[U-Boot-Users] [PATCH] Add CONFIG_MII_INIT support to related boards
Replace CONFIG_8xx and CONFIG_MCF532x to CONFIG_MII_INIT in cmd_init.c. Add CONFIG_MII_INIT to board configuration files that use mii_init() in cmd_init.c.
Signed-off-by: TsiChung Liew Tsi-Chung.Liew@freescale.com --- board/fads/fads.h | 1 + common/cmd_mii.c | 2 +- include/configs/Adder.h | 1 + include/configs/EB+MCF-EV123.h | 1 + include/configs/EP88x.h | 1 + include/configs/GEN860T.h | 1 + include/configs/M5235EVB.h | 1 + include/configs/M5271EVB.h | 1 + include/configs/M5275EVB.h | 1 + include/configs/M5282EVB.h | 1 + include/configs/M5329EVB.h | 1 + include/configs/M5373EVB.h | 1 + include/configs/M54455EVB.h | 4 ++-- include/configs/M5475EVB.h | 1 + include/configs/M5485EVB.h | 1 + include/configs/NETPHONE.h | 1 + include/configs/NETTA.h | 1 + include/configs/NETTA2.h | 1 + include/configs/TK885D.h | 2 ++ include/configs/TOP860.h | 1 + include/configs/TQM885D.h | 1 + include/configs/cobra5272.h | 1 + include/configs/idmr.h | 3 ++- include/configs/spc1920.h | 1 + include/configs/stxxtc.h | 1 + include/configs/uc100.h | 1 + 26 files changed, 29 insertions(+), 4 deletions(-)
diff --git a/board/fads/fads.h b/board/fads/fads.h index dea8a0d..b217068 100644 --- a/board/fads/fads.h +++ b/board/fads/fads.h @@ -96,6 +96,7 @@
#ifdef CONFIG_FEC_ENET #define CFG_DISCOVER_PHY +#define CONFIG_MII_INIT 1 #endif
diff --git a/common/cmd_mii.c b/common/cmd_mii.c index fa753dd..bcbd7aa 100644 --- a/common/cmd_mii.c +++ b/common/cmd_mii.c @@ -306,7 +306,7 @@ int do_mii (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) return 1; }
-#if defined(CONFIG_8xx) || defined(CONFIG_MCF532x) || defined(CONFIG_MII_INIT) +#if defined(CONFIG_MII_INIT) mii_init (); #endif
diff --git a/include/configs/Adder.h b/include/configs/Adder.h index 7919991..8a76c26 100644 --- a/include/configs/Adder.h +++ b/include/configs/Adder.h @@ -42,6 +42,7 @@
#if defined(CONFIG_ETHER_ON_FEC1) || defined(CONFIG_ETHER_ON_FEC2) #define CFG_DISCOVER_PHY +#define CONFIG_MII_INIT 1 #define FEC_ENET #endif /* CONFIG_ETHER_ON_FEC || CONFIG_ETHER_ON_FEC2 */
diff --git a/include/configs/EB+MCF-EV123.h b/include/configs/EB+MCF-EV123.h index ea49a5d..5ba7585 100644 --- a/include/configs/EB+MCF-EV123.h +++ b/include/configs/EB+MCF-EV123.h @@ -88,6 +88,7 @@ #ifdef CONFIG_MCFFEC # define CONFIG_NET_MULTI 1 # define CONFIG_MII 1 +# define CONFIG_MII_INIT 1 # define CFG_DISCOVER_PHY # define CFG_RX_ETH_BUFFER 8 # define CFG_FAULT_ECHO_LINK_DOWN diff --git a/include/configs/EP88x.h b/include/configs/EP88x.h index 89e0eeb..c2ab18a 100644 --- a/include/configs/EP88x.h +++ b/include/configs/EP88x.h @@ -42,6 +42,7 @@ #define CONFIG_ETHER_ON_FEC2 /* Enable Ethernet on FEC2 */ #if defined(CONFIG_ETHER_ON_FEC1) || defined(CONFIG_ETHER_ON_FEC2) #define CFG_DISCOVER_PHY +#define CONFIG_MII_INIT 1 #define FEC_ENET #endif /* CONFIG_FEC_ENET */
