[U-Boot] [UBOOT PATCH 1/2] spi: zynqmp_qspi: Add support for ZynqMP qspi driver
This patch adds qspi driver support for ZynqMP SoC. This driver is responsible for communicating with qspi flash devices.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- arch/arm/cpu/armv8/zynqmp/Kconfig | 7 + drivers/spi/Makefile | 1 + drivers/spi/zynqmp_qspi.c | 817 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 825 insertions(+) create mode 100644 drivers/spi/zynqmp_qspi.c
diff --git a/arch/arm/cpu/armv8/zynqmp/Kconfig b/arch/arm/cpu/armv8/zynqmp/Kconfig index 5ffc9f6..278248a 100644 --- a/arch/arm/cpu/armv8/zynqmp/Kconfig +++ b/arch/arm/cpu/armv8/zynqmp/Kconfig @@ -50,6 +50,13 @@ config BOOT_INIT_FILE Add register writes to boot.bin format (max 256 pairs). Expect a table of register-value pairs, e.g. "0x12345678 0x4321"
+config ZYNQMP_QSPI + bool "Configure ZynqMP QSPI" + select DM_SPI + help + This option is used to enable ZynqMP QSPI controller driver which + is used to communicate with qspi flash devices. + config ZYNQMP_USB bool "Configure ZynqMP USB"
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index ad56203..b465c71 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -50,3 +50,4 @@ obj-$(CONFIG_TI_QSPI) += ti_qspi.o obj-$(CONFIG_XILINX_SPI) += xilinx_spi.o obj-$(CONFIG_ZYNQ_SPI) += zynq_spi.o obj-$(CONFIG_ZYNQ_QSPI) += zynq_qspi.o +obj-$(CONFIG_ZYNQMP_QSPI) += zynqmp_qspi.o diff --git a/drivers/spi/zynqmp_qspi.c b/drivers/spi/zynqmp_qspi.c new file mode 100644 index 0000000..7ec669e --- /dev/null +++ b/drivers/spi/zynqmp_qspi.c @@ -0,0 +1,817 @@ +/* + * (C) Copyright 2014 - 2015 Xilinx + * + * Xilinx ZynqMP Quad-SPI(QSPI) controller driver (master mode only) + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <malloc.h> +#include <memalign.h> +#include <ubi_uboot.h> +#include <spi.h> +#include <spi_flash.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/clk.h> +#include "../mtd/spi/sf_internal.h" +#include <clk.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define ZYNQMP_QSPI_GFIFO_STRT_MODE_MASK BIT(29) +#define ZYNQMP_QSPI_CONFIG_MODE_EN_MASK (3 << 30) +#define ZYNQMP_QSPI_CONFIG_DMA_MODE (2 << 30) +#define ZYNQMP_QSPI_CONFIG_CPHA_MASK BIT(2) +#define ZYNQMP_QSPI_CONFIG_CPOL_MASK BIT(1) + +/* QSPI MIO's count for different connection topologies */ +#define ZYNQMP_QSPI_MIO_NUM_QSPI0 6 +#define ZYNQMP_QSPI_MIO_NUM_QSPI1 5 +#define ZYNQMP_QSPI_MIO_NUM_QSPI1_CS 1 + +/* + * QSPI Interrupt Registers bit Masks + * + * All the four interrupt registers (Status/Mask/Enable/Disable) have the same + * bit definitions. + */ +#define ZYNQMP_QSPI_IXR_TXNFULL_MASK 0x00000004 /* QSPI TX FIFO Overflow */ +#define ZYNQMP_QSPI_IXR_TXFULL_MASK 0x00000008 /* QSPI TX FIFO is full */ +#define ZYNQMP_QSPI_IXR_RXNEMTY_MASK 0x00000010 /* QSPI RX FIFO Not Empty */ +#define ZYNQMP_QSPI_IXR_GFEMTY_MASK 0x00000080 /* QSPI Generic FIFO Empty */ +#define ZYNQMP_QSPI_IXR_ALL_MASK (ZYNQMP_QSPI_IXR_TXNFULL_MASK | \ + ZYNQMP_QSPI_IXR_RXNEMTY_MASK) + +/* + * QSPI Enable Register bit Masks + * + * This register is used to enable or disable the QSPI controller + */ +#define ZYNQMP_QSPI_ENABLE_ENABLE_MASK 0x00000001 /* QSPI Enable Bit Mask */ + +#define ZYNQMP_QSPI_GFIFO_LOW_BUS BIT(14) +#define ZYNQMP_QSPI_GFIFO_CS_LOWER BIT(12) +#define ZYNQMP_QSPI_GFIFO_UP_BUS BIT(15) +#define ZYNQMP_QSPI_GFIFO_CS_UPPER BIT(13) +#define ZYNQMP_QSPI_SPI_MODE_QSPI (3 << 10) +#define ZYNQMP_QSPI_SPI_MODE_SPI BIT(10) +#define ZYNQMP_QSPI_SPI_MODE_DUAL_SPI (2 << 10) +#define ZYNQMP_QSPI_IMD_DATA_CS_ASSERT 5 +#define ZYNQMP_QSPI_IMD_DATA_CS_DEASSERT 5 +#define ZYNQMP_QSPI_GFIFO_TX BIT(16) +#define ZYNQMP_QSPI_GFIFO_RX BIT(17) +#define ZYNQMP_QSPI_GFIFO_STRIPE_MASK BIT(18) +#define ZYNQMP_QSPI_GFIFO_IMD_MASK 0xFF +#define ZYNQMP_QSPI_GFIFO_EXP_MASK BIT(9) +#define ZYNQMP_QSPI_GFIFO_DATA_XFR_MASK BIT(8) +#define ZYNQMP_QSPI_STRT_GEN_FIFO BIT(28) +#define ZYNQMP_QSPI_GEN_FIFO_STRT_MOD BIT(29) +#define ZYNQMP_QSPI_GFIFO_WP_HOLD BIT(19) +#define ZYNQMP_QSPI_BAUD_DIV_MASK (7 << 3) +#define ZYNQMP_QSPI_DFLT_BAUD_RATE_DIV BIT(3) +#define ZYNQMP_QSPI_GFIFO_ALL_INT_MASK 0xFBE +#define ZYNQMP_QSPI_DMA_DST_I_STS_DONE BIT(1) +#define ZYNQMP_QSPI_DMA_DST_I_STS_MASK 0xFE +#define MODEBITS 0x6 + +#define QUAD_OUT_READ_CMD 0x6B +#define QUAD_PAGE_PROGRAM_CMD 0x32 +#define DUAL_OUTPUT_FASTRD_CMD 0x3B + +#define ZYNQMP_QSPI_GFIFO_SELECT BIT(0) + +#define ZYNQMP_QSPI_FIFO_THRESHOLD 1 + +#define SPI_XFER_ON_BOTH 0 +#define SPI_XFER_ON_LOWER 1 +#define SPI_XFER_ON_UPPER 2 + +#define ZYNQMP_QSPI_DMA_ALIGN 0x4 +#define ZYNQMP_QSPI_MAX_BAUD_RATE_VAL 7 +#define ZYNQMP_QSPI_DFLT_BAUD_RATE_VAL 2 + +#define ZYNQMP_QSPI_TIMEOUT 100000000 + +/* QSPI register offsets */ +struct zynqmp_qspi_regs { + u32 