[PATCH] efi_loader: update SetVariable attribute check
UEFI specification v2.10 says that EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS is deprecated and EFI_UNSUPPORTED should be returned in SetVariable variable service. Current implementation returns EFI_INVALID_PARAMETER, let's fix the return value.
Together with above change, this commit also updates the SetVariable attribute check to be aligned with the EDK2 reference implementation.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- lib/efi_loader/efi_variable.c | 30 +++++++++++++++++++++++------- 1 file changed, 23 insertions(+), 7 deletions(-)
diff --git a/lib/efi_loader/efi_variable.c b/lib/efi_loader/efi_variable.c index 4c85cfa607..1076ff7585 100644 --- a/lib/efi_loader/efi_variable.c +++ b/lib/efi_loader/efi_variable.c @@ -230,9 +230,28 @@ efi_status_t efi_set_variable_int(const u16 *variable_name, u64 time = 0; enum efi_auth_var_type var_type;
- if (!variable_name || !*variable_name || !vendor || - ((attributes & EFI_VARIABLE_RUNTIME_ACCESS) && - !(attributes & EFI_VARIABLE_BOOTSERVICE_ACCESS))) + if (!variable_name || !*variable_name || !vendor) + return EFI_INVALID_PARAMETER; + + if (data_size != 0 && !data) + return EFI_INVALID_PARAMETER; + + /* EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS is deprecated */ + if (attributes & EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS || + ((attributes & EFI_VARIABLE_MASK) == 0)) + return EFI_UNSUPPORTED; + + /* Make sure if runtime bit is set, boot service bit is set also */ + if ((attributes & + (EFI_VARIABLE_RUNTIME_ACCESS | EFI_VARIABLE_BOOTSERVICE_ACCESS)) == + EFI_VARIABLE_RUNTIME_ACCESS) + return EFI_INVALID_PARAMETER; + + /* only EFI_VARIABLE_NON_VOLATILE attribute is invalid */ + if ((attributes & EFI_VARIABLE_MASK) == EFI_VARIABLE_NON_VOLATILE) + return EFI_INVALID_PARAMETER; + + if (attributes & EFI_VARIABLE_HARDWARE_ERROR_RECORD) return EFI_INVALID_PARAMETER;
/* check if a variable exists */ @@ -281,8 +300,6 @@ efi_status_t efi_set_variable_int(const u16 *variable_name,
/* authenticate a variable */ if (IS_ENABLED(CONFIG_EFI_SECURE_BOOT)) { - if (attributes & EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS) - return EFI_INVALID_PARAMETER; if (attributes & EFI_VARIABLE_TIME_BASED_AUTHENTICATED_WRITE_ACCESS) { u32 env_attr; @@ -300,8 +317,7 @@ efi_status_t efi_set_variable_int(const u16 *variable_name, } } else { if (attributes & - (EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS | - EFI_VARIABLE_TIME_BASED_AUTHENTICATED_WRITE_ACCESS)) { + EFI_VARIABLE_TIME_BASED_AUTHENTICATED_WRITE_ACCESS) { EFI_PRINT("Secure boot is not configured\n"); return EFI_INVALID_PARAMETER; }
- if (!variable_name || !*variable_name || !vendor)
- if (data_size != 0 && !data)
We tend to not use '!= 0' and ' == 0' in logical constraints. You could use
if (data_size && !data)
instead.
- /* EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS is deprecated */
- if (attributes & EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS ||
!(attributes & EFI_VARIABLE_MASK)
- /* Make sure if runtime bit is set, boot service bit is set also */
- if ((attributes &
- /* only EFI_VARIABLE_NON_VOLATILE attribute is invalid */
- if ((attributes & EFI_VARIABLE_MASK) == EFI_VARIABLE_NON_VOLATILE)
- if (attributes & EFI_VARIABLE_HARDWARE_ERROR_RECORD) return EFI_INVALID_PARAMETER;
Variables with flags NV, BS, RT, HR, name HwErrRec####, and GUID EFI_HARDWARE_ERROR_VARIABLE are allowable according to the UEFI spec. Why do we return EFI_INVALID_PARAMETER here?
Please, sort the checks above such that all EFI_INVALID_PARAMETER are together followed by EFI_UNSUPPORTED.
Best regards
Heinrich
if (attributes & EFI_VARIABLE_TIME_BASED_AUTHENTICATED_WRITE_ACCESS) { u32 env_attr;return EFI_INVALID_PARAMETER;
}EFI_VARIABLE_TIME_BASED_AUTHENTICATED_WRITE_ACCESS) { EFI_PRINT("Secure boot is not configured\n"); return EFI_INVALID_PARAMETER;
instead.
OK.
OK.
if ((attributes &
Sorry, I misunderstood EDK2 implementation. I will update to check HR must be set with NV.
454a9442fb(efi_loader: update attribute check for QueryVariableInfo()) also does wrong check for HR, I will fix it.
SCT SIE(Security Interface Extension) expects that deprecated EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS attribute check is first priority. So let me prioritise EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS check. In the next version, the error check order is: - basic parameter check such as variable_name is NULL - deprecated and unsupported attribute check - invalid attribute check
Thanks, Masahisa Kojima
Best regards
Heinrich
Masahisa Kojima
