[U-Boot] [PATCH v4 00/25] Fix and extend i.MX HAB layer
v4: - No change mixed extra patches @ v3 unnoticed with previous git-send
v3: - Only call into ROM if headers are verified. - Bryan
- Print HAB event log if and only if a call was made to HAB and a meaningful status code has been obtained. - Breno
v2: - Fix compilation warnings and errors in SPL highlighted by Breno Matheus Lima
- Add CC: Breno Matheus Lima brenomatheus@gmail.com to all patches
v1: This patchset updates the i.MX HAB layer in u-boot to fix a list of identified issues and then to add and extend existing functionality.
The first block of patches 0001-0006 deal with fixing existing code,
- Fixes indentation - Fixes the treatment of input parameters to hab_auth_image.
The second block of patches 0007-0013 are about tidying up the HAB code
- Remove reliance on hard-coding to specific offsets - IVT header drives locating CSF - Continue to support existing boards
Patches 0014 onwards extend out the HAB functionality.
- hab_rvt_check_target is a recommended check in the NXP documents to perform prior to hab_rvt_authenticate_image - hab_rvt_failsafe is a useful function to set the board into BootROM USB recovery mode.
Bryan O'Donoghue (25): arm: imx: hab: Make authenticate_image return int arm: imx: hab: Fix authenticate_image result code arm: imx: hab: Optimise flow of authenticate_image on is_enabled fail arm: imx: hab: Optimise flow of authenticate_image on hab_entry fail arm: imx: hab: Move IVT_SIZE to hab.h arm: imx: hab: Move CSF_PAD_SIZE to hab.h arm: imx: hab: Fix authenticate_image input parameters arm: imx: hab: Fix authenticate image lockup on MX7 arm: imx: hab: Add IVT header definitions arm: imx: hab: Add IVT header verification arm: imx: hab: Verify IVT self matches calculated address arm: imx: hab: Only call ROM once headers are verified arm: imx: hab: Print CSF based on IVT descriptor arm: imx: hab: Print additional IVT elements during debug arm: imx: hab: Define rvt_check_target() arm: imx: hab: Implement hab_rvt_check_target arm: imx: hab: Add a hab_rvt_check_target to image auth arm: imx: hab: Print HAB event log only after calling ROM arm: imx: hab: Make internal functions and data static arm: imx: hab: Prefix authenticate_image with imx_hab arm: imx: hab: Rename is_hab_enabled imx_hab_is_enabled arm: imx: hab: Make imx_hab_is_enabled global arm: imx: hab: Define rvt_failsafe() arm: imx: hab: Implement hab_rvt_failsafe arm: imx: hab: Add hab_failsafe console command
arch/arm/include/asm/mach-imx/hab.h | 46 +++- arch/arm/mach-imx/hab.c | 476 ++++++++++++++++++++++-------------- arch/arm/mach-imx/spl.c | 38 ++- 3 files changed, 369 insertions(+), 191 deletions(-)
Both usages of authenticate_image treat the result code as a simple binary. The command line usage of authenticate_image directly returns the result code of authenticate_image as a success/failure code.
Right now when calling hab_auth_img and test the result code in a shell a passing hab_auth_img will appear to the shell as a fail.
The first step in fixing this behaviour is to fix-up the result code return by authenticate_image() itself, subsequent patches fix the interpretation of authenticate_image so that zero will return CMD_RET_SUCCESS and non-zero will return CMD_RET_FAILURE.
The first step is fixing the return type in authenticate_image() so do that now.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/include/asm/mach-imx/hab.h | 2 +- arch/arm/mach-imx/hab.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/mach-imx/hab.h b/arch/arm/include/asm/mach-imx/hab.h index e0ff459..1b7a5e4 100644 --- a/arch/arm/include/asm/mach-imx/hab.h +++ b/arch/arm/include/asm/mach-imx/hab.h @@ -145,6 +145,6 @@ typedef void hapi_clock_init_t(void);
/* ----------- end of HAB API updates ------------*/
-uint32_t authenticate_image(uint32_t ddr_start, uint32_t image_size); +int authenticate_image(uint32_t ddr_start, uint32_t image_size);
#endif diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 02c7ae4..09892a6 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -410,7 +410,7 @@ static bool is_hab_enabled(void) return (reg & IS_HAB_ENABLED_BIT) == IS_HAB_ENABLED_BIT; }
-uint32_t authenticate_image(uint32_t ddr_start, uint32_t image_size) +int authenticate_image(uint32_t ddr_start, uint32_t image_size) { uint32_t load_addr = 0; size_t bytes;
authenticate_image returns 1 for success and 0 for failure. That result code is mapped directly to the result code for the command line function hab_auth_img - which means when hab_auth_img succeeds it is returning CMD_RET_FAILURE (1) instead of CMD_RET_SUCCESS (0).
This patch fixes this behaviour by making authenticate_image() return 0 for success and 1 for failure. Both users of authenticate_image() as a result have some minimal churn. The upshot is once done when hab_auth_img is called from the command line we set $? in the standard way for scripting functions to act on.