confr; /* 0x00 */ + u32 isr; /* 0x04 */ + u32 ier; /* 0x08 */ + u32 idisr; /* 0x0C */ + u32 imaskr; /* 0x10 */ + u32 enbr; /* 0x14 */ + u32 dr; /* 0x18 */ + u32 txd0r; /* 0x1C */ + u32 drxr; /* 0x20 */ + u32 sicr; /* 0x24 */ + u32 txftr; /* 0x28 */ + u32 rxftr; /* 0x2C */ + u32 gpior; /* 0x30 */ + u32 reserved0; /* 0x34 */ + u32 lpbkdly; /* 0x38 */ + u32 reserved1; /* 0x3C */ + u32 genfifo; /* 0x40 */ + u32 gqspisel; /* 0x44 */ + u32 reserved2; /* 0x48 */ + u32 gqfifoctrl; /* 0x4C */ + u32 gqfthr; /* 0x50 */ + u32 gqpollcfg; /* 0x54 */ + u32 gqpollto; /* 0x58 */ + u32 gqxfersts; /* 0x5C */ + u32 gqfifosnap; /* 0x60 */ + u32 gqrxcpy; /* 0x64 */ + u32 reserved3[36]; /* 0x68 */ + u32 gqspidlyadj; /* 0xF8 */ +}; + +struct zynqmp_qspi_dma_regs { + u32 dmadst; /* 0x00 */ + u32 dmasize; /* 0x04 */ + u32 dmasts; /* 0x08 */ + u32 dmactrl; /* 0x0C */ + u32 reserved0; /* 0x10 */ + u32 dmaisr; /* 0x14 */ + u32 dmaier; /* 0x18 */ + u32 dmaidr; /* 0x1C */ + u32 dmaimr; /* 0x20 */ + u32 dmactrl2; /* 0x24 */ + u32 dmadstmsb; /* 0x28 */ +}; + +struct zynqmp_qspi_platdata { + struct zynqmp_qspi_regs *regs; + struct zynqmp_qspi_dma_regs *dma_regs; + u32 frequency; + u32 speed_hz; + unsigned int tx_rx_mode; +}; + +struct zynqmp_qspi_priv { + struct zynqmp_qspi_regs *regs; + struct zynqmp_qspi_dma_regs *dma_regs; + u8 mode; + const void *tx_buf; + void *rx_buf; + unsigned int len; + int bytes_to_transfer; + int bytes_to_receive; + unsigned int is_inst; + unsigned int cs_change:1; +}; + +static u8 last_cmd; + +static int zynqmp_qspi_ofdata_to_platdata(struct udevice *bus) +{ + struct zynqmp_qspi_platdata *plat = bus->platdata; + u32 mode = 0; + u32 value; + int ret; + struct clk clk; + unsigned long clock; + + debug("%s\n", __func__); + + plat->regs = (struct zynqmp_qspi_regs *)(devfdt_get_addr(bus) + 0x100); + plat->dma_regs = (struct zynqmp_qspi_dma_regs *)(devfdt_get_addr(bus) + + 0x800); + + ret = clk_get_by_index(bus, 0, &clk); + if (ret < 0) { + dev_err(dev, "failed to get clock\n"); + return ret; + } + + clock = clk_get_rate(&clk); + if (IS_ERR_VALUE(clock)) { + dev_err(dev, "failed to get rate\n"); + return clock; + } + debug("%s: CLK %ld\n", __func__, clock); + + ret = clk_enable(&clk); + if (ret && ret != -ENOSYS) { + dev_err(dev, "failed to enable clock\n"); + return ret; + } + + value = dev_read_u32_default(bus, "spi-rx-bus-width", 1); + switch (value) { + case 1: + break; + case 2: + mode |= SPI_RX_DUAL; + break; + case 4: + mode |= SPI_RX_QUAD; + break; + default: + printf("Invalid spi-rx-bus-width %d\n", value); + break; + } + + value = dev_read_u32_default(bus, "spi-tx-bus-width", 1); + switch (value) { + case 1: + break; + case 2: + mode |= SPI_TX_DUAL; + break; + case 4: + mode |= SPI_TX_QUAD; + break; + default: + printf("Invalid spi-tx-bus-width %d\n", value); + break; + } + + plat->tx_rx_mode = mode; + + plat->frequency = clock; + plat->speed_hz = plat->frequency; + + return 0; +} + +static void zynqmp_qspi_init_hw(struct zynqmp_qspi_priv *priv) +{ + u32 config_reg; + struct zynqmp_qspi_regs *regs = priv->regs; + + writel(ZYNQMP_QSPI_GFIFO_SELECT, ®s->gqspisel); + writel(ZYNQMP_QSPI_GFIFO_ALL_INT_MASK, ®s->idisr); + writel(ZYNQMP_QSPI_FIFO_THRESHOLD, ®s->txftr); + writel(ZYNQMP_QSPI_FIFO_THRESHOLD, ®s->rxftr); + writel(ZYNQMP_QSPI_GFIFO_ALL_INT_MASK, ®s->isr); + + config_reg = readl(®s->confr); + config_reg &= ~(ZYNQMP_QSPI_GFIFO_STRT_MODE_MASK | + ZYNQMP_QSPI_CONFIG_MODE_EN_MASK); + config_reg |= ZYNQMP_QSPI_CONFIG_DMA_MODE | + ZYNQMP_QSPI_GFIFO_WP_HOLD | + ZYNQMP_QSPI_DFLT_BAUD_RATE_DIV; + writel(config_reg, ®s->confr); + + writel(ZYNQMP_QSPI_ENABLE_ENABLE_MASK, ®s->enbr); +} + +static u32 zynqmp_qspi_bus_select(struct zynqmp_qspi_priv *priv) +{ + u32 gqspi_fifo_reg = 0; + + gqspi_fifo_reg = ZYNQMP_QSPI_GFIFO_LOW_BUS | + ZYNQMP_QSPI_GFIFO_CS_LOWER; + + return gqspi_fifo_reg; +} + +static void zynqmp_qspi_fill_gen_fifo(struct zynqmp_qspi_priv *priv, + u32 gqspi_fifo_reg) +{ + struct zynqmp_qspi_regs *regs = priv->regs; + u32 reg; + + do { + reg = readl(®s->isr); + } while (!