[U-Boot] [PATCH v4 0/2] DW SPI: Get clock value from Device Tree
As discussed with Marek during the LINUX-PITER here is v4 patch:
Add option to set spi controller clock frequency via device tree using standard clock bindings.
Define dw_spi_get_clk function as 'weak' as some targets (like SOCFPGA_GEN5 and SOCFPGA_ARRIA10) fon't use standard clock API and implement dw_spi_get_clk their own way in their clock manager.
Get rid of clock_manager.h include in designware_spi.c as we don't use cm_get_spi_controller_clk_hz function anymore - we use redefined dw_spi_get_clk in SOCFPGA clock managers (clock_manager_gen5.c and clock_manager_arria10.c) instead.
Eugeniy Paltsev (2): SOCFPGA: clock manager: implement dw_spi_get_clk function DW SPI: Get clock value from Device Tree
arch/arm/mach-socfpga/clock_manager_arria10.c | 9 +++++ arch/arm/mach-socfpga/clock_manager_gen5.c | 9 +++++ drivers/spi/designware_spi.c | 47 +++++++++++++++++++++++++-- 3 files changed, 63 insertions(+), 2 deletions(-)
Implement dw_spi_get_clk function to override its weak implementation in designware_spi.c driver.
We need this change to get rid of cm_get_spi_controller_clk_hz function and clock_manager.h include in designware_spi.c driver.
Signed-off-by: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com --- arch/arm/mach-socfpga/clock_manager_arria10.c | 9 +++++++++ arch/arm/mach-socfpga/clock_manager_gen5.c | 9 +++++++++ 2 files changed, 18 insertions(+)
diff --git a/arch/arm/mach-socfpga/clock_manager_arria10.c b/arch/arm/mach-socfpga/clock_manager_arria10.c index 482b854..623a266 100644 --- a/arch/arm/mach-socfpga/clock_manager_arria10.c +++ b/arch/arm/mach-socfpga/clock_manager_arria10.c @@ -7,6 +7,7 @@ #include <common.h> #include <fdtdec.h> #include <asm/io.h> +#include <dm.h> #include <asm/arch/clock_manager.h>
DECLARE_GLOBAL_DATA_PTR; @@ -1076,6 +1077,14 @@ unsigned int cm_get_qspi_controller_clk_hz(void) return cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MAINCLK_LSB); }
+/* Override weak dw_spi_get_clk implementation in designware_spi.c driver */ +int dw_spi_get_clk(struct udevice *bus, ulong *rate) +{ + *rate = cm_get_spi_controller_clk_hz(); + + return 0; +} + void cm_print_clock_quick_summary(void) { printf("MPU %10ld kHz\n", cm_get_mpu_clk_hz() / 1000); diff --git a/arch/arm/mach-socfpga/clock_manager_gen5.c b/arch/arm/mach-socfpga/clock_manager_gen5.c index 31fd510..a371d83 100644 --- a/arch/arm/mach-socfpga/clock_manager_gen5.c +++ b/arch/arm/mach-socfpga/clock_manager_gen5.c @@ -6,6 +6,7 @@
#include <common.h> #include <asm/io.h> +#include <dm.h> #include <asm/arch/clock_manager.h> #include <wait_bit.h>
@@ -509,6 +510,14 @@ unsigned int cm_get_spi_controller_clk_hz(void) return clock; }
- *rate = cm_get_spi_controller_clk_hz();
Get rid of clock_manager.h include as we don't use cm_get_spi_controller_clk_hz function anymore. (we use redefined dw_spi_get_clk in SOCFPGA clock managers instead)
Signed-off-by: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com --- drivers/spi/designware_spi.c | 46 ++++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 44 insertions(+), 2 deletions(-)
