[U-Boot] [PATCH 0/3] Ethernet support for QEMU sifive_u machine
This patchset enables Cadance MACB ethernet driver for QEMU sifive_u machine. The Cadance MACB ethernet driver works fine for QEMU sifive_u machince in both M-mode and S-mode with some minor fixes.
The patches are based upon latest RISC-V U-Boot tree (git://git.denx.de/u-boot-riscv.git) at commit id 9deb8d2fcd13d4a40a4e63c396fe4376af46efac
To try on QEMU, please ensure following patches are applied to QEMU sources: https://patchwork.kernel.org/patch/10729579/ https://patchwork.kernel.org/patch/10729581/
Anup Patel (3): riscv: Add asm/dma-mapping.h for DMA mappings net: macb: Fix clk API usage for RISC-V systems riscv: qemu: Imply MACB ethernet for emulation
arch/riscv/include/asm/dma-mapping.h | 37 ++++++++++++++++++++++++++++ board/emulation/qemu-riscv/Kconfig | 4 +++ drivers/net/macb.c | 4 ++- 3 files changed, 44 insertions(+), 1 deletion(-) create mode 100644 arch/riscv/include/asm/dma-mapping.h
This patch adds asm/dma-mapping.h for Linux-like DMA mappings APIs required by some of the drivers (such as, Cadance MACB Ethernet driver).
Signed-off-by: Anup Patel anup.patel@wdc.com --- arch/riscv/include/asm/dma-mapping.h | 37 ++++++++++++++++++++++++++++ 1 file changed, 37 insertions(+) create mode 100644 arch/riscv/include/asm/dma-mapping.h
diff --git a/arch/riscv/include/asm/dma-mapping.h b/arch/riscv/include/asm/dma-mapping.h new file mode 100644 index 0000000000..9782b6f168 --- /dev/null +++ b/arch/riscv/include/asm/dma-mapping.h @@ -0,0 +1,37 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2018 Western Digital Corporation or its affiliates. + * + * Authors: + * Anup Patel anup.patel@wdc.com + */ +#ifndef __ASM_RISCV_DMA_MAPPING_H +#define __ASM_RISCV_DMA_MAPPING_H + +#include <linux/dma-direction.h> + +#define dma_mapping_error(x, y) 0 + +static inline void *dma_alloc_coherent(size_t len, unsigned long *handle) +{ + *handle = (unsigned long)memalign(ARCH_DMA_MINALIGN, len); + return (void *)*handle; +} + +static inline void dma_free_coherent(void *addr) +{ + free(addr); +} + +static inline unsigned long dma_map_single(volatile void *vaddr, size_t len, + enum dma_data_direction dir) +{ + return (unsigned long)vaddr; +} + +static inline void dma_unmap_single(volatile void *vaddr, size_t len, + unsigned long paddr) +{ +} + +#endif /* __ASM_RISCV_DMA_MAPPING_H */
But please see nits below:
- Copyright (c) 2018 Western Digital Corporation or its affiliates.
- Authors:
- Anup Patel anup.patel@wdc.com
nits: should have one blank line here
nits: no <tab> between #define and dma_
free(addr);
Regards, Bin
- Authors:
OK, will update.
OK, will update.
free(addr);
Regards, Bin
Regards, Anup
+Michal
- Authors:
free(addr);
2.17.1
This patch does following fixes in MACB ethernet driver for using it on RISC-V systems (particularly QEMU sifive_u machine): 1. asm/arch/clk.h is not available on RISC-V port so include it only for non-RISC-V systems. 2. Don't fail in macb_enable_clk() if clk_enable() returns -ENOSYS because we get -ENOSYS for fixed-rate clocks.
Signed-off-by: Anup Patel anup.patel@wdc.com --- drivers/net/macb.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 94c89c762b..9a06b523cc 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -38,7 +38,9 @@ #include <linux/mii.h> #include <asm/io.h> #include <asm/dma-mapping.h> +#ifndef CONFIG_RISCV #include <asm/arch/clk.h> +#endif #include <linux/errno.h>
#include "macb.h" @@ -1066,7 +1068,7 @@ static int macb_enable_clk(struct udevice *dev) */ #ifndef CONFIG_MACB_ZYNQ ret = clk_enable(&clk); - if (ret) + if (ret && ret != -ENOSYS) return ret; #endif
- asm/arch/clk.h is not available on RISC-V port so include it only for non-RISC-V systems.
- Don't fail in macb_enable_clk() if clk_enable() returns -ENOSYS because we get -ENOSYS for fixed-rate clocks.
But please see comments below:
I suspect this "#ifndef CONFIG_MACB_ZYNQ" can be removed per the comments below, with the adding check of (ret != -ENOSYS).
/* * Zynq clock driver didn't support for enable or disable * clock. Hence, clk_enable() didn't apply for Zynq */
Someone else who has access to Zynq targets need to confirm.
if (ret)
#endif
Regards, Bin
- Zynq clock driver didn't support for enable or disable
- clock. Hence, clk_enable() didn't apply for Zynq
I think let someone with Zynq SOC based board remove this.
Regards, Anup
This patch enables Cadence MACB ethernet driver for QEMU RISC-V emulation by implying MACB, MII, RGMII and NET_RANDOM_ETHADDR on BOARD_SPECIFIC_OPTIONS.
Signed-off-by: Anup Patel anup.patel@wdc.com --- board/emulation/qemu-riscv/Kconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/emulation/qemu-riscv/Kconfig b/board/emulation/qemu-riscv/Kconfig index 0d865acf10..5d9611bdc7 100644 --- a/board/emulation/qemu-riscv/Kconfig +++ b/board/emulation/qemu-riscv/Kconfig @@ -34,5 +34,9 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply BOARD_LATE_INIT imply OF_BOARD_SETUP imply SIFIVE_SERIAL + imply MACB + imply RGMII + imply MII + imply NET_RANDOM_ETHADDR
endif
Hi Anup,
What "-device " parameter should I tell QEMU to instantiate the MACB? "-device ?" does not give me anything that looks like MACB. Without a proper "-device " parameter, I can boot U-Boot on QEMU sifive_u and see U-Boot driver is probed, but a simple 'ping' test does not work.
Regards, Bin
On Tue, Dec 18, 2018 at 3:21 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Anup,
Try the following: # setenv ipaddr 10.0.2.1 # ping 10.0.2.2
The above works for me on QEMU.
