[U-Boot] Support for Calao USB A9263 board based on AT91SAM9263 CPU
Hello,
Here is a patch that adds the support for the Calao USB A9263 board. This is my first board support contribution to U-Boot, so don't hesitate to comment and suggest improvements.
Thanks,
Thomas
Support for the Calao USB A9263 board
The Calao USB A9263 board is a board manufactured and sold by Calao Systems http://www.calao-systems.com. Its components are very similar to the AT91SAM9263EK board, so its configuration is based on the configuration of this board. There are however some differences: different clocks, no LCD, etc.
Signed-off-by: Thomas Petazzoni thomas.petazzoni@free-electrons.com
MAKEALL | 1 Makefile | 3 board/usb-a9263/Makefile | 56 +++++++++++++ board/usb-a9263/config.mk | 1 board/usb-a9263/led.c | 44 ++++++++++ board/usb-a9263/partition.c | 37 ++++++++ board/usb-a9263/usb-a9263.c | 189 ++++++++++++++++++++++++++++++++++++++++++++ include/configs/usb-a9263.h | 188 +++++++++++++++++++++++++++++++++++++++++++ 8 files changed, 519 insertions(+)
diff --git a/MAKEALL b/MAKEALL index f4599d6..6581427 100755 --- a/MAKEALL +++ b/MAKEALL @@ -590,6 +590,7 @@ LIST_at91=" \ mp2usb \ m501sk \ pm9263 \ + usb-a9263 \ "
######################################################################### diff --git a/Makefile b/Makefile index bcc81c9..176885f 100644 --- a/Makefile +++ b/Makefile @@ -2785,6 +2785,9 @@ at91sam9rlek_config : unconfig pm9263_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs pm9263 ronetix at91
+usb_a9263_config : unconfig + $(MKCONFIG) -a usb-a9263 arm arm926ejs usb-a9263 NULL at91 + ######################################################################## ## ARM Integrator boards - see doc/README-integrator for more info. integratorap_config \ diff --git a/board/usb-a9263/Makefile b/board/usb-a9263/Makefile new file mode 100644 index 0000000..18325e0 --- /dev/null +++ b/board/usb-a9263/Makefile @@ -0,0 +1,56 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += usb-a9263.o +COBJS-y += led.o +COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/usb-a9263/config.mk b/board/usb-a9263/config.mk new file mode 100644 index 0000000..ff2cfd1 --- /dev/null +++ b/board/usb-a9263/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x23f00000 diff --git a/board/usb-a9263/led.c b/board/usb-a9263/led.c new file mode 100644 index 0000000..82c5388 --- /dev/null +++ b/board/usb-a9263/led.c @@ -0,0 +1,44 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9263.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void coloured_LED_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOB | + 1 << AT91SAM9263_ID_PIOCDE); + + at91_set_gpio_output(CONFIG_RED_LED, 1); + at91_set_gpio_output(CONFIG_GREEN_LED, 1); + at91_set_gpio_output(CONFIG_YELLOW_LED, 1); + + at91_set_gpio_value(CONFIG_RED_LED, 0); + at91_set_gpio_value(CONFIG_GREEN_LED, 1); + at91_set_gpio_value(CONFIG_YELLOW_LED, 1); +} diff --git a/board/usb-a9263/partition.c b/board/usb-a9263/partition.c new file mode 100644 index 0000000..94ec265 --- /dev/null +++ b/board/usb-a9263/partition.c @@ -0,0 +1,37 @@ +/* + * (C) Copyright 2008 + * Ulf Samuelsson ulf@atmel.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#include <common.h> +#include <config.h> +#include <asm/hardware.h> +#include <dataflash.h> + +AT91S_DATAFLASH_INFO dataflash_info[CONFIG_SYS_MAX_DATAFLASH_BANKS]; + +struct dataflash_addr cs[CONFIG_SYS_MAX_DATAFLASH_BANKS] = { + {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0, 0}, /* Logical adress, CS */ +}; + +/*define the area offsets*/ +dataflash_protect_t area_list[NB_DATAFLASH_AREA] = { + {0x00000000, 0x00001FFF, FLAG_PROTECT_SET, 0, "Bootstrap"}, + {0x00002000, 0x00003FFF, FLAG_PROTECT_CLEAR, 0, "Environment"}, + {0x00004000, 0xFFFFFFFF, FLAG_PROTECT_SET, 0, "U-Boot"}, +}; diff --git a/board/usb-a9263/usb-a9263.c b/board/usb-a9263/usb-a9263.c new file mode 100644 index 0000000..0f00e82 --- /dev/null +++ b/board/usb-a9263/usb-a9263.c @@ -0,0 +1,189 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/sizes.h> +#include <asm/arch/at91sam9263.h> +#include <asm/arch/at91sam9263_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/clk.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> +#include <asm/arch/hardware.h> +#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) +#include <net.h> +#endif +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +#ifdef CONFIG_CMD_NAND +static void usb_a9263_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBI0CSA); + at91_sys_write(AT91_MATRIX_EBI0CSA, + csa | AT91_MATRIX_EBI0_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | +#ifdef CONFIG_SYS_NAND_DBW_16 + AT91_SMC_DBW_16 | +#else /* CONFIG_SYS_NAND_DBW_8 */ + AT91_SMC_DBW_8 | +#endif + AT91_SMC_TDF_(2)); + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOA | + 1 << AT91SAM9263_ID_PIOCDE); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} +#endif + +#ifdef CONFIG_MACB +static void usb_a9263_macb_hw_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_EMAC); + + /* + * Disable pull-up on: + * RXDV (PC25) => PHY normal mode (not Test mode) + * ERX0 (PE25) => PHY ADDR0 + * ERX1 (PE26) => PHY ADDR1 => PHYADDR = 0x0 + * + * PHY has internal pull-down + */ + writel(pin_to_mask(AT91_PIN_PC25), + pin_to_controller(AT91_PIN_PC0) + PIO_PUDR); + writel(pin_to_mask(AT91_PIN_PE25) | + pin_to_mask(AT91_PIN_PE26), + pin_to_controller(AT91_PIN_PE0) + PIO_PUDR); + + /* Need to reset PHY -> 500ms reset */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + (AT91_RSTC_ERSTL & (0x0D << 8)) | + AT91_RSTC_URSTEN); + + at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST); + + /* Wait for end hardware reset */ + while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL)); + + /* Restore NRST value */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + (AT91_RSTC_ERSTL & (0x0 << 8)) | + AT91_RSTC_URSTEN); + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PC25), + pin_to_controller(AT91_PIN_PC0) + PIO_PUER); + writel(pin_to_mask(AT91_PIN_PE25) | + pin_to_mask(AT91_PIN_PE26), + pin_to_controller(AT91_PIN_PE0) + PIO_PUER); + + at91_macb_hw_init(); +} +#endif + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of USB-A9263-Board */ + gd->bd->bi_arch_number = MACH_TYPE_USB_A9263; + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + usb_a9263_nand_hw_init(); +#endif +#ifdef CONFIG_HAS_DATAFLASH + at91_set_gpio_output(AT91_PIN_PE20, 1); /* select spi0 clock */ + at91_spi0_hw_init(1 << 0); +#endif +#ifdef CONFIG_MACB + usb_a9263_macb_hw_init(); +#endif +#ifdef CONFIG_USB_OHCI_NEW + at91_uhp_hw_init(); +#endif + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +void reset_phy(void) +{ +#ifdef CONFIG_MACB + /* + * Initialize ethernet HW addr prior to starting Linux, + * needed for nfsroot + */ + eth_init(gd->bd); +#endif +} +#endif + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_MACB + rc = macb_eth_initialize(0, (void *)AT91SAM9263_BASE_EMAC, 0x00); +#endif + return rc; +} diff --git a/include/configs/usb-a9263.h b/include/configs/usb-a9263.h new file mode 100644 index 0000000..6bf6c8f --- /dev/null +++ b/include/configs/usb-a9263.h @@ -0,0 +1,188 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Thomas Petazzoni thomas.petazzoni@free-electrons.com + * + * Configuration settings for the Calao USB-A9263 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* ARM asynchronous clock */ +#define AT91_CPU_NAME "AT91SAM9263" +#define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +#define CONFIG_AT91SAM9263 1 /* It's an Atmel AT91SAM9263 SoC*/ +#define CONFIG_CALAO_USB_A9263 1 /* on an Calao USB A 9263 Board */ +#define CONFIG_ARCH_CPU_INIT +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT + +/* + * Hardware drivers + */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +/* LCD */ +#undef CONFIG_LCD + +/* LED */ +#define CONFIG_AT91_LED +#define CONFIG_RED_LED AT91_PIN_PB7 /* this is the power led */ +#define CONFIG_GREEN_LED AT91_PIN_PB8 /* this is the user1 led */ +#define CONFIG_YELLOW_LED AT91_PIN_PC29 /* this is the user2 led */ + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_USB 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE 0x04000000 /* 64 megs */ + +/* DataFlash */ +#define CONFIG_ATMEL_DATAFLASH_SPI +#define CONFIG_HAS_DATAFLASH 1 +#define CONFIG_SYS_SPI_WRITE_TOUT (5*CONFIG_SYS_HZ) +#define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 +#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ +#define AT91_SPI_CLK 8000000 +#define DATAFLASH_TCSS (0x1c << 16) +#define DATAFLASH_TCHS (0x1 << 24) + +/* no NOR flash */ +#define CONFIG_SYS_NO_FLASH 1 + +/* NAND flash */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_DBW_8 1 +/* our ALE is AD21 */ +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +/* our CLE is AD22 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PD15 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PA22 +#endif + +/* Ethernet */ +#define CONFIG_MACB 1 +#define CONFIG_RMII 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_RESET_PHY_R 1 +#define CONFIG_MACB_SEARCH_PHY 1 +#define CONFIG_ETHADDR 00:0D:00:0D:00:AB + +/* USB */ +#define CONFIG_USB_ATMEL +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00a00000 /* AT91SAM9263_UHP_BASE */ +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9263" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 +#define CONFIG_CMD_FAT 1 + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END 0x23e00000 + +/* bootstrap + u-boot + env in dataflash on CS0 */ +#define CONFIG_ENV_IS_IN_DATAFLASH 1 +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0) +#define CONFIG_ENV_OFFSET 0x2000 +#define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_BOOTCOMMAND "nboot 21000000 0" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock1 " \ + "mtdparts=atmel_nand:2m(kernel)ro,-(root) "\ + "rw rootfstype=jffs2" + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "U-Boot> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define ROUND(A, B) (((A) + (B)) & ~((B) - 1)) +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32*1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif
On 14:07 Wed 01 Jul , Thomas Petazzoni wrote:
Hello,
Thanks,
Thomas
this need to move after ---
and this before
- /* Enable clock */
- at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_EMAC);
- writel(pin_to_mask(AT91_PIN_PC25),
- writel(pin_to_mask(AT91_PIN_PE25) |
- /* Need to reset PHY -> 500ms reset */
- at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY |
AT91_RSTC_URSTEN);
- at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST);
- /* Wait for end hardware reset */
- while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL));
- /* Restore NRST value */
AT91_RSTC_URSTEN);
please check recent Sedji fix for this at91sam9260/9263: add back up for the rst(reset controller).
- /* Re-enable pull-up */
- at91_macb_hw_init();
+} +#endif
<snip>
--- /dev/null
- (C) Copyright 2007-2008
- Stelian Pop stelian.pop@leadtechdesign.com
- Lead Tech Design <www.leadtechdesign.com>
- Thomas Petazzoni thomas.petazzoni@free-electrons.com
- Configuration settings for the Calao USB-A9263 board.
- project.
- MA 02111-1307 USA
no-need please remove
- Hardware drivers
- BOOTP options
- Command line configuration.
whitespace please fix
please remove
Best Regards, J.
Changes from previous version:
* Take into account comments from Jean-Christophe Plagniol-Villard (whitespace issues, integration of MABC RST fix, removal of MAC address setting in board configuration file)
* Moved board-specific code from board/usb-a9263/ to board/calao/usb-a9263/, since support for other boards from Calao will follow shortly.
