifosize |= DWC2_HOST_PERIO_TX_FIFO_SIZE << @@ -277,45 +278,45 @@ static void dwc_otg_core_host_init(struct udevice *dev, ptxfifosize |= (DWC2_HOST_RX_FIFO_SIZE + DWC2_HOST_NPERIO_TX_FIFO_SIZE) << DWC2_FIFOSIZE_STARTADDR_OFFSET; - writel(ptxfifosize, ®s->hptxfsiz); + writel(ptxfifosize, ®s->global_regs.hptxfsiz); } #endif
/* Clear Host Set HNP Enable in the OTG Control Register */ - clrbits_le32(®s->gotgctl, DWC2_GOTGCTL_HSTSETHNPEN); + clrbits_le32(®s->global_regs.gotgctl, DWC2_GOTGCTL_HSTSETHNPEN);
/* Make sure the FIFOs are flushed. */ dwc_otg_flush_tx_fifo(dev, regs, 0x10); /* All Tx FIFOs */ dwc_otg_flush_rx_fifo(dev, regs);
/* Flush out any leftover queued requests. */ - num_channels = readl(®s->ghwcfg2); + num_channels = readl(®s->global_regs.ghwcfg2); num_channels &= DWC2_HWCFG2_NUM_HOST_CHAN_MASK; num_channels >>= DWC2_HWCFG2_NUM_HOST_CHAN_OFFSET; num_channels += 1;
for (i = 0; i < num_channels; i++) - clrsetbits_le32(®s->hc_regs[i].hcchar, + clrsetbits_le32(®s->host_regs.hc[i].hcchar, DWC2_HCCHAR_CHEN | DWC2_HCCHAR_EPDIR, DWC2_HCCHAR_CHDIS);
/* Halt all channels to put them into a known state. */ for (i = 0; i < num_channels; i++) { - clrsetbits_le32(®s->hc_regs[i].hcchar, + clrsetbits_le32(®s->host_regs.hc[i].hcchar, DWC2_HCCHAR_EPDIR, DWC2_HCCHAR_CHEN | DWC2_HCCHAR_CHDIS); - ret = wait_for_bit_le32(®s->hc_regs[i].hcchar, + ret = wait_for_bit_le32(®s->host_regs.hc[i].hcchar, DWC2_HCCHAR_CHEN, false, 1000, false); if (ret) dev_info(dev, "%s: Timeout!\n", __func__); }
/* Turn on the vbus power. */ - if (readl(®s->gintsts) & DWC2_GINTSTS_CURMODE_HOST) { - hprt0 = readl(®s->hprt0) & ~DWC2_HPRT0_W1C_MASK; + if (readl(®s->global_regs.gintsts) & DWC2_GINTSTS_CURMODE_HOST) { + hprt0 = readl(®s->host_regs.hprt0) & ~DWC2_HPRT0_W1C_MASK; if (!(hprt0 & DWC2_HPRT0_PRTPWR)) { hprt0 |= DWC2_HPRT0_PRTPWR; - writel(hprt0, ®s->hprt0); + writel(hprt0, ®s->host_regs.hprt0); } }
@@ -338,7 +339,7 @@ static void dwc_otg_core_init(struct udevice *dev) uint8_t brst_sz = DWC2_DMA_BURST_SIZE;
/* Common Initialization */ - usbcfg = readl(®s->gusbcfg); + usbcfg = readl(®s->global_regs.gusbcfg);
/* Program the ULPI External VBUS bit if needed */ if (priv->ext_vbus) { @@ -357,7 +358,7 @@ static void dwc_otg_core_init(struct udevice *dev) #else usbcfg &= ~DWC2_GUSBCFG_TERM_SEL_DL_PULSE; #endif - writel(usbcfg, ®s->gusbcfg); + writel(usbcfg, ®s->global_regs.gusbcfg);
/* Reset the Controller */ dwc_otg_core_reset(dev, regs); @@ -369,28 +370,28 @@ static void dwc_otg_core_init(struct udevice *dev) #if defined(DWC2_DFLT_SPEED_FULL) && \ (DWC2_PHY_TYPE == DWC2_PHY_TYPE_FS) /* If FS mode with FS PHY */ - setbits_le32(®s->gusbcfg, DWC2_GUSBCFG_PHYSEL); + setbits_le32(®s->global_regs.gusbcfg, DWC2_GUSBCFG_PHYSEL);
/* Reset after a PHY select */ - dwc_otg_core_reset(dev, regs); + dwc2_core_reset(regs);
/* * Program DCFG.DevSpd or HCFG.FSLSPclkSel to 48Mhz in FS. * Also do this on HNP Dev/Host mode switches (done in dev_init * and host_init). */ - if (readl(®s->gintsts) & DWC2_GINTSTS_CURMODE_HOST) + if (readl(®s->global_regs.gintsts) & DWC2_GINTSTS_CURMODE_HOST) init_fslspclksel(regs);
#ifdef DWC2_I2C_ENABLE /* Program GUSBCFG.OtgUtmifsSel to I2C */ - setbits_le32(®s->gusbcfg, DWC2_GUSBCFG_OTGUTMIFSSEL); + setbits_le32(®s->global_regs.gusbcfg, DWC2_GUSBCFG_OTGUTMIFSSEL);
/* Program GI2CCTL.I2CEn */ - clrsetbits_le32(®s->gi2cctl, DWC2_GI2CCTL_I2CEN | + clrsetbits_le32(®s->global_regs.gi2cctl, DWC2_GI2CCTL_I2CEN | DWC2_GI2CCTL_I2CDEVADDR_MASK, 1 << DWC2_GI2CCTL_I2CDEVADDR_OFFSET); - setbits_le32(®s->gi2cctl, DWC2_GI2CCTL_I2CEN); + setbits_le32(®s->global_regs.gi2cctl, DWC2_GI2CCTL_I2CEN); #endif
#else @@ -416,16 +417,16 @@ static void dwc_otg_core_init(struct udevice *dev) #endif }
/* Reset after setting the PHY parameters */ dwc_otg_core_reset(dev, regs); #endif
- usbcfg = readl(®s->gusbcfg); + usbcfg = readl(®s->global_regs.gusbcfg); usbcfg &= ~(DWC2_GUSBCFG_ULPI_FSLS | DWC2_GUSBCFG_ULPI_CLK_SUS_M); #ifdef DWC2_ULPI_FS_LS - uint32_t hwcfg2 = readl(®s->ghwcfg2); + uint32_t hwcfg2 = readl(®s->global_regs.ghwcfg2); uint32_t hval = (ghwcfg2 & DWC2_HWCFG2_HS_PHY_TYPE_MASK) >> DWC2_HWCFG2_HS_PHY_TYPE_OFFSET; uint32_t fval = (ghwcfg2 & DWC2_HWCFG2_FS_PHY_TYPE_MASK) >> @@ -438,10 +439,10 @@ static void dwc_otg_core_init(struct udevice *dev) if (priv->hnp_srp_disable) usbcfg |= DWC2_GUSBCFG_FORCEHOSTMODE;
/* Program the GAHBCFG Register. */ - switch (readl(®s->ghwcfg2) & DWC2_HWCFG2_ARCHITECTURE_MASK) { + switch (readl(®s->global_regs.ghwcfg2) & DWC2_HWCFG2_ARCHITECTURE_MASK) { case DWC2_HWCFG2_ARCHITECTURE_SLAVE_ONLY: break; case DWC2_HWCFG2_ARCHITECTURE_EXT_DMA: @@ -464,7 +465,7 @@ static void dwc_otg_core_init(struct udevice *dev) break; }
- writel(ahbcfg, ®s->gahbcfg); + writel(ahbcfg, ®s->global_regs.gahbcfg);
/* Program the capabilities in GUSBCFG Register */ usbcfg = 0; @@ -475,7 +476,7 @@ static void dwc_otg_core_init(struct udevice *dev) usbcfg |= DWC2_GUSBCFG_IC_USB_CAP; #endif
- setbits_le32(®s->gusbcfg, usbcfg); + setbits_le32(®s->global_regs.gusbcfg, usbcfg); }
/* @@ -491,7 +492,7 @@ static void dwc_otg_hc_init(struct dwc2_core_regs *regs, uint8_t hc_num, struct usb_device *dev, uint8_t dev_addr, uint8_t ep_num, uint8_t ep_is_in, uint8_t ep_type, uint16_t max_packet) { - struct dwc2_hc_regs *hc_regs = ®s->hc_regs[hc_num]; + struct dwc2_hc_regs *hc_regs = ®s->host_regs.hc[hc_num]; uint32_t hcchar = (dev_addr << DWC2_HCCHAR_DEVADDR_OFFSET) | (ep_num << DWC2_HCCHAR_EPNUM_OFFSET) | (ep_is_in << DWC2_HCCHAR_EPDIR_OFFSET) | @@ -553,7 +554,7 @@ static int dwc_otg_submit_rh_msg_in_status(struct dwc2_core_regs *regs, len = 4; break; case USB_RECIP_OTHER | USB_TYPE_CLASS: - hprt0 = readl(®s->hprt0); + hprt0 = readl(®s->host_regs.hprt0); if (hprt0 & DWC2_HPRT0_PRTCONNSTS) port_status |= USB_PORT_STAT_CONNECTION; if (hprt0 & DWC2_HPRT0_PRTENA) @@ -743,7 +744,8 @@ static int dwc_otg_submit_rh_msg_out(struct dwc2_priv *priv, case (USB_REQ_CLEAR_FEATURE << 8) | USB_RECIP_OTHER | USB_TYPE_CLASS: switch (wValue) { case USB_PORT_FEAT_C_CONNECTION: - clrsetbits_le32(®s->hprt0, DWC2_HPRT0_W1C_MASK, DWC2_HPRT0_PRTCONNDET); + clrsetbits_le32(®s->host_regs.hprt0, DWC2_HPRT0_W1C_MASK, + DWC2_HPRT0_PRTCONNDET); break; } break; @@ -754,13 +756,16 @@ static int dwc_otg_submit_rh_msg_out(struct dwc2_priv *priv, break;
case USB_PORT_FEAT_RESET: - clrsetbits_le32(®s->hprt0, DWC2_HPRT0_W1C_MASK, DWC2_HPRT0_PRTRST); + clrsetbits_le32(®s->host_regs.hprt0, DWC2_HPRT0_W1C_MASK, + DWC2_HPRT0_PRTRST); mdelay(50); - clrbits_le32(®s->hprt0, DWC2_HPRT0_W1C_MASK | DWC2_HPRT0_PRTRST); + clrbits_le32(®s->host_regs.hprt0, + DWC2_HPRT0_W1C_MASK | DWC2_HPRT0_PRTRST); break;
case USB_PORT_FEAT_POWER: - clrsetbits_le32(®s->hprt0, DWC2_HPRT0_W1C_MASK, DWC2_HPRT0_PRTRST); + clrsetbits_le32(®s->host_regs.hprt0, DWC2_HPRT0_W1C_MASK, + DWC2_HPRT0_PRTRST); break;
case USB_PORT_FEAT_ENABLE: @@ -907,7 +912,7 @@ int chunk_msg(struct dwc2_priv *priv, struct usb_device *dev, unsigned long pipe, u8 *pid, int in, void *buffer, int len) { struct dwc2_core_regs *regs = priv->regs; - struct dwc2_hc_regs *hc_regs = ®s->hc_regs[DWC2_HC_CHANNEL]; + struct dwc2_hc_regs *hc_regs = ®s->host_regs.hc[DWC2_HC_CHANNEL]; struct dwc2_host_regs *host_regs = ®s->host_regs; int devnum = usb_pipedevice(pipe); int ep = usb_pipeendpoint(pipe); @@ -944,7 +949,8 @@ int chunk_msg(struct dwc2_priv *priv, struct usb_device *dev, if (dev->speed != USB_SPEED_HIGH) { uint8_t hub_addr; uint8_t hub_port; - uint32_t hprt0 = readl(®s->hprt0); + uint32_t hprt0 = readl(®s->host_regs.hprt0); + if ((hprt0 & DWC2_HPRT0_PRTSPD_MASK) == DWC2_HPRT0_PRTSPD_HIGH) { usb_find_usb2_hub_address_port(dev, &hub_addr, @@ -1174,7 +1180,7 @@ static int dwc2_init_common(struct udevice *dev, struct dwc2_priv *priv) if (ret) return ret;
- snpsid = readl(®s->gsnpsid); + snpsid = readl(®s->global_regs.gsnpsid); dev_info(dev, "Core Release: %x.%03x\n", snpsid >> 12 & 0xf, snpsid & 0xfff);
@@ -1200,9 +1206,9 @@ static int dwc2_init_common(struct udevice *dev, struct dwc2_priv *priv) dwc_otg_core_host_init(dev, regs); }
- clrsetbits_le32(®s->hprt0, DWC2_HPRT0_W1C_MASK, DWC2_HPRT0_PRTRST); + clrsetbits_le32(®s->host_regs.hprt0, DWC2_HPRT0_W1C_MASK, DWC2_HPRT0_PRTRST); mdelay(50); - clrbits_le32(®s->hprt0, DWC2_HPRT0_W1C_MASK | DWC2_HPRT0_PRTRST); + clrbits_le32(®s->host_regs.hprt0, DWC2_HPRT0_W1C_MASK | DWC2_HPRT0_PRTRST);
for (i = 0; i < MAX_DEVICE; i++) { for (j = 0; j < MAX_ENDPOINT; j++) { @@ -1217,7 +1223,7 @@ static int dwc2_init_common(struct udevice *dev, struct dwc2_priv *priv) * is started (the bus is scanned) and fixes the USB detection * problems with some problematic USB keys. */ - if (readl(®s->gintsts) & DWC2_GINTSTS_CURMODE_HOST) + if (readl(®s->global_regs.gintsts) & DWC2_GINTSTS_CURMODE_HOST) mdelay(1000);
printf("USB DWC2\n"); @@ -1228,7 +1234,7 @@ static int dwc2_init_common(struct udevice *dev, struct dwc2_priv *priv) static void dwc2_uninit_common(struct dwc2_core_regs *regs) { /* Put everything in reset. */ - clrsetbits_le32(®s->hprt0, DWC2_HPRT0_W1C_MASK, DWC2_HPRT0_PRTRST); + clrsetbits_le32(®s->host_regs.hprt0, DWC2_HPRT0_W1C_MASK, DWC2_HPRT0_PRTRST); }
#if !CONFIG_IS_ENABLED(DM_USB) diff --git a/drivers/usb/host/dwc2.h b/drivers/usb/host/dwc2.h index 6f022e33a19244d65a6b82e210948506c7bc1096..61b544462edfd6778ddf2ddf2dcf6db3f02a3754 100644 --- a/drivers/usb/host/dwc2.h +++ b/drivers/usb/host/dwc2.h @@ -6,64 +6,6 @@ #ifndef __DWC2_H__ #define __DWC2_H__
-struct dwc2_hc_regs { - u32 hcchar; /* 0x00 */ - u32 hcsplt; - u32 hcint; - u32 hcintmsk; - u32 hctsiz; /* 0x10 */ - u32 hcdma; - u32 reserved; - u32 hcdmab; -}; - -struct dwc2_host_regs { - u32 hcfg; /* 0x00 */ - u32 hfir; - u32 hfnum; - u32 _pad_0x40c; - u32 hptxsts; /* 0x10 */ - u32 haint; - u32 haintmsk; - u32 hflbaddr; -}; - -struct dwc2_core_regs { - u32 gotgctl; /* 0x000 */ - u32 gotgint; - u32 gahbcfg; - u32 gusbcfg; - u32 grstctl; /* 0x010 */ - u32 gintsts; - u32 gintmsk; - u32 grxstsr; - u32 grxstsp; /* 0x020 */ - u32 grxfsiz; - u32 gnptxfsiz; - u32 gnptxsts; - u32 gi2cctl; /* 0x030 */ - u32 gpvndctl; - u32 ggpio; - u32 guid; - u32 gsnpsid; /* 0x040 */ - u32 ghwcfg1; - u32 ghwcfg2; - u32 ghwcfg3; - u32 ghwcfg4; /* 0x050 */ - u32 glpmcfg; - u32 _pad_0x58_0x9c[42]; - u32 hptxfsiz; /* 0x100 */ - u32 dptxfsiz_dieptxf[15]; - u32 _pad_0x140_0x3fc[176]; - struct dwc2_host_regs host_regs; /* 0x400 */ - u32 _pad_0x420_0x43c[8]; - u32 hprt0; /* 0x440 */ - u32 _pad_0x444_0x4fc[47]; - struct dwc2_hc_regs hc_regs[16]; /* 0x500 */ - u32 _pad_0x700_0xe00[448]; - u32 pcgcctl; /* 0xe00 */ -}; - #define DWC2_GOTGCTL_SESREQSCS (1 << 0) #define DWC2_GOTGCTL_SESREQSCS_OFFSET 0 #define DWC2_GOTGCTL_SESREQ (1 << 1)
The ULPI_UTMI_SEL bit in the DWC2 driver was set incorrectly. According to the datasheet [1], this bit should be set to 0 for UTMI interface and 1 for ULPI interface. The existing code had this logic reversed, causing the interface selection to be incorrect.
This commit corrects the ULPI_UTMI_SEL bit setting to match the datasheet's description. Referencing the kernel's code [2] also confirms this fix.
[1] https://rockchip.fr/RK312X%20TRM/chapter-26-usb-otg-2-0.pdf#page=30 [2] https://github.com/torvalds/linux/blob/v6.13-rc3/drivers/usb/dwc2/core.c#L11...
Reviewed-by: Marek Vasut marex@denx.de Tested-by: Peter Robinson pbrobinson@gmail.com Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Junhui Liu junhui.liu@pigmoral.tech --- drivers/usb/host/dwc2.c | 24 +++++++++++++----------- 1 file changed, 13 insertions(+), 11 deletions(-)
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index b6c8b3d5a6bdf375f1adeb106d4832d92307f0db..609de18faa3abc5f4ecb0c23cf3590966bad7992 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -402,20 +402,22 @@ static void dwc_otg_core_init(struct udevice *dev) * soft reset so only program the first time. Do a soft reset * immediately after setting phyif. */ - usbcfg &= ~(DWC2_GUSBCFG_ULPI_UTMI_SEL | DWC2_GUSBCFG_PHYIF); - usbcfg |= DWC2_PHY_TYPE << DWC2_GUSBCFG_ULPI_UTMI_SEL_OFFSET; - - if (usbcfg & DWC2_GUSBCFG_ULPI_UTMI_SEL) { /* ULPI interface */ +#if (DWC2_PHY_TYPE == DWC2_PHY_TYPE_ULPI) + usbcfg |= DWC2_GUSBCFG_ULPI_UTMI_SEL; + usbcfg &= ~DWC2_GUSBCFG_PHYIF; #ifdef DWC2_PHY_ULPI_DDR - usbcfg |= DWC2_GUSBCFG_DDRSEL; + usbcfg |= DWC2_GUSBCFG_DDRSEL; #else - usbcfg &= ~DWC2_GUSBCFG_DDRSEL; -#endif - } else { /* UTMI+ interface */ + usbcfg &= ~DWC2_GUSBCFG_DDRSEL; +#endif /* DWC2_PHY_ULPI_DDR */ +#elif (DWC2_PHY_TYPE == DWC2_PHY_TYPE_UTMI) + usbcfg &= ~DWC2_GUSBCFG_ULPI_UTMI_SEL; #if (DWC2_UTMI_WIDTH == 16) - usbcfg |= DWC2_GUSBCFG_PHYIF; -#endif - } + usbcfg |= DWC2_GUSBCFG_PHYIF; +#else + usbcfg &= ~DWC2_GUSBCFG_PHYIF; +#endif /* DWC2_UTMI_WIDTH */ +#endif /* DWC2_PHY_TYPE */
The loop used to calculate HBstLen for extern DMA mode does not produce the correct result according to the datasheet [1]. Replacing that loop with a direct calculation using LOG2 to correctly assign the burst length in the GAHBCFG register for external DMA mode.
[1] https://rockchip.fr/RK312X%20TRM/chapter-26-usb-otg-2-0.pdf#page=24
--- Additionally, the boards I have only use internal DMA mode, and it’s unclear which chips employ external DMA. The testing was performed by comparing against the datasheet, and the results are shown in [2].
[2] https://gist.github.com/Judehahh/34530da390b58728102778406e602cb1 --- drivers/usb/host/dwc2.c | 7 ++----- 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index 609de18faa3abc5f4ecb0c23cf3590966bad7992..954650d856a4f2e95d74e1b5716c0ebe83fa9ba8 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -448,11 +448,8 @@ static void dwc_otg_core_init(struct udevice *dev) case DWC2_HWCFG2_ARCHITECTURE_SLAVE_ONLY: break; case DWC2_HWCFG2_ARCHITECTURE_EXT_DMA: - while (brst_sz > 1) { - ahbcfg |= ahbcfg + (1 << DWC2_GAHBCFG_HBURSTLEN_OFFSET); - ahbcfg &= DWC2_GAHBCFG_HBURSTLEN_MASK; - brst_sz >>= 1; - } + ahbcfg |= (LOG2(brst_sz >> 1) << DWC2_GAHBCFG_HBURSTLEN_OFFSET) & + DWC2_GAHBCFG_HBURSTLEN_MASK;
#ifdef DWC2_DMA_ENABLE ahbcfg |= DWC2_GAHBCFG_DMAENABLE;
Use FIELD_PREP, FIELD_GET, BIT, and GENMASK macros to standardize bit manipulation across the DWC2 code, improving readability and maintainability without altering functionality.
Signed-off-by: Kongyang Liu seashell11234455@gmail.com Reviewed-by: Marek Vasut marex@denx.de Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Tested-by: Peter Robinson pbrobinson@gmail.com Signed-off-by: Junhui Liu junhui.liu@pigmoral.tech --- drivers/usb/gadget/dwc2_udc_otg.c | 5 +- drivers/usb/gadget/dwc2_udc_otg_regs.h | 250 ++++---- drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c | 21 +- drivers/usb/host/dwc2.c | 101 ++- drivers/usb/host/dwc2.h | 993 ++++++++++------------------- 5 files changed, 517 insertions(+), 853 deletions(-)
diff --git a/drivers/usb/gadget/dwc2_udc_otg.c b/drivers/usb/gadget/dwc2_udc_otg.c index fde1a6af6b0e79c9bd8d24b0849c4030bd22012b..b89f751b8cc08c4f9a7cee4ac829b5a9648e930a 100644 --- a/drivers/usb/gadget/dwc2_udc_otg.c +++ b/drivers/usb/gadget/dwc2_udc_otg.c @@ -29,6 +29,7 @@ #include <linux/delay.h> #include <linux/printk.h>
+#include <linux/bitfield.h> #include <linux/errno.h> #include <linux/list.h>
@@ -526,8 +527,8 @@ static void reconfig_usbd(struct dwc2_udc *dev) }
/* 8. Unmask EPO interrupts*/ - writel(((1 << EP0_CON) << DAINT_OUT_BIT) - | (1 << EP0_CON), ®->device_regs.daintmsk); + writel(FIELD_PREP(DAINT_OUTEP_MASK, BIT(EP0_CON)) | + FIELD_PREP(DAINT_INEP_MASK, BIT(EP0_CON)), ®->device_regs.daintmsk);
/* 9. Unmask device OUT EP common interrupts*/ writel(DOEPMSK_INIT, ®->device_regs.doepmsk); diff --git a/drivers/usb/gadget/dwc2_udc_otg_regs.h b/drivers/usb/gadget/dwc2_udc_otg_regs.h index 198ba7a7c37d05dca084ef017534265f5fb5fd70..34b1c15ea174cc80f04a69bf41ff1819de10ccaa 100644 --- a/drivers/usb/gadget/dwc2_udc_otg_regs.h +++ b/drivers/usb/gadget/dwc2_udc_otg_regs.h @@ -32,45 +32,44 @@ struct dwc2_usbotg_phy { #define VB_VALOEN BIT(2)
/* DWC2_UDC_OTG_GOTINT */ -#define GOTGINT_SES_END_DET (1<<2) +#define GOTGINT_SES_END_DET BIT(2)
/* DWC2_UDC_OTG_GAHBCFG */ -#define PTXFE_HALF (0<<8) -#define PTXFE_ZERO (1<<8) -#define NPTXFE_HALF (0<<7) -#define NPTXFE_ZERO (1<<7) -#define MODE_SLAVE (0<<5) -#define MODE_DMA (1<<5) -#define BURST_SINGLE (0<<1) -#define BURST_INCR (1<<1) -#define BURST_INCR4 (3<<1) -#define BURST_INCR8 (5<<1) -#define BURST_INCR16 (7<<1) -#define GBL_INT_UNMASK (1<<0) -#define GBL_INT_MASK (0<<0) +#define PTXFE_HALF (0 << 8) +#define PTXFE_ZERO (1 << 8) +#define NPTXFE_HALF (0 << 7) +#define NPTXFE_ZERO (1 << 7) +#define MODE_SLAVE (0 << 5) +#define MODE_DMA (1 << 5) +#define BURST_SINGLE (0 << 1) +#define BURST_INCR (1 << 1) +#define BURST_INCR4 (3 << 1) +#define BURST_INCR8 (5 << 1) +#define BURST_INCR16 (7 << 1) +#define GBL_INT_UNMASK (1 << 0) +#define GBL_INT_MASK (0 << 0)
/* DWC2_UDC_OTG_GRSTCTL */ -#define AHB_MASTER_IDLE (1u<<31) -#define CORE_SOFT_RESET (0x1<<0) +#define AHB_MASTER_IDLE BIT(31) +#define CORE_SOFT_RESET BIT(0)
/* DWC2_UDC_OTG_GINTSTS/DWC2_UDC_OTG_GINTMSK core interrupt register */ -#define INT_RESUME (1u<<31) -#define INT_DISCONN (0x1<<29) -#define INT_CONN_ID_STS_CNG (0x1<<28) -#define INT_OUT_EP (0x1<<19) -#define INT_IN_EP (0x1<<18) -#define INT_ENUMDONE (0x1<<13) -#define INT_RESET (0x1<<12) -#define INT_SUSPEND (0x1<<11) -#define INT_EARLY_SUSPEND (0x1<<10) -#define INT_NP_TX_FIFO_EMPTY (0x1<<5) -#define INT_RX_FIFO_NOT_EMPTY (0x1<<4) -#define INT_SOF (0x1<<3) -#define INT_OTG (0x1<<2) -#define INT_DEV_MODE (0x0<<0) -#define INT_HOST_MODE (0x1<<1) -#define INT_GOUTNakEff (0x01<<7) -#define INT_GINNakEff (0x01<<6) +#define INT_RESUME BIT(31) +#define INT_DISCONN BIT(29) +#define INT_CONN_ID_STS_CNG BIT(28) +#define INT_OUT_EP BIT(19) +#define INT_IN_EP BIT(18) +#define INT_ENUMDONE BIT(13) +#define INT_RESET BIT(12) +#define INT_SUSPEND BIT(11) +#define INT_EARLY_SUSPEND BIT(10) +#define INT_GOUTNakEff BIT(7) +#define INT_GINNakEff BIT(6) +#define INT_NP_TX_FIFO_EMPTY BIT(5) +#define INT_RX_FIFO_NOT_EMPTY BIT(4) +#define INT_SOF BIT(3) +#define INT_OTG BIT(2) +#define INT_HOST_MODE BIT(1)
#define FULL_SPEED_CONTROL_PKT_SIZE 8 #define FULL_SPEED_BULK_PKT_SIZE 64 @@ -78,119 +77,117 @@ struct dwc2_usbotg_phy { #define HIGH_SPEED_CONTROL_PKT_SIZE 64 #define HIGH_SPEED_BULK_PKT_SIZE 512
-#define RX_FIFO_SIZE (1024) -#define NPTX_FIFO_SIZE (1024) -#define PTX_FIFO_SIZE (384) +#define RX_FIFO_SIZE 1024 +#define NPTX_FIFO_SIZE 1024 +#define PTX_FIFO_SIZE 384
-#define DEPCTL_TXFNUM_0 (0x0<<22) -#define DEPCTL_TXFNUM_1 (0x1<<22) -#define DEPCTL_TXFNUM_2 (0x2<<22) -#define DEPCTL_TXFNUM_3 (0x3<<22) -#define DEPCTL_TXFNUM_4 (0x4<<22) +#define DEPCTL_TXFNUM_0 (0x0 << 22) +#define DEPCTL_TXFNUM_1 (0x1 << 22) +#define DEPCTL_TXFNUM_2 (0x2 << 22) +#define DEPCTL_TXFNUM_3 (0x3 << 22) +#define DEPCTL_TXFNUM_4 (0x4 << 22)
/* Enumeration speed */ -#define USB_HIGH_30_60MHZ (0x0<<1) -#define USB_FULL_30_60MHZ (0x1<<1) -#define USB_LOW_6MHZ (0x2<<1) -#define USB_FULL_48MHZ (0x3<<1) +#define USB_HIGH_30_60MHZ (0x0 << 1) +#define USB_FULL_30_60MHZ (0x1 << 1) +#define USB_LOW_6MHZ (0x2 << 1) +#define USB_FULL_48MHZ (0x3 << 1)
/* DWC2_UDC_OTG_GRXSTSP STATUS */ -#define OUT_PKT_RECEIVED (0x2<<17) -#define OUT_TRANSFER_COMPLELTED (0x3<<17) -#define SETUP_TRANSACTION_COMPLETED (0x4<<17) -#define SETUP_PKT_RECEIVED (0x6<<17) -#define GLOBAL_OUT_NAK (0x1<<17) +#define OUT_PKT_RECEIVED (0x2 << 17) +#define OUT_TRANSFER_COMPLELTED (0x3 << 17) +#define SETUP_TRANSACTION_COMPLETED (0x4 << 17) +#define SETUP_PKT_RECEIVED (0x6 << 17) +#define GLOBAL_OUT_NAK (0x1 << 17)
/* DWC2_UDC_OTG_DCTL device control register */ -#define NORMAL_OPERATION (0x1<<0) -#define SOFT_DISCONNECT (0x1<<1) +#define NORMAL_OPERATION BIT(0) +#define SOFT_DISCONNECT BIT(1)
/* DWC2_UDC_OTG_DAINT device all endpoint interrupt register */ -#define DAINT_OUT_BIT (16) -#define DAINT_MASK (0xFFFF) +#define DAINT_OUTEP_MASK GENMASK(31, 16) +#define DAINT_INEP_MASK GENMASK(15, 0)
/* DWC2_UDC_OTG_DIEPCTL0/DOEPCTL0 device control IN/OUT endpoint 0 control register */ -#define DEPCTL_EPENA (0x1<<31) -#define DEPCTL_EPDIS (0x1<<30) -#define DEPCTL_SETD1PID (0x1<<29) -#define DEPCTL_SETD0PID (0x1<<28) -#define DEPCTL_SNAK (0x1<<27) -#define DEPCTL_CNAK (0x1<<26) -#define DEPCTL_STALL (0x1<<21) -#define DEPCTL_TYPE_BIT (18) -#define DEPCTL_TYPE_MASK (0x3<<18) -#define DEPCTL_CTRL_TYPE (0x0<<18) -#define DEPCTL_ISO_TYPE (0x1<<18) -#define DEPCTL_BULK_TYPE (0x2<<18) -#define DEPCTL_INTR_TYPE (0x3<<18) -#define DEPCTL_USBACTEP (0x1<<15) -#define DEPCTL_NEXT_EP_BIT (11) -#define DEPCTL_MPS_BIT (0) -#define DEPCTL_MPS_MASK (0x7FF) - -#define DEPCTL0_MPS_64 (0x0<<0) -#define DEPCTL0_MPS_32 (0x1<<0) -#define DEPCTL0_MPS_16 (0x2<<0) -#define DEPCTL0_MPS_8 (0x3<<0) -#define DEPCTL_MPS_BULK_512 (512<<0) -#define DEPCTL_MPS_INT_MPS_16 (16<<0) +#define DEPCTL_EPENA BIT(31) +#define DEPCTL_EPDIS BIT(30) +#define DEPCTL_SETD1PID BIT(29) +#define DEPCTL_SETD0PID BIT(28) +#define DEPCTL_SNAK BIT(27) +#define DEPCTL_CNAK BIT(26) +#define DEPCTL_STALL BIT(21) +#define DEPCTL_TYPE_MASK GENMASK(19, 18) +#define DEPCTL_CTRL_TYPE (0x0 << 18) +#define DEPCTL_ISO_TYPE (0x1 << 18) +#define DEPCTL_BULK_TYPE (0x2 << 18) +#define DEPCTL_INTR_TYPE (0x3 << 18) +#define DEPCTL_USBACTEP BIT(15) +#define DEPCTL_NEXT_EP_MASK GENMASK(14, 11) +#define DEPCTL_MPS_MASK GENMASK(10, 0) + +#define DEPCTL0_MPS_64 (0x0 << 0) +#define DEPCTL0_MPS_32 (0x1 << 0) +#define DEPCTL0_MPS_16 (0x2 << 0) +#define DEPCTL0_MPS_8 (0x3 << 0) +#define DEPCTL_MPS_BULK_512 (512 << 0) +#define DEPCTL_MPS_INT_MPS_16 (16 << 0)
#define DIEPCTL0_NEXT_EP_BIT (11)
/* DWC2_UDC_OTG_DIEPMSK/DOEPMSK device IN/OUT endpoint common interrupt mask register */ /* DWC2_UDC_OTG_DIEPINTn/DOEPINTn device IN/OUT endpoint interrupt register */ -#define BACK2BACK_SETUP_RECEIVED (0x1<<6) -#define INTKNEPMIS (0x1<<5) -#define INTKN_TXFEMP (0x1<<4) -#define NON_ISO_IN_EP_TIMEOUT (0x1<<3) -#define CTRL_OUT_EP_SETUP_PHASE_DONE (0x1<<3) -#define AHB_ERROR (0x1<<2) -#define EPDISBLD (0x1<<1) -#define TRANSFER_DONE (0x1<<0) +#define BACK2BACK_SETUP_RECEIVED BIT(6) +#define INTKNEPMIS BIT(5) +#define INTKN_TXFEMP BIT(4) +#define NON_ISO_IN_EP_TIMEOUT BIT(3) +#define CTRL_OUT_EP_SETUP_PHASE_DONE BIT(3) +#define AHB_ERROR BIT(2) +#define EPDISBLD BIT(1) +#define TRANSFER_DONE BIT(0)
-#define USB_PHY_CTRL_EN0 (0x1 << 0) +#define USB_PHY_CTRL_EN0 BIT(0)
/* OPHYPWR */ -#define PHY_0_SLEEP (0x1 << 5) -#define OTG_DISABLE_0 (0x1 << 4) -#define ANALOG_PWRDOWN (0x1 << 3) -#define FORCE_SUSPEND_0 (0x1 << 0) +#define PHY_0_SLEEP BIT(5) +#define OTG_DISABLE_0 BIT(4) +#define ANALOG_PWRDOWN BIT(3) +#define FORCE_SUSPEND_0 BIT(0)
/* URSTCON */ -#define HOST_SW_RST (0x1 << 4) -#define PHY_SW_RST1 (0x1 << 3) -#define PHYLNK_SW_RST (0x1 << 2) -#define LINK_SW_RST (0x1 << 1) -#define PHY_SW_RST0 (0x1 << 0) +#define HOST_SW_RST BIT(4) +#define PHY_SW_RST1 BIT(3) +#define PHYLNK_SW_RST BIT(2) +#define LINK_SW_RST BIT(1) +#define PHY_SW_RST0 BIT(0)
/* OPHYCLK */ -#define COMMON_ON_N1 (0x1 << 7) -#define COMMON_ON_N0 (0x1 << 4) -#define ID_PULLUP0 (0x1 << 2) -#define CLK_SEL_24MHZ (0x3 << 0) -#define CLK_SEL_12MHZ (0x2 << 0) -#define CLK_SEL_48MHZ (0x0 << 0) - -#define EXYNOS4X12_ID_PULLUP0 (0x01 << 3) -#define EXYNOS4X12_COMMON_ON_N0 (0x01 << 4) +#define COMMON_ON_N1 BIT(7) +#define COMMON_ON_N0 BIT(4) +#define ID_PULLUP0 BIT(2) +#define CLK_SEL_24MHZ (0x3 << 0) +#define CLK_SEL_12MHZ (0x2 << 0) +#define CLK_SEL_48MHZ (0x0 << 0) + +#define EXYNOS4X12_ID_PULLUP0 BIT(3) +#define EXYNOS4X12_COMMON_ON_N0 BIT(4) #define EXYNOS4X12_CLK_SEL_12MHZ (0x02 << 0) #define EXYNOS4X12_CLK_SEL_24MHZ (0x05 << 0)
/* Device Configuration Register DCFG */ -#define DEV_SPEED_HIGH_SPEED_20 (0x0 << 0) -#define DEV_SPEED_FULL_SPEED_20 (0x1 << 0) -#define DEV_SPEED_LOW_SPEED_11 (0x2 << 0) -#define DEV_SPEED_FULL_SPEED_11 (0x3 << 0) -#define EP_MISS_CNT(x) (x << 18) -#define DEVICE_ADDRESS(x) (x << 4) +#define DEV_SPEED_HIGH_SPEED_20 (0x0 << 0) +#define DEV_SPEED_FULL_SPEED_20 (0x1 << 0) +#define DEV_SPEED_LOW_SPEED_11 (0x2 << 0) +#define DEV_SPEED_FULL_SPEED_11 (0x3 << 0) +#define EP_MISS_CNT(x) ((x) << 18) +#define DEVICE_ADDRESS(x) ((x) << 4)
/* Core Reset Register (GRSTCTL) */ -#define TX_FIFO_FLUSH (0x1 << 5) -#define RX_FIFO_FLUSH (0x1 << 4) -#define TX_FIFO_NUMBER(x) (x << 6) -#define TX_FIFO_FLUSH_ALL TX_FIFO_NUMBER(0x10) +#define TX_FIFO_FLUSH BIT(5) +#define RX_FIFO_FLUSH BIT(4) +#define TX_FIFO_NUMBER(x) ((x) << 6) +#define TX_FIFO_FLUSH_ALL TX_FIFO_NUMBER(0x10)
/* Masks definitions */ #define GINTMSK_INIT (INT_OUT_EP | INT_IN_EP | INT_RESUME | INT_ENUMDONE\ @@ -201,29 +198,28 @@ struct dwc2_usbotg_phy { | GBL_INT_UNMASK)
/* Device Endpoint X Transfer Size Register (DIEPTSIZX) */ -#define DIEPT_SIZ_PKT_CNT(x) (x << 19) -#define DIEPT_SIZ_XFER_SIZE(x) (x << 0) +#define DIEPT_SIZ_PKT_CNT(x) ((x) << 19) +#define DIEPT_SIZ_XFER_SIZE(x) ((x) << 0)
/* Device OUT Endpoint X Transfer Size Register (DOEPTSIZX) */ -#define DOEPT_SIZ_PKT_CNT(x) (x << 19) -#define DOEPT_SIZ_XFER_SIZE(x) (x << 0) -#define DOEPT_SIZ_XFER_SIZE_MAX_EP0 (0x7F << 0) -#define DOEPT_SIZ_XFER_SIZE_MAX_EP (0x7FFF << 0) +#define DOEPT_SIZ_PKT_CNT(x) ((x) << 19) +#define DOEPT_SIZ_XFER_SIZE(x) ((x) << 0) +#define DOEPT_SIZ_XFER_SIZE_MAX_EP0 (0x7F << 0) +#define DOEPT_SIZ_XFER_SIZE_MAX_EP (0x7FFF << 0)
/* Device Endpoint-N Control Register (DIEPCTLn/DOEPCTLn) */ -#define DIEPCTL_TX_FIFO_NUM(x) (x << 22) -#define DIEPCTL_TX_FIFO_NUM_MASK (~DIEPCTL_TX_FIFO_NUM(0xF)) +#define DIEPCTL_TX_FIFO_NUM_MASK GENMASK(25, 22)
/* Device ALL Endpoints Interrupt Register (DAINT) */ -#define DAINT_IN_EP_INT(x) (x << 0) -#define DAINT_OUT_EP_INT(x) (x << 16) +#define DAINT_IN_EP_INT(x) ((x) << 0) +#define DAINT_OUT_EP_INT(x) ((x) << 16)
/* User HW Config4 */ #define GHWCFG4_NUM_IN_EPS_MASK (0xf << 26) #define GHWCFG4_NUM_IN_EPS_SHIFT 26
/* OTG general core configuration register (OTG_GCCFG:0x38) for STM32MP1 */ -#define GGPIO_STM32_OTG_GCCFG_VBDEN BIT(21) -#define GGPIO_STM32_OTG_GCCFG_IDEN BIT(22) +#define GGPIO_STM32_OTG_GCCFG_VBDEN BIT(21) +#define GGPIO_STM32_OTG_GCCFG_IDEN BIT(22)
#endif diff --git a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c index 81ced055f02ac1b6775527099a21cd39326d93cc..ceefae1b1d1e42ed4ea73406e47621a2214c3b86 100644 --- a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c +++ b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c @@ -19,6 +19,7 @@
#include <cpu_func.h> #include <log.h> +#include <linux/bitfield.h> #include <linux/bug.h>
static u8 clear_feature_num; @@ -174,11 +175,11 @@ static int setdma_tx(struct dwc2_ep *ep, struct dwc2_request *req) ctrl = readl(®->device_regs.in_endp[ep_num].diepctl);
/* Write the FIFO number to be used for this endpoint */ - ctrl &= DIEPCTL_TX_FIFO_NUM_MASK; - ctrl |= DIEPCTL_TX_FIFO_NUM(ep->fifo_num); + ctrl &= ~DIEPCTL_TX_FIFO_NUM_MASK; + ctrl |= FIELD_PREP(DIEPCTL_TX_FIFO_NUM_MASK, ep->fifo_num);
/* Clear reserved (Next EP) bits */ - ctrl = (ctrl&~(EP_MASK<<DEPCTL_NEXT_EP_BIT)); + ctrl &= ~DEPCTL_NEXT_EP_MASK;
@@ -380,7 +381,7 @@ static void process_ep_in_intr(struct dwc2_udc *dev) debug_cond(DEBUG_IN_EP, "*** %s: EP In interrupt : DAINT = 0x%x\n", __func__, ep_intr);
- ep_intr &= DAINT_MASK; + ep_intr = FIELD_GET(DAINT_INEP_MASK, ep_intr);
while (ep_intr) { if (ep_intr & DAINT_IN_EP_INT(1)) { @@ -431,10 +432,10 @@ static void process_ep_out_intr(struct dwc2_udc *dev) "*** %s: EP OUT interrupt : DAINT = 0x%x\n", __func__, ep_intr);