Regards, Anup
Hi Anup,
Hi Anup,
Yes, I have set up all the required network parameters.
My understanding is that we need enable QEMU network via "-netdev " (either usr, or tap), with a corresponding "-device". I don't know how to set it up. What's your command line to test this?
Regards, Bin
On Tue, Dec 18, 2018 at 4:06 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Anup,
Hi Anup,
"-netdev" or "-device" parameters are not mandatory. By default, virtual NICs are in NAT mode. The QEMU NAT gateway is at IP address 10.0.2.2. We can always ping the NAT gateway when virtual NIC is in NAT mode.
Here's how I compile for M-mode: # ARCH=riscv # CROSS_COMPILE=riscv64-unknown-linux-gnu- # make qemu-riscv64_defconfig # make
My U-boot log is as follows:
anup@anup-ubuntu64:~/Work/riscv-test/u-boot$ qemu-system-riscv64 -M sifive_u -m 256M -display none -serial stdio -kernel ./u-boot
U-Boot 2019.01-rc1-00948-ge6b3cdafd0 (Dec 19 2018 - 10:05:50 +0530)
CPU: rv64imafdcsu Model: ucbbar,spike-bare,qemu DRAM: 256 MiB In: uart@10013000 Out: uart@10013000 Err: uart@10013000 Net: Warning: ethernet@100900fc (eth0) using random MAC address - f6:1f:8c:13:83:c0 eth0: ethernet@100900fc Hit any key to stop autoboot: 0
Device 0: unknown device ethernet@100900fc: PHY present at 0 ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) BOOTP broadcast 1 DHCP client bound to address 10.0.2.15 (2 ms) Using ethernet@100900fc device TFTP from server 10.0.2.2; our IP address is 10.0.2.15 Filename 'boot.scr.uimg'. Load address: 0x82100000 Loading: * TFTP error: 'Access violation' (2) Not retrying... ethernet@100900fc: PHY present at 0 ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) BOOTP broadcast 1 DHCP client bound to address 10.0.2.15 (1 ms) Using ethernet@100900fc device TFTP from server 10.0.2.2; our IP address is 10.0.2.15 Filename 'boot.scr.uimg'. Load address: 0x81000000 Loading: * TFTP error: 'Access violation' (2) Not retrying... => ping 10.0.2.2 ethernet@100900fc: PHY present at 0 ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) Using ethernet@100900fc device host 10.0.2.2 is alive => ethernet@100900fc: PHY present at 0 ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) Using ethernet@100900fc device host 10.0.2.2 is alive => qemu-system-riscv64: terminating on signal 2
Regards, Anup
Hi Anup,
Hi Anup,
Hi Anup,
I have always been using "qemu-system-riscv64 -nographic -M sifive_u -kernel u-boot" to test U-Boot on qemu risc-v. With above command, I can "ping 10.0.2.2" and get the exact the same result as yours.
However I wanted to connect the tap interface to the emulated network controller for testing, that's why I wanted to use "-device" and "-netdev", but I don't know which device string I need to tell QEMU. After a bit googleing I got the following page: https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Zynq-QEMU-Netw...
From the page it looks that the device should be "-device
cadence_gem", but when I pass it to QEMU I got:
qemu-system-riscv64: -device cadence_gem,netdev=net0: Parameter 'driver' expects pluggable device type
It looks cadence_gem is not a pluggable device. Any ideas?
Regards, Bin
On Wed, Dec 19, 2018 at 11:02 AM Bin Meng bmeng.cn@gmail.com wrote:
Hi Anup,
Hi Anup,
Hi Anup,
From the page it looks that the device should be "-device cadence_gem", but when I pass it to QEMU I got:
I have mostly tried TAP devices with VirtIO-Net. I believe this could be some bug in Cadence GEM emulation of QEMU.
Regards, Anup
Hi Anup,
Hi Anup,
Hi Anup,
Hi Anup,
On Mon, Dec 17, 2018 at 7:51 PM Anup Patel anup@brainfault.org wrote: > > This patchset enables Cadance MACB ethernet driver for > QEMU sifive_u machine. The Cadance MACB ethernet driver > works fine for QEMU sifive_u machince in both M-mode and > S-mode with some minor fixes. > > The patches are based upon latest RISC-V U-Boot tree > (git://git.denx.de/u-boot-riscv.git) at commit id > 9deb8d2fcd13d4a40a4e63c396fe4376af46efac > > To try on QEMU, please ensure following patches are > applied to QEMU sources: > https://patchwork.kernel.org/patch/10729579/ > https://patchwork.kernel.org/patch/10729581/ >
I managed to get tap interface connected to the cadence_gem controller. The QEMU command line is "qemu-system-riscv64 -nographic -M sifive_u -kernel u-boot -nic tap,model=cadence_gem"
A single "ping" works after I set related network environments in the shell. But "tftp" test fails. It looks the driver just time out.
=> tftp 84000000 bmeng/uImage.riscv ethernet@100900fc: PHY present at 0 ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) Using ethernet@100900fc device TFTP from server 10.10.0.100; our IP address is 10.10.0.108 Filename 'bmeng/uImage.riscv'. Load address: 0x84000000 Loading: #T T #T T #T #T T #T #T T # Retry count exceeded; starting again
Can you please take a look?
Regards, Bin
Hi Anup,
On Wed, Dec 19, 2018 at 5:05 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Anup,
Hi Anup,
Hi Anup,
On Tue, Dec 18, 2018 at 3:21 PM Bin Meng bmeng.cn@gmail.com wrote: > > Hi Anup, > > On Mon, Dec 17, 2018 at 7:51 PM Anup Patel anup@brainfault.org wrote: > > > > This patchset enables Cadance MACB ethernet driver for > > QEMU sifive_u machine. The Cadance MACB ethernet driver > > works fine for QEMU sifive_u machince in both M-mode and > > S-mode with some minor fixes. > > > > The patches are based upon latest RISC-V U-Boot tree > > (git://git.denx.de/u-boot-riscv.git) at commit id > > 9deb8d2fcd13d4a40a4e63c396fe4376af46efac > > > > To try on QEMU, please ensure following patches are > > applied to QEMU sources: > > https://patchwork.kernel.org/patch/10729579/ > > https://patchwork.kernel.org/patch/10729581/ > > > > What "-device " parameter should I tell QEMU to instantiate the MACB? > "-device ?" does not give me anything that looks like MACB. Without a > proper "-device " parameter, I can boot U-Boot on QEMU sifive_u and > see U-Boot driver is probed, but a simple 'ping' test does not work.
