[U-Boot] [PATCH] Revert "binman: Correct symbol calculation with non-zero image base"
This reverts commit 15c981cc8adc26501e3a19ca7fb35705870ef597. "binman: Correct symbol calculation with non-zero image base". This was previously reported to break initial boot on Jetson TK1, and Simon dropped the patch from his branch. However, it seems to have shown up again in a pull request somehow. Revert it until the problem is fixed.
Signed-off-by: Stephen Warren swarren@nvidia.com --- tools/binman/elf.py | 4 +++- tools/binman/test/u_boot_binman_syms.lds | 2 +- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/tools/binman/elf.py b/tools/binman/elf.py index 0c1a5b44b669..7bc7cf61b5d8 100644 --- a/tools/binman/elf.py +++ b/tools/binman/elf.py @@ -135,7 +135,9 @@ def LookupAndWriteSymbols(elf_fname, entry, section):
# Look up the symbol in our entry tables. value = section.LookupSymbol(name, sym.weak, msg) - if value is None: + if value is not None: + value += base.address + else: value = -1 pack_string = pack_string.lower() value_bytes = struct.pack(pack_string, value) diff --git a/tools/binman/test/u_boot_binman_syms.lds b/tools/binman/test/u_boot_binman_syms.lds index 825fc3f649f7..926df873cb70 100644 --- a/tools/binman/test/u_boot_binman_syms.lds +++ b/tools/binman/test/u_boot_binman_syms.lds @@ -9,7 +9,7 @@ ENTRY(_start)
SECTIONS { - . = 0x00000010; + . = 0x00000000; _start = .;
. = ALIGN(4);
We can drop this and replace it with Simon's "[PATCH] binman: tegra: Adjust symbol calculation depending on end-at-4gb". That patch fixes the same bug, but without reverting the change.
Stephen Warren