- ep_intr = (ep_intr >> DAINT_OUT_BIT) & DAINT_MASK; + ep_intr = FIELD_GET(DAINT_OUTEP_MASK, ep_intr);
while (ep_intr) { - if (ep_intr & 0x1) { + if (ep_intr & BIT(EP0_CON)) { ep_intr_status = readl(®->device_regs.out_endp[ep_num].doepint); debug_cond(DEBUG_OUT_EP != 0, "\tEP%d-OUT : DOEPINT = 0x%x\n", @@ -1114,10 +1115,10 @@ static void dwc2_udc_ep_activate(struct dwc2_ep *ep) /* Read DEPCTLn register */ if (ep_is_in(ep)) { ep_ctrl = readl(®->device_regs.in_endp[ep_num].diepctl); - daintmsk = 1 << ep_num; + daintmsk = FIELD_PREP(DAINT_INEP_MASK, BIT(ep_num)); } else { ep_ctrl = readl(®->device_regs.out_endp[ep_num].doepctl); - daintmsk = (1 << ep_num) << DAINT_OUT_BIT; + daintmsk = FIELD_PREP(DAINT_OUTEP_MASK, BIT(ep_num)); }
debug("%s: EPCTRL%d = 0x%x, ep_is_in = %d\n", @@ -1127,9 +1128,9 @@ static void dwc2_udc_ep_activate(struct dwc2_ep *ep) * register. */ if (!(ep_ctrl & DEPCTL_USBACTEP)) { ep_ctrl = (ep_ctrl & ~DEPCTL_TYPE_MASK) | - (ep->bmAttributes << DEPCTL_TYPE_BIT); + FIELD_PREP(DEPCTL_TYPE_MASK, ep->bmAttributes); ep_ctrl = (ep_ctrl & ~DEPCTL_MPS_MASK) | - (ep->ep.maxpacket << DEPCTL_MPS_BIT); + FIELD_PREP(DEPCTL_MPS_MASK, ep->ep.maxpacket); ep_ctrl |= (DEPCTL_SETD0PID | DEPCTL_USBACTEP | DEPCTL_SNAK);
if (ep_is_in(ep)) { diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index 954650d856a4f2e95d74e1b5716c0ebe83fa9ba8..d4245b9cb71c91adc658668dcf897bcb10366b73 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -19,6 +19,7 @@ #include <asm/cache.h> #include <asm/io.h> #include <dm/device_compat.h> +#include <linux/bitfield.h> #include <linux/delay.h> #include <linux/usb/otg.h> #include <power/regulator.h> @@ -95,10 +96,8 @@ static void init_fslspclksel(struct dwc2_core_regs *regs)
#ifdef DWC2_ULPI_FS_LS uint32_t hwcfg2 = readl(®s->global_regs.ghwcfg2); - uint32_t hval = (ghwcfg2 & DWC2_HWCFG2_HS_PHY_TYPE_MASK) >> - DWC2_HWCFG2_HS_PHY_TYPE_OFFSET; - uint32_t fval = (ghwcfg2 & DWC2_HWCFG2_FS_PHY_TYPE_MASK) >> - DWC2_HWCFG2_FS_PHY_TYPE_OFFSET; + uint32_t hval = FIELD_GET(GHWCFG2_HS_PHY_TYPE_MASK, ghwcfg2); + uint32_t fval = FIELD_GET(GHWCFG2_FS_PHY_TYPE_MASK, ghwcfg2);
if (hval == 2 && fval == 1) phyclk = DWC2_HCFG_FSLSPCLKSEL_48_MHZ; /* Full speed PHY */ @@ -106,7 +105,7 @@ static void init_fslspclksel(struct dwc2_core_regs *regs)
clrsetbits_le32(®s->host_regs.hcfg, DWC2_HCFG_FSLSPCLKSEL_MASK, - phyclk << DWC2_HCFG_FSLSPCLKSEL_OFFSET); + FIELD_PREP(DWC2_HCFG_FSLSPCLKSEL_MASK, phyclk)); }
/* @@ -120,7 +119,7 @@ static void dwc_otg_flush_tx_fifo(struct udevice *dev, { int ret;
- writel(DWC2_GRSTCTL_TXFFLSH | (num << DWC2_GRSTCTL_TXFNUM_OFFSET), + writel(DWC2_GRSTCTL_TXFFLSH | FIELD_PREP(DWC2_GRSTCTL_TXFNUM_MASK, num), ®s->global_regs.grstctl); ret = wait_for_bit_le32(®s->global_regs.grstctl, DWC2_GRSTCTL_TXFFLSH, false, 1000, false); @@ -266,18 +265,14 @@ static void dwc_otg_core_host_init(struct udevice *dev, writel(DWC2_HOST_RX_FIFO_SIZE, ®s->global_regs.grxfsiz);
/* Non-periodic Tx FIFO */ - nptxfifosize |= DWC2_HOST_NPERIO_TX_FIFO_SIZE << - DWC2_FIFOSIZE_DEPTH_OFFSET; - nptxfifosize |= DWC2_HOST_RX_FIFO_SIZE << - DWC2_FIFOSIZE_STARTADDR_OFFSET; + nptxfifosize |= FIELD_PREP(DWC2_FIFOSIZE_DEPTH_MASK, DWC2_HOST_NPERIO_TX_FIFO_SIZE); + nptxfifosize |= FIELD_PREP(DWC2_FIFOSIZE_STARTADDR_MASK, DWC2_HOST_RX_FIFO_SIZE); writel(nptxfifosize, ®s->global_regs.gnptxfsiz);
/* Periodic Tx FIFO */ - ptxfifosize |= DWC2_HOST_PERIO_TX_FIFO_SIZE << - DWC2_FIFOSIZE_DEPTH_OFFSET; - ptxfifosize |= (DWC2_HOST_RX_FIFO_SIZE + - DWC2_HOST_NPERIO_TX_FIFO_SIZE) << - DWC2_FIFOSIZE_STARTADDR_OFFSET; + ptxfifosize |= FIELD_PREP(DWC2_FIFOSIZE_DEPTH_MASK, DWC2_HOST_PERIO_TX_FIFO_SIZE); + ptxfifosize |= FIELD_PREP(DWC2_FIFOSIZE_STARTADDR_MASK, DWC2_HOST_RX_FIFO_SIZE + + DWC2_HOST_NPERIO_TX_FIFO_SIZE); writel(ptxfifosize, ®s->global_regs.hptxfsiz); } #endif @@ -290,10 +285,8 @@ static void dwc_otg_core_host_init(struct udevice *dev, dwc_otg_flush_rx_fifo(dev, regs);
/* Flush out any leftover queued requests. */ - num_channels = readl(®s->global_regs.ghwcfg2); - num_channels &= DWC2_HWCFG2_NUM_HOST_CHAN_MASK; - num_channels >>= DWC2_HWCFG2_NUM_HOST_CHAN_OFFSET; - num_channels += 1; + num_channels = FIELD_GET(DWC2_HWCFG2_NUM_HOST_CHAN_MASK, + readl(®s->global_regs.ghwcfg2)) + 1;
for (i = 0; i < num_channels; i++) clrsetbits_le32(®s->host_regs.hc[i].hcchar, @@ -390,7 +383,7 @@ static void dwc_otg_core_init(struct udevice *dev) /* Program GI2CCTL.I2CEn */ clrsetbits_le32(®s->global_regs.gi2cctl, DWC2_GI2CCTL_I2CEN | DWC2_GI2CCTL_I2CDEVADDR_MASK, - 1 << DWC2_GI2CCTL_I2CDEVADDR_OFFSET); + FIELD_PREP(DWC2_GI2CCTL_I2CDEVADDR_MASK, 1)); setbits_le32(®s->global_regs.gi2cctl, DWC2_GI2CCTL_I2CEN); #endif
@@ -429,10 +422,8 @@ static void dwc_otg_core_init(struct udevice *dev) usbcfg &= ~(DWC2_GUSBCFG_ULPI_FSLS | DWC2_GUSBCFG_ULPI_CLK_SUS_M); #ifdef DWC2_ULPI_FS_LS uint32_t hwcfg2 = readl(®s->global_regs.ghwcfg2); - uint32_t hval = (ghwcfg2 & DWC2_HWCFG2_HS_PHY_TYPE_MASK) >> - DWC2_HWCFG2_HS_PHY_TYPE_OFFSET; - uint32_t fval = (ghwcfg2 & DWC2_HWCFG2_FS_PHY_TYPE_MASK) >> - DWC2_HWCFG2_FS_PHY_TYPE_OFFSET; + uint32_t hval = FIELD_GET(DWC2_HWCFG2_HS_PHY_TYPE_MASK, ghwcfg2); + uint32_t fval = FIELD_GET(DWC2_HWCFG2_FS_PHY_TYPE_MASK, ghwcfg2); if (hval == 2 && fval == 1) { usbcfg |= DWC2_GUSBCFG_ULPI_FSLS; usbcfg |= DWC2_GUSBCFG_ULPI_CLK_SUS_M; @@ -444,12 +435,11 @@ static void dwc_otg_core_init(struct udevice *dev) writel(usbcfg, ®s->global_regs.gusbcfg);
/* Program the GAHBCFG Register. */ - switch (readl(®s->global_regs.ghwcfg2) & DWC2_HWCFG2_ARCHITECTURE_MASK) { + switch (FIELD_GET(DWC2_HWCFG2_ARCHITECTURE_MASK, readl(®s->global_regs.ghwcfg2))) { case DWC2_HWCFG2_ARCHITECTURE_SLAVE_ONLY: break; case DWC2_HWCFG2_ARCHITECTURE_EXT_DMA: - ahbcfg |= (LOG2(brst_sz >> 1) << DWC2_GAHBCFG_HBURSTLEN_OFFSET) & - DWC2_GAHBCFG_HBURSTLEN_MASK; + ahbcfg |= FIELD_PREP(DWC2_GAHBCFG_HBURSTLEN_MASK, LOG2(brst_sz >> 1));
#ifdef DWC2_DMA_ENABLE ahbcfg |= DWC2_GAHBCFG_DMAENABLE; @@ -492,11 +482,11 @@ static void dwc_otg_hc_init(struct dwc2_core_regs *regs, uint8_t hc_num, uint8_t ep_is_in, uint8_t ep_type, uint16_t max_packet) { struct dwc2_hc_regs *hc_regs = ®s->host_regs.hc[hc_num]; - uint32_t hcchar = (dev_addr << DWC2_HCCHAR_DEVADDR_OFFSET) | - (ep_num << DWC2_HCCHAR_EPNUM_OFFSET) | - (ep_is_in << DWC2_HCCHAR_EPDIR_OFFSET) | - (ep_type << DWC2_HCCHAR_EPTYPE_OFFSET) | - (max_packet << DWC2_HCCHAR_MPS_OFFSET); + u32 hcchar = FIELD_PREP(DWC2_HCCHAR_DEVADDR_MASK, dev_addr) | + FIELD_PREP(DWC2_HCCHAR_EPNUM_MASK, ep_num) | + FIELD_PREP(DWC2_HCCHAR_EPDIR, ep_is_in) | + FIELD_PREP(DWC2_HCCHAR_EPTYPE_MASK, ep_type) | + FIELD_PREP(DWC2_HCCHAR_MPS_MASK, max_packet);
if (dev->speed == USB_SPEED_LOW) hcchar |= DWC2_HCCHAR_LSPDDEV; @@ -517,8 +507,8 @@ static void dwc_otg_hc_init_split(struct dwc2_hc_regs *hc_regs, uint32_t hcsplt = 0;
hcsplt = DWC2_HCSPLT_SPLTENA; - hcsplt |= hub_devnum << DWC2_HCSPLT_HUBADDR_OFFSET; - hcsplt |= hub_port << DWC2_HCSPLT_PRTADDR_OFFSET; + hcsplt |= FIELD_PREP(DWC2_HCSPLT_HUBADDR_MASK, hub_devnum); + hcsplt |= FIELD_PREP(DWC2_HCSPLT_PRTADDR_MASK, hub_port);
/* Program the HCSPLIT register for SPLITs */ writel(hcsplt, &hc_regs->hcsplt); @@ -567,11 +557,14 @@ static int dwc_otg_submit_rh_msg_in_status(struct dwc2_core_regs *regs, if (hprt0 & DWC2_HPRT0_PRTPWR) port_status |= USB_PORT_STAT_POWER;
- if ((hprt0 & DWC2_HPRT0_PRTSPD_MASK) == DWC2_HPRT0_PRTSPD_LOW) + switch (FIELD_GET(DWC2_HPRT0_PRTSPD_MASK, hprt0)) { + case DWC2_HPRT0_PRTSPD_LOW: port_status |= USB_PORT_STAT_LOW_SPEED; - else if ((hprt0 & DWC2_HPRT0_PRTSPD_MASK) == - DWC2_HPRT0_PRTSPD_HIGH) + break; + case DWC2_HPRT0_PRTSPD_HIGH: port_status |= USB_PORT_STAT_HIGH_SPEED; + break; + }
if (hprt0 & DWC2_HPRT0_PRTENCHNG) port_change |= USB_PORT_STAT_C_ENABLE; @@ -822,9 +815,8 @@ int wait_for_chhltd(struct dwc2_hc_regs *hc_regs, uint32_t *sub, u8 *toggle)
hcint = readl(&hc_regs->hcint); hctsiz = readl(&hc_regs->hctsiz); - *sub = (hctsiz & DWC2_HCTSIZ_XFERSIZE_MASK) >> - DWC2_HCTSIZ_XFERSIZE_OFFSET; - *toggle = (hctsiz & DWC2_HCTSIZ_PID_MASK) >> DWC2_HCTSIZ_PID_OFFSET; + *sub = FIELD_GET(DWC2_HCTSIZ_XFERSIZE_MASK, hctsiz); + *toggle = FIELD_GET(DWC2_HCTSIZ_PID_MASK, hctsiz);
debug("%s: HCINT=%08x sub=%u toggle=%d\n", __func__, hcint, *sub, *toggle); @@ -856,9 +848,9 @@ static int transfer_chunk(struct dwc2_hc_regs *hc_regs, void *aligned_buffer, debug("%s: chunk: pid %d xfer_len %u pkts %u\n", __func__, *pid, xfer_len, num_packets);
- writel((xfer_len << DWC2_HCTSIZ_XFERSIZE_OFFSET) | - (num_packets << DWC2_HCTSIZ_PKTCNT_OFFSET) | - (*pid << DWC2_HCTSIZ_PID_OFFSET), + writel(FIELD_PREP(DWC2_HCTSIZ_XFERSIZE_MASK, xfer_len) | + FIELD_PREP(DWC2_HCTSIZ_PKTCNT_MASK, num_packets) | + FIELD_PREP(DWC2_HCTSIZ_PID_MASK, *pid), &hc_regs->hctsiz);
if (xfer_len) { @@ -885,8 +877,8 @@ static int transfer_chunk(struct dwc2_hc_regs *hc_regs, void *aligned_buffer, clrsetbits_le32(&hc_regs->hcchar, DWC2_HCCHAR_MULTICNT_MASK | DWC2_HCCHAR_CHEN | DWC2_HCCHAR_CHDIS | DWC2_HCCHAR_ODDFRM, - (1 << DWC2_HCCHAR_MULTICNT_OFFSET) | - (odd_frame << DWC2_HCCHAR_ODDFRM_OFFSET) | + FIELD_PREP(DWC2_HCCHAR_MULTICNT_MASK, 1) | + FIELD_PREP(DWC2_HCCHAR_ODDFRM, odd_frame) | DWC2_HCCHAR_CHEN);
ret = wait_for_chhltd(hc_regs, &sub, pid); @@ -950,8 +942,7 @@ int chunk_msg(struct dwc2_priv *priv, struct usb_device *dev, uint8_t hub_port; uint32_t hprt0 = readl(®s->host_regs.hprt0);
- if ((hprt0 & DWC2_HPRT0_PRTSPD_MASK) == - DWC2_HPRT0_PRTSPD_HIGH) { + if (FIELD_GET(DWC2_HPRT0_PRTSPD_MASK, hprt0) == DWC2_HPRT0_PRTSPD_HIGH) { usb_find_usb2_hub_address_port(dev, &hub_addr, &hub_port); dwc_otg_hc_init_split(hc_regs, hub_addr, hub_port); @@ -995,17 +986,17 @@ int chunk_msg(struct dwc2_priv *priv, struct usb_device *dev, stop_transfer = 0; if (hcint & DWC2_HCINT_NYET) { ret = 0; - int frame_num = DWC2_HFNUM_MAX_FRNUM & - readl(&host_regs->hfnum); - if (((frame_num - ssplit_frame_num) & - DWC2_HFNUM_MAX_FRNUM) > 4) + int frame_num = FIELD_GET(DWC2_HFNUM_FRNUM_MASK, + readl(&host_regs->hfnum)); + + if (((frame_num - ssplit_frame_num) & DWC2_HFNUM_FRNUM_MASK) > 4) ret = -EAGAIN; } else complete_split = 0; } else if (do_split) { if (hcint & DWC2_HCINT_ACK) { - ssplit_frame_num = DWC2_HFNUM_MAX_FRNUM & - readl(&host_regs->hfnum); + ssplit_frame_num = FIELD_GET(DWC2_HFNUM_FRNUM_MASK, + readl(&host_regs->hfnum)); ret = 0; complete_split = 1; } @@ -1183,8 +1174,8 @@ static int dwc2_init_common(struct udevice *dev, struct dwc2_priv *priv) dev_info(dev, "Core Release: %x.%03x\n", snpsid >> 12 & 0xf, snpsid & 0xfff);
- if ((snpsid & DWC2_SNPSID_DEVID_MASK) != DWC2_SNPSID_DEVID_VER_2xx && - (snpsid & DWC2_SNPSID_DEVID_MASK) != DWC2_SNPSID_DEVID_VER_3xx) { + if (FIELD_GET(DWC2_SNPSID_DEVID_MASK, snpsid) != DWC2_SNPSID_DEVID_VER_2xx && + FIELD_GET(DWC2_SNPSID_DEVID_MASK, snpsid) != DWC2_SNPSID_DEVID_VER_3xx) { dev_info(dev, "SNPSID invalid (not DWC2 OTG device): %08x\n", snpsid); return -ENODEV; diff --git a/drivers/usb/host/dwc2.h b/drivers/usb/host/dwc2.h index 61b544462edfd6778ddf2ddf2dcf6db3f02a3754..6bd98b481f2449e32f5ccf3dc5baca814a2f4a16 100644 --- a/drivers/usb/host/dwc2.h +++ b/drivers/usb/host/dwc2.h @@ -6,683 +6,358 @@ #ifndef __DWC2_H__ #define __DWC2_H__
-#define DWC2_GOTGCTL_SESREQSCS (1 << 0) -#define DWC2_GOTGCTL_SESREQSCS_OFFSET 0 -#define DWC2_GOTGCTL_SESREQ (1 << 1) -#define DWC2_GOTGCTL_SESREQ_OFFSET 1 -#define DWC2_GOTGCTL_HSTNEGSCS (1 << 8) -#define DWC2_GOTGCTL_HSTNEGSCS_OFFSET 8 -#define DWC2_GOTGCTL_HNPREQ (1 << 9) -#define DWC2_GOTGCTL_HNPREQ_OFFSET 9 -#define DWC2_GOTGCTL_HSTSETHNPEN (1 << 10) -#define DWC2_GOTGCTL_HSTSETHNPEN_OFFSET 10 -#define DWC2_GOTGCTL_DEVHNPEN (1 << 11) -#define DWC2_GOTGCTL_DEVHNPEN_OFFSET 11 -#define DWC2_GOTGCTL_CONIDSTS (1 << 16) -#define DWC2_GOTGCTL_CONIDSTS_OFFSET 16 -#define DWC2_GOTGCTL_DBNCTIME (1 << 17) -#define DWC2_GOTGCTL_DBNCTIME_OFFSET 17 -#define DWC2_GOTGCTL_ASESVLD (1 << 18) -#define DWC2_GOTGCTL_ASESVLD_OFFSET 18 -#define DWC2_GOTGCTL_BSESVLD (1 << 19) -#define DWC2_GOTGCTL_BSESVLD_OFFSET 19 -#define DWC2_GOTGCTL_OTGVER (1 << 20) -#define DWC2_GOTGCTL_OTGVER_OFFSET 20 -#define DWC2_GOTGINT_SESENDDET (1 << 2) -#define DWC2_GOTGINT_SESENDDET_OFFSET 2 -#define DWC2_GOTGINT_SESREQSUCSTSCHNG (1 << 8) -#define DWC2_GOTGINT_SESREQSUCSTSCHNG_OFFSET 8 -#define DWC2_GOTGINT_HSTNEGSUCSTSCHNG (1 << 9) -#define DWC2_GOTGINT_HSTNEGSUCSTSCHNG_OFFSET 9 -#define DWC2_GOTGINT_RESERVER10_16_MASK (0x7F << 10) -#define DWC2_GOTGINT_RESERVER10_16_OFFSET 10 -#define DWC2_GOTGINT_HSTNEGDET (1 << 17) -#define DWC2_GOTGINT_HSTNEGDET_OFFSET 17 -#define DWC2_GOTGINT_ADEVTOUTCHNG (1 << 18) -#define DWC2_GOTGINT_ADEVTOUTCHNG_OFFSET 18 -#define DWC2_GOTGINT_DEBDONE (1 << 19) -#define DWC2_GOTGINT_DEBDONE_OFFSET 19 -#define DWC2_GAHBCFG_GLBLINTRMSK (1 << 0) -#define DWC2_GAHBCFG_GLBLINTRMSK_OFFSET 0 +#include <linux/bitops.h> + +#define DWC2_GOTGCTL_SESREQSCS BIT(0) +#define DWC2_GOTGCTL_SESREQ BIT(1) +#define DWC2_GOTGCTL_HSTNEGSCS BIT(8) +#define DWC2_GOTGCTL_HNPREQ BIT(9) +#define DWC2_GOTGCTL_HSTSETHNPEN BIT(10) +#define DWC2_GOTGCTL_DEVHNPEN BIT(11) +#define DWC2_GOTGCTL_CONIDSTS BIT(16) +#define DWC2_GOTGCTL_DBNCTIME BIT(17) +#define DWC2_GOTGCTL_ASESVLD BIT(18) +#define DWC2_GOTGCTL_BSESVLD BIT(19) +#define DWC2_GOTGCTL_OTGVER BIT(20) +#define DWC2_GOTGINT_SESENDDET BIT(2) +#define DWC2_GOTGINT_SESREQSUCSTSCHNG BIT(8) +#define DWC2_GOTGINT_HSTNEGSUCSTSCHNG BIT(9) +#define DWC2_GOTGINT_RESERVER10_16_MASK GENMASK(16, 10) +#define DWC2_GOTGINT_HSTNEGDET BIT(17) +#define DWC2_GOTGINT_ADEVTOUTCHNG BIT(18) +#define DWC2_GOTGINT_DEBDONE BIT(19) +#define DWC2_GAHBCFG_GLBLINTRMSK BIT(0) #define DWC2_GAHBCFG_HBURSTLEN_SINGLE (0 << 1) #define DWC2_GAHBCFG_HBURSTLEN_INCR (1 << 1) #define DWC2_GAHBCFG_HBURSTLEN_INCR4 (3 << 1) #define DWC2_GAHBCFG_HBURSTLEN_INCR8 (5 << 1) #define DWC2_GAHBCFG_HBURSTLEN_INCR16 (7 << 1) -#define DWC2_GAHBCFG_HBURSTLEN_MASK (0xF << 1) -#define DWC2_GAHBCFG_HBURSTLEN_OFFSET 1 -#define DWC2_GAHBCFG_DMAENABLE (1 << 5) -#define DWC2_GAHBCFG_DMAENABLE_OFFSET 5 -#define DWC2_GAHBCFG_NPTXFEMPLVL_TXFEMPLVL (1 << 7) -#define DWC2_GAHBCFG_NPTXFEMPLVL_TXFEMPLVL_OFFSET 7 -#define DWC2_GAHBCFG_PTXFEMPLVL (1 << 8) -#define DWC2_GAHBCFG_PTXFEMPLVL_OFFSET 8 -#define DWC2_GUSBCFG_TOUTCAL_MASK (0x7 << 0) -#define DWC2_GUSBCFG_TOUTCAL_OFFSET 0 -#define DWC2_GUSBCFG_PHYIF (1 << 3) -#define DWC2_GUSBCFG_PHYIF_OFFSET 3 -#define DWC2_GUSBCFG_ULPI_UTMI_SEL (1 << 4) -#define DWC2_GUSBCFG_ULPI_UTMI_SEL_OFFSET 4 -#define DWC2_GUSBCFG_FSINTF (1 << 5) -#define DWC2_GUSBCFG_FSINTF_OFFSET 5 -#define DWC2_GUSBCFG_PHYSEL (1 << 6) -#define DWC2_GUSBCFG_PHYSEL_OFFSET 6 -#define DWC2_GUSBCFG_DDRSEL (1 << 7) -#define DWC2_GUSBCFG_DDRSEL_OFFSET 7 -#define DWC2_GUSBCFG_SRPCAP (1 << 8) -#define DWC2_GUSBCFG_SRPCAP_OFFSET 8 -#define DWC2_GUSBCFG_HNPCAP (1 << 9) -#define DWC2_GUSBCFG_HNPCAP_OFFSET 9 -#define DWC2_GUSBCFG_USBTRDTIM_MASK (0xF << 10) -#define DWC2_GUSBCFG_USBTRDTIM_OFFSET 10 -#define DWC2_GUSBCFG_NPTXFRWNDEN (1 << 14) -#define DWC2_GUSBCFG_NPTXFRWNDEN_OFFSET 14 -#define DWC2_GUSBCFG_PHYLPWRCLKSEL (1 << 15) -#define DWC2_GUSBCFG_PHYLPWRCLKSEL_OFFSET 15 -#define DWC2_GUSBCFG_OTGUTMIFSSEL (1 << 16) -#define DWC2_GUSBCFG_OTGUTMIFSSEL_OFFSET 16 -#define DWC2_GUSBCFG_ULPI_FSLS (1 << 17) -#define DWC2_GUSBCFG_ULPI_FSLS_OFFSET 17 -#define DWC2_GUSBCFG_ULPI_AUTO_RES (1 << 18) -#define DWC2_GUSBCFG_ULPI_AUTO_RES_OFFSET 18 -#define DWC2_GUSBCFG_ULPI_CLK_SUS_M (1 << 19) -#define DWC2_GUSBCFG_ULPI_CLK_SUS_M_OFFSET 19 -#define DWC2_GUSBCFG_ULPI_EXT_VBUS_DRV (1 << 20) -#define DWC2_GUSBCFG_ULPI_EXT_VBUS_DRV_OFFSET 20 -#define DWC2_GUSBCFG_ULPI_INT_VBUS_INDICATOR (1 << 21) -#define DWC2_GUSBCFG_ULPI_INT_VBUS_INDICATOR_OFFSET 21 -#define DWC2_GUSBCFG_TERM_SEL_DL_PULSE (1 << 22) -#define DWC2_GUSBCFG_TERM_SEL_DL_PULSE_OFFSET 22 -#define DWC2_GUSBCFG_INDICATOR_PASSTHROUGH (1 << 24) -#define DWC2_GUSBCFG_INDICATOR_PASSTHROUGH_OFFSET 24 -#define DWC2_GUSBCFG_IC_USB_CAP (1 << 26) -#define DWC2_GUSBCFG_IC_USB_CAP_OFFSET 26 -#define DWC2_GUSBCFG_IC_TRAFFIC_PULL_REMOVE (1 << 27) -#define DWC2_GUSBCFG_IC_TRAFFIC_PULL_REMOVE_OFFSET 27 -#define DWC2_GUSBCFG_TX_END_DELAY (1 << 28) -#define DWC2_GUSBCFG_TX_END_DELAY_OFFSET 28 -#define DWC2_GUSBCFG_FORCEHOSTMODE (1 << 29) -#define DWC2_GUSBCFG_FORCEHOSTMODE_OFFSET 29 -#define DWC2_GUSBCFG_FORCEDEVMODE (1 << 30) -#define DWC2_GUSBCFG_FORCEDEVMODE_OFFSET 30 -#define DWC2_GLPMCTL_LPM_CAP_EN (1 << 0) -#define DWC2_GLPMCTL_LPM_CAP_EN_OFFSET 0 -#define DWC2_GLPMCTL_APPL_RESP (1 << 1) -#define DWC2_GLPMCTL_APPL_RESP_OFFSET 1 -#define DWC2_GLPMCTL_HIRD_MASK (0xF << 2) -#define DWC2_GLPMCTL_HIRD_OFFSET 2 -#define DWC2_GLPMCTL_REM_WKUP_EN (1 << 6) -#define DWC2_GLPMCTL_REM_WKUP_EN_OFFSET 6 -#define DWC2_GLPMCTL_EN_UTMI_SLEEP (1 << 7) -#define DWC2_GLPMCTL_EN_UTMI_SLEEP_OFFSET 7 -#define DWC2_GLPMCTL_HIRD_THRES_MASK (0x1F << 8) -#define DWC2_GLPMCTL_HIRD_THRES_OFFSET 8 -#define DWC2_GLPMCTL_LPM_RESP_MASK (0x3 << 13) -#define DWC2_GLPMCTL_LPM_RESP_OFFSET 13 -#define DWC2_GLPMCTL_PRT_SLEEP_STS (1 << 15) -#define DWC2_GLPMCTL_PRT_SLEEP_STS_OFFSET 15 -#define DWC2_GLPMCTL_SLEEP_STATE_RESUMEOK (1 << 16) -#define DWC2_GLPMCTL_SLEEP_STATE_RESUMEOK_OFFSET 16 -#define DWC2_GLPMCTL_LPM_CHAN_INDEX_MASK (0xF << 17) -#define DWC2_GLPMCTL_LPM_CHAN_INDEX_OFFSET 17 -#define DWC2_GLPMCTL_RETRY_COUNT_MASK (0x7 << 21) -#define DWC2_GLPMCTL_RETRY_COUNT_OFFSET 21 -#define DWC2_GLPMCTL_SEND_LPM (1 << 24) -#define DWC2_GLPMCTL_SEND_LPM_OFFSET 24 -#define DWC2_GLPMCTL_RETRY_COUNT_STS_MASK (0x7 << 25) -#define DWC2_GLPMCTL_RETRY_COUNT_STS_OFFSET 25 -#define DWC2_GLPMCTL_HSIC_CONNECT (1 << 30) -#define DWC2_GLPMCTL_HSIC_CONNECT_OFFSET 30 -#define DWC2_GLPMCTL_INV_SEL_HSIC (1 << 31) -#define DWC2_GLPMCTL_INV_SEL_HSIC_OFFSET 31 -#define DWC2_GRSTCTL_CSFTRST (1 << 0) -#define DWC2_GRSTCTL_CSFTRST_OFFSET 0 -#define DWC2_GRSTCTL_HSFTRST (1 << 1) -#define DWC2_GRSTCTL_HSFTRST_OFFSET 1 -#define DWC2_GRSTCTL_HSTFRM (1 << 2) -#define DWC2_GRSTCTL_HSTFRM_OFFSET 2 -#define DWC2_GRSTCTL_INTKNQFLSH (1 << 3) -#define DWC2_GRSTCTL_INTKNQFLSH_OFFSET 3 -#define DWC2_GRSTCTL_RXFFLSH (1 << 4) -#define DWC2_GRSTCTL_RXFFLSH_OFFSET 4 -#define DWC2_GRSTCTL_TXFFLSH (1 << 5) -#define DWC2_GRSTCTL_TXFFLSH_OFFSET 5 -#define DWC2_GRSTCTL_TXFNUM_MASK (0x1F << 6) -#define DWC2_GRSTCTL_TXFNUM_OFFSET 6 -#define DWC2_GRSTCTL_DMAREQ (1 << 30) -#define DWC2_GRSTCTL_DMAREQ_OFFSET 30 -#define DWC2_GRSTCTL_AHBIDLE (1 << 31) -#define DWC2_GRSTCTL_AHBIDLE_OFFSET 31 -#define DWC2_GINTMSK_MODEMISMATCH (1 << 1) -#define DWC2_GINTMSK_MODEMISMATCH_OFFSET 1 -#define DWC2_GINTMSK_OTGINTR (1 << 2) -#define DWC2_GINTMSK_OTGINTR_OFFSET 2 -#define DWC2_GINTMSK_SOFINTR (1 << 3) -#define DWC2_GINTMSK_SOFINTR_OFFSET 3 -#define DWC2_GINTMSK_RXSTSQLVL (1 << 4) -#define DWC2_GINTMSK_RXSTSQLVL_OFFSET 4 -#define DWC2_GINTMSK_NPTXFEMPTY (1 << 5) -#define DWC2_GINTMSK_NPTXFEMPTY_OFFSET 5 -#define DWC2_GINTMSK_GINNAKEFF (1 << 6) -#define DWC2_GINTMSK_GINNAKEFF_OFFSET 6 -#define DWC2_GINTMSK_GOUTNAKEFF (1 << 7) -#define DWC2_GINTMSK_GOUTNAKEFF_OFFSET 7 -#define DWC2_GINTMSK_I2CINTR (1 << 9) -#define DWC2_GINTMSK_I2CINTR_OFFSET 9 -#define DWC2_GINTMSK_ERLYSUSPEND (1 << 10) -#define DWC2_GINTMSK_ERLYSUSPEND_OFFSET 10 -#define DWC2_GINTMSK_USBSUSPEND (1 << 11) -#define DWC2_GINTMSK_USBSUSPEND_OFFSET 11 -#define DWC2_GINTMSK_USBRESET (1 << 12) -#define DWC2_GINTMSK_USBRESET_OFFSET 12 -#define DWC2_GINTMSK_ENUMDONE (1 << 13) -#define DWC2_GINTMSK_ENUMDONE_OFFSET 13 -#define DWC2_GINTMSK_ISOOUTDROP (1 << 14) -#define DWC2_GINTMSK_ISOOUTDROP_OFFSET 14 -#define DWC2_GINTMSK_EOPFRAME (1 << 15) -#define DWC2_GINTMSK_EOPFRAME_OFFSET 15 -#define DWC2_GINTMSK_EPMISMATCH (1 << 17) -#define DWC2_GINTMSK_EPMISMATCH_OFFSET 17 -#define DWC2_GINTMSK_INEPINTR (1 << 18) -#define DWC2_GINTMSK_INEPINTR_OFFSET 18 -#define DWC2_GINTMSK_OUTEPINTR (1 << 19) -#define DWC2_GINTMSK_OUTEPINTR_OFFSET 19 -#define DWC2_GINTMSK_INCOMPLISOIN (1 << 20) -#define DWC2_GINTMSK_INCOMPLISOIN_OFFSET 20 -#define DWC2_GINTMSK_INCOMPLISOOUT (1 << 21) -#define DWC2_GINTMSK_INCOMPLISOOUT_OFFSET 21 -#define DWC2_GINTMSK_PORTINTR (1 << 24) -#define DWC2_GINTMSK_PORTINTR_OFFSET 24 -#define DWC2_GINTMSK_HCINTR (1 << 25) -#define DWC2_GINTMSK_HCINTR_OFFSET 25 -#define DWC2_GINTMSK_PTXFEMPTY (1 << 26) -#define DWC2_GINTMSK_PTXFEMPTY_OFFSET 26 -#define DWC2_GINTMSK_LPMTRANRCVD (1 << 27) -#define DWC2_GINTMSK_LPMTRANRCVD_OFFSET 27 -#define DWC2_GINTMSK_CONIDSTSCHNG (1 << 28) -#define DWC2_GINTMSK_CONIDSTSCHNG_OFFSET 28 -#define DWC2_GINTMSK_DISCONNECT (1 << 29) -#define DWC2_GINTMSK_DISCONNECT_OFFSET 29 -#define DWC2_GINTMSK_SESSREQINTR (1 << 30) -#define DWC2_GINTMSK_SESSREQINTR_OFFSET 30 -#define DWC2_GINTMSK_WKUPINTR (1 << 31) -#define DWC2_GINTMSK_WKUPINTR_OFFSET 31 -#define DWC2_GINTSTS_CURMODE_DEVICE (0 << 0) -#define DWC2_GINTSTS_CURMODE_HOST (1 << 0) -#define DWC2_GINTSTS_CURMODE (1 << 0) -#define DWC2_GINTSTS_CURMODE_OFFSET 0 -#define DWC2_GINTSTS_MODEMISMATCH (1 << 1) -#define DWC2_GINTSTS_MODEMISMATCH_OFFSET 1 -#define DWC2_GINTSTS_OTGINTR (1 << 2) -#define DWC2_GINTSTS_OTGINTR_OFFSET 2 -#define DWC2_GINTSTS_SOFINTR (1 << 3) -#define DWC2_GINTSTS_SOFINTR_OFFSET 3 -#define DWC2_GINTSTS_RXSTSQLVL (1 << 4) -#define DWC2_GINTSTS_RXSTSQLVL_OFFSET 4 -#define DWC2_GINTSTS_NPTXFEMPTY (1 << 5) -#define DWC2_GINTSTS_NPTXFEMPTY_OFFSET 5 -#define DWC2_GINTSTS_GINNAKEFF (1 << 6) -#define DWC2_GINTSTS_GINNAKEFF_OFFSET 6 -#define DWC2_GINTSTS_GOUTNAKEFF (1 << 7) -#define DWC2_GINTSTS_GOUTNAKEFF_OFFSET 7 -#define DWC2_GINTSTS_I2CINTR (1 << 9) -#define DWC2_GINTSTS_I2CINTR_OFFSET 9 -#define DWC2_GINTSTS_ERLYSUSPEND (1 << 10) -#define DWC2_GINTSTS_ERLYSUSPEND_OFFSET 10 -#define DWC2_GINTSTS_USBSUSPEND (1 << 11) -#define DWC2_GINTSTS_USBSUSPEND_OFFSET 11 -#define DWC2_GINTSTS_USBRESET (1 << 12) -#define DWC2_GINTSTS_USBRESET_OFFSET 12 -#define DWC2_GINTSTS_ENUMDONE (1 << 13) -#define DWC2_GINTSTS_ENUMDONE_OFFSET 13 -#define DWC2_GINTSTS_ISOOUTDROP (1 << 14) -#define DWC2_GINTSTS_ISOOUTDROP_OFFSET 14 -#define DWC2_GINTSTS_EOPFRAME (1 << 15) -#define DWC2_GINTSTS_EOPFRAME_OFFSET 15 -#define DWC2_GINTSTS_INTOKENRX (1 << 16) -#define DWC2_GINTSTS_INTOKENRX_OFFSET 16 -#define DWC2_GINTSTS_EPMISMATCH (1 << 17) -#define DWC2_GINTSTS_EPMISMATCH_OFFSET 17 -#define DWC2_GINTSTS_INEPINT (1 << 18) -#define DWC2_GINTSTS_INEPINT_OFFSET 18 -#define DWC2_GINTSTS_OUTEPINTR (1 << 19) -#define DWC2_GINTSTS_OUTEPINTR_OFFSET 19 -#define DWC2_GINTSTS_INCOMPLISOIN (1 << 20) -#define DWC2_GINTSTS_INCOMPLISOIN_OFFSET 20 -#define DWC2_GINTSTS_INCOMPLISOOUT (1 << 21) -#define DWC2_GINTSTS_INCOMPLISOOUT_OFFSET 21 -#define DWC2_GINTSTS_PORTINTR (1 << 24) -#define DWC2_GINTSTS_PORTINTR_OFFSET 24 -#define DWC2_GINTSTS_HCINTR (1 << 25) -#define DWC2_GINTSTS_HCINTR_OFFSET 25 -#define DWC2_GINTSTS_PTXFEMPTY (1 << 26) -#define DWC2_GINTSTS_PTXFEMPTY_OFFSET 26 -#define DWC2_GINTSTS_LPMTRANRCVD (1 << 27) -#define DWC2_GINTSTS_LPMTRANRCVD_OFFSET 27 -#define DWC2_GINTSTS_CONIDSTSCHNG (1 << 28) -#define DWC2_GINTSTS_CONIDSTSCHNG_OFFSET 28 -#define DWC2_GINTSTS_DISCONNECT (1 << 29) -#define DWC2_GINTSTS_DISCONNECT_OFFSET 29 -#define DWC2_GINTSTS_SESSREQINTR (1 << 30) -#define DWC2_GINTSTS_SESSREQINTR_OFFSET 30 -#define DWC2_GINTSTS_WKUPINTR (1 << 31) -#define DWC2_GINTSTS_WKUPINTR_OFFSET 31 -#define DWC2_GRXSTS_EPNUM_MASK (0xF << 0) -#define DWC2_GRXSTS_EPNUM_OFFSET 0 -#define DWC2_GRXSTS_BCNT_MASK (0x7FF << 4) -#define DWC2_GRXSTS_BCNT_OFFSET 4 -#define DWC2_GRXSTS_DPID_MASK (0x3 << 15) -#define DWC2_GRXSTS_DPID_OFFSET 15 -#define DWC2_GRXSTS_PKTSTS_MASK (0xF << 17) -#define DWC2_GRXSTS_PKTSTS_OFFSET 17 -#define DWC2_GRXSTS_FN_MASK (0xF << 21) -#define DWC2_GRXSTS_FN_OFFSET 21 -#define DWC2_FIFOSIZE_STARTADDR_MASK (0xFFFF << 0) -#define DWC2_FIFOSIZE_STARTADDR_OFFSET 0 -#define DWC2_FIFOSIZE_DEPTH_MASK (0xFFFF << 16) -#define DWC2_FIFOSIZE_DEPTH_OFFSET 16 -#define DWC2_GNPTXSTS_NPTXFSPCAVAIL_MASK (0xFFFF << 0) -#define DWC2_GNPTXSTS_NPTXFSPCAVAIL_OFFSET 0 -#define DWC2_GNPTXSTS_NPTXQSPCAVAIL_MASK (0xFF << 16) -#define DWC2_GNPTXSTS_NPTXQSPCAVAIL_OFFSET 16 -#define DWC2_GNPTXSTS_NPTXQTOP_TERMINATE (1 << 24) -#define DWC2_GNPTXSTS_NPTXQTOP_TERMINATE_OFFSET 24 -#define DWC2_GNPTXSTS_NPTXQTOP_TOKEN_MASK (0x3 << 25) -#define DWC2_GNPTXSTS_NPTXQTOP_TOKEN_OFFSET 25 -#define DWC2_GNPTXSTS_NPTXQTOP_CHNEP_MASK (0xF << 27) -#define DWC2_GNPTXSTS_NPTXQTOP_CHNEP_OFFSET 27 -#define DWC2_DTXFSTS_TXFSPCAVAIL_MASK (0xFFFF << 0) -#define DWC2_DTXFSTS_TXFSPCAVAIL_OFFSET 0 -#define DWC2_GI2CCTL_RWDATA_MASK (0xFF << 0) -#define DWC2_GI2CCTL_RWDATA_OFFSET 0 -#define DWC2_GI2CCTL_REGADDR_MASK (0xFF << 8) -#define DWC2_GI2CCTL_REGADDR_OFFSET 8 -#define DWC2_GI2CCTL_ADDR_MASK (0x7F << 16) -#define DWC2_GI2CCTL_ADDR_OFFSET 16 -#define DWC2_GI2CCTL_I2CEN (1 << 23) -#define DWC2_GI2CCTL_I2CEN_OFFSET 23 -#define DWC2_GI2CCTL_ACK (1 << 24) -#define DWC2_GI2CCTL_ACK_OFFSET 24 -#define DWC2_GI2CCTL_I2CSUSPCTL (1 << 25) -#define DWC2_GI2CCTL_I2CSUSPCTL_OFFSET 25 -#define DWC2_GI2CCTL_I2CDEVADDR_MASK (0x3 << 26) -#define DWC2_GI2CCTL_I2CDEVADDR_OFFSET 26 -#define DWC2_GI2CCTL_RW (1 << 30) -#define DWC2_GI2CCTL_RW_OFFSET 30 -#define DWC2_GI2CCTL_BSYDNE (1 << 31) -#define DWC2_GI2CCTL_BSYDNE_OFFSET 31 -#define DWC2_HWCFG1_EP_DIR0_MASK (0x3 << 0) -#define DWC2_HWCFG1_EP_DIR0_OFFSET 0 -#define DWC2_HWCFG1_EP_DIR1_MASK (0x3 << 2) -#define DWC2_HWCFG1_EP_DIR1_OFFSET 2 -#define DWC2_HWCFG1_EP_DIR2_MASK (0x3 << 4) -#define DWC2_HWCFG1_EP_DIR2_OFFSET 4 -#define DWC2_HWCFG1_EP_DIR3_MASK (0x3 << 6) -#define DWC2_HWCFG1_EP_DIR3_OFFSET 6 -#define DWC2_HWCFG1_EP_DIR4_MASK (0x3 << 8) -#define DWC2_HWCFG1_EP_DIR4_OFFSET 8 -#define DWC2_HWCFG1_EP_DIR5_MASK (0x3 << 10) -#define DWC2_HWCFG1_EP_DIR5_OFFSET 10 -#define DWC2_HWCFG1_EP_DIR6_MASK (0x3 << 12) -#define DWC2_HWCFG1_EP_DIR6_OFFSET 12 -#define DWC2_HWCFG1_EP_DIR7_MASK (0x3 << 14) -#define DWC2_HWCFG1_EP_DIR7_OFFSET 14 -#define DWC2_HWCFG1_EP_DIR8_MASK (0x3 << 16) -#define DWC2_HWCFG1_EP_DIR8_OFFSET 16 -#define DWC2_HWCFG1_EP_DIR9_MASK (0x3 << 18) -#define DWC2_HWCFG1_EP_DIR9_OFFSET 18 -#define DWC2_HWCFG1_EP_DIR10_MASK (0x3 << 20) -#define DWC2_HWCFG1_EP_DIR10_OFFSET 20 -#define DWC2_HWCFG1_EP_DIR11_MASK (0x3 << 22) -#define DWC2_HWCFG1_EP_DIR11_OFFSET 22 -#define DWC2_HWCFG1_EP_DIR12_MASK (0x3 << 24) -#define DWC2_HWCFG1_EP_DIR12_OFFSET 24 -#define DWC2_HWCFG1_EP_DIR13_MASK (0x3 << 26) -#define DWC2_HWCFG1_EP_DIR13_OFFSET 26 -#define DWC2_HWCFG1_EP_DIR14_MASK (0x3 << 28) -#define DWC2_HWCFG1_EP_DIR14_OFFSET 28 -#define DWC2_HWCFG1_EP_DIR15_MASK (0x3 << 30) -#define DWC2_HWCFG1_EP_DIR15_OFFSET 30 -#define DWC2_HWCFG2_OP_MODE_MASK (0x7 << 0) -#define DWC2_HWCFG2_OP_MODE_OFFSET 0 +#define DWC2_GAHBCFG_HBURSTLEN_MASK GENMASK(4, 1) +#define DWC2_GAHBCFG_DMAENABLE BIT(5) +#define DWC2_GAHBCFG_NPTXFEMPLVL_TXFEMPLVL BIT(7) +#define DWC2_GAHBCFG_PTXFEMPLVL BIT(8) +#define DWC2_GUSBCFG_TOUTCAL_MASK GENMASK(2, 0) +#define DWC2_GUSBCFG_PHYIF BIT(3) +#define DWC2_GUSBCFG_ULPI_UTMI_SEL BIT(4) +#define DWC2_GUSBCFG_FSINTF BIT(5) +#define DWC2_GUSBCFG_PHYSEL BIT(6) +#define DWC2_GUSBCFG_DDRSEL BIT(7) +#define DWC2_GUSBCFG_SRPCAP BIT(8) +#define DWC2_GUSBCFG_HNPCAP BIT(9) +#define DWC2_GUSBCFG_USBTRDTIM_MASK GENMASK(13, 10) +#define DWC2_GUSBCFG_NPTXFRWNDEN BIT(14) +#define DWC2_GUSBCFG_PHYLPWRCLKSEL BIT(15) +#define DWC2_GUSBCFG_OTGUTMIFSSEL BIT(16) +#define DWC2_GUSBCFG_ULPI_FSLS BIT(17) +#define