Any idea about the timeouts?
Regards, Bin
On Mon, Dec 24, 2018 at 6:59 AM Bin Meng bmeng.cn@gmail.com wrote:
Hi Anup,
Hi Anup,
Hi Anup,
Hi Anup,
On Tue, Dec 18, 2018 at 6:33 PM Anup Patel anup@brainfault.org wrote: > > On Tue, Dec 18, 2018 at 3:21 PM Bin Meng bmeng.cn@gmail.com wrote: > > > > Hi Anup, > > > > On Mon, Dec 17, 2018 at 7:51 PM Anup Patel anup@brainfault.org wrote: > > > > > > This patchset enables Cadance MACB ethernet driver for > > > QEMU sifive_u machine. The Cadance MACB ethernet driver > > > works fine for QEMU sifive_u machince in both M-mode and > > > S-mode with some minor fixes. > > > > > > The patches are based upon latest RISC-V U-Boot tree > > > (git://git.denx.de/u-boot-riscv.git) at commit id > > > 9deb8d2fcd13d4a40a4e63c396fe4376af46efac > > > > > > To try on QEMU, please ensure following patches are > > > applied to QEMU sources: > > > https://patchwork.kernel.org/patch/10729579/ > > > https://patchwork.kernel.org/patch/10729581/ > > > > > > > What "-device " parameter should I tell QEMU to instantiate the MACB? > > "-device ?" does not give me anything that looks like MACB. Without a > > proper "-device " parameter, I can boot U-Boot on QEMU sifive_u and > > see U-Boot driver is probed, but a simple 'ping' test does not work. > > Try the following: > # setenv ipaddr 10.0.2.1 > # ping 10.0.2.2 >
Sorry, I got busy with other stuff.
I think this is specific to QEMU environment. The ethernet driver also few udelay calls which can further slow things down.
From your log it seems that, it is working functionally but you
are seeing too many timeouts. Try playing with "TIMEOUT" or "TIMEOUT_COUNT" in net/tftp.c
You can also try same thing over VirtIO net of QEMU virt machine.
Regards, Anup
Hi Anup,
Hi Anup,
Hi Anup,
Hi Anup,
On Tue, Dec 18, 2018 at 4:06 PM Bin Meng bmeng.cn@gmail.com wrote: > > Hi Anup, > > On Tue, Dec 18, 2018 at 6:33 PM Anup Patel anup@brainfault.org wrote: > > > > On Tue, Dec 18, 2018 at 3:21 PM Bin Meng bmeng.cn@gmail.com wrote: > > > > > > Hi Anup, > > > > > > On Mon, Dec 17, 2018 at 7:51 PM Anup Patel anup@brainfault.org wrote: > > > > > > > > This patchset enables Cadance MACB ethernet driver for > > > > QEMU sifive_u machine. The Cadance MACB ethernet driver > > > > works fine for QEMU sifive_u machince in both M-mode and > > > > S-mode with some minor fixes. > > > > > > > > The patches are based upon latest RISC-V U-Boot tree > > > > (git://git.denx.de/u-boot-riscv.git) at commit id > > > > 9deb8d2fcd13d4a40a4e63c396fe4376af46efac > > > > > > > > To try on QEMU, please ensure following patches are > > > > applied to QEMU sources: > > > > https://patchwork.kernel.org/patch/10729579/ > > > > https://patchwork.kernel.org/patch/10729581/ > > > > > > > > > > What "-device " parameter should I tell QEMU to instantiate the MACB? > > > "-device ?" does not give me anything that looks like MACB. Without a > > > proper "-device " parameter, I can boot U-Boot on QEMU sifive_u and > > > see U-Boot driver is probed, but a simple 'ping' test does not work. > > > > Try the following: > > # setenv ipaddr 10.0.2.1 > > # ping 10.0.2.2 > > > > Yes, I have set up all the required network parameters. > > > The above works for me on QEMU. > > My understanding is that we need enable QEMU network via "-netdev " > (either usr, or tap), with a corresponding "-device". I don't know how > to set it up. What's your command line to test this? >
From your log it seems that, it is working functionally but you are seeing too many timeouts. Try playing with "TIMEOUT" or "TIMEOUT_COUNT" in net/tftp.c
I suspect there are some issues with the MACB driver to be used with RISC-V.
The default same settings with VirtIO net interface works like a charm.