(reg & ZYNQMP_QSPI_IXR_GFEMTY_MASK)); + + writel(gqspi_fifo_reg, ®s->genfifo); +} + +static void zynqmp_qspi_chipselect(struct zynqmp_qspi_priv *priv, int is_on) +{ + u32 gqspi_fifo_reg = 0; + + if (is_on) { + gqspi_fifo_reg = zynqmp_qspi_bus_select(priv); + gqspi_fifo_reg |= ZYNQMP_QSPI_SPI_MODE_SPI | + ZYNQMP_QSPI_IMD_DATA_CS_ASSERT; + } else { + gqspi_fifo_reg = ZYNQMP_QSPI_GFIFO_LOW_BUS; + gqspi_fifo_reg |= ZYNQMP_QSPI_IMD_DATA_CS_DEASSERT; + } + + debug("GFIFO_CMD_CS: 0x%x\n", gqspi_fifo_reg); + + zynqmp_qspi_fill_gen_fifo(priv, gqspi_fifo_reg); +} + +#define GQSPI_BAUD_DIV_SHIFT 2 +#define GQSPI_LPBK_DLY_ADJ_LPBK_SHIFT 5 +#define GQSPI_LPBK_DLY_ADJ_DLY_1 0x2 +#define GQSPI_LPBK_DLY_ADJ_DLY_1_SHIFT 3 +#define GQSPI_LPBK_DLY_ADJ_DLY_0 0x3 +#define GQSPI_USE_DATA_DLY 0x1 +#define GQSPI_USE_DATA_DLY_SHIFT 31 +#define GQSPI_DATA_DLY_ADJ_VALUE 0x2 +#define GQSPI_DATA_DLY_ADJ_SHIFT 28 +#define TAP_DLY_BYPASS_LQSPI_RX_VALUE 0x1 +#define TAP_DLY_BYPASS_LQSPI_RX_SHIFT 2 +#define GQSPI_DATA_DLY_ADJ_OFST 0x000001F8 +#define IOU_TAPDLY_BYPASS_OFST 0xFF180390 +#define GQSPI_LPBK_DLY_ADJ_USE_LPBK_MASK 0x00000020 +#define GQSPI_FREQ_40MHZ 40000000 +#define GQSPI_FREQ_100MHZ 100000000 +#define GQSPI_FREQ_150MHZ 150000000 +#define IOU_TAPDLY_BYPASS_MASK 0x7 + +void zynqmp_qspi_set_tapdelay(struct udevice *bus, u32 baudrateval) +{ + struct zynqmp_qspi_platdata *plat = bus->platdata; + struct zynqmp_qspi_priv *priv = dev_get_priv(bus); + struct zynqmp_qspi_regs *regs = priv->regs; + u32 tapdlybypass = 0, lpbkdlyadj = 0, datadlyadj = 0, clk_rate; + u32 reqhz = 0; + + clk_rate = plat->frequency; + reqhz = (clk_rate / (GQSPI_BAUD_DIV_SHIFT << baudrateval)); + + debug("%s, req_hz:%d, clk_rate:%d, baudrateval:%d\n", + __func__, reqhz, clk_rate, baudrateval); + + if (reqhz < GQSPI_FREQ_40MHZ) { + zynqmp_mmio_read(IOU_TAPDLY_BYPASS_OFST, &tapdlybypass); + tapdlybypass |= (TAP_DLY_BYPASS_LQSPI_RX_VALUE << + TAP_DLY_BYPASS_LQSPI_RX_SHIFT); + } else if (reqhz < GQSPI_FREQ_100MHZ) { + zynqmp_mmio_read(IOU_TAPDLY_BYPASS_OFST, &tapdlybypass); + tapdlybypass |= (TAP_DLY_BYPASS_LQSPI_RX_VALUE << + TAP_DLY_BYPASS_LQSPI_RX_SHIFT); + lpbkdlyadj = readl(®s->lpbkdly); + lpbkdlyadj |= (GQSPI_LPBK_DLY_ADJ_USE_LPBK_MASK); + datadlyadj = readl(®s->gqspidlyadj); + datadlyadj |= ((GQSPI_USE_DATA_DLY << GQSPI_USE_DATA_DLY_SHIFT) + | (GQSPI_DATA_DLY_ADJ_VALUE << + GQSPI_DATA_DLY_ADJ_SHIFT)); + } else if (reqhz < GQSPI_FREQ_150MHZ) { + lpbkdlyadj = readl(®s->lpbkdly); + lpbkdlyadj |= ((GQSPI_LPBK_DLY_ADJ_USE_LPBK_MASK) | + GQSPI_LPBK_DLY_ADJ_DLY_0); + } + + zynqmp_mmio_write(IOU_TAPDLY_BYPASS_OFST, IOU_TAPDLY_BYPASS_MASK, + tapdlybypass); + writel(lpbkdlyadj, ®s->lpbkdly); + writel(datadlyadj, ®s->gqspidlyadj); +} + +static int zynqmp_qspi_set_speed(struct udevice *bus, uint speed) +{ + struct zynqmp_qspi_platdata *plat = bus->platdata; + struct zynqmp_qspi_priv *priv = dev_get_priv(bus); + struct zynqmp_qspi_regs *regs = priv->regs; + u32 confr; + u8 baud_rate_val = 0; + + debug("%s\n", __func__); + if (speed > plat->frequency) + speed = plat->frequency; + + /* Set the clock frequency */ + confr = readl(®s->confr); + if (speed == 0) { + /* Set baudrate x8, if the freq is 0 */ + baud_rate_val = ZYNQMP_QSPI_DFLT_BAUD_RATE_VAL; + } else if (plat->speed_hz != speed) { + while ((baud_rate_val < 8) && + ((plat->frequency / + (2 << baud_rate_val)) > speed)) + baud_rate_val++; + + if (baud_rate_val > ZYNQMP_QSPI_MAX_BAUD_RATE_VAL) + baud_rate_val = ZYNQMP_QSPI_DFLT_BAUD_RATE_VAL; + + plat->speed_hz = plat->frequency / (2 << baud_rate_val); + } + confr &= ~ZYNQMP_QSPI_BAUD_DIV_MASK; + confr |= (baud_rate_val << 3); + writel(confr, ®s->confr); + + zynqmp_qspi_set_tapdelay(bus, baud_rate_val); + debug("regs=%p, speed=%d\n", priv->regs, plat->speed_hz); + + return 0; +} + +static int zynqmp_qspi_child_pre_probe(struct udevice *bus) +{ + struct spi_slave *slave = dev_get_parent_priv(bus); + struct zynqmp_qspi_platdata *plat = dev_get_platdata(bus->parent); + + slave->option = SF_SINGLE_FLASH; + slave->mode = plat->tx_rx_mode; + + return 0; +} + +static int zynqmp_qspi_probe(struct udevice *bus) +{ + struct zynqmp_qspi_platdata *plat = dev_get_platdata(bus); + struct zynqmp_qspi_priv *priv = dev_get_priv(bus); + + debug("%s: bus:%p, priv:%p\n", __func__, bus, priv); + + priv->regs = plat->regs; + priv->dma_regs = plat->dma_regs; + + /* init the zynq spi hw */ + zynqmp_qspi_init_hw(priv); + + return 0; +} + +static int zynqmp_qspi_set_mode(struct udevice *bus, uint mode) +{ + struct zynqmp_qspi_priv *priv = dev_get_priv(bus); + struct zynqmp_qspi_regs *regs = priv->regs; + u32 confr; + + debug("%s\n", __func__); + /* Set the SPI Clock phase and polarities */ + confr = readl(®s->confr); + confr &= ~(ZYNQMP_QSPI_CONFIG_CPHA_MASK | + ZYNQMP_QSPI_CONFIG_CPOL_MASK); + + if (priv->mode & SPI_CPHA) + confr |= ZYNQMP_QSPI_CONFIG_CPHA_MASK; + if (priv->mode & SPI_CPOL) + confr |= ZYNQMP_QSPI_CONFIG_CPOL_MASK; + + //writel(confr, ®s->confr); + priv->mode = mode; + + debug("regs=%p, mode=%d\n", priv->regs, priv->mode); + + return 0; +} + +static int zynqmp_qspi_fill_tx_fifo(struct zynqmp_qspi_priv *priv, u32 size) +{ + u32 data; + u32 timeout = ZYNQMP_QSPI_TIMEOUT; + struct zynqmp_qspi_regs *regs = priv->regs; + u32 *buf = (u32 *)priv->tx_buf; + u32 len = size; + + debug("TxFIFO: 0x%x, size: 0x%x\n", readl(®s->isr), + size); + + while (size && timeout) { + if (readl(®s->isr) & + ZYNQMP_QSPI_IXR_TXNFULL_MASK) { + if (size >= 4) { + writel(*buf, ®s->txd0r); + buf++; + size -= 4; + } else { + switch (size) { + case 1: + data = *((u8 *)buf); + buf += 1; + data |= 0xFFFFFF00; + break; + case 2: + data = *((u16 *)buf); + buf += 2; + data |= 0xFFFF0000; + break; + case 3: + data = *((u16 *)buf); + buf += 2; + data |= (*((u8 *)buf) << 16); + buf += 1; + data |= 0xFF000000; + break; + } + writel(data, ®s->txd0r); + size = 0; + } + } else { + udelay(1); + timeout--; + } + } + if (!timeout) { + printf("%s: Timeout\n", __func__); + return -1; + } + + priv->tx_buf += len; + return 0; +} + +static void zynqmp_qspi_genfifo_cmd(struct zynqmp_qspi_priv *priv) +{ + u8 command = 1; + u32 gen_fifo_cmd; + u32 bytecount = 0; + + while (priv->len) { + gen_fifo_cmd = zynqmp_qspi_bus_select(priv); + gen_fifo_cmd |= ZYNQMP_QSPI_GFIFO_TX; + + if (command) { + command = 0; + last_cmd = *(u8 *)priv->tx_buf; + } + + gen_fifo_cmd |= ZYNQMP_QSPI_SPI_MODE_SPI; + gen_fifo_cmd |= *(u8 *)priv->tx_buf; + bytecount++; + priv->len--; + priv->tx_buf = (u8 *)priv->tx_buf + 1; + + debug("GFIFO_CMD_Cmd = 0x%x\n", gen_fifo_cmd); + + zynqmp_qspi_fill_gen_fifo(priv, gen_fifo_cmd); + } +} + +static u32 zynqmp_qspi_calc_exp(struct zynqmp_qspi_priv *priv, + u32 *gen_fifo_cmd) +{ + u32 expval = 8; + u32 len; + + while (1) { + if (priv->len > 255) { + if (priv->len & (1 << expval)) { + *gen_fifo_cmd &= ~ZYNQMP_QSPI_GFIFO_IMD_MASK; + *gen_fifo_cmd |= ZYNQMP_QSPI_GFIFO_EXP_MASK; + *gen_fifo_cmd |= expval; + priv->len -= (1 << expval); + return expval; + } + expval++; + } else { + *gen_fifo_cmd &= ~(ZYNQMP_QSPI_GFIFO_IMD_MASK | + ZYNQMP_QSPI_GFIFO_EXP_MASK); + *gen_fifo_cmd |= (u8)priv->len; + len = (u8)priv->len; + priv->len = 0; + return len; + } + } +} + +static int zynqmp_qspi_genfifo_fill_tx(struct zynqmp_qspi_priv *priv) +{ + u32 gen_fifo_cmd; + u32 len; + int ret = 0; + + gen_fifo_cmd = zynqmp_qspi_bus_select(priv); + gen_fifo_cmd |= ZYNQMP_QSPI_GFIFO_TX | + ZYNQMP_QSPI_GFIFO_DATA_XFR_MASK; + + if (last_cmd == QUAD_PAGE_PROGRAM_CMD) + gen_fifo_cmd |= ZYNQMP_QSPI_SPI_MODE_QSPI; + else + gen_fifo_cmd |= ZYNQMP_QSPI_SPI_MODE_SPI; + + while (priv->len) { + len = zynqmp_qspi_calc_exp(priv, &gen_fifo_cmd); + zynqmp_qspi_fill_gen_fifo(priv, gen_fifo_cmd); + + debug("GFIFO_CMD_TX:0x%x\n", gen_fifo_cmd); + + if (gen_fifo_cmd & ZYNQMP_QSPI_GFIFO_EXP_MASK) + ret = zynqmp_qspi_fill_tx_fifo(priv, + 1 << len); + else + ret = zynqmp_qspi_fill_tx_fifo(priv, + len); + + if (ret) + return ret; + } + return ret; +} + +static int zynqmp_qspi_start_dma(struct zynqmp_qspi_priv *priv, + u32 gen_fifo_cmd, u32 *buf) +{ + u32 addr; + u32 size, len; + u32 timeout = ZYNQMP_QSPI_TIMEOUT; + u32 actuallen = priv->len; + struct zynqmp_qspi_dma_regs *dma_regs = priv->dma_regs; + + writel((unsigned long)buf, &dma_regs->dmadst); + writel(roundup(priv->len, 4), &dma_regs->dmasize); + writel(ZYNQMP_QSPI_DMA_DST_I_STS_MASK, &dma_regs->dmaier); + addr = (unsigned long)buf; + size = roundup(priv->len, ARCH_DMA_MINALIGN); + flush_dcache_range(addr, addr + size); + + while (priv->len) { + len = zynqmp_qspi_calc_exp(priv, &gen_fifo_cmd); + if (!(gen_fifo_cmd & ZYNQMP_QSPI_GFIFO_EXP_MASK) && + (len % 4)) { + gen_fifo_cmd &= ~(0xFF); + gen_fifo_cmd |= (len / 4 + 1) * 4; + } + zynqmp_qspi_fill_gen_fifo(priv, gen_fifo_cmd); + + debug("GFIFO_CMD_RX:0x%x\n", gen_fifo_cmd); + } + + while (timeout) { + if (readl(&dma_regs->dmaisr) & + ZYNQMP_QSPI_DMA_DST_I_STS_DONE) { + writel(ZYNQMP_QSPI_DMA_DST_I_STS_DONE, + &dma_regs->dmaisr); + break; + } + udelay(1); + timeout--; + } + + debug("buf:0x%lx, rxbuf:0x%lx, *buf:0x%x len: 0x%x\n", + (unsigned long)buf, (unsigned long)priv->rx_buf, *buf, + actuallen); + if (!timeout) { + printf("DMA Timeout:0x%x\n", readl(&dma_regs->dmaisr)); + return -1; + } + + if (buf != priv->rx_buf) + memcpy(priv->rx_buf, buf, actuallen); + + return 0; +} + +static int zynqmp_qspi_genfifo_fill_rx(struct zynqmp_qspi_priv *priv) +{ + u32 gen_fifo_cmd; + u32 *buf; + u32 actuallen = priv->len; + + gen_fifo_cmd = zynqmp_qspi_bus_select(priv); + gen_fifo_cmd |= ZYNQMP_QSPI_GFIFO_RX | + ZYNQMP_QSPI_GFIFO_DATA_XFR_MASK; + + if (last_cmd == QUAD_OUT_READ_CMD) + gen_fifo_cmd |= ZYNQMP_QSPI_SPI_MODE_QSPI; + else if (last_cmd == DUAL_OUTPUT_FASTRD_CMD) + gen_fifo_cmd |= ZYNQMP_QSPI_SPI_MODE_DUAL_SPI; + else + gen_fifo_cmd |= ZYNQMP_QSPI_SPI_MODE_SPI; + + /* + * Check if receive buffer is aligned to 4 byte and length + * is multiples of four byte as we are using dma to receive. + */ + if (!((unsigned long)priv->rx_buf & (ZYNQMP_QSPI_DMA_ALIGN - 1)) && + !