[U-Boot-Users] [PATCH11] microblaze - Ml401
Desc: repair ML401 config file
Signed-off-by: Michal Simek monstr@monstr.eu
Note: repair email, remove spaces, remove commands which are defined in config_cmd_default.h
diff --git a/include/configs/ml401.h b/include/configs/ml401.h index 7eeae70..bb72fac 100644 --- a/include/configs/ml401.h +++ b/include/configs/ml401.h @@ -1,7 +1,7 @@ /* - * (C) Copyright 2007 Czech Technical University. + * (C) Copyright 2007 Michal Simek * - * Michal SIMEK monstr@seznam.cz + * Michal SIMEK monstr@monstr.eu * * See file CREDITS for list of people who contributed to this * project. @@ -32,6 +32,7 @@ #define CONFIG_ML401 1 /* ML401 Board */
/* uart */ +#define XILINX_UARTLITE #define CONFIG_SERIAL_BASE XILINX_UART_BASEADDR #define CONFIG_BAUDRATE XILINX_UART_BAUDRATE #define CFG_BAUDRATE_TABLE { CONFIG_BAUDRATE } @@ -86,7 +87,7 @@ * 0x11FB_F000 CFG_MONITOR_BASE * MONITOR_CODE 256kB Env * 0x13FF_F000 CFG_GBL_DATA_OFFSET - * GLOBAL_DATA 4kB bd, gd + * GLOBAL_DATA 4kB bd, gd * 0x1400_0000 CFG_SDRAM_BASE + CFG_SDRAM_SIZE */
@@ -99,7 +100,7 @@ /* global pointer */ #define CFG_GBL_DATA_SIZE 0x1000 /* size of global data */ /* start of global data */ -#define CFG_GBL_DATA_OFFSET (CFG_SDRAM_BASE + CFG_SDRAM_SIZE - CFG_GBL_DATA_SIZE) +#define CFG_GBL_DATA_OFFSET (CFG_SDRAM_BASE + CFG_SDRAM_SIZE - CFG_GBL_DATA_SIZE)
/* monitor code */ #define SIZE 0x40000 @@ -153,28 +154,18 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ #include <config_cmd_default.h>
#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_AUTOSCRIPT -#define CONFIG_CMD_BDI #define CONFIG_CMD_CACHE #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT -#define CONFIG_CMD_IMI #define CONFIG_CMD_IRQ -#define CONFIG_CMD_LOADB -#define CONFIG_CMD_LOADS -#define CONFIG_CMD_MEMORY -#define CONFIG_CMD_MISC #define CONFIG_CMD_MFSL -#define CONFIG_CMD_NET #define CONFIG_CMD_PING -#define CONFIG_CMD_RUN
#if defined(FLASH) #define CONFIG_CMD_ECHO @@ -210,10 +201,10 @@ #define CONFIG_BOOTDELAY 30 #define CONFIG_BOOTARGS "root=romfs" #define CONFIG_HOSTNAME "ml401" -#define CONFIG_BOOTCOMMAND "base 0;tftp 11000000 image.img;bootm" +#define CONFIG_BOOTCOMMAND "base 0;tftp 11000000 image.img;bootm" #define CONFIG_IPADDR 192.168.0.3 -#define CONFIG_SERVERIP 192.168.0.5 -#define CONFIG_GATEWAYIP 192.168.0.1 +#define CONFIG_SERVERIP 192.168.0.5 +#define CONFIG_GATEWAYIP 192.168.0.1 #define CONFIG_ETHADDR 00:E0:0C:00:00:FD
/* architecture dependent code */
- (C) Copyright 2007 Czech Technical University.
Can you confirm that you are legally entitled to do this? Does the Czech Technical University hold any copyright on this work?
- (C) Copyright 2007 Michal Simek
- Michal SIMEK monstr@seznam.cz
- Michal SIMEK monstr@monstr.eu
- project.
CONFIG_XILINX_UARTLITE
- 0x11FB_F000 CFG_MONITOR_BASE
- 0x13FF_F000 CFG_GBL_DATA_OFFSET
- 0x1400_0000 CFG_SDRAM_BASE + CFG_SDRAM_SIZE
- Command line configuration.
This SF.net email is sponsored by: Splunk Inc. Still grepping through log files to find problems? Stop. Now Search log events and configuration files using AJAX and a browser. Download your FREE copy of Splunk now >> http://get.splunk.com/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
------------ Původní zpráva ------------ Od: Grant Likely grant.likely@secretlab.ca Předmět: Re: [U-Boot-Users] [PATCH11] microblaze - Ml401 Datum: 11.9.2007 17:43:24 ---------------------------------------- On 8/30/07, Michal Simek Monstr@seznam.cz wrote:
Yes. Czech Technical University don't hold any copyright on this work. All files are made my self privately.
M
Grant Likely
Michal Simek