Fixes: 36c1ca4d46ef ("imx: Support i.MX6 High Assurance Boot authentication")
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/mach-imx/hab.c | 9 ++++++--- arch/arm/mach-imx/spl.c | 4 ++-- 2 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 09892a6..9fe6d43 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -373,7 +373,10 @@ static int do_authenticate_image(cmd_tbl_t *cmdtp, int flag, int argc, ivt_offset = simple_strtoul(argv[2], NULL, 16);
rcode = authenticate_image(addr, ivt_offset); - + if (rcode == 0) + rcode = CMD_RET_SUCCESS; + else + rcode = CMD_RET_FAILURE; return rcode; }
@@ -415,7 +418,7 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size) uint32_t load_addr = 0; size_t bytes; ptrdiff_t ivt_offset = 0; - int result = 0; + int result = 1; ulong start; hab_rvt_authenticate_image_t *hab_rvt_authenticate_image; hab_rvt_entry_t *hab_rvt_entry; @@ -510,7 +513,7 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size) }
if ((!is_hab_enabled()) || (load_addr != 0)) - result = 1; + result = 0;
return result; } diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index d0d1b73..6e930b3 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -163,8 +163,8 @@ __weak void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image)
/* HAB looks for the CSF at the end of the authenticated data therefore, * we need to subtract the size of the CSF from the actual filesize */ - if (authenticate_image(spl_image->load_addr, - spl_image->size - CONFIG_CSF_SIZE)) { + if (!authenticate_image(spl_image->load_addr, + spl_image->size - CONFIG_CSF_SIZE)) { image_entry(); } else { puts("spl: ERROR: image authentication unsuccessful\n");
There is no need to call is_enabled() twice in authenticate_image - it does nothing but add an additional layer of indentation.
We can check for is_enabled() at the start of the function and return the result code directly.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/mach-imx/hab.c | 138 ++++++++++++++++++++++++------------------------ 1 file changed, 69 insertions(+), 69 deletions(-)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 9fe6d43..6f86c02 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -428,91 +428,91 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size) hab_rvt_entry = hab_rvt_entry_p; hab_rvt_exit = hab_rvt_exit_p;
- if (is_hab_enabled()) { - printf("\nAuthenticate image from DDR location 0x%x...\n", - ddr_start); + if (!is_hab_enabled()) { + puts("hab fuse not enabled\n"); + return result; + }
- hab_caam_clock_enable(1); + printf("\nAuthenticate image from DDR location 0x%x...\n", + ddr_start);
- if (hab_rvt_entry() == HAB_SUCCESS) { - /* If not already aligned, Align to ALIGN_SIZE */ - ivt_offset = (image_size + ALIGN_SIZE - 1) & - ~(ALIGN_SIZE - 1); + hab_caam_clock_enable(1);
- start = ddr_start; - bytes = ivt_offset + IVT_SIZE + CSF_PAD_SIZE; + if (hab_rvt_entry() == HAB_SUCCESS) { + /* If not already aligned, Align to ALIGN_SIZE */ + ivt_offset = (image_size + ALIGN_SIZE - 1) & + ~(ALIGN_SIZE - 1); + + start = ddr_start; + bytes = ivt_offset + IVT_SIZE + CSF_PAD_SIZE; #ifdef DEBUG - printf("\nivt_offset = 0x%x, ivt addr = 0x%x\n", - ivt_offset, ddr_start + ivt_offset); - puts("Dumping IVT\n"); - print_buffer(ddr_start + ivt_offset, - (void *)(ddr_start + ivt_offset), - 4, 0x8, 0); - - puts("Dumping CSF Header\n"); - print_buffer(ddr_start + ivt_offset+IVT_SIZE, - (void *)(ddr_start + ivt_offset+IVT_SIZE), - 4, 0x10, 0); + printf("\nivt_offset = 0x%x, ivt addr = 0x%x\n", + ivt_offset, ddr_start + ivt_offset); + puts("Dumping IVT\n"); + print_buffer(ddr_start + ivt_offset, + (void *)(ddr_start + ivt_offset), + 4, 0x8, 0); + + puts("Dumping CSF Header\n"); + print_buffer(ddr_start + ivt_offset + IVT_SIZE, + (void *)(ddr_start + ivt_offset + IVT_SIZE), + 4, 0x10, 0);
#if !defined(CONFIG_SPL_BUILD) - get_hab_status(); + get_hab_status(); #endif
- puts("\nCalling authenticate_image in ROM\n"); - printf("\tivt_offset = 0x%x\n", ivt_offset); - printf("\tstart = 0x%08lx\n", start); - printf("\tbytes = 0x%x\n", bytes); + puts("\nCalling authenticate_image in ROM\n"); + printf("\tivt_offset = 0x%x\n", ivt_offset); + printf("\tstart = 0x%08lx\n", start); + printf("\tbytes = 0x%x\n", bytes); #endif - /* - * If the MMU is enabled, we have to notify the ROM - * code, or it won't flush the caches when needed. - * This is done, by setting the "pu_irom_mmu_enabled" - * word to 1. You can find its address by looking in - * the ROM map. This is critical for - * authenticate_image(). If MMU is enabled, without - * setting this bit, authentication will fail and may - * crash. - */ - /* Check MMU enabled */ - if (is_soc_type(MXC_SOC_MX6) && get_cr() & CR_M) { - if (is_mx6dq()) { - /* - * This won't work on Rev 1.0.0 of - * i.MX6Q/D, since their ROM doesn't - * do cache flushes. don't think any - * exist, so we ignore them. - */ - if (!is_mx6dqp()) - writel(1, MX6DQ_PU_IROM_MMU_EN_VAR); - } else if (is_mx6sdl()) { - writel(1, MX6DLS_PU_IROM_MMU_EN_VAR); - } else if (is_mx6sl()) { - writel(1, MX6SL_PU_IROM_MMU_EN_VAR); - } + /* + * If the MMU is enabled, we have to notify the ROM + * code, or it won't flush the caches when needed. + * This is done, by setting the "pu_irom_mmu_enabled" + * word to 1. You can find its address by looking in + * the ROM map. This is critical for + * authenticate_image(). If MMU is enabled, without + * setting this bit, authentication will fail and may + * crash. + */ + /* Check MMU enabled */ + if (is_soc_type(MXC_SOC_MX6) && get_cr() & CR_M) { + if (is_mx6dq()) { + /* + * This won't work on Rev 1.0.0 of + * i.MX6Q/D, since their ROM doesn't + * do cache flushes. don't think any + * exist, so we ignore them. + */ + if (!is_mx6dqp()) + writel(1, MX6DQ_PU_IROM_MMU_EN_VAR); + } else if (is_mx6sdl()) { + writel(1, MX6DLS_PU_IROM_MMU_EN_VAR); + } else if (is_mx6sl()) { + writel(1, MX6SL_PU_IROM_MMU_EN_VAR); } + }
