[U-Boot] [PATCH 3/4] udoo: Adjust default boot envirnment
Change u-boot default environment for uDoo board to: - mount /dev/mmcblk0p1 partition - activate hdmi monitor by default (instead of nothing)
Signed-off-by: Giuseppe Pagano giuseppe.pagano@seco.com Cc: sbabic@denx.de
diff -uNr a/include/configs/udoo.h b/include/configs/udoo.h --- a/include/configs/udoo.h 2013-11-06 18:51:57.000000000 +0100 +++ b/include/configs/udoo.h 2013-11-06 18:52:16.000000000 +0100 @@ -100,7 +100,7 @@
#define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \ - "uimage=uImage\0" \ + "uimage=/boot/uImage\0" \ "console=ttymxc1\0" \ "splashpos=m,m\0" \ "fdt_high=0xffffffff\0" \ @@ -111,7 +111,7 @@ "ip_dyn=yes\0" \ "mmcdev=0\0" \ "mmcpart=1\0" \ - "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ + "mmcroot=/dev/mmcblk0p1 rootwait rw\0" \ "update_sd_firmware_filename=u-boot.imx\0" \ "update_sd_firmware=" \ "if test ${ip_dyn} = yes; then " \ @@ -127,13 +127,14 @@ "fi; " \ "fi\0" \ "mmcargs=setenv bootargs console=${console},${baudrate} " \ - "root=${mmcroot}\0" \ + "root=${mmcroot} rootwait rw " \ + "fbmem=24M video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24\0" \ "loadbootscript=" \ - "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "ext2load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ "bootscript=echo Running bootscript from mmc ...; " \ "source\0" \ - "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ - "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "loaduimage=ext2load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "loadfdt=ext2load mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ @@ -189,7 +190,7 @@ /* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP #define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_SYS_PROMPT "uDoo board >" #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256
Hi Giuseppe,
- "uimage=/boot/uImage\0" \ "console=ttymxc1\0" \ "splashpos=m,m\0" \ "fdt_high=0xffffffff\0" \
- "mmcroot=/dev/mmcblk0p1 rootwait rw\0" \ "update_sd_firmware_filename=u-boot.imx\0" \ "update_sd_firmware=" \ "if test ${ip_dyn} = yes; then " \
"loadbootscript=" \"fbmem=24M video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24\0" \
I have already explained my doubts regarding the abuse of EXTRA_ENV_SETTINGS. The setup that should be minimal and general for most of uses is then customized for a specific scope, that conflict with other goals. You are changing the filesystem on the card: I cannot estimate how this can be useful for everyone (maybe yes, maybe not).
I hope that Simon's patches to split the default environment from the configuration file will find soon a way to mainline. Check in the ML for
"env: Add support for environment files"
Then it will be possible to define an own text file containing the environment outside of the configuration file. And adding a new default environment will mean only to specify the env file in boards.cfg.
- "loaduimage=ext2load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0"
- "loadfdt=ext2load mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0"
We had already some discussion on the mailing list about the meaning and the usefulness of the U-Boot prompt. I will apply a patch for all Freescale boards that remove a custom prompt, letting the default. Which is the improvement to have a custom prompt ?
Maybe you are the second one asking for the feature:
http://u-boot.10912.n7.nabble.com/Changing-CONFIG-SYS-PROMPT-on-the-fly-td16...
As suggested by Simon (take a look at the whole thread), it is then better to set the prompt from an environment variable. Feel free to submit a patch for it.
Best regards, Stefano Babic
Hi Stefano,
On Thu, 2013-11-07 at 09:33 +0100, Stefano Babic wrote:
Hi Giuseppe,
Ok I will leave unchanged default environment.
And also I will leave unchanged u-boot prompt. I think I will support Simon idea, I think it is useful to recognize uboot console prompt if you have more than one serial console connected to your host.
Best regards, Giuseppe Pagano
Giuseppe Pagano
Stefano Babic
