[U-Boot-Users] [PATCH] [new uImage] Fix build errors when CONFIG_LOGBUFFER and CONFIG_FIT are enabled
Recent modifcations to LOGBUFFER handling code were incorrecly introduced to fit_check_kernel() routine during "Merge branch 'new-image' of git://www.denx.de/git/u-boot-testing", commit 27f33e9f45ef7f9685cbdc65066a1828e85dde4f.
This patch cleans up this merge issue.
Signed-off-by: Marian Balakowicz m8@semihalf.com ---
common/cmd_bootm.c | 11 ----------- common/image.c | 4 ---- 2 files changed, 0 insertions(+), 15 deletions(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 44f6b9f..0d67132 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -433,17 +433,6 @@ static int fit_check_kernel (const void *fit, int os_noffset, int verify) } show_boot_progress (105);
-#ifdef CONFIG_LOGBUFFER -#ifndef CONFIG_ALT_LB_ADDR - kbd=gd->bd; - /* Prevent initrd from overwriting logbuffer */ - if (initrd_high < (kbd->bi_memsize-LOGBUFF_LEN-LOGBUFF_OVERHEAD)) - initrd_high = kbd->bi_memsize-LOGBUFF_LEN-LOGBUFF_OVERHEAD; - debug ("## Logbuffer at 0x%08lX ", kbd->bi_memsize-LOGBUFF_LEN); -#else - debug ("## Logbuffer at 0x%08lX ", CONFIG_ALT_LB_ADDR); -#endif -#endif if (!fit_image_check_target_arch (fit, os_noffset)) { puts ("Unsupported Architecture\n"); show_boot_progress (-105); diff --git a/common/image.c b/common/image.c index 4a024d4..0a78385 100644 --- a/common/image.c +++ b/common/image.c @@ -36,10 +36,6 @@ #include <dataflash.h> #endif
-#ifdef CONFIG_LOGBUFFER -#include <logbuff.h> -#endif - #if defined(CONFIG_TIMESTAMP) || defined(CONFIG_CMD_DATE) #include <rtc.h> #endif
Ummm... but don't you break logbuffer support that way?
- kbd=gd->bd;
-#else
-#endif -#endif
Well, it's easy to remove the code here, but if serves a purpose, so it cannot be simply removed without adding it somewhere else. Or am I missing something?
- kbd=gd->bd;
-#else
-#endif -#endif
This piece of the code was removed earlier with one of the Kumar's patches that added LMB support for booting allocations.
Then it got incorrectly merged back in a wrong place, which this patch intends to fix.
As to the check itself: - it seem bogus, it does not properly check for initrd and logbuffer areas overlaps - it does not take into account the recent "effective" memory size limitation introduced for ppc
I'll post a separate, preliminary patch that will attempt to implement the check in a proper way.
Cheers, Marian
Applied, thanks.
Marian Balakowicz