- load_addr = (uint32_t)hab_rvt_authenticate_image( - HAB_CID_UBOOT, - ivt_offset, (void **)&start, - (size_t *)&bytes, NULL); - if (hab_rvt_exit() != HAB_SUCCESS) { - puts("hab exit function fail\n"); - load_addr = 0; - } - } else { - puts("hab entry function fail\n"); + load_addr = (uint32_t)hab_rvt_authenticate_image( + HAB_CID_UBOOT, + ivt_offset, (void **)&start, + (size_t *)&bytes, NULL); + if (hab_rvt_exit() != HAB_SUCCESS) { + puts("hab exit function fail\n"); + load_addr = 0; } + } else { + puts("hab entry function fail\n"); + }
- hab_caam_clock_enable(0); + hab_caam_clock_enable(0);
#if !defined(CONFIG_SPL_BUILD) - get_hab_status(); + get_hab_status(); #endif - } else { - puts("hab fuse not enabled\n"); - } - - if ((!is_hab_enabled()) || (load_addr != 0)) + if (load_addr != 0) result = 0;
return result;
The current code disjoins an entire block of code on hab_entry pass/fail resulting in a large chunk of authenticate_image being offset to the right.
Fix this by checking hab_entry() pass/failure and exiting the function directly if in an error state.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/mach-imx/hab.c | 118 ++++++++++++++++++++++++------------------------ 1 file changed, 60 insertions(+), 58 deletions(-)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 6f86c02..f878b7b 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -438,75 +438,77 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size)
- if (hab_rvt_entry() == HAB_SUCCESS) { - /* If not already aligned, Align to ALIGN_SIZE */ - ivt_offset = (image_size + ALIGN_SIZE - 1) & - ~(ALIGN_SIZE - 1); + if (hab_rvt_entry() != HAB_SUCCESS) { + puts("hab entry function fail\n"); + goto hab_caam_clock_disable; + }
- start = ddr_start; - bytes = ivt_offset + IVT_SIZE + CSF_PAD_SIZE; + /* If not already aligned, Align to ALIGN_SIZE */ + ivt_offset = (image_size + ALIGN_SIZE - 1) & + ~(ALIGN_SIZE - 1); + + start = ddr_start; + bytes = ivt_offset + IVT_SIZE + CSF_PAD_SIZE; #ifdef DEBUG - printf("\nivt_offset = 0x%x, ivt addr = 0x%x\n", - ivt_offset, ddr_start + ivt_offset); - puts("Dumping IVT\n"); - print_buffer(ddr_start + ivt_offset, - (void *)(ddr_start + ivt_offset), - 4, 0x8, 0); - - puts("Dumping CSF Header\n"); - print_buffer(ddr_start + ivt_offset + IVT_SIZE, - (void *)(ddr_start + ivt_offset + IVT_SIZE), - 4, 0x10, 0); + printf("\nivt_offset = 0x%x, ivt addr = 0x%x\n", + ivt_offset, ddr_start + ivt_offset); + puts("Dumping IVT\n"); + print_buffer(ddr_start + ivt_offset, + (void *)(ddr_start + ivt_offset), + 4, 0x8, 0); + + puts("Dumping CSF Header\n"); + print_buffer(ddr_start + ivt_offset + IVT_SIZE, + (void *)(ddr_start + ivt_offset + IVT_SIZE), + 4, 0x10, 0);
+hab_caam_clock_disable: hab_caam_clock_enable(0);
The size of the IVT header should be defined in hab.h move it there now.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/include/asm/mach-imx/hab.h | 2 ++ arch/arm/mach-imx/hab.c | 1 - 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/mach-imx/hab.h b/arch/arm/include/asm/mach-imx/hab.h index 1b7a5e4..3c19d2e 100644 --- a/arch/arm/include/asm/mach-imx/hab.h +++ b/arch/arm/include/asm/mach-imx/hab.h @@ -143,6 +143,8 @@ typedef void hapi_clock_init_t(void); #define HAB_CID_ROM 0 /**< ROM Caller ID */ #define HAB_CID_UBOOT 1 /**< UBOOT Caller ID*/
+#define IVT_SIZE 0x20 + /* ----------- end of HAB API updates ------------*/
int authenticate_image(uint32_t ddr_start, uint32_t image_size); diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index f878b7b..6367562 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -70,7 +70,6 @@ ((hab_rvt_exit_t *)HAB_RVT_EXIT) \ )
-#define IVT_SIZE 0x20 #define ALIGN_SIZE 0x1000 #define CSF_PAD_SIZE 0x2000 #define MX6DQ_PU_IROM_MMU_EN_VAR 0x009024a8
CSF_PAD_SIZE should be defined in hab.h, move it to that location now.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/include/asm/mach-imx/hab.h | 1 + arch/arm/mach-imx/hab.c | 1 - 2 files changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/mach-imx/hab.h b/arch/arm/include/asm/mach-imx/hab.h index 3c19d2e..91dda42 100644 --- a/arch/arm/include/asm/mach-imx/hab.h +++ b/arch/arm/include/asm/mach-imx/hab.h @@ -144,6 +144,7 @@ typedef void hapi_clock_init_t(void); #define HAB_CID_UBOOT 1 /**< UBOOT Caller ID*/
#define IVT_SIZE 0x20 +#define CSF_PAD_SIZE 0x2000
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 6367562..039a017 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -71,7 +71,6 @@ )
#define ALIGN_SIZE 0x1000 -#define CSF_PAD_SIZE 0x2000 #define MX6DQ_PU_IROM_MMU_EN_VAR 0x009024a8 #define MX6DLS_PU_IROM_MMU_EN_VAR 0x00901dd0 #define MX6SL_PU_IROM_MMU_EN_VAR 0x00900a18
u-boot command "hab_auth_img" tells a user that it takes
- addr - image hex address - offset - hex offset of IVT in the image
but in fact the callback hab_auth_img makes to authenticate_image treats the second 'offset' parameter as an image length.