DWC2_GUSBCFG_ULPI_AUTO_RES BIT(18) +#define DWC2_GUSBCFG_ULPI_CLK_SUS_M BIT(19) +#define DWC2_GUSBCFG_ULPI_EXT_VBUS_DRV BIT(20) +#define DWC2_GUSBCFG_ULPI_INT_VBUS_INDICATOR BIT(21) +#define DWC2_GUSBCFG_TERM_SEL_DL_PULSE BIT(22) +#define DWC2_GUSBCFG_INDICATOR_PASSTHROUGH BIT(24) +#define DWC2_GUSBCFG_IC_USB_CAP BIT(26) +#define DWC2_GUSBCFG_IC_TRAFFIC_PULL_REMOVE BIT(27) +#define DWC2_GUSBCFG_TX_END_DELAY BIT(28) +#define DWC2_GUSBCFG_FORCEHOSTMODE BIT(29) +#define DWC2_GUSBCFG_FORCEDEVMODE BIT(30) +#define DWC2_GLPMCTL_LPM_CAP_EN BIT(0) +#define DWC2_GLPMCTL_APPL_RESP BIT(1) +#define DWC2_GLPMCTL_HIRD_MASK GENMASK(5, 2) +#define DWC2_GLPMCTL_REM_WKUP_EN BIT(6) +#define DWC2_GLPMCTL_EN_UTMI_SLEEP BIT(7) +#define DWC2_GLPMCTL_HIRD_THRES_MASK GENMASK(12, 8) +#define DWC2_GLPMCTL_LPM_RESP_MASK GENMASK(14, 13) +#define DWC2_GLPMCTL_PRT_SLEEP_STS BIT(15) +#define DWC2_GLPMCTL_SLEEP_STATE_RESUMEOK BIT(16) +#define DWC2_GLPMCTL_LPM_CHAN_INDEX_MASK GENMASK(20, 17) +#define DWC2_GLPMCTL_RETRY_COUNT_MASK GENMASK(23, 21) +#define DWC2_GLPMCTL_SEND_LPM BIT(24) +#define DWC2_GLPMCTL_RETRY_COUNT_STS_MASK GENMASK(27, 25) +#define DWC2_GLPMCTL_HSIC_CONNECT BIT(30) +#define DWC2_GLPMCTL_INV_SEL_HSIC BIT(31) +#define DWC2_GRSTCTL_CSFTRST BIT(0) +#define DWC2_GRSTCTL_HSFTRST BIT(1) +#define DWC2_GRSTCTL_HSTFRM BIT(2) +#define DWC2_GRSTCTL_INTKNQFLSH BIT(3) +#define DWC2_GRSTCTL_RXFFLSH BIT(4) +#define DWC2_GRSTCTL_TXFFLSH BIT(5) +#define DWC2_GRSTCTL_TXFNUM_MASK GENMASK(10, 6) +#define DWC2_GRSTCTL_DMAREQ BIT(30) +#define DWC2_GRSTCTL_AHBIDLE BIT(31) +#define DWC2_GINTMSK_MODEMISMATCH BIT(1) +#define DWC2_GINTMSK_OTGINTR BIT(2) +#define DWC2_GINTMSK_SOFINTR BIT(3) +#define DWC2_GINTMSK_RXSTSQLVL BIT(4) +#define DWC2_GINTMSK_NPTXFEMPTY BIT(5) +#define DWC2_GINTMSK_GINNAKEFF BIT(6) +#define DWC2_GINTMSK_GOUTNAKEFF BIT(7) +#define DWC2_GINTMSK_I2CINTR BIT(9) +#define DWC2_GINTMSK_ERLYSUSPEND BIT(10) +#define DWC2_GINTMSK_USBSUSPEND BIT(11) +#define DWC2_GINTMSK_USBRESET BIT(12) +#define DWC2_GINTMSK_ENUMDONE BIT(13) +#define DWC2_GINTMSK_ISOOUTDROP BIT(14) +#define DWC2_GINTMSK_EOPFRAME BIT(15) +#define DWC2_GINTMSK_EPMISMATCH BIT(17) +#define DWC2_GINTMSK_INEPINTR BIT(18) +#define DWC2_GINTMSK_OUTEPINTR BIT(19) +#define DWC2_GINTMSK_INCOMPLISOIN BIT(20) +#define DWC2_GINTMSK_INCOMPLISOOUT BIT(21) +#define DWC2_GINTMSK_PORTINTR BIT(24) +#define DWC2_GINTMSK_HCINTR BIT(25) +#define DWC2_GINTMSK_PTXFEMPTY BIT(26) +#define DWC2_GINTMSK_LPMTRANRCVD BIT(27) +#define DWC2_GINTMSK_CONIDSTSCHNG BIT(28) +#define DWC2_GINTMSK_DISCONNECT BIT(29) +#define DWC2_GINTMSK_SESSREQINTR BIT(30) +#define DWC2_GINTMSK_WKUPINTR BIT(31) +#define DWC2_GINTSTS_CURMODE_HOST BIT(0) +#define DWC2_GINTSTS_MODEMISMATCH BIT(1) +#define DWC2_GINTSTS_OTGINTR BIT(2) +#define DWC2_GINTSTS_SOFINTR BIT(3) +#define DWC2_GINTSTS_RXSTSQLVL BIT(4) +#define DWC2_GINTSTS_NPTXFEMPTY BIT(5) +#define DWC2_GINTSTS_GINNAKEFF BIT(6) +#define DWC2_GINTSTS_GOUTNAKEFF BIT(7) +#define DWC2_GINTSTS_I2CINTR BIT(9) +#define DWC2_GINTSTS_ERLYSUSPEND BIT(10) +#define DWC2_GINTSTS_USBSUSPEND BIT(11) +#define DWC2_GINTSTS_USBRESET BIT(12) +#define DWC2_GINTSTS_ENUMDONE BIT(13) +#define DWC2_GINTSTS_ISOOUTDROP BIT(14) +#define DWC2_GINTSTS_EOPFRAME BIT(15) +#define DWC2_GINTSTS_INTOKENRX BIT(16) +#define DWC2_GINTSTS_EPMISMATCH BIT(17) +#define DWC2_GINTSTS_INEPINT BIT(18) +#define DWC2_GINTSTS_OUTEPINTR BIT(19) +#define DWC2_GINTSTS_INCOMPLISOIN BIT(20) +#define DWC2_GINTSTS_INCOMPLISOOUT BIT(21) +#define DWC2_GINTSTS_PORTINTR BIT(24) +#define DWC2_GINTSTS_HCINTR BIT(25) +#define DWC2_GINTSTS_PTXFEMPTY BIT(26) +#define DWC2_GINTSTS_LPMTRANRCVD BIT(27) +#define DWC2_GINTSTS_CONIDSTSCHNG BIT(28) +#define DWC2_GINTSTS_DISCONNECT BIT(29) +#define DWC2_GINTSTS_SESSREQINTR BIT(30) +#define DWC2_GINTSTS_WKUPINTR BIT(31) +#define DWC2_GRXSTS_EPNUM_MASK GENMASK(3, 0) +#define DWC2_GRXSTS_BCNT_MASK GENMASK(14, 4) +#define DWC2_GRXSTS_DPID_MASK GENMASK(16, 15) +#define DWC2_GRXSTS_PKTSTS_MASK GENMASK(20, 17) +#define DWC2_GRXSTS_FN_MASK GENMASK(24, 21) +#define DWC2_FIFOSIZE_STARTADDR_MASK GENMASK(15, 0) +#define DWC2_FIFOSIZE_DEPTH_MASK GENMASK(31, 16) +#define DWC2_GNPTXSTS_NPTXFSPCAVAIL_MASK GENMASK(15, 0) +#define DWC2_GNPTXSTS_NPTXQSPCAVAIL_MASK GENMASK(23, 16) +#define DWC2_GNPTXSTS_NPTXQTOP_TERMINATE BIT(24) +#define DWC2_GNPTXSTS_NPTXQTOP_TOKEN_MASK GENMASK(26, 25) +#define DWC2_GNPTXSTS_NPTXQTOP_CHNEP_MASK GENMASK(30, 27) +#define DWC2_DTXFSTS_TXFSPCAVAIL_MASK GENMASK(15, 0) +#define DWC2_GI2CCTL_RWDATA_MASK GENMASK(7, 0) +#define DWC2_GI2CCTL_REGADDR_MASK GENMASK(15, 8) +#define DWC2_GI2CCTL_ADDR_MASK GENMASK(22, 16) +#define DWC2_GI2CCTL_I2CEN BIT(23) +#define DWC2_GI2CCTL_ACK BIT(24) +#define DWC2_GI2CCTL_I2CSUSPCTL BIT(25) +#define DWC2_GI2CCTL_I2CDEVADDR_MASK GENMASK(27, 26) +#define DWC2_GI2CCTL_RW BIT(30) +#define DWC2_GI2CCTL_BSYDNE BIT(31) +#define DWC2_HWCFG1_EP_DIR0_MASK GENMASK(1, 0) +#define DWC2_HWCFG1_EP_DIR1_MASK GENMASK(3, 2) +#define DWC2_HWCFG1_EP_DIR2_MASK GENMASK(5, 4) +#define DWC2_HWCFG1_EP_DIR3_MASK GENMASK(7, 6) +#define DWC2_HWCFG1_EP_DIR4_MASK GENMASK(9, 8) +#define DWC2_HWCFG1_EP_DIR5_MASK GENMASK(11, 10) +#define DWC2_HWCFG1_EP_DIR6_MASK GENMASK(13, 12) +#define DWC2_HWCFG1_EP_DIR7_MASK GENMASK(15, 14) +#define DWC2_HWCFG1_EP_DIR8_MASK GENMASK(17, 16) +#define DWC2_HWCFG1_EP_DIR9_MASK GENMASK(19, 18) +#define DWC2_HWCFG1_EP_DIR10_MASK GENMASK(21, 20) +#define DWC2_HWCFG1_EP_DIR11_MASK GENMASK(23, 22) +#define DWC2_HWCFG1_EP_DIR12_MASK GENMASK(25, 24) +#define DWC2_HWCFG1_EP_DIR13_MASK GENMASK(27, 26) +#define DWC2_HWCFG1_EP_DIR14_MASK GENMASK(29, 28) +#define DWC2_HWCFG1_EP_DIR15_MASK GENMASK(31, 30) +#define DWC2_HWCFG2_OP_MODE_MASK GENMASK(2, 0) #define DWC2_HWCFG2_ARCHITECTURE_SLAVE_ONLY (0x0 << 3) #define DWC2_HWCFG2_ARCHITECTURE_EXT_DMA (0x1 << 3) #define DWC2_HWCFG2_ARCHITECTURE_INT_DMA (0x2 << 3) -#define DWC2_HWCFG2_ARCHITECTURE_MASK (0x3 << 3) -#define DWC2_HWCFG2_ARCHITECTURE_OFFSET 3 -#define DWC2_HWCFG2_POINT2POINT (1 << 5) -#define DWC2_HWCFG2_POINT2POINT_OFFSET 5 -#define DWC2_HWCFG2_HS_PHY_TYPE_MASK (0x3 << 6) -#define DWC2_HWCFG2_HS_PHY_TYPE_OFFSET 6 -#define DWC2_HWCFG2_FS_PHY_TYPE_MASK (0x3 << 8) -#define DWC2_HWCFG2_FS_PHY_TYPE_OFFSET 8 -#define DWC2_HWCFG2_NUM_DEV_EP_MASK (0xF << 10) -#define DWC2_HWCFG2_NUM_DEV_EP_OFFSET 10 -#define DWC2_HWCFG2_NUM_HOST_CHAN_MASK (0xF << 14) -#define DWC2_HWCFG2_NUM_HOST_CHAN_OFFSET 14 -#define DWC2_HWCFG2_PERIO_EP_SUPPORTED (1 << 18) -#define DWC2_HWCFG2_PERIO_EP_SUPPORTED_OFFSET 18 -#define DWC2_HWCFG2_DYNAMIC_FIFO (1 << 19) -#define DWC2_HWCFG2_DYNAMIC_FIFO_OFFSET 19 -#define DWC2_HWCFG2_MULTI_PROC_INT (1 << 20) -#define DWC2_HWCFG2_MULTI_PROC_INT_OFFSET 20 -#define DWC2_HWCFG2_NONPERIO_TX_Q_DEPTH_MASK (0x3 << 22) -#define DWC2_HWCFG2_NONPERIO_TX_Q_DEPTH_OFFSET 22 -#define DWC2_HWCFG2_HOST_PERIO_TX_Q_DEPTH_MASK (0x3 << 24) -#define DWC2_HWCFG2_HOST_PERIO_TX_Q_DEPTH_OFFSET 24 -#define DWC2_HWCFG2_DEV_TOKEN_Q_DEPTH_MASK (0x1F << 26) -#define DWC2_HWCFG2_DEV_TOKEN_Q_DEPTH_OFFSET 26 -#define DWC2_HWCFG3_XFER_SIZE_CNTR_WIDTH_MASK (0xF << 0) -#define DWC2_HWCFG3_XFER_SIZE_CNTR_WIDTH_OFFSET 0 -#define DWC2_HWCFG3_PACKET_SIZE_CNTR_WIDTH_MASK (0x7 << 4) -#define DWC2_HWCFG3_PACKET_SIZE_CNTR_WIDTH_OFFSET 4 -#define DWC2_HWCFG3_OTG_FUNC (1 << 7) -#define DWC2_HWCFG3_OTG_FUNC_OFFSET 7 -#define DWC2_HWCFG3_I2C (1 << 8) -#define DWC2_HWCFG3_I2C_OFFSET 8 -#define DWC2_HWCFG3_VENDOR_CTRL_IF (1 << 9) -#define DWC2_HWCFG3_VENDOR_CTRL_IF_OFFSET 9 -#define DWC2_HWCFG3_OPTIONAL_FEATURES (1 << 10) -#define DWC2_HWCFG3_OPTIONAL_FEATURES_OFFSET 10 -#define DWC2_HWCFG3_SYNCH_RESET_TYPE (1 << 11) -#define DWC2_HWCFG3_SYNCH_RESET_TYPE_OFFSET 11 -#define DWC2_HWCFG3_OTG_ENABLE_IC_USB (1 << 12) -#define DWC2_HWCFG3_OTG_ENABLE_IC_USB_OFFSET 12 -#define DWC2_HWCFG3_OTG_ENABLE_HSIC (1 << 13) -#define DWC2_HWCFG3_OTG_ENABLE_HSIC_OFFSET 13 -#define DWC2_HWCFG3_OTG_LPM_EN (1 << 15) -#define DWC2_HWCFG3_OTG_LPM_EN_OFFSET 15 -#define DWC2_HWCFG3_DFIFO_DEPTH_MASK (0xFFFF << 16) -#define DWC2_HWCFG3_DFIFO_DEPTH_OFFSET 16 -#define DWC2_HWCFG4_NUM_DEV_PERIO_IN_EP_MASK (0xF << 0) -#define DWC2_HWCFG4_NUM_DEV_PERIO_IN_EP_OFFSET 0 -#define DWC2_HWCFG4_POWER_OPTIMIZ (1 << 4) -#define DWC2_HWCFG4_POWER_OPTIMIZ_OFFSET 4 -#define DWC2_HWCFG4_MIN_AHB_FREQ_MASK (0x1FF << 5) -#define DWC2_HWCFG4_MIN_AHB_FREQ_OFFSET 5 -#define DWC2_HWCFG4_UTMI_PHY_DATA_WIDTH_MASK (0x3 << 14) -#define DWC2_HWCFG4_UTMI_PHY_DATA_WIDTH_OFFSET 14 -#define DWC2_HWCFG4_NUM_DEV_MODE_CTRL_EP_MASK (0xF << 16) -#define DWC2_HWCFG4_NUM_DEV_MODE_CTRL_EP_OFFSET 16 -#define DWC2_HWCFG4_IDDIG_FILT_EN (1 << 20) -#define DWC2_HWCFG4_IDDIG_FILT_EN_OFFSET 20 -#define DWC2_HWCFG4_VBUS_VALID_FILT_EN (1 << 21) -#define DWC2_HWCFG4_VBUS_VALID_FILT_EN_OFFSET 21 -#define DWC2_HWCFG4_A_VALID_FILT_EN (1 << 22) -#define DWC2_HWCFG4_A_VALID_FILT_EN_OFFSET 22 -#define DWC2_HWCFG4_B_VALID_FILT_EN (1 << 23) -#define DWC2_HWCFG4_B_VALID_FILT_EN_OFFSET 23 -#define DWC2_HWCFG4_SESSION_END_FILT_EN (1 << 24) -#define DWC2_HWCFG4_SESSION_END_FILT_EN_OFFSET 24 -#define DWC2_HWCFG4_DED_FIFO_EN (1 << 25) -#define DWC2_HWCFG4_DED_FIFO_EN_OFFSET 25 -#define DWC2_HWCFG4_NUM_IN_EPS_MASK (0xF << 26) -#define DWC2_HWCFG4_NUM_IN_EPS_OFFSET 26 -#define DWC2_HWCFG4_DESC_DMA (1 << 30) -#define DWC2_HWCFG4_DESC_DMA_OFFSET 30 -#define DWC2_HWCFG4_DESC_DMA_DYN (1 << 31) -#define DWC2_HWCFG4_DESC_DMA_DYN_OFFSET 31 +#define DWC2_HWCFG2_ARCHITECTURE_MASK GENMASK(4, 3) +#define DWC2_HWCFG2_POINT2POINT BIT(5) +#define DWC2_HWCFG2_HS_PHY_TYPE_MASK GENMASK(7, 6) +#define DWC2_HWCFG2_FS_PHY_TYPE_MASK GENMASK(9, 8) +#define DWC2_HWCFG2_NUM_DEV_EP_MASK GENMASK(13, 10) +#define DWC2_HWCFG2_NUM_HOST_CHAN_MASK GENMASK(17, 14) +#define DWC2_HWCFG2_PERIO_EP_SUPPORTED BIT(18) +#define DWC2_HWCFG2_DYNAMIC_FIFO BIT(19) +#define DWC2_HWCFG2_MULTI_PROC_INT BIT(20) +#define DWC2_HWCFG2_NONPERIO_TX_Q_DEPTH_MASK GENMASK(23, 22) +#define DWC2_HWCFG2_HOST_PERIO_TX_Q_DEPTH_MASK GENMASK(25, 24) +#define DWC2_HWCFG2_DEV_TOKEN_Q_DEPTH_MASK GENMASK(30, 26) +#define DWC2_HWCFG3_XFER_SIZE_CNTR_WIDTH_MASK GENMASK(3, 0) +#define DWC2_HWCFG3_PACKET_SIZE_CNTR_WIDTH_MASK GENMASK(6, 4) +#define DWC2_HWCFG3_OTG_FUNC BIT(7) +#define DWC2_HWCFG3_I2C BIT(8) +#define DWC2_HWCFG3_VENDOR_CTRL_IF BIT(9) +#define DWC2_HWCFG3_OPTIONAL_FEATURES BIT(10) +#define DWC2_HWCFG3_SYNCH_RESET_TYPE BIT(11) +#define DWC2_HWCFG3_OTG_ENABLE_IC_USB BIT(12) +#define DWC2_HWCFG3_OTG_ENABLE_HSIC BIT(13) +#define DWC2_HWCFG3_OTG_LPM_EN BIT(15) +#define DWC2_HWCFG3_DFIFO_DEPTH_MASK GENMASK(31, 16) +#define DWC2_HWCFG4_NUM_DEV_PERIO_IN_EP_MASK GENMASK(3, 0) +#define DWC2_HWCFG4_POWER_OPTIMIZ BIT(4) +#define DWC2_HWCFG4_MIN_AHB_FREQ_MASK GENMASK(13, 5) +#define DWC2_HWCFG4_UTMI_PHY_DATA_WIDTH_MASK GENMASK(15, 14) +#define DWC2_HWCFG4_NUM_DEV_MODE_CTRL_EP_MASK GENMASK(19, 16) +#define DWC2_HWCFG4_IDDIG_FILT_EN BIT(20) +#define DWC2_HWCFG4_VBUS_VALID_FILT_EN BIT(21) +#define DWC2_HWCFG4_A_VALID_FILT_EN BIT(22) +#define DWC2_HWCFG4_B_VALID_FILT_EN BIT(23) +#define DWC2_HWCFG4_SESSION_END_FILT_EN BIT(24) +#define DWC2_HWCFG4_DED_FIFO_EN BIT(25) +#define DWC2_HWCFG4_NUM_IN_EPS_MASK GENMASK(29, 26) +#define DWC2_HWCFG4_DESC_DMA BIT(30) +#define DWC2_HWCFG4_DESC_DMA_DYN BIT(31) #define DWC2_HCFG_FSLSPCLKSEL_30_60_MHZ 0 #define DWC2_HCFG_FSLSPCLKSEL_48_MHZ 1 #define DWC2_HCFG_FSLSPCLKSEL_6_MHZ 2 -#define DWC2_HCFG_FSLSPCLKSEL_MASK (0x3 << 0) -#define DWC2_HCFG_FSLSPCLKSEL_OFFSET 0 -#define DWC2_HCFG_FSLSSUPP (1 << 2) -#define DWC2_HCFG_FSLSSUPP_OFFSET 2 -#define DWC2_HCFG_DESCDMA (1 << 23) -#define DWC2_HCFG_DESCDMA_OFFSET 23 -#define DWC2_HCFG_FRLISTEN_MASK (0x3 << 24) -#define DWC2_HCFG_FRLISTEN_OFFSET 24 -#define DWC2_HCFG_PERSCHEDENA (1 << 26) -#define DWC2_HCFG_PERSCHEDENA_OFFSET 26 -#define DWC2_HCFG_PERSCHEDSTAT (1 << 27) -#define DWC2_HCFG_PERSCHEDSTAT_OFFSET 27 -#define DWC2_HFIR_FRINT_MASK (0xFFFF << 0) -#define DWC2_HFIR_FRINT_OFFSET 0 -#define DWC2_HFNUM_FRNUM_MASK (0xFFFF << 0) -#define DWC2_HFNUM_FRNUM_OFFSET 0 -#define DWC2_HFNUM_FRREM_MASK (0xFFFF << 16) -#define DWC2_HFNUM_FRREM_OFFSET 16 +#define DWC2_HCFG_FSLSPCLKSEL_MASK GENMASK(1, 0) +#define DWC2_HCFG_FSLSSUPP BIT(2) +#define DWC2_HCFG_DESCDMA BIT(23) +#define DWC2_HCFG_FRLISTEN_MASK GENMASK(25, 24) +#define DWC2_HCFG_PERSCHEDENA BIT(26) +#define DWC2_HCFG_PERSCHEDSTAT BIT(27) +#define DWC2_HFIR_FRINT_MASK GENMASK(15, 0) +#define DWC2_HFNUM_FRNUM_MASK GENMASK(15, 0) +#define DWC2_HFNUM_FRREM_MASK GENMASK(31, 16) #define DWC2_HFNUM_MAX_FRNUM 0x3FFF -#define DWC2_HPTXSTS_PTXFSPCAVAIL_MASK (0xFFFF << 0) -#define DWC2_HPTXSTS_PTXFSPCAVAIL_OFFSET 0 -#define DWC2_HPTXSTS_PTXQSPCAVAIL_MASK (0xFF << 16) -#define DWC2_HPTXSTS_PTXQSPCAVAIL_OFFSET 16 -#define DWC2_HPTXSTS_PTXQTOP_TERMINATE (1 << 24) -#define DWC2_HPTXSTS_PTXQTOP_TERMINATE_OFFSET 24 -#define DWC2_HPTXSTS_PTXQTOP_TOKEN_MASK (0x3 << 25) -#define DWC2_HPTXSTS_PTXQTOP_TOKEN_OFFSET 25 -#define DWC2_HPTXSTS_PTXQTOP_CHNUM_MASK (0xF << 27) -#define DWC2_HPTXSTS_PTXQTOP_CHNUM_OFFSET 27 -#define DWC2_HPTXSTS_PTXQTOP_ODD (1 << 31) -#define DWC2_HPTXSTS_PTXQTOP_ODD_OFFSET 31 -#define DWC2_HPRT0_PRTCONNSTS (1 << 0) -#define DWC2_HPRT0_PRTCONNSTS_OFFSET 0 -#define DWC2_HPRT0_PRTCONNDET (1 << 1) -#define DWC2_HPRT0_PRTCONNDET_OFFSET 1 -#define DWC2_HPRT0_PRTENA (1 << 2) -#define DWC2_HPRT0_PRTENA_OFFSET 2 -#define DWC2_HPRT0_PRTENCHNG (1 << 3) -#define DWC2_HPRT0_PRTENCHNG_OFFSET 3 -#define DWC2_HPRT0_PRTOVRCURRACT (1 << 4) -#define DWC2_HPRT0_PRTOVRCURRACT_OFFSET 4 -#define DWC2_HPRT0_PRTOVRCURRCHNG (1 << 5) -#define DWC2_HPRT0_PRTOVRCURRCHNG_OFFSET 5 -#define DWC2_HPRT0_PRTRES (1 << 6) -#define DWC2_HPRT0_PRTRES_OFFSET 6 -#define DWC2_HPRT0_PRTSUSP (1 << 7) -#define DWC2_HPRT0_PRTSUSP_OFFSET 7 -#define DWC2_HPRT0_PRTRST (1 << 8) -#define DWC2_HPRT0_PRTRST_OFFSET 8 -#define DWC2_HPRT0_PRTLNSTS_MASK (0x3 << 10) -#define DWC2_HPRT0_PRTLNSTS_OFFSET 10 -#define DWC2_HPRT0_PRTPWR (1 << 12) -#define DWC2_HPRT0_PRTPWR_OFFSET 12 -#define DWC2_HPRT0_PRTTSTCTL_MASK (0xF << 13) -#define DWC2_HPRT0_PRTTSTCTL_OFFSET 13 +#define DWC2_HPTXSTS_PTXFSPCAVAIL_MASK GENMASK(15, 0) +#define DWC2_HPTXSTS_PTXQSPCAVAIL_MASK GENMASK(23, 16) +#define DWC2_HPTXSTS_PTXQTOP_TERMINATE BIT(24) +#define DWC2_HPTXSTS_PTXQTOP_TOKEN_MASK GENMASK(26, 25) +#define DWC2_HPTXSTS_PTXQTOP_CHNUM_MASK GENMASK(30, 27) +#define DWC2_HPTXSTS_PTXQTOP_ODD BIT(31) +#define DWC2_HPRT0_PRTCONNSTS BIT(0) +#define DWC2_HPRT0_PRTCONNDET BIT(1) +#define DWC2_HPRT0_PRTENA BIT(2) +#define DWC2_HPRT0_PRTENCHNG BIT(3) +#define DWC2_HPRT0_PRTOVRCURRACT BIT(4) +#define DWC2_HPRT0_PRTOVRCURRCHNG BIT(5) +#define DWC2_HPRT0_PRTRES BIT(6) +#define DWC2_HPRT0_PRTSUSP BIT(7) +#define DWC2_HPRT0_PRTRST BIT(8) +#define DWC2_HPRT0_PRTLNSTS_MASK GENMASK(11, 10) +#define DWC2_HPRT0_PRTPWR BIT(12) +#define DWC2_HPRT0_PRTTSTCTL_MASK GENMASK(16, 13) #define DWC2_HPRT0_PRTSPD_HIGH (0 << 17) #define DWC2_HPRT0_PRTSPD_FULL (1 << 17) #define DWC2_HPRT0_PRTSPD_LOW (2 << 17) -#define DWC2_HPRT0_PRTSPD_MASK (0x3 << 17) -#define DWC2_HPRT0_PRTSPD_OFFSET 17 +#define DWC2_HPRT0_PRTSPD_MASK GENMASK(18, 17) #define DWC2_HPRT0_W1C_MASK (DWC2_HPRT0_PRTCONNDET | \ DWC2_HPRT0_PRTENA | \ DWC2_HPRT0_PRTENCHNG | \ DWC2_HPRT0_PRTOVRCURRCHNG) -#define DWC2_HAINT_CH0 (1 << 0) -#define DWC2_HAINT_CH0_OFFSET 0 -#define DWC2_HAINT_CH1 (1 << 1) -#define DWC2_HAINT_CH1_OFFSET 1 -#define DWC2_HAINT_CH2 (1 << 2) -#define DWC2_HAINT_CH2_OFFSET 2 -#define DWC2_HAINT_CH3 (1 << 3) -#define DWC2_HAINT_CH3_OFFSET 3 -#define DWC2_HAINT_CH4 (1 << 4) -#define DWC2_HAINT_CH4_OFFSET 4 -#define DWC2_HAINT_CH5 (1 << 5) -#define DWC2_HAINT_CH5_OFFSET 5 -#define DWC2_HAINT_CH6 (1 << 6) -#define DWC2_HAINT_CH6_OFFSET 6 -#define DWC2_HAINT_CH7 (1 << 7) -#define DWC2_HAINT_CH7_OFFSET 7 -#define DWC2_HAINT_CH8 (1 << 8) -#define DWC2_HAINT_CH8_OFFSET 8 -#define DWC2_HAINT_CH9 (1 << 9) -#define DWC2_HAINT_CH9_OFFSET 9 -#define DWC2_HAINT_CH10 (1 << 10) -#define DWC2_HAINT_CH10_OFFSET 10 -#define DWC2_HAINT_CH11 (1 << 11) -#define DWC2_HAINT_CH11_OFFSET 11 -#define DWC2_HAINT_CH12 (1 << 12) -#define DWC2_HAINT_CH12_OFFSET 12 -#define DWC2_HAINT_CH13 (1 << 13) -#define DWC2_HAINT_CH13_OFFSET 13 -#define DWC2_HAINT_CH14 (1 << 14) -#define DWC2_HAINT_CH14_OFFSET 14 -#define DWC2_HAINT_CH15 (1 << 15) -#define DWC2_HAINT_CH15_OFFSET 15 -#define DWC2_HAINT_CHINT_MASK 0xffff -#define DWC2_HAINT_CHINT_OFFSET 0 -#define DWC2_HAINTMSK_CH0 (1 << 0) -#define DWC2_HAINTMSK_CH0_OFFSET 0 -#define DWC2_HAINTMSK_CH1 (1 << 1) -#define DWC2_HAINTMSK_CH1_OFFSET 1 -#define DWC2_HAINTMSK_CH2 (1 << 2) -#define DWC2_HAINTMSK_CH2_OFFSET 2 -#define DWC2_HAINTMSK_CH3 (1 << 3) -#define DWC2_HAINTMSK_CH3_OFFSET 3 -#define DWC2_HAINTMSK_CH4 (1 << 4) -#define DWC2_HAINTMSK_CH4_OFFSET 4 -#define DWC2_HAINTMSK_CH5 (1 << 5) -#define DWC2_HAINTMSK_CH5_OFFSET 5 -#define DWC2_HAINTMSK_CH6 (1 << 6) -#define DWC2_HAINTMSK_CH6_OFFSET 6 -#define DWC2_HAINTMSK_CH7 (1 << 7) -#define DWC2_HAINTMSK_CH7_OFFSET 7 -#define DWC2_HAINTMSK_CH8 (1 << 8) -#define DWC2_HAINTMSK_CH8_OFFSET 8 -#define DWC2_HAINTMSK_CH9 (1 << 9) -#define DWC2_HAINTMSK_CH9_OFFSET 9 -#define DWC2_HAINTMSK_CH10 (1 << 10) -#define DWC2_HAINTMSK_CH10_OFFSET 10 -#define DWC2_HAINTMSK_CH11 (1 << 11) -#define DWC2_HAINTMSK_CH11_OFFSET 11 -#define DWC2_HAINTMSK_CH12 (1 << 12) -#define DWC2_HAINTMSK_CH12_OFFSET 12 -#define DWC2_HAINTMSK_CH13 (1 << 13) -#define DWC2_HAINTMSK_CH13_OFFSET 13 -#define DWC2_HAINTMSK_CH14 (1 << 14) -#define DWC2_HAINTMSK_CH14_OFFSET 14 -#define DWC2_HAINTMSK_CH15 (1 << 15) -#define DWC2_HAINTMSK_CH15_OFFSET 15 -#define DWC2_HAINTMSK_CHINT_MASK 0xffff -#define DWC2_HAINTMSK_CHINT_OFFSET 0 -#define DWC2_HCCHAR_MPS_MASK (0x7FF << 0) -#define DWC2_HCCHAR_MPS_OFFSET 0 -#define DWC2_HCCHAR_EPNUM_MASK (0xF << 11) -#define DWC2_HCCHAR_EPNUM_OFFSET 11 -#define DWC2_HCCHAR_EPDIR (1 << 15) -#define DWC2_HCCHAR_EPDIR_OFFSET 15 -#define DWC2_HCCHAR_LSPDDEV (1 << 17) -#define DWC2_HCCHAR_LSPDDEV_OFFSET 17 +#define DWC2_HAINT_CH0 BIT(0) +#define DWC2_HAINT_CH1 BIT(1) +#define DWC2_HAINT_CH2 BIT(2) +#define DWC2_HAINT_CH3 BIT(3) +#define DWC2_HAINT_CH4 BIT(4) +#define DWC2_HAINT_CH5 BIT(5) +#define DWC2_HAINT_CH6 BIT(6) +#define DWC2_HAINT_CH7 BIT(7) +#define DWC2_HAINT_CH8 BIT(8) +#define DWC2_HAINT_CH9 BIT(9) +#define DWC2_HAINT_CH10 BIT(10) +#define DWC2_HAINT_CH11 BIT(11) +#define DWC2_HAINT_CH12 BIT(12) +#define DWC2_HAINT_CH13 BIT(13) +#define DWC2_HAINT_CH14 BIT(14) +#define DWC2_HAINT_CH15 BIT(15) +#define DWC2_HAINT_CHINT_MASK GENMASK(15, 0) +#define DWC2_HAINTMSK_CH0 BIT(0) +#define DWC2_HAINTMSK_CH1 BIT(1) +#define DWC2_HAINTMSK_CH2 BIT(2) +#define DWC2_HAINTMSK_CH3 BIT(3) +#define DWC2_HAINTMSK_CH4 BIT(4) +#define DWC2_HAINTMSK_CH5 BIT(5) +#define DWC2_HAINTMSK_CH6 BIT(6) +#define DWC2_HAINTMSK_CH7 BIT(7) +#define DWC2_HAINTMSK_CH8 BIT(8) +#define DWC2_HAINTMSK_CH9 BIT(9) +#define DWC2_HAINTMSK_CH10 BIT(10) +#define DWC2_HAINTMSK_CH11 BIT(11) +#define DWC2_HAINTMSK_CH12 BIT(12) +#define DWC2_HAINTMSK_CH13 BIT(13) +#define DWC2_HAINTMSK_CH14 BIT(14) +#define DWC2_HAINTMSK_CH15 BIT(15) +#define DWC2_HAINTMSK_CHINT_MASK GENMASK(15, 0) +#define DWC2_HCCHAR_MPS_MASK GENMASK(10, 0) +#define DWC2_HCCHAR_EPNUM_MASK GENMASK(14, 11) +#define DWC2_HCCHAR_EPDIR BIT(15) +#define DWC2_HCCHAR_LSPDDEV BIT(17) #define DWC2_HCCHAR_EPTYPE_CONTROL 0 #define DWC2_HCCHAR_EPTYPE_ISOC 1 #define DWC2_HCCHAR_EPTYPE_BULK 2 #define DWC2_HCCHAR_EPTYPE_INTR 3 -#define DWC2_HCCHAR_EPTYPE_MASK (0x3 << 18) -#define DWC2_HCCHAR_EPTYPE_OFFSET 18 -#define DWC2_HCCHAR_MULTICNT_MASK (0x3 << 20) -#define DWC2_HCCHAR_MULTICNT_OFFSET 20 -#define DWC2_HCCHAR_DEVADDR_MASK (0x7F << 22) -#define DWC2_HCCHAR_DEVADDR_OFFSET 22 -#define DWC2_HCCHAR_ODDFRM (1 << 29) -#define DWC2_HCCHAR_ODDFRM_OFFSET 29 -#define DWC2_HCCHAR_CHDIS (1 << 30) -#define DWC2_HCCHAR_CHDIS_OFFSET 30 -#define DWC2_HCCHAR_CHEN (1 << 31) -#define DWC2_HCCHAR_CHEN_OFFSET 31 -#define DWC2_HCSPLT_PRTADDR_MASK (0x7F << 0) -#define DWC2_HCSPLT_PRTADDR_OFFSET 0 -#define DWC2_HCSPLT_HUBADDR_MASK (0x7F << 7) -#define DWC2_HCSPLT_HUBADDR_OFFSET 7 -#define DWC2_HCSPLT_XACTPOS_MASK (0x3 << 14) -#define DWC2_HCSPLT_XACTPOS_OFFSET 14 -#define DWC2_HCSPLT_COMPSPLT (1 << 16) -#define DWC2_HCSPLT_COMPSPLT_OFFSET 16 -#define DWC2_HCSPLT_SPLTENA (1 << 31) -#define DWC2_HCSPLT_SPLTENA_OFFSET 31 -#define DWC2_HCINT_XFERCOMP (1 << 0) -#define DWC2_HCINT_XFERCOMP_OFFSET 0 -#define DWC2_HCINT_CHHLTD (1 << 1) -#define DWC2_HCINT_CHHLTD_OFFSET 1 -#define DWC2_HCINT_AHBERR (1 << 2) -#define DWC2_HCINT_AHBERR_OFFSET 2 -#define DWC2_HCINT_STALL (1 << 3) -#define DWC2_HCINT_STALL_OFFSET 3 -#define DWC2_HCINT_NAK (1 << 4) -#define DWC2_HCINT_NAK_OFFSET 4 -#define DWC2_HCINT_ACK (1 << 5) -#define DWC2_HCINT_ACK_OFFSET 5 -#define DWC2_HCINT_NYET (1 << 6) -#define DWC2_HCINT_NYET_OFFSET 6 -#define DWC2_HCINT_XACTERR (1 << 7) -#define DWC2_HCINT_XACTERR_OFFSET 7 -#define DWC2_HCINT_BBLERR (1 << 8) -#define DWC2_HCINT_BBLERR_OFFSET 8 -#define DWC2_HCINT_FRMOVRUN (1 << 9) -#define DWC2_HCINT_FRMOVRUN_OFFSET 9 -#define DWC2_HCINT_DATATGLERR (1 << 10) -#define DWC2_HCINT_DATATGLERR_OFFSET 10 -#define DWC2_HCINT_BNA (1 << 11) -#define DWC2_HCINT_BNA_OFFSET 11 -#define DWC2_HCINT_XCS_XACT (1 << 12) -#define DWC2_HCINT_XCS_XACT_OFFSET 12 -#define DWC2_HCINT_FRM_LIST_ROLL (1 << 13) -#define DWC2_HCINT_FRM_LIST_ROLL_OFFSET 13 -#define DWC2_HCINTMSK_XFERCOMPL (1 << 0) -#define DWC2_HCINTMSK_XFERCOMPL_OFFSET 0 -#define DWC2_HCINTMSK_CHHLTD (1 << 1) -#define DWC2_HCINTMSK_CHHLTD_OFFSET 1 -#define DWC2_HCINTMSK_AHBERR (1 << 2) -#define DWC2_HCINTMSK_AHBERR_OFFSET 2 -#define DWC2_HCINTMSK_STALL (1 << 3) -#define DWC2_HCINTMSK_STALL_OFFSET 3 -#define DWC2_HCINTMSK_NAK (1 << 4) -#define DWC2_HCINTMSK_NAK_OFFSET 4 -#define DWC2_HCINTMSK_ACK (1 << 5) -#define DWC2_HCINTMSK_ACK_OFFSET 5 -#define DWC2_HCINTMSK_NYET (1 << 6) -#define DWC2_HCINTMSK_NYET_OFFSET 6 -#define DWC2_HCINTMSK_XACTERR (1 << 7) -#define DWC2_HCINTMSK_XACTERR_OFFSET 7 -#define DWC2_HCINTMSK_BBLERR (1 << 8) -#define DWC2_HCINTMSK_BBLERR_OFFSET 8 -#define DWC2_HCINTMSK_FRMOVRUN (1 << 9) -#define DWC2_HCINTMSK_FRMOVRUN_OFFSET 9 -#define DWC2_HCINTMSK_DATATGLERR (1 << 10) -#define DWC2_HCINTMSK_DATATGLERR_OFFSET 10 -#define DWC2_HCINTMSK_BNA (1 << 11) -#define DWC2_HCINTMSK_BNA_OFFSET 11 -#define DWC2_HCINTMSK_XCS_XACT (1 << 12) -#define DWC2_HCINTMSK_XCS_XACT_OFFSET 12 -#define DWC2_HCINTMSK_FRM_LIST_ROLL (1 << 13) -#define DWC2_HCINTMSK_FRM_LIST_ROLL_OFFSET 13 -#define DWC2_HCTSIZ_XFERSIZE_MASK 0x7ffff -#define DWC2_HCTSIZ_XFERSIZE_OFFSET 0 -#define DWC2_HCTSIZ_SCHINFO_MASK 0xff -#define DWC2_HCTSIZ_SCHINFO_OFFSET 0 -#define DWC2_HCTSIZ_NTD_MASK (0xff << 8) -#define DWC2_HCTSIZ_NTD_OFFSET 8 -#define DWC2_HCTSIZ_PKTCNT_MASK (0x3ff << 19) -#define DWC2_HCTSIZ_PKTCNT_OFFSET 19 -#define DWC2_HCTSIZ_PID_MASK (0x3 << 29) -#define DWC2_HCTSIZ_PID_OFFSET 29 -#define DWC2_HCTSIZ_DOPNG (1 << 31) -#define DWC2_HCTSIZ_DOPNG_OFFSET 31 -#define DWC2_HCDMA_CTD_MASK (0xFF << 3) -#define DWC2_HCDMA_CTD_OFFSET 3 -#define DWC2_HCDMA_DMA_ADDR_MASK (0x1FFFFF << 11) -#define DWC2_HCDMA_DMA_ADDR_OFFSET 11 -#define DWC2_PCGCCTL_STOPPCLK (1 << 0) -#define DWC2_PCGCCTL_STOPPCLK_OFFSET 0 -#define DWC2_PCGCCTL_GATEHCLK (1 << 1) -#define DWC2_PCGCCTL_GATEHCLK_OFFSET 1 -#define DWC2_PCGCCTL_PWRCLMP (1 << 2) -#define DWC2_PCGCCTL_PWRCLMP_OFFSET 2 -#define DWC2_PCGCCTL_RSTPDWNMODULE (1 << 3) -#define DWC2_PCGCCTL_RSTPDWNMODULE_OFFSET 3 -#define DWC2_PCGCCTL_PHYSUSPENDED (1 << 4) -#define DWC2_PCGCCTL_PHYSUSPENDED_OFFSET 4 -#define DWC2_PCGCCTL_ENBL_SLEEP_GATING (1 << 5) -#define DWC2_PCGCCTL_ENBL_SLEEP_GATING_OFFSET 5 -#define DWC2_PCGCCTL_PHY_IN_SLEEP (1 << 6) -#define DWC2_PCGCCTL_PHY_IN_SLEEP_OFFSET 6 -#define DWC2_PCGCCTL_DEEP_SLEEP (1 << 7) -#define DWC2_PCGCCTL_DEEP_SLEEP_OFFSET 7 +#define DWC2_HCCHAR_EPTYPE_MASK GENMASK(19, 18) +#define DWC2_HCCHAR_MULTICNT_MASK GENMASK(21, 20) +#define DWC2_HCCHAR_DEVADDR_MASK GENMASK(28, 22) +#define DWC2_HCCHAR_ODDFRM BIT(29) +#define DWC2_HCCHAR_CHDIS BIT(30) +#define DWC2_HCCHAR_CHEN BIT(31) +#define DWC2_HCSPLT_PRTADDR_MASK GENMASK(6, 0) +#define DWC2_HCSPLT_HUBADDR_MASK GENMASK(13, 7) +#define DWC2_HCSPLT_XACTPOS_MASK GENMASK(15, 14) +#define DWC2_HCSPLT_COMPSPLT BIT(16) +#define DWC2_HCSPLT_SPLTENA BIT(31) +#define DWC2_HCINT_XFERCOMP BIT(0) +#define DWC2_HCINT_CHHLTD BIT(1) +#define DWC2_HCINT_AHBERR BIT(2) +#define DWC2_HCINT_STALL BIT(3) +#define DWC2_HCINT_NAK BIT(4) +#define DWC2_HCINT_ACK BIT(5) +#define DWC2_HCINT_NYET BIT(6) +#define DWC2_HCINT_XACTERR BIT(7) +#define DWC2_HCINT_BBLERR BIT(8) +#define DWC2_HCINT_FRMOVRUN BIT(9) +#define DWC2_HCINT_DATATGLERR BIT(10) +#define DWC2_HCINT_BNA BIT(11) +#define DWC2_HCINT_XCS_XACT BIT(12) +#define DWC2_HCINT_FRM_LIST_ROLL BIT(13) +#define DWC2_HCINTMSK_XFERCOMPL BIT(0) +#define DWC2_HCINTMSK_CHHLTD BIT(1) +#define DWC2_HCINTMSK_AHBERR BIT(2) +#define DWC2_HCINTMSK_STALL BIT(3) +#define DWC2_HCINTMSK_NAK BIT(4) +#define DWC2_HCINTMSK_ACK BIT(5) +#define DWC2_HCINTMSK_NYET BIT(6) +#define DWC2_HCINTMSK_XACTERR BIT(7) +#define DWC2_HCINTMSK_BBLERR BIT(8) +#define DWC2_HCINTMSK_FRMOVRUN BIT(9) +#define DWC2_HCINTMSK_DATATGLERR BIT(10) +#define DWC2_HCINTMSK_BNA BIT(11) +#define DWC2_HCINTMSK_XCS_XACT BIT(12) +#define DWC2_HCINTMSK_FRM_LIST_ROLL BIT(13) +#define DWC2_HCTSIZ_XFERSIZE_MASK GENMASK(18, 0) +#define DWC2_HCTSIZ_SCHINFO_MASK GENMASK(7, 0) +#define DWC2_HCTSIZ_NTD_MASK GENMASK(15, 8) +#define DWC2_HCTSIZ_PKTCNT_MASK GENMASK(28, 19) +#define DWC2_HCTSIZ_PID_MASK GENMASK(30, 29) +#define DWC2_HCTSIZ_DOPNG BIT(31) +#define DWC2_HCDMA_CTD_MASK GENMASK(10, 3) +#define DWC2_HCDMA_DMA_ADDR_MASK GENMASK(31, 11) +#define DWC2_PCGCCTL_STOPPCLK BIT(0) +#define DWC2_PCGCCTL_GATEHCLK BIT(1) +#define DWC2_PCGCCTL_PWRCLMP BIT(2) +#define DWC2_PCGCCTL_RSTPDWNMODULE BIT(3) +#define DWC2_PCGCCTL_PHYSUSPENDED BIT(4) +#define DWC2_PCGCCTL_ENBL_SLEEP_GATING BIT(5) +#define DWC2_PCGCCTL_PHY_IN_SLEEP BIT(6) +#define DWC2_PCGCCTL_DEEP_SLEEP BIT(7) #define DWC2_SNPSID_DEVID_VER_2xx (0x4f542 << 12) #define DWC2_SNPSID_DEVID_VER_3xx (0x4f543 << 12) -#define DWC2_SNPSID_DEVID_MASK (0xfffff << 12) -#define DWC2_SNPSID_DEVID_OFFSET 12 +#define DWC2_SNPSID_DEVID_MASK GENMASK(31, 12)
/* Host controller specific */ #define DWC2_HC_PID_DATA0 0 @@ -692,13 +367,13 @@ #define DWC2_HC_PID_SETUP 3
/* roothub.a masks */ -#define RH_A_NDP (0xff << 0) /* number of downstream ports */ -#define RH_A_PSM (1 << 8) /* power switching mode */ -#define RH_A_NPS (1 << 9) /* no power switching */ -#define RH_A_DT (1 << 10) /* device type (mbz) */ -#define RH_A_OCPM (1 << 11) /* over current protection mode */ -#define RH_A_NOCP (1 << 12) /* no over current protection */ -#define RH_A_POTPGT (0xff << 24) /* power on to power good time */ +#define RH_A_NDP GENMASK(7, 0) /* number of downstream ports */ +#define RH_A_PSM BIT(8) /* power switching mode */ +#define RH_A_NPS BIT(9) /* no power switching */ +#define RH_A_DT BIT(10) /* device type (mbz) */ +#define RH_A_OCPM BIT(11) /* over current protection mode */ +#define RH_A_NOCP BIT(12) /* no over current protection */ +#define RH_A_POTPGT GENMASK(31, 24) /* power on to power good time */
/* roothub.b masks */ #define RH_B_DR 0x0000ffff /* device removable flags */
Update the DWC2 macros to match those used in the Linux kernel, making it easier to synchronize updates with kernel. Also removed some unused macros to cleanup the code.