diff --git a/include/configs/GEN860T.h b/include/configs/GEN860T.h index 3eb3131..c8b5a6d 100644 --- a/include/configs/GEN860T.h +++ b/include/configs/GEN860T.h @@ -147,6 +147,7 @@ #define CONFIG_FEC_ENET #define CFG_DISCOVER_PHY #define CONFIG_MII +#define CONFIG_MII_INIT 1 #define CONFIG_PHY_ADDR 0
/* diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index 3b4bff3..3ee2b39 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -77,6 +77,7 @@ #ifdef CONFIG_MCFFEC # define CONFIG_NET_MULTI 1 # define CONFIG_MII 1 +# define CONFIG_MII_INIT 1 # define CFG_DISCOVER_PHY # define CFG_RX_ETH_BUFFER 8 # define CFG_FAULT_ECHO_LINK_DOWN diff --git a/include/configs/M5271EVB.h b/include/configs/M5271EVB.h index 47e1e03..e1cc720 100644 --- a/include/configs/M5271EVB.h +++ b/include/configs/M5271EVB.h @@ -88,6 +88,7 @@ #ifdef CONFIG_MCFFEC # define CONFIG_NET_MULTI 1 # define CONFIG_MII 1 +# define CONFIG_MII_INIT 1 # define CFG_DISCOVER_PHY # define CFG_RX_ETH_BUFFER 8 # define CFG_FAULT_ECHO_LINK_DOWN diff --git a/include/configs/M5275EVB.h b/include/configs/M5275EVB.h index 599f8dc..283c873 100644 --- a/include/configs/M5275EVB.h +++ b/include/configs/M5275EVB.h @@ -89,6 +89,7 @@ #ifdef CONFIG_MCFFEC #define CONFIG_NET_MULTI 1 #define CONFIG_MII 1 +#define CONFIG_MII_INIT 1 #define CFG_DISCOVER_PHY #define CFG_RX_ETH_BUFFER 8 #define CFG_FAULT_ECHO_LINK_DOWN diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index 7bb9f60..826778c 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -75,6 +75,7 @@ #ifdef CONFIG_MCFFEC # define CONFIG_NET_MULTI 1 # define CONFIG_MII 1 +# define CONFIG_MII_INIT 1 # define CFG_DISCOVER_PHY # define CFG_RX_ETH_BUFFER 8 # define CFG_FAULT_ECHO_LINK_DOWN diff --git a/include/configs/M5329EVB.h b/include/configs/M5329EVB.h index 1a15c77..42692d6 100644 --- a/include/configs/M5329EVB.h +++ b/include/configs/M5329EVB.h @@ -70,6 +70,7 @@ #ifdef CONFIG_MCFFEC # define CONFIG_NET_MULTI 1 # define CONFIG_MII 1 +# define CONFIG_MII_INIT 1 # define CFG_DISCOVER_PHY # define CFG_RX_ETH_BUFFER 8 # define CFG_FAULT_ECHO_LINK_DOWN diff --git a/include/configs/M5373EVB.h b/include/configs/M5373EVB.h index da4156c..3b9da17 100644 --- a/include/configs/M5373EVB.h +++ b/include/configs/M5373EVB.h @@ -70,6 +70,7 @@ #ifdef CONFIG_MCFFEC # define CONFIG_NET_MULTI 1 # define CONFIG_MII 1 +# define CONFIG_MII_INIT 1 # define CFG_DISCOVER_PHY # define CFG_RX_ETH_BUFFER 8 # define CFG_FAULT_ECHO_LINK_DOWN diff --git a/include/configs/M54455EVB.h b/include/configs/M54455EVB.h