* Rebased and re-tested with latest U-Boot git.
Thanks for the review and feedback!
MAKEALL | 1 Makefile | 3 board/calao/usb-a9263/Makefile | 56 ++++++++ board/calao/usb-a9263/config.mk | 1 board/calao/usb-a9263/led.c | 44 ++++++ board/calao/usb-a9263/partition.c | 37 +++++ board/calao/usb-a9263/usb-a9263.c | 193 ++++++++++++++++++++++++++++ include/configs/usb-a9263.h | 186 ++++++++++++++++++++++++++ 8 files changed, 521 insertions(+)
diff --git a/MAKEALL b/MAKEALL index 020ff73..452d09a 100755 --- a/MAKEALL +++ b/MAKEALL @@ -599,6 +599,7 @@ LIST_at91=" \ m501sk \ pm9261 \ pm9263 \ + usb9263 \ "
######################################################################### diff --git a/Makefile b/Makefile index 090e645..244b8b1 100644 --- a/Makefile +++ b/Makefile @@ -2847,6 +2847,9 @@ at91sam9g45ekes_config : unconfig pm9263_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs pm9263 ronetix at91
+usb_a9263_config : unconfig + $(MKCONFIG) -a usb-a9263 arm arm926ejs usb-a9263 calao at91 + ######################################################################## ## ARM Integrator boards - see doc/README-integrator for more info. integratorap_config \ diff --git a/board/calao/usb-a9263/Makefile b/board/calao/usb-a9263/Makefile new file mode 100644 index 0000000..18325e0 --- /dev/null +++ b/board/calao/usb-a9263/Makefile @@ -0,0 +1,56 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += usb-a9263.o +COBJS-y += led.o +COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/calao/usb-a9263/config.mk b/board/calao/usb-a9263/config.mk new file mode 100644 index 0000000..ff2cfd1 --- /dev/null +++ b/board/calao/usb-a9263/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x23f00000 diff --git a/board/calao/usb-a9263/led.c b/board/calao/usb-a9263/led.c new file mode 100644 index 0000000..82c5388 --- /dev/null +++ b/board/calao/usb-a9263/led.c @@ -0,0 +1,44 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9263.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void coloured_LED_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOB | + 1 << AT91SAM9263_ID_PIOCDE); + + at91_set_gpio_output(CONFIG_RED_LED, 1); + at91_set_gpio_output(CONFIG_GREEN_LED, 1); + at91_set_gpio_output(CONFIG_YELLOW_LED, 1); + + at91_set_gpio_value(CONFIG_RED_LED, 0); + at91_set_gpio_value(CONFIG_GREEN_LED, 1); + at91_set_gpio_value(CONFIG_YELLOW_LED, 1); +} diff --git a/board/calao/usb-a9263/partition.c b/board/calao/usb-a9263/partition.c new file mode 100644 index 0000000..94ec265 --- /dev/null +++ b/board/calao/usb-a9263/partition.c @@ -0,0 +1,37 @@ +/* + * (C) Copyright 2008 + * Ulf Samuelsson ulf@atmel.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#include <common.h> +#include <config.h> +#include <asm/hardware.h> +#include <dataflash.h> + +AT91S_DATAFLASH_INFO dataflash_info[CONFIG_SYS_MAX_DATAFLASH_BANKS]; + +struct dataflash_addr cs[CONFIG_SYS_MAX_DATAFLASH_BANKS] = { + {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0, 0}, /* Logical adress, CS */ +}; + +/*define the area offsets*/ +dataflash_protect_t area_list[NB_DATAFLASH_AREA] = { + {0x00000000, 0x00001FFF, FLAG_PROTECT_SET, 0, "Bootstrap"}, + {0x00002000, 0x00003FFF, FLAG_PROTECT_CLEAR, 0, "Environment"}, + {0x00004000, 0xFFFFFFFF, FLAG_PROTECT_SET, 0, "U-Boot"}, +}; diff --git a/board/calao/usb-a9263/usb-a9263.c b/board/calao/usb-a9263/usb-a9263.c new file mode 100644 index 0000000..bf6b87e --- /dev/null +++ b/board/calao/usb-a9263/usb-a9263.c @@ -0,0 +1,193 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/sizes.h> +#include <asm/arch/at91sam9263.h> +#include <asm/arch/at91sam9263_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/clk.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> +#include <asm/arch/hardware.h> +#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) +#include <net.h> +#endif +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +#ifdef CONFIG_CMD_NAND +static void usb_a9263_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBI0CSA); + at91_sys_write(AT91_MATRIX_EBI0CSA, + csa | AT91_MATRIX_EBI0_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | +#ifdef CONFIG_SYS_NAND_DBW_16 + AT91_SMC_DBW_16 | +#else /* CONFIG_SYS_NAND_DBW_8 */ + AT91_SMC_DBW_8 | +#endif + AT91_SMC_TDF_(2)); + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOA | + 1 << AT91SAM9263_ID_PIOCDE); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} +#endif + +#ifdef CONFIG_MACB +static void usb_a9263_macb_hw_init(void) +{ + unsigned long rstc; + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_EMAC); + + /* + * Disable pull-up on: + * RXDV (PC25) => PHY normal mode (not Test mode) + * ERX0 (PE25) => PHY ADDR0 + * ERX1 (PE26) => PHY ADDR1 => PHYADDR = 0x0 + * + * PHY has internal pull-down + */ + writel(pin_to_mask(AT91_PIN_PC25), + pin_to_controller(AT91_PIN_PC0) + PIO_PUDR); + writel(pin_to_mask(AT91_PIN_PE25) | + pin_to_mask(AT91_PIN_PE26), + pin_to_controller(AT91_PIN_PE0) + PIO_PUDR); + + rstc = at91_sys_read(AT91_RSTC_MR) & AT91_RSTC_ERSTL; + + /* Need to reset PHY -> 500ms reset */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + (AT91_RSTC_ERSTL & (0x0D << 