Signed-off-by: Kongyang Liu seashell11234455@gmail.com Reviewed-by: Marek Vasut marex@denx.de Tested-by: Peter Robinson pbrobinson@gmail.com Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Junhui Liu junhui.liu@pigmoral.tech --- drivers/usb/gadget/dwc2_udc_otg.c | 62 +-- drivers/usb/gadget/dwc2_udc_otg_regs.h | 243 ++++++----- drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c | 130 +++--- drivers/usb/host/dwc2.c | 260 ++++++------ drivers/usb/host/dwc2.h | 638 +++++++++++++---------------- 5 files changed, 632 insertions(+), 701 deletions(-)
diff --git a/drivers/usb/gadget/dwc2_udc_otg.c b/drivers/usb/gadget/dwc2_udc_otg.c index b89f751b8cc08c4f9a7cee4ac829b5a9648e930a..b08ea5ba79a5f1f094a2407687e5f5aad9f3577e 100644 --- a/drivers/usb/gadget/dwc2_udc_otg.c +++ b/drivers/usb/gadget/dwc2_udc_otg.c @@ -160,7 +160,7 @@ struct dwc2_core_regs *reg;
bool dfu_usb_get_reset(void) { - return !!(readl(®->global_regs.gintsts) & INT_RESET); + return !!(readl(®->global_regs.gintsts) & GINTSTS_USBRST); }
__weak void otg_phy_init(struct dwc2_udc *dev) {} @@ -240,8 +240,8 @@ static int udc_enable(struct dwc2_udc *dev)
static int dwc2_gadget_pullup(struct usb_gadget *g, int is_on) { - clrsetbits_le32(®->device_regs.dctl, SOFT_DISCONNECT, - is_on ? 0 : SOFT_DISCONNECT); + clrsetbits_le32(®->device_regs.dctl, DCTL_SFTDISCON, + is_on ? 0 : DCTL_SFTDISCON);
return 0; } @@ -471,7 +471,7 @@ static void reconfig_usbd(struct dwc2_udc *dev) u32 max_hw_ep; int pdata_hw_ep;
- writel(CORE_SOFT_RESET, ®->global_regs.grstctl); + writel(GRSTCTL_CSFTRST, ®->global_regs.grstctl);
debug("Resetting OTG controller\n");
@@ -498,19 +498,20 @@ static void reconfig_usbd(struct dwc2_udc *dev)
/* 3. Put the OTG device core in the disconnected state.*/ uTemp = readl(®->device_regs.dctl); - uTemp |= SOFT_DISCONNECT; + uTemp |= DCTL_SFTDISCON; writel(uTemp, ®->device_regs.dctl);
udelay(20);
/* 4. Make the OTG device core exit from the disconnected state.*/ uTemp = readl(®->device_regs.dctl); - uTemp = uTemp & ~SOFT_DISCONNECT; + uTemp = uTemp & ~DCTL_SFTDISCON; writel(uTemp, ®->device_regs.dctl);
/* 5. Configure OTG Core to initial settings of device mode.*/ /* [][1: full speed(30Mhz) 0:high speed]*/ - writel(EP_MISS_CNT(1) | DEV_SPEED_HIGH_SPEED_20, ®->device_regs.dcfg); + writel(FIELD_PREP(DCFG_EPMISCNT_MASK, 1) | + FIELD_PREP(DCFG_DEVSPD_MASK, DCFG_DEVSPD_HS), ®->device_regs.dcfg);
mdelay(1);
@@ -518,12 +519,12 @@ static void reconfig_usbd(struct dwc2_udc *dev) writel(GINTMSK_INIT, ®->global_regs.gintmsk);
/* 7. Set NAK bit of EP0, EP1, EP2*/ - writel(DEPCTL_EPDIS | DEPCTL_SNAK, ®->device_regs.out_endp[EP0_CON].doepctl); - writel(DEPCTL_EPDIS | DEPCTL_SNAK, ®->device_regs.in_endp[EP0_CON].diepctl); + writel(DXEPCTL_EPDIS | DXEPCTL_SNAK, ®->device_regs.out_endp[EP0_CON].doepctl); + writel(DXEPCTL_EPDIS | DXEPCTL_SNAK, ®->device_regs.in_endp[EP0_CON].diepctl);
for (i = 1; i < DWC2_MAX_ENDPOINTS; i++) { - writel(DEPCTL_EPDIS | DEPCTL_SNAK, ®->device_regs.out_endp[i].doepctl); - writel(DEPCTL_EPDIS | DEPCTL_SNAK, ®->device_regs.in_endp[i].diepctl); + writel(DXEPCTL_EPDIS | DXEPCTL_SNAK, ®->device_regs.out_endp[i].doepctl); + writel(DXEPCTL_EPDIS | DXEPCTL_SNAK, ®->device_regs.in_endp[i].diepctl); }
/* 8. Unmask EPO interrupts*/ @@ -551,12 +552,12 @@ static void reconfig_usbd(struct dwc2_udc *dev) writel(rx_fifo_sz, ®->global_regs.grxfsiz);
/* 12. Set Non Periodic Tx FIFO Size */ - writel((np_tx_fifo_sz << 16) | rx_fifo_sz, + writel(FIELD_PREP(FIFOSIZE_DEPTH_MASK, np_tx_fifo_sz) | + FIELD_PREP(FIFOSIZE_STARTADDR_MASK, rx_fifo_sz), ®->global_regs.gnptxfsiz);
/* retrieve the number of IN Endpoints (excluding ep0) */ - max_hw_ep = (readl(®->global_regs.ghwcfg4) & GHWCFG4_NUM_IN_EPS_MASK) >> - GHWCFG4_NUM_IN_EPS_SHIFT; + max_hw_ep = FIELD_GET(GHWCFG4_NUM_IN_EPS_MASK, readl(®->global_regs.ghwcfg4)); pdata_hw_ep = dev->pdata->tx_fifo_sz_nb;
/* tx_fifo_sz_nb should equal to number of IN Endpoint */ @@ -568,24 +569,27 @@ static void reconfig_usbd(struct dwc2_udc *dev) if (pdata_hw_ep) tx_fifo_sz = dev->pdata->tx_fifo_sz_array[i];
- writel((rx_fifo_sz + np_tx_fifo_sz + (tx_fifo_sz * i)) | - tx_fifo_sz << 16, ®->global_regs.dptxfsizn[i]); + writel(FIELD_PREP(FIFOSIZE_DEPTH_MASK, tx_fifo_sz) | + FIELD_PREP(FIFOSIZE_STARTADDR_MASK, + rx_fifo_sz + np_tx_fifo_sz + tx_fifo_sz * i), + ®->global_regs.dptxfsizn[i]); } /* Flush the RX FIFO */ - writel(RX_FIFO_FLUSH, ®->global_regs.grstctl); - while (readl(®->global_regs.grstctl) & RX_FIFO_FLUSH) + writel(GRSTCTL_RXFFLSH, ®->global_regs.grstctl); + while (readl(®->global_regs.grstctl) & GRSTCTL_RXFFLSH) debug("%s: waiting for DWC2_UDC_OTG_GRSTCTL\n", __func__);
/* Flush all the Tx FIFO's */ - writel(TX_FIFO_FLUSH_ALL, ®->global_regs.grstctl); - writel(TX_FIFO_FLUSH_ALL | TX_FIFO_FLUSH, ®->global_regs.grstctl); - while (readl(®->global_regs.grstctl) & TX_FIFO_FLUSH) + writel(FIELD_PREP(GRSTCTL_TXFNUM_MASK, GRSTCTL_TXFNUM_ALL), ®->global_regs.grstctl); + writel(FIELD_PREP(GRSTCTL_TXFNUM_MASK, GRSTCTL_TXFNUM_ALL) | GRSTCTL_TXFFLSH, + ®->global_regs.grstctl); + while (readl(®->global_regs.grstctl) & GRSTCTL_TXFFLSH) debug("%s: waiting for DWC2_UDC_OTG_GRSTCTL\n", __func__);
/* 13. Clear NAK bit of EP0, EP1, EP2*/ /* For Slave mode*/ /* EP0: Control OUT */ - writel(DEPCTL_EPDIS | DEPCTL_CNAK, + writel(DXEPCTL_EPDIS | DXEPCTL_CNAK, ®->device_regs.out_endp[EP0_CON].doepctl);
/* 14. Initialize OTG Link Core.*/ @@ -1127,8 +1131,8 @@ static int dwc2_udc_otg_probe(struct udevice *dev) if (plat->force_b_session_valid && !plat->force_vbus_detection) { /* Override VBUS detection: enable then value*/ - setbits_le32(&usbotg_reg->global_regs.gotgctl, VB_VALOEN); - setbits_le32(&usbotg_reg->global_regs.gotgctl, VB_VALOVAL); + setbits_le32(&usbotg_reg->global_regs.gotgctl, GOTGCTL_VBVALOEN); + setbits_le32(&usbotg_reg->global_regs.gotgctl, GOTGCTL_VBVALOVAL); } else { /* Enable VBUS sensing */ setbits_le32(&usbotg_reg->global_regs.ggpio, @@ -1137,9 +1141,9 @@ static int dwc2_udc_otg_probe(struct udevice *dev) if (plat->force_b_session_valid) { /* Override B session bits: enable then value */ setbits_le32(&usbotg_reg->global_regs.gotgctl, - A_VALOEN | B_VALOEN); + GOTGCTL_AVALOEN | GOTGCTL_BVALOEN); setbits_le32(&usbotg_reg->global_regs.gotgctl, - A_VALOVAL | B_VALOVAL); + GOTGCTL_AVALOVAL | GOTGCTL_BVALOVAL); } else { /* Enable ID detection */ setbits_le32(&usbotg_reg->global_regs.ggpio, @@ -1205,10 +1209,10 @@ U_BOOT_DRIVER(dwc2_udc_otg) = { int dwc2_udc_B_session_valid(struct udevice *dev) { struct dwc2_plat_otg_data *plat = dev_get_plat(dev); - struct dwc2_usbotg_reg *usbotg_reg = - (struct dwc2_usbotg_reg *)plat->regs_otg; + struct dwc2_core_regs *usbotg_reg = + (struct dwc2_core_regs *)plat->regs_otg;
- return readl(&usbotg_reg->gotgctl) & B_SESSION_VALID; + return readl(&usbotg_reg->global_regs.gotgctl) & GOTGCTL_BSESVLD; } #else int dm_usb_gadget_handle_interrupts(struct udevice *dev) diff --git a/drivers/usb/gadget/dwc2_udc_otg_regs.h b/drivers/usb/gadget/dwc2_udc_otg_regs.h index 34b1c15ea174cc80f04a69bf41ff1819de10ccaa..6aec55970db682ef8a21fad0b47144a4a87a47ca 100644 --- a/drivers/usb/gadget/dwc2_udc_otg_regs.h +++ b/drivers/usb/gadget/dwc2_udc_otg_regs.h @@ -22,54 +22,53 @@ struct dwc2_usbotg_phy { /*definitions related to CSR setting */
/* DWC2_UDC_OTG_GOTGCTL */ -#define B_SESSION_VALID BIT(19) -#define A_SESSION_VALID BIT(18) -#define B_VALOVAL BIT(7) -#define B_VALOEN BIT(6) -#define A_VALOVAL BIT(5) -#define A_VALOEN BIT(4) -#define VB_VALOVAL BIT(3) -#define VB_VALOEN BIT(2) +#define GOTGCTL_BSESVLD BIT(19) +#define GOTGCTL_ASESVLD BIT(18) +#define GOTGCTL_BVALOVAL BIT(7) +#define GOTGCTL_BVALOEN BIT(6) +#define GOTGCTL_AVALOVAL BIT(5) +#define GOTGCTL_AVALOEN BIT(4) +#define GOTGCTL_VBVALOVAL BIT(3) +#define GOTGCTL_VBVALOEN BIT(2)
/* DWC2_UDC_OTG_GOTINT */ #define GOTGINT_SES_END_DET BIT(2)
/* DWC2_UDC_OTG_GAHBCFG */ -#define PTXFE_HALF (0 << 8) -#define PTXFE_ZERO (1 << 8) -#define NPTXFE_HALF (0 << 7) -#define NPTXFE_ZERO (1 << 7) -#define MODE_SLAVE (0 << 5) -#define MODE_DMA (1 << 5) -#define BURST_SINGLE (0 << 1) -#define BURST_INCR (1 << 1) -#define BURST_INCR4 (3 << 1) -#define BURST_INCR8 (5 << 1) -#define BURST_INCR16 (7 << 1) -#define GBL_INT_UNMASK (1 << 0) -#define GBL_INT_MASK (0 << 0) +#define GAHBCFG_AHB_SINGLE BIT(23) +#define GAHBCFG_NOTI_ALL_DMA_WRIT BIT(22) +#define GAHBCFG_REM_MEM_SUPP BIT(21) +#define GAHBCFG_P_TXF_EMP_LVL BIT(8) +#define GAHBCFG_NP_TXF_EMP_LVL BIT(7) +#define GAHBCFG_DMA_EN BIT(5) +#define GAHBCFG_HBSTLEN_MASK GENMASK(4, 1) +#define GAHBCFG_HBSTLEN_SINGLE 0 +#define GAHBCFG_HBSTLEN_INCR 1 +#define GAHBCFG_HBSTLEN_INCR4 3 +#define GAHBCFG_HBSTLEN_INCR8 5 +#define GAHBCFG_HBSTLEN_INCR16 7 +#define GAHBCFG_GLBL_INTR_EN BIT(0)
/* DWC2_UDC_OTG_GRSTCTL */ -#define AHB_MASTER_IDLE BIT(31) -#define CORE_SOFT_RESET BIT(0) +#define GRSTCTL_AHBIDLE BIT(31) +#define GRSTCTL_CSFTRST BIT(0)
/* DWC2_UDC_OTG_GINTSTS/DWC2_UDC_OTG_GINTMSK core interrupt register */ -#define INT_RESUME BIT(31) -#define INT_DISCONN BIT(29) -#define INT_CONN_ID_STS_CNG BIT(28) -#define INT_OUT_EP BIT(19) -#define INT_IN_EP BIT(18) -#define INT_ENUMDONE BIT(13) -#define INT_RESET BIT(12) -#define INT_SUSPEND BIT(11) -#define INT_EARLY_SUSPEND BIT(10) -#define INT_GOUTNakEff BIT(7) -#define INT_GINNakEff BIT(6) -#define INT_NP_TX_FIFO_EMPTY BIT(5) -#define INT_RX_FIFO_NOT_EMPTY BIT(4) -#define INT_SOF BIT(3) -#define INT_OTG BIT(2) -#define INT_HOST_MODE BIT(1) +#define GINTSTS_WKUPINT BIT(31) +#define GINTSTS_DISCONNINT BIT(29) +#define GINTSTS_CONIDSTSCHNG BIT(28) +#define GINTSTS_OEPINT BIT(19) +#define GINTSTS_IEPINT BIT(18) +#define GINTSTS_ENUMDONE BIT(13) +#define GINTSTS_USBRST BIT(12) +#define GINTSTS_USBSUSP BIT(11) +#define GINTSTS_ERLYSUSP BIT(10) +#define GINTSTS_NPTXFEMP BIT(5) +#define GINTSTS_RXFLVL BIT(4) +#define GINTSTS_SOF BIT(3) +#define GINTSTS_OTGINT BIT(2) +#define GINTSTS_MODEMIS BIT(1) +#define GINTSTS_CURMODE_HOST BIT(0)
#define FULL_SPEED_CONTROL_PKT_SIZE 8 #define FULL_SPEED_BULK_PKT_SIZE 64 @@ -81,28 +80,18 @@ struct dwc2_usbotg_phy { #define NPTX_FIFO_SIZE 1024 #define PTX_FIFO_SIZE 384
-#define DEPCTL_TXFNUM_0 (0x0 << 22) -#define DEPCTL_TXFNUM_1 (0x1 << 22) -#define DEPCTL_TXFNUM_2 (0x2 << 22) -#define DEPCTL_TXFNUM_3 (0x3 << 22) -#define DEPCTL_TXFNUM_4 (0x4 << 22) +#define FIFOSIZE_DEPTH_MASK GENMASK(31, 16) +#define FIFOSIZE_STARTADDR_MASK GENMASK(15, 0)
/* Enumeration speed */ -#define USB_HIGH_30_60MHZ (0x0 << 1) -#define USB_FULL_30_60MHZ (0x1 << 1) -#define USB_LOW_6MHZ (0x2 << 1) -#define USB_FULL_48MHZ (0x3 << 1) - -/* DWC2_UDC_OTG_GRXSTSP STATUS */ -#define OUT_PKT_RECEIVED (0x2 << 17) -#define OUT_TRANSFER_COMPLELTED (0x3 << 17) -#define SETUP_TRANSACTION_COMPLETED (0x4 << 17) -#define SETUP_PKT_RECEIVED (0x6 << 17) -#define GLOBAL_OUT_NAK (0x1 << 17) +#define DSTS_ENUMSPD_MASK GENMASK(2, 1) +#define DSTS_ENUMSPD_HS 0 +#define DSTS_ENUMSPD_FS 1 +#define DSTS_ENUMSPD_LS 2
/* DWC2_UDC_OTG_DCTL device control register */ -#define NORMAL_OPERATION BIT(0) -#define SOFT_DISCONNECT BIT(1) +#define DCTL_SFTDISCON BIT(1) +#define DCTL_RMTWKUPSIG BIT(0)
/* DWC2_UDC_OTG_DAINT device all endpoint interrupt register */ #define DAINT_OUTEP_MASK GENMASK(31, 16) @@ -110,44 +99,51 @@ struct dwc2_usbotg_phy {
/* DWC2_UDC_OTG_DIEPCTL0/DOEPCTL0 device control IN/OUT endpoint 0 control register */ -#define DEPCTL_EPENA BIT(31) -#define DEPCTL_EPDIS BIT(30) -#define DEPCTL_SETD1PID BIT(29) -#define DEPCTL_SETD0PID BIT(28) -#define DEPCTL_SNAK BIT(27) -#define DEPCTL_CNAK BIT(26) -#define DEPCTL_STALL BIT(21) -#define DEPCTL_TYPE_MASK GENMASK(19, 18) -#define DEPCTL_CTRL_TYPE (0x0 << 18) -#define DEPCTL_ISO_TYPE (0x1 << 18) -#define DEPCTL_BULK_TYPE (0x2 << 18) -#define DEPCTL_INTR_TYPE (0x3 << 18) -#define DEPCTL_USBACTEP BIT(15) -#define DEPCTL_NEXT_EP_MASK GENMASK(14, 11) -#define DEPCTL_MPS_MASK GENMASK(10, 0) - -#define DEPCTL0_MPS_64 (0x0 << 0) -#define DEPCTL0_MPS_32 (0x1 << 0) -#define DEPCTL0_MPS_16 (0x2 << 0) -#define DEPCTL0_MPS_8 (0x3 << 0) -#define DEPCTL_MPS_BULK_512 (512 << 0) -#define DEPCTL_MPS_INT_MPS_16 (16 << 0) - -#define DIEPCTL0_NEXT_EP_BIT (11) +#define DXEPCTL_EPENA BIT(31) +#define DXEPCTL_EPDIS BIT(30) +#define DXEPCTL_SETD1PID BIT(29) +#define DXEPCTL_SETODDFR BIT(29) +#define DXEPCTL_SETD0PID BIT(28) +#define DXEPCTL_SETEVENFR BIT(28) +#define DXEPCTL_SNAK BIT(27) +#define DXEPCTL_CNAK BIT(26) +#define DXEPCTL_STALL BIT(21) +#define DXEPCTL_EPTYPE_MASK GENMASK(19, 18) +#define DXEPCTL_EPTYPE_CONTROL 0 +#define DXEPCTL_EPTYPE_ISO 1 +#define DXEPCTL_EPTYPE_BULK 2 +#define DXEPCTL_EPTYPE_INTERRUPT 3 +#define DXEPCTL_EOFRNUM BIT(16) +#define DXEPCTL_USBACTEP BIT(15) +#define DXEPCTL_NEXTEP_MASK GENMASK(14, 11) +#define DXEPCTL_MPS_MASK GENMASK(10, 0) +
/* DWC2_UDC_OTG_DIEPMSK/DOEPMSK device IN/OUT endpoint common interrupt mask register */ /* DWC2_UDC_OTG_DIEPINTn/DOEPINTn device IN/OUT endpoint interrupt register */ -#define BACK2BACK_SETUP_RECEIVED BIT(6) -#define INTKNEPMIS BIT(5) -#define INTKN_TXFEMP BIT(4) -#define NON_ISO_IN_EP_TIMEOUT BIT(3) -#define CTRL_OUT_EP_SETUP_PHASE_DONE BIT(3) -#define AHB_ERROR BIT(2) -#define EPDISBLD BIT(1) -#define TRANSFER_DONE BIT(0) - -#define USB_PHY_CTRL_EN0 BIT(0) +#define DIEPMSK_NAKMSK BIT(13) +#define DIEPMSK_BNAININTRMSK BIT(9) +#define DIEPMSK_TXFIFOUNDRNMSK BIT(8) +#define DIEPMSK_TXFIFOEMPTY BIT(7) +#define DIEPMSK_INEPNAKEFFMSK BIT(6) +#define DIEPMSK_INTKNEPMISMSK BIT(5) +#define DIEPMSK_INTKNTXFEMPMSK BIT(4) +#define DIEPMSK_TIMEOUTMSK BIT(3) +#define DIEPMSK_AHBERRMSK BIT(2) +#define DIEPMSK_EPDISBLDMSK BIT(1) +#define DIEPMSK_XFERCOMPLMSK BIT(0) + +#define DOEPMSK_BNAMSK BIT(9) +#define DOEPMSK_BACK2BACKSETUP BIT(6) +#define DOEPMSK_STSPHSERCVDMSK BIT(5) +#define DOEPMSK_OUTTKNEPDISMSK BIT(4) +#define DOEPMSK_SETUPMSK BIT(3) +#define DOEPMSK_AHBERRMSK BIT(2) +#define DOEPMSK_EPDISBLDMSK BIT(1) +#define DOEPMSK_XFERCOMPLMSK BIT(0) + +#define USB_PHY_CTRL_EN0 BIT(0)
/* OPHYPWR */ #define PHY_0_SLEEP BIT(5) @@ -176,47 +172,46 @@ struct dwc2_usbotg_phy { #define EXYNOS4X12_CLK_SEL_24MHZ (0x05 << 0)
/* Device Configuration Register DCFG */ -#define DEV_SPEED_HIGH_SPEED_20 (0x0 << 0) -#define DEV_SPEED_FULL_SPEED_20 (0x1 << 0) -#define DEV_SPEED_LOW_SPEED_11 (0x2 << 0) -#define DEV_SPEED_FULL_SPEED_11 (0x3 << 0) -#define EP_MISS_CNT(x) ((x) << 18) -#define DEVICE_ADDRESS(x) ((x) << 4) +#define DCFG_EPMISCNT_MASK GENMASK(22, 18) +#define DCFG_DEVADDR_MASK GENMASK(10, 4) +#define DCFG_DEVSPD_MASK GENMASK(1, 0) +#define DCFG_DEVSPD_HS 0 +#define DCFG_DEVSPD_FS 1 +#define DCFG_DEVSPD_LS 2 +#define DCFG_DEVSPD_FS48 3
/* Core Reset Register (GRSTCTL) */ -#define TX_FIFO_FLUSH BIT(5) -#define RX_FIFO_FLUSH BIT(4) -#define TX_FIFO_NUMBER(x) ((x) << 6) -#define TX_FIFO_FLUSH_ALL TX_FIFO_NUMBER(0x10) +#define GRSTCTL_TXFNUM_MASK GENMASK(10, 6) +#define GRSTCTL_TXFFLSH BIT(5) +#define GRSTCTL_RXFFLSH BIT(4) +#define GRSTCTL_TXFNUM_ALL 0x10
/* Masks definitions */ -#define GINTMSK_INIT (INT_OUT_EP | INT_IN_EP | INT_RESUME | INT_ENUMDONE\ - | INT_RESET | INT_SUSPEND | INT_OTG) -#define DOEPMSK_INIT (CTRL_OUT_EP_SETUP_PHASE_DONE | AHB_ERROR|TRANSFER_DONE) -#define DIEPMSK_INIT (NON_ISO_IN_EP_TIMEOUT|AHB_ERROR|TRANSFER_DONE) -#define GAHBCFG_INIT (PTXFE_HALF | NPTXFE_HALF | MODE_DMA | BURST_INCR4\ - | GBL_INT_UNMASK) - -/* Device Endpoint X Transfer Size Register (DIEPTSIZX) */ -#define DIEPT_SIZ_PKT_CNT(x) ((x) << 19) -#define DIEPT_SIZ_XFER_SIZE(x) ((x) << 0) - -/* Device OUT Endpoint X Transfer Size Register (DOEPTSIZX) */ -#define DOEPT_SIZ_PKT_CNT(x) ((x) << 19) -#define DOEPT_SIZ_XFER_SIZE(x) ((x) << 0) -#define DOEPT_SIZ_XFER_SIZE_MAX_EP0 (0x7F << 0) -#define DOEPT_SIZ_XFER_SIZE_MAX_EP (0x7FFF << 0) +#define GINTMSK_INIT (GINTSTS_WKUPINT | GINTSTS_OEPINT | GINTSTS_IEPINT | GINTSTS_ENUMDONE | \ + GINTSTS_USBRST | GINTSTS_USBSUSP | GINTSTS_OTGINT) +#define DOEPMSK_INIT (DOEPMSK_SETUPMSK | DOEPMSK_AHBERRMSK | DOEPMSK_XFERCOMPLMSK) +#define DIEPMSK_INIT (DIEPMSK_TIMEOUTMSK | DIEPMSK_AHBERRMSK | DIEPMSK_XFERCOMPLMSK) +#define GAHBCFG_INIT (GAHBCFG_DMA_EN | \ + FIELD_PREP(GAHBCFG_HBSTLEN_MASK, GAHBCFG_HBSTLEN_INCR4) | \ + GAHBCFG_GLBL_INTR_EN) + +/* Device Endpoint X Transfer Size Register (DIEPTSIZX/DOEPTSIZX) */ +#define DIEPTSIZ0_PKTCNT_MASK GENMASK(20, 19) +#define DIEPTSIZ0_XFERSIZE_MASK GENMASK(6, 0) + +#define DOEPTSIZ0_SUPCNT_MASK GENMASK(30, 29) +#define DOEPTSIZ0_PKTCNT BIT(19) +#define DOEPTSIZ0_XFERSIZE_MASK GENMASK(6, 0) + +#define DXEPTSIZ_MC_MASK GENMASK(30, 29) +#define DXEPTSIZ_PKTCNT_MASK GENMASK(28, 19) +#define DXEPTSIZ_XFERSIZE_MASK GENMASK(18, 0)
/* Device Endpoint-N Control Register (DIEPCTLn/DOEPCTLn) */ -#define DIEPCTL_TX_FIFO_NUM_MASK GENMASK(25, 22) - -/* Device ALL Endpoints Interrupt Register (DAINT) */ -#define DAINT_IN_EP_INT(x) ((x) << 0) -#define DAINT_OUT_EP_INT(x) ((x) << 16) +#define DXEPCTL_TXFNUM_MASK GENMASK(25, 22)
/* User HW Config4 */ -#define GHWCFG4_NUM_IN_EPS_MASK (0xf << 26) -#define GHWCFG4_NUM_IN_EPS_SHIFT 26 +#define GHWCFG4_NUM_IN_EPS_MASK GENMASK(29, 26)
/* OTG general core configuration register (OTG_GCCFG:0x38) for STM32MP1 */ #define GGPIO_STM32_OTG_GCCFG_VBDEN BIT(21) diff --git a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c index ceefae1b1d1e42ed4ea73406e47621a2214c3b86..64d2fe7bbde4494b4cbcdf57032b720901fdd4eb 100644 --- a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c +++ b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c @@ -35,10 +35,10 @@ static inline void dwc2_udc_ep0_zlp(struct dwc2_udc *dev)
writel(phys_to_bus((unsigned long)usb_ctrl_dma_addr), ®->device_regs.in_endp[EP0_CON].diepdma); - writel(DIEPT_SIZ_PKT_CNT(1), ®->device_regs.in_endp[EP0_CON].dieptsiz); + writel(FIELD_PREP(DXEPTSIZ_PKTCNT_MASK, 1), ®->device_regs.in_endp[EP0_CON].dieptsiz);
ep_ctrl = readl(®->device_regs.in_endp[EP0_CON].diepctl); - writel(ep_ctrl | DEPCTL_EPENA | DEPCTL_CNAK, + writel(ep_ctrl | DXEPCTL_EPENA | DXEPCTL_CNAK, ®->device_regs.in_endp[EP0_CON].diepctl);
debug_cond(DEBUG_EP0 != 0, "%s:EP0 ZLP DIEPCTL0 = 0x%x\n", @@ -53,13 +53,13 @@ static void dwc2_udc_pre_setup(void) debug_cond(DEBUG_IN_EP, "%s : Prepare Setup packets.\n", __func__);
- writel(DOEPT_SIZ_PKT_CNT(1) | sizeof(struct usb_ctrlrequest), + writel(FIELD_PREP(DXEPTSIZ_PKTCNT_MASK, 1) | sizeof(struct usb_ctrlrequest), ®->device_regs.out_endp[EP0_CON].doeptsiz); writel(phys_to_bus((unsigned long)usb_ctrl_dma_addr), ®->device_regs.out_endp[EP0_CON].doepdma);
ep_ctrl = readl(®->device_regs.out_endp[EP0_CON].doepctl); - writel(ep_ctrl | DEPCTL_EPENA, ®->device_regs.out_endp[EP0_CON].doepctl); + writel(ep_ctrl | DXEPCTL_EPENA, ®->device_regs.out_endp[EP0_CON].doepctl);
debug_cond(DEBUG_EP0 != 0, "%s:EP0 ZLP DIEPCTL0 = 0x%x\n", __func__, readl(®->device_regs.in_endp[EP0_CON].diepctl)); @@ -80,13 +80,13 @@ static inline void dwc2_ep0_complete_out(void) debug_cond(DEBUG_IN_EP, "%s : Prepare Complete Out packet.\n", __func__);
ep_ctrl = readl(®->device_regs.out_endp[EP0_CON].doepctl); - writel(ep_ctrl | DEPCTL_EPENA | DEPCTL_CNAK, + writel(ep_ctrl | DXEPCTL_EPENA | DXEPCTL_CNAK, ®->device_regs.out_endp[EP0_CON].doepctl);
debug_cond(DEBUG_EP0 != 0, "%s:EP0 ZLP DIEPCTL0 = 0x%x\n", @@ -121,9 +121,10 @@ static int setdma_rx(struct dwc2_ep *ep, struct dwc2_request *req) ROUND(ep->len, CONFIG_SYS_CACHELINE_SIZE));
writel(phys_to_bus((unsigned long)ep->dma_buf), ®->device_regs.out_endp[ep_num].doepdma); - writel(DOEPT_SIZ_PKT_CNT(pktcnt) | DOEPT_SIZ_XFER_SIZE(length), + writel(FIELD_PREP(DXEPTSIZ_PKTCNT_MASK, pktcnt) | + FIELD_PREP(DXEPTSIZ_XFERSIZE_MASK, length), ®->device_regs.out_endp[ep_num].doeptsiz); - writel(DEPCTL_EPENA | DEPCTL_CNAK | ctrl, ®->device_regs.out_endp[ep_num].doepctl); + writel(DXEPCTL_EPENA | DXEPCTL_CNAK | ctrl, ®->device_regs.out_endp[ep_num].doepctl);
debug_cond(DEBUG_OUT_EP != 0, "%s: EP%d RX DMA start : DOEPDMA = 0x%x," @@ -163,25 +164,27 @@ static int setdma_tx(struct dwc2_ep *ep, struct dwc2_request *req) pktcnt = (length - 1)/(ep->ep.maxpacket) + 1;
/* Flush the endpoint's Tx FIFO */ - writel(TX_FIFO_NUMBER(ep->fifo_num), ®->global_regs.grstctl); - writel(TX_FIFO_NUMBER(ep->fifo_num) | TX_FIFO_FLUSH, ®->global_regs.grstctl); - while (readl(®->global_regs.grstctl) & TX_FIFO_FLUSH) + writel(FIELD_PREP(GRSTCTL_TXFNUM_MASK, ep->fifo_num), ®->global_regs.grstctl); + writel(FIELD_PREP(GRSTCTL_TXFNUM_MASK, ep->fifo_num) | GRSTCTL_TXFFLSH, + ®->global_regs.grstctl); + while (readl(®->global_regs.grstctl) & GRSTCTL_TXFFLSH) ;
writel(phys_to_bus((unsigned long)ep->dma_buf), ®->device_regs.in_endp[ep_num].diepdma); - writel(DIEPT_SIZ_PKT_CNT(pktcnt) | DIEPT_SIZ_XFER_SIZE(length), + writel(FIELD_PREP(DXEPTSIZ_PKTCNT_MASK, pktcnt) | + FIELD_PREP(DXEPTSIZ_XFERSIZE_MASK, length), ®->device_regs.in_endp[ep_num].dieptsiz);
ctrl = readl(®->device_regs.in_endp[ep_num].diepctl);
/* Write the FIFO number to be used for this endpoint */ - ctrl &= ~DIEPCTL_TX_FIFO_NUM_MASK; - ctrl |= FIELD_PREP(DIEPCTL_TX_FIFO_NUM_MASK, ep->fifo_num); + ctrl &= ~DXEPCTL_TXFNUM_MASK; + ctrl |= FIELD_PREP(DXEPCTL_TXFNUM_MASK, ep->fifo_num);
/* Clear reserved (Next EP) bits */ - ctrl &= ~DEPCTL_NEXT_EP_MASK; + ctrl &= ~DXEPCTL_NEXTEP_MASK;
- writel(DEPCTL_EPENA | DEPCTL_CNAK | ctrl, ®->device_regs.in_endp[ep_num].diepctl); + writel(DXEPCTL_EPENA | DXEPCTL_CNAK | ctrl, ®->device_regs.in_endp[ep_num].diepctl);
debug_cond(DEBUG_IN_EP, "%s:EP%d TX DMA start : DIEPDMA0 = 0x%x," @@ -214,9 +217,9 @@ static void complete_rx(struct dwc2_udc *dev, u8 ep_num) ep_tsr = readl(®->device_regs.out_endp[ep_num].doeptsiz);
if (ep_num == EP0_CON) - xfer_size = (ep_tsr & DOEPT_SIZ_XFER_SIZE_MAX_EP0); + xfer_size = FIELD_PREP(DIEPTSIZ0_XFERSIZE_MASK, ep_tsr); else - xfer_size = (ep_tsr & DOEPT_SIZ_XFER_SIZE_MAX_EP); + xfer_size = FIELD_PREP(DXEPTSIZ_XFERSIZE_MASK, ep_tsr);
xfer_size = ep->len - xfer_size;
@@ -384,7 +387,7 @@ static void process_ep_in_intr(struct dwc2_udc *dev) ep_intr = FIELD_GET(DAINT_INEP_MASK, ep_intr);
while (ep_intr) { - if (ep_intr & DAINT_IN_EP_INT(1)) { + if (ep_intr & BIT(EP0_CON)) { ep_intr_status = readl(®->device_regs.in_endp[ep_num].diepint); debug_cond(DEBUG_IN_EP, "\tEP%d-IN : DIEPINT = 0x%x\n", @@ -393,7 +396,7 @@ static void process_ep_in_intr(struct dwc2_udc *dev) /* Interrupt Clear */ writel(ep_intr_status, ®->device_regs.in_endp[ep_num].diepint);
- if (ep_intr_status & TRANSFER_DONE) { + if (ep_intr_status & DIEPMSK_XFERCOMPLMSK) { complete_tx(dev, ep_num);
if (ep_num == 0) { @@ -445,10 +448,9 @@ static void process_ep_out_intr(struct dwc2_udc *dev) writel(ep_intr_status, ®->device_regs.out_endp[ep_num].doepint);
if (ep_num == 0) { - if (ep_intr_status & TRANSFER_DONE) { + if (ep_intr_status & DOEPMSK_XFERCOMPLMSK) { ep_tsr = readl(&epsiz_reg); - xfer_size = ep_tsr & - DOEPT_SIZ_XFER_SIZE_MAX_EP0; + xfer_size = ep_tsr & DOEPTSIZ0_XFERSIZE_MASK;
if (xfer_size == req_size && dev->ep0state == WAIT_FOR_SETUP) { @@ -462,14 +464,13 @@ static void process_ep_out_intr(struct dwc2_udc *dev) } }
- if (ep_intr_status & - CTRL_OUT_EP_SETUP_PHASE_DONE) { + if (ep_intr_status & DOEPMSK_SETUPMSK) { debug_cond(DEBUG_OUT_EP != 0, "SETUP packet arrived\n"); dwc2_handle_ep0(dev); } } else { - if (ep_intr_status & TRANSFER_DONE) + if (ep_intr_status & DOEPMSK_XFERCOMPLMSK) complete_rx(dev, ep_num); } } @@ -504,13 +505,13 @@ static int dwc2_udc_irq(int irq, void *_dev) return IRQ_HANDLED; }
- if (intr_status & INT_ENUMDONE) { + if (intr_status & GINTSTS_ENUMDONE) { debug_cond(DEBUG_ISR, "\tSpeed Detection interrupt\n");
- writel(INT_ENUMDONE, ®->global_regs.gintsts); - usb_status = (readl(®->device_regs.dsts) & 0x6); + writel(GINTSTS_ENUMDONE, ®->global_regs.gintsts); + usb_status = FIELD_GET(DSTS_ENUMSPD_MASK, readl(®->device_regs.dsts));
- if (usb_status & (USB_FULL_30_60MHZ | USB_FULL_48MHZ)) { + if (usb_status != DSTS_ENUMSPD_HS) { debug_cond(DEBUG_ISR, "\t\tFull Speed Detection\n"); set_max_pktsize(dev, USB_SPEED_FULL); @@ -523,16 +524,16 @@ static int dwc2_udc_irq(int irq, void *_dev) } }
- if (intr_status & INT_EARLY_SUSPEND) { + if (intr_status & GINTSTS_ERLYSUSP) { debug_cond(DEBUG_ISR, "\tEarly suspend interrupt\n"); - writel(INT_EARLY_SUSPEND, ®->global_regs.gintsts); + writel(GINTSTS_ERLYSUSP, ®->global_regs.gintsts); }
- if (intr_status & INT_SUSPEND) { + if (intr_status & GINTSTS_USBSUSP) { usb_status = readl(®->device_regs.dsts); debug_cond(DEBUG_ISR, "\tSuspend interrupt :(DSTS):0x%x\n", usb_status); - writel(INT_SUSPEND, ®->global_regs.gintsts); + writel(GINTSTS_USBSUSP, ®->global_regs.gintsts);
if (dev->gadget.speed != USB_SPEED_UNKNOWN && dev->driver) { @@ -541,7 +542,7 @@ static int dwc2_udc_irq(int irq, void *_dev) } }
- if (intr_status & INT_OTG) { + if (intr_status & GINTSTS_OTGINT) { gotgint = readl(®->global_regs.gotgint); debug_cond(DEBUG_ISR, "\tOTG interrupt: (GOTGINT):0x%x\n", gotgint); @@ -558,9 +559,9 @@ static int dwc2_udc_irq(int irq, void *_dev) writel(gotgint, ®->global_regs.gotgint); }
- if (intr_status & INT_RESUME) { + if (intr_status & GINTSTS_WKUPINT) { debug_cond(DEBUG_ISR, "\tResume interrupt\n"); - writel(INT_RESUME, ®->global_regs.gintsts); + writel(GINTSTS_WKUPINT, ®->global_regs.gintsts);
if (dev->gadget.speed != USB_SPEED_UNKNOWN && dev->driver @@ -570,13 +571,13 @@ static int dwc2_udc_irq(int irq, void *_dev) } }
- if (intr_status & INT_RESET) { + if (intr_status & GINTSTS_USBRST) { usb_status = readl(®->global_regs.gotgctl); debug_cond(DEBUG_ISR, "\tReset interrupt - (GOTGCTL):0x%x\n", usb_status); - writel(INT_RESET, ®->global_regs.gintsts); + writel(GINTSTS_USBRST, ®->global_regs.gintsts);
