[PATCH 1/1] dfu: fix dfu tftp on sandbox
The environment variable loadaddr is in the virtual address space of the sandbox. To get the actual memory address where the FIT image has been loaded we have to convert this address according to the memory mapping of the sandbox.
Equally the addresses in the *.its file have to be converted when used in the dfu_ram driver.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- common/update.c | 3 ++- drivers/dfu/dfu_ram.c | 7 ++++--- include/dfu.h | 2 +- 3 files changed, 7 insertions(+), 5 deletions(-)
diff --git a/common/update.c b/common/update.c index 8abc7bc02e..5811fac269 100644 --- a/common/update.c +++ b/common/update.c @@ -16,6 +16,7 @@ #include <net.h> #include <net/tftp.h> #include <malloc.h> +#include <mapmem.h> #include <dfu.h> #include <errno.h>
@@ -141,7 +142,7 @@ int update_tftp(ulong addr, char *interface, char *devstring) }
got_update_file: - fit = (void *)addr; + fit = map_sysmem(addr, 0);
if (!fit_check_format((void *)fit)) { printf("Bad FIT format of the update file, aborting " diff --git a/drivers/dfu/dfu_ram.c b/drivers/dfu/dfu_ram.c index cc98668e7a..ab0ce9e6fa 100644 --- a/drivers/dfu/dfu_ram.c +++ b/drivers/dfu/dfu_ram.c @@ -10,6 +10,7 @@
#include <common.h> #include <malloc.h> +#include <mapmem.h> #include <errno.h> #include <dfu.h>
@@ -27,9 +28,9 @@ static int dfu_transfer_medium_ram(enum dfu_op op, struct dfu_entity *dfu, }
if (op == DFU_OP_WRITE) - memcpy(dfu->data.ram.start + offset, buf, *len); + memcpy(map_sysmem(dfu->data.ram.start + offset, 0), buf, *len); else - memcpy(buf, dfu->data.ram.start + offset, *len); + memcpy(buf, map_sysmem(dfu->data.ram.start + offset, 0), *len);
return 0; } @@ -73,7 +74,7 @@ int dfu_fill_entity_ram(struct dfu_entity *dfu, char *devstr, char *s) }
dfu->layout = DFU_RAM_ADDR; - dfu->data.ram.start = (void *)simple_strtoul(argv[1], NULL, 16); + dfu->data.ram.start = simple_strtoul(argv[1], NULL, 16); dfu->data.ram.size = simple_strtoul(argv[2], NULL, 16);
dfu->write_medium = dfu_write_medium_ram; diff --git a/include/dfu.h b/include/dfu.h index 6fa4505936..84abdc79ac 100644 --- a/include/dfu.h +++ b/include/dfu.h @@ -79,7 +79,7 @@ struct nand_internal_data { };
struct ram_internal_data { - void *start; + unsigned long start; unsigned int size; };
-- 2.27.0