Regards, Bin
On Mon, Dec 24, 2018 at 12:01 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Anup,
Hi Anup,
Hi Anup,
Hi Anup,
On Wed, Dec 19, 2018 at 12:41 PM Anup Patel anup@brainfault.org wrote: > > On Tue, Dec 18, 2018 at 4:06 PM Bin Meng bmeng.cn@gmail.com wrote: > > > > Hi Anup, > > > > On Tue, Dec 18, 2018 at 6:33 PM Anup Patel anup@brainfault.org wrote: > > > > > > On Tue, Dec 18, 2018 at 3:21 PM Bin Meng bmeng.cn@gmail.com wrote: > > > > > > > > Hi Anup, > > > > > > > > On Mon, Dec 17, 2018 at 7:51 PM Anup Patel anup@brainfault.org wrote: > > > > > > > > > > This patchset enables Cadance MACB ethernet driver for > > > > > QEMU sifive_u machine. The Cadance MACB ethernet driver > > > > > works fine for QEMU sifive_u machince in both M-mode and > > > > > S-mode with some minor fixes. > > > > > > > > > > The patches are based upon latest RISC-V U-Boot tree > > > > > (git://git.denx.de/u-boot-riscv.git) at commit id > > > > > 9deb8d2fcd13d4a40a4e63c396fe4376af46efac > > > > > > > > > > To try on QEMU, please ensure following patches are > > > > > applied to QEMU sources: > > > > > https://patchwork.kernel.org/patch/10729579/ > > > > > https://patchwork.kernel.org/patch/10729581/ > > > > > > > > > > > > > What "-device " parameter should I tell QEMU to instantiate the MACB? > > > > "-device ?" does not give me anything that looks like MACB. Without a > > > > proper "-device " parameter, I can boot U-Boot on QEMU sifive_u and > > > > see U-Boot driver is probed, but a simple 'ping' test does not work. > > > > > > Try the following: > > > # setenv ipaddr 10.0.2.1 > > > # ping 10.0.2.2 > > > > > > > Yes, I have set up all the required network parameters. > > > > > The above works for me on QEMU. > > > > My understanding is that we need enable QEMU network via "-netdev " > > (either usr, or tap), with a corresponding "-device". I don't know how > > to set it up. What's your command line to test this? > > > > "-netdev" or "-device" parameters are not mandatory. By default, virtual > NICs are in NAT mode. The QEMU NAT gateway is at IP address > 10.0.2.2. We can always ping the NAT gateway when virtual NIC is in > NAT mode. > > Here's how I compile for M-mode: > # ARCH=riscv > # CROSS_COMPILE=riscv64-unknown-linux-gnu- > # make qemu-riscv64_defconfig > # make > > My U-boot log is as follows: > > anup@anup-ubuntu64:~/Work/riscv-test/u-boot$ qemu-system-riscv64 -M > sifive_u -m 256M -display none -serial stdio -kernel ./u-boot > > > U-Boot 2019.01-rc1-00948-ge6b3cdafd0 (Dec 19 2018 - 10:05:50 +0530) > > CPU: rv64imafdcsu > Model: ucbbar,spike-bare,qemu > DRAM: 256 MiB > In: uart@10013000 > Out: uart@10013000 > Err: uart@10013000 > Net: > Warning: ethernet@100900fc (eth0) using random MAC address - f6:1f:8c:13:83:c0 > eth0: ethernet@100900fc > Hit any key to stop autoboot: 0 > > Device 0: unknown device > ethernet@100900fc: PHY present at 0 > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > BOOTP broadcast 1 > DHCP client bound to address 10.0.2.15 (2 ms) > Using ethernet@100900fc device > TFTP from server 10.0.2.2; our IP address is 10.0.2.15 > Filename 'boot.scr.uimg'. > Load address: 0x82100000 > Loading: * > TFTP error: 'Access violation' (2) > Not retrying... > ethernet@100900fc: PHY present at 0 > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > BOOTP broadcast 1 > DHCP client bound to address 10.0.2.15 (1 ms) > Using ethernet@100900fc device > TFTP from server 10.0.2.2; our IP address is 10.0.2.15 > Filename 'boot.scr.uimg'. > Load address: 0x81000000 > Loading: * > TFTP error: 'Access violation' (2) > Not retrying... > => ping 10.0.2.2 > ethernet@100900fc: PHY present at 0 > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > Using ethernet@100900fc device > host 10.0.2.2 is alive > => > ethernet@100900fc: PHY present at 0 > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > Using ethernet@100900fc device > host 10.0.2.2 is alive > => qemu-system-riscv64: terminating on signal 2 >
Unlikely because Microsemi folks seems to use it on HiFive Unleashed board. https://github.com/Microsemi-SoC-IP/HiFive_U-Boot
We are still debugging on HiFive Unleashed board so stay tuned for more patches.
Regards, Anup
Hi Anup,
Hi Anup,
Hi Anup,
Hi Anup,
On Wed, Dec 19, 2018 at 11:02 AM Bin Meng bmeng.cn@gmail.com wrote: > > Hi Anup, > > On Wed, Dec 19, 2018 at 12:41 PM Anup Patel anup@brainfault.org wrote: > > > > On Tue, Dec 18, 2018 at 4:06 PM Bin Meng bmeng.cn@gmail.com wrote: > > > > > > Hi Anup, > > > > > > On Tue, Dec 18, 2018 at 6:33 PM Anup Patel anup@brainfault.org wrote: > > > > > > > > On Tue, Dec 18, 2018 at 3:21 PM Bin Meng bmeng.cn@gmail.com wrote: > > > > > > > > > > Hi Anup, > > > > > > > > > > On Mon, Dec 17, 2018 at 7:51 PM Anup Patel anup@brainfault.org wrote: > > > > > > > > > > > > This patchset enables Cadance MACB ethernet driver for > > > > > > QEMU sifive_u machine. The Cadance MACB ethernet driver > > > > > > works fine for QEMU sifive_u machince in both M-mode and > > > > > > S-mode with some minor fixes. > > > > > > > > > > > > The patches are based upon latest RISC-V U-Boot tree > > > > > > (git://git.denx.de/u-boot-riscv.git) at commit id > > > > > > 9deb8d2fcd13d4a40a4e63c396fe4376af46efac > > > > > > > > > > > > To try on QEMU, please ensure following patches are > > > > > > applied to QEMU sources: > > > > > > https://patchwork.kernel.org/patch/10729579/ > > > > > > https://patchwork.kernel.org/patch/10729581/ > > > > > > > > > > > > > > > > What "-device " parameter should I tell QEMU to instantiate the MACB? > > > > > "-device ?" does not give me anything that looks like MACB. Without a > > > > > proper "-device " parameter, I can boot U-Boot on QEMU sifive_u and > > > > > see U-Boot driver is probed, but a simple 'ping' test does not work. > > > > > > > > Try the following: > > > > # setenv ipaddr 10.0.2.1 > > > > # ping 