- if ((usb_status & 0xc0000) == (0x3 << 18)) { + if (usb_status & (GOTGCTL_ASESVLD | GOTGCTL_BSESVLD)) { if (reset_available) { debug_cond(DEBUG_ISR, "\t\tOTG core got reset (%d)!!\n", @@ -595,10 +596,10 @@ static int dwc2_udc_irq(int irq, void *_dev) } }
- if (intr_status & INT_IN_EP) + if (intr_status & GINTSTS_IEPINT) process_ep_in_intr(dev);
- if (intr_status & INT_OUT_EP) + if (intr_status & GINTSTS_OEPINT) process_ep_out_intr(dev);
spin_unlock_irqrestore(&dev->lock, flags); @@ -770,7 +771,8 @@ static int dwc2_fifo_read(struct dwc2_ep *ep, void *cp, int max) static void udc_set_address(struct dwc2_udc *dev, unsigned char address) { u32 ctrl = readl(®->device_regs.dcfg); - writel(DEVICE_ADDRESS(address) | ctrl, ®->device_regs.dcfg); + + writel(FIELD_PREP(DCFG_DEVADDR_MASK, address) | ctrl, ®->device_regs.dcfg);
dwc2_udc_ep0_zlp(dev);
@@ -790,10 +792,10 @@ static inline void dwc2_udc_ep0_set_stall(struct dwc2_ep *ep) ep_ctrl = readl(®->device_regs.in_endp[EP0_CON].diepctl);
/* set the disable and stall bits */ - if (ep_ctrl & DEPCTL_EPENA) - ep_ctrl |= DEPCTL_EPDIS; + if (ep_ctrl & DXEPCTL_EPENA) + ep_ctrl |= DXEPCTL_EPDIS;
- ep_ctrl |= DEPCTL_STALL; + ep_ctrl |= DXEPCTL_STALL;
writel(ep_ctrl, ®->device_regs.in_endp[EP0_CON].diepctl);
@@ -939,11 +941,11 @@ static int dwc2_udc_get_status(struct dwc2_udc *dev, ROUND(sizeof(g_status), CONFIG_SYS_CACHELINE_SIZE));
writel(phys_to_bus(usb_ctrl_dma_addr), ®->device_regs.in_endp[EP0_CON].diepdma); - writel(DIEPT_SIZ_PKT_CNT(1) | DIEPT_SIZ_XFER_SIZE(2), + writel(FIELD_PREP(DXEPTSIZ_PKTCNT_MASK, 1) | FIELD_PREP(DXEPTSIZ_XFERSIZE_MASK, 2), ®->device_regs.in_endp[EP0_CON].dieptsiz);
ep_ctrl = readl(®->device_regs.in_endp[EP0_CON].diepctl); - writel(ep_ctrl | DEPCTL_EPENA | DEPCTL_CNAK, + writel(ep_ctrl | DXEPCTL_EPENA | DXEPCTL_CNAK, ®->device_regs.in_endp[EP0_CON].diepctl); dev->ep0state = WAIT_FOR_NULL_COMPLETE;
@@ -960,13 +962,13 @@ static void dwc2_udc_set_nak(struct dwc2_ep *ep)
if (ep_is_in(ep)) { ep_ctrl = readl(®->device_regs.in_endp[ep_num].diepctl); - ep_ctrl |= DEPCTL_SNAK; + ep_ctrl |= DXEPCTL_SNAK; writel(ep_ctrl, ®->device_regs.in_endp[ep_num].diepctl); debug("%s: set NAK, DIEPCTL%d = 0x%x\n", __func__, ep_num, readl(®->device_regs.in_endp[ep_num].diepctl)); } else { ep_ctrl = readl(®->device_regs.out_endp[ep_num].doepctl); - ep_ctrl |= DEPCTL_SNAK; + ep_ctrl |= DXEPCTL_SNAK; writel(ep_ctrl, ®->device_regs.out_endp[ep_num].doepctl); debug("%s: set NAK, DOEPCTL%d = 0x%x\n", __func__, ep_num, readl(®->device_regs.out_endp[ep_num].doepctl)); @@ -987,10 +989,10 @@ static void dwc2_udc_ep_set_stall(struct dwc2_ep *ep) ep_ctrl = readl(®->device_regs.in_endp[ep_num].diepctl);
writel(ep_ctrl, ®->device_regs.in_endp[ep_num].diepctl); debug("%s: set stall, DIEPCTL%d = 0x%x\n", @@ -1000,7 +1002,7 @@ static void dwc2_udc_ep_set_stall(struct dwc2_ep *ep) ep_ctrl = readl(®->device_regs.out_endp[ep_num].doepctl);
/* set the stall bit */ - ep_ctrl |= DEPCTL_STALL; + ep_ctrl |= DXEPCTL_STALL;
writel(ep_ctrl, ®->device_regs.out_endp[ep_num].doepctl); debug("%s: set stall, DOEPCTL%d = 0x%x\n", @@ -1022,7 +1024,7 @@ static void dwc2_udc_ep_clear_stall(struct dwc2_ep *ep) ep_ctrl = readl(®->device_regs.in_endp[ep_num].diepctl);
/* clear stall bit */ - ep_ctrl &= ~DEPCTL_STALL; + ep_ctrl &= ~DXEPCTL_STALL;
/* * USB Spec 9.4.5: For endpoints using data toggle, regardless @@ -1032,7 +1034,7 @@ static void dwc2_udc_ep_clear_stall(struct dwc2_ep *ep) */ if (ep->bmAttributes == USB_ENDPOINT_XFER_INT || ep->bmAttributes == USB_ENDPOINT_XFER_BULK) { - ep_ctrl |= DEPCTL_SETD0PID; /* DATA0 */ + ep_ctrl |= DXEPCTL_SETD0PID; /* DATA0 */ }
writel(ep_ctrl, ®->device_regs.in_endp[ep_num].diepctl); @@ -1043,11 +1045,11 @@ static void dwc2_udc_ep_clear_stall(struct dwc2_ep *ep) ep_ctrl = readl(®->device_regs.out_endp[ep_num].doepctl);
writel(ep_ctrl, ®->device_regs.out_endp[ep_num].doepctl); @@ -1126,12 +1128,12 @@ static void dwc2_udc_ep_activate(struct dwc2_ep *ep)
/* If the EP is already active don't change the EP Control * register. */ - if (!(ep_ctrl & DEPCTL_USBACTEP)) { - ep_ctrl = (ep_ctrl & ~DEPCTL_TYPE_MASK) | - FIELD_PREP(DEPCTL_TYPE_MASK, ep->bmAttributes); - ep_ctrl = (ep_ctrl & ~DEPCTL_MPS_MASK) | - FIELD_PREP(DEPCTL_MPS_MASK, ep->ep.maxpacket); - ep_ctrl |= (DEPCTL_SETD0PID | DEPCTL_USBACTEP | DEPCTL_SNAK); + if (!(ep_ctrl & DXEPCTL_USBACTEP)) { + ep_ctrl = (ep_ctrl & ~DXEPCTL_EPTYPE_MASK) | + FIELD_PREP(DXEPCTL_EPTYPE_MASK, ep->bmAttributes); + ep_ctrl = (ep_ctrl & ~DXEPCTL_MPS_MASK) | + FIELD_PREP(DXEPCTL_MPS_MASK, ep->ep.maxpacket); + ep_ctrl |= (DXEPCTL_SETD0PID | DXEPCTL_USBACTEP | DXEPCTL_SNAK);
if (ep_is_in(ep)) { writel(ep_ctrl, ®->device_regs.in_endp[ep_num].diepctl); diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index d4245b9cb71c91adc658668dcf897bcb10366b73..ff7885f8195c0bc08669dd99ef6c94992c991945 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -88,10 +88,10 @@ static void init_fslspclksel(struct dwc2_core_regs *regs) uint32_t phyclk;
#if (DWC2_PHY_TYPE == DWC2_PHY_TYPE_FS) - phyclk = DWC2_HCFG_FSLSPCLKSEL_48_MHZ; /* Full speed PHY */ + phyclk = HCFG_FSLSPCLKSEL_48_MHZ; /* Full speed PHY */ #else /* High speed PHY running at full speed or high speed */ - phyclk = DWC2_HCFG_FSLSPCLKSEL_30_60_MHZ; + phyclk = HCFG_FSLSPCLKSEL_30_60_MHZ; #endif
#ifdef DWC2_ULPI_FS_LS @@ -99,13 +99,13 @@ static void init_fslspclksel(struct dwc2_core_regs *regs) uint32_t hval = FIELD_GET(GHWCFG2_HS_PHY_TYPE_MASK, ghwcfg2); uint32_t fval = FIELD_GET(GHWCFG2_FS_PHY_TYPE_MASK, ghwcfg2);
- if (hval == 2 && fval == 1) - phyclk = DWC2_HCFG_FSLSPCLKSEL_48_MHZ; /* Full speed PHY */ + if (hval == GHWCFG2_FS_PHY_TYPE_SHARED_UTMI && fval == GHWCFG2_HS_PHY_TYPE_UTMI) + phyclk = HCFG_FSLSPCLKSEL_48_MHZ; /* Full speed PHY */ #endif
clrsetbits_le32(®s->host_regs.hcfg, - DWC2_HCFG_FSLSPCLKSEL_MASK, - FIELD_PREP(DWC2_HCFG_FSLSPCLKSEL_MASK, phyclk)); + HCFG_FSLSPCLKSEL_MASK, + FIELD_PREP(HCFG_FSLSPCLKSEL_MASK, phyclk)); }
/* @@ -119,9 +119,9 @@ static void dwc_otg_flush_tx_fifo(struct udevice *dev, { int ret;
- writel(DWC2_GRSTCTL_TXFFLSH | FIELD_PREP(DWC2_GRSTCTL_TXFNUM_MASK, num), + writel(GRSTCTL_TXFFLSH | FIELD_PREP(GRSTCTL_TXFNUM_MASK, num), ®s->global_regs.grstctl); - ret = wait_for_bit_le32(®s->global_regs.grstctl, DWC2_GRSTCTL_TXFFLSH, + ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_TXFFLSH, false, 1000, false); if (ret) dev_info(dev, "%s: Timeout!\n", __func__); @@ -140,8 +140,8 @@ static void dwc_otg_flush_rx_fifo(struct udevice *dev, { int ret;
- writel(DWC2_GRSTCTL_RXFFLSH, ®s->global_regs.grstctl); - ret = wait_for_bit_le32(®s->global_regs.grstctl, DWC2_GRSTCTL_RXFFLSH, + writel(GRSTCTL_RXFFLSH, ®s->global_regs.grstctl); + ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_RXFFLSH, false, 1000, false); if (ret) dev_info(dev, "%s: Timeout!\n", __func__); @@ -160,14 +160,14 @@ static void dwc_otg_core_reset(struct udevice *dev, int ret;
/* Wait for AHB master IDLE state. */ - ret = wait_for_bit_le32(®s->global_regs.grstctl, DWC2_GRSTCTL_AHBIDLE, + ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_AHBIDLE, true, 1000, false); if (ret) dev_info(dev, "%s: Timeout!\n", __func__);
/* Core Soft Reset */ - writel(DWC2_GRSTCTL_CSFTRST, ®s->global_regs.grstctl); - ret = wait_for_bit_le32(®s->global_regs.grstctl, DWC2_GRSTCTL_CSFTRST, + writel(GRSTCTL_CSFTRST, ®s->global_regs.grstctl); + ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_CSFTRST, false, 1000, false); if (ret) dev_info(dev, "%s: Timeout!\n", __func__); @@ -255,60 +255,58 @@ static void dwc_otg_core_host_init(struct udevice *dev, /* Initialize Host Configuration Register */ init_fslspclksel(regs); #ifdef DWC2_DFLT_SPEED_FULL - setbits_le32(®s->host_regs.hcfg, DWC2_HCFG_FSLSSUPP); + setbits_le32(®s->host_regs.hcfg, HCFG_FSLSSUPP); #endif
/* Configure data FIFO sizes */ #ifdef DWC2_ENABLE_DYNAMIC_FIFO - if (readl(®s->global_regs.ghwcfg2) & DWC2_HWCFG2_DYNAMIC_FIFO) { + if (readl(®s->global_regs.ghwcfg2) & GHWCFG2_DYNAMIC_FIFO) { /* Rx FIFO */ writel(DWC2_HOST_RX_FIFO_SIZE, ®s->global_regs.grxfsiz);
/* Non-periodic Tx FIFO */ - nptxfifosize |= FIELD_PREP(DWC2_FIFOSIZE_DEPTH_MASK, DWC2_HOST_NPERIO_TX_FIFO_SIZE); - nptxfifosize |= FIELD_PREP(DWC2_FIFOSIZE_STARTADDR_MASK, DWC2_HOST_RX_FIFO_SIZE); + nptxfifosize |= FIELD_PREP(FIFOSIZE_DEPTH_MASK, DWC2_HOST_NPERIO_TX_FIFO_SIZE); + nptxfifosize |= FIELD_PREP(FIFOSIZE_STARTADDR_MASK, DWC2_HOST_RX_FIFO_SIZE); writel(nptxfifosize, ®s->global_regs.gnptxfsiz);
/* Periodic Tx FIFO */ - ptxfifosize |= FIELD_PREP(DWC2_FIFOSIZE_DEPTH_MASK, DWC2_HOST_PERIO_TX_FIFO_SIZE); - ptxfifosize |= FIELD_PREP(DWC2_FIFOSIZE_STARTADDR_MASK, DWC2_HOST_RX_FIFO_SIZE + + ptxfifosize |= FIELD_PREP(FIFOSIZE_DEPTH_MASK, DWC2_HOST_PERIO_TX_FIFO_SIZE); + ptxfifosize |= FIELD_PREP(FIFOSIZE_STARTADDR_MASK, DWC2_HOST_RX_FIFO_SIZE + DWC2_HOST_NPERIO_TX_FIFO_SIZE); writel(ptxfifosize, ®s->global_regs.hptxfsiz); } #endif
/* Clear Host Set HNP Enable in the OTG Control Register */ - clrbits_le32(®s->global_regs.gotgctl, DWC2_GOTGCTL_HSTSETHNPEN); + clrbits_le32(®s->global_regs.gotgctl, GOTGCTL_HSTSETHNPEN);
/* Make sure the FIFOs are flushed. */ - dwc_otg_flush_tx_fifo(dev, regs, 0x10); /* All Tx FIFOs */ + dwc_otg_flush_tx_fifo(dev, regs, GRSTCTL_TXFNUM_ALL); /* All Tx FIFOs */ dwc_otg_flush_rx_fifo(dev, regs);
/* Flush out any leftover queued requests. */ - num_channels = FIELD_GET(DWC2_HWCFG2_NUM_HOST_CHAN_MASK, - readl(®s->global_regs.ghwcfg2)) + 1; + num_channels = FIELD_GET(GHWCFG2_NUM_HOST_CHAN_MASK, readl(®s->global_regs.ghwcfg2)) + 1;
for (i = 0; i < num_channels; i++) - clrsetbits_le32(®s->host_regs.hc[i].hcchar, - DWC2_HCCHAR_CHEN | DWC2_HCCHAR_EPDIR, - DWC2_HCCHAR_CHDIS); + clrsetbits_le32(®s->host_regs.hc[i].hcchar, HCCHAR_CHENA | HCCHAR_EPDIR, + HCCHAR_CHDIS);
/* Halt all channels to put them into a known state. */ for (i = 0; i < num_channels; i++) { clrsetbits_le32(®s->host_regs.hc[i].hcchar, - DWC2_HCCHAR_EPDIR, - DWC2_HCCHAR_CHEN | DWC2_HCCHAR_CHDIS); + HCCHAR_EPDIR, + HCCHAR_CHENA | HCCHAR_CHDIS); ret = wait_for_bit_le32(®s->host_regs.hc[i].hcchar, - DWC2_HCCHAR_CHEN, false, 1000, false); + HCCHAR_CHENA, false, 1000, false); if (ret) dev_info(dev, "%s: Timeout!\n", __func__); }
/* Turn on the vbus power. */ - if (readl(®s->global_regs.gintsts) & DWC2_GINTSTS_CURMODE_HOST) { - hprt0 = readl(®s->host_regs.hprt0) & ~DWC2_HPRT0_W1C_MASK; - if (!(hprt0 & DWC2_HPRT0_PRTPWR)) { - hprt0 |= DWC2_HPRT0_PRTPWR; + if (readl(®s->global_regs.gintsts) & GINTSTS_CURMODE_HOST) { + hprt0 = readl(®s->host_regs.hprt0) & ~HPRT0_W1C_MASK; + if (!(hprt0 & HPRT0_PWR)) { + hprt0 |= HPRT0_PWR; writel(hprt0, ®s->host_regs.hprt0); } } @@ -336,20 +334,20 @@ static void dwc_otg_core_init(struct udevice *dev)
/* Program the ULPI External VBUS bit if needed */ if (priv->ext_vbus) { - usbcfg |= DWC2_GUSBCFG_ULPI_EXT_VBUS_DRV; + usbcfg |= GUSBCFG_ULPI_EXT_VBUS_DRV; if (!priv->oc_disable) { - usbcfg |= DWC2_GUSBCFG_ULPI_INT_VBUS_INDICATOR | - DWC2_GUSBCFG_INDICATOR_PASSTHROUGH; + usbcfg |= GUSBCFG_ULPI_INT_VBUS_IND | + GUSBCFG_INDICATORPASSTHROUGH; } } else { - usbcfg &= ~DWC2_GUSBCFG_ULPI_EXT_VBUS_DRV; + usbcfg &= ~GUSBCFG_ULPI_EXT_VBUS_DRV; }
/* Set external TS Dline pulsing */ #ifdef DWC2_TS_DLINE - usbcfg |= DWC2_GUSBCFG_TERM_SEL_DL_PULSE; + usbcfg |= GUSBCFG_TERMSELDLPULSE; #else - usbcfg &= ~DWC2_GUSBCFG_TERM_SEL_DL_PULSE; + usbcfg &= ~GUSBCFG_TERMSELDLPULSE; #endif writel(usbcfg, ®s->global_regs.gusbcfg);
@@ -363,7 +361,7 @@ static void dwc_otg_core_init(struct udevice *dev) #if defined(DWC2_DFLT_SPEED_FULL) && \ (DWC2_PHY_TYPE == DWC2_PHY_TYPE_FS) /* If FS mode with FS PHY */ - setbits_le32(®s->global_regs.gusbcfg, DWC2_GUSBCFG_PHYSEL); + setbits_le32(®s->global_regs.gusbcfg, GUSBCFG_PHYSEL);
/* Reset after a PHY select */ dwc2_core_reset(regs); @@ -373,18 +371,18 @@ static void dwc_otg_core_init(struct udevice *dev) * Also do this on HNP Dev/Host mode switches (done in dev_init * and host_init). */ - if (readl(®s->global_regs.gintsts) & DWC2_GINTSTS_CURMODE_HOST) + if (readl(®s->global_regs.gintsts) & GINTSTS_CURMODE_HOST) init_fslspclksel(regs);
#ifdef DWC2_I2C_ENABLE /* Program GUSBCFG.OtgUtmifsSel to I2C */ - setbits_le32(®s->global_regs.gusbcfg, DWC2_GUSBCFG_OTGUTMIFSSEL); + setbits_le32(®s->global_regs.gusbcfg, GUSBCFG_OTG_UTMI_FS_SEL);
/* Program GI2CCTL.I2CEn */ - clrsetbits_le32(®s->global_regs.gi2cctl, DWC2_GI2CCTL_I2CEN | - DWC2_GI2CCTL_I2CDEVADDR_MASK, - FIELD_PREP(DWC2_GI2CCTL_I2CDEVADDR_MASK, 1)); - setbits_le32(®s->global_regs.gi2cctl, DWC2_GI2CCTL_I2CEN); + clrsetbits_le32(®s->global_regs.gi2cctl, GI2CCTL_I2CEN | + GI2CCTL_I2CDEVADDR_MASK, + FIELD_PREP(GI2CCTL_I2CDEVADDR_MASK, 1)); + setbits_le32(®s->global_regs.gi2cctl, GI2CCTL_I2CEN); #endif
#else @@ -396,19 +394,19 @@ static void dwc_otg_core_init(struct udevice *dev) * immediately after setting phyif. */ #if (DWC2_PHY_TYPE == DWC2_PHY_TYPE_ULPI) - usbcfg |= DWC2_GUSBCFG_ULPI_UTMI_SEL; - usbcfg &= ~DWC2_GUSBCFG_PHYIF; + usbcfg |= GUSBCFG_ULPI_UTMI_SEL; + usbcfg &= ~GUSBCFG_PHYIF16; #ifdef DWC2_PHY_ULPI_DDR - usbcfg |= DWC2_GUSBCFG_DDRSEL; + usbcfg |= GUSBCFG_DDRSEL; #else - usbcfg &= ~DWC2_GUSBCFG_DDRSEL; + usbcfg &= ~GUSBCFG_DDRSEL; #endif /* DWC2_PHY_ULPI_DDR */ #elif (DWC2_PHY_TYPE == DWC2_PHY_TYPE_UTMI) - usbcfg &= ~DWC2_GUSBCFG_ULPI_UTMI_SEL; + usbcfg &= ~GUSBCFG_ULPI_UTMI_SEL; #if (DWC2_UTMI_WIDTH == 16) - usbcfg |= DWC2_GUSBCFG_PHYIF; + usbcfg |= GUSBCFG_PHYIF16; #else - usbcfg &= ~DWC2_GUSBCFG_PHYIF; + usbcfg &= ~GUSBCFG_PHYIF16; #endif /* DWC2_UTMI_WIDTH */ #endif /* DWC2_PHY_TYPE */
@@ -419,37 +417,36 @@ static void dwc_otg_core_init(struct udevice *dev) #endif
usbcfg = readl(®s->global_regs.gusbcfg); - usbcfg &= ~(DWC2_GUSBCFG_ULPI_FSLS | DWC2_GUSBCFG_ULPI_CLK_SUS_M); + usbcfg &= ~(GUSBCFG_ULPI_FS_LS | GUSBCFG_ULPI_CLK_SUSP_M); #ifdef DWC2_ULPI_FS_LS uint32_t hwcfg2 = readl(®s->global_regs.ghwcfg2); - uint32_t hval = FIELD_GET(DWC2_HWCFG2_HS_PHY_TYPE_MASK, ghwcfg2); - uint32_t fval = FIELD_GET(DWC2_HWCFG2_FS_PHY_TYPE_MASK, ghwcfg2); - if (hval == 2 && fval == 1) { - usbcfg |= DWC2_GUSBCFG_ULPI_FSLS; - usbcfg |= DWC2_GUSBCFG_ULPI_CLK_SUS_M; + uint32_t hval = FIELD_GET(GHWCFG2_HS_PHY_TYPE_MASK, ghwcfg2); + uint32_t fval = FIELD_GET(GHWCFG2_FS_PHY_TYPE_MASK, ghwcfg2); + + if (hval == GHWCFG2_FS_PHY_TYPE_SHARED_UTMI && fval == GHWCFG2_HS_PHY_TYPE_UTMI) { + usbcfg |= GUSBCFG_ULPI_FS_LS; + usbcfg |= GUSBCFG_ULPI_CLK_SUSP_M; } #endif if (priv->hnp_srp_disable) - usbcfg |= DWC2_GUSBCFG_FORCEHOSTMODE; + usbcfg |= GUSBCFG_FORCEHOSTMODE;
/* Program the GAHBCFG Register. */ - switch (FIELD_GET(DWC2_HWCFG2_ARCHITECTURE_MASK, readl(®s->global_regs.ghwcfg2))) { - case DWC2_HWCFG2_ARCHITECTURE_SLAVE_ONLY: + switch (FIELD_GET(GHWCFG2_ARCHITECTURE_MASK, readl(®s->global_regs.ghwcfg2))) { + case GHWCFG2_SLAVE_ONLY_ARCH: break; - case DWC2_HWCFG2_ARCHITECTURE_EXT_DMA: - ahbcfg |= FIELD_PREP(DWC2_GAHBCFG_HBURSTLEN_MASK, LOG2(brst_sz >> 1)); - + case GHWCFG2_EXT_DMA_ARCH: + ahbcfg |= FIELD_PREP(GAHBCFG_HBSTLEN_MASK, LOG2(brst_sz >> 1)); #ifdef DWC2_DMA_ENABLE - ahbcfg |= DWC2_GAHBCFG_DMAENABLE; + ahbcfg |= GAHBCFG_DMA_EN; #endif break; - - case DWC2_HWCFG2_ARCHITECTURE_INT_DMA: - ahbcfg |= DWC2_GAHBCFG_HBURSTLEN_INCR4; + case GHWCFG2_INT_DMA_ARCH: + ahbcfg |= FIELD_PREP(GAHBCFG_HBSTLEN_MASK, GAHBCFG_HBSTLEN_INCR4); #ifdef DWC2_DMA_ENABLE - ahbcfg |= DWC2_GAHBCFG_DMAENABLE; + ahbcfg |= GAHBCFG_DMA_EN; #endif break; } @@ -460,9 +457,9 @@ static void dwc_otg_core_init(struct udevice *dev) usbcfg = 0;
if (!priv->hnp_srp_disable) - usbcfg |= DWC2_GUSBCFG_HNPCAP | DWC2_GUSBCFG_SRPCAP; + usbcfg |= GUSBCFG_HNPCAP | GUSBCFG_SRPCAP; #ifdef DWC2_IC_USB_CAP - usbcfg |= DWC2_GUSBCFG_IC_USB_CAP; + usbcfg |= GUSBCFG_ICUSBCAP; #endif
setbits_le32(®s->global_regs.gusbcfg, usbcfg); @@ -482,14 +479,14 @@ static void dwc_otg_hc_init(struct dwc2_core_regs *regs, uint8_t hc_num, uint8_t ep_is_in, uint8_t ep_type, uint16_t max_packet) { struct dwc2_hc_regs *hc_regs = ®s->host_regs.hc[hc_num]; - u32 hcchar = FIELD_PREP(DWC2_HCCHAR_DEVADDR_MASK, dev_addr) | - FIELD_PREP(DWC2_HCCHAR_EPNUM_MASK, ep_num) | - FIELD_PREP(DWC2_HCCHAR_EPDIR, ep_is_in) | - FIELD_PREP(DWC2_HCCHAR_EPTYPE_MASK, ep_type) | - FIELD_PREP(DWC2_HCCHAR_MPS_MASK, max_packet); + u32 hcchar = FIELD_PREP(HCCHAR_DEVADDR_MASK, dev_addr) | + FIELD_PREP(HCCHAR_EPNUM_MASK, ep_num) | + FIELD_PREP(HCCHAR_EPDIR, ep_is_in) | + FIELD_PREP(HCCHAR_EPTYPE_MASK, ep_type) | + FIELD_PREP(HCCHAR_MPS_MASK, max_packet);
if (dev->speed == USB_SPEED_LOW) - hcchar |= DWC2_HCCHAR_LSPDDEV; + hcchar |= HCCHAR_LSPDDEV;
/* * Program the HCCHARn register with the endpoint characteristics @@ -506,9 +503,9 @@ static void dwc_otg_hc_init_split(struct dwc2_hc_regs *hc_regs, { uint32_t hcsplt = 0;
- hcsplt = DWC2_HCSPLT_SPLTENA; - hcsplt |= FIELD_PREP(DWC2_HCSPLT_HUBADDR_MASK, hub_devnum); - hcsplt |= FIELD_PREP(DWC2_HCSPLT_PRTADDR_MASK, hub_port); + hcsplt = HCSPLT_SPLTENA; + hcsplt |= FIELD_PREP(HCSPLT_HUBADDR_MASK, hub_devnum); + hcsplt |= FIELD_PREP(HCSPLT_PRTADDR_MASK, hub_port);
/* Program the HCSPLIT register for SPLITs */ writel(hcsplt, &hc_regs->hcsplt); @@ -544,33 +541,33 @@ static int dwc_otg_submit_rh_msg_in_status(struct dwc2_core_regs *regs, break; case USB_RECIP_OTHER | USB_TYPE_CLASS: hprt0 = readl(®s->host_regs.hprt0); - if (hprt0 & DWC2_HPRT0_PRTCONNSTS) + if (hprt0 & HPRT0_CONNSTS) port_status |= USB_PORT_STAT_CONNECTION; - if (hprt0 & DWC2_HPRT0_PRTENA) + if (hprt0 & HPRT0_ENA) port_status |= USB_PORT_STAT_ENABLE; - if (hprt0 & DWC2_HPRT0_PRTSUSP) + if (hprt0 & HPRT0_SUSP) port_status |= USB_PORT_STAT_SUSPEND; - if (hprt0 & DWC2_HPRT0_PRTOVRCURRACT) + if (hprt0 & HPRT0_OVRCURRACT) port_status |= USB_PORT_STAT_OVERCURRENT; - if (hprt0 & DWC2_HPRT0_PRTRST) + if (hprt0 & HPRT0_RST) port_status |= USB_PORT_STAT_RESET; - if (hprt0 & DWC2_HPRT0_PRTPWR) + if (hprt0 & HPRT0_PWR) port_status |= USB_PORT_STAT_POWER;
- switch (FIELD_GET(DWC2_HPRT0_PRTSPD_MASK, hprt0)) { - case DWC2_HPRT0_PRTSPD_LOW: + switch (FIELD_GET(HPRT0_SPD_MASK, hprt0)) { + case HPRT0_SPD_LOW_SPEED: port_status |= USB_PORT_STAT_LOW_SPEED; break; - case DWC2_HPRT0_PRTSPD_HIGH: + case HPRT0_SPD_HIGH_SPEED: port_status |= USB_PORT_STAT_HIGH_SPEED; break; }
- if (hprt0 & DWC2_HPRT0_PRTENCHNG) + if (hprt0 & HPRT0_ENACHG) port_change |= USB_PORT_STAT_C_ENABLE; - if (hprt0 & DWC2_HPRT0_PRTCONNDET) + if (hprt0 & HPRT0_CONNDET) port_change |= USB_PORT_STAT_C_CONNECTION; - if (hprt0 & DWC2_HPRT0_PRTOVRCURRCHNG) + if (hprt0 & HPRT0_OVRCURRCHG) port_change |= USB_PORT_STAT_C_OVERCURRENT;
*(uint32_t *)buffer = cpu_to_le32(port_status | @@ -736,8 +733,7 @@ static int dwc_otg_submit_rh_msg_out(struct dwc2_priv *priv, case (USB_REQ_CLEAR_FEATURE << 8) | USB_RECIP_OTHER | USB_TYPE_CLASS: switch (wValue) { case USB_PORT_FEAT_C_CONNECTION: - clrsetbits_le32(®s->host_regs.hprt0, DWC2_HPRT0_W1C_MASK, - DWC2_HPRT0_PRTCONNDET); + clrsetbits_le32(®s->host_regs.hprt0, HPRT0_W1C_MASK, HPRT0_CONNDET); break; } break; @@ -748,16 +744,13 @@ static int dwc_otg_submit_rh_msg_out(struct dwc2_priv *priv, break;
case USB_PORT_FEAT_RESET: - clrsetbits_le32(®s->host_regs.hprt0, DWC2_HPRT0_W1C_MASK, - DWC2_HPRT0_PRTRST); + clrsetbits_le32(®s->host_regs.hprt0, HPRT0_W1C_MASK, HPRT0_RST); mdelay(50); - clrbits_le32(®s->host_regs.hprt0, - DWC2_HPRT0_W1C_MASK | DWC2_HPRT0_PRTRST); + clrbits_le32(®s->host_regs.hprt0, HPRT0_W1C_MASK | HPRT0_RST); break;
case USB_PORT_FEAT_POWER: - clrsetbits_le32(®s->host_regs.hprt0, DWC2_HPRT0_W1C_MASK, - DWC2_HPRT0_PRTRST); + clrsetbits_le32(®s->host_regs.hprt0, HPRT0_W1C_MASK, HPRT0_RST); break;
case USB_PORT_FEAT_ENABLE: @@ -808,23 +801,23 @@ int wait_for_chhltd(struct dwc2_hc_regs *hc_regs, uint32_t *sub, u8 *toggle) int ret; uint32_t hcint, hctsiz;
- ret = wait_for_bit_le32(&hc_regs->hcint, DWC2_HCINT_CHHLTD, true, + ret = wait_for_bit_le32(&hc_regs->hcint, HCINTMSK_CHHLTD, true, 2000, false); if (ret) return ret;
hcint = readl(&hc_regs->hcint); hctsiz = readl(&hc_regs->hctsiz); - *sub = FIELD_GET(DWC2_HCTSIZ_XFERSIZE_MASK, hctsiz); - *toggle = FIELD_GET(DWC2_HCTSIZ_PID_MASK, hctsiz); + *sub = FIELD_GET(TSIZ_XFERSIZE_MASK, hctsiz); + *toggle = FIELD_GET(TSIZ_SC_MC_PID_MASK, hctsiz);
debug("%s: HCINT=%08x sub=%u toggle=%d\n", __func__, hcint, *sub, *toggle);
- if (hcint & DWC2_HCINT_XFERCOMP) + if (hcint & HCINTMSK_XFERCOMPL) return 0;
- if (hcint & (DWC2_HCINT_NAK | DWC2_HCINT_FRMOVRUN)) + if (hcint & (HCINTMSK_NAK | HCINTMSK_FRMOVRUN)) return -EAGAIN;
debug("%s: Error (HCINT=%08x)\n", __func__, hcint); @@ -832,10 +825,10 @@ int wait_for_chhltd(struct dwc2_hc_regs *hc_regs, uint32_t *sub, u8 *toggle) }
static int dwc2_eptype[] = { - DWC2_HCCHAR_EPTYPE_ISOC, - DWC2_HCCHAR_EPTYPE_INTR, - DWC2_HCCHAR_EPTYPE_CONTROL, - DWC2_HCCHAR_EPTYPE_BULK, + HCCHAR_EPTYPE_ISOC, + HCCHAR_EPTYPE_INTR, + HCCHAR_EPTYPE_CONTROL, + HCCHAR_EPTYPE_BULK, };
static int transfer_chunk(struct dwc2_hc_regs *hc_regs, void *aligned_buffer, @@ -848,9 +841,9 @@ static int transfer_chunk(struct dwc2_hc_regs *hc_regs, void *aligned_buffer, debug("%s: chunk: pid %d xfer_len %u pkts %u\n", __func__, *pid, xfer_len, num_packets);
- writel(FIELD_PREP(DWC2_HCTSIZ_XFERSIZE_MASK, xfer_len) | - FIELD_PREP(DWC2_HCTSIZ_PKTCNT_MASK, num_packets) | - FIELD_PREP(DWC2_HCTSIZ_PID_MASK, *pid), + writel(FIELD_PREP(TSIZ_XFERSIZE_MASK, xfer_len) | + FIELD_PREP(TSIZ_PKTCNT_MASK, num_packets) | + FIELD_PREP(TSIZ_SC_MC_PID_MASK, *pid), &hc_regs->hctsiz);
if (xfer_len) { @@ -874,12 +867,12 @@ static int transfer_chunk(struct dwc2_hc_regs *hc_regs, void *aligned_buffer, writel(0x3fff, &hc_regs->hcint);
/* Set host channel enable after all other setup is complete. */ - clrsetbits_le32(&hc_regs->hcchar, DWC2_HCCHAR_MULTICNT_MASK | - DWC2_HCCHAR_CHEN | DWC2_HCCHAR_CHDIS | - DWC2_HCCHAR_ODDFRM, - FIELD_PREP(DWC2_HCCHAR_MULTICNT_MASK, 1) | - FIELD_PREP(DWC2_HCCHAR_ODDFRM, odd_frame) | - DWC2_HCCHAR_CHEN); + clrsetbits_le32(&hc_regs->hcchar, HCCHAR_MULTICNT_MASK | + HCCHAR_CHENA | HCCHAR_CHDIS | + HCCHAR_ODDFRM, + FIELD_PREP(HCCHAR_MULTICNT_MASK, 1) | + FIELD_PREP(HCCHAR_ODDFRM, odd_frame) | + HCCHAR_CHENA);
ret = wait_for_chhltd(hc_regs, &sub, pid); if (ret < 0) @@ -942,7 +935,7 @@ int chunk_msg(struct dwc2_priv *priv, struct usb_device *dev, uint8_t hub_port; uint32_t hprt0 = readl(®s->host_regs.hprt0);
- if (FIELD_GET(DWC2_HPRT0_PRTSPD_MASK, hprt0) == DWC2_HPRT0_PRTSPD_HIGH) { + if (FIELD_GET(HPRT0_SPD_MASK, hprt0) == HPRT0_SPD_HIGH_SPEED) { usb_find_usb2_hub_address_port(dev, &hub_addr, &hub_port); dwc_otg_hc_init_split(hc_regs, hub_addr, hub_port); @@ -967,11 +960,11 @@ int chunk_msg(struct dwc2_priv *priv, struct usb_device *dev, num_packets = 1;
if (complete_split) - setbits_le32(&hc_regs->hcsplt, DWC2_HCSPLT_COMPSPLT); + setbits_le32(&hc_regs->hcsplt, HCSPLT_COMPSPLT); else if (do_split) - clrbits_le32(&hc_regs->hcsplt, DWC2_HCSPLT_COMPSPLT); + clrbits_le32(&hc_regs->hcsplt, HCSPLT_COMPSPLT);
- if (eptype == DWC2_HCCHAR_EPTYPE_INTR) { + if (eptype == HCCHAR_EPTYPE_INTR) { int uframe_num = readl(&host_regs->hfnum); if (!(uframe_num & 0x1)) odd_frame = 1; @@ -984,18 +977,18 @@ int chunk_msg(struct dwc2_priv *priv, struct usb_device *dev, hcint = readl(&hc_regs->hcint); if (complete_split) { stop_transfer = 0; - if (hcint & DWC2_HCINT_NYET) { + if (hcint & HCINTMSK_NYET) { ret = 0; - int frame_num = FIELD_GET(DWC2_HFNUM_FRNUM_MASK, + int frame_num = FIELD_GET(HFNUM_FRNUM_MASK, readl(&host_regs->hfnum));
- if (((frame_num - ssplit_frame_num) & DWC2_HFNUM_FRNUM_MASK) > 4) + if (((frame_num - ssplit_frame_num) & HFNUM_FRNUM_MASK) > 4) ret = -EAGAIN; } else complete_split = 0; } else if (do_split) { - if (hcint & DWC2_HCINT_ACK) { - ssplit_frame_num = FIELD_GET(DWC2_HFNUM_FRNUM_MASK, + if (hcint & HCINTMSK_ACK) { + ssplit_frame_num = FIELD_GET(HFNUM_FRNUM_MASK, readl(&host_regs->hfnum)); ret = 0; complete_split = 1; @@ -1174,8 +1167,7 @@ static int dwc2_init_common(struct udevice *dev, struct dwc2_priv *priv) dev_info(dev, "Core Release: %x.%03x\n", snpsid >> 12 & 0xf, snpsid & 0xfff);
- if (FIELD_GET(DWC2_SNPSID_DEVID_MASK, snpsid) != DWC2_SNPSID_DEVID_VER_2xx && - FIELD_GET(DWC2_SNPSID_DEVID_MASK, snpsid) != DWC2_SNPSID_DEVID_VER_3xx) { + if (FIELD_GET(GSNPSID_ID_MASK, snpsid) != GSNPSID_OTG_ID) { dev_info(dev, "SNPSID invalid (not DWC2 OTG device): %08x\n", snpsid); return -ENODEV; @@ -1196,9 +1188,9 @@ static int dwc2_init_common(struct udevice *dev, struct dwc2_priv *priv) dwc_otg_core_host_init(dev, regs); }
- clrsetbits_le32(®s->host_regs.hprt0, DWC2_HPRT0_W1C_MASK, DWC2_HPRT0_PRTRST); + clrsetbits_le32(®s->host_regs.hprt0, HPRT0_W1C_MASK, HPRT0_RST); mdelay(50); - clrbits_le32(®s->host_regs.hprt0, DWC2_HPRT0_W1C_MASK | DWC2_HPRT0_PRTRST); + clrbits_le32(®s->host_regs.hprt0, HPRT0_W1C_MASK | HPRT0_RST);
for (i = 0; i < MAX_DEVICE; i++) { for (j = 0; j < MAX_ENDPOINT; j++) { @@ -1213,7 +1205,7 @@ static int dwc2_init_common(struct udevice *dev, struct dwc2_priv *priv) * is started (the bus is scanned) and fixes the USB detection * problems with some problematic USB keys. */ - if (readl(®s->global_regs.gintsts) & DWC2_GINTSTS_CURMODE_HOST) + if (readl(®s->global_regs.gintsts) & GINTSTS_CURMODE_HOST) mdelay(1000);
printf("USB DWC2\n"); @@ -1224,7 +1216,7 @@ static int dwc2_init_common(struct udevice *dev, struct dwc2_priv *priv) static void dwc2_uninit_common(struct dwc2_core_regs *regs) { /* Put everything in reset. */ - clrsetbits_le32(®s->host_regs.hprt0, DWC2_HPRT0_W1C_MASK, DWC2_HPRT0_PRTRST); + clrsetbits_le32(®s->host_regs.hprt0, HPRT0_W1C_MASK, HPRT0_RST); }