Furthermore existing code requires the IVT header to be appended to the end of the image which is not actually a requirement of HABv4.
This patch fixes this situation by
1: Adding a new parameter to hab_auth_img - addr : image hex address - length : total length of the image - offset : offset of IVT from addr
2: Updates the existing call into authenticate_image() in arch/arm/mach-imx/spl.c:jump_to_image_no_args() to pass addr, length and IVT offset respectively.
This allows then hab_auth_img to actually operate the way it was specified in the help text and should still allow existing code to work.
It has the added advantage that the IVT header doesn't have to be appended to an image given to HAB - it can be prepended for example.
Note prepending the IVT is what u-boot will do when making an IVT for the BootROM. It should be possible for u-boot properly authenticate images made by mkimage via HAB.
This patch is the first step in making that happen subsequent patches will focus on removing hard-coded offsets to the IVT, which again is not mandated to live at the end of a .imx image.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/include/asm/mach-imx/hab.h | 3 +- arch/arm/mach-imx/hab.c | 73 +++++++++++-------------------------- arch/arm/mach-imx/spl.c | 35 +++++++++++++++++- 3 files changed, 57 insertions(+), 54 deletions(-)
diff --git a/arch/arm/include/asm/mach-imx/hab.h b/arch/arm/include/asm/mach-imx/hab.h index 91dda42..b2a8031 100644 --- a/arch/arm/include/asm/mach-imx/hab.h +++ b/arch/arm/include/asm/mach-imx/hab.h @@ -148,6 +148,7 @@ typedef void hapi_clock_init_t(void);
-int authenticate_image(uint32_t ddr_start, uint32_t image_size); +int authenticate_image(uint32_t ddr_start, uint32_t image_size, + uint32_t ivt_offset);
#endif diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 039a017..2a40d06 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -78,37 +78,6 @@ (is_soc_type(MXC_SOC_MX7ULP) ? 0x80000000 : \ (is_soc_type(MXC_SOC_MX7) ? 0x2000000 : 0x2))
-/* - * +------------+ 0x0 (DDR_UIMAGE_START) - - * | Header | | - * +------------+ 0x40 | - * | | | - * | | | - * | | | - * | | | - * | Image Data | | - * . | | - * . | > Stuff to be authenticated ----+ - * . | | | - * | | | | - * | | | | - * +------------+ | | - * | | | | - * | Fill Data | | | - * | | | | - * +------------+ Align to ALIGN_SIZE | | - * | IVT | | | - * +------------+ + IVT_SIZE - | - * | | | - * | CSF DATA | <---------------------------------------------------------+ - * | | - * +------------+ - * | | - * | Fill Data | - * | | - * +------------+ + CSF_PAD_SIZE - */ - static bool is_hab_enabled(void);
#if !defined(CONFIG_SPL_BUILD) @@ -361,20 +330,22 @@ int do_hab_status(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) static int do_authenticate_image(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - ulong addr, ivt_offset; + ulong addr, length, ivt_offset; int rcode = 0;
- if (argc < 3) + if (argc < 4) return CMD_RET_USAGE;
addr = simple_strtoul(argv[1], NULL, 16); - ivt_offset = simple_strtoul(argv[2], NULL, 16); + length = simple_strtoul(argv[2], NULL, 16); + ivt_offset = simple_strtoul(argv[3], NULL, 16);
- rcode = authenticate_image(addr, ivt_offset); + rcode = authenticate_image(addr, length, ivt_offset); if (rcode == 0) rcode = CMD_RET_SUCCESS; else rcode = CMD_RET_FAILURE; + return rcode; }
@@ -385,10 +356,11 @@ U_BOOT_CMD( );
U_BOOT_CMD( - hab_auth_img, 3, 0, do_authenticate_image, + hab_auth_img, 4, 0, do_authenticate_image, "authenticate image via HAB", - "addr ivt_offset\n" + "addr length ivt_offset\n" "addr - image hex address\n" + "length - image hex length\n" "ivt_offset - hex offset of IVT in the image" );
@@ -411,11 +383,12 @@ static bool is_hab_enabled(void) return (reg & IS_HAB_ENABLED_BIT) == IS_HAB_ENABLED_BIT; }
-int authenticate_image(uint32_t ddr_start, uint32_t image_size) +int authenticate_image(uint32_t ddr_start, uint32_t image_size, + uint32_t ivt_offset) { uint32_t load_addr = 0; size_t bytes; - ptrdiff_t ivt_offset = 0; + uint32_t ivt_addr = 0; int result = 1; ulong start; hab_rvt_authenticate_image_t *hab_rvt_authenticate_image; @@ -441,24 +414,18 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size) goto hab_caam_clock_disable; }