diff --git a/drivers/spi/designware_spi.c b/drivers/spi/designware_spi.c index 6cc4f51..5460ad7 100644 --- a/drivers/spi/designware_spi.c +++ b/drivers/spi/designware_spi.c @@ -12,6 +12,7 @@
#include <asm-generic/gpio.h> #include <common.h> +#include <clk.h> #include <dm.h> #include <errno.h> #include <malloc.h> @@ -19,7 +20,6 @@ #include <fdtdec.h> #include <linux/compat.h> #include <asm/io.h> -#include <asm/arch/clock_manager.h>
@@ -95,6 +95,7 @@ struct dw_spi_priv { void __iomem *regs; unsigned int freq; /* Default frequency */ unsigned int mode; + unsigned long bus_clk_rate;
struct gpio_desc cs_gpio; /* External chip-select gpio */
@@ -195,14 +196,55 @@ static void spi_hw_init(struct dw_spi_priv *priv) debug("%s: fifo_len=%d\n", __func__, priv->fifo_len); }
+/* + * We define dw_spi_get_clk function as 'weak' as some targets + * (like SOCFPGA_GEN5 and SOCFPGA_ARRIA10) fon't use standard clock API + * and implement dw_spi_get_clk their own way in their clock manager. + */ +__weak int dw_spi_get_clk(struct udevice *bus, ulong *rate) +{ +#if CONFIG_IS_ENABLED(OF_CONTROL) && CONFIG_IS_ENABLED(CLK) + struct clk clk; + int ret; + + ret = clk_get_by_index(bus, 0, &clk); + if (ret) + return -EINVAL; + + ret = clk_enable(&clk); + if (ret && ret != -ENOSYS) + return ret; + + *rate = clk_get_rate(&clk); + if (!*rate) { + clk_disable(&clk); + return -EINVAL; + } + + debug("%s: get spi controller clk via device tree: %lu Hz\n", + __func__, *rate); + + clk_free(&clk); + + return 0; +#else + return -ENOSYS; +#endif +} + static int dw_spi_probe(struct udevice *bus) { struct dw_spi_platdata *plat = dev_get_platdata(bus); struct dw_spi_priv *priv = dev_get_priv(bus); + int ret;
priv->regs = plat->regs; priv->freq = plat->frequency;
+ ret = dw_spi_get_clk(bus, &priv->bus_clk_rate); + if (ret) + return ret; + /* Currently only bits_per_word == 8 supported */ priv->bits_per_word = 8;
@@ -411,7 +453,7 @@ static int dw_spi_set_speed(struct udevice *bus, uint speed) spi_enable_chip(priv, 0);
/* clk_div doesn't support odd number */ - clk_div = cm_get_spi_controller_clk_hz() / speed; + clk_div = priv->bus_clk_rate / speed; clk_div = (clk_div + 1) & 0xfffe; dw_write(priv, DW_SPI_BAUDR, clk_div);
^ don't ... detail
- We define dw_spi_get_clk function as 'weak' as some targets
- (like SOCFPGA_GEN5 and SOCFPGA_ARRIA10) fon't use standard clock API
- and implement dw_spi_get_clk their own way in their clock manager.
You can drop this ifdef IMO, this code will be overridden on SoCFPGA and all the other systems should use DT and clock framework.
- struct clk clk;
- int ret;
- ret = clk_get_by_index(bus, 0, &clk);
- if (ret)
return -EINVAL;
- ret = clk_enable(&clk);
- if (ret && ret != -ENOSYS)
return ret;
- *rate = clk_get_rate(&clk);
- if (!*rate) {
clk_disable(&clk);
return -EINVAL;
- debug("%s: get spi controller clk via device tree: %lu Hz\n",
__func__, *rate);
- clk_free(&clk);
+#else
- return -ENOSYS;
+#endif +}
int ret;
if (ret)
return ret;
- clk_div = priv->bus_clk_rate / speed; clk_div = (clk_div + 1) & 0xfffe; dw_write(priv, DW_SPI_BAUDR, clk_div);
Eugeniy Paltsev