(actuallen % ZYNQMP_QSPI_DMA_ALIGN)) { + buf = (u32 *)priv->rx_buf; + return zynqmp_qspi_start_dma(priv, gen_fifo_cmd, buf); + } + + ALLOC_CACHE_ALIGN_BUFFER(u8, tmp, roundup(priv->len, + ZYNQMP_QSPI_DMA_ALIGN)); + buf = (u32 *)tmp; + return zynqmp_qspi_start_dma(priv, gen_fifo_cmd, buf); +} + +static int zynqmp_qspi_start_transfer(struct zynqmp_qspi_priv *priv) +{ + int ret = 0; + + if (priv->is_inst) { + if (priv->tx_buf) + zynqmp_qspi_genfifo_cmd(priv); + else + ret = -1; + } else { + if (priv->tx_buf) + ret = zynqmp_qspi_genfifo_fill_tx(priv); + else if (priv->rx_buf) + ret = zynqmp_qspi_genfifo_fill_rx(priv); + else + ret = -1; + } + return ret; +} + +static int zynqmp_qspi_transfer(struct zynqmp_qspi_priv *priv) +{ + static unsigned int cs_change = 1; + int status = 0; + + debug("%s\n", __func__); + + while (1) { + /* Select the chip if required */ + if (cs_change) + zynqmp_qspi_chipselect(priv, 1); + + cs_change = priv->cs_change; + + if (!priv->tx_buf && !priv->rx_buf && priv->len) { + status = -1; + break; + } + + /* Request the transfer */ + if (priv->len) { + status = zynqmp_qspi_start_transfer(priv); + priv->is_inst = 0; + if (status < 0) + break; + } + + if (cs_change) + /* Deselect the chip */ + zynqmp_qspi_chipselect(priv, 0); + break; + } + + return status; +} + +static int zynqmp_qspi_claim_bus(struct udevice *dev) +{ + struct udevice *bus = dev->parent; + struct zynqmp_qspi_priv *priv = dev_get_priv(bus); + struct zynqmp_qspi_regs *regs = priv->regs; + + debug("%s\n", __func__); + writel(ZYNQMP_QSPI_ENABLE_ENABLE_MASK, ®s->enbr); + + return 0; +} + +static int zynqmp_qspi_release_bus(struct udevice *dev) +{ + struct udevice *bus = dev->parent; + struct zynqmp_qspi_priv *priv = dev_get_priv(bus); + struct zynqmp_qspi_regs *regs = priv->regs; + + debug("%s\n", __func__); + writel(~ZYNQMP_QSPI_ENABLE_ENABLE_MASK, ®s->enbr); + + return 0; +} + +int zynqmp_qspi_xfer(struct udevice *dev, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + struct udevice *bus = dev->parent; + struct zynqmp_qspi_priv *priv = dev_get_priv(bus); + + debug("%s: priv: 0x%08lx bitlen: %d dout: 0x%08lx ", __func__, + (unsigned long)priv, bitlen, (unsigned long)dout); + debug("din: 0x%08lx flags: 0x%lx\n", (unsigned long)din, flags); + + priv->tx_buf = dout; + priv->rx_buf = din; + priv->len = bitlen / 8; + + /* + * Festering sore. + * Assume that the beginning of a transfer with bits to + * transmit must contain a device command. + */ + if (dout && flags & SPI_XFER_BEGIN) + priv->is_inst = 1; + else + priv->is_inst = 0; + + if (flags & SPI_XFER_END) + priv->cs_change = 1; + else + priv->cs_change = 0; + + zynqmp_qspi_transfer(priv); + + return 0; +} + +static const struct dm_spi_ops zynqmp_qspi_ops = { + .claim_bus = zynqmp_qspi_claim_bus, + .release_bus = zynqmp_qspi_release_bus, + .xfer = zynqmp_qspi_xfer, + .set_speed = zynqmp_qspi_set_speed, + .set_mode = zynqmp_qspi_set_mode, +}; + +static const struct udevice_id zynqmp_qspi_ids[] = { + { .compatible = "xlnx,zynqmp-qspi-1.0" }, + { } +}; + +U_BOOT_DRIVER(zynqmp_qspi) = { + .name = "zynqmp_qspi", + .id = UCLASS_SPI, + .of_match = zynqmp_qspi_ids, + .ops = &zynqmp_qspi_ops, + .ofdata_to_platdata = zynqmp_qspi_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct zynqmp_qspi_platdata), + .priv_auto_alloc_size = sizeof(struct zynqmp_qspi_priv), + .probe = zynqmp_qspi_probe, + .child_pre_probe = zynqmp_qspi_child_pre_probe, +};
This patch adds qspi driver support for ZynqMP ZCU102 board.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- configs/xilinx_zynqmp_zcu102_revB_defconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index 9dd8cc9..78085e5 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_IDENT_STRING=" Xilinx ZynqMP ZCU102" CONFIG_ZYNQMP_USB=y +CONFIG_ZYNQMP_QSPI=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu102-revB" CONFIG_DEBUG_UART=y CONFIG_AHCI=y @@ -30,6 +31,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y @@ -51,11 +53,15 @@ CONFIG_CMD_PCA953X=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_DM_ETH=y CONFIG_PHY_GIGE=y CONFIG_ZYNQ_GEM=y
Hi Siva Durga Prasad,
diff --git a/arch/arm/cpu/armv8/zynqmp/Kconfig b/arch/arm/cpu/armv8/zynqmp/Kconfig index 5ffc9f6..278248a 100644 --- a/arch/arm/cpu/armv8/zynqmp/Kconfig +++ b/arch/arm/cpu/armv8/zynqmp/Kconfig @@ -50,6 +50,13 @@ config BOOT_INIT_FILE Add register writes to boot.bin format (max 256 pairs). Expect a table of register-value pairs, e.g. "0x12345678 0x4321" +config ZYNQMP_QSPI
- bool "Configure ZynqMP QSPI"
- select DM_SPI
- help
driver which
- (C) Copyright 2014 - 2015 Xilinx
- Xilinx ZynqMP Quad-SPI(QSPI) controller driver (master mode only)
- SPDX-License-Identifier: GPL-2.0
- QSPI Interrupt Registers bit Masks
- All the four interrupt registers (Status/Mask/Enable/Disable)
have the same
- bit definitions.
