[U-Boot] [PATCH v2 6/6] sf: Fix code cleanups
- CHECK: Alignment should match open parenthesis - trailing whitespace
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- drivers/mtd/spi/atmel.c | 10 +++++----- drivers/mtd/spi/gigadevice.c | 2 +- drivers/mtd/spi/ramtron.c | 2 +- drivers/mtd/spi/spansion.c | 2 +- drivers/mtd/spi/spi_spl_load.c | 2 +- drivers/mtd/spi/sst.c | 6 +++--- drivers/mtd/spi/stmicro.c | 5 +++-- drivers/mtd/spi/winbond.c | 2 +- 8 files changed, 16 insertions(+), 15 deletions(-)
diff --git a/drivers/mtd/spi/atmel.c b/drivers/mtd/spi/atmel.c index 6a92c4b..f34df43 100644 --- a/drivers/mtd/spi/atmel.c +++ b/drivers/mtd/spi/atmel.c @@ -252,7 +252,7 @@ static int dataflash_write_p2(struct spi_flash *flash, }
debug("SF: AT45: Successfully programmed %zu bytes @ 0x%x\n", - len, offset); + len, offset); ret = 0;
out: @@ -325,7 +325,7 @@ static int dataflash_write_at45(struct spi_flash *flash, }
out: @@ -387,7 +387,7 @@ static int dataflash_erase_p2(struct spi_flash *flash, u32 offset, size_t len) }
debug("SF: AT45: Successfully erased %zu bytes @ 0x%x\n", - len, offset); + len, offset); ret = 0;
out: @@ -450,7 +450,7 @@ static int dataflash_erase_at45(struct spi_flash *flash, u32 offset, size_t len) }
out: @@ -476,7 +476,7 @@ struct spi_flash *spi_flash_probe_atmel(struct spi_slave *spi, u8 *idcode)
if (i == ARRAY_SIZE(atmel_spi_flash_table)) { debug("SF: Unsupported DataFlash ID %02x\n", - idcode[1]); + idcode[1]); return NULL; }
diff --git a/drivers/mtd/spi/gigadevice.c b/drivers/mtd/spi/gigadevice.c index 950c777..b42581a 100644 --- a/drivers/mtd/spi/gigadevice.c +++ b/drivers/mtd/spi/gigadevice.c @@ -45,7 +45,7 @@ struct spi_flash *spi_flash_probe_gigadevice(struct spi_slave *spi, u8 *idcode)
if (i == ARRAY_SIZE(gigadevice_spi_flash_table)) { debug("SF: Unsupported Gigadevice ID %02x%02x\n", - idcode[1], idcode[2]); + idcode[1], idcode[2]); return NULL; }
diff --git a/drivers/mtd/spi/ramtron.c b/drivers/mtd/spi/ramtron.c index 27e6411..38f9d69 100644 --- a/drivers/mtd/spi/ramtron.c +++ b/drivers/mtd/spi/ramtron.c @@ -266,7 +266,7 @@ struct spi_flash *spi_fram_probe_ramtron(struct spi_slave *spi, u8 *idcode)
/* arriving here means no method has found a device we can handle */ debug("SF/ramtron: unsupported device id0=%02x id1=%02x id2=%02x\n", - idcode[0], idcode[1], idcode[2]); + idcode[0], idcode[1], idcode[2]); return NULL;
found: diff --git a/drivers/mtd/spi/spansion.c b/drivers/mtd/spi/spansion.c index b9a36c2..fa7ac8c 100644 --- a/drivers/mtd/spi/spansion.c +++ b/drivers/mtd/spi/spansion.c @@ -6,7 +6,7 @@ * TsiChung Liew (Tsi-Chung.Liew@freescale.com), * and Jason McMullan (mcmullan@netapp.com) * - * SPDX-License-Identifier: GPL-2.0+ + * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> diff --git a/drivers/mtd/spi/spi_spl_load.c b/drivers/mtd/spi/spi_spl_load.c index 7c799ca..2935530 100644 --- a/drivers/mtd/spi/spi_spl_load.c +++ b/drivers/mtd/spi/spi_spl_load.c @@ -39,7 +39,7 @@ void spl_spi_load_image(void)
/* Load u-boot, mkimage header is 64 bytes. */ spi_flash_read(flash, CONFIG_SYS_SPI_U_BOOT_OFFS, 0x40, - (void *) header); + (void *)header); spl_parse_image_header(header); spi_flash_read(flash, CONFIG_SYS_SPI_U_BOOT_OFFS, spl_image.size, (void *)spl_image.load_addr); diff --git a/drivers/mtd/spi/sst.c b/drivers/mtd/spi/sst.c index 6292289..c9dec3c52 100644 --- a/drivers/mtd/spi/sst.c +++ b/drivers/mtd/spi/sst.c @@ -113,7 +113,7 @@ sst_byte_write(struct spi_flash *flash, u32 offset, const void *buf) };
debug("BP[%02x]: 0x%p => cmd = { 0x%02x 0x%06x }\n", - spi_w8r8(flash->spi, CMD_READ_STATUS), buf, cmd[0], offset); + spi_w8r8(flash->spi, CMD_READ_STATUS), buf, cmd[0], offset);
ret = spi_flash_cmd_write_enable(flash); if (ret) @@ -160,8 +160,8 @@ sst_write_wp(struct spi_flash *flash, u32 offset, size_t len, const void *buf)
for (; actual < len - 1; actual += 2) { debug("WP[%02x]: 0x%p => cmd = { 0x%02x 0x%06x }\n", - spi_w8r8(flash->spi, CMD_READ_STATUS), buf + actual, - cmd[0], offset); + spi_w8r8(flash->spi, CMD_READ_STATUS), buf + actual, + cmd[0], offset);
ret = spi_flash_cmd_write(flash->spi, cmd, cmd_len, buf + actual, 2); diff --git a/drivers/mtd/spi/stmicro.c b/drivers/mtd/spi/stmicro.c index e8cc827..c5fa64e 100644 --- a/drivers/mtd/spi/stmicro.c +++ b/drivers/mtd/spi/stmicro.c @@ -8,7 +8,7 @@ * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. * TsiChung Liew (Tsi-Chung.Liew@freescale.com) * - * SPDX-License-Identifier: GPL-2.0+ + * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> @@ -166,8 +166,9 @@ struct spi_flash *spi_flash_probe_stmicro(struct spi_slave *spi, u8 *idcode) idcode[0] = 0x20; idcode[1] = 0x20; idcode[2] = idcode[3] + 1; - } else + } else { return NULL; + } }
id = ((idcode[1] << 8) | idcode[2]); diff --git a/drivers/mtd/spi/winbond.c b/drivers/mtd/spi/winbond.c index c399bf1..b31911a 100644 --- a/drivers/mtd/spi/winbond.c +++ b/drivers/mtd/spi/winbond.c @@ -123,7 +123,7 @@ struct spi_flash *spi_flash_probe_winbond(struct spi_slave *spi, u8 *idcode)
if (i == ARRAY_SIZE(winbond_spi_flash_table)) { debug("SF: Unsupported Winbond ID %02x%02x\n", - idcode[1], idcode[2]); + idcode[1], idcode[2]); return NULL; }