10.0.2.2 > > > > > > > > > > Yes, I have set up all the required network parameters. > > > > > > > The above works for me on QEMU. > > > > > > My understanding is that we need enable QEMU network via "-netdev " > > > (either usr, or tap), with a corresponding "-device". I don't know how > > > to set it up. What's your command line to test this? > > > > > > > "-netdev" or "-device" parameters are not mandatory. By default, virtual > > NICs are in NAT mode. The QEMU NAT gateway is at IP address > > 10.0.2.2. We can always ping the NAT gateway when virtual NIC is in > > NAT mode. > > > > Here's how I compile for M-mode: > > # ARCH=riscv > > # CROSS_COMPILE=riscv64-unknown-linux-gnu- > > # make qemu-riscv64_defconfig > > # make > > > > My U-boot log is as follows: > > > > anup@anup-ubuntu64:~/Work/riscv-test/u-boot$ qemu-system-riscv64 -M > > sifive_u -m 256M -display none -serial stdio -kernel ./u-boot > > > > > > U-Boot 2019.01-rc1-00948-ge6b3cdafd0 (Dec 19 2018 - 10:05:50 +0530) > > > > CPU: rv64imafdcsu > > Model: ucbbar,spike-bare,qemu > > DRAM: 256 MiB > > In: uart@10013000 > > Out: uart@10013000 > > Err: uart@10013000 > > Net: > > Warning: ethernet@100900fc (eth0) using random MAC address - f6:1f:8c:13:83:c0 > > eth0: ethernet@100900fc > > Hit any key to stop autoboot: 0 > > > > Device 0: unknown device > > ethernet@100900fc: PHY present at 0 > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > BOOTP broadcast 1 > > DHCP client bound to address 10.0.2.15 (2 ms) > > Using ethernet@100900fc device > > TFTP from server 10.0.2.2; our IP address is 10.0.2.15 > > Filename 'boot.scr.uimg'. > > Load address: 0x82100000 > > Loading: * > > TFTP error: 'Access violation' (2) > > Not retrying... > > ethernet@100900fc: PHY present at 0 > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > BOOTP broadcast 1 > > DHCP client bound to address 10.0.2.15 (1 ms) > > Using ethernet@100900fc device > > TFTP from server 10.0.2.2; our IP address is 10.0.2.15 > > Filename 'boot.scr.uimg'. > > Load address: 0x81000000 > > Loading: * > > TFTP error: 'Access violation' (2) > > Not retrying... > > => ping 10.0.2.2 > > ethernet@100900fc: PHY present at 0 > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > Using ethernet@100900fc device > > host 10.0.2.2 is alive > > => > > ethernet@100900fc: PHY present at 0 > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > Using ethernet@100900fc device > > host 10.0.2.2 is alive > > => qemu-system-riscv64: terminating on signal 2 > > > > I have always been using "qemu-system-riscv64 -nographic -M sifive_u > -kernel u-boot" to test U-Boot on qemu risc-v. > With above command, I can "ping 10.0.2.2" and get the exact the same > result as yours. > > However I wanted to connect the tap interface to the emulated network > controller for testing, that's why I wanted to use "-device" and > "-netdev", but I don't know which device string I need to tell QEMU. > After a bit googleing I got the following page: > https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Zynq-QEMU-Netw... > > From the page it looks that the device should be "-device > cadence_gem", but when I pass it to QEMU I got: > > qemu-system-riscv64: -device cadence_gem,netdev=net0: Parameter > 'driver' expects pluggable device type > > It looks cadence_gem is not a pluggable device. Any ideas?
It looks Microsemi's port is using the non-DM version of MACB driver while this series is using DM version. Something is wrong when working with QEMU's MACB controller.
Regards, Bin
On Mon, Dec 24, 2018 at 12:45 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Anup,
Hi Anup,
Hi Anup,
Hi Anup,
On Wed, Dec 19, 2018 at 2:32 PM Anup Patel anup@brainfault.org wrote: > > On Wed, Dec 19, 2018 at 11:02 AM Bin Meng bmeng.cn@gmail.com wrote: > > > > Hi Anup, > > > > On Wed, Dec 19, 2018 at 12:41 PM Anup Patel anup@brainfault.org wrote: > > > > > > On Tue, Dec 18, 2018 at 4:06 PM Bin Meng bmeng.cn@gmail.com wrote: > > > > > > > > Hi Anup, > > > > > > > > On Tue, Dec 18, 2018 at 6:33 PM Anup Patel anup@brainfault.org wrote: > > > > > > > > > > On Tue, Dec 18, 2018 at 3:21 PM Bin Meng bmeng.cn@gmail.com wrote: > > > > > > > > > > > > Hi Anup, > > > > > > > > > > > > On Mon, Dec 17, 2018 at 7:51 PM Anup Patel anup@brainfault.org wrote: > > > > > > > > > > > > > > This patchset enables Cadance MACB ethernet driver for > > > > > > > QEMU sifive_u machine. The Cadance MACB ethernet driver > > > > > > > works fine for QEMU sifive_u machince in both M-mode and > > > > > > > S-mode with some minor fixes. > > > > > > > > > > > > > > The patches are based upon latest RISC-V U-Boot tree > > > > > > > (git://git.denx.de/u-boot-riscv.git) at commit id > > > > > > > 9deb8d2fcd13d4a40a4e63c396fe4376af46efac > > > > > > > > > > > > > > To try on QEMU, please ensure following patches are > > > > > > > applied to QEMU sources: > > > > > > > https://patchwork.kernel.org/patch/10729579/ > > > > > > > https://patchwork.kernel.org/patch/10729581/ > > > > > > > > > > > > > > > > > > > What "-device " parameter should I tell QEMU to instantiate the MACB? > > > > > > "-device ?" does not give me anything that looks like MACB. Without a > > > > > > proper "-device " parameter, I can boot U-Boot on QEMU sifive_u and > > > > > > see U-Boot driver is probed, but a simple 'ping' test does not work. > > > > > > > > > > Try the following: > > > > > # setenv ipaddr 10.0.2.1 > > > > > # ping 10.0.2.2 > > > > > > > > > > > > > Yes, I have set up all the required network parameters. > > > > > > > > > The above works for me on QEMU. > > > > > > > > My understanding is that we need enable QEMU network via "-netdev " > > > > (either usr, or tap), with a corresponding "-device". I don't know how > > > > to set it up. What's your command line to test this? > > > > > > > > > > "-netdev" or "-device" parameters are not mandatory. By