8)) | + AT91_RSTC_URSTEN); + + at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST); + + /* Wait for end hardware reset */ + while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL)); + + /* Restore NRST value */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + (rstc) | + AT91_RSTC_URSTEN); + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PC25), + pin_to_controller(AT91_PIN_PC0) + PIO_PUER); + writel(pin_to_mask(AT91_PIN_PE25) | + pin_to_mask(AT91_PIN_PE26), + pin_to_controller(AT91_PIN_PE0) + PIO_PUER); + + at91_macb_hw_init(); +} +#endif + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of USB-A9263-Board */ + gd->bd->bi_arch_number = MACH_TYPE_USB_A9263; + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + usb_a9263_nand_hw_init(); +#endif +#ifdef CONFIG_HAS_DATAFLASH + at91_set_gpio_output(AT91_PIN_PE20, 1); /* select spi0 clock */ + at91_spi0_hw_init(1 << 0); +#endif +#ifdef CONFIG_MACB + usb_a9263_macb_hw_init(); +#endif +#ifdef CONFIG_USB_OHCI_NEW + at91_uhp_hw_init(); +#endif + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +void reset_phy(void) +{ +#ifdef CONFIG_MACB + /* + * Initialize ethernet HW addr prior to starting Linux, + * needed for nfsroot + */ + eth_init(gd->bd); +#endif +} +#endif + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_MACB + rc = macb_eth_initialize(0, (void *)AT91SAM9263_BASE_EMAC, 0x00); +#endif + return rc; +} diff --git a/include/configs/usb-a9263.h b/include/configs/usb-a9263.h new file mode 100644 index 0000000..b670f5f --- /dev/null +++ b/include/configs/usb-a9263.h @@ -0,0 +1,186 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Thomas Petazzoni thomas.petazzoni@free-electrons.com + * + * Configuration settings for the Calao USB-A9263 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* ARM asynchronous clock */ +#define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +#define CONFIG_AT91SAM9263 1 /* It's an Atmel AT91SAM9263 SoC*/ +#define CONFIG_CALAO_USB_A9263 1 /* on an Calao USB A 9263 Board */ +#define CONFIG_ARCH_CPU_INIT +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT + +/* + * Hardware drivers + */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +/* LCD */ +#undef CONFIG_LCD + +/* LED */ +#define CONFIG_AT91_LED +#define CONFIG_RED_LED AT91_PIN_PB7 /* this is the power led */ +#define CONFIG_GREEN_LED AT91_PIN_PB8 /* this is the user1 led */ +#define CONFIG_YELLOW_LED AT91_PIN_PC29 /* this is the user2 led */ + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_USB 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE 0x04000000 /* 64 megs */ + +/* DataFlash */ +#define CONFIG_ATMEL_DATAFLASH_SPI +#define CONFIG_HAS_DATAFLASH 1 +#define CONFIG_SYS_SPI_WRITE_TOUT (5*CONFIG_SYS_HZ) +#define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 +#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ +#define AT91_SPI_CLK 8000000 +#define DATAFLASH_TCSS (0x1c << 16) +#define DATAFLASH_TCHS (0x1 << 24) + +/* no NOR flash */ +#define CONFIG_SYS_NO_FLASH 1 + +/* NAND flash */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_DBW_8 1 +/* our ALE is AD21 */ +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +/* our CLE is AD22 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PD15 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PA22 +#endif + +/* Ethernet */ +#define CONFIG_MACB 1 +#define CONFIG_RMII 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_RESET_PHY_R 1 +#define CONFIG_MACB_SEARCH_PHY 1 + +/* USB */ +#define CONFIG_USB_ATMEL +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00a00000 /* AT91SAM9263_UHP_BASE */ +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9263" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 +#define CONFIG_CMD_FAT 1 + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END 0x23e00000 + +/* bootstrap + u-boot + env in dataflash on CS0 */ +#define CONFIG_ENV_IS_IN_DATAFLASH 1 +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0) +#define CONFIG_ENV_OFFSET 0x2000 +#define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_BOOTCOMMAND "nboot 21000000 0" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock1 " \ + "mtdparts=atmel_nand:2m(kernel)ro,-(root) "\ + "rw rootfstype=jffs2" + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "U-Boot> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define ROUND(A, B) (((A) + (B)) & ~((B) - 1)) +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32*1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif
You can get rid of the line above. It is nearly identical to the patch subject and doesn't add any useful info.
<snip>
You should add an entry to MAINTAINERS
<snip>
Funky indentation.
<snip>
I'd try and use the round functions already in include/common.h if possible. Maybe its not possible if this file is included prior to common.h though, I'm not sure.
Best, Peter
Ok.
Done.
Funky indentation.
Fixed.
Not sure about this one. All at91 boards do it this way, so if a fix needs to be done, I'd suggest to make it separatly. Is this ok ?
Below is an updated version of the patch. Not sure it's the right way to resend it, though.
Thanks for the review!
