[U-Boot] Fw: Make Menuconfig Error
To: Duncan Hare dh@synoia.com Cc: U-Boot Mailing List u-boot@lists.denx.de Sent: Wednesday, June 20, 2018 2:16 PM Subject: Re: Make Menuconfig Error
On Wed, Jun 20, 2018 at 12:33:45AM +0000, Duncan Hare wrote:
Makefile:491: recipe for target 'menuconfig' failed make: *** [menuconfig] Error 2 root@debian:/home/duncan/archive/u-boot#>>>>The problem is the same on Raspbian and Debian. Client Raspbian mounts the repository through NFS. Debian is the server.
This test was run on the server.>
I'm sorry but I cannot reproduce your problem. I don't have access to a Raspbian/stable installation, but I have run the same steps on a Debian/stable for armhf (which should be close enough as Raspbian/stable is largely an armv6 build of the Debian/stable package sources) and on a Debian/stable amd64 system. In both cases everything builds without problems:
therefore tend to believe that something in your local repository checkout is broken. Please run a "git reset --hard master; git pull; git status; git log| head -1; make distclean; make menuconfig" and provide the resulting output.
I deleted the git archive and cloned again. git clone git://git.denx.de/u-boot.git duncan@debian:~/archive$ git clone git://git.denx.de/u-boot.git Cloning into 'u-boot'... remote: Counting objects: 559784, done. remote: Compressing objects: 100% (97184/97184), done. remote: Total 559784 (delta 462603), reused 551414 (delta 454519) Receiving objects: 100% (559784/559784), 113.77 MiB | 32.00 KiB/s, done. Resolving deltas: 100% (462603/462603), done. duncan@debian:~/archive$ cd u-boot duncan@debian:~/archive/u-boot$ make clean duncan@debian:~/archive/u-boot$ make menuconfig HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/mconf.o YACC scripts/kconfig/zconf.tab.c scripts/kconfig/zconf.y:44 parser name defined to default :"parse" "scripts/kconfig/zconf.y", line 97: junk after `%%' in definition section Segmentation fault scripts/Makefile.lib:228: recipe for target 'scripts/kconfig/zconf.tab.c' failed make[1]: *** [scripts/kconfig/zconf.tab.c] Error 139 Makefile:491: recipe for target 'menuconfig' failed make: *** [menuconfig] Error 2 duncan@debian:~/archive/u-boot$
Now the set of git commands you providedduncan@debian:~/archive/u-boot$ git reset --hard HEAD is now at a5742efa20 Prepare v2018.07-rc2 duncan@debian:~/archive/u-boot$ git reset --hard master HEAD is now at a5742efa20 Prepare v2018.07-rc2 duncan@debian:~/archive/u-boot$ git pull Already up-to-date. duncan@debian:~/archive/u-boot$ git status On branch master Your branch is up-to-date with 'origin/master'. nothing to commit, working tree clean duncan@debian:~/archive/u-boot$ git log | head -1 commit a5742efa20384a27d51ee6c43d02c2025536c65d duncan@debian:~/archive/u-boot$ make distclean CLEAN scripts/basic duncan@debian:~/archive/u-boot$ make menuconfig HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/mconf.o YACC scripts/kconfig/zconf.tab.c scripts/kconfig/zconf.y:44 parser name defined to default :"parse" "scripts/kconfig/zconf.y", line 97: junk after `%%' in definition section Segmentation fault scripts/Makefile.lib:228: recipe for target 'scripts/kconfig/zconf.tab.c' failed make[1]: *** [scripts/kconfig/zconf.tab.c] Error 139 Makefile:491: recipe for target 'menuconfig' failed make: *** [menuconfig] Error 2 duncan@debian:~/archive/u-boot$
this looks questionable:scripts/kconfig/zconf.y:44 parser name defined to default :"parse" "scripts/kconfig/zconf.y", line 97: junk after `%%' in definition section
Debian version
duncan@debian:~/archive/u-boot$ cat /etc/debian_version 9.4 Should I redo the debian image?
Duncan Hare