default, virtual > > > NICs are in NAT mode. The QEMU NAT gateway is at IP address > > > 10.0.2.2. We can always ping the NAT gateway when virtual NIC is in > > > NAT mode. > > > > > > Here's how I compile for M-mode: > > > # ARCH=riscv > > > # CROSS_COMPILE=riscv64-unknown-linux-gnu- > > > # make qemu-riscv64_defconfig > > > # make > > > > > > My U-boot log is as follows: > > > > > > anup@anup-ubuntu64:~/Work/riscv-test/u-boot$ qemu-system-riscv64 -M > > > sifive_u -m 256M -display none -serial stdio -kernel ./u-boot > > > > > > > > > U-Boot 2019.01-rc1-00948-ge6b3cdafd0 (Dec 19 2018 - 10:05:50 +0530) > > > > > > CPU: rv64imafdcsu > > > Model: ucbbar,spike-bare,qemu > > > DRAM: 256 MiB > > > In: uart@10013000 > > > Out: uart@10013000 > > > Err: uart@10013000 > > > Net: > > > Warning: ethernet@100900fc (eth0) using random MAC address - f6:1f:8c:13:83:c0 > > > eth0: ethernet@100900fc > > > Hit any key to stop autoboot: 0 > > > > > > Device 0: unknown device > > > ethernet@100900fc: PHY present at 0 > > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > > BOOTP broadcast 1 > > > DHCP client bound to address 10.0.2.15 (2 ms) > > > Using ethernet@100900fc device > > > TFTP from server 10.0.2.2; our IP address is 10.0.2.15 > > > Filename 'boot.scr.uimg'. > > > Load address: 0x82100000 > > > Loading: * > > > TFTP error: 'Access violation' (2) > > > Not retrying... > > > ethernet@100900fc: PHY present at 0 > > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > > BOOTP broadcast 1 > > > DHCP client bound to address 10.0.2.15 (1 ms) > > > Using ethernet@100900fc device > > > TFTP from server 10.0.2.2; our IP address is 10.0.2.15 > > > Filename 'boot.scr.uimg'. > > > Load address: 0x81000000 > > > Loading: * > > > TFTP error: 'Access violation' (2) > > > Not retrying... > > > => ping 10.0.2.2 > > > ethernet@100900fc: PHY present at 0 > > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > > Using ethernet@100900fc device > > > host 10.0.2.2 is alive > > > => > > > ethernet@100900fc: PHY present at 0 > > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > > Using ethernet@100900fc device > > > host 10.0.2.2 is alive > > > => qemu-system-riscv64: terminating on signal 2 > > > > > > > I have always been using "qemu-system-riscv64 -nographic -M sifive_u > > -kernel u-boot" to test U-Boot on qemu risc-v. > > With above command, I can "ping 10.0.2.2" and get the exact the same > > result as yours. > > > > However I wanted to connect the tap interface to the emulated network > > controller for testing, that's why I wanted to use "-device" and > > "-netdev", but I don't know which device string I need to tell QEMU. > > After a bit googleing I got the following page: > > https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Zynq-QEMU-Netw... > > > > From the page it looks that the device should be "-device > > cadence_gem", but when I pass it to QEMU I got: > > > > qemu-system-riscv64: -device cadence_gem,netdev=net0: Parameter > > 'driver' expects pluggable device type > > > > It looks cadence_gem is not a pluggable device. Any ideas? > > I have mostly tried TAP devices with VirtIO-Net. I believe this could be > some bug in Cadence GEM emulation of QEMU.
Yes, could be some issue with QEMU MACB emulation.
Anyway, we have U-Boot booting on Unleashed board with few fixes in SiFive UART driver (Atish will send-out the fixes after more testing).
This means same u-boot.bin boots on QEMU virt, QEMU sifive_u and HiFive unleashed. We are on path towards having unified u-boot.bin for multiple targets.
Regards, Anup
Hi Anup,
Hi Anup,
Hi Anup,
Hi Anup,
On Wed, Dec 19, 2018 at 5:05 PM Bin Meng bmeng.cn@gmail.com wrote: > > Hi Anup, > > On Wed, Dec 19, 2018 at 2:32 PM Anup Patel anup@brainfault.org wrote: > > > > On Wed, Dec 19, 2018 at 11:02 AM Bin Meng bmeng.cn@gmail.com wrote: > > > > > > Hi Anup, > > > > > > On Wed, Dec 19, 2018 at 12:41 PM Anup Patel anup@brainfault.org wrote: > > > > > > > > On Tue, Dec 18, 2018 at 4:06 PM Bin Meng bmeng.cn@gmail.com wrote: > > > > > > > > > > Hi Anup, > > > > > > > > > > On Tue, Dec 18, 2018 at 6:33 PM Anup Patel anup@brainfault.org wrote: > > > > > > > > > > > > On Tue, Dec 18, 2018 at 3:21 PM Bin Meng bmeng.cn@gmail.com wrote: > > > > > > > > > > > > > > Hi Anup, > > > > > > > > > > > > > > On Mon, Dec 17, 2018 at 7:51 PM Anup Patel anup@brainfault.org wrote: > > > > > > > > > > > > > > > > This patchset enables Cadance MACB ethernet driver for > > > > > > > > QEMU sifive_u machine. The Cadance MACB ethernet driver > > > > > > > > works fine for QEMU sifive_u machince in both M-mode and > > > > > > > > S-mode with some minor fixes. > > > > > > > > > > > > > > > > The patches are based upon latest RISC-V U-Boot tree > > > > > > > > (git://git.denx.de/u-boot-riscv.git) at commit id > > > > > > > > 9deb8d2fcd13d4a40a4e63c396fe4376af46efac > > > > > > > > > > > > > > > > To try on QEMU, please ensure following patches are > > > > > > > > applied to QEMU sources: > > > > > > > > https://patchwork.kernel.org/patch/10729579/ > > > > > > > > https://patchwork.kernel.org/patch/10729581/ > > > > > > > > > > > > > > > > > > > > > > What "-device " parameter should I tell QEMU to instantiate the MACB? > > > > > > > "-device ?" does not give me anything that looks like MACB. Without a > > > > > > > proper "-device " parameter, I can boot U-Boot on QEMU sifive_u and > > > > > > > see U-Boot driver is probed, but a simple 'ping' test does not work. > > > > > > > > > > > > Try the following: > > > > > > # setenv ipaddr 10.0.2.1 > > > > > > # ping 10.0.2.2 > > > > > > > > > > > > > > > > Yes, I have set up all the required network parameters. > > > > > > > > > > > The above works for me on QEMU. > > > > > > > > > > My understanding is that we need enable QEMU network via "-netdev " > > > > > (either usr, or tap), with a corresponding "-device". I don't