#if !CONFIG_IS_ENABLED(DM_USB) diff --git a/drivers/usb/host/dwc2.h b/drivers/usb/host/dwc2.h index 6bd98b481f2449e32f5ccf3dc5baca814a2f4a16..a01edc5eff3ac8ef89addff29d2df26952288ccc 100644 --- a/drivers/usb/host/dwc2.h +++ b/drivers/usb/host/dwc2.h @@ -8,356 +8,294 @@
#include <linux/bitops.h>
-#define DWC2_GOTGCTL_SESREQSCS BIT(0) -#define DWC2_GOTGCTL_SESREQ BIT(1) -#define DWC2_GOTGCTL_HSTNEGSCS BIT(8) -#define DWC2_GOTGCTL_HNPREQ BIT(9) -#define DWC2_GOTGCTL_HSTSETHNPEN BIT(10) -#define DWC2_GOTGCTL_DEVHNPEN BIT(11) -#define DWC2_GOTGCTL_CONIDSTS BIT(16) -#define DWC2_GOTGCTL_DBNCTIME BIT(17) -#define DWC2_GOTGCTL_ASESVLD BIT(18) -#define DWC2_GOTGCTL_BSESVLD BIT(19) -#define DWC2_GOTGCTL_OTGVER BIT(20) -#define DWC2_GOTGINT_SESENDDET BIT(2) -#define DWC2_GOTGINT_SESREQSUCSTSCHNG BIT(8) -#define DWC2_GOTGINT_HSTNEGSUCSTSCHNG BIT(9) -#define DWC2_GOTGINT_RESERVER10_16_MASK GENMASK(16, 10) -#define DWC2_GOTGINT_HSTNEGDET BIT(17) -#define DWC2_GOTGINT_ADEVTOUTCHNG BIT(18) -#define DWC2_GOTGINT_DEBDONE BIT(19) -#define DWC2_GAHBCFG_GLBLINTRMSK BIT(0) -#define DWC2_GAHBCFG_HBURSTLEN_SINGLE (0 << 1) -#define DWC2_GAHBCFG_HBURSTLEN_INCR (1 << 1) -#define DWC2_GAHBCFG_HBURSTLEN_INCR4 (3 << 1) -#define DWC2_GAHBCFG_HBURSTLEN_INCR8 (5 << 1) -#define DWC2_GAHBCFG_HBURSTLEN_INCR16 (7 << 1) -#define DWC2_GAHBCFG_HBURSTLEN_MASK GENMASK(4, 1) -#define DWC2_GAHBCFG_DMAENABLE BIT(5) -#define DWC2_GAHBCFG_NPTXFEMPLVL_TXFEMPLVL BIT(7) -#define DWC2_GAHBCFG_PTXFEMPLVL BIT(8) -#define DWC2_GUSBCFG_TOUTCAL_MASK GENMASK(2, 0) -#define DWC2_GUSBCFG_PHYIF BIT(3) -#define DWC2_GUSBCFG_ULPI_UTMI_SEL BIT(4) -#define DWC2_GUSBCFG_FSINTF BIT(5) -#define DWC2_GUSBCFG_PHYSEL BIT(6) -#define DWC2_GUSBCFG_DDRSEL BIT(7) -#define DWC2_GUSBCFG_SRPCAP BIT(8) -#define DWC2_GUSBCFG_HNPCAP BIT(9) -#define DWC2_GUSBCFG_USBTRDTIM_MASK GENMASK(13, 10) -#define DWC2_GUSBCFG_NPTXFRWNDEN BIT(14) -#define DWC2_GUSBCFG_PHYLPWRCLKSEL BIT(15) -#define DWC2_GUSBCFG_OTGUTMIFSSEL BIT(16) -#define DWC2_GUSBCFG_ULPI_FSLS BIT(17) -#define DWC2_GUSBCFG_ULPI_AUTO_RES BIT(18) -#define DWC2_GUSBCFG_ULPI_CLK_SUS_M BIT(19) -#define DWC2_GUSBCFG_ULPI_EXT_VBUS_DRV BIT(20) -#define DWC2_GUSBCFG_ULPI_INT_VBUS_INDICATOR BIT(21) -#define DWC2_GUSBCFG_TERM_SEL_DL_PULSE BIT(22) -#define DWC2_GUSBCFG_INDICATOR_PASSTHROUGH BIT(24) -#define DWC2_GUSBCFG_IC_USB_CAP BIT(26) -#define DWC2_GUSBCFG_IC_TRAFFIC_PULL_REMOVE BIT(27) -#define DWC2_GUSBCFG_TX_END_DELAY BIT(28) -#define DWC2_GUSBCFG_FORCEHOSTMODE BIT(29) -#define DWC2_GUSBCFG_FORCEDEVMODE BIT(30) -#define DWC2_GLPMCTL_LPM_CAP_EN BIT(0) -#define DWC2_GLPMCTL_APPL_RESP BIT(1) -#define DWC2_GLPMCTL_HIRD_MASK GENMASK(5, 2) -#define DWC2_GLPMCTL_REM_WKUP_EN BIT(6) -#define DWC2_GLPMCTL_EN_UTMI_SLEEP BIT(7) -#define DWC2_GLPMCTL_HIRD_THRES_MASK GENMASK(12, 8) -#define DWC2_GLPMCTL_LPM_RESP_MASK GENMASK(14, 13) -#define DWC2_GLPMCTL_PRT_SLEEP_STS BIT(15) -#define DWC2_GLPMCTL_SLEEP_STATE_RESUMEOK BIT(16) -#define DWC2_GLPMCTL_LPM_CHAN_INDEX_MASK GENMASK(20, 17) -#define DWC2_GLPMCTL_RETRY_COUNT_MASK GENMASK(23, 21) -#define DWC2_GLPMCTL_SEND_LPM BIT(24) -#define DWC2_GLPMCTL_RETRY_COUNT_STS_MASK GENMASK(27, 25) -#define DWC2_GLPMCTL_HSIC_CONNECT BIT(30) -#define DWC2_GLPMCTL_INV_SEL_HSIC BIT(31) -#define DWC2_GRSTCTL_CSFTRST BIT(0) -#define DWC2_GRSTCTL_HSFTRST BIT(1) -#define DWC2_GRSTCTL_HSTFRM BIT(2) -#define DWC2_GRSTCTL_INTKNQFLSH BIT(3) -#define DWC2_GRSTCTL_RXFFLSH BIT(4) -#define DWC2_GRSTCTL_TXFFLSH BIT(5) -#define DWC2_GRSTCTL_TXFNUM_MASK GENMASK(10, 6) -#define DWC2_GRSTCTL_DMAREQ BIT(30) -#define DWC2_GRSTCTL_AHBIDLE BIT(31) -#define DWC2_GINTMSK_MODEMISMATCH BIT(1) -#define DWC2_GINTMSK_OTGINTR BIT(2) -#define DWC2_GINTMSK_SOFINTR BIT(3) -#define DWC2_GINTMSK_RXSTSQLVL BIT(4) -#define DWC2_GINTMSK_NPTXFEMPTY BIT(5) -#define DWC2_GINTMSK_GINNAKEFF BIT(6) -#define DWC2_GINTMSK_GOUTNAKEFF BIT(7) -#define DWC2_GINTMSK_I2CINTR BIT(9) -#define DWC2_GINTMSK_ERLYSUSPEND BIT(10) -#define DWC2_GINTMSK_USBSUSPEND BIT(11) -#define DWC2_GINTMSK_USBRESET BIT(12) -#define DWC2_GINTMSK_ENUMDONE BIT(13) -#define DWC2_GINTMSK_ISOOUTDROP BIT(14) -#define DWC2_GINTMSK_EOPFRAME BIT(15) -#define DWC2_GINTMSK_EPMISMATCH BIT(17) -#define DWC2_GINTMSK_INEPINTR BIT(18) -#define DWC2_GINTMSK_OUTEPINTR BIT(19) -#define DWC2_GINTMSK_INCOMPLISOIN BIT(20) -#define DWC2_GINTMSK_INCOMPLISOOUT BIT(21) -#define DWC2_GINTMSK_PORTINTR BIT(24) -#define DWC2_GINTMSK_HCINTR BIT(25) -#define DWC2_GINTMSK_PTXFEMPTY BIT(26) -#define DWC2_GINTMSK_LPMTRANRCVD BIT(27) -#define DWC2_GINTMSK_CONIDSTSCHNG BIT(28) -#define DWC2_GINTMSK_DISCONNECT BIT(29) -#define DWC2_GINTMSK_SESSREQINTR BIT(30) -#define DWC2_GINTMSK_WKUPINTR BIT(31) -#define DWC2_GINTSTS_CURMODE_HOST BIT(0) -#define DWC2_GINTSTS_MODEMISMATCH BIT(1) -#define DWC2_GINTSTS_OTGINTR BIT(2) -#define DWC2_GINTSTS_SOFINTR BIT(3) -#define DWC2_GINTSTS_RXSTSQLVL BIT(4) -#define DWC2_GINTSTS_NPTXFEMPTY BIT(5) -#define DWC2_GINTSTS_GINNAKEFF BIT(6) -#define DWC2_GINTSTS_GOUTNAKEFF BIT(7) -#define DWC2_GINTSTS_I2CINTR BIT(9) -#define DWC2_GINTSTS_ERLYSUSPEND BIT(10) -#define DWC2_GINTSTS_USBSUSPEND BIT(11) -#define DWC2_GINTSTS_USBRESET BIT(12) -#define DWC2_GINTSTS_ENUMDONE BIT(13) -#define DWC2_GINTSTS_ISOOUTDROP BIT(14) -#define DWC2_GINTSTS_EOPFRAME BIT(15) -#define DWC2_GINTSTS_INTOKENRX BIT(16) -#define DWC2_GINTSTS_EPMISMATCH BIT(17) -#define DWC2_GINTSTS_INEPINT BIT(18) -#define DWC2_GINTSTS_OUTEPINTR BIT(19) -#define DWC2_GINTSTS_INCOMPLISOIN BIT(20) -#define DWC2_GINTSTS_INCOMPLISOOUT BIT(21) -#define DWC2_GINTSTS_PORTINTR BIT(24) -#define DWC2_GINTSTS_HCINTR BIT(25) -#define DWC2_GINTSTS_PTXFEMPTY BIT(26) -#define DWC2_GINTSTS_LPMTRANRCVD BIT(27) -#define DWC2_GINTSTS_CONIDSTSCHNG BIT(28) -#define DWC2_GINTSTS_DISCONNECT BIT(29) -#define DWC2_GINTSTS_SESSREQINTR BIT(30) -#define DWC2_GINTSTS_WKUPINTR BIT(31) -#define DWC2_GRXSTS_EPNUM_MASK GENMASK(3, 0) -#define DWC2_GRXSTS_BCNT_MASK GENMASK(14, 4) -#define DWC2_GRXSTS_DPID_MASK GENMASK(16, 15) -#define DWC2_GRXSTS_PKTSTS_MASK GENMASK(20, 17) -#define DWC2_GRXSTS_FN_MASK GENMASK(24, 21) -#define DWC2_FIFOSIZE_STARTADDR_MASK GENMASK(15, 0) -#define DWC2_FIFOSIZE_DEPTH_MASK GENMASK(31, 16) -#define DWC2_GNPTXSTS_NPTXFSPCAVAIL_MASK GENMASK(15, 0) -#define DWC2_GNPTXSTS_NPTXQSPCAVAIL_MASK GENMASK(23, 16) -#define DWC2_GNPTXSTS_NPTXQTOP_TERMINATE BIT(24) -#define DWC2_GNPTXSTS_NPTXQTOP_TOKEN_MASK GENMASK(26, 25) -#define DWC2_GNPTXSTS_NPTXQTOP_CHNEP_MASK GENMASK(30, 27) -#define DWC2_DTXFSTS_TXFSPCAVAIL_MASK GENMASK(15, 0) -#define DWC2_GI2CCTL_RWDATA_MASK GENMASK(7, 0) -#define DWC2_GI2CCTL_REGADDR_MASK GENMASK(15, 8) -#define DWC2_GI2CCTL_ADDR_MASK GENMASK(22, 16) -#define DWC2_GI2CCTL_I2CEN BIT(23) -#define DWC2_GI2CCTL_ACK BIT(24) -#define DWC2_GI2CCTL_I2CSUSPCTL BIT(25) -#define DWC2_GI2CCTL_I2CDEVADDR_MASK GENMASK(27, 26) -#define DWC2_GI2CCTL_RW BIT(30) -#define DWC2_GI2CCTL_BSYDNE BIT(31) -#define DWC2_HWCFG1_EP_DIR0_MASK GENMASK(1, 0) -#define DWC2_HWCFG1_EP_DIR1_MASK GENMASK(3, 2) -#define DWC2_HWCFG1_EP_DIR2_MASK GENMASK(5, 4) -#define DWC2_HWCFG1_EP_DIR3_MASK GENMASK(7, 6) -#define DWC2_HWCFG1_EP_DIR4_MASK GENMASK(9, 8) -#define DWC2_HWCFG1_EP_DIR5_MASK GENMASK(11, 10) -#define DWC2_HWCFG1_EP_DIR6_MASK GENMASK(13, 12) -#define DWC2_HWCFG1_EP_DIR7_MASK GENMASK(15, 14) -#define DWC2_HWCFG1_EP_DIR8_MASK GENMASK(17, 16) -#define DWC2_HWCFG1_EP_DIR9_MASK GENMASK(19, 18) -#define DWC2_HWCFG1_EP_DIR10_MASK GENMASK(21, 20) -#define DWC2_HWCFG1_EP_DIR11_MASK GENMASK(23, 22) -#define DWC2_HWCFG1_EP_DIR12_MASK GENMASK(25, 24) -#define DWC2_HWCFG1_EP_DIR13_MASK GENMASK(27, 26) -#define DWC2_HWCFG1_EP_DIR14_MASK GENMASK(29, 28) -#define DWC2_HWCFG1_EP_DIR15_MASK GENMASK(31, 30) -#define DWC2_HWCFG2_OP_MODE_MASK GENMASK(2, 0) -#define DWC2_HWCFG2_ARCHITECTURE_SLAVE_ONLY (0x0 << 3) -#define DWC2_HWCFG2_ARCHITECTURE_EXT_DMA (0x1 << 3) -#define DWC2_HWCFG2_ARCHITECTURE_INT_DMA (0x2 << 3) -#define DWC2_HWCFG2_ARCHITECTURE_MASK GENMASK(4, 3) -#define DWC2_HWCFG2_POINT2POINT BIT(5) -#define DWC2_HWCFG2_HS_PHY_TYPE_MASK GENMASK(7, 6) -#define DWC2_HWCFG2_FS_PHY_TYPE_MASK GENMASK(9, 8) -#define DWC2_HWCFG2_NUM_DEV_EP_MASK GENMASK(13, 10) -#define DWC2_HWCFG2_NUM_HOST_CHAN_MASK GENMASK(17, 14) -#define DWC2_HWCFG2_PERIO_EP_SUPPORTED BIT(18) -#define DWC2_HWCFG2_DYNAMIC_FIFO BIT(19) -#define DWC2_HWCFG2_MULTI_PROC_INT BIT(20) -#define DWC2_HWCFG2_NONPERIO_TX_Q_DEPTH_MASK GENMASK(23, 22) -#define DWC2_HWCFG2_HOST_PERIO_TX_Q_DEPTH_MASK GENMASK(25, 24) -#define DWC2_HWCFG2_DEV_TOKEN_Q_DEPTH_MASK GENMASK(30, 26) -#define DWC2_HWCFG3_XFER_SIZE_CNTR_WIDTH_MASK GENMASK(3, 0) -#define DWC2_HWCFG3_PACKET_SIZE_CNTR_WIDTH_MASK GENMASK(6, 4) -#define DWC2_HWCFG3_OTG_FUNC BIT(7) -#define DWC2_HWCFG3_I2C BIT(8) -#define DWC2_HWCFG3_VENDOR_CTRL_IF BIT(9) -#define DWC2_HWCFG3_OPTIONAL_FEATURES BIT(10) -#define DWC2_HWCFG3_SYNCH_RESET_TYPE BIT(11) -#define DWC2_HWCFG3_OTG_ENABLE_IC_USB BIT(12) -#define DWC2_HWCFG3_OTG_ENABLE_HSIC BIT(13) -#define DWC2_HWCFG3_OTG_LPM_EN BIT(15) -#define DWC2_HWCFG3_DFIFO_DEPTH_MASK GENMASK(31, 16) -#define DWC2_HWCFG4_NUM_DEV_PERIO_IN_EP_MASK GENMASK(3, 0) -#define DWC2_HWCFG4_POWER_OPTIMIZ BIT(4) -#define DWC2_HWCFG4_MIN_AHB_FREQ_MASK GENMASK(13, 5) -#define DWC2_HWCFG4_UTMI_PHY_DATA_WIDTH_MASK GENMASK(15, 14) -#define DWC2_HWCFG4_NUM_DEV_MODE_CTRL_EP_MASK GENMASK(19, 16) -#define DWC2_HWCFG4_IDDIG_FILT_EN BIT(20) -#define DWC2_HWCFG4_VBUS_VALID_FILT_EN BIT(21) -#define DWC2_HWCFG4_A_VALID_FILT_EN BIT(22) -#define DWC2_HWCFG4_B_VALID_FILT_EN BIT(23) -#define DWC2_HWCFG4_SESSION_END_FILT_EN BIT(24) -#define DWC2_HWCFG4_DED_FIFO_EN BIT(25) -#define DWC2_HWCFG4_NUM_IN_EPS_MASK GENMASK(29, 26) -#define DWC2_HWCFG4_DESC_DMA BIT(30) -#define DWC2_HWCFG4_DESC_DMA_DYN BIT(31) -#define DWC2_HCFG_FSLSPCLKSEL_30_60_MHZ 0 -#define DWC2_HCFG_FSLSPCLKSEL_48_MHZ 1 -#define DWC2_HCFG_FSLSPCLKSEL_6_MHZ 2 -#define DWC2_HCFG_FSLSPCLKSEL_MASK GENMASK(1, 0) -#define DWC2_HCFG_FSLSSUPP BIT(2) -#define DWC2_HCFG_DESCDMA BIT(23) -#define DWC2_HCFG_FRLISTEN_MASK GENMASK(25, 24) -#define DWC2_HCFG_PERSCHEDENA BIT(26) -#define DWC2_HCFG_PERSCHEDSTAT BIT(27) -#define DWC2_HFIR_FRINT_MASK GENMASK(15, 0) -#define DWC2_HFNUM_FRNUM_MASK GENMASK(15, 0) -#define DWC2_HFNUM_FRREM_MASK GENMASK(31, 16) -#define DWC2_HFNUM_MAX_FRNUM 0x3FFF -#define DWC2_HPTXSTS_PTXFSPCAVAIL_MASK GENMASK(15, 0) -#define DWC2_HPTXSTS_PTXQSPCAVAIL_MASK GENMASK(23, 16) -#define DWC2_HPTXSTS_PTXQTOP_TERMINATE BIT(24) -#define DWC2_HPTXSTS_PTXQTOP_TOKEN_MASK GENMASK(26, 25) -#define DWC2_HPTXSTS_PTXQTOP_CHNUM_MASK GENMASK(30, 27) -#define DWC2_HPTXSTS_PTXQTOP_ODD BIT(31) -#define DWC2_HPRT0_PRTCONNSTS BIT(0) -#define DWC2_HPRT0_PRTCONNDET BIT(1) -#define DWC2_HPRT0_PRTENA BIT(2) -#define DWC2_HPRT0_PRTENCHNG BIT(3) -#define DWC2_HPRT0_PRTOVRCURRACT BIT(4) -#define DWC2_HPRT0_PRTOVRCURRCHNG BIT(5) -#define DWC2_HPRT0_PRTRES BIT(6) -#define DWC2_HPRT0_PRTSUSP BIT(7) -#define DWC2_HPRT0_PRTRST BIT(8) -#define DWC2_HPRT0_PRTLNSTS_MASK GENMASK(11, 10) -#define DWC2_HPRT0_PRTPWR BIT(12) -#define DWC2_HPRT0_PRTTSTCTL_MASK GENMASK(16, 13) -#define DWC2_HPRT0_PRTSPD_HIGH (0 << 17) -#define DWC2_HPRT0_PRTSPD_FULL (1 << 17) -#define DWC2_HPRT0_PRTSPD_LOW (2 << 17) -#define DWC2_HPRT0_PRTSPD_MASK GENMASK(18, 17) -#define DWC2_HPRT0_W1C_MASK (DWC2_HPRT0_PRTCONNDET | \ - DWC2_HPRT0_PRTENA | \ - DWC2_HPRT0_PRTENCHNG | \ - DWC2_HPRT0_PRTOVRCURRCHNG) -#define DWC2_HAINT_CH0 BIT(0) -#define DWC2_HAINT_CH1 BIT(1) -#define DWC2_HAINT_CH2 BIT(2) -#define DWC2_HAINT_CH3 BIT(3) -#define DWC2_HAINT_CH4 BIT(4) -#define DWC2_HAINT_CH5 BIT(5) -#define DWC2_HAINT_CH6 BIT(6) -#define DWC2_HAINT_CH7 BIT(7) -#define DWC2_HAINT_CH8 BIT(8) -#define DWC2_HAINT_CH9 BIT(9) -#define DWC2_HAINT_CH10 BIT(10) -#define DWC2_HAINT_CH11 BIT(11) -#define DWC2_HAINT_CH12 BIT(12) -#define DWC2_HAINT_CH13 BIT(13) -#define DWC2_HAINT_CH14 BIT(14) -#define DWC2_HAINT_CH15 BIT(15) -#define DWC2_HAINT_CHINT_MASK GENMASK(15, 0) -#define DWC2_HAINTMSK_CH0 BIT(0) -#define DWC2_HAINTMSK_CH1 BIT(1) -#define DWC2_HAINTMSK_CH2 BIT(2) -#define DWC2_HAINTMSK_CH3 BIT(3) -#define DWC2_HAINTMSK_CH4 BIT(4) -#define DWC2_HAINTMSK_CH5 BIT(5) -#define DWC2_HAINTMSK_CH6 BIT(6) -#define DWC2_HAINTMSK_CH7 BIT(7) -#define DWC2_HAINTMSK_CH8 BIT(8) -#define DWC2_HAINTMSK_CH9 BIT(9) -#define DWC2_HAINTMSK_CH10 BIT(10) -#define DWC2_HAINTMSK_CH11 BIT(11) -#define DWC2_HAINTMSK_CH12 BIT(12) -#define DWC2_HAINTMSK_CH13 BIT(13) -#define DWC2_HAINTMSK_CH14 BIT(14) -#define DWC2_HAINTMSK_CH15 BIT(15) -#define DWC2_HAINTMSK_CHINT_MASK GENMASK(15, 0) -#define DWC2_HCCHAR_MPS_MASK GENMASK(10, 0) -#define DWC2_HCCHAR_EPNUM_MASK GENMASK(14, 11) -#define DWC2_HCCHAR_EPDIR BIT(15) -#define DWC2_HCCHAR_LSPDDEV BIT(17) -#define DWC2_HCCHAR_EPTYPE_CONTROL 0 -#define DWC2_HCCHAR_EPTYPE_ISOC 1 -#define DWC2_HCCHAR_EPTYPE_BULK 2 -#define DWC2_HCCHAR_EPTYPE_INTR 3 -#define DWC2_HCCHAR_EPTYPE_MASK GENMASK(19, 18) -#define DWC2_HCCHAR_MULTICNT_MASK GENMASK(21, 20) -#define DWC2_HCCHAR_DEVADDR_MASK GENMASK(28, 22) -#define DWC2_HCCHAR_ODDFRM BIT(29) -#define DWC2_HCCHAR_CHDIS BIT(30) -#define DWC2_HCCHAR_CHEN BIT(31) -#define DWC2_HCSPLT_PRTADDR_MASK GENMASK(6, 0) -#define DWC2_HCSPLT_HUBADDR_MASK GENMASK(13, 7) -#define DWC2_HCSPLT_XACTPOS_MASK GENMASK(15, 14) -#define DWC2_HCSPLT_COMPSPLT BIT(16) -#define DWC2_HCSPLT_SPLTENA BIT(31) -#define DWC2_HCINT_XFERCOMP BIT(0) -#define DWC2_HCINT_CHHLTD BIT(1) -#define DWC2_HCINT_AHBERR BIT(2) -#define DWC2_HCINT_STALL BIT(3) -#define DWC2_HCINT_NAK BIT(4) -#define DWC2_HCINT_ACK BIT(5) -#define DWC2_HCINT_NYET BIT(6) -#define DWC2_HCINT_XACTERR BIT(7) -#define DWC2_HCINT_BBLERR BIT(8) -#define DWC2_HCINT_FRMOVRUN BIT(9) -#define DWC2_HCINT_DATATGLERR BIT(10) -#define DWC2_HCINT_BNA BIT(11) -#define DWC2_HCINT_XCS_XACT BIT(12) -#define DWC2_HCINT_FRM_LIST_ROLL BIT(13) -#define DWC2_HCINTMSK_XFERCOMPL BIT(0) -#define DWC2_HCINTMSK_CHHLTD BIT(1) -#define DWC2_HCINTMSK_AHBERR BIT(2) -#define DWC2_HCINTMSK_STALL BIT(3) -#define DWC2_HCINTMSK_NAK BIT(4) -#define DWC2_HCINTMSK_ACK BIT(5) -#define DWC2_HCINTMSK_NYET BIT(6) -#define DWC2_HCINTMSK_XACTERR BIT(7) -#define DWC2_HCINTMSK_BBLERR BIT(8) -#define DWC2_HCINTMSK_FRMOVRUN BIT(9) -#define DWC2_HCINTMSK_DATATGLERR BIT(10) -#define DWC2_HCINTMSK_BNA BIT(11) -#define DWC2_HCINTMSK_XCS_XACT BIT(12) -#define DWC2_HCINTMSK_FRM_LIST_ROLL BIT(13) -#define DWC2_HCTSIZ_XFERSIZE_MASK GENMASK(18, 0) -#define DWC2_HCTSIZ_SCHINFO_MASK GENMASK(7, 0) -#define DWC2_HCTSIZ_NTD_MASK GENMASK(15, 8) -#define DWC2_HCTSIZ_PKTCNT_MASK GENMASK(28, 19) -#define DWC2_HCTSIZ_PID_MASK GENMASK(30, 29) -#define DWC2_HCTSIZ_DOPNG BIT(31) -#define DWC2_HCDMA_CTD_MASK GENMASK(10, 3) -#define DWC2_HCDMA_DMA_ADDR_MASK GENMASK(31, 11) -#define DWC2_PCGCCTL_STOPPCLK BIT(0) -#define DWC2_PCGCCTL_GATEHCLK BIT(1) -#define DWC2_PCGCCTL_PWRCLMP BIT(2) -#define DWC2_PCGCCTL_RSTPDWNMODULE BIT(3) -#define DWC2_PCGCCTL_PHYSUSPENDED BIT(4) -#define DWC2_PCGCCTL_ENBL_SLEEP_GATING BIT(5) -#define DWC2_PCGCCTL_PHY_IN_SLEEP BIT(6) -#define DWC2_PCGCCTL_DEEP_SLEEP BIT(7) -#define DWC2_SNPSID_DEVID_VER_2xx (0x4f542 << 12) -#define DWC2_SNPSID_DEVID_VER_3xx (0x4f543 << 12) -#define DWC2_SNPSID_DEVID_MASK GENMASK(31, 12) +#define GOTGCTL_CHIRPEN BIT(27) +#define GOTGCTL_MULT_VALID_BC_MASK GENMASK(26, 22) +#define GOTGCTL_CURMODE_HOST BIT(21) +#define GOTGCTL_OTGVER BIT(20) +#define GOTGCTL_BSESVLD BIT(19) +#define GOTGCTL_ASESVLD BIT(18) +#define GOTGCTL_DBNC_SHORT BIT(17) +#define GOTGCTL_CONID_B BIT(16) +#define GOTGCTL_DBNCE_FLTR_BYPASS BIT(15) +#define GOTGCTL_DEVHNPEN BIT(11) +#define GOTGCTL_HSTSETHNPEN BIT(10) +#define GOTGCTL_HNPREQ BIT(9) +#define GOTGCTL_HSTNEGSCS BIT(8) +#define GOTGCTL_BVALOVAL BIT(7) +#define GOTGCTL_BVALOEN BIT(6) +#define GOTGCTL_AVALOVAL BIT(5) +#define GOTGCTL_AVALOEN BIT(4) +#define GOTGCTL_VBVALOVAL BIT(3) +#define GOTGCTL_VBVALOEN BIT(2) +#define GOTGCTL_SESREQ BIT(1) +#define GOTGCTL_SESREQSCS BIT(0) + +#define GOTGINT_DBNCE_DONE BIT(19) +#define GOTGINT_A_DEV_TOUT_CHG BIT(18) +#define GOTGINT_HST_NEG_DET BIT(17) +#define GOTGINT_HST_NEG_SUC_STS_CHNG BIT(9) +#define GOTGINT_SES_REQ_SUC_STS_CHNG BIT(8) +#define GOTGINT_SES_END_DET BIT(2) + +#define GAHBCFG_AHB_SINGLE BIT(23) +#define GAHBCFG_NOTI_ALL_DMA_WRIT BIT(22) +#define GAHBCFG_REM_MEM_SUPP BIT(21) +#define GAHBCFG_P_TXF_EMP_LVL BIT(8) +#define GAHBCFG_NP_TXF_EMP_LVL BIT(7) +#define GAHBCFG_DMA_EN BIT(5) +#define GAHBCFG_HBSTLEN_MASK GENMASK(4, 1) +#define GAHBCFG_HBSTLEN_SINGLE 0 +#define GAHBCFG_HBSTLEN_INCR 1 +#define GAHBCFG_HBSTLEN_INCR4 3 +#define GAHBCFG_HBSTLEN_INCR8 5 +#define GAHBCFG_HBSTLEN_INCR16 7 +#define GAHBCFG_GLBL_INTR_EN BIT(0) +#define GAHBCFG_CTRL_MASK (GAHBCFG_P_TXF_EMP_LVL | \ + GAHBCFG_NP_TXF_EMP_LVL | \ + GAHBCFG_DMA_EN | \ + GAHBCFG_GLBL_INTR_EN) + +#define GUSBCFG_FORCEDEVMODE BIT(30) +#define GUSBCFG_FORCEHOSTMODE BIT(29) +#define GUSBCFG_TXENDDELAY BIT(28) +#define GUSBCFG_ICTRAFFICPULLREMOVE BIT(27) +#define GUSBCFG_ICUSBCAP BIT(26) +#define GUSBCFG_ULPI_INT_PROT_DIS BIT(25) +#define GUSBCFG_INDICATORPASSTHROUGH BIT(24) +#define GUSBCFG_INDICATORCOMPLEMENT BIT(23) +#define GUSBCFG_TERMSELDLPULSE BIT(22) +#define GUSBCFG_ULPI_INT_VBUS_IND BIT(21) +#define GUSBCFG_ULPI_EXT_VBUS_DRV BIT(20) +#define GUSBCFG_ULPI_CLK_SUSP_M BIT(19) +#define GUSBCFG_ULPI_AUTO_RES BIT(18) +#define GUSBCFG_ULPI_FS_LS BIT(17) +#define GUSBCFG_OTG_UTMI_FS_SEL BIT(16) +#define GUSBCFG_PHY_LP_CLK_SEL BIT(15) +#define GUSBCFG_USBTRDTIM_MASK GENMASK(14, 10) +#define GUSBCFG_HNPCAP BIT(9) +#define GUSBCFG_SRPCAP BIT(8) +#define GUSBCFG_DDRSEL BIT(7) +#define GUSBCFG_PHYSEL BIT(6) +#define GUSBCFG_FSINTF BIT(5) +#define GUSBCFG_ULPI_UTMI_SEL BIT(4) +#define GUSBCFG_PHYIF16 BIT(3) +#define GUSBCFG_TOUTCAL_MASK GENMASK(2, 0) + +#define GRSTCTL_AHBIDLE BIT(31) +#define GRSTCTL_DMAREQ BIT(30) +#define GRSTCTL_CSFTRST_DONE BIT(29) +#define GRSTCTL_TXFNUM_MASK GENMASK(10, 6) +#define GRSTCTL_TXFFLSH BIT(5) +#define GRSTCTL_RXFFLSH BIT(4) +#define GRSTCTL_IN_TKNQ_FLSH BIT(3) +#define GRSTCTL_FRMCNTRRST BIT(2) +#define GRSTCTL_HSFTRST BIT(1) +#define GRSTCTL_CSFTRST BIT(0) +#define GRSTCTL_TXFNUM_ALL 0x10 + +#define GINTSTS_WKUPINT BIT(31) +#define GINTSTS_SESSREQINT BIT(30) +#define GINTSTS_DISCONNINT BIT(29) +#define GINTSTS_CONIDSTSCHNG BIT(28) +#define GINTSTS_LPMTRANRCVD BIT(27) +#define GINTSTS_PTXFEMP BIT(26) +#define GINTSTS_HCHINT BIT(25) +#define GINTSTS_PRTINT BIT(24) +#define GINTSTS_RESETDET BIT(23) +#define GINTSTS_FET_SUSP BIT(22) +#define GINTSTS_INCOMPL_IP BIT(21) +#define GINTSTS_INCOMPL_SOOUT BIT(21) +#define GINTSTS_INCOMPL_SOIN BIT(20) +#define GINTSTS_OEPINT BIT(19) +#define GINTSTS_IEPINT BIT(18) +#define GINTSTS_EPMIS BIT(17) +#define GINTSTS_RESTOREDONE BIT(16) +#define GINTSTS_EOPF BIT(15) +#define GINTSTS_ISOUTDROP BIT(14) +#define GINTSTS_ENUMDONE BIT(13) +#define GINTSTS_USBRST BIT(12) +#define GINTSTS_USBSUSP BIT(11) +#define GINTSTS_ERLYSUSP BIT(10) +#define GINTSTS_I2CINT BIT(9) +#define GINTSTS_ULPI_CK_INT BIT(8) +#define GINTSTS_GOUTNAKEFF BIT(7) +#define GINTSTS_GINNAKEFF BIT(6) +#define GINTSTS_NPTXFEMP BIT(5) +#define GINTSTS_RXFLVL BIT(4) +#define GINTSTS_SOF BIT(3) +#define GINTSTS_OTGINT BIT(2) +#define GINTSTS_MODEMIS BIT(1) +#define GINTSTS_CURMODE_HOST BIT(0) + +#define FIFOSIZE_DEPTH_MASK GENMASK(31, 16) +#define FIFOSIZE_STARTADDR_MASK GENMASK(15, 0) + +#define GI2CCTL_BSYDNE BIT(31) +#define GI2CCTL_RW BIT(30) +#define GI2CCTL_I2CDATSE0 BIT(28) +#define GI2CCTL_I2CDEVADDR_MASK GENMASK(27, 26) +#define GI2CCTL_I2CSUSPCTL BIT(25) +#define GI2CCTL_ACK BIT(24) +#define GI2CCTL_I2CEN BIT(23) +#define GI2CCTL_ADDR_MASK GENMASK(22, 16) +#define GI2CCTL_REGADDR_MASK GENMASK(15, 8) +#define GI2CCTL_RWDATA_MASK GENMASK(7, 0) + +#define GHWCFG2_OTG_ENABLE_IC_USB BIT(31) +#define GHWCFG2_DEV_TOKEN_Q_DEPTH_MASK GENMASK(30, 26) +#define GHWCFG2_HOST_PERIO_TX_Q_DEPTH_MASK GENMASK(25, 24) +#define GHWCFG2_NONPERIO_TX_Q_DEPTH_MASK GENMASK(23, 22) +#define GHWCFG2_MULTI_PROC_INT BIT(20) +#define GHWCFG2_DYNAMIC_FIFO BIT(19) +#define GHWCFG2_PERIO_EP_SUPPORTED BIT(18) +#define GHWCFG2_NUM_HOST_CHAN_MASK GENMASK(17, 14) +#define GHWCFG2_NUM_DEV_EP_MASK GENMASK(13, 10) +#define GHWCFG2_FS_PHY_TYPE_MASK GENMASK(9, 8) +#define GHWCFG2_FS_PHY_TYPE_NOT_SUPPORTED 0 +#define GHWCFG2_FS_PHY_TYPE_DEDICATED 1 +#define GHWCFG2_FS_PHY_TYPE_SHARED_UTMI 2 +#define GHWCFG2_FS_PHY_TYPE_SHARED_ULPI 3 +#define GHWCFG2_HS_PHY_TYPE_MASK GENMASK(7, 6) +#define GHWCFG2_HS_PHY_TYPE_NOT_SUPPORTED 0 +#define GHWCFG2_HS_PHY_TYPE_UTMI 1 +#define GHWCFG2_HS_PHY_TYPE_ULPI 2 +#define GHWCFG2_HS_PHY_TYPE_UTMI_ULPI 3 +#define GHWCFG2_POINT2POINT BIT(5) +#define GHWCFG2_ARCHITECTURE_MASK GENMASK(4, 3) +#define GHWCFG2_SLAVE_ONLY_ARCH 0 +#define GHWCFG2_EXT_DMA_ARCH 1 +#define GHWCFG2_INT_DMA_ARCH 2 +#define GHWCFG2_OP_MODE_MASK GENMASK(2, 0) +#define GHWCFG2_OP_MODE_HNP_SRP_CAPABLE 0 +#define GHWCFG2_OP_MODE_SRP_ONLY_CAPABLE 1 +#define GHWCFG2_OP_MODE_NO_HNP_SRP_CAPABLE 2 +#define GHWCFG2_OP_MODE_SRP_CAPABLE_DEVICE 3 +#define GHWCFG2_OP_MODE_NO_SRP_CAPABLE_DEVICE 4 +#define GHWCFG2_OP_MODE_SRP_CAPABLE_HOST 5 +#define GHWCFG2_OP_MODE_NO_SRP_CAPABLE_HOST 6 +#define GHWCFG2_OP_MODE_UNDEFINED 7 + +#define GHWCFG4_DESC_DMA_DYN BIT(31) +#define GHWCFG4_DESC_DMA BIT(30) +#define GHWCFG4_NUM_IN_EPS_MASK GENMASK(29, 26) +#define GHWCFG4_DED_FIFO_EN BIT(25) +#define GHWCFG4_SESSION_END_FILT_EN BIT(24) +#define GHWCFG4_B_VALID_FILT_EN BIT(23) +#define GHWCFG4_A_VALID_FILT_EN BIT(22) +#define GHWCFG4_VBUS_VALID_FILT_EN BIT(21) +#define GHWCFG4_IDDIG_FILT_EN BIT(20) +#define GHWCFG4_NUM_DEV_MODE_CTRL_EP_MASK GENMASK(19, 16) +#define GHWCFG4_UTMI_PHY_DATA_WIDTH_MASK GENMASK(15, 14) +#define GHWCFG4_UTMI_PHY_DATA_WIDTH_8 0 +#define GHWCFG4_UTMI_PHY_DATA_WIDTH_16 1 +#define GHWCFG4_UTMI_PHY_DATA_WIDTH_8_OR_16 2 +#define GHWCFG4_ACG_SUPPORTED BIT(12) +#define GHWCFG4_IPG_ISOC_SUPPORTED BIT(11) +#define GHWCFG4_SERVICE_INTERVAL_SUPPORTED BIT(10) +#define GHWCFG4_XHIBER BIT(7) +#define GHWCFG4_HIBER BIT(6) +#define GHWCFG4_MIN_AHB_FREQ BIT(5) +#define GHWCFG4_POWER_OPTIMIZ BIT(4) +#define GHWCFG4_NUM_DEV_PERIO_IN_EP_MASK GENMASK(3, 0) + +#define HCFG_MODECHTIMEN BIT(31) +#define HCFG_PERSCHEDENA BIT(26) +#define HCFG_FRLISTEN_MASK GENMASK(25, 24) +#define HCFG_FRLISTEN_8 0 +#define HCFG_FRLISTEN_16 1 +#define HCFG_FRLISTEN_32 2 +#define HCFG_FRLISTEN_64 3 +#define HCFG_DESCDMA BIT(23) +#define HCFG_RESVALID_MASK GENMASK(15, 8) +#define HCFG_ENA32KHZ BIT(7) +#define HCFG_FSLSSUPP BIT(2) +#define HCFG_FSLSPCLKSEL_MASK GENMASK(2, 0) +#define HCFG_FSLSPCLKSEL_30_60_MHZ 0 +#define HCFG_FSLSPCLKSEL_48_MHZ 1 +#define HCFG_FSLSPCLKSEL_6_MHZ 2 + +#define HFIR_FRINT_MASK GENMASK(15, 0) +#define HFIR_RLDCTRL BIT(16) + +#define HFNUM_FRREM_MASK GENMASK(31, 16) +#define HFNUM_FRNUM_MASK GENMASK(15, 0) + +#define HPRT0_SPD_MASK GENMASK(18, 17) +#define HPRT0_SPD_HIGH_SPEED 0 +#define HPRT0_SPD_FULL_SPEED 1 +#define HPRT0_SPD_LOW_SPEED 2 +#define HPRT0_TSTCTL_MASK GENMASK(16, 13) +#define HPRT0_PWR BIT(12) +#define HPRT0_LNSTS_MASK GENMASK(11, 10) +#define HPRT0_RST BIT(8) +#define HPRT0_SUSP BIT(7) +#define HPRT0_RES BIT(6) +#define HPRT0_OVRCURRCHG BIT(5) +#define HPRT0_OVRCURRACT BIT(4) +#define HPRT0_ENACHG BIT(3) +#define HPRT0_ENA BIT(2) +#define HPRT0_CONNDET BIT(1) +#define HPRT0_CONNSTS BIT(0) +#define HPRT0_W1C_MASK (HPRT0_CONNDET | \ + HPRT0_ENA | \ + HPRT0_ENACHG | \ + HPRT0_OVRCURRCHG) + +#define HCCHAR_CHENA BIT(31) +#define HCCHAR_CHDIS BIT(30) +#define HCCHAR_ODDFRM BIT(29) +#define HCCHAR_DEVADDR_MASK GENMASK(28, 22) +#define HCCHAR_MULTICNT_MASK GENMASK(21, 20) +#define HCCHAR_EPTYPE_MASK GENMASK(19, 18) +#define HCCHAR_EPTYPE_CONTROL 0 +#define HCCHAR_EPTYPE_ISOC 1 +#define HCCHAR_EPTYPE_BULK 2 +#define HCCHAR_EPTYPE_INTR 3 +#define HCCHAR_LSPDDEV BIT(17) +#define HCCHAR_EPDIR BIT(15) +#define HCCHAR_EPNUM_MASK GENMASK(14, 11) +#define HCCHAR_MPS_MASK GENMASK(10, 0) + +#define HCSPLT_SPLTENA BIT(31) +#define HCSPLT_COMPSPLT BIT(16) +#define HCSPLT_XACTPOS_MASK GENMASK(15, 14) +#define HCSPLT_XACTPOS_MID 0 +#define HCSPLT_XACTPOS_END 1 +#define HCSPLT_XACTPOS_BEGIN 2 +#define HCSPLT_XACTPOS_ALL 3 +#define HCSPLT_HUBADDR_MASK GENMASK(13, 7) +#define HCSPLT_PRTADDR_MASK GENMASK(6, 0) + +#define HCINTMSK_FRM_LIST_ROLL BIT(13) +#define HCINTMSK_XCS_XACT BIT(12) +#define HCINTMSK_BNA BIT(11) +#define HCINTMSK_DATATGLERR BIT(10) +#define HCINTMSK_FRMOVRUN BIT(9) +#define HCINTMSK_BBLERR BIT(8) +#define HCINTMSK_XACTERR BIT(7) +#define HCINTMSK_NYET BIT(6) +#define HCINTMSK_ACK BIT(5) +#define HCINTMSK_NAK BIT(4) +#define HCINTMSK_STALL BIT(3) +#define HCINTMSK_AHBERR BIT(2) +#define HCINTMSK_CHHLTD BIT(1) +#define HCINTMSK_XFERCOMPL BIT(0) + +#define TSIZ_DOPNG BIT(31) +#define TSIZ_SC_MC_PID_MASK GENMASK(30, 29) +#define TSIZ_SC_MC_PID_DATA0 0 +#define TSIZ_SC_MC_PID_DATA2 1 +#define TSIZ_SC_MC_PID_DATA1 2 +#define TSIZ_SC_MC_PID_MDATA 3 +#define TSIZ_SC_MC_PID_SETUP 3 +#define TSIZ_PKTCNT_MASK GENMASK(28, 19) +#define TSIZ_NTD_MASK GENMASK(15, 8) +#define TSIZ_SCHINFO_MASK GENMASK(7, 0) +#define TSIZ_XFERSIZE_MASK GENMASK(18, 0) + +#define GSNPSID_ID_MASK GENMASK(31, 16) +#define GSNPSID_OTG_ID 0x4f54 +#define GSNPSID_VER_MASK GENMASK(15, 0)
/* Host controller specific */ #define DWC2_HC_PID_DATA0 0
Some macros are shared between host and gadget code, causing duplicated definitions. Move DWC2 macro definitions from host and gadget code into a common header to reduce duplication.