- QSPI Enable Register bit Masks
- This register is used to enable or disable the QSPI controller
- u32 confr; /* 0x00 */
- u32 isr; /* 0x04 */
- u32 ier; /* 0x08 */
- u32 idisr; /* 0x0C */
- u32 imaskr; /* 0x10 */
- u32 enbr; /* 0x14 */
- u32 dr; /* 0x18 */
- u32 txd0r; /* 0x1C */
- u32 drxr; /* 0x20 */
- u32 sicr; /* 0x24 */
- u32 txftr; /* 0x28 */
- u32 rxftr; /* 0x2C */
- u32 gpior; /* 0x30 */
- u32 reserved0; /* 0x34 */
- u32 lpbkdly; /* 0x38 */
- u32 reserved1; /* 0x3C */
- u32 genfifo; /* 0x40 */
- u32 gqspisel; /* 0x44 */
- u32 reserved2; /* 0x48 */
- u32 gqfifoctrl; /* 0x4C */
- u32 gqfthr; /* 0x50 */
- u32 gqpollcfg; /* 0x54 */
- u32 gqpollto; /* 0x58 */
- u32 gqxfersts; /* 0x5C */
- u32 gqfifosnap; /* 0x60 */
- u32 gqrxcpy; /* 0x64 */
- u32 reserved3[36]; /* 0x68 */
- u32 gqspidlyadj; /* 0xF8 */
- u32 dmadst; /* 0x00 */
- u32 dmasize; /* 0x04 */
- u32 dmasts; /* 0x08 */
- u32 dmactrl; /* 0x0C */
- u32 reserved0; /* 0x10 */
- u32 dmaisr; /* 0x14 */
- u32 dmaier; /* 0x18 */
- u32 dmaidr; /* 0x1C */
- u32 dmaimr; /* 0x20 */
- u32 dmactrl2; /* 0x24 */
- u32 dmadstmsb; /* 0x28 */
- struct zynqmp_qspi_regs *regs;
- struct zynqmp_qspi_dma_regs *dma_regs;
- u32 frequency;
- u32 speed_hz;
- unsigned int tx_rx_mode;
- u8 mode;
- const void *tx_buf;
- void *rx_buf;
- unsigned int len;
- int bytes_to_transfer;
- int bytes_to_receive;
- unsigned int is_inst;
- unsigned int cs_change:1;
Please split this driver to *.h and *.c files.
- struct zynqmp_qspi_platdata *plat = bus->platdata;
- u32 mode = 0;
- u32 value;
- int ret;
- struct clk clk;
- unsigned long clock;
- debug("%s\n", __func__);
- plat->regs = (struct zynqmp_qspi_regs
- plat->dma_regs = (struct zynqmp_qspi_dma_regs
0x800);
Please provide explanation - defines for magic values (0x800).
- ret = clk_get_by_index(bus, 0, &clk);
- if (ret < 0) {
return ret;
- clock = clk_get_rate(&clk);
- if (IS_ERR_VALUE(clock)) {
return clock;
- debug("%s: CLK %ld\n", __func__, clock);
- ret = clk_enable(&clk);
- if (ret && ret != -ENOSYS) {
return ret;
- value = dev_read_u32_default(bus, "spi-rx-bus-width", 1);
- switch (value) {
- case 1:
break;
- case 2:
break;
- case 4:
break;
- default:
break;
- value = dev_read_u32_default(bus, "spi-tx-bus-width", 1);
- switch (value) {
- case 1:
break;
- case 2:
break;
- case 4:
break;
- default:
break;
- plat->tx_rx_mode = mode;
- plat->frequency = clock;
- plat->speed_hz = plat->frequency;
- u32 config_reg;
- struct zynqmp_qspi_regs *regs = priv->regs;
- writel(ZYNQMP_QSPI_GFIFO_SELECT, ®s->gqspisel);
- writel(ZYNQMP_QSPI_GFIFO_ALL_INT_MASK, ®s->idisr);
- writel(ZYNQMP_QSPI_FIFO_THRESHOLD, ®s->txftr);
- writel(ZYNQMP_QSPI_FIFO_THRESHOLD, ®s->rxftr);
- writel(ZYNQMP_QSPI_GFIFO_ALL_INT_MASK, ®s->isr);
- config_reg = readl(®s->confr);
- config_reg &= ~(ZYNQMP_QSPI_GFIFO_STRT_MODE_MASK |
- config_reg |= ZYNQMP_QSPI_CONFIG_DMA_MODE |
- writel(config_reg, ®s->confr);
- writel(ZYNQMP_QSPI_ENABLE_ENABLE_MASK, ®s->enbr);
- u32 gqspi_fifo_reg = 0;
- gqspi_fifo_reg = ZYNQMP_QSPI_GFIFO_LOW_BUS |
- return gqspi_fifo_reg;
u32 gqspi_fifo_reg)
- u32 reg;
- do {
- } while (!(reg & ZYNQMP_QSPI_IXR_GFEMTY_MASK));
- writel(gqspi_fifo_reg, ®s->genfifo);
- if (is_on) {
- } else {
- debug("GFIFO_CMD_CS: 0x%x\n", gqspi_fifo_reg);
- zynqmp_qspi_fill_gen_fifo(priv, gqspi_fifo_reg);
Please move it to *.h
- struct zynqmp_qspi_priv *priv = dev_get_priv(bus);
- u32 tapdlybypass = 0, lpbkdlyadj = 0, datadlyadj = 0,
clk_rate;
- u32 reqhz = 0;
- clk_rate = plat->frequency;
- reqhz = (clk_rate / (GQSPI_BAUD_DIV_SHIFT << baudrateval));
- debug("%s, req_hz:%d, clk_rate:%d, baudrateval:%d\n",
- if (reqhz < GQSPI_FREQ_40MHZ) {
&tapdlybypass);
- } else if (reqhz < GQSPI_FREQ_100MHZ) {
&tapdlybypass);
- } else if (reqhz < GQSPI_FREQ_150MHZ) {
- zynqmp_mmio_write(IOU_TAPDLY_BYPASS_OFST,
tapdlybypass);
- writel(lpbkdlyadj, ®s->lpbkdly);
- writel(datadlyadj, ®s->gqspidlyadj);
- u32 confr;
- u8 baud_rate_val = 0;
- if (speed > plat->frequency)
- /* Set the clock frequency */
- confr = readl(®s->confr);
- if (speed == 0) {
- } else if (plat->speed_hz != speed) {
((plat->frequency /
baud_rate_val++;
baud_rate_val =
baud_rate_val);
- confr &= ~ZYNQMP_QSPI_BAUD_DIV_MASK;
- confr |= (baud_rate_val << 3);
- writel(confr, ®s->confr);
- zynqmp_qspi_set_tapdelay(bus, baud_rate_val);