know how > > > > > to set it up. What's your command line to test this? > > > > > > > > > > > > > "-netdev" or "-device" parameters are not mandatory. By default, virtual > > > > NICs are in NAT mode. The QEMU NAT gateway is at IP address > > > > 10.0.2.2. We can always ping the NAT gateway when virtual NIC is in > > > > NAT mode. > > > > > > > > Here's how I compile for M-mode: > > > > # ARCH=riscv > > > > # CROSS_COMPILE=riscv64-unknown-linux-gnu- > > > > # make qemu-riscv64_defconfig > > > > # make > > > > > > > > My U-boot log is as follows: > > > > > > > > anup@anup-ubuntu64:~/Work/riscv-test/u-boot$ qemu-system-riscv64 -M > > > > sifive_u -m 256M -display none -serial stdio -kernel ./u-boot > > > > > > > > > > > > U-Boot 2019.01-rc1-00948-ge6b3cdafd0 (Dec 19 2018 - 10:05:50 +0530) > > > > > > > > CPU: rv64imafdcsu > > > > Model: ucbbar,spike-bare,qemu > > > > DRAM: 256 MiB > > > > In: uart@10013000 > > > > Out: uart@10013000 > > > > Err: uart@10013000 > > > > Net: > > > > Warning: ethernet@100900fc (eth0) using random MAC address - f6:1f:8c:13:83:c0 > > > > eth0: ethernet@100900fc > > > > Hit any key to stop autoboot: 0 > > > > > > > > Device 0: unknown device > > > > ethernet@100900fc: PHY present at 0 > > > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > > > BOOTP broadcast 1 > > > > DHCP client bound to address 10.0.2.15 (2 ms) > > > > Using ethernet@100900fc device > > > > TFTP from server 10.0.2.2; our IP address is 10.0.2.15 > > > > Filename 'boot.scr.uimg'. > > > > Load address: 0x82100000 > > > > Loading: * > > > > TFTP error: 'Access violation' (2) > > > > Not retrying... > > > > ethernet@100900fc: PHY present at 0 > > > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > > > BOOTP broadcast 1 > > > > DHCP client bound to address 10.0.2.15 (1 ms) > > > > Using ethernet@100900fc device > > > > TFTP from server 10.0.2.2; our IP address is 10.0.2.15 > > > > Filename 'boot.scr.uimg'. > > > > Load address: 0x81000000 > > > > Loading: * > > > > TFTP error: 'Access violation' (2) > > > > Not retrying... > > > > => ping 10.0.2.2 > > > > ethernet@100900fc: PHY present at 0 > > > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > > > Using ethernet@100900fc device > > > > host 10.0.2.2 is alive > > > > => > > > > ethernet@100900fc: PHY present at 0 > > > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > > > Using ethernet@100900fc device > > > > host 10.0.2.2 is alive > > > > => qemu-system-riscv64: terminating on signal 2 > > > > > > > > > > I have always been using "qemu-system-riscv64 -nographic -M sifive_u > > > -kernel u-boot" to test U-Boot on qemu risc-v. > > > With above command, I can "ping 10.0.2.2" and get the exact the same > > > result as yours. > > > > > > However I wanted to connect the tap interface to the emulated network > > > controller for testing, that's why I wanted to use "-device" and > > > "-netdev", but I don't know which device string I need to tell QEMU. > > > After a bit googleing I got the following page: > > > https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Zynq-QEMU-Netw... > > > > > > From the page it looks that the device should be "-device > > > cadence_gem", but when I pass it to QEMU I got: > > > > > > qemu-system-riscv64: -device cadence_gem,netdev=net0: Parameter > > > 'driver' expects pluggable device type > > > > > > It looks cadence_gem is not a pluggable device. Any ideas? > > > > I have mostly tried TAP devices with VirtIO-Net. I believe this could be > > some bug in Cadence GEM emulation of QEMU. > > I managed to get tap interface connected to the cadence_gem > controller. The QEMU command line is "qemu-system-riscv64 -nographic > -M sifive_u -kernel u-boot -nic tap,model=cadence_gem" > > A single "ping" works after I set related network environments in the > shell. But "tftp" test fails. It looks the driver just time out. > > => tftp 84000000 bmeng/uImage.riscv > ethernet@100900fc: PHY present at 0 > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > Using ethernet@100900fc device > TFTP from server 10.10.0.100; our IP address is 10.10.0.108 > Filename 'bmeng/uImage.riscv'. > Load address: 0x84000000 > Loading: #T T #T T #T #T T #T #T T # > Retry count exceeded; starting again > > Can you please take a look?
This is great! Once it's ready I can help the testing.
Regards, Bin
On Mon, Dec 24, 2018 at 1:06 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Anup,
Hi Anup,
Hi Anup,
On Mon, Dec 24, 2018 at 6:59 AM Bin Meng bmeng.cn@gmail.com wrote: > > Hi Anup, > > On Wed, Dec 19, 2018 at 5:05 PM Bin Meng bmeng.cn@gmail.com wrote: > > > > Hi Anup, > > > > On Wed, Dec 19, 2018 at 2:32 PM Anup Patel anup@brainfault.org wrote: > > > > > > On Wed, Dec 19, 2018 at 11:02 AM Bin Meng bmeng.cn@gmail.com wrote: > > > > > > > > Hi Anup, > > > > > > > > On Wed, Dec 19, 2018 at 12:41 PM Anup Patel anup@brainfault.org wrote: > > > > > > > > > > On Tue, Dec 18, 2018 at 4:06 PM Bin Meng bmeng.cn@gmail.com wrote: > > > > > > > > > > > > Hi Anup, > > > > > > > > > > > > On Tue, Dec 18, 2018 at 6:33 PM Anup Patel anup@brainfault.org wrote: > > > > > > > > > > > > > > On Tue, Dec 18, 2018 at 3:21 PM Bin Meng bmeng.cn@gmail.com wrote: > > > > > > > > > > > > > > > > Hi Anup, > > > > > > > > > > > > > > > > On Mon, Dec 17, 2018 at 7:51 PM Anup Patel anup@brainfault.org wrote: > > > > > > > > > > > > > > > > > > This patchset enables Cadance MACB ethernet driver for > > > > > > > > > QEMU sifive_u machine. The Cadance MACB ethernet driver > > > > > > > > > works fine for QEMU sifive_u machince in both M-mode and > > > > > > > > > S-mode with some minor fixes. > > > > > > > > > > > > > > > > > > The patches are based upon latest RISC-V U-Boot tree > > > > > > > > > (git://git.denx.de/u-boot-riscv.git) at commit id > > > > > > > > > 9deb8d2fcd13d4a40a4e63c396fe4376af46efac > > > > > > > > > > > > > > > > > > To