[U-Boot] [PATCH] zynq: treat ps7_init.c/h as external files to ignore them
ps7_init.c and ps7_init.h are supposed to be exported by hw project and copied to board/xilinx/zynq/ directory.
We want them to be ignored by git. So what we should do is to always treat them as external files rather than replacing ps7_init.c
This commit does:
- Move a weak function ps7_init() to arch/arm/cpu/armv7/zynq/spl.c and delete board/xilinx/zynq/ps7_init.c
- Compile board/xilinx/zynq/ps7_init.c only when it exists
- Add .gitignore to ignore ps7_init.c/h
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Michal Simek michal.simek@xilinx.com --- arch/arm/cpu/armv7/zynq/spl.c | 8 ++++++++ board/xilinx/zynq/.gitignore | 1 + board/xilinx/zynq/Makefile | 5 ++++- board/xilinx/zynq/ps7_init.c | 12 ------------ 4 files changed, 13 insertions(+), 13 deletions(-) create mode 100644 board/xilinx/zynq/.gitignore delete mode 100644 board/xilinx/zynq/ps7_init.c
diff --git a/arch/arm/cpu/armv7/zynq/spl.c b/arch/arm/cpu/armv7/zynq/spl.c index fcad762..e97695e 100644 --- a/arch/arm/cpu/armv7/zynq/spl.c +++ b/arch/arm/cpu/armv7/zynq/spl.c @@ -67,3 +67,11 @@ int spl_start_uboot(void) return 0; } #endif + +__weak void ps7_init(void) +{ + /* + * This function is replaced by the one in + * board/xilinx/zynq/ps7_init.c, if it exists. + */ +} diff --git a/board/xilinx/zynq/.gitignore b/board/xilinx/zynq/.gitignore new file mode 100644 index 0000000..68b8edd --- /dev/null +++ b/board/xilinx/zynq/.gitignore @@ -0,0 +1 @@ +ps7_init.[ch] diff --git a/board/xilinx/zynq/Makefile b/board/xilinx/zynq/Makefile index 3f19a1c..f91214c 100644 --- a/board/xilinx/zynq/Makefile +++ b/board/xilinx/zynq/Makefile @@ -6,4 +6,7 @@ #
obj-y := board.o -obj-$(CONFIG_SPL_BUILD) += ps7_init.o + +# Please copy ps7_init.c/h from hw project +obj-$(CONFIG_SPL_BUILD) += \ + $(if $(wildcard $(srctree)/$(src)/ps7_init.c),ps7_init.o) diff --git a/board/xilinx/zynq/ps7_init.c b/board/xilinx/zynq/ps7_init.c deleted file mode 100644 index c47da09..0000000 --- a/board/xilinx/zynq/ps7_init.c +++ /dev/null @@ -1,12 +0,0 @@ -/* - * (C) Copyright 2014 Xilinx, Inc. Michal Simek - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#include <common.h> -#include <asm/arch/spl.h> - -__weak void ps7_init(void) -{ - puts("Please copy ps7_init.c/h from hw project\n"); -}
This commit does:
Signed-off-by: Michal Simek monstr@monstr.eu
Masahiro: I have just tried to run this on the top of my zynq branch with fpga changes I have sent and I can't see any problem in MMC boot mode.
As we discussed earlier - I am doing these changes in zynq-common not to deal with dts files now.
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 8e0f93599fc4..fb08a978019a 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -226,15 +226,6 @@ #define CONFIG_FIT #define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */
-/* FDT support */ -#define CONFIG_OF_CONTROL -#define CONFIG_OF_SEPARATE -#define CONFIG_DISPLAY_BOARDINFO_LATE - -/* RSA support */ -#define CONFIG_FIT_SIGNATURE -#define CONFIG_RSA -
And I get this (I am sending generic board enabling for Zynq in a minute).
U-Boot SPL 2014.04-00236-gb861b285b4e9-dirty (May 08 2014 - 15:08:00) mmc boot reading system.dtb spl_load_image_fat_os: error reading image system.dtb, err - -1 reading u-boot.img reading u-boot.img
U-Boot 2014.04-00236-gb861b285b4e9-dirty (May 08 2014 - 15:08:00)
I2C: ready DRAM: Memory: ECC disabled 1 GiB MMC: zynq_sdhci: 0 Using default environment
In: serial Out: serial Err: serial Net: Gem.e000b000 Warning: failed to set MAC address
Hit any key to stop autoboot: 0 zynq-uboot>
Thanks, Michal
Masahiro Yamada
Michal Simek