index a3c71e3..3a022af 100644 --- a/include/configs/M54455EVB.h +++ b/include/configs/M54455EVB.h @@ -83,9 +83,9 @@ /* Network configuration */ #define CONFIG_MCFFEC #ifdef CONFIG_MCFFEC -# define CONFIG_NET_MULTI 1 +# define CONFIG_NET_MULTI 1 # define CONFIG_MII 1 -# define CONFIG_CF_DOMII +# define CONFIG_MII_INIT 1 # define CFG_DISCOVER_PHY # define CFG_RX_ETH_BUFFER 8 # define CFG_FAULT_ECHO_LINK_DOWN diff --git a/include/configs/M5475EVB.h b/include/configs/M5475EVB.h index a4e6c5d..6bb4619 100644 --- a/include/configs/M5475EVB.h +++ b/include/configs/M5475EVB.h @@ -69,6 +69,7 @@ #ifdef CONFIG_FSLDMAFEC # define CONFIG_NET_MULTI 1 # define CONFIG_MII 1 +# define CONFIG_MII_INIT 1 # define CONFIG_HAS_ETH1
# define CFG_DISCOVER_PHY diff --git a/include/configs/M5485EVB.h b/include/configs/M5485EVB.h index 9121023..cba51c8 100644 --- a/include/configs/M5485EVB.h +++ b/include/configs/M5485EVB.h @@ -69,6 +69,7 @@ #ifdef CONFIG_FSLDMAFEC # define CONFIG_NET_MULTI 1 # define CONFIG_MII 1 +# define CONFIG_MII_INIT 1 # define CONFIG_HAS_ETH1
# define CFG_DISCOVER_PHY diff --git a/include/configs/NETPHONE.h b/include/configs/NETPHONE.h index bb3d19d..e3c6fd3 100644 --- a/include/configs/NETPHONE.h +++ b/include/configs/NETPHONE.h @@ -101,6 +101,7 @@ #define FEC_ENET 1 /* eth.c needs it that way... */ #undef CFG_DISCOVER_PHY #define CONFIG_MII 1 +#define CONFIG_MII_INIT 1 #define CONFIG_RMII 1 /* use RMII interface */
#define CONFIG_ETHER_ON_FEC1 1 diff --git a/include/configs/NETTA.h b/include/configs/NETTA.h index 945f47f..20404a3 100644 --- a/include/configs/NETTA.h +++ b/include/configs/NETTA.h @@ -97,6 +97,7 @@ #define FEC_ENET 1 /* eth.c needs it that way... */ #undef CFG_DISCOVER_PHY /* do not discover phys */ #define CONFIG_MII 1 +#define CONFIG_MII_INIT 1 #define CONFIG_RMII 1 /* use RMII interface */
#if defined(CONFIG_NETTA_ISDN) diff --git a/include/configs/NETTA2.h b/include/configs/NETTA2.h index fb8085d..cf66e04 100644 --- a/include/configs/NETTA2.h +++ b/include/configs/NETTA2.h @@ -102,6 +102,7 @@ #define FEC_ENET 1 /* eth.c needs it that way... */ #undef CFG_DISCOVER_PHY #define CONFIG_MII 1 +#define CONFIG_MII_INIT 1 #define CONFIG_RMII 1 /* use RMII interface */
#define CONFIG_ETHER_ON_FEC1 1 diff --git a/include/configs/TK885D.h b/include/configs/TK885D.h index 50f1c63..7310abf 100644 --- a/include/configs/TK885D.h +++ b/include/configs/TK885D.h @@ -510,6 +510,8 @@ #define CONFIG_FEC2_PHY 2 #endif
+#define CONFIG_MII_INIT 1 + #define CONFIG_NET_RETRY_COUNT 3 #define CONFIG_ETHPRIME "FEC ETHERNET"