try on QEMU, please ensure following patches are > > > > > > > > > applied to QEMU sources: > > > > > > > > > https://patchwork.kernel.org/patch/10729579/ > > > > > > > > > https://patchwork.kernel.org/patch/10729581/ > > > > > > > > > > > > > > > > > > > > > > > > > What "-device " parameter should I tell QEMU to instantiate the MACB? > > > > > > > > "-device ?" does not give me anything that looks like MACB. Without a > > > > > > > > proper "-device " parameter, I can boot U-Boot on QEMU sifive_u and > > > > > > > > see U-Boot driver is probed, but a simple 'ping' test does not work. > > > > > > > > > > > > > > Try the following: > > > > > > > # setenv ipaddr 10.0.2.1 > > > > > > > # ping 10.0.2.2 > > > > > > > > > > > > > > > > > > > Yes, I have set up all the required network parameters. > > > > > > > > > > > > > The above works for me on QEMU. > > > > > > > > > > > > My understanding is that we need enable QEMU network via "-netdev " > > > > > > (either usr, or tap), with a corresponding "-device". I don't know how > > > > > > to set it up. What's your command line to test this? > > > > > > > > > > > > > > > > "-netdev" or "-device" parameters are not mandatory. By default, virtual > > > > > NICs are in NAT mode. The QEMU NAT gateway is at IP address > > > > > 10.0.2.2. We can always ping the NAT gateway when virtual NIC is in > > > > > NAT mode. > > > > > > > > > > Here's how I compile for M-mode: > > > > > # ARCH=riscv > > > > > # CROSS_COMPILE=riscv64-unknown-linux-gnu- > > > > > # make qemu-riscv64_defconfig > > > > > # make > > > > > > > > > > My U-boot log is as follows: > > > > > > > > > > anup@anup-ubuntu64:~/Work/riscv-test/u-boot$ qemu-system-riscv64 -M > > > > > sifive_u -m 256M -display none -serial stdio -kernel ./u-boot > > > > > > > > > > > > > > > U-Boot 2019.01-rc1-00948-ge6b3cdafd0 (Dec 19 2018 - 10:05:50 +0530) > > > > > > > > > > CPU: rv64imafdcsu > > > > > Model: ucbbar,spike-bare,qemu > > > > > DRAM: 256 MiB > > > > > In: uart@10013000 > > > > > Out: uart@10013000 > > > > > Err: uart@10013000 > > > > > Net: > > > > > Warning: ethernet@100900fc (eth0) using random MAC address - f6:1f:8c:13:83:c0 > > > > > eth0: ethernet@100900fc > > > > > Hit any key to stop autoboot: 0 > > > > > > > > > > Device 0: unknown device > > > > > ethernet@100900fc: PHY present at 0 > > > > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > > > > BOOTP broadcast 1 > > > > > DHCP client bound to address 10.0.2.15 (2 ms) > > > > > Using ethernet@100900fc device > > > > > TFTP from server 10.0.2.2; our IP address is 10.0.2.15 > > > > > Filename 'boot.scr.uimg'. > > > > > Load address: 0x82100000 > > > > > Loading: * > > > > > TFTP error: 'Access violation' (2) > > > > > Not retrying... > > > > > ethernet@100900fc: PHY present at 0 > > > > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > > > > BOOTP broadcast 1 > > > > > DHCP client bound to address 10.0.2.15 (1 ms) > > > > > Using ethernet@100900fc device > > > > > TFTP from server 10.0.2.2; our IP address is 10.0.2.15 > > > > > Filename 'boot.scr.uimg'. > > > > > Load address: 0x81000000 > > > > > Loading: * > > > > > TFTP error: 'Access violation' (2) > > > > > Not retrying... > > > > > => ping 10.0.2.2 > > > > > ethernet@100900fc: PHY present at 0 > > > > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > > > > Using ethernet@100900fc device > > > > > host 10.0.2.2 is alive > > > > > => > > > > > ethernet@100900fc: PHY present at 0 > > > > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > > > > Using ethernet@100900fc device > > > > > host 10.0.2.2 is alive > > > > > => qemu-system-riscv64: terminating on signal 2 > > > > > > > > > > > > > I have always been using "qemu-system-riscv64 -nographic -M sifive_u > > > > -kernel u-boot" to test U-Boot on qemu risc-v. > > > > With above command, I can "ping 10.0.2.2" and get the exact the same > > > > result as yours. > > > > > > > > However I wanted to connect the tap interface to the emulated network > > > > controller for testing, that's why I wanted to use "-device" and > > > > "-netdev", but I don't know which device string I need to tell QEMU. > > > > After a bit googleing I got the following page: > > > > https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Zynq-QEMU-Netw... > > > > > > > > From the page it looks that the device should be "-device > > > > cadence_gem", but when I pass it to QEMU I got: > > > > > > > > qemu-system-riscv64: -device cadence_gem,netdev=net0: Parameter > > > > 'driver' expects pluggable device type > > > > > > > > It looks cadence_gem is not a pluggable device. Any ideas? > > > > > > I have mostly tried TAP devices with VirtIO-Net. I believe this could be > > > some bug in Cadence GEM emulation of QEMU. > > > > I managed to get tap interface connected to the cadence_gem > > controller. The QEMU command line is "qemu-system-riscv64 -nographic > > -M sifive_u -kernel u-boot -nic tap,model=cadence_gem" > > > > A single "ping" works after I set related network environments in the > > shell. But "tftp" test fails. It looks the driver just time out. > > > > => tftp 84000000 bmeng/uImage.riscv > > ethernet@100900fc: PHY present at 0 > > ethernet@100900fc: link up, 100Mbps full-duplex (lpa: 0xcde1) > > Using ethernet@100900fc device > > TFTP from server 10.10.0.100; our IP address is 10.10.0.108 > > Filename 'bmeng/uImage.riscv'. > > Load address: 0x84000000 > > Loading: #T T #T T #T #T T #T #T T # > > Retry count exceeded; starting again > > > > Can you please take a look? > > Any idea about the timeouts?
Thanks in-advance.
I would suggest to get this series for U-Boot 2019.01. What say?
Regards, Anup
Hi Anup,
Hi Anup,
Hi Anup,
Just let everyone know that this GEM emulation issue has been fixed by the following QEMU patch (series): http://patchwork.ozlabs.org/patch/1143358/
Regards, Bin
Anup Patel
Bin Meng
