[PATCH 1/3] rockchip: evb-rk3399: Provide init voltage
Add missing regulator-init-microvolt property to vdd_center regulator.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/dts/rk3399-evb-u-boot.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/rk3399-evb-u-boot.dtsi b/arch/arm/dts/rk3399-evb-u-boot.dtsi index 8056dc843e..523ae78657 100644 --- a/arch/arm/dts/rk3399-evb-u-boot.dtsi +++ b/arch/arm/dts/rk3399-evb-u-boot.dtsi @@ -38,6 +38,10 @@ status = "okay"; };
+&vdd_center { + regulator-init-microvolt = <900000>; +}; + &sdmmc { u-boot,dm-pre-reloc; bus-width = <4>;
Add missing regulator-init-microvolt property to vdd_log regulator.
arch/arm/dts/rk3399-firefly-u-boot.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/rk3399-firefly-u-boot.dtsi b/arch/arm/dts/rk3399-firefly-u-boot.dtsi index 38e0897db9..c58ad95d12 100644 --- a/arch/arm/dts/rk3399-firefly-u-boot.dtsi +++ b/arch/arm/dts/rk3399-firefly-u-boot.dtsi @@ -11,3 +11,7 @@ u-boot,spl-boot-order = "same-as-spl", &sdhci, &sdmmc; }; }; + +&vdd_log { + regulator-init-microvolt = <950000>; +};
arch/arm/dts/rk3399-leez-p710-u-boot.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/rk3399-leez-p710-u-boot.dtsi b/arch/arm/dts/rk3399-leez-p710-u-boot.dtsi index f8b2a1d56e..c638ce2597 100644 --- a/arch/arm/dts/rk3399-leez-p710-u-boot.dtsi +++ b/arch/arm/dts/rk3399-leez-p710-u-boot.dtsi @@ -11,3 +11,7 @@ u-boot,spl-boot-order = "same-as-spl", &sdhci, &sdmmc; }; }; + +&vdd_log { + regulator-init-microvolt = <950000>; +};
Kever Yang