- /* If not already aligned, Align to ALIGN_SIZE */ - ivt_offset = (image_size + ALIGN_SIZE - 1) & - ~(ALIGN_SIZE - 1); - + /* Calculate IVT address header */ + ivt_addr = ddr_start + ivt_offset; start = ddr_start; - bytes = ivt_offset + IVT_SIZE + CSF_PAD_SIZE; + bytes = image_size; #ifdef DEBUG - printf("\nivt_offset = 0x%x, ivt addr = 0x%x\n", - ivt_offset, ddr_start + ivt_offset); + printf("\nivt_offset = 0x%x, ivt addr = 0x%x\n", ivt_offset, ivt_addr); puts("Dumping IVT\n"); - print_buffer(ddr_start + ivt_offset, - (void *)(ddr_start + ivt_offset), - 4, 0x8, 0); + print_buffer(ivt_addr, (void *)(ivt_addr), 4, 0x8, 0);
puts("Dumping CSF Header\n"); - print_buffer(ddr_start + ivt_offset + IVT_SIZE, - (void *)(ddr_start + ivt_offset + IVT_SIZE), - 4, 0x10, 0); + print_buffer(ivt_addr + IVT_SIZE, (void *)(ivt_addr + IVT_SIZE), 4, + 0x10, 0);
#if !defined(CONFIG_SPL_BUILD) get_hab_status(); @@ -468,6 +435,8 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size) printf("\tivt_offset = 0x%x\n", ivt_offset); printf("\tstart = 0x%08lx\n", start); printf("\tbytes = 0x%x\n", bytes); +#else + (void)ivt_addr; #endif /* * If the MMU is enabled, we have to notify the ROM diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index 6e930b3..e5d0c35 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -152,9 +152,41 @@ u32 spl_boot_mode(const u32 boot_device)
#if defined(CONFIG_SECURE_BOOT)
+/* + * +------------+ 0x0 (DDR_UIMAGE_START) - + * | Header | | + * +------------+ 0x40 | + * | | | + * | | | + * | | | + * | | | + * | Image Data | | + * . | | + * . | > Stuff to be authenticated ----+ + * . | | | + * | | | | + * | | | | + * +------------+ | | + * | | | | + * | Fill Data | | | + * | | | | + * +------------+ Align to ALIGN_SIZE | | + * | IVT | | | + * +------------+ + IVT_SIZE - | + * | | | + * | CSF DATA | <---------------------------------------------------------+ + * | | + * +------------+ + * | | + * | Fill Data | + * | | + * +------------+ + CSF_PAD_SIZE + */ + __weak void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) { typedef void __noreturn (*image_entry_noargs_t)(void); + uint32_t offset;
image_entry_noargs_t image_entry = (image_entry_noargs_t)(unsigned long)spl_image->entry_point; @@ -163,8 +195,9 @@ __weak void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image)
/* HAB looks for the CSF at the end of the authenticated data therefore, * we need to subtract the size of the CSF from the actual filesize */ + offset = spl_image->size - CONFIG_CSF_SIZE; if (!authenticate_image(spl_image->load_addr, - spl_image->size - CONFIG_CSF_SIZE)) { + offset + IVT_SIZE + CSF_PAD_SIZE, offset)) { image_entry(); } else { puts("spl: ERROR: image authentication unsuccessful\n");
The i.MX6 has some pretty explicit code associated with informing the IROM about flushing caches during authenticate_image().
Looking at various pieces of documentation its pretty clear the i.MX6 IROM registers are not documented and absent similar documentation on the i.MX7 the next-best fix is to disabled the dcache while making an authenticate_image() callback.
This patch therefore disables dcache temporarily while doing an IROM authenticate_image() callback, thus resolving a lockup encountered in a complex set of authenticate-image calls observed.
Note there is no appreciable performance impact with dcache switched off so this fix is relatively pain-free.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/mach-imx/hab.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 2a40d06..1d7b069 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -466,10 +466,25 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size, } }
+ /* + * FIXME: Need to disable dcache on MX7 is there an IROM + * register like on MX6 above ? Certain images called in certain + * orders with the dcache switched on will cause + * authenticate_image() to lockup. Switching off the dcache + * resolves the issue. + * https://community.nxp.com/message/953261 + */ + if (is_soc_type(MXC_SOC_MX7)) + dcache_disable(); + load_addr = (uint32_t)hab_rvt_authenticate_image( HAB_CID_UBOOT, ivt_offset, (void **)&start, (size_t *)&bytes, NULL); + + if (is_soc_type(MXC_SOC_MX7)) + dcache_enable(); + if (hab_rvt_exit() != HAB_SUCCESS) { puts("hab exit function fail\n"); load_addr = 0;
Hi Bryan,
2018-01-02 14:43 GMT-02:00 Bryan O'Donoghue bryan.odonoghue@linaro.org:
I'm trying to reproduce the same issue on an i.MX7D board but I'm not being able so far, Is it possible to share more details on how to reproduce this issue? Looking the thread at the NXP community seems that this can be reproduced in a specific situation, I would like to test in a similar environment as yours.
