[U-Boot] [PATCH v4 0/3] mtd: nand: omap: add support for BCH16_ECC
This patch series should be picked above http://lists.denx.de/pipermail/u-boot/2014-April/177323.html
*changes v3 -> v4* [PATCH 1/3] (new patch) [PATCH 2/3] fixed BCH16 implementation for omap_gpmc.c [PATCH 3/3] (no change) include minor clean-up patch to use macro GPMC_MAX_SECTORS
*changes v2 -> v3* - dropped [PATCH] am33xx: elm: add support for BCH16_ECC - ELM driver updates re-using existing code in omap_elm.c - rebased and refreshed above [1] and u-boot-2014.04 - Documentation updated in doc/nand.README
*changes v1 -> v2* - rebased for http://lists.denx.de/pipermail/u-boot/2013-September/162107.html - minor code cleanup
*original v1* This patch series add support of BCH16_ECC scheme. As BCH16_ECC scheme generates 26bytes of ECC syndrome per 512B data, hence this scheme is usable only for NAND devices having 4K or above page-size, as their OOB/spare area has enough space to accomodate ECC.
This patch series is applicable over an above following series: http://lists.denx.de/pipermail/u-boot/2013-September/161859.html
Pekon Gupta (3): mtd: nand: omap_gpmc: use macro for register definitions mtd: nand: omap: add support for BCH16_ECC - NAND driver updates am335x: update README for BCH16
doc/README.nand | 42 +++++++++++++++++++++++ drivers/mtd/nand/omap_gpmc.c | 79 ++++++++++++++++++++++++++++++++++++++++++- include/linux/mtd/omap_gpmc.h | 11 +++++- 3 files changed, 130 insertions(+), 2 deletions(-)
GPMC can support simultaneous processing of 8 512Byte data chunks, in parallel
Signed-off-by: Pekon Gupta pekon@ti.com --- include/linux/mtd/omap_gpmc.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/linux/mtd/omap_gpmc.h b/include/linux/mtd/omap_gpmc.h index 22f6573..d55fe32 100644 --- a/include/linux/mtd/omap_gpmc.h +++ b/include/linux/mtd/omap_gpmc.h @@ -11,6 +11,7 @@
#define GPMC_BUF_EMPTY 0 #define GPMC_BUF_FULL 1 +#define GPMC_MAX_SECTORS 8
enum omap_ecc { /* 1-bit ECC calculation by Software, Error detection by Software */ @@ -75,7 +76,7 @@ struct gpmc { u8 res7[12]; /* 0x224 */ u32 testmomde_ctrl; /* 0x230 */ u8 res8[12]; /* 0x234 */ - struct bch_res_0_3 bch_result_0_3[2]; /* 0x240 */ + struct bch_res_0_3 bch_result_0_3[GPMC_MAX_SECTORS]; /* 0x240,0x250, */ };
/* Used for board specific gpmc initialization */
Applied to u-boot-ti/master, thanks!
This patch add support for BCH16_ECC to omap_gpmc driver.
*need to BCH16 ECC scheme* With newer SLC Flash technologies and MLC NAND, and large densities, pagesizes Flash devices have become more suspectible to bit-flips. Thus stronger ECC schemes are required for protecting the data. But stronger ECC schemes have come with larger-sized ECC syndromes which require more space in OOB/Spare. This puts constrains like; (a) BCH16_ECC can correct 16 bit-flips per 512Bytes of data. (b) BCH16_ECC generates 26-bytes of ECC syndrome / 512B. Due to (b) this scheme can only be used with NAND devices which have enough OOB to satisfy following equation: OOBsize per page >= 26 * (page-size / 512)