Thomas
MAINTAINERS | 4 MAKEALL | 1 Makefile | 3 board/calao/usb-a9263/Makefile | 56 ++++++++ board/calao/usb-a9263/config.mk | 1 board/calao/usb-a9263/led.c | 44 ++++++ board/calao/usb-a9263/partition.c | 37 +++++ board/calao/usb-a9263/usb-a9263.c | 193 ++++++++++++++++++++++++++++ include/configs/usb-a9263.h | 186 ++++++++++++++++++++++++++ 9 files changed, 525 insertions(+)
diff --git a/MAINTAINERS b/MAINTAINERS index 575a7ec..5c37647 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -624,6 +624,10 @@ Peter Pearse peter.pearse@arm.com versatile ARM926EJ-S versatile ARM926EJ-S
+Thomas Petazzoni thomas.petazzoni@free-electrons.com + + usb-a9263 ARM926EJS (AT91SAM9263 SoC) + Dave Peverley dpeverley@mpc-data.co.uk
omap730p2 ARM926EJS diff --git a/MAKEALL b/MAKEALL index 020ff73..452d09a 100755 --- a/MAKEALL +++ b/MAKEALL @@ -599,6 +599,7 @@ LIST_at91=" \ m501sk \ pm9261 \ pm9263 \ + usb9263 \ "
+usb_a9263_config : unconfig + $(MKCONFIG) -a usb-a9263 arm arm926ejs usb-a9263 calao at91 + ######################################################################## ## ARM Integrator boards - see doc/README-integrator for more info. integratorap_config \ diff --git a/board/calao/usb-a9263/Makefile b/board/calao/usb-a9263/Makefile new file mode 100644 index 0000000..18325e0 --- /dev/null +++ b/board/calao/usb-a9263/Makefile @@ -0,0 +1,56 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += usb-a9263.o +COBJS-y += led.o +COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/calao/usb-a9263/config.mk b/board/calao/usb-a9263/config.mk new file mode 100644 index 0000000..ff2cfd1 --- /dev/null +++ b/board/calao/usb-a9263/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x23f00000 diff --git a/board/calao/usb-a9263/led.c b/board/calao/usb-a9263/led.c new file mode 100644 index 0000000..82c5388 --- /dev/null +++ b/board/calao/usb-a9263/led.c @@ -0,0 +1,44 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9263.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void coloured_LED_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOB | + 1 << AT91SAM9263_ID_PIOCDE); + + at91_set_gpio_output(CONFIG_RED_LED, 1); + at91_set_gpio_output(CONFIG_GREEN_LED, 1); + at91_set_gpio_output(CONFIG_YELLOW_LED, 1); + + at91_set_gpio_value(CONFIG_RED_LED, 0); + at91_set_gpio_value(CONFIG_GREEN_LED, 1); + at91_set_gpio_value(CONFIG_YELLOW_LED, 1); +} diff --git a/board/calao/usb-a9263/partition.c b/board/calao/usb-a9263/partition.c new file mode 100644 index 0000000..94ec265 --- /dev/null +++ b/board/calao/usb-a9263/partition.c @@ -0,0 +1,37 @@ +/* + * (C) Copyright 2008 + * Ulf Samuelsson ulf@atmel.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#include <common.h> +#include <config.h> +#include <asm/hardware.h> +#include <dataflash.h> + +AT91S_DATAFLASH_INFO dataflash_info[CONFIG_SYS_MAX_DATAFLASH_BANKS]; + +struct dataflash_addr cs[CONFIG_SYS_MAX_DATAFLASH_BANKS] = { + {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0, 0}, /* Logical adress, CS */ +}; + +/*define the area offsets*/ +dataflash_protect_t area_list[NB_DATAFLASH_AREA] = { + {0x00000000, 0x00001FFF, FLAG_PROTECT_SET, 0, "Bootstrap"}, + {0x00002000, 0x00003FFF, FLAG_PROTECT_CLEAR, 0, "Environment"}, + {0x00004000, 0xFFFFFFFF, FLAG_PROTECT_SET, 0, "U-Boot"}, +}; diff --git a/board/calao/usb-a9263/usb-a9263.c b/board/calao/usb-a9263/usb-a9263.c new file mode 100644 index 0000000..bf6b87e --- /dev/null +++ b/board/calao/usb-a9263/usb-a9263.c @@ -0,0 +1,193 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/sizes.h> +#include <asm/arch/at91sam9263.h> +#include <asm/arch/at91sam9263_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/clk.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> +#include <asm/arch/hardware.h> +#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) +#include <net.h> +#endif +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +#ifdef CONFIG_CMD_NAND +static void usb_a9263_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBI0CSA); + at91_sys_write(AT91_MATRIX_EBI0CSA, + csa | AT91_MATRIX_EBI0_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | +#ifdef CONFIG_SYS_NAND_DBW_16 + AT91_SMC_DBW_16 | +#else /* CONFIG_SYS_NAND_DBW_8 */ + AT91_SMC_DBW_8 | +#endif + AT91_SMC_TDF_(2)); + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOA | + 1 << AT91SAM9263_ID_PIOCDE); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} +#endif + +#ifdef CONFIG_MACB +static void usb_a9263_macb_hw_init(void) +{ + unsigned long rstc; + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_EMAC); + + /* + * Disable pull-up on: + * RXDV (PC25) => PHY normal mode (not Test mode) + * ERX0 (PE25) => PHY ADDR0 + * ERX1 (PE26) => PHY ADDR1 => PHYADDR = 0x0 + * + * PHY has internal pull-down + */ + writel(pin_to_mask(AT91_PIN_PC25), + pin_to_controller(AT91_PIN_PC0) + PIO_PUDR); + writel(pin_to_mask(AT91_PIN_PE25) | + pin_to_mask(AT91_PIN_PE26), + pin_to_controller(AT91_PIN_PE0) + PIO_PUDR); + + rstc = at91_sys_read(AT91_RSTC_MR) & AT91_RSTC_ERSTL; + + /* Need to reset PHY -> 500ms reset */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + (AT91_RSTC_ERSTL & (0x0D << 8)) | + AT91_RSTC_URSTEN); + + at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST); + + /* Wait for end hardware reset */ + while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL)); + + /* Restore NRST value */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + (rstc) | + AT91_RSTC_URSTEN); + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PC25), + pin_to_controller(AT91_PIN_PC0) + PIO_PUER); + writel(pin_to_mask(AT91_PIN_PE25) | + pin_to_mask(AT91_PIN_PE26), + pin_to_controller(AT91_PIN_PE0) + PIO_PUER); + + at91_macb_hw_init(); +} +#endif + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of USB-A9263-Board */ + gd->bd->bi_arch_number = MACH_TYPE_USB_A9263; + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + usb_a9263_nand_hw_init(); +#endif +#ifdef CONFIG_HAS_DATAFLASH + at91_set_gpio_output(AT91_PIN_PE20, 1); /* select spi0 clock */ + at91_spi0_hw_init(1 << 0); +#endif +#ifdef CONFIG_MACB + usb_a9263_macb_hw_init(); +#endif +#ifdef CONFIG_USB_OHCI_NEW + at91_uhp_hw_init(); +#endif + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +void reset_phy(void) +{ +#ifdef CONFIG_MACB + /* + * Initialize ethernet HW addr prior to starting Linux, + * needed for nfsroot + */ + eth_init(gd->bd); +#endif +} +#endif + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_MACB + rc = macb_eth_initialize(0, (void *)AT91SAM9263_BASE_EMAC, 0x00); +#endif + return rc; +} diff --git a/include/configs/usb-a9263.h b/include/configs/usb-a9263.h new file mode 100644 index 0000000..fe479b2 --- /dev/null +++ b/include/configs/usb-a9263.h @@ -0,0 +1,186 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Thomas Petazzoni thomas.petazzoni@free-electrons.com + * + * Configuration settings for the Calao USB-A9263 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* ARM asynchronous clock */ +#define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +#define CONFIG_AT91SAM9263 1 /* It's an Atmel AT91SAM9263 SoC*/ +#define CONFIG_CALAO_USB_A9263 1 /* on an Calao USB A 9263 Board */ +#define CONFIG_ARCH_CPU_INIT +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT + +/* + * Hardware drivers + */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +/* LCD */ +#undef CONFIG_LCD + +/* LED */ +#define CONFIG_AT91_LED +#define CONFIG_RED_LED AT91_PIN_PB7 /* this is the power led */ +#define CONFIG_GREEN_LED AT91_PIN_PB8 /* this is the user1 led */ +#define CONFIG_YELLOW_LED AT91_PIN_PC29 /* this is the user2 led */ + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_USB 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE 0x04000000 /* 64 megs */ + +/* DataFlash */ +#define CONFIG_ATMEL_DATAFLASH_SPI +#define CONFIG_HAS_DATAFLASH 1 +#define CONFIG_SYS_SPI_WRITE_TOUT (5*CONFIG_SYS_HZ) +#define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 +#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ +#define AT91_SPI_CLK 8000000 +#define DATAFLASH_TCSS (0x1c << 16) +#define DATAFLASH_TCHS (0x1 << 24) + +/* no NOR flash */ +#define CONFIG_SYS_NO_FLASH 1 + +/* NAND flash */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_DBW_8 1 +/* our ALE is AD21 */ +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +/* our CLE is AD22 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PD15 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PA22 +#endif + +/* Ethernet */ +#define CONFIG_MACB 1 +#define CONFIG_RMII 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_RESET_PHY_R 1 +#define CONFIG_MACB_SEARCH_PHY 1 + +/* USB */ +#define CONFIG_USB_ATMEL +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00a00000 /* AT91SAM9263_UHP_BASE */ +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9263" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 +#define CONFIG_CMD_FAT 1 + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END 0x23e00000 + +/* bootstrap + u-boot + env in dataflash on CS0 */ +#define CONFIG_ENV_IS_IN_DATAFLASH 1 +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0) +#define CONFIG_ENV_OFFSET 0x2000 +#define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_BOOTCOMMAND "nboot 21000000 0" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock1 " \ + "mtdparts=atmel_nand:2m(kernel)ro,-(root) "\ + "rw rootfstype=jffs2" + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "U-Boot> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define ROUND(A, B) (((A) + (B)) & ~((B) - 1)) +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32*1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif
Hi Thomas,
I don't have the final say here, I'm just giving my opinion. If it was possible to clean up, the best way in my would be to fix your board (ie this patch), then send a separate follow-up patch fixing other boards. I don't think its too big of a deal either way.
Not quite the right way. As is, all your comments above would go into U-Boot's changelog, which you don't want. You should either send your patch and comments in separate emails, or put any comments you don't want in the changelog below the --- mentioned below.
You need to add a '---' line here. Anything from the --- to the first diff below are only comments and will be discarded when your patch is applied.
<snip>
You should add a copyright header of some sort to config.mk.
Best, Peter
Including <common.h> in a include/configs/ configuration file doesn't seem to work, unfortunately.
In a one-line file, which just contains a factual definition ?
Thanks!
Thomas
There might be other ways, eg it looks like Wolfgang addressed the issue in this patch: http://www.mail-archive.com/u-boot@lists.denx.de/msg17937.html
Does that patch work for you? I'm assuming it will go in the next U-Boot release.
In my opinion yes. A copyright will explicitly say how the file may be used, trivial as it may be. Check out doc/feature-removal-schedule.txt:
What: GPL cleanup When: August 2009 Why: Over time, a couple of files have sneaked in into the U-Boot source code that are either missing a valid GPL license header or that carry a license that is incompatible with the GPL. Such files shall be removed from the U-Boot source tree. See http://www.denx.de/wiki/pub/U-Boot/TaskGplCleanup/u-boot-1.1.2-files for an old and probably incomplete list of such files.
You're free to use whatever license you'd like, as long as its GPL compatible. There's no harm in adding a license header, right?
Best, Peter
Dear Thomas Petazzoni,
Entries to maintainers is missing.
- gd->bd->bi_dram[0].start = PHYS_SDRAM;
- gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE;
Any specific reason for not using autosizing and testing via get_ram_size() ?
Line too long. Please fix globally.
Yes, it was missing in the initial version of my patch, but further versions got it added, thanks to other people review.
The initial reason is that the code for this board is taken from the Atmel boards code, which doesn't use get_ram_size(). However, my board has a fixed RAM size, so in that case, is it still useful to use get_ram_size() ?
Thanks, will do.
Thomas
Yes, it is still useful, as it will for example detect most memory errors and as such broken (or dying) hardware.
This new version includes the following changes :
* Copyright header on config.mk, by suggestion of Peter Tyser
* Updated copyright informations in all new files
* Use get_ram_size(), as suggested by Wolfgang Denk
* Do some cleanup of useless comments, re-indent definitions to avoid long lines, etc.
* Add entry to MAINTAINERS
I'm still including the definition of ROUND() in the board configuration file, since Wolfgang's patch has yet been merged to the Git tree (and I don't think sending a patch that doesn't compile against the current Git tree is useful).