Thanks, Breno Lima
On 03/01/18 01:25, Breno Matheus Lima wrote:
Hi Bryan,
Thanks, Breno Lima
OK I'll try to put some images onto gdrive for you.
Do you have an mx7 board which _doesn't_ have the OTP fuses blown ?
You will need to
1. Program SRK efuse index 3 to the same SRK we use 2. Set the part into secure-boot mode
If you don't have a *spare* board - we'll have to figure out how to regenerate the signed images in the same format with your SRK hashes.
--- bod
The various i.MX BootROMs containing the High Assurance Boot (HAB) block rely on a data structure called the Image Vector Table (IVT) to describe to the BootROM where to locate various data-structures used by HAB during authentication.
This patch adds a definition of the IVT header for use in later patches, where we will break the current incorrect dependence on fixed offsets in favour of an IVT described parsing of incoming binaries.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/include/asm/mach-imx/hab.h | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/arch/arm/include/asm/mach-imx/hab.h b/arch/arm/include/asm/mach-imx/hab.h index b2a8031..28cde38 100644 --- a/arch/arm/include/asm/mach-imx/hab.h +++ b/arch/arm/include/asm/mach-imx/hab.h @@ -10,6 +10,34 @@
#include <linux/types.h>
+/* + * IVT header definitions + * Security Reference Manual for i.MX 7Dual and 7Solo Applications Processors, + * Rev. 0, 03/2017 + * Section : 6.7.1.1 + */ +#define IVT_HEADER_MAGIC 0xD1 +#define IVT_TOTAL_LENGTH 0x20 +#define IVT_HEADER_V1 0x40 +#define IVT_HEADER_V2 0x41 + +struct ivt_header { + uint8_t magic; + uint16_t length; + uint8_t version; +} __attribute__((packed)); + +struct ivt { + struct ivt_header hdr; /* IVT header above */ + uint32_t entry; /* Absolute address of first instruction */ + uint32_t reserved1; /* Reserved should be zero */ + uint32_t dcd; /* Absolute address of the image DCD */ + uint32_t boot; /* Absolute address of the boot data */ + uint32_t self; /* Absolute address of the IVT */ + uint32_t csf; /* Absolute address of the CSF */ + uint32_t reserved2; /* Reserved should be zero */ +}; + /* -------- start of HAB API updates ------------*/ /* The following are taken from HAB4 SIS */
The IVT header contains a magic number, fixed length and one of two version identifiers. Validate these settings before doing anything with a putative IVT binary.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/mach-imx/hab.c | 36 ++++++++++++++++++++++++++++++++++-- 1 file changed, 34 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 1d7b069..cb6214d 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -80,6 +80,31 @@
+static int ivt_header_error(const char *err_str, struct ivt_header *ivt_hdr) +{ + printf("%s magic=0x%x length=0x%02x version=0x%x\n", err_str, + ivt_hdr->magic, ivt_hdr->length, ivt_hdr->version); + + return 1; +} + +static int verify_ivt_header(struct ivt_header *ivt_hdr) +{ + int result = 0; + + if (ivt_hdr->magic != IVT_HEADER_MAGIC) + result = ivt_header_error("bad magic", ivt_hdr); + + if (be16_to_cpu(ivt_hdr->length) != IVT_TOTAL_LENGTH) + result = ivt_header_error("bad length", ivt_hdr); + + if (ivt_hdr->version != IVT_HEADER_V1 && + ivt_hdr->version != IVT_HEADER_V2) + result = ivt_header_error("bad version", ivt_hdr); + + return result; +} + #if !defined(CONFIG_SPL_BUILD)
#define MAX_RECORD_BYTES (8*1024) /* 4 kbytes */ @@ -394,6 +419,8 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size, hab_rvt_authenticate_image_t *hab_rvt_authenticate_image; hab_rvt_entry_t *hab_rvt_entry; hab_rvt_exit_t *hab_rvt_exit; + struct ivt *ivt; + struct ivt_header *ivt_hdr;
hab_rvt_authenticate_image = hab_rvt_authenticate_image_p; hab_rvt_entry = hab_rvt_entry_p; @@ -416,6 +443,13 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size,
/* Calculate IVT address header */ ivt_addr = ddr_start + ivt_offset; + ivt = (struct ivt *)ivt_addr; + ivt_hdr = &ivt->hdr; + + /* Verify IVT header bugging out on error */ + if (verify_ivt_header(ivt_hdr)) + goto hab_caam_clock_disable; + start = ddr_start; bytes = image_size; #ifdef DEBUG @@ -435,8 +469,6 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size, printf("\tivt_offset = 0x%x\n", ivt_offset); printf("\tstart = 0x%08lx\n", start); printf("\tbytes = 0x%x\n", bytes); -#else - (void)ivt_addr; #endif /* * If the MMU is enabled, we have to notify the ROM
The IVT is a self-describing structure which contains a self field. The self field is the absolute physical base address the IVT ought to be at in memory. Use the IVT self field to validate the calculated ivt_addr bugging out if the two values differ.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/mach-imx/hab.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index cb6214d..479ed96 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -450,6 +450,13 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size, if (verify_ivt_header(ivt_hdr)) goto hab_caam_clock_disable;
+ /* Verify IVT body */ + if (ivt->self != ivt_addr) { + printf("ivt->self 0x%08x pointer is 0x%08x\n", + ivt->self, ivt_addr); + goto hab_caam_clock_disable; + } + start = ddr_start; bytes = image_size; #ifdef DEBUG
Previous patches added IVT header verification steps. We shouldn't call hab_rvt_entry() until we have done the basic header verification steps.
