[U-Boot] [PATCH] ARM: kirkwood: fix cpu info for 6282 device id
Signed-off-by: Luka Perkov luka@openwrt.org CC: Prafulla Wadaskar prafulla@marvell.com CC: Stefan Roese sr@denx.de --- arch/arm/cpu/arm926ejs/kirkwood/cpu.c | 11 ++++++++--- 1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/kirkwood/cpu.c b/arch/arm/cpu/arm926ejs/kirkwood/cpu.c index da80240..312d2b2 100644 --- a/arch/arm/cpu/arm926ejs/kirkwood/cpu.c +++ b/arch/arm/cpu/arm926ejs/kirkwood/cpu.c @@ -252,7 +252,7 @@ static void kw_sysrst_check(void) #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo(void) { - char *rev; + char *rev = "??"; u16 devid = (readl(KW_REG_PCIE_DEVID) >> 16) & 0xffff; u8 revid = readl(KW_REG_PCIE_REVID) & 0xff;
@@ -263,7 +263,13 @@ int print_cpuinfo(void)
switch (revid) { case 0: - rev = "Z0"; + if (devid == 0x6281) + rev = "Z0"; + else if (devid == 0x6282) + rev = "A0"; + break; + case 1: + rev = "A1"; break; case 2: rev = "A0"; @@ -272,7 +278,6 @@ int print_cpuinfo(void) rev = "A1"; break; default: - rev = "??"; break; }
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
-----Original Message----- From: Luka Perkov [mailto:luka@openwrt.org] Sent: 02 July 2014 05:48 To: u-boot@lists.denx.de Cc: luka@openwrt.org; Prafulla Wadaskar; Stefan Roese Subject: [PATCH] ARM: kirkwood: fix cpu info for 6282 device id
- char *rev;
- char *rev = "??"; u16 devid = (readl(KW_REG_PCIE_DEVID) >> 16) &
rev = "Z0";
rev = "Z0";
rev = "A0";
break;
- case 1:
break; case 2: rev = "A0";rev = "A1";
break; }rev = "??";
Acked-By: Prafulla Wadaskar prafulla@marvell.com
Will be pulled latter.
Regards... Prafulla . . .
Hi Prafulla,
On Fri, 4 Jul 2014 11:43:48 -0700, Prafulla Wadaskar prafulla@marvell.com wrote:
- char *rev;
rev = "Z0";
rev = "Z0";
rev = "A0";
break;
- case 1:
break; }rev = "??";
Prafulla, just a note in case you intend to send a PR for 2014.07: I'll be unavailable for U-Boot work from Monday july 7th to Tuesday july 22nd inclusive, so meanwhile, a Marvell PR for 2014.07 would have to be sent to Tom Rini.
Amicalement,
Albert ARIBAUD
Luka Perkov
Prafulla Wadaskar
Stefan Roese