MAINTAINERS | 4 MAKEALL | 1 Makefile | 3 board/calao/usb-a9263/Makefile | 58 +++++++++++ board/calao/usb-a9263/config.mk | 24 ++++ board/calao/usb-a9263/partition.c | 38 +++++++ board/calao/usb-a9263/usb-a9263.c | 194 ++++++++++++++++++++++++++++++++++++++ include/configs/usb-a9263.h | 185 ++++++++++++++++++++++++++++++++++++ 8 files changed, 507 insertions(+)
######################################################################### diff --git a/Makefile b/Makefile index 4fe3232..e484204 100644 --- a/Makefile +++ b/Makefile @@ -2807,6 +2807,9 @@ at91sam9g45ekes_config : unconfig pm9263_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs pm9263 ronetix at91
+usb_a9263_config : unconfig + $(MKCONFIG) -a usb-a9263 arm arm926ejs usb-a9263 calao at91 + ######################################################################## ## ARM Integrator boards - see doc/README-integrator for more info. integratorap_config \ diff --git a/board/calao/usb-a9263/Makefile b/board/calao/usb-a9263/Makefile new file mode 100644 index 0000000..ec79872 --- /dev/null +++ b/board/calao/usb-a9263/Makefile @@ -0,0 +1,58 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# +# (C) Copyright 2009 +# Thomas Petazzoni, Free Electrons, thomas.petazzoni@free-electrons.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += usb-a9263.o +COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/calao/usb-a9263/config.mk b/board/calao/usb-a9263/config.mk new file mode 100644 index 0000000..2724a7d --- /dev/null +++ b/board/calao/usb-a9263/config.mk @@ -0,0 +1,24 @@ +# +# (C) Copyright 2009 +# Thomas Petazzoni, Free Electrons, thomas.petazzoni@free-electrons.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +TEXT_BASE = 0x23f00000 diff --git a/board/calao/usb-a9263/partition.c b/board/calao/usb-a9263/partition.c new file mode 100644 index 0000000..614ef0d --- /dev/null +++ b/board/calao/usb-a9263/partition.c @@ -0,0 +1,38 @@ +/* + * (C) Copyright 2008-2009 + * Ulf Samuelsson ulf@atmel.com + * Thomas Petazzoni, Free Electrons, thomas.petazzoni@free-electrons.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#include <common.h> +#include <config.h> +#include <asm/hardware.h> +#include <dataflash.h> + +AT91S_DATAFLASH_INFO dataflash_info[CONFIG_SYS_MAX_DATAFLASH_BANKS]; + +struct dataflash_addr cs[CONFIG_SYS_MAX_DATAFLASH_BANKS] = { + {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0, 0}, /* Logical adress, CS */ +}; + +/*define the area offsets*/ +dataflash_protect_t area_list[NB_DATAFLASH_AREA] = { + {0x00000000, 0x00001FFF, FLAG_PROTECT_SET, 0, "Bootstrap"}, + {0x00002000, 0x00003FFF, FLAG_PROTECT_CLEAR, 0, "Environment"}, + {0x00004000, 0xFFFFFFFF, FLAG_PROTECT_SET, 0, "U-Boot"}, +}; diff --git a/board/calao/usb-a9263/usb-a9263.c b/board/calao/usb-a9263/usb-a9263.c new file mode 100644 index 0000000..7cf1925 --- /dev/null +++ b/board/calao/usb-a9263/usb-a9263.c @@ -0,0 +1,194 @@ +/* + * (C) Copyright 2007-2009 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Thomas Petazzoni, Free Electrons, thomas.petazzoni@free-electrons.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/sizes.h> +#include <asm/arch/at91sam9263.h> +#include <asm/arch/at91sam9263_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/clk.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> +#include <asm/arch/hardware.h> +#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) +#include <net.h> +#endif +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +#ifdef CONFIG_CMD_NAND +static void usb_a9263_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBI0CSA); + at91_sys_write(AT91_MATRIX_EBI0CSA, + csa | AT91_MATRIX_EBI0_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | +#ifdef CONFIG_SYS_NAND_DBW_16 + AT91_SMC_DBW_16 | +#else /* CONFIG_SYS_NAND_DBW_8 */ + AT91_SMC_DBW_8 | +#endif + AT91_SMC_TDF_(2)); + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOA | + 1 << AT91SAM9263_ID_PIOCDE); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} +#endif + +#ifdef CONFIG_MACB +static void usb_a9263_macb_hw_init(void) +{ + unsigned long rstc; + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_EMAC); + + /* + * Disable pull-up on: + * RXDV (PC25) => PHY normal mode (not Test mode) + * ERX0 (PE25) => PHY ADDR0 + * ERX1 (PE26) => PHY ADDR1 => PHYADDR = 0x0 + * + * PHY has internal pull-down + */ + writel(pin_to_mask(AT91_PIN_PC25), + pin_to_controller(AT91_PIN_PC0) + PIO_PUDR); + writel(pin_to_mask(AT91_PIN_PE25) | + pin_to_mask(AT91_PIN_PE26), + pin_to_controller(AT91_PIN_PE0) + PIO_PUDR); + + rstc = at91_sys_read(AT91_RSTC_MR) & AT91_RSTC_ERSTL; + + /* Need to reset PHY -> 500ms reset */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + (AT91_RSTC_ERSTL & (0x0D << 8)) | + AT91_RSTC_URSTEN); + + at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST); + + /* Wait for end hardware reset */ + while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL)); + + /* Restore NRST value */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + (rstc) | + AT91_RSTC_URSTEN); + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PC25), + pin_to_controller(AT91_PIN_PC0) + PIO_PUER); + writel(pin_to_mask(AT91_PIN_PE25) | + pin_to_mask(AT91_PIN_PE26), + pin_to_controller(AT91_PIN_PE0) + PIO_PUER); + + at91_macb_hw_init(); +} +#endif + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of USB-A9263-Board */ + gd->bd->bi_arch_number = MACH_TYPE_USB_A9263; + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + usb_a9263_nand_hw_init(); +#endif +#ifdef CONFIG_HAS_DATAFLASH + at91_set_gpio_output(AT91_PIN_PE20, 1); /* select spi0 clock */ + at91_spi0_hw_init(1 << 0); +#endif +#ifdef CONFIG_MACB + usb_a9263_macb_hw_init(); +#endif +#ifdef CONFIG_USB_OHCI_NEW + at91_uhp_hw_init(); +#endif + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = get_ram_size((long*) PHYS_SDRAM, PHYS_SDRAM_SIZE); + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +void reset_phy(void) +{ +#ifdef CONFIG_MACB + /* + * Initialize ethernet HW addr prior to starting Linux, + * needed for nfsroot + */ + eth_init(gd->bd); +#endif +} +#endif + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_MACB + rc = macb_eth_initialize(0, (void *)AT91SAM9263_BASE_EMAC, 0x00); +#endif + return rc; +} diff --git a/include/configs/usb-a9263.h b/include/configs/usb-a9263.h new file mode 100644 index 0000000..0833325 --- /dev/null +++ b/include/configs/usb-a9263.h @@ -0,0 +1,185 @@ +/* + * (C) Copyright 2007-2009 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Thomas Petazzoni, Free Electrons, thomas.petazzoni@free-electrons.com + * + * Configuration settings for the Calao USB-A9263 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/at91sam9263.h> + +/* ARM asynchronous clock */ +#define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +#define CONFIG_AT91SAM9263 1 /* It's an Atmel AT91SAM9263 SoC*/ +#define CONFIG_CALAO_USB_A9263 1 /* on an Calao USB A 9263 Board */ +#define CONFIG_ARCH_CPU_INIT +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT + +/* + * Hardware drivers + */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +/* LCD */ +#undef CONFIG_LCD + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_USB 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE 0x04000000 + +/* DataFlash */ +#define CONFIG_ATMEL_DATAFLASH_SPI +#define CONFIG_HAS_DATAFLASH 1 +#define CONFIG_SYS_SPI_WRITE_TOUT (5*CONFIG_SYS_HZ) +#define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 +#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 +#define AT91_SPI_CLK 8000000 +#define DATAFLASH_TCSS (0x1c << 16) +#define DATAFLASH_TCHS (0x1 << 24) + +/* no NOR flash */ +#define CONFIG_SYS_NO_FLASH 1 + +/* NAND flash */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_DBW_8 1 +/* our ALE is AD21 */ +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +/* our CLE is AD22 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PD15 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PA22 +#endif + +/* Ethernet */ +#define CONFIG_MACB 1 +#define CONFIG_RMII 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_RESET_PHY_R 1 +#define CONFIG_MACB_SEARCH_PHY 1 + +/* USB */ +#define CONFIG_USB_ATMEL +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE AT91SAM9263_UHP_BASE +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9263" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 +#define CONFIG_CMD_FAT 1 + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END 0x23e00000 + +/* bootstrap + u-boot + env in dataflash on CS0 */ +#define CONFIG_ENV_IS_IN_DATAFLASH 1 +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0) +#define CONFIG_ENV_OFFSET 0x2000 +#define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + \ + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_BOOTCOMMAND "nboot 21000000 0" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock1 " \ + "mtdparts=atmel_nand:2m(kernel)ro,-(root) "\ + "rw rootfstype=jffs2" + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "U-Boot> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define ROUND(A, B) (((A) + (B)) & ~((B) - 1)) +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, \ + 0x1000) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32*1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif
Hi Thomas,
Just a note, but its nice when you resend patches to include the string [PATCH vX] where X=2, 3, etc. That way whoever applies your patch can tell which email contains the latest iteration of it.
That's just plain bad luck, Wolfgang just merged the ROUND() commit a few hours ago:)
http://git.denx.de/?p=u-boot.git;a=commit;h=70ebf31633f372a24505e47846b2628e...
Its up to the ARM maintainer to determine if having the ROUND() defined locally is a show stopper.
Best, Peter
Le Wed, 22 Jul 2009 10:57:09 -0500, Peter Tyser ptyser@xes-inc.com a écrit :
Hi Thomas,
Ok.
Yes, but it also doesn't seem to work (yet): http://lists.denx.de/pipermail/u-boot/2009-July/057230.html
Thomas
Hi Thomas,
Ok.
I see, well I'll gracefully bow out of this conversation now:)
Best, Peter
On Wed, Jul 22, 2009 at 10:57:09AM -0500, Peter Tyser wrote :
Hi Thomas,
Which consequently made all those boards fail to compile. See http://lists.denx.de/pipermail/u-boot/2009-July/057230.html for further details
Cheers,
On 17:30 Wed 22 Jul , Thomas Petazzoni wrote:
The Calao USB A9263 board is a board manufactured and sold by Calao Systems http://www.calao-systems.com. Its components are very similar to the AT91SAM9263EK board, so its configuration is based on the configuration of this board. There are however some differences: different clocks, no LCD, etc.
Signed-off-by: Thomas Petazzoni thomas.petazzoni@free-electrons.com
please no RE in the subject
- usb-a9263 ARM926EJS (AT91SAM9263 SoC)
omap730p2 ARM926EJS
<snip>
- (C) Copyright 2007-2009
- Thomas Petazzoni, Free Electrons, thomas.petazzoni@free-electrons.com
- project.
- MA 02111-1307 USA
please #include <asm/arch/at91sam9_matrix.h>
- Miscelaneous platform dependent initialisations
no please do not include it here but in the correctly file need
- Hardware drivers
- BOOTP options
do you have multiple phy?
no need please remove
Best Regards, J.
Dear Jean-Christophe PLAGNIOL-VILLARD,
Oops??? Why not?? It is strictly RFC-conformant to add a (single) "Re: " in front of the Subject on replies.
What exactly do you mean????
git am does not like it and v2 will be better
Best Regards, J.
What are you talking about?
"git am" on the patch with "Subject: Re: [U-Boot] Support for Calao USB A9263 board based on AT91SAM9263 CPU" results in:
-> git-am -3 -i -u --whitespace=strip ~/Mail/U-Boot/8418 Commit Body is: -------------------------- Support for Calao USB A9263 board based on AT91SAM9263 CPU
Signed-off-by: Thomas Petazzoni thomas.petazzoni@free-electrons.com -------------------------- Apply? [y]es/[n]o/[e]dit/[v]iew patch/[a]ccept all n
As you can see there is zero problem with the "Re: " (and I'd be seriously surprised if there was).
So please explain what exactly you are talking about.
participants (5)
Albin Tonnerre
Peter Tyser
Thomas Petazzoni