This patch changes the time we make the hab_rvt_entry() call so that it only takes place if we are happy with the IVT header sanity checks.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/mach-imx/hab.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 479ed96..e325d1f 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -436,11 +436,6 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size,
- if (hab_rvt_entry() != HAB_SUCCESS) { - puts("hab entry function fail\n"); - goto hab_caam_clock_disable; - } - /* Calculate IVT address header */ ivt_addr = ddr_start + ivt_offset; ivt = (struct ivt *)ivt_addr; @@ -459,6 +454,12 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size,
start = ddr_start; bytes = image_size; + + if (hab_rvt_entry() != HAB_SUCCESS) { + puts("hab entry function fail\n"); + goto hab_caam_clock_disable; + } + #ifdef DEBUG printf("\nivt_offset = 0x%x, ivt addr = 0x%x\n", ivt_offset, ivt_addr); puts("Dumping IVT\n");
The IVT gives the absolute address of the CSF. There is no requirement for the CSF to be located adjacent to the IVT so lets use the address provided in the IVT header instead of the hard-coded fixed CSF offset currently in place.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/mach-imx/hab.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index e325d1f..f9b8cb7 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -466,8 +466,7 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size, print_buffer(ivt_addr, (void *)(ivt_addr), 4, 0x8, 0);
puts("Dumping CSF Header\n"); - print_buffer(ivt_addr + IVT_SIZE, (void *)(ivt_addr + IVT_SIZE), 4, - 0x10, 0); + print_buffer(ivt->csf, (void *)(ivt->csf), 4, 0x10, 0);
This patch enables printout of the IVT entry, dcd and csf data fields.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/mach-imx/hab.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index f9b8cb7..7c3a621 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -462,6 +462,8 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size,
#ifdef DEBUG printf("\nivt_offset = 0x%x, ivt addr = 0x%x\n", ivt_offset, ivt_addr); + printf("ivt entry = 0x%08x, dcd = 0x%08x, csf = 0x%08x\n", ivt->entry, + ivt->dcd, ivt->csf); puts("Dumping IVT\n"); print_buffer(ivt_addr, (void *)(ivt_addr), 4, 0x8, 0);
The hab_rvt_check_target() callback according to the HABv4 documentation:
"This function reports whether or not a given target region is allowed for either peripheral configuration or image loading in memory. It is intended for use by post-ROM boot stage components, via the ROM Vector Table, in order to avoid configuring security-sensitive peripherals, or loading images over sensitive memory regions or outside recognized memory devices in the address map."
It is a useful function to support as a precursor to calling into authenticate_image() to validate the target memory region is good.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/include/asm/mach-imx/hab.h | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/include/asm/mach-imx/hab.h b/arch/arm/include/asm/mach-imx/hab.h index 28cde38..14e1220 100644 --- a/arch/arm/include/asm/mach-imx/hab.h +++ b/arch/arm/include/asm/mach-imx/hab.h @@ -113,6 +113,12 @@ enum hab_context { HAB_CTX_MAX };
+enum hab_target { + HAB_TGT_MEMORY = 0x0f, + HAB_TGT_PERIPHERAL = 0xf0, + HAB_TGT_ANY = 0x55, +}; + struct imx_sec_config_fuse_t { int bank; int word; @@ -132,6 +138,8 @@ typedef enum hab_status hab_rvt_entry_t(void); typedef enum hab_status hab_rvt_exit_t(void); typedef void *hab_rvt_authenticate_image_t(uint8_t, ptrdiff_t, void **, size_t *, hab_loader_callback_f_t); +typedef enum hab_status hab_rvt_check_target_t(enum hab_target, const void *, + size_t); typedef void hapi_clock_init_t(void);
#define HAB_ENG_ANY 0x00 /* Select first compatible engine */ @@ -158,6 +166,7 @@ typedef void hapi_clock_init_t(void);
#define HAB_RVT_ENTRY (*(uint32_t *)(HAB_RVT_BASE + 0x04)) #define HAB_RVT_EXIT (*(uint32_t *)(HAB_RVT_BASE + 0x08)) +#define HAB_RVT_CHECK_TARGET (*(uint32_t *)(HAB_RVT_BASE + 0x0C)) #define HAB_RVT_AUTHENTICATE_IMAGE (*(uint32_t *)(HAB_RVT_BASE + 0x10)) #define HAB_RVT_REPORT_EVENT (*(uint32_t *)(HAB_RVT_BASE + 0x20)) #define HAB_RVT_REPORT_STATUS (*(uint32_t *)(HAB_RVT_BASE + 0x24))
This patch implements the basic callback hooks for hab_rvt_check_target() for BootROM code using the older BootROM address layout - in my test case the i.MX7. Code based on new BootROM callbacks will just have HAB_SUCCESS as a result code. Adding support for the new BootROM callbacks is a TODO.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/mach-imx/hab.c | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 7c3a621..858f2a7 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -70,6 +70,24 @@ ((hab_rvt_exit_t *)HAB_RVT_EXIT) \ )
+static inline enum hab_status hab_rvt_check_target_new(enum hab_target target, + const void *start, + size_t bytes) +{ + return HAB_SUCCESS; +} + +#define hab_rvt_check_target_p \ +( \ + (is_mx6dqp()) ? \ + ((hab_rvt_check_target_t *)hab_rvt_check_target_new) : \ + (is_mx6dq() && (soc_rev() >= CHIP_REV_1_5)) ? \ + ((hab_rvt_check_target_t *)hab_rvt_check_target_new) : \ + (is_mx6sdl() && (soc_rev() >= CHIP_REV_1_2)) ? \ + ((hab_rvt_check_target_t *)hab_rvt_check_target_new) : \ + ((hab_rvt_check_target_t *)HAB_RVT_CHECK_TARGET) \ +) + #define ALIGN_SIZE 0x1000 #define MX6DQ_PU_IROM_MMU_EN_VAR 0x009024a8 #define MX6DLS_PU_IROM_MMU_EN_VAR 0x00901dd0
Add a hab_rvt_check_target() step to authenticate_image() as a sanity check for the target memory region authenticate_image() will run over, prior to making the BootROM authentication callback itself.
