[PATCH] arm: mvebu: dts: Build only arch-compatible dts files
64-bit Armada DTS files are not build correctly during compilation of 32-bit Armada boards and vice versa. So fix makefile build system to compile only those dts files which are compatible for the current build (64-bit Armada DTS files only for 64-bit builds and 32-bit Armada DTS files only for 32-bit builds).
Signed-off-by: Pali Rohár pali@kernel.org --- arch/arm/dts/Makefile | 28 ++++++++++++++++------------ 1 file changed, 16 insertions(+), 12 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ceaa39e4b4d6..7330121dbaba 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -232,12 +232,8 @@ dtb-$(CONFIG_ARCH_TEGRA) += tegra20-harmony.dtb \ tegra210-p2571.dtb \ tegra210-p3450-0000.dtb
+ifdef CONFIG_ARMADA_32BIT dtb-$(CONFIG_ARCH_MVEBU) += \ - armada-3720-db.dtb \ - armada-3720-espressobin.dtb \ - armada-3720-turris-mox.dtb \ - armada-3720-eDPU.dtb \ - armada-3720-uDPU.dtb \ armada-375-db.dtb \ armada-385-atl-x530.dtb \ armada-385-atl-x530DP.dtb \ @@ -247,12 +243,6 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-388-gp.dtb \ armada-388-helios4.dtb \ armada-38x-controlcenterdc.dtb \ - armada-7040-db-nand.dtb \ - armada-7040-db.dtb \ - armada-8040-clearfog-gt-8k.dtb \ - armada-8040-db.dtb \ - armada-8040-mcbin.dtb \ - armada-8040-puzzle-m801.dtb \ armada-xp-crs305-1g-4s.dtb \ armada-xp-crs305-1g-4s-bit.dtb \ armada-xp-crs326-24g-2s.dtb \ @@ -263,7 +253,20 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-xp-gp.dtb \ armada-xp-maxbcm.dtb \ armada-xp-synology-ds414.dtb \ - armada-xp-theadorable.dtb \ + armada-xp-theadorable.dtb +else +dtb-$(CONFIG_ARCH_MVEBU) += \ + armada-3720-db.dtb \ + armada-3720-espressobin.dtb \ + armada-3720-turris-mox.dtb \ + armada-3720-eDPU.dtb \ + armada-3720-uDPU.dtb \ + armada-7040-db-nand.dtb \ + armada-7040-db.dtb \ + armada-8040-clearfog-gt-8k.dtb \ + armada-8040-db.dtb \ + armada-8040-mcbin.dtb \ + armada-8040-puzzle-m801.dtb \ cn9130-db-A.dtb \ cn9130-db-B.dtb \ cn9131-db-A.dtb \ @@ -272,6 +275,7 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ cn9132-db-B.dtb \ cn9130-crb-A.dtb \ cn9130-crb-B.dtb +endif
dtb-$(CONFIG_ARCH_SYNQUACER) += synquacer-sc2a11-developerbox.dtb dtb-$(CONFIG_ARCH_UNIPHIER_LD11) += \
Thanks, Stefan
- armada-8040-puzzle-m801.dtb \ cn9130-db-A.dtb \ cn9130-db-B.dtb \ cn9131-db-A.dtb \
Viele Grüße, Stefan Roese
Applied to u-boot-marvell/master
Thanks, Stefan
Pali Rohár
Stefan Roese