- debug("regs=%p, speed=%d\n", priv->regs, plat->speed_hz);
- struct spi_slave *slave = dev_get_parent_priv(bus);
- slave->option = SF_SINGLE_FLASH;
- slave->mode = plat->tx_rx_mode;
- struct zynqmp_qspi_platdata *plat = dev_get_platdata(bus);
- debug("%s: bus:%p, priv:%p\n", __func__, bus, priv);
- priv->regs = plat->regs;
- priv->dma_regs = plat->dma_regs;
- /* init the zynq spi hw */
- zynqmp_qspi_init_hw(priv);
- u32 confr;
- /* Set the SPI Clock phase and polarities */
- confr &= ~(ZYNQMP_QSPI_CONFIG_CPHA_MASK |
- if (priv->mode & SPI_CPHA)
- if (priv->mode & SPI_CPOL)
- //writel(confr, ®s->confr);
- priv->mode = mode;
- debug("regs=%p, mode=%d\n", priv->regs, priv->mode);
- u32 data;
- u32 timeout = ZYNQMP_QSPI_TIMEOUT;
- u32 *buf = (u32 *)priv->tx_buf;
- u32 len = size;
- debug("TxFIFO: 0x%x, size: 0x%x\n", readl(®s->isr),
size);
- while (size && timeout) {
if (size >= 4) {
buf++;
size -= 4;
} else {
switch (size) {
case 1:
buf += 1;
data |= 0xFFFFFF00;
break;
case 2:
buf += 2;
data |= 0xFFFF0000;
break;
case 3:
buf += 2;
buf += 1;
data |= 0xFF000000;
break;
size = 0;
} else {
udelay(1);
timeout--;
- if (!timeout) {
return -1;
- priv->tx_buf += len;
- u8 command = 1;
- u32 gen_fifo_cmd;
- u32 bytecount = 0;
- while (priv->len) {
if (command) {
command = 0;
bytecount++;
priv->len--;
u32 *gen_fifo_cmd)
- u32 expval = 8;
- u32 len;
- while (1) {
*gen_fifo_cmd &=
*gen_fifo_cmd |=
return expval;
expval++;
} else {
*gen_fifo_cmd &=
priv->len = 0;
return len;
- u32 gen_fifo_cmd;
- u32 len;
- int ret = 0;
- gen_fifo_cmd = zynqmp_qspi_bus_select(priv);
- gen_fifo_cmd |= ZYNQMP_QSPI_GFIFO_TX |
- if (last_cmd == QUAD_PAGE_PROGRAM_CMD)
- else
1 << len);
else
len);
if (ret)
return ret;
- return ret;
- u32 addr;
- u32 size, len;
- u32 actuallen = priv->len;
- struct zynqmp_qspi_dma_regs *dma_regs = priv->dma_regs;
- writel((unsigned long)buf, &dma_regs->dmadst);
- writel(roundup(priv->len, 4), &dma_regs->dmasize);
- writel(ZYNQMP_QSPI_DMA_DST_I_STS_MASK, &dma_regs->dmaier);
- addr = (unsigned long)buf;
- size = roundup(priv->len, ARCH_DMA_MINALIGN);
- flush_dcache_range(addr, addr + size);
(len % 4)) {
- while (timeout) {
&dma_regs->dmaisr);
break;
udelay(1);
timeout--;
- debug("buf:0x%lx, rxbuf:0x%lx, *buf:0x%x len: 0x%x\n",
actuallen);
- if (!timeout) {
return -1;
- if (buf != priv->rx_buf)
- u32 gen_fifo_cmd;
- u32 *buf;
- gen_fifo_cmd |= ZYNQMP_QSPI_GFIFO_RX |
- if (last_cmd == QUAD_OUT_READ_CMD)
- else if (last_cmd == DUAL_OUTPUT_FASTRD_CMD)
- else
- if (!((unsigned long)priv->rx_buf & (ZYNQMP_QSPI_DMA_ALIGN -
1)) &&
buf);
- ALLOC_CACHE_ALIGN_BUFFER(u8, tmp, roundup(priv->len,
- buf = (u32 *)tmp;
- return zynqmp_qspi_start_dma(priv, gen_fifo_cmd, buf);
- int ret = 0;
- if (priv->is_inst) {
if (priv->tx_buf)
else
ret = -1;
- } else {
if (priv->tx_buf)
else
ret = -1;
- return ret;
- static unsigned int cs_change = 1;
- int status = 0;
- while (1) {
if (cs_change)
status = -1;
break;
if (priv->len) {
priv->is_inst = 0;
if (status < 0)
break;
if (cs_change)
break;
- return status;
- struct udevice *bus = dev->parent;
- writel(~ZYNQMP_QSPI_ENABLE_ENABLE_MASK, ®s->enbr);
- debug("%s: priv: 0x%08lx bitlen: %d dout: 0x%08lx ",
__func__,
- debug("din: 0x%08lx flags: 0x%lx\n", (unsigned long)din,
flags); +
- priv->tx_buf = dout;
- priv->rx_buf = din;
- priv->len = bitlen / 8;
* Festering sore.
- if (dout && flags & SPI_XFER_BEGIN)
priv->is_inst = 1;
- else
priv->is_inst = 0;
- if (flags & SPI_XFER_END)
- else
- zynqmp_qspi_transfer(priv);
- .claim_bus = zynqmp_qspi_claim_bus,
- .release_bus = zynqmp_qspi_release_bus,
- .xfer = zynqmp_qspi_xfer,
- .set_speed = zynqmp_qspi_set_speed,
- .set_mode = zynqmp_qspi_set_mode,
- { .compatible = "xlnx,zynqmp-qspi-1.0" },
- .name = "zynqmp_qspi",
- .id = UCLASS_SPI,
- .of_match = zynqmp_qspi_ids,
- .ops = &zynqmp_qspi_ops,
- .ofdata_to_platdata = zynqmp_qspi_ofdata_to_platdata,
- .platdata_auto_alloc_size = sizeof(struct
- .priv_auto_alloc_size = sizeof(struct zynqmp_qspi_priv),
- .probe = zynqmp_qspi_probe,
- .child_pre_probe = zynqmp_qspi_child_pre_probe,
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
On Tue, Oct 24, 2017 at 3:33 PM, Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com wrote:
Legacy question, what is your approach for dual memory setup? Did you write another flash driver?