diff --git a/include/configs/TOP860.h b/include/configs/TOP860.h index 66f7a11..8237ba1 100644 --- a/include/configs/TOP860.h +++ b/include/configs/TOP860.h @@ -205,6 +205,7 @@ #define FEC_ENET 1 /* eth.c needs it that way... */ #define CFG_DISCOVER_PHY 1 #define CONFIG_MII 1 +#define CONFIG_MII_INIT 1 #define CONFIG_PHY_ADDR 31
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM885D.h b/include/configs/TQM885D.h index a254bcd..f075442 100644 --- a/include/configs/TQM885D.h +++ b/include/configs/TQM885D.h @@ -497,6 +497,7 @@
#if defined(CONFIG_CMD_MII) #define CFG_DISCOVER_PHY +#define CONFIG_MII_INIT 1 #endif
#define CONFIG_NET_RETRY_COUNT 1 /* reduce max. timeout before diff --git a/include/configs/cobra5272.h b/include/configs/cobra5272.h index 104d94e..c7e3899 100644 --- a/include/configs/cobra5272.h +++ b/include/configs/cobra5272.h @@ -158,6 +158,7 @@ #ifdef CONFIG_MCFFEC # define CONFIG_NET_MULTI 1 # define CONFIG_MII 1 +# define CONFIG_MII_INIT 1 # define CFG_DISCOVER_PHY # define CFG_RX_ETH_BUFFER 8 # define CFG_FAULT_ECHO_LINK_DOWN diff --git a/include/configs/idmr.h b/include/configs/idmr.h index a15f69a..2ed51f7 100644 --- a/include/configs/idmr.h +++ b/include/configs/idmr.h @@ -156,7 +156,8 @@ #define CONFIG_MCFFEC #ifdef CONFIG_MCFFEC # define CONFIG_NET_MULTI 1 -#define CONFIG_MII 1 +# define CONFIG_MII 1 +# define CONFIG_MII_INIT 1 # define CFG_DISCOVER_PHY # define CFG_RX_ETH_BUFFER 8 # define CFG_FAULT_ECHO_LINK_DOWN diff --git a/include/configs/spc1920.h b/include/configs/spc1920.h index 2efc8f1..729f3c0 100644 --- a/include/configs/spc1920.h +++ b/include/configs/spc1920.h @@ -31,6 +31,7 @@ #undef CONFIG_8xx_CONS_NONE
#define CONFIG_MII +#define CONFIG_MII_INIT 1 #undef CONFIG_ETHER_ON_FEC1 #define CONFIG_ETHER_ON_FEC2 #define FEC_ENET diff --git a/include/configs/stxxtc.h b/include/configs/stxxtc.h index f12765d..a3ab798 100644 --- a/include/configs/stxxtc.h +++ b/include/configs/stxxtc.h @@ -97,6 +97,7 @@ #define FEC_ENET 1 /* eth.c needs it that way... */ #undef CFG_DISCOVER_PHY #define CONFIG_MII 1 +#define CONFIG_MII_INIT 1 #undef CONFIG_RMII
#define CONFIG_ETHER_ON_FEC1 1 diff --git a/include/configs/uc100.h b/include/configs/uc100.h index c1c2e03..3c2de40 100644 --- a/include/configs/uc100.h +++ b/include/configs/uc100.h @@ -510,6 +510,7 @@ #define CONFIG_FEC_ENET 1 /* use FEC ethernet */ #define FEC_ENET #define CONFIG_MII +#define CONFIG_MII_INIT 1 #define CFG_DISCOVER_PHY 1
#endif /* __CONFIG_H */
Acked-by: Ben Warren biggerbadderben@gmail.com
Wolfgang - This patch depends on code that is in the net tree, but I can't pull it in because it contains files that the net tree doesn't know about.
regards, Ben
In message 1206858133-18090-1-git-send-email-Tsi-Chung.Liew@freescale.com you wrote:
Applied, thanks.
Viele Grüße,
Ben Warren
Tsi-Chung Liew
