[U-Boot] Uboot send pull request
Hi Tom,
Please pull the following patch from u-boot-riscv into your tree. Thanks!
The following changes since commit d73d81fd85e4a030ade42c4b2d13466d45090aa3:
Merge tag 'mips-pull-2018-11-18' of git://git.denx.de/u-boot-mips (2018-11-18 15:47:16 -0500)
git://git.denx.de/u-boot-riscv.git
for you to fetch changes up to f1b8761952aca2cdd91f42dbfd26c656072f2d11:
riscv: ax25-ae350: Pass dtb address to u-boot with a1 register (2018-11-20 14:37:31 +0800)
---------------------------------------------------------------- Bin Meng (1): Drop CONFIG_INIT_CRITICAL
Lukas Auer (26): tools: .gitignore: add prelink-riscv dts: riscv: update makefile to also clean the RISC-V dts directory riscv: rename CPU_RISCV_32/64 to match architecture names ARCH_RV32I/64I riscv: select CONFIG_PHYS_64BIT on RV64I systems riscv: add Kconfig entries for the C and A ISA extensions riscv: set -march and -mabi based on the Kconfig configuration riscv: fix use of incorrectly sized variables riscv: make use of the barrier functions from Linux riscv: do not reimplement generic io functions riscv: complete the list of exception codes riscv: treat undefined exception codes as reserved riscv: hang on unhandled exceptions riscv: implement the invalidate_icache_* functions riscv: fix inconsistent use of spaces and tabs in start.S riscv: align mtvec on a 4-byte boundary riscv: remove unused labels in start.S riscv: do not blindly modify the mstatus CSR riscv: save hart ID and device tree passed by prior boot stage riscv: qemu: use device tree passed by prior boot stage riscv: qemu: support booting Linux riscv: align bootm implementation with that of other architectures distro_bootcmd: add VirtIO distro boot command riscv: qemu: enable distro boot dm: core: add missing prototype for ofnode_read_u64 riscv: qemu: detect and boot the kernel passed by QEMU riscv: qemu: clear kernel-start/-end in device tree as workaround for BBL
Rick Chen (7): riscv: enable -fdata-sections riscv: dts: Sync to Linux Kernel ae350 dts. configs: ax25-ae350: Separate ax25-ae350 for RV32/64I. riscv: dts: Add ae350_32.dts for RV32I configs: ax25-ae350: Enable DISPLAY_CPUINFO & DISPLAY_BOARDINFO riscv: cache: Implement i/dcache [status, enable, disable] riscv: ax25-ae350: Pass dtb address to u-boot with a1 register
arch/nds32/cpu/n1213/start.S | 51 -------------- arch/riscv/Kconfig | 34 ++++++--- arch/riscv/Makefile | 20 ++++++ arch/riscv/config.mk | 7 +- arch/riscv/cpu/ax25/Kconfig | 7 ++ arch/riscv/cpu/ax25/Makefile | 1 + arch/riscv/cpu/ax25/cache.c | 95 ++++++++++++++++++++++++++ arch/riscv/cpu/ax25/cpu.c | 4 ++ arch/riscv/cpu/cpu.c | 6 ++ arch/riscv/cpu/qemu/cpu.c | 2 +- arch/riscv/cpu/start.S | 344 +++++++++++++++++++++++++++++++++++++++++++++----------------------------------------------- arch/riscv/dts/Makefile | 1 - arch/riscv/dts/ae350.dts | 107 +++++++++++++++++++++++++---- arch/riscv/dts/ae350_32.dts | 229 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/riscv/dts/ae350_64.dts | 229 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/riscv/include/asm/barrier.h | 67 ++++++++++++++++++ arch/riscv/include/asm/cache.h | 3 + arch/riscv/include/asm/io.h | 48 +++---------- arch/riscv/include/asm/posix_types.h | 6 +- arch/riscv/include/asm/types.h | 4 ++ arch/riscv/lib/bootm.c | 97 ++++++++++++++++++-------- arch/riscv/lib/cache.c | 36 ++++++++-- arch/riscv/lib/interrupts.c | 31 +++++++-- arch/riscv/lib/setjmp.S | 2 +- board/AndesTech/ax25-ae350/ax25-ae350.c | 3 +- board/armltd/integrator/README | 4 +- board/emulation/qemu-riscv/Kconfig | 2 + board/emulation/qemu-riscv/qemu-riscv.c | 73 +++++++++++++++++--- configs/{ax25-ae350_defconfig => a25-ae350_32_defconfig} | 5 +- configs/ax25-ae350_64_defconfig | 39 +++++++++++ configs/qemu-riscv32_defconfig | 5 +- configs/qemu-riscv64_defconfig | 7 +- doc/README.distro | 3 +- dts/Makefile | 2 +- include/common.h | 5 -- include/config_distro_bootcmd.h | 21 ++++-- include/configs/qemu-riscv.h | 28 ++++++++ include/dm/ofnode.h | 10 +++ scripts/config_whitelist.txt | 1 - tools/.gitignore | 1 + 40 files changed, 1271 insertions(+), 369 deletions(-) create mode 100644 arch/riscv/cpu/ax25/Kconfig create mode 100644 arch/riscv/cpu/ax25/cache.c create mode 100644 arch/riscv/dts/ae350_32.dts create mode 100644 arch/riscv/dts/ae350_64.dts create mode 100644 arch/riscv/include/asm/barrier.h rename configs/{ax25-ae350_defconfig => a25-ae350_32_defconfig} (89%) create mode 100644 configs/ax25-ae350_64_defconfig
Hi Rick,
On Tue, Nov 20, 2018 at 6:33 PM uboot@andestech.com wrote:
Hi Tom,
Do any of your above patches get v2 posted? At least I did not see any follow-up response [1] regarding to "riscv: ax25-ae350: Pass dtb address to u-boot with a1 register"
[snip]
[1] https://lists.denx.de/pipermail/u-boot/2018-October/345903.html
Regards, Bin
On Tue, 2018-11-20 at 18:18 +0800, uboot@andestech.com wrote:
Hi Tom,
Hi Rick,
Thanks for pulling my changes! I have some notes and questions on it.
I can't find all of your patches on the mailing list, for example the patch "configs: ax25-ae350: Enable DISPLAY_CPUINFO & DISPLAY_BOARDINFO". Others include changes, which have not been submitted to the mailing list. Please send all changes to the mailing list before including them in a pull request. This is really helpful for me and others, to be able to see if there are any conflicts with other patches currently under development or with other boards.
Something seems to have gone wrong while applying the patch "riscv: enable -fdata-sections". This is one of my patches and part of the patch series.
Can you please consider removing your patch "riscv: cache: Implement i/dcache [status, enable, disable]" from this pull request and re- sending it with the next? There are still some points you did not reply to in my comments on v2 of your patch. For example, I think it makes sense to split this patch into multiple patches to make it clearer what it changes. If you want, I can re-send my comments in reply to v3 of your patch :)
Thank you! Lukas
include/configs/qemu-riscv.h | 28 ++++++++ include/dm/ofnode.h | 10 +++ scripts/config_whitelist.txt | 1 - tools/.gitignore | 1 + 40 files changed, 1271 insertions(+), 369 deletions(-) create mode 100644 arch/riscv/cpu/ax25/Kconfig create mode 100644 arch/riscv/cpu/ax25/cache.c create mode 100644 arch/riscv/dts/ae350_32.dts create mode 100644 arch/riscv/dts/ae350_64.dts create mode 100644 arch/riscv/include/asm/barrier.h rename configs/{ax25-ae350_defconfig => a25-ae350_32_defconfig} (89%) create mode 100644 configs/ax25-ae350_64_defconfig _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
On Tue, Nov 20, 2018 at 06:18:07PM +0800, uboot@andestech.com wrote:
Hi Tom,
Since it seems like there's a lot of relevant feedback on this specific PR I'm going to wait for that to be addressed or (I suspect more likely) a new PR to be sent, thanks!
Auer, Lukas
Bin Meng
uboot@andestech.com