Signed-off-by: Kongyang Liu seashell11234455@gmail.com Reviewed-by: Marek Vasut marex@denx.de Tested-by: Peter Robinson pbrobinson@gmail.com Signed-off-by: Junhui Liu junhui.liu@pigmoral.tech --- drivers/usb/common/dwc2_core.h | 430 +++++++++++++++++++++++++++++++++ drivers/usb/gadget/dwc2_udc_otg_regs.h | 154 +----------- drivers/usb/host/dwc2.h | 291 ---------------------- 3 files changed, 431 insertions(+), 444 deletions(-)
diff --git a/drivers/usb/common/dwc2_core.h b/drivers/usb/common/dwc2_core.h index 26483a57e7df58e2b9fe820367e1680b9251af8d..862d3b3691c9caf84590d34960df21117848df0a 100644 --- a/drivers/usb/common/dwc2_core.h +++ b/drivers/usb/common/dwc2_core.h @@ -7,6 +7,8 @@ #ifndef __DWC2_CORE_H_ #define __DWC2_CORE_H_
+#include <linux/bitops.h> + struct dwc2_global_regs { u32 gotgctl; /* 0x000 */ u32 gotgint; @@ -123,4 +125,432 @@ struct dwc2_core_regs { u8 ep_fifo[16][0x1000]; /* 0x1000 */ };
+/* Core Global Register */ +#define GOTGCTL_CHIRPEN BIT(27) +#define GOTGCTL_MULT_VALID_BC_MASK GENMASK(26, 22) +#define GOTGCTL_CURMODE_HOST BIT(21) +#define GOTGCTL_OTGVER BIT(20) +#define GOTGCTL_BSESVLD BIT(19) +#define GOTGCTL_ASESVLD BIT(18) +#define GOTGCTL_DBNC_SHORT BIT(17) +#define GOTGCTL_CONID_B BIT(16) +#define GOTGCTL_DBNCE_FLTR_BYPASS BIT(15) +#define GOTGCTL_DEVHNPEN BIT(11) +#define GOTGCTL_HSTSETHNPEN BIT(10) +#define GOTGCTL_HNPREQ BIT(9) +#define GOTGCTL_HSTNEGSCS BIT(8) +#define GOTGCTL_BVALOVAL BIT(7) +#define GOTGCTL_BVALOEN BIT(6) +#define GOTGCTL_AVALOVAL BIT(5) +#define GOTGCTL_AVALOEN BIT(4) +#define GOTGCTL_VBVALOVAL BIT(3) +#define GOTGCTL_VBVALOEN BIT(2) +#define GOTGCTL_SESREQ BIT(1) +#define GOTGCTL_SESREQSCS BIT(0) + +#define GOTGINT_DBNCE_DONE BIT(19) +#define GOTGINT_A_DEV_TOUT_CHG BIT(18) +#define GOTGINT_HST_NEG_DET BIT(17) +#define GOTGINT_HST_NEG_SUC_STS_CHNG BIT(9) +#define GOTGINT_SES_REQ_SUC_STS_CHNG BIT(8) +#define GOTGINT_SES_END_DET BIT(2) + +#define GAHBCFG_AHB_SINGLE BIT(23) +#define GAHBCFG_NOTI_ALL_DMA_WRIT BIT(22) +#define GAHBCFG_REM_MEM_SUPP BIT(21) +#define GAHBCFG_P_TXF_EMP_LVL BIT(8) +#define GAHBCFG_NP_TXF_EMP_LVL BIT(7) +#define GAHBCFG_DMA_EN BIT(5) +#define GAHBCFG_HBSTLEN_MASK GENMASK(4, 1) +#define GAHBCFG_HBSTLEN_SINGLE 0 +#define GAHBCFG_HBSTLEN_INCR 1 +#define GAHBCFG_HBSTLEN_INCR4 3 +#define GAHBCFG_HBSTLEN_INCR8 5 +#define GAHBCFG_HBSTLEN_INCR16 7 +#define GAHBCFG_GLBL_INTR_EN BIT(0) +#define GAHBCFG_CTRL_MASK (GAHBCFG_P_TXF_EMP_LVL | \ + GAHBCFG_NP_TXF_EMP_LVL | \ + GAHBCFG_DMA_EN | \ + GAHBCFG_GLBL_INTR_EN) + +#define GUSBCFG_FORCEDEVMODE BIT(30) +#define GUSBCFG_FORCEHOSTMODE BIT(29) +#define GUSBCFG_TXENDDELAY BIT(28) +#define GUSBCFG_ICTRAFFICPULLREMOVE BIT(27) +#define GUSBCFG_ICUSBCAP BIT(26) +#define GUSBCFG_ULPI_INT_PROT_DIS BIT(25) +#define GUSBCFG_INDICATORPASSTHROUGH BIT(24) +#define GUSBCFG_INDICATORCOMPLEMENT BIT(23) +#define GUSBCFG_TERMSELDLPULSE BIT(22) +#define GUSBCFG_ULPI_INT_VBUS_IND BIT(21) +#define GUSBCFG_ULPI_EXT_VBUS_DRV BIT(20) +#define GUSBCFG_ULPI_CLK_SUSP_M BIT(19) +#define GUSBCFG_ULPI_AUTO_RES BIT(18) +#define GUSBCFG_ULPI_FS_LS BIT(17) +#define GUSBCFG_OTG_UTMI_FS_SEL BIT(16) +#define GUSBCFG_PHY_LP_CLK_SEL BIT(15) +#define GUSBCFG_USBTRDTIM_MASK GENMASK(14, 10) +#define GUSBCFG_HNPCAP BIT(9) +#define GUSBCFG_SRPCAP BIT(8) +#define GUSBCFG_DDRSEL BIT(7) +#define GUSBCFG_PHYSEL BIT(6) +#define GUSBCFG_FSINTF BIT(5) +#define GUSBCFG_ULPI_UTMI_SEL BIT(4) +#define GUSBCFG_PHYIF16 BIT(3) +#define GUSBCFG_TOUTCAL_MASK GENMASK(2, 0) + +#define GRSTCTL_AHBIDLE BIT(31) +#define GRSTCTL_DMAREQ BIT(30) +#define GRSTCTL_CSFTRST_DONE BIT(29) +#define GRSTCTL_TXFNUM_MASK GENMASK(10, 6) +#define GRSTCTL_TXFFLSH BIT(5) +#define GRSTCTL_RXFFLSH BIT(4) +#define GRSTCTL_IN_TKNQ_FLSH BIT(3) +#define GRSTCTL_FRMCNTRRST BIT(2) +#define GRSTCTL_HSFTRST BIT(1) +#define GRSTCTL_CSFTRST BIT(0) +#define GRSTCTL_TXFNUM_ALL 0x10 + +#define GINTSTS_WKUPINT BIT(31) +#define GINTSTS_SESSREQINT BIT(30) +#define GINTSTS_DISCONNINT BIT(29) +#define GINTSTS_CONIDSTSCHNG BIT(28) +#define GINTSTS_LPMTRANRCVD BIT(27) +#define GINTSTS_PTXFEMP BIT(26) +#define GINTSTS_HCHINT BIT(25) +#define GINTSTS_PRTINT BIT(24) +#define GINTSTS_RESETDET BIT(23) +#define GINTSTS_FET_SUSP BIT(22) +#define GINTSTS_INCOMPL_IP BIT(21) +#define GINTSTS_INCOMPL_SOOUT BIT(21) +#define GINTSTS_INCOMPL_SOIN BIT(20) +#define GINTSTS_OEPINT BIT(19) +#define GINTSTS_IEPINT BIT(18) +#define GINTSTS_EPMIS BIT(17) +#define GINTSTS_RESTOREDONE BIT(16) +#define GINTSTS_EOPF BIT(15) +#define GINTSTS_ISOUTDROP BIT(14) +#define GINTSTS_ENUMDONE BIT(13) +#define GINTSTS_USBRST BIT(12) +#define GINTSTS_USBSUSP BIT(11) +#define GINTSTS_ERLYSUSP BIT(10) +#define GINTSTS_I2CINT BIT(9) +#define GINTSTS_ULPI_CK_INT BIT(8) +#define GINTSTS_GOUTNAKEFF BIT(7) +#define GINTSTS_GINNAKEFF BIT(6) +#define GINTSTS_NPTXFEMP BIT(5) +#define GINTSTS_RXFLVL BIT(4) +#define GINTSTS_SOF BIT(3) +#define GINTSTS_OTGINT BIT(2) +#define GINTSTS_MODEMIS BIT(1) +#define GINTSTS_CURMODE_HOST BIT(0) + +#define GRXSTS_FN_MASK GENMASK(31, 25) +#define GRXSTS_PKTSTS_MASK GENMASK(20, 17) +#define GRXSTS_PKTSTS_GLOBALOUTNAK 1 +#define GRXSTS_PKTSTS_OUTRX 2 +#define GRXSTS_PKTSTS_HCHIN 2 +#define GRXSTS_PKTSTS_OUTDONE 3 +#define GRXSTS_PKTSTS_HCHIN_XFER_COMP 3 +#define GRXSTS_PKTSTS_SETUPDONE 4 +#define GRXSTS_PKTSTS_DATATOGGLEERR 5 +#define GRXSTS_PKTSTS_SETUPRX 6 +#define GRXSTS_PKTSTS_HCHHALTED 7 +#define GRXSTS_DPID_MASK GENMASK(16, 15) +#define GRXSTS_BYTECNT_MASK GENMASK(14, 4) +#define GRXSTS_HCHNUM_MASK GENMASK(3, 0) + +#define GRXFSIZ_DEPTH_MASK GENMASK(15, 0) + +#define GI2CCTL_BSYDNE BIT(31) +#define GI2CCTL_RW BIT(30) +#define GI2CCTL_I2CDATSE0 BIT(28) +#define GI2CCTL_I2CDEVADDR_MASK GENMASK(27, 26) +#define GI2CCTL_I2CSUSPCTL BIT(25) +#define GI2CCTL_ACK BIT(24) +#define GI2CCTL_I2CEN BIT(23) +#define GI2CCTL_ADDR_MASK GENMASK(22, 16) +#define GI2CCTL_REGADDR_MASK GENMASK(15, 8) +#define GI2CCTL_RWDATA_MASK GENMASK(7, 0) + +#define GGPIO_STM32_OTG_GCCFG_IDEN BIT(22) +#define GGPIO_STM32_OTG_GCCFG_VBDEN BIT(21) +#define GGPIO_STM32_OTG_GCCFG_PWRDWN BIT(16) + +#define GSNPSID_ID_MASK GENMASK(31, 16) +#define GSNPSID_OTG_ID 0x4f54 +#define GSNPSID_VER_MASK GENMASK(15, 0) + +#define GHWCFG2_OTG_ENABLE_IC_USB BIT(31) +#define GHWCFG2_DEV_TOKEN_Q_DEPTH_MASK GENMASK(30, 26) +#define GHWCFG2_HOST_PERIO_TX_Q_DEPTH_MASK GENMASK(25, 24) +#define GHWCFG2_NONPERIO_TX_Q_DEPTH_MASK GENMASK(23, 22) +#define GHWCFG2_MULTI_PROC_INT BIT(20) +#define GHWCFG2_DYNAMIC_FIFO BIT(19) +#define GHWCFG2_PERIO_EP_SUPPORTED BIT(18) +#define GHWCFG2_NUM_HOST_CHAN_MASK GENMASK(17, 14) +#define GHWCFG2_NUM_DEV_EP_MASK GENMASK(13, 10) +#define GHWCFG2_FS_PHY_TYPE_MASK GENMASK(9, 8) +#define GHWCFG2_FS_PHY_TYPE_NOT_SUPPORTED 0 +#define GHWCFG2_FS_PHY_TYPE_DEDICATED 1 +#define GHWCFG2_FS_PHY_TYPE_SHARED_UTMI 2 +#define GHWCFG2_FS_PHY_TYPE_SHARED_ULPI 3 +#define GHWCFG2_HS_PHY_TYPE_MASK GENMASK(7, 6) +#define GHWCFG2_HS_PHY_TYPE_NOT_SUPPORTED 0 +#define GHWCFG2_HS_PHY_TYPE_UTMI 1 +#define GHWCFG2_HS_PHY_TYPE_ULPI 2 +#define GHWCFG2_HS_PHY_TYPE_UTMI_ULPI 3 +#define GHWCFG2_POINT2POINT BIT(5) +#define GHWCFG2_ARCHITECTURE_MASK GENMASK(4, 3) +#define GHWCFG2_SLAVE_ONLY_ARCH 0 +#define GHWCFG2_EXT_DMA_ARCH 1 +#define GHWCFG2_INT_DMA_ARCH 2 +#define GHWCFG2_OP_MODE_MASK GENMASK(2, 0) +#define GHWCFG2_OP_MODE_HNP_SRP_CAPABLE 0 +#define GHWCFG2_OP_MODE_SRP_ONLY_CAPABLE 1 +#define GHWCFG2_OP_MODE_NO_HNP_SRP_CAPABLE 2 +#define GHWCFG2_OP_MODE_SRP_CAPABLE_DEVICE 3 +#define GHWCFG2_OP_MODE_NO_SRP_CAPABLE_DEVICE 4 +#define GHWCFG2_OP_MODE_SRP_CAPABLE_HOST 5 +#define GHWCFG2_OP_MODE_NO_SRP_CAPABLE_HOST 6 +#define GHWCFG2_OP_MODE_UNDEFINED 7 + +#define GHWCFG4_DESC_DMA_DYN BIT(31) +#define GHWCFG4_DESC_DMA BIT(30) +#define GHWCFG4_NUM_IN_EPS_MASK GENMASK(29, 26) +#define GHWCFG4_DED_FIFO_EN BIT(25) +#define GHWCFG4_SESSION_END_FILT_EN BIT(24) +#define GHWCFG4_B_VALID_FILT_EN BIT(23) +#define GHWCFG4_A_VALID_FILT_EN BIT(22) +#define GHWCFG4_VBUS_VALID_FILT_EN BIT(21) +#define GHWCFG4_IDDIG_FILT_EN BIT(20) +#define GHWCFG4_NUM_DEV_MODE_CTRL_EP_MASK GENMASK(19, 16) +#define GHWCFG4_UTMI_PHY_DATA_WIDTH_MASK GENMASK(15, 14) +#define GHWCFG4_UTMI_PHY_DATA_WIDTH_8 0 +#define GHWCFG4_UTMI_PHY_DATA_WIDTH_16 1 +#define GHWCFG4_UTMI_PHY_DATA_WIDTH_8_OR_16 2 +#define GHWCFG4_ACG_SUPPORTED BIT(12) +#define GHWCFG4_IPG_ISOC_SUPPORTED BIT(11) +#define GHWCFG4_SERVICE_INTERVAL_SUPPORTED BIT(10) +#define GHWCFG4_XHIBER BIT(7) +#define GHWCFG4_HIBER BIT(6) +#define GHWCFG4_MIN_AHB_FREQ BIT(5) +#define GHWCFG4_POWER_OPTIMIZ BIT(4) +#define GHWCFG4_NUM_DEV_PERIO_IN_EP_MASK GENMASK(3, 0) + +#define FIFOSIZE_DEPTH_MASK GENMASK(31, 16) +#define FIFOSIZE_STARTADDR_MASK GENMASK(15, 0) + +/* Host Register */ +#define HCFG_MODECHTIMEN BIT(31) +#define HCFG_PERSCHEDENA BIT(26) +#define HCFG_FRLISTEN_MASK GENMASK(25, 24) +#define HCFG_FRLISTEN_8 0 +#define HCFG_FRLISTEN_16 1 +#define HCFG_FRLISTEN_32 2 +#define HCFG_FRLISTEN_64 3 +#define HCFG_DESCDMA BIT(23) +#define HCFG_RESVALID_MASK GENMASK(15, 8) +#define HCFG_ENA32KHZ BIT(7) +#define HCFG_FSLSSUPP BIT(2) +#define HCFG_FSLSPCLKSEL_MASK GENMASK(2, 0) +#define HCFG_FSLSPCLKSEL_30_60_MHZ 0 +#define HCFG_FSLSPCLKSEL_48_MHZ 1 +#define HCFG_FSLSPCLKSEL_6_MHZ 2 + +#define HFNUM_FRREM_MASK GENMASK(31, 16) +#define HFNUM_FRNUM_MASK GENMASK(15, 0) + +#define HPRT0_SPD_MASK GENMASK(18, 17) +#define HPRT0_SPD_HIGH_SPEED 0 +#define HPRT0_SPD_FULL_SPEED 1 +#define HPRT0_SPD_LOW_SPEED 2 +#define HPRT0_TSTCTL_MASK GENMASK(16, 13) +#define HPRT0_PWR BIT(12) +#define HPRT0_LNSTS_MASK GENMASK(11, 10) +#define HPRT0_RST BIT(8) +#define HPRT0_SUSP BIT(7) +#define HPRT0_RES BIT(6) +#define HPRT0_OVRCURRCHG BIT(5) +#define HPRT0_OVRCURRACT BIT(4) +#define HPRT0_ENACHG BIT(3) +#define HPRT0_ENA BIT(2) +#define HPRT0_CONNDET BIT(1) +#define HPRT0_CONNSTS BIT(0) +#define HPRT0_W1C_MASK (HPRT0_CONNDET | \ + HPRT0_ENA | \ + HPRT0_ENACHG | \ + HPRT0_OVRCURRCHG) + +#define HCCHAR_CHENA BIT(31) +#define HCCHAR_CHDIS BIT(30) +#define HCCHAR_ODDFRM BIT(29) +#define HCCHAR_DEVADDR_MASK GENMASK(28, 22) +#define HCCHAR_MULTICNT_MASK GENMASK(21, 20) +#define HCCHAR_EPTYPE_MASK GENMASK(19, 18) +#define HCCHAR_EPTYPE_CONTROL 0 +#define HCCHAR_EPTYPE_ISOC 1 +#define HCCHAR_EPTYPE_BULK 2 +#define HCCHAR_EPTYPE_INTR 3 +#define HCCHAR_LSPDDEV BIT(17) +#define HCCHAR_EPDIR BIT(15) +#define HCCHAR_EPNUM_MASK GENMASK(14, 11) +#define HCCHAR_MPS_MASK GENMASK(10, 0) + +#define HCSPLT_SPLTENA BIT(31) +#define HCSPLT_COMPSPLT BIT(16) +#define HCSPLT_XACTPOS_MASK GENMASK(15, 14) +#define HCSPLT_XACTPOS_MID 0 +#define HCSPLT_XACTPOS_END 1 +#define HCSPLT_XACTPOS_BEGIN 2 +#define HCSPLT_XACTPOS_ALL 3 +#define HCSPLT_HUBADDR_MASK GENMASK(13, 7) +#define HCSPLT_PRTADDR_MASK GENMASK(6, 0) + +#define HCINTMSK_FRM_LIST_ROLL BIT(13) +#define HCINTMSK_XCS_XACT BIT(12) +#define HCINTMSK_BNA BIT(11) +#define HCINTMSK_DATATGLERR BIT(10) +#define HCINTMSK_FRMOVRUN BIT(9) +#define HCINTMSK_BBLERR BIT(8) +#define HCINTMSK_XACTERR BIT(7) +#define HCINTMSK_NYET BIT(6) +#define HCINTMSK_ACK BIT(5) +#define HCINTMSK_NAK BIT(4) +#define HCINTMSK_STALL BIT(3) +#define HCINTMSK_AHBERR BIT(2) +#define HCINTMSK_CHHLTD BIT(1) +#define HCINTMSK_XFERCOMPL BIT(0) + +#define TSIZ_DOPNG BIT(31) +#define TSIZ_SC_MC_PID_MASK GENMASK(30, 29) +#define TSIZ_SC_MC_PID_DATA0 0 +#define TSIZ_SC_MC_PID_DATA2 1 +#define TSIZ_SC_MC_PID_DATA1 2 +#define TSIZ_SC_MC_PID_MDATA 3 +#define TSIZ_SC_MC_PID_SETUP 3 +#define TSIZ_PKTCNT_MASK GENMASK(28, 19) +#define TSIZ_NTD_MASK GENMASK(15, 8) +#define TSIZ_SCHINFO_MASK GENMASK(7, 0) +#define TSIZ_XFERSIZE_MASK GENMASK(18, 0) + +/* Device Mode Register */ +#define DCFG_DESCDMA_EN BIT(23) +#define DCFG_EPMISCNT_MASK GENMASK(22, 18) +#define DCFG_IPG_ISOC_SUPPORDED BIT(17) +#define DCFG_PERFRINT_MASK GENMASK(12, 11) +#define DCFG_DEVADDR_MASK GENMASK(10, 4) +#define DCFG_NZ_STS_OUT_HSHK BIT(2) +#define DCFG_DEVSPD_MASK GENMASK(1, 0) +#define DCFG_DEVSPD_HS 0 +#define DCFG_DEVSPD_FS 1 +#define DCFG_DEVSPD_LS 2 +#define DCFG_DEVSPD_FS48 3 + +#define DCTL_SERVICE_INTERVAL_SUPPORTED BIT(19) +#define DCTL_PWRONPRGDONE BIT(11) +#define DCTL_CGOUTNAK BIT(10) +#define DCTL_SGOUTNAK BIT(9) +#define DCTL_CGNPINNAK BIT(8) +#define DCTL_SGNPINNAK BIT(7) +#define DCTL_TSTCTL_MASK GENMASK(6, 4) +#define DCTL_GOUTNAKSTS BIT(3) +#define DCTL_GNPINNAKSTS BIT(2) +#define DCTL_SFTDISCON BIT(1) +#define DCTL_RMTWKUPSIG BIT(0) + +#define DSTS_SOFFN_MASK GENMASK(21, 8) +#define DSTS_ERRATICERR BIT(3) +#define DSTS_ENUMSPD_MASK GENMASK(2, 1) +#define DSTS_ENUMSPD_HS 0 +#define DSTS_ENUMSPD_FS 1 +#define DSTS_ENUMSPD_LS 2 +#define DSTS_ENUMSPD_FS48 3 +#define DSTS_SUSPSTS BIT(0) + +#define DIEPMSK_NAKMSK BIT(13) +#define DIEPMSK_BNAININTRMSK BIT(9) +#define DIEPMSK_TXFIFOUNDRNMSK BIT(8) +#define DIEPMSK_TXFIFOEMPTY BIT(7) +#define DIEPMSK_INEPNAKEFFMSK BIT(6) +#define DIEPMSK_INTKNEPMISMSK BIT(5) +#define DIEPMSK_INTKNTXFEMPMSK BIT(4) +#define DIEPMSK_TIMEOUTMSK BIT(3) +#define DIEPMSK_AHBERRMSK BIT(2) +#define DIEPMSK_EPDISBLDMSK BIT(1) +#define DIEPMSK_XFERCOMPLMSK BIT(0) + +#define DOEPMSK_BNAMSK BIT(9) +#define DOEPMSK_BACK2BACKSETUP BIT(6) +#define DOEPMSK_STSPHSERCVDMSK BIT(5) +#define DOEPMSK_OUTTKNEPDISMSK BIT(4) +#define DOEPMSK_SETUPMSK BIT(3) +#define DOEPMSK_AHBERRMSK BIT(2) +#define DOEPMSK_EPDISBLDMSK BIT(1) +#define DOEPMSK_XFERCOMPLMSK BIT(0) + +#define DAINT_OUTEP_MASK GENMASK(31, 16) +#define DAINT_INEP_MASK GENMASK(15, 0) + +#define D0EPCTL_MPS_MASK GENMASK(1, 0) +#define D0EPCTL_MPS_64 0 +#define D0EPCTL_MPS_32 1 +#define D0EPCTL_MPS_16 2 +#define D0EPCTL_MPS_8 3 + +#define DXEPCTL_EPENA BIT(31) +#define DXEPCTL_EPDIS BIT(30) +#define DXEPCTL_SETD1PID BIT(29) +#define DXEPCTL_SETODDFR BIT(29) +#define DXEPCTL_SETD0PID BIT(28) +#define DXEPCTL_SETEVENFR BIT(28) +#define DXEPCTL_SNAK BIT(27) +#define DXEPCTL_CNAK BIT(26) +#define DXEPCTL_TXFNUM_MASK GENMASK(25, 22) +#define DXEPCTL_STALL BIT(21) +#define DXEPCTL_SNP BIT(20) +#define DXEPCTL_EPTYPE_MASK GENMASK(19, 18) +#define DXEPCTL_EPTYPE_CONTROL 0 +#define DXEPCTL_EPTYPE_ISO 1 +#define DXEPCTL_EPTYPE_BULK 2 +#define DXEPCTL_EPTYPE_INTERRUPT 3 +#define DXEPCTL_NAKSTS BIT(17) +#define DXEPCTL_DPID BIT(16) +#define DXEPCTL_EOFRNUM BIT(16) +#define DXEPCTL_USBACTEP BIT(15) +#define DXEPCTL_NEXTEP_MASK GENMASK(14, 11) +#define DXEPCTL_MPS_MASK GENMASK(10, 0) + +#define DXEPINT_SETUP_RCVD BIT(15) +#define DXEPINT_NYETINTRPT BIT(14) +#define DXEPINT_NAKINTRPT BIT(13) +#define DXEPINT_BBLEERRINTRPT BIT(12) +#define DXEPINT_PKTDRPSTS BIT(11) +#define DXEPINT_BNAINTR BIT(9) +#define DXEPINT_TXFIFOUNDRN BIT(8) +#define DXEPINT_OUTPKTERR BIT(8) +#define DXEPINT_TXFEMP BIT(7) +#define DXEPINT_INEPNAKEFF BIT(6) +#define DXEPINT_BACK2BACKSETUP BIT(6) +#define DXEPINT_INTKNEPMIS BIT(5) +#define DXEPINT_STSPHSERCVD BIT(5) +#define DXEPINT_INTKNTXFEMP BIT(4) +#define DXEPINT_OUTTKNEPDIS BIT(4) +#define DXEPINT_TIMEOUT BIT(3) +#define DXEPINT_SETUP BIT(3) +#define DXEPINT_AHBERR BIT(2) +#define DXEPINT_EPDISBLD BIT(1) +#define DXEPINT_XFERCOMPL BIT(0) + +#define DIEPTSIZ0_PKTCNT_MASK GENMASK(20, 19) +#define DIEPTSIZ0_XFERSIZE_MASK GENMASK(6, 0) + +#define DOEPTSIZ0_SUPCNT_MASK GENMASK(30, 29) +#define DOEPTSIZ0_PKTCNT BIT(19) +#define DOEPTSIZ0_XFERSIZE_MASK GENMASK(6, 0) + +#define DXEPTSIZ_MC_MASK GENMASK(30, 29) +#define DXEPTSIZ_PKTCNT_MASK GENMASK(28, 19) +#define DXEPTSIZ_XFERSIZE_MASK GENMASK(18, 0) + #endif /* __DWC2_CORE_H_ */ diff --git a/drivers/usb/gadget/dwc2_udc_otg_regs.h b/drivers/usb/gadget/dwc2_udc_otg_regs.h index 6aec55970db682ef8a21fad0b47144a4a87a47ca..5dd2d3a45bf90eb09bd681bca14df7bc3e3f9a78 100644 --- a/drivers/usb/gadget/dwc2_udc_otg_regs.h +++ b/drivers/usb/gadget/dwc2_udc_otg_regs.h @@ -10,7 +10,7 @@ #ifndef __ASM_ARCH_REGS_USB_OTG_HS_H #define __ASM_ARCH_REGS_USB_OTG_HS_H
-#include <linux/bitops.h> +#include "../common/dwc2_core.h"
struct dwc2_usbotg_phy { u32 phypwr; @@ -18,58 +18,6 @@ struct dwc2_usbotg_phy { u32 rstcon; };
-/*===================================================================== */ -/*definitions related to CSR setting */ - -/* DWC2_UDC_OTG_GOTGCTL */ -#define GOTGCTL_BSESVLD BIT(19) -#define GOTGCTL_ASESVLD BIT(18) -#define GOTGCTL_BVALOVAL BIT(7) -#define GOTGCTL_BVALOEN BIT(6) -#define GOTGCTL_AVALOVAL BIT(5) -#define GOTGCTL_AVALOEN BIT(4) -#define GOTGCTL_VBVALOVAL BIT(3) -#define GOTGCTL_VBVALOEN BIT(2) - -/* DWC2_UDC_OTG_GOTINT */ -#define GOTGINT_SES_END_DET BIT(2) - -/* DWC2_UDC_OTG_GAHBCFG */ -#define GAHBCFG_AHB_SINGLE BIT(23) -#define GAHBCFG_NOTI_ALL_DMA_WRIT BIT(22) -#define GAHBCFG_REM_MEM_SUPP BIT(21) -#define GAHBCFG_P_TXF_EMP_LVL BIT(8) -#define GAHBCFG_NP_TXF_EMP_LVL BIT(7) -#define GAHBCFG_DMA_EN BIT(5) -#define GAHBCFG_HBSTLEN_MASK GENMASK(4, 1) -#define GAHBCFG_HBSTLEN_SINGLE 0 -#define GAHBCFG_HBSTLEN_INCR 1 -#define GAHBCFG_HBSTLEN_INCR4 3 -#define GAHBCFG_HBSTLEN_INCR8 5 -#define GAHBCFG_HBSTLEN_INCR16 7 -#define GAHBCFG_GLBL_INTR_EN BIT(0) - -/* DWC2_UDC_OTG_GRSTCTL */ -#define GRSTCTL_AHBIDLE BIT(31) -#define GRSTCTL_CSFTRST BIT(0) - -/* DWC2_UDC_OTG_GINTSTS/DWC2_UDC_OTG_GINTMSK core interrupt register */ -#define GINTSTS_WKUPINT BIT(31) -#define GINTSTS_DISCONNINT BIT(29) -#define GINTSTS_CONIDSTSCHNG BIT(28) -#define GINTSTS_OEPINT BIT(19) -#define GINTSTS_IEPINT BIT(18) -#define GINTSTS_ENUMDONE BIT(13) -#define GINTSTS_USBRST BIT(12) -#define GINTSTS_USBSUSP BIT(11) -#define GINTSTS_ERLYSUSP BIT(10) -#define GINTSTS_NPTXFEMP BIT(5) -#define GINTSTS_RXFLVL BIT(4) -#define GINTSTS_SOF BIT(3) -#define GINTSTS_OTGINT BIT(2) -#define GINTSTS_MODEMIS BIT(1) -#define GINTSTS_CURMODE_HOST BIT(0) - #define FULL_SPEED_CONTROL_PKT_SIZE 8 #define FULL_SPEED_BULK_PKT_SIZE 64
@@ -80,69 +28,6 @@ struct dwc2_usbotg_phy { #define NPTX_FIFO_SIZE 1024 #define PTX_FIFO_SIZE 384
-#define FIFOSIZE_DEPTH_MASK GENMASK(31, 16) -#define FIFOSIZE_STARTADDR_MASK GENMASK(15, 0) - -/* Enumeration speed */ -#define DSTS_ENUMSPD_MASK GENMASK(2, 1) -#define DSTS_ENUMSPD_HS 0 -#define DSTS_ENUMSPD_FS 1 -#define DSTS_ENUMSPD_LS 2 - -/* DWC2_UDC_OTG_DCTL device control register */ -#define DCTL_SFTDISCON BIT(1) -#define DCTL_RMTWKUPSIG BIT(0) - -/* DWC2_UDC_OTG_DAINT device all endpoint interrupt register */ -#define DAINT_OUTEP_MASK GENMASK(31, 16) -#define DAINT_INEP_MASK GENMASK(15, 0) - -/* DWC2_UDC_OTG_DIEPCTL0/DOEPCTL0 device - control IN/OUT endpoint 0 control register */ -#define DXEPCTL_EPENA BIT(31) -#define DXEPCTL_EPDIS BIT(30) -#define DXEPCTL_SETD1PID BIT(29) -#define DXEPCTL_SETODDFR BIT(29) -#define DXEPCTL_SETD0PID BIT(28) -#define DXEPCTL_SETEVENFR BIT(28) -#define DXEPCTL_SNAK BIT(27) -#define DXEPCTL_CNAK BIT(26) -#define DXEPCTL_STALL BIT(21) -#define DXEPCTL_EPTYPE_MASK GENMASK(19, 18) -#define DXEPCTL_EPTYPE_CONTROL 0 -#define DXEPCTL_EPTYPE_ISO 1 -#define DXEPCTL_EPTYPE_BULK 2 -#define DXEPCTL_EPTYPE_INTERRUPT 3 -#define DXEPCTL_EOFRNUM BIT(16) -#define DXEPCTL_USBACTEP BIT(15) -#define DXEPCTL_NEXTEP_MASK GENMASK(14, 11) -#define DXEPCTL_MPS_MASK GENMASK(10, 0) - - -/* DWC2_UDC_OTG_DIEPMSK/DOEPMSK device IN/OUT endpoint - common interrupt mask register */ -/* DWC2_UDC_OTG_DIEPINTn/DOEPINTn device IN/OUT endpoint interrupt register */ -#define DIEPMSK_NAKMSK BIT(13) -#define DIEPMSK_BNAININTRMSK BIT(9) -#define DIEPMSK_TXFIFOUNDRNMSK BIT(8) -#define DIEPMSK_TXFIFOEMPTY BIT(7) -#define DIEPMSK_INEPNAKEFFMSK BIT(6) -#define DIEPMSK_INTKNEPMISMSK BIT(5) -#define DIEPMSK_INTKNTXFEMPMSK BIT(4) -#define DIEPMSK_TIMEOUTMSK BIT(3) -#define DIEPMSK_AHBERRMSK BIT(2) -#define DIEPMSK_EPDISBLDMSK BIT(1) -#define DIEPMSK_XFERCOMPLMSK BIT(0) - -#define DOEPMSK_BNAMSK BIT(9) -#define DOEPMSK_BACK2BACKSETUP BIT(6) -#define DOEPMSK_STSPHSERCVDMSK BIT(5) -#define DOEPMSK_OUTTKNEPDISMSK BIT(4) -#define DOEPMSK_SETUPMSK BIT(3) -#define DOEPMSK_AHBERRMSK BIT(2) -#define DOEPMSK_EPDISBLDMSK BIT(1) -#define DOEPMSK_XFERCOMPLMSK BIT(0) - #define USB_PHY_CTRL_EN0 BIT(0)
/* OPHYPWR */ @@ -171,21 +56,6 @@ struct dwc2_usbotg_phy { #define EXYNOS4X12_CLK_SEL_12MHZ (0x02 << 0) #define EXYNOS4X12_CLK_SEL_24MHZ (0x05 << 0)
-/* Device Configuration Register DCFG */ -#define DCFG_EPMISCNT_MASK GENMASK(22, 18) -#define DCFG_DEVADDR_MASK GENMASK(10, 4) -#define DCFG_DEVSPD_MASK GENMASK(1, 0) -#define DCFG_DEVSPD_HS 0 -#define DCFG_DEVSPD_FS 1 -#define DCFG_DEVSPD_LS 2 -#define DCFG_DEVSPD_FS48 3 - -/* Core Reset Register (GRSTCTL) */ -#define GRSTCTL_TXFNUM_MASK GENMASK(10, 6) -#define GRSTCTL_TXFFLSH BIT(5) -#define GRSTCTL_RXFFLSH BIT(4) -#define GRSTCTL_TXFNUM_ALL 0x10 - /* Masks definitions */ #define GINTMSK_INIT (GINTSTS_WKUPINT | GINTSTS_OEPINT | GINTSTS_IEPINT | GINTSTS_ENUMDONE | \ GINTSTS_USBRST | GINTSTS_USBSUSP | GINTSTS_OTGINT) @@ -195,26 +65,4 @@ struct dwc2_usbotg_phy { FIELD_PREP(GAHBCFG_HBSTLEN_MASK, GAHBCFG_HBSTLEN_INCR4) | \ GAHBCFG_GLBL_INTR_EN)
-/* Device Endpoint X Transfer Size Register (DIEPTSIZX/DOEPTSIZX) */ -#define DIEPTSIZ0_PKTCNT_MASK GENMASK(20, 19) -#define DIEPTSIZ0_XFERSIZE_MASK GENMASK(6, 0) - -#define DOEPTSIZ0_SUPCNT_MASK GENMASK(30, 29) -#define DOEPTSIZ0_PKTCNT BIT(19) -#define DOEPTSIZ0_XFERSIZE_MASK GENMASK(6, 0) - -#define DXEPTSIZ_MC_MASK GENMASK(30, 29) -#define DXEPTSIZ_PKTCNT_MASK GENMASK(28, 19) -#define DXEPTSIZ_XFERSIZE_MASK GENMASK(18, 0) - -/* Device Endpoint-N Control Register (DIEPCTLn/DOEPCTLn) */ -#define DXEPCTL_TXFNUM_MASK GENMASK(25, 22) - -/* User HW Config4 */ -#define GHWCFG4_NUM_IN_EPS_MASK GENMASK(29, 26) - -/* OTG general core configuration register (OTG_GCCFG:0x38) for STM32MP1 */ -#define GGPIO_STM32_OTG_GCCFG_VBDEN BIT(21) -#define GGPIO_STM32_OTG_GCCFG_IDEN BIT(22) - #endif diff --git a/drivers/usb/host/dwc2.h b/drivers/usb/host/dwc2.h index a01edc5eff3ac8ef89addff29d2df26952288ccc..f0bb29496490463458ad5d61e7902934fb638bcd 100644 --- a/drivers/usb/host/dwc2.h +++ b/drivers/usb/host/dwc2.h @@ -6,297 +6,6 @@ #ifndef __DWC2_H__ #define __DWC2_H__
-#include <linux/bitops.h> - -#define GOTGCTL_CHIRPEN BIT(27) -#define GOTGCTL_MULT_VALID_BC_MASK GENMASK(26, 22) -#define GOTGCTL_CURMODE_HOST BIT(21) -#define GOTGCTL_OTGVER BIT(20) -#define GOTGCTL_BSESVLD BIT(19) -#define GOTGCTL_ASESVLD BIT(18) -#define GOTGCTL_DBNC_SHORT BIT(17) -#define GOTGCTL_CONID_B BIT(16) -#define GOTGCTL_DBNCE_FLTR_BYPASS BIT(15) -#define GOTGCTL_DEVHNPEN BIT(11) -#define GOTGCTL_HSTSETHNPEN BIT(10) -#define GOTGCTL_HNPREQ BIT(9) -#define GOTGCTL_HSTNEGSCS BIT(8) -#define GOTGCTL_BVALOVAL BIT(7) -#define GOTGCTL_BVALOEN BIT(6) -#define GOTGCTL_AVALOVAL BIT(5) -#define GOTGCTL_AVALOEN BIT(4) -#define GOTGCTL_VBVALOVAL BIT(3) -#define GOTGCTL_VBVALOEN BIT(2) -#define GOTGCTL_SESREQ BIT(1) -#define GOTGCTL_SESREQSCS BIT(0) - -#define GOTGINT_DBNCE_DONE BIT(19) -#define GOTGINT_A_DEV_TOUT_CHG BIT(18) -#define GOTGINT_HST_NEG_DET BIT(17) -#define GOTGINT_HST_NEG_SUC_STS_CHNG BIT(9) -#define GOTGINT_SES_REQ_SUC_STS_CHNG BIT(8) -#define GOTGINT_SES_END_DET BIT(2) - -#define GAHBCFG_AHB_SINGLE BIT(23) -#define GAHBCFG_NOTI_ALL_DMA_WRIT BIT(22) -#define GAHBCFG_REM_MEM_SUPP BIT(21) -#define GAHBCFG_P_TXF_EMP_LVL BIT(8) -#define GAHBCFG_NP_TXF_EMP_LVL BIT(7) -#define GAHBCFG_DMA_EN BIT(5) -#define GAHBCFG_HBSTLEN_MASK GENMASK(4, 1) -#define GAHBCFG_HBSTLEN_SINGLE 0 -#define GAHBCFG_HBSTLEN_INCR 1 -#define GAHBCFG_HBSTLEN_INCR4 3 -#define GAHBCFG_HBSTLEN_INCR8 5 -#define GAHBCFG_HBSTLEN_INCR16 7 -#define GAHBCFG_GLBL_INTR_EN BIT(0) -#define GAHBCFG_CTRL_MASK (GAHBCFG_P_TXF_EMP_LVL | \ - GAHBCFG_NP_TXF_EMP_LVL | \ - GAHBCFG_DMA_EN | \ - GAHBCFG_GLBL_INTR_EN) - -#define GUSBCFG_FORCEDEVMODE BIT(30) -#define GUSBCFG_FORCEHOSTMODE BIT(29) -#define GUSBCFG_TXENDDELAY BIT(28) -#define GUSBCFG_ICTRAFFICPULLREMOVE BIT(27) -#define GUSBCFG_ICUSBCAP BIT(26) -#define GUSBCFG_ULPI_INT_PROT_DIS BIT(25) -#define GUSBCFG_INDICATORPASSTHROUGH BIT(24) -#define GUSBCFG_INDICATORCOMPLEMENT BIT(23) -#define GUSBCFG_TERMSELDLPULSE BIT(22) -#define GUSBCFG_ULPI_INT_VBUS_IND BIT(21) -#define GUSBCFG_ULPI_EXT_VBUS_DRV BIT(20) -#define GUSBCFG_ULPI_CLK_SUSP_M BIT(19) -#define GUSBCFG_ULPI_AUTO_RES BIT(18) -#define GUSBCFG_ULPI_FS_LS BIT(17) -#define GUSBCFG_OTG_UTMI_FS_SEL BIT(16) -#define GUSBCFG_PHY_LP_CLK_SEL BIT(15) -#define GUSBCFG_USBTRDTIM_MASK GENMASK(14, 10) -#define GUSBCFG_HNPCAP BIT(9) -#define GUSBCFG_SRPCAP BIT(8) -#define GUSBCFG_DDRSEL BIT(7) -#define GUSBCFG_PHYSEL BIT(6) -#define GUSBCFG_FSINTF BIT(5) -#define GUSBCFG_ULPI_UTMI_SEL BIT(4) -#define GUSBCFG_PHYIF16 BIT(3) -#define GUSBCFG_TOUTCAL_MASK GENMASK(2, 0) - -#define GRSTCTL_AHBIDLE BIT(31) -#define GRSTCTL_DMAREQ BIT(30) -#define GRSTCTL_CSFTRST_DONE BIT(29) -#define GRSTCTL_TXFNUM_MASK GENMASK(10, 6) -#define GRSTCTL_TXFFLSH BIT(5) -#define GRSTCTL_RXFFLSH BIT(4) -#define GRSTCTL_IN_TKNQ_FLSH BIT(3) -#define GRSTCTL_FRMCNTRRST BIT(2) -#define GRSTCTL_HSFTRST BIT(1) -#define GRSTCTL_CSFTRST BIT(0) -#define GRSTCTL_TXFNUM_ALL 0x10 - -#define GINTSTS_WKUPINT BIT(31) -#define GINTSTS_SESSREQINT BIT(30) -#define GINTSTS_DISCONNINT BIT(29) -#define GINTSTS_CONIDSTSCHNG BIT(28) -#define GINTSTS_LPMTRANRCVD BIT(27) -#define GINTSTS_PTXFEMP BIT(26) -#define GINTSTS_HCHINT BIT(25) -#define GINTSTS_PRTINT BIT(24) -#define GINTSTS_RESETDET BIT(23) -#define GINTSTS_FET_SUSP BIT(22) -#define GINTSTS_INCOMPL_IP BIT(21) -#define GINTSTS_INCOMPL_SOOUT BIT(21) -#define GINTSTS_INCOMPL_SOIN BIT(20) -#define GINTSTS_OEPINT BIT(19) -#define GINTSTS_IEPINT BIT(18) -#define GINTSTS_EPMIS BIT(17) -#define GINTSTS_RESTOREDONE BIT(16) -#define GINTSTS_EOPF BIT(15) -#define GINTSTS_ISOUTDROP BIT(14) -#define GINTSTS_ENUMDONE BIT(13) -#define GINTSTS_USBRST BIT(12) -#define GINTSTS_USBSUSP BIT(11) -#define GINTSTS_ERLYSUSP BIT(10) -#define GINTSTS_I2CINT BIT(9) -#define GINTSTS_ULPI_CK_INT BIT(8) -#define GINTSTS_GOUTNAKEFF BIT(7) -#define GINTSTS_GINNAKEFF BIT(6) -#define GINTSTS_NPTXFEMP BIT(5) -#define GINTSTS_RXFLVL BIT(4) -#define GINTSTS_SOF BIT(3) -#define GINTSTS_OTGINT BIT(2) -#define GINTSTS_MODEMIS BIT(1) -#define GINTSTS_CURMODE_HOST BIT(0) - -#define FIFOSIZE_DEPTH_MASK GENMASK(31, 16) -#define FIFOSIZE_STARTADDR_MASK GENMASK(15, 0) - -#define GI2CCTL_BSYDNE BIT(31) -#define GI2CCTL_RW BIT(30) -#define GI2CCTL_I2CDATSE0 BIT(28) -#define GI2CCTL_I2CDEVADDR_MASK GENMASK(27, 26) -#define GI2CCTL_I2CSUSPCTL BIT(25) -#define GI2CCTL_ACK BIT(24) -#define GI2CCTL_I2CEN BIT(23) -#define GI2CCTL_ADDR_MASK GENMASK(22, 16) -#define GI2CCTL_REGADDR_MASK GENMASK(15, 8) -#define GI2CCTL_RWDATA_MASK GENMASK(7, 0) - -#define GHWCFG2_OTG_ENABLE_IC_USB BIT(31) -#define GHWCFG2_DEV_TOKEN_Q_DEPTH_MASK GENMASK(30, 26) -#define GHWCFG2_HOST_PERIO_TX_Q_DEPTH_MASK GENMASK(25, 24) -#define GHWCFG2_NONPERIO_TX_Q_DEPTH_MASK GENMASK(23, 22) -#define GHWCFG2_MULTI_PROC_INT BIT(20) -#define GHWCFG2_DYNAMIC_FIFO BIT(19) -#define GHWCFG2_PERIO_EP_SUPPORTED BIT(18) -#define GHWCFG2_NUM_HOST_CHAN_MASK GENMASK(17, 14) -#define GHWCFG2_NUM_DEV_EP_MASK GENMASK(13, 10) -#define GHWCFG2_FS_PHY_TYPE_MASK GENMASK(9, 8) -#define GHWCFG2_FS_PHY_TYPE_NOT_SUPPORTED 0 -#define GHWCFG2_FS_PHY_TYPE_DEDICATED 1 -#define GHWCFG2_FS_PHY_TYPE_SHARED_UTMI 2 -#define GHWCFG2_FS_PHY_TYPE_SHARED_ULPI 3 -#define GHWCFG2_HS_PHY_TYPE_MASK GENMASK(7, 6) -#define GHWCFG2_HS_PHY_TYPE_NOT_SUPPORTED 0 -#define GHWCFG2_HS_PHY_TYPE_UTMI 1 -#define GHWCFG2_HS_PHY_TYPE_ULPI 2 -#define GHWCFG2_HS_PHY_TYPE_UTMI_ULPI 3 -#define GHWCFG2_POINT2POINT BIT(5) -#define GHWCFG2_ARCHITECTURE_MASK GENMASK(4, 3) -#define GHWCFG2_SLAVE_ONLY_ARCH 0 -#define GHWCFG2_EXT_DMA_ARCH 1 -#define GHWCFG2_INT_DMA_ARCH 2 -#define GHWCFG2_OP_MODE_MASK GENMASK(2, 0) -#define GHWCFG2_OP_MODE_HNP_SRP_CAPABLE 0 -#define GHWCFG2_OP_MODE_SRP_ONLY_CAPABLE 1 -#define GHWCFG2_OP_MODE_NO_HNP_SRP_CAPABLE 2 -#define GHWCFG2_OP_MODE_SRP_CAPABLE_DEVICE 3 -#define GHWCFG2_OP_MODE_NO_SRP_CAPABLE_DEVICE 4 -#define GHWCFG2_OP_MODE_SRP_CAPABLE_HOST 5 -#define GHWCFG2_OP_MODE_NO_SRP_CAPABLE_HOST 6 -#define GHWCFG2_OP_MODE_UNDEFINED 7 - -#define GHWCFG4_DESC_DMA_DYN BIT(31) -#define GHWCFG4_DESC_DMA BIT(30) -#define GHWCFG4_NUM_IN_EPS_MASK GENMASK(29, 26) -#define GHWCFG4_DED_FIFO_EN BIT(25) -#define GHWCFG4_SESSION_END_FILT_EN BIT(24) -#define GHWCFG4_B_VALID_FILT_EN BIT(23) -#define GHWCFG4_A_VALID_FILT_EN BIT(22) -#define GHWCFG4_VBUS_VALID_FILT_EN BIT(21) -#define GHWCFG4_IDDIG_FILT_EN BIT(20) -#define GHWCFG4_NUM_DEV_MODE_CTRL_EP_MASK GENMASK(19, 16) -#define GHWCFG4_UTMI_PHY_DATA_WIDTH_MASK GENMASK(15, 14) -#define GHWCFG4_UTMI_PHY_DATA_WIDTH_8 0 -#define GHWCFG4_UTMI_PHY_DATA_WIDTH_16 1 -#define GHWCFG4_UTMI_PHY_DATA_WIDTH_8_OR_16 2 -#define GHWCFG4_ACG_SUPPORTED BIT(12) -#define GHWCFG4_IPG_ISOC_SUPPORTED BIT(11) -#define GHWCFG4_SERVICE_INTERVAL_SUPPORTED BIT(10) -#define GHWCFG4_XHIBER BIT(7) -#define GHWCFG4_HIBER BIT(6) -#define GHWCFG4_MIN_AHB_FREQ BIT(5) -#define GHWCFG4_POWER_OPTIMIZ BIT(4) -#define GHWCFG4_NUM_DEV_PERIO_IN_EP_MASK GENMASK(3, 0) - -#define HCFG_MODECHTIMEN BIT(31) -#define HCFG_PERSCHEDENA BIT(26) -#define HCFG_FRLISTEN_MASK GENMASK(25, 24) -#define HCFG_FRLISTEN_8 0 -#define HCFG_FRLISTEN_16 1 -#define HCFG_FRLISTEN_32 2 -#define HCFG_FRLISTEN_64 3 -#define HCFG_DESCDMA BIT(23) -#define HCFG_RESVALID_MASK GENMASK(15, 8) -#define HCFG_ENA32KHZ BIT(7) -#define HCFG_FSLSSUPP BIT(2) -#define HCFG_FSLSPCLKSEL_MASK GENMASK(2, 0) -#define HCFG_FSLSPCLKSEL_30_60_MHZ 0 -#define HCFG_FSLSPCLKSEL_48_MHZ 1 -#define HCFG_FSLSPCLKSEL_6_MHZ 2 - -#define HFIR_FRINT_MASK GENMASK(15, 0) -#define HFIR_RLDCTRL BIT(16) - -#define HFNUM_FRREM_MASK GENMASK(31, 16) -#define HFNUM_FRNUM_MASK GENMASK(15, 0) - -#define HPRT0_SPD_MASK GENMASK(18, 17) -#define HPRT0_SPD_HIGH_SPEED 0 -#define HPRT0_SPD_FULL_SPEED 1 -#define HPRT0_SPD_LOW_SPEED 2 -#define HPRT0_TSTCTL_MASK GENMASK(16, 13) -#define HPRT0_PWR BIT(12) -#define HPRT0_LNSTS_MASK GENMASK(11, 10) -#define HPRT0_RST BIT(8) -#define HPRT0_SUSP BIT(7) -#define HPRT0_RES BIT(6) -#define HPRT0_OVRCURRCHG BIT(5) -#define HPRT0_OVRCURRACT BIT(4) -#define HPRT0_ENACHG BIT(3) -#define HPRT0_ENA BIT(2) -#define HPRT0_CONNDET BIT(1) -#define HPRT0_CONNSTS BIT(0) -#define HPRT0_W1C_MASK (HPRT0_CONNDET | \ - HPRT0_ENA | \ - HPRT0_ENACHG | \ - HPRT0_OVRCURRCHG) - -#define HCCHAR_CHENA BIT(31) -#define HCCHAR_CHDIS BIT(30) -#define HCCHAR_ODDFRM BIT(29) -#define HCCHAR_DEVADDR_MASK GENMASK(28, 22) -#define HCCHAR_MULTICNT_MASK GENMASK(21, 20) -#define HCCHAR_EPTYPE_MASK GENMASK(19, 18) -#define HCCHAR_EPTYPE_CONTROL 0 -#define HCCHAR_EPTYPE_ISOC 1 -#define HCCHAR_EPTYPE_BULK 2 -#define HCCHAR_EPTYPE_INTR 3 -#define HCCHAR_LSPDDEV BIT(17) -#define HCCHAR_EPDIR BIT(15) -#define HCCHAR_EPNUM_MASK GENMASK(14, 11) -#define HCCHAR_MPS_MASK GENMASK(10, 0) - -#define HCSPLT_SPLTENA BIT(31) -#define HCSPLT_COMPSPLT BIT(16) -#define HCSPLT_XACTPOS_MASK GENMASK(15, 14) -#define HCSPLT_XACTPOS_MID 0 -#define HCSPLT_XACTPOS_END 1 -#define HCSPLT_XACTPOS_BEGIN 2 -#define HCSPLT_XACTPOS_ALL 3 -#define HCSPLT_HUBADDR_MASK GENMASK(13, 7) -#define HCSPLT_PRTADDR_MASK GENMASK(6, 0) - -#define HCINTMSK_FRM_LIST_ROLL BIT(13) -#define HCINTMSK_XCS_XACT BIT(12) -#define HCINTMSK_BNA BIT(11) -#define HCINTMSK_DATATGLERR BIT(10) -#define HCINTMSK_FRMOVRUN BIT(9) -#define HCINTMSK_BBLERR BIT(8) -#define HCINTMSK_XACTERR BIT(7) -#define HCINTMSK_NYET BIT(6) -#define HCINTMSK_ACK BIT(5) -#define HCINTMSK_NAK BIT(4) -#define HCINTMSK_STALL BIT(3) -#define HCINTMSK_AHBERR BIT(2) -#define HCINTMSK_CHHLTD BIT(1) -#define HCINTMSK_XFERCOMPL BIT(0) - -#define TSIZ_DOPNG BIT(31) -#define TSIZ_SC_MC_PID_MASK GENMASK(30, 29) -#define TSIZ_SC_MC_PID_DATA0 0 -#define TSIZ_SC_MC_PID_DATA2 1 -#define TSIZ_SC_MC_PID_DATA1 2 -#define TSIZ_SC_MC_PID_MDATA 3 -#define TSIZ_SC_MC_PID_SETUP 3 -#define TSIZ_PKTCNT_MASK GENMASK(28, 19) -#define TSIZ_NTD_MASK GENMASK(15, 8) -#define TSIZ_SCHINFO_MASK GENMASK(7, 0) -#define TSIZ_XFERSIZE_MASK GENMASK(18, 0) - -#define GSNPSID_ID_MASK GENMASK(31, 16) -#define GSNPSID_OTG_ID 0x4f54 -#define GSNPSID_VER_MASK GENMASK(15, 0) - /* Host controller specific */ #define DWC2_HC_PID_DATA0 0 #define DWC2_HC_PID_DATA2 1
Hi Junhui,
Thank you for the patch.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
GAHBCFG_DMA_EN | \
HPRT0_ENA | \
HPRT0_ENACHG | \
HPRT0_OVRCURRCHG)
GAHBCFG_DMA_EN | \
HPRT0_ENA | \
HPRT0_ENACHG | \
HPRT0_OVRCURRCHG)
-- 2.47.1
This patch merges flush and reset logic for both host and gadget code into a common set of functions, reducing duplication. It also adds support for the updated reset logic to compatible with core version since v4.20a.