Signed-off-by: Pekon Gupta pekon@ti.com --- drivers/mtd/nand/omap_gpmc.c | 79 ++++++++++++++++++++++++++++++++++++++++++- include/linux/mtd/omap_gpmc.h | 8 +++++ 2 files changed, 86 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/omap_gpmc.c b/drivers/mtd/nand/omap_gpmc.c index cdfa6bc..1acf06b 100644 --- a/drivers/mtd/nand/omap_gpmc.c +++ b/drivers/mtd/nand/omap_gpmc.c @@ -224,6 +224,19 @@ static void omap_enable_hwecc(struct mtd_info *mtd, int32_t mode) eccsize1 = 2; /* non-ECC bits in nibbles per sector */ } break; + case OMAP_ECC_BCH16_CODE_HW: + ecc_algo = 0x1; + bch_type = 0x2; + if (mode == NAND_ECC_WRITE) { + bch_wrapmode = 0x01; + eccsize0 = 0; /* extra bits in nibbles per sector */ + eccsize1 = 52; /* OOB bits in nibbles per sector */ + } else { + bch_wrapmode = 0x01; + eccsize0 = 52; /* ECC bits in nibbles per sector */ + eccsize1 = 0; /* non-ECC bits in nibbles per sector */ + } + break; default: return; } @@ -290,6 +303,29 @@ static int omap_calculate_ecc(struct mtd_info *mtd, const uint8_t *dat, ptr--; } break; + case OMAP_ECC_BCH16_CODE_HW: + val = readl(&gpmc_cfg->bch_result_4_6[0].bch_result_x[2]); + ecc_code[i++] = (val >> 8) & 0xFF; + ecc_code[i++] = (val >> 0) & 0xFF; + val = readl(&gpmc_cfg->bch_result_4_6[0].bch_result_x[1]); + ecc_code[i++] = (val >> 24) & 0xFF; + ecc_code[i++] = (val >> 16) & 0xFF; + ecc_code[i++] = (val >> 8) & 0xFF; + ecc_code[i++] = (val >> 0) & 0xFF; + val = readl(&gpmc_cfg->bch_result_4_6[0].bch_result_x[0]); + ecc_code[i++] = (val >> 24) & 0xFF; + ecc_code[i++] = (val >> 16) & 0xFF; + ecc_code[i++] = (val >> 8) & 0xFF; + ecc_code[i++] = (val >> 0) & 0xFF; + for (j = 3; j >= 0; j--) { + val = readl(&gpmc_cfg->bch_result_0_3[0].bch_result_x[j] + ); + ecc_code[i++] = (val >> 24) & 0xFF; + ecc_code[i++] = (val >> 16) & 0xFF; + ecc_code[i++] = (val >> 8) & 0xFF; + ecc_code[i++] = (val >> 0) & 0xFF; + } + break; default: return -EINVAL; } @@ -308,6 +344,8 @@ static int omap_calculate_ecc(struct mtd_info *mtd, const uint8_t *dat, case OMAP_ECC_BCH8_CODE_HW: ecc_code[chip->ecc.bytes - 1] = 0x00; break; + case OMAP_ECC_BCH16_CODE_HW: + break; default: return -EINVAL; } @@ -333,7 +371,7 @@ static int omap_correct_data_bch(struct mtd_info *mtd, uint8_t *dat, struct omap_nand_info *info = chip->priv; struct nand_ecc_ctrl *ecc = &chip->ecc; uint32_t error_count = 0, error_max; - uint32_t error_loc[8]; + uint32_t error_loc[ELM_MAX_ERROR_COUNT]; enum bch_level bch_type; uint32_t i, ecc_flag = 0; uint8_t count, err = 0; @@ -365,6 +403,10 @@ static int omap_correct_data_bch(struct mtd_info *mtd, uint8_t *dat, bch_type = BCH_8_BIT; omap_reverse_list(calc_ecc, ecc->bytes - 1); break; + case OMAP_ECC_BCH16_CODE_HW: + bch_type = BCH_16_BIT; + omap_reverse_list(calc_ecc, ecc->bytes); + break; default: return -EINVAL; } @@ -381,6 +423,9 @@ static int omap_correct_data_bch(struct mtd_info *mtd, uint8_t *dat, /* 14th byte in ECC is reserved to match ROM layout */ error_max = SECTOR_BYTES + (ecc->bytes - 1); break; + case OMAP_ECC_BCH16_CODE_HW: + error_max = SECTOR_BYTES + ecc->bytes; + break; default: return -EINVAL; } @@ -666,6 +711,38 @@ static int omap_select_ecc_scheme(struct nand_chip *nand, return -EINVAL; #endif
+ case OMAP_ECC_BCH16_CODE_HW: +#ifdef CONFIG_NAND_OMAP_ELM + debug("nand: using OMAP_ECC_BCH16_CODE_HW\n"); + /* check ecc-scheme requirements before updating ecc info */ + if ((26 * eccsteps) + BADBLOCK_MARKER_LENGTH > oobsize) { + printf("nand: error: insufficient OOB: require=%d\n", ( + (26 * eccsteps) + BADBLOCK_MARKER_LENGTH)); + return -EINVAL; + } + /* intialize ELM for ECC error detection */ + elm_init(); + /* populate ecc specific fields */ + nand->ecc.mode = NAND_ECC_HW; + nand->ecc.size = SECTOR_BYTES; + nand->ecc.bytes = 26; + nand->ecc.strength = 16; + nand->ecc.hwctl = omap_enable_hwecc; + nand->ecc.correct = omap_correct_data_bch; + nand->ecc.calculate = omap_calculate_ecc; + nand->ecc.read_page = omap_read_page_bch; + /* define ecc-layout */ + ecclayout->eccbytes = nand->ecc.bytes * eccsteps; + for (i = 0; i < ecclayout->eccbytes; i++) + ecclayout->eccpos[i] = i + BADBLOCK_MARKER_LENGTH; + ecclayout->oobfree[0].offset = i + BADBLOCK_MARKER_LENGTH; + ecclayout->oobfree[0].length = oobsize - nand->ecc.bytes - + BADBLOCK_MARKER_LENGTH; + break; +#else + printf("nand: error: CONFIG_NAND_OMAP_ELM required for ECC\n"); + return -EINVAL; +#endif default: debug("nand: error: ecc scheme not enabled or supported\n"); return -EINVAL; diff --git a/include/linux/mtd/omap_gpmc.h b/include/linux/mtd/omap_gpmc.h index d55fe32..9a86582 100644 --- a/include/linux/mtd/omap_gpmc.h +++ b/include/linux/mtd/omap_gpmc.h @@ -27,6 +27,8 @@ enum omap_ecc { OMAP_ECC_BCH8_CODE_HW_DETECTION_SW, /* 8-bit ECC calculation by GPMC, Error detection by ELM */ OMAP_ECC_BCH8_CODE_HW, + /* 16-bit ECC calculation by GPMC, Error detection by ELM */ + OMAP_ECC_BCH16_CODE_HW, };
struct gpmc_cs { @@ -47,6 +49,10 @@ struct bch_res_0_3 { u32 bch_result_x[4]; };
+struct bch_res_4_6 { + u32 bch_result_x[3]; +}; + struct gpmc { u8 res1[0x10]; u32 sysconfig; /* 0x10 */ @@ -77,6 +83,8 @@ struct gpmc { u32 testmomde_ctrl; /* 0x230 */ u8 res8[12]; /* 0x234 */ struct bch_res_0_3 bch_result_0_3[GPMC_MAX_SECTORS]; /* 0x240,0x250, */ + u8 res9[16 * 4]; /* 0x2C0 - 0x2FF */ + struct bch_res_4_6 bch_result_4_6[GPMC_MAX_SECTORS]; /* 0x300,0x310, */ };
updates documentation with explanation on how to select ECC schemes.
Signed-off-by: Pekon Gupta pekon@ti.com --- doc/README.nand | 42 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 42 insertions(+)
diff --git a/doc/README.nand b/doc/README.nand index 2bc5b39..70cf768 100644 --- a/doc/README.nand +++ b/doc/README.nand @@ -249,6 +249,48 @@ Platform specific options 8-bit BCH code with - ecc calculation using GPMC hardware engine, - error detection using ELM hardware engine. + OMAP_ECC_BCH16_CODE_HW + 16-bit BCH code with + - ecc calculation using GPMC hardware engine, + - error detection using ELM hardware engine. + + How to select ECC scheme on OMAP and AMxx platforms ? + ----------------------------------------------------- + Though higher ECC schemes have more capability to detect and correct + bit-flips, but still selection of ECC scheme is dependent on following + - hardware engines present in SoC. + Some legacy OMAP SoC do not have ELM h/w engine thus such + SoC cannot support BCHx_HW ECC schemes. + - size of OOB/Spare region + With higher ECC schemes, more OOB/Spare area is required to + store ECC. So choice of ECC scheme is limited by NAND oobsize. + + In general following expression can help: + NAND_OOBSIZE >= 2 + (NAND_PAGESIZE / 512) * ECC_BYTES + where + NAND_OOBSIZE = number of bytes available in + OOB/spare area per NAND page. + NAND_PAGESIZE = bytes in main-area of NAND page. + ECC_BYTES = number of ECC bytes generated to + protect 512 bytes of data, which is: + 3 for HAM1_xx ecc schemes + 7 for BCH4_xx ecc schemes + 14 for BCH8_xx ecc schemes + 26 for BCH16_xx ecc schemes + + example to check for BCH16 on 2K page NAND + NAND_PAGESIZE = 2048 + NAND_OOBSIZE = 64 + 2 + (2048 / 512) * 26 = 106 > NAND_OOBSIZE + Thus BCH16 cannot be supported on 2K page NAND. + + However, for 4K pagesize NAND + NAND_PAGESIZE = 4096 + NAND_OOBSIZE = 64 + ECC_BYTES = 26 + 2 + (4096 / 512) * 26 = 210 < NAND_OOBSIZE + Thus BCH16 can be supported on 4K page NAND. +
NOTE: =====
Pekon Gupta