I see this driver use dual flash slave 'option' which doesn't live on spi side anymore. better to have a discussion on approach and will review further.
thanks!
Hi Jagan,
-----Original Message----- From: Jagan Teki [mailto:jagannadh.teki@gmail.com] Sent: Tuesday, October 31, 2017 2:40 PM To: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: u-boot@lists.denx.de; Liam Beguin liambeguin@gmail.com; Siva Durga Prasad Paladugu sivadur@xilinx.com Subject: Re: [UBOOT PATCH 1/2] spi: zynqmp_qspi: Add support for ZynqMP qspi driver
No
I can see that spi_flash.c(driver/mtd/spi/spi_flash.c) has the option for dual flash under CONFIG_SF_DUAL_FLASH. I thought of using the same. Isn't it takes care of dual flash case? Please let me know if you any further thoughts on how it has to be handled.
Thanks, Siva
thanks!
Jagan Teki Free Software Engineer | www.openedev.com U-Boot, Linux | Upstream Maintainer Hyderabad, India.
On Tue, Oct 31, 2017 at 2:50 PM, Siva Durga Prasad Paladugu sivadur@xilinx.com wrote:
Hi Jagan,
No
Dual flash case should take for generic spi drivers, if you strictly want your controller to handle flash device rather !flashes then we need to write the driver at flash side. ie why I asked as first question.
thanks!
Hi Jagan,
-----Original Message----- From: Jagan Teki [mailto:jagannadh.teki@gmail.com] Sent: Tuesday, October 31, 2017 3:01 PM To: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: u-boot@lists.denx.de; Liam Beguin liambeguin@gmail.com Subject: Re: [UBOOT PATCH 1/2] spi: zynqmp_qspi: Add support for ZynqMP qspi driver
Hi Jagan,
No
review further.
handled.
Does this mean that drivers that are present in drivers/spi/ should work for both flashes and !flashes. And the drivers that only targets flash devices should be in different place and doesn’t use Dual flash functionality under CONFIG_SF_DUAL_FLASH? Or it can still use this.
Thanks, DP
thanks!
On Tue, Oct 31, 2017 at 6:33 PM, Siva Durga Prasad Paladugu sivadur@xilinx.com wrote:
Hi Jagan,
Hi Jagan,
No
review further.
handled.
Sorry, you understand it reverse or may be I'm not clear.
drivers at drivers/spi can handle only generic slaves which includes spi-flash and some spi-flash(spi-nor) controllers which only deals with spi-flash slaves which can be part of drivers/mtd/spi. Since your driver is categorized as spi-nor controller(in above notes from you) it's better to write driver at drivers/mtd/spi side.
Hope it clear.
thanks!
Hi Jagan,
-----Original Message----- From: Jagan Teki [mailto:jagannadh.teki@gmail.com] Sent: Wednesday, November 01, 2017 2:54 PM To: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: u-boot@lists.denx.de; Liam Beguin liambeguin@gmail.com Subject: Re: [UBOOT PATCH 1/2] spi: zynqmp_qspi: Add support for ZynqMP qspi driver
Hi Jagan,
Hi Jagan,
Siva
No
review further.
handled.
No, the controller is meant to handle other slaves as well along with spi-nor. Also for now, we are targeting single spi flash. So, keeping the driver here should just be fine. Please let me know if you need any further info.
Thanks, Siva.
Hope it clear.
thanks!
Hi Jagan,
Ping!!
Thanks, Siva
-----Original Message----- From: Siva Durga Prasad Paladugu Sent: Thursday, November 23, 2017 1:01 PM To: Jagan Teki jagannadh.teki@gmail.com Cc: u-boot@lists.denx.de; Liam Beguin liambeguin@gmail.com Subject: RE: [UBOOT PATCH 1/2] spi: zynqmp_qspi: Add support for ZynqMP qspi driver
Hi Jagan,
Hi Jagan,
Hi Jagan,
Siva
On Tue, Oct 24, 2017 at 3:33 PM, Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com wrote: > This patch adds qspi driver support for ZynqMP SoC. This > driver is responsible for communicating with qspi flash devices.
No
review further.
handled.
first question.
Thanks, Siva.
Hope it clear.
thanks!
On Thu, Nov 23, 2017 at 1:00 PM, Siva Durga Prasad Paladugu sivadur@xilinx.com wrote:
Hi Jagan,
Hi Jagan,
Hi Jagan,
Siva
On Tue, Oct 24, 2017 at 3:33 PM, Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com wrote: > This patch adds qspi driver support for ZynqMP SoC. This driver > is responsible for communicating with qspi flash devices.
No
review further.
handled.
remember if driver sits here, then we can't extent your controller specific functions.
And rebase your patches and set it again.
Hi jagan,
-----Original Message----- From: Jagan Teki [mailto:jagannadh.teki@gmail.com] Sent: Thursday, December 07, 2017 10:56 AM To: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: u-boot@lists.denx.de; Liam Beguin liambeguin@gmail.com Subject: Re: [UBOOT PATCH 1/2] spi: zynqmp_qspi: Add support for ZynqMP qspi driver
Hi Jagan,
Hi Jagan,
Hi Jagan,
> -----Original Message----- > From: Jagan Teki [mailto:jagannadh.teki@gmail.com] > Sent: Tuesday, October 31, 2017 2:40 PM > To: Siva Durga Prasad Paladugu sivadur@xilinx.com > Cc: u-boot@lists.denx.de; Liam Beguin liambeguin@gmail.com;
Siva
> Durga Prasad Paladugu sivadur@xilinx.com > Subject: Re: [UBOOT PATCH 1/2] spi: zynqmp_qspi: Add support > for ZynqMP qspi driver > > On Tue, Oct 24, 2017 at 3:33 PM, Siva Durga Prasad Paladugu > siva.durga.paladugu@xilinx.com wrote: > > This patch adds qspi driver support for ZynqMP SoC. This > > driver is responsible for communicating with qspi flash devices. > > Legacy question, what is your approach for dual memory setup? > Did you write another flash driver? No
> > I see this driver use dual flash slave 'option' which doesn't > live on spi side anymore. better to have a discussion on > approach and will
review further.
handled.
as first question.
nor.
info.
Yes, that’s fine, we are not targeting to have controller specific features. When we do We will move it to new place as you suggest.
I will rebase on top of latest master and will send v2.
Thanks, Siva
Jagan Teki
Lukasz Majewski