This patch mainly refers to the patch in the kernel. link: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?i...
Signed-off-by: Kongyang Liu seashell11234455@gmail.com Tested-by: Peter Robinson pbrobinson@gmail.com Signed-off-by: Junhui Liu junhui.liu@pigmoral.tech
--- This commit does not add the handling of ret returned from the dwc2_core_reset, dwc2_flush_tx_fifo and dwc2_flush_rx_fifo, because this may involve changes to the code logic, I think this should be a separate patch to handle with it. --- drivers/usb/common/Makefile | 2 + drivers/usb/common/dwc2_core.c | 131 +++++++++++++++++++++++++++++ drivers/usb/common/dwc2_core.h | 4 + drivers/usb/gadget/dwc2_udc_otg.c | 12 +-- drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c | 6 +- drivers/usb/host/dwc2.c | 80 +----------------- 6 files changed, 145 insertions(+), 90 deletions(-)
diff --git a/drivers/usb/common/Makefile b/drivers/usb/common/Makefile index 11cc4657a0f403b84b1b8336781e1893d9c7a8f1..73e5bc6d7fdca692276e119911b47db4bf03586a 100644 --- a/drivers/usb/common/Makefile +++ b/drivers/usb/common/Makefile @@ -4,6 +4,8 @@ #
obj-$(CONFIG_$(XPL_)DM_USB) += common.o +obj-$(CONFIG_USB_DWC2) += dwc2_core.o +obj-$(CONFIG_USB_GADGET_DWC2_OTG) += dwc2_core.o obj-$(CONFIG_USB_ISP1760) += usb_urb.o obj-$(CONFIG_USB_MUSB_HOST) += usb_urb.o obj-$(CONFIG_USB_MUSB_GADGET) += usb_urb.o diff --git a/drivers/usb/common/dwc2_core.c b/drivers/usb/common/dwc2_core.c new file mode 100644 index 0000000000000000000000000000000000000000..63062d5cc943b0367100d43e4443be7b3d59b77c --- /dev/null +++ b/drivers/usb/common/dwc2_core.c @@ -0,0 +1,131 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2024-2025, Kongyang Liu seashell11234455@gmail.com + */ + +#include <linux/bitfield.h> +#include <linux/errno.h> +#include <linux/io.h> +#include <wait_bit.h> + +#include "dwc2_core.h" + +int dwc2_core_reset(struct dwc2_core_regs *regs) +{ + u32 snpsid; + int ret; + bool host_mode = false; + + if (!(readl(®s->global_regs.gotgctl) & GOTGCTL_CONID_B) || + (readl(®s->global_regs.gusbcfg) & GUSBCFG_FORCEDEVMODE)) + host_mode = true; + + /* Core Soft Reset */ + snpsid = readl(®s->global_regs.gsnpsid); + writel(GRSTCTL_CSFTRST, ®s->global_regs.grstctl); + if (FIELD_GET(GSNPSID_VER_MASK, snpsid) < 0x420a) { + ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_CSFTRST, + false, 1000, false); + if (ret) { + log_warning("%s: Waiting for GRSTCTL_CSFTRST timeout\n", __func__); + return ret; + } + } else { + ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_CSFTRST_DONE, + true, 1000, false); + if (ret) { + log_warning("%s: Waiting for GRSTCTL_CSFTRST_DONE timeout\n", __func__); + return ret; + } + clrsetbits_le32(®s->global_regs.grstctl, GRSTCTL_CSFTRST, GRSTCTL_CSFTRST_DONE); + } + + /* Wait for AHB master IDLE state. */ + ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_AHBIDLE, + true, 1000, false); + if (ret) { + log_warning("%s: Waiting for GRSTCTL_AHBIDLE timeout\n", __func__); + return ret; + } + + if (host_mode) { + ret = wait_for_bit_le32(®s->global_regs.gintsts, GINTSTS_CURMODE_HOST, + host_mode, 1000, false); + if (ret) { + log_warning("%s: Waiting for GINTSTS_CURMODE_HOST timeout\n", __func__); + return ret; + } + } + + return 0; +} + +int dwc2_flush_tx_fifo(struct dwc2_core_regs *regs, const int num) +{ + int ret; + + log_debug("Flush Tx FIFO %d\n", num); + + /* Wait for AHB master IDLE state */ + ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_AHBIDLE, true, 1000, false); + if (ret) { + log_warning("%s: Waiting for GRSTCTL_AHBIDLE timeout\n", __func__); + return ret; + } + + writel(GRSTCTL_TXFFLSH | FIELD_PREP(GRSTCTL_TXFNUM_MASK, num), ®s->global_regs.grstctl); + + ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_TXFFLSH, false, 1000, false); + if (ret) { + log_warning("%s: Waiting for GRSTCTL_TXFFLSH timeout\n", __func__); + return ret; + } + + /* + * Wait for at least 3 PHY clocks. + * + * The PHY clock frequency can be configured to 6/30/48/60 MHz + * based on the speed mode. A fixed delay of 1us ensures that the + * wait time is sufficient even at the lowest PHY clock frequency + * (6 MHz), where 1us corresponds to twice the duration of 3 PHY + * clocks. + */ + udelay(1); + + return 0; +} + +int dwc2_flush_rx_fifo(struct dwc2_core_regs *regs) +{ + int ret; + + log_debug("Flush Rx FIFO\n"); + + /* Wait for AHB master IDLE state */ + ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_AHBIDLE, true, 1000, false); + if (ret) { + log_warning("%s: Waiting for GRSTCTL_AHBIDLE timeout\n", __func__); + return ret; + } + + writel(GRSTCTL_RXFFLSH, ®s->global_regs.grstctl); + + ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_RXFFLSH, false, 1000, false); + if (ret) { + log_warning("%s: Waiting for GRSTCTL_RXFFLSH timeout\n", __func__); + return ret; + } + + /* + * Wait for at least 3 PHY clocks. + * + * The PHY clock frequency can be configured to 6/30/48/60 MHz + * based on the speed mode. A fixed delay of 1us ensures that the + * wait time is sufficient even at the lowest PHY clock frequency + * (6 MHz), where 1us corresponds to twice the duration of 3 PHY + * clocks. + */ + udelay(1); + + return 0; +} diff --git a/drivers/usb/common/dwc2_core.h b/drivers/usb/common/dwc2_core.h index 862d3b3691c9caf84590d34960df21117848df0a..1897ad7cb540ed7a24fd8cd21650a40da20363fb 100644 --- a/drivers/usb/common/dwc2_core.h +++ b/drivers/usb/common/dwc2_core.h @@ -125,6 +125,10 @@ struct dwc2_core_regs { u8 ep_fifo[16][0x1000]; /* 0x1000 */ };
+int dwc2_core_reset(struct dwc2_core_regs *regs); +int dwc2_flush_tx_fifo(struct dwc2_core_regs *regs, const int num); +int dwc2_flush_rx_fifo(struct dwc2_core_regs *regs); + /* Core Global Register */ #define GOTGCTL_CHIRPEN BIT(27) #define GOTGCTL_MULT_VALID_BC_MASK GENMASK(26, 22) diff --git a/drivers/usb/gadget/dwc2_udc_otg.c b/drivers/usb/gadget/dwc2_udc_otg.c index b08ea5ba79a5f1f094a2407687e5f5aad9f3577e..084e9824faac03d47e23e0d52e81a9d12308e06a 100644 --- a/drivers/usb/gadget/dwc2_udc_otg.c +++ b/drivers/usb/gadget/dwc2_udc_otg.c @@ -471,7 +471,7 @@ static void reconfig_usbd(struct dwc2_udc *dev) u32 max_hw_ep; int pdata_hw_ep;
- writel(GRSTCTL_CSFTRST, ®->global_regs.grstctl); + dwc2_core_reset(reg);
debug("Resetting OTG controller\n");
@@ -575,16 +575,10 @@ static void reconfig_usbd(struct dwc2_udc *dev) ®->global_regs.dptxfsizn[i]); } /* Flush the RX FIFO */ - writel(GRSTCTL_RXFFLSH, ®->global_regs.grstctl); - while (readl(®->global_regs.grstctl) & GRSTCTL_RXFFLSH) - debug("%s: waiting for DWC2_UDC_OTG_GRSTCTL\n", __func__); + dwc2_flush_rx_fifo(reg);
/* Flush all the Tx FIFO's */ - writel(FIELD_PREP(GRSTCTL_TXFNUM_MASK, GRSTCTL_TXFNUM_ALL), ®->global_regs.grstctl); - writel(FIELD_PREP(GRSTCTL_TXFNUM_MASK, GRSTCTL_TXFNUM_ALL) | GRSTCTL_TXFFLSH, - ®->global_regs.grstctl); - while (readl(®->global_regs.grstctl) & GRSTCTL_TXFFLSH) - debug("%s: waiting for DWC2_UDC_OTG_GRSTCTL\n", __func__); + dwc2_flush_tx_fifo(reg, GRSTCTL_TXFNUM_ALL);
/* 13. Clear NAK bit of EP0, EP1, EP2*/ /* For Slave mode*/ diff --git a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c index 64d2fe7bbde4494b4cbcdf57032b720901fdd4eb..2be93592c423df7a9acea473b0e84e1f948999be 100644 --- a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c +++ b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c @@ -164,11 +164,7 @@ static int setdma_tx(struct dwc2_ep *ep, struct dwc2_request *req) pktcnt = (length - 1)/(ep->ep.maxpacket) + 1;
/* Flush the endpoint's Tx FIFO */ - writel(FIELD_PREP(GRSTCTL_TXFNUM_MASK, ep->fifo_num), ®->global_regs.grstctl); - writel(FIELD_PREP(GRSTCTL_TXFNUM_MASK, ep->fifo_num) | GRSTCTL_TXFFLSH, - ®->global_regs.grstctl); - while (readl(®->global_regs.grstctl) & GRSTCTL_TXFFLSH) - ; + dwc2_flush_tx_fifo(reg, ep->fifo_num);
writel(phys_to_bus((unsigned long)ep->dma_buf), ®->device_regs.in_endp[ep_num].diepdma); writel(FIELD_PREP(DXEPTSIZ_PKTCNT_MASK, pktcnt) | diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index ff7885f8195c0bc08669dd99ef6c94992c991945..b27429235798ce223bb8a11999e3d520c26ef377 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -108,78 +108,6 @@ static void init_fslspclksel(struct dwc2_core_regs *regs) FIELD_PREP(HCFG_FSLSPCLKSEL_MASK, phyclk)); }
-/* - * Flush a Tx FIFO. - * - * @param regs Programming view of DWC_otg controller. - * @param num Tx FIFO to flush. - */ -static void dwc_otg_flush_tx_fifo(struct udevice *dev, - struct dwc2_core_regs *regs, const int num) -{ - int ret; - - writel(GRSTCTL_TXFFLSH | FIELD_PREP(GRSTCTL_TXFNUM_MASK, num), - ®s->global_regs.grstctl); - ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_TXFFLSH, - false, 1000, false); - if (ret) - dev_info(dev, "%s: Timeout!\n", __func__); - - /* Wait for 3 PHY Clocks */ - udelay(1); -} - -/* - * Flush Rx FIFO. - * - * @param regs Programming view of DWC_otg controller. - */ -static void dwc_otg_flush_rx_fifo(struct udevice *dev, - struct dwc2_core_regs *regs) -{ - int ret; - - writel(GRSTCTL_RXFFLSH, ®s->global_regs.grstctl); - ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_RXFFLSH, - false, 1000, false); - if (ret) - dev_info(dev, "%s: Timeout!\n", __func__); - - /* Wait for 3 PHY Clocks */ - udelay(1); -} - -/* - * Do core a soft reset of the core. Be careful with this because it - * resets all the internal state machines of the core. - */ -static void dwc_otg_core_reset(struct udevice *dev, - struct dwc2_core_regs *regs) -{ - int ret; - - /* Wait for AHB master IDLE state. */ - ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_AHBIDLE, - true, 1000, false); - if (ret) - dev_info(dev, "%s: Timeout!\n", __func__); - - /* Core Soft Reset */ - writel(GRSTCTL_CSFTRST, ®s->global_regs.grstctl); - ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_CSFTRST, - false, 1000, false); - if (ret) - dev_info(dev, "%s: Timeout!\n", __func__); - - /* - * Wait for core to come out of reset. - * NOTE: This long sleep is _very_ important, otherwise the core will - * not stay in host mode after a connector ID change! - */ - mdelay(100); -} - #if CONFIG_IS_ENABLED(DM_USB) && defined(CONFIG_DM_REGULATOR) static int dwc_vbus_supply_init(struct udevice *dev) { @@ -281,8 +209,8 @@ static void dwc_otg_core_host_init(struct udevice *dev, clrbits_le32(®s->global_regs.gotgctl, GOTGCTL_HSTSETHNPEN);
/* Make sure the FIFOs are flushed. */ - dwc_otg_flush_tx_fifo(dev, regs, GRSTCTL_TXFNUM_ALL); /* All Tx FIFOs */ - dwc_otg_flush_rx_fifo(dev, regs); + dwc2_flush_tx_fifo(regs, GRSTCTL_TXFNUM_ALL); /* All Tx FIFOs */ + dwc2_flush_rx_fifo(regs);
/* Flush out any leftover queued requests. */ num_channels = FIELD_GET(GHWCFG2_NUM_HOST_CHAN_MASK, readl(®s->global_regs.ghwcfg2)) + 1; @@ -352,7 +280,7 @@ static void dwc_otg_core_init(struct udevice *dev) writel(usbcfg, ®s->global_regs.gusbcfg);
/* Reset the Controller */ - dwc_otg_core_reset(dev, regs); + dwc2_core_reset(regs);
/* * This programming sequence needs to happen in FS mode before @@ -413,7 +341,7 @@ static void dwc_otg_core_init(struct udevice *dev) writel(usbcfg, ®s->global_regs.gusbcfg);
/* Reset after setting the PHY parameters */ - dwc_otg_core_reset(dev, regs); + dwc2_core_reset(regs); #endif
usbcfg = readl(®s->global_regs.gusbcfg);
Hi Junhui,
- Copyright (c) 2024-2025, Kongyang Liu seashell11234455@gmail.com
- u32 snpsid;
- int ret;
- bool host_mode = false;
- if (!(readl(®s->global_regs.gotgctl) & GOTGCTL_CONID_B) ||
host_mode = true;
- snpsid = readl(®s->global_regs.gsnpsid);
- if (FIELD_GET(GSNPSID_VER_MASK, snpsid) < 0x420a) {
if (ret) {
return ret;
- } else {
true, 1000, false);
if (ret) {
return ret;
true, 1000, false);
- if (ret) {
return ret;
- if (host_mode) {
if (ret) {
return ret;
- int ret;
- log_debug("Flush Tx FIFO %d\n", num);
- /* Wait for AHB master IDLE state */
- ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_AHBIDLE, true, 1000, false);
- if (ret) {
return ret;
- writel(GRSTCTL_TXFFLSH | FIELD_PREP(GRSTCTL_TXFNUM_MASK, num), ®s->global_regs.grstctl);
- ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_TXFFLSH, false, 1000, false);
- if (ret) {
return ret;
* clocks.
- udelay(1);
- int ret;
- log_debug("Flush Rx FIFO\n");
- if (ret) {
return ret;
- ret = wait_for_bit_le32(®s->global_regs.grstctl, GRSTCTL_RXFFLSH, false, 1000, false);
- if (ret) {
return ret;
* clocks.
- udelay(1);
- Flush a Tx FIFO.
- @param regs Programming view of DWC_otg controller.
- @param num Tx FIFO to flush.
- int ret;
- if (ret)
- udelay(1);
- Flush Rx FIFO.
- int ret;
- if (ret)
- udelay(1);
- Do core a soft reset of the core. Be careful with this because it
- resets all the internal state machines of the core.
- int ret;
true, 1000, false);
- if (ret)
- if (ret)
- mdelay(100);
- This programming sequence needs to happen in FS mode before
- dwc2_core_reset(regs);
#endif
-- 2.47.1
Updates all instances of uint8_t, uint16_t, and uint32_t to u8, u16, and u32 respectively, ensuring consistent use of kernel-preferred types and resolving checkpatch.pl warnings.
Signed-off-by: Kongyang Liu seashell11234455@gmail.com Reviewed-by: Marek Vasut marex@denx.de Tested-by: Peter Robinson pbrobinson@gmail.com Signed-off-by: Junhui Liu junhui.liu@pigmoral.tech --- drivers/usb/gadget/dwc2_udc_otg.c | 4 +- drivers/usb/host/dwc2.c | 100 +++++++++++++++++++------------------- 2 files changed, 52 insertions(+), 52 deletions(-)
diff --git a/drivers/usb/gadget/dwc2_udc_otg.c b/drivers/usb/gadget/dwc2_udc_otg.c index 084e9824faac03d47e23e0d52e81a9d12308e06a..c3fdc81e9096bb216b63ff0ac672d216bed3f23d 100644 --- a/drivers/usb/gadget/dwc2_udc_otg.c +++ b/drivers/usb/gadget/dwc2_udc_otg.c @@ -466,8 +466,8 @@ static void reconfig_usbd(struct dwc2_udc *dev) /* 2. Soft-reset OTG Core and then unreset again. */ int i; unsigned int uTemp; - uint32_t dflt_gusbcfg; - uint32_t rx_fifo_sz, tx_fifo_sz, np_tx_fifo_sz; + u32 dflt_gusbcfg; + u32 rx_fifo_sz, tx_fifo_sz, np_tx_fifo_sz; u32 max_hw_ep; int pdata_hw_ep;
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index b27429235798ce223bb8a11999e3d520c26ef377..16f21fa9083a71da1c8dd62d174712962d0227b1 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -39,16 +39,16 @@
struct dwc2_priv { #if CONFIG_IS_ENABLED(DM_USB) - uint8_t aligned_buffer[DWC2_DATA_BUF_SIZE] __aligned(ARCH_DMA_MINALIGN); - uint8_t status_buffer[DWC2_STATUS_BUF_SIZE] __aligned(ARCH_DMA_MINALIGN); + u8 aligned_buffer[DWC2_DATA_BUF_SIZE] __aligned(ARCH_DMA_MINALIGN); + u8 status_buffer[DWC2_STATUS_BUF_SIZE] __aligned(ARCH_DMA_MINALIGN); #ifdef CONFIG_DM_REGULATOR struct udevice *vbus_supply; #endif struct phy phy; struct clk_bulk clks; #else - uint8_t *aligned_buffer; - uint8_t *status_buffer; + u8 *aligned_buffer; + u8 *status_buffer; #endif u8 in_data_toggle[MAX_DEVICE][MAX_ENDPOINT]; u8 out_data_toggle[MAX_DEVICE][MAX_ENDPOINT]; @@ -67,10 +67,10 @@ struct dwc2_priv {
#if !CONFIG_IS_ENABLED(DM_USB) /* We need cacheline-aligned buffers for DMA transfers and dcache support */ -DEFINE_ALIGN_BUFFER(uint8_t, aligned_buffer_addr, DWC2_DATA_BUF_SIZE, - ARCH_DMA_MINALIGN); -DEFINE_ALIGN_BUFFER(uint8_t, status_buffer_addr, DWC2_STATUS_BUF_SIZE, - ARCH_DMA_MINALIGN); +DEFINE_ALIGN_BUFFER(u8, aligned_buffer_addr, DWC2_DATA_BUF_SIZE, + ARCH_DMA_MINALIGN); +DEFINE_ALIGN_BUFFER(u8, status_buffer_addr, DWC2_STATUS_BUF_SIZE, + ARCH_DMA_MINALIGN);
static struct dwc2_priv local; #endif @@ -85,7 +85,7 @@ static struct dwc2_priv local; */ static void init_fslspclksel(struct dwc2_core_regs *regs) { - uint32_t phyclk; + u32 phyclk;
#if (DWC2_PHY_TYPE == DWC2_PHY_TYPE_FS) phyclk = HCFG_FSLSPCLKSEL_48_MHZ; /* Full speed PHY */ @@ -95,9 +95,9 @@ static void init_fslspclksel(struct dwc2_core_regs *regs) #endif
#ifdef DWC2_ULPI_FS_LS - uint32_t hwcfg2 = readl(®s->global_regs.ghwcfg2); - uint32_t hval = FIELD_GET(GHWCFG2_HS_PHY_TYPE_MASK, ghwcfg2); - uint32_t fval = FIELD_GET(GHWCFG2_FS_PHY_TYPE_MASK, ghwcfg2); + u32 hwcfg2 = readl(®s->global_regs.ghwcfg2); + u32 hval = FIELD_GET(GHWCFG2_HS_PHY_TYPE_MASK, ghwcfg2); + u32 fval = FIELD_GET(GHWCFG2_FS_PHY_TYPE_MASK, ghwcfg2);
if (hval == GHWCFG2_FS_PHY_TYPE_SHARED_UTMI && fval == GHWCFG2_HS_PHY_TYPE_UTMI) phyclk = HCFG_FSLSPCLKSEL_48_MHZ; /* Full speed PHY */ @@ -172,9 +172,9 @@ static int dwc_vbus_supply_exit(struct udevice *dev) static void dwc_otg_core_host_init(struct udevice *dev, struct dwc2_core_regs *regs) { - uint32_t nptxfifosize = 0; - uint32_t ptxfifosize = 0; - uint32_t hprt0 = 0; + u32 nptxfifosize = 0; + u32 ptxfifosize = 0; + u32 hprt0 = 0; int i, ret, num_channels;
/* Restart the Phy Clock */ @@ -253,9 +253,9 @@ static void dwc_otg_core_init(struct udevice *dev) { struct dwc2_priv *priv = dev_get_priv(dev); struct dwc2_core_regs *regs = priv->regs; - uint32_t ahbcfg = 0; - uint32_t usbcfg = 0; - uint8_t brst_sz = DWC2_DMA_BURST_SIZE; + u32 ahbcfg = 0; + u32 usbcfg = 0; + u8 brst_sz = DWC2_DMA_BURST_SIZE;
/* Common Initialization */ usbcfg = readl(®s->global_regs.gusbcfg); @@ -347,9 +347,9 @@ static void dwc_otg_core_init(struct udevice *dev) usbcfg = readl(®s->global_regs.gusbcfg); usbcfg &= ~(GUSBCFG_ULPI_FS_LS | GUSBCFG_ULPI_CLK_SUSP_M); #ifdef DWC2_ULPI_FS_LS - uint32_t hwcfg2 = readl(®s->global_regs.ghwcfg2); - uint32_t hval = FIELD_GET(GHWCFG2_HS_PHY_TYPE_MASK, ghwcfg2); - uint32_t fval = FIELD_GET(GHWCFG2_FS_PHY_TYPE_MASK, ghwcfg2); + u32 hwcfg2 = readl(®s->global_regs.ghwcfg2); + u32 hval = FIELD_GET(GHWCFG2_HS_PHY_TYPE_MASK, ghwcfg2); + u32 fval = FIELD_GET(GHWCFG2_FS_PHY_TYPE_MASK, ghwcfg2);
if (hval == GHWCFG2_FS_PHY_TYPE_SHARED_UTMI && fval == GHWCFG2_HS_PHY_TYPE_UTMI) { usbcfg |= GUSBCFG_ULPI_FS_LS; @@ -402,9 +402,9 @@ static void dwc_otg_core_init(struct udevice *dev) * @param regs Programming view of DWC_otg controller * @param hc Information needed to initialize the host channel */ -static void dwc_otg_hc_init(struct dwc2_core_regs *regs, uint8_t hc_num, - struct usb_device *dev, uint8_t dev_addr, uint8_t ep_num, - uint8_t ep_is_in, uint8_t ep_type, uint16_t max_packet) +static void dwc_otg_hc_init(struct dwc2_core_regs *regs, u8 hc_num, + struct usb_device *dev, u8 dev_addr, u8 ep_num, + u8 ep_is_in, u8 ep_type, u16 max_packet) { struct dwc2_hc_regs *hc_regs = ®s->host_regs.hc[hc_num]; u32 hcchar = FIELD_PREP(HCCHAR_DEVADDR_MASK, dev_addr) | @@ -427,9 +427,9 @@ static void dwc_otg_hc_init(struct dwc2_core_regs *regs, uint8_t hc_num, }
static void dwc_otg_hc_init_split(struct dwc2_hc_regs *hc_regs, - uint8_t hub_devnum, uint8_t hub_port) + u8 hub_devnum, u8 hub_port) { - uint32_t hcsplt = 0; + u32 hcsplt = 0;
hcsplt = HCSPLT_SPLTENA; hcsplt |= FIELD_PREP(HCSPLT_HUBADDR_MASK, hub_devnum); @@ -447,24 +447,24 @@ static int dwc_otg_submit_rh_msg_in_status(struct dwc2_core_regs *regs, struct usb_device *dev, void *buffer, int txlen, struct devrequest *cmd) { - uint32_t hprt0 = 0; - uint32_t port_status = 0; - uint32_t port_change = 0; + u32 hprt0 = 0; + u32 port_status = 0; + u32 port_change = 0; int len = 0; int stat = 0;
switch (cmd->requesttype & ~USB_DIR_IN) { case 0: - *(uint16_t *)buffer = cpu_to_le16(1); + *(u16 *)buffer = cpu_to_le16(1); len = 2; break; case USB_RECIP_INTERFACE: case USB_RECIP_ENDPOINT: - *(uint16_t *)buffer = cpu_to_le16(0); + *(u16 *)buffer = cpu_to_le16(0); len = 2; break; case USB_TYPE_CLASS: - *(uint32_t *)buffer = cpu_to_le32(0); + *(u32 *)buffer = cpu_to_le32(0); len = 4; break; case USB_RECIP_OTHER | USB_TYPE_CLASS: @@ -498,7 +498,7 @@ static int dwc_otg_submit_rh_msg_in_status(struct dwc2_core_regs *regs, if (hprt0 & HPRT0_OVRCURRCHG) port_change |= USB_PORT_STAT_C_OVERCURRENT;
- *(uint32_t *)buffer = cpu_to_le32(port_status | + *(u32 *)buffer = cpu_to_le32(port_status | (port_change << 16)); len = 4; break; @@ -519,11 +519,11 @@ static int dwc_otg_submit_rh_msg_in_descriptor(struct usb_device *dev, struct devrequest *cmd) { unsigned char data[32]; - uint32_t dsc; + u32 dsc; int len = 0; int stat = 0; - uint16_t wValue = cpu_to_le16(cmd->value); - uint16_t wLength = cpu_to_le16(cmd->length); + u16 wValue = cpu_to_le16(cmd->value); + u16 wLength = cpu_to_le16(cmd->length);
switch (cmd->requesttype & ~USB_DIR_IN) { case 0: @@ -606,7 +606,7 @@ static int dwc_otg_submit_rh_msg_in_configuration(struct usb_device *dev,
switch (cmd->requesttype & ~USB_DIR_IN) { case 0: - *(uint8_t *)buffer = 0x01; + *(u8 *)buffer = 0x01; len = 1; break; default: @@ -650,8 +650,8 @@ static int dwc_otg_submit_rh_msg_out(struct dwc2_priv *priv, struct dwc2_core_regs *regs = priv->regs; int len = 0; int stat = 0; - uint16_t bmrtype_breq = cmd->requesttype | (cmd->request << 8); - uint16_t wValue = cpu_to_le16(cmd->value); + u16 bmrtype_breq = cmd->requesttype | (cmd->request << 8); + u16 wValue = cpu_to_le16(cmd->value);
switch (bmrtype_breq & ~USB_DIR_IN) { case (USB_REQ_CLEAR_FEATURE << 8) | USB_RECIP_ENDPOINT: @@ -724,10 +724,10 @@ static int dwc_otg_submit_rh_msg(struct dwc2_priv *priv, struct usb_device *dev, return stat; }
-int wait_for_chhltd(struct dwc2_hc_regs *hc_regs, uint32_t *sub, u8 *toggle) +int wait_for_chhltd(struct dwc2_hc_regs *hc_regs, u32 *sub, u8 *toggle) { int ret; - uint32_t hcint, hctsiz; + u32 hcint, hctsiz;
ret = wait_for_bit_le32(&hc_regs->hcint, HCINTMSK_CHHLTD, true, 2000, false); @@ -764,7 +764,7 @@ static int transfer_chunk(struct dwc2_hc_regs *hc_regs, void *aligned_buffer, int xfer_len, int *actual_len, int odd_frame) { int ret = 0; - uint32_t sub; + u32 sub;
debug("%s: chunk: pid %d xfer_len %u pkts %u\n", __func__, *pid, xfer_len, num_packets); @@ -834,10 +834,10 @@ int chunk_msg(struct dwc2_priv *priv, struct usb_device *dev, int ret = 0; int do_split = 0; int complete_split = 0; - uint32_t xfer_len; - uint32_t num_packets; + u32 xfer_len; + u32 num_packets; int stop_transfer = 0; - uint32_t max_xfer_len; + u32 max_xfer_len; int ssplit_frame_num = 0;
debug("%s: msg: pipe %lx pid %d in %d len %d\n", __func__, pipe, *pid, @@ -859,9 +859,9 @@ int chunk_msg(struct dwc2_priv *priv, struct usb_device *dev,
/* Check if the target is a FS/LS device behind a HS hub */ if (dev->speed != USB_SPEED_HIGH) { - uint8_t hub_addr; - uint8_t hub_port; - uint32_t hprt0 = readl(®s->host_regs.hprt0); + u8 hub_addr; + u8 hub_port; + u32 hprt0 = readl(®s->host_regs.hprt0);
if (FIELD_GET(HPRT0_SPD_MASK, hprt0) == HPRT0_SPD_HIGH_SPEED) { usb_find_usb2_hub_address_port(dev, &hub_addr, @@ -876,7 +876,7 @@ int chunk_msg(struct dwc2_priv *priv, struct usb_device *dev,
do { int actual_len = 0; - uint32_t hcint; + u32 hcint; int odd_frame = 0; xfer_len = len - done;
@@ -1083,7 +1083,7 @@ static int dwc2_reset(struct udevice *dev) static int dwc2_init_common(struct udevice *dev, struct dwc2_priv *priv) { struct dwc2_core_regs *regs = priv->regs; - uint32_t snpsid; + u32 snpsid; int i, j; int ret;
Hi Junhui,
- u32 dflt_gusbcfg;
- u32 rx_fifo_sz, tx_fifo_sz, np_tx_fifo_sz; u32 max_hw_ep; int pdata_hw_ep;
- u8 aligned_buffer[DWC2_DATA_BUF_SIZE] __aligned(ARCH_DMA_MINALIGN);
- u8 status_buffer[DWC2_STATUS_BUF_SIZE] __aligned(ARCH_DMA_MINALIGN);
- u8 *aligned_buffer;
- u8 *status_buffer;
ARCH_DMA_MINALIGN);
ARCH_DMA_MINALIGN);
ARCH_DMA_MINALIGN);
ARCH_DMA_MINALIGN);
- uint32_t phyclk;
- u32 phyclk;
u32 ahbcfg = 0;
u32 usbcfg = 0;
- @param hc Information needed to initialize the host channel
u32 hcsplt = 0;
u32 hprt0 = 0;
len = 2; break; case USB_RECIP_INTERFACE: case USB_RECIP_ENDPOINT:*(u16 *)buffer = cpu_to_le16(1);
len = 2; break; case USB_TYPE_CLASS:*(u16 *)buffer = cpu_to_le16(0);
len = 4; break; case USB_RECIP_OTHER | USB_TYPE_CLASS:*(u32 *)buffer = cpu_to_le32(0);
len = 4; break;*(u32 *)buffer = cpu_to_le32(port_status | (port_change << 16));
- uint32_t dsc;
- u32 dsc; int len = 0; int stat = 0;
len = 1; break; default:*(u8 *)buffer = 0x01;
u32 hcint, hctsiz;
- uint32_t sub;
u32 sub;
- u32 xfer_len;
- u32 num_packets; int stop_transfer = 0;
uint8_t hub_addr;
uint8_t hub_port;
u8 hub_addr;
u8 hub_port;
uint32_t hcint;
int odd_frame = 0; xfer_len = len - done;u32 hcint;
- uint32_t snpsid;
- u32 snpsid; int i, j; int ret;
-- 2.47.1
Junhui Liu
Mattijs Korpershoek