This check is recommended by the HAB documentation so it makes sense to adhere to the guidance and perform that check as directed.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/mach-imx/hab.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 858f2a7..92d342b 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -437,12 +437,15 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size, hab_rvt_authenticate_image_t *hab_rvt_authenticate_image; hab_rvt_entry_t *hab_rvt_entry; hab_rvt_exit_t *hab_rvt_exit; + hab_rvt_check_target_t *hab_rvt_check_target; struct ivt *ivt; struct ivt_header *ivt_hdr; + enum hab_status status;
hab_rvt_authenticate_image = hab_rvt_authenticate_image_p; hab_rvt_entry = hab_rvt_entry_p; hab_rvt_exit = hab_rvt_exit_p; + hab_rvt_check_target = hab_rvt_check_target_p;
if (!is_hab_enabled()) { puts("hab fuse not enabled\n"); @@ -478,6 +481,12 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size, goto hab_caam_clock_disable; }
+ status = hab_rvt_check_target(HAB_TGT_MEMORY, (void *)ddr_start, bytes); + if (status != HAB_SUCCESS) { + printf("HAB check target 0x%08x-0x%08x fail\n", + ddr_start, ddr_start + bytes); + goto hab_caam_clock_disable; + } #ifdef DEBUG printf("\nivt_offset = 0x%x, ivt addr = 0x%x\n", ivt_offset, ivt_addr); printf("ivt entry = 0x%08x, dcd = 0x%08x, csf = 0x%08x\n", ivt->entry,
The current flow of authenticate_image() will print the HAB event log even if we reject an element of the IVT header before ever calling into the ROM. This can be confusing.
This patch changes the flow of the code so that the HAB event log is only printed out if we have called into the ROM and received some sort of status code.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Suggested-by: Cc: Breno Matheus Lima brenomatheus@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com --- arch/arm/mach-imx/hab.c | 12 +++++++----- 1 file changed, 7 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 92d342b..d574f2e 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -478,14 +478,14 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size,
if (hab_rvt_entry() != HAB_SUCCESS) { puts("hab entry function fail\n"); - goto hab_caam_clock_disable; + goto hab_exit_failure_print_status; }
status = hab_rvt_check_target(HAB_TGT_MEMORY, (void *)ddr_start, bytes); if (status != HAB_SUCCESS) { printf("HAB check target 0x%08x-0x%08x fail\n", ddr_start, ddr_start + bytes); - goto hab_caam_clock_disable; + goto hab_exit_failure_print_status; } #ifdef DEBUG printf("\nivt_offset = 0x%x, ivt addr = 0x%x\n", ivt_offset, ivt_addr); @@ -558,12 +558,14 @@ int authenticate_image(uint32_t ddr_start, uint32_t image_size, load_addr = 0; }
-hab_caam_clock_disable: - hab_caam_clock_enable(0); - +hab_exit_failure_print_status: #if !defined(CONFIG_SPL_BUILD) get_hab_status(); #endif + +hab_caam_clock_disable: + hab_caam_clock_enable(0); + if (load_addr != 0) result = 0;
There is no need to export these functions and data structures externally. Make them all static now.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/mach-imx/hab.c | 159 +++++++++++++++++++++++++----------------------- 1 file changed, 84 insertions(+), 75 deletions(-)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index d574f2e..b2c3875 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -135,73 +135,81 @@ struct record { bool any_rec_flag; };
-char *rsn_str[] = {"RSN = HAB_RSN_ANY (0x00)\n", - "RSN = HAB_ENG_FAIL (0x30)\n", - "RSN = HAB_INV_ADDRESS (0x22)\n", - "RSN = HAB_INV_ASSERTION (0x0C)\n", - "RSN = HAB_INV_CALL (0x28)\n", - "RSN = HAB_INV_CERTIFICATE (0x21)\n", - "RSN = HAB_INV_COMMAND (0x06)\n", - "RSN = HAB_INV_CSF (0x11)\n", - "RSN = HAB_INV_DCD (0x27)\n", - "RSN = HAB_INV_INDEX (0x0F)\n", - "RSN = HAB_INV_IVT (0x05)\n", - "RSN = HAB_INV_KEY (0x1D)\n", - "RSN = HAB_INV_RETURN (0x1E)\n", - "RSN = HAB_INV_SIGNATURE (0x18)\n", - "RSN = HAB_INV_SIZE (0x17)\n", - "RSN = HAB_MEM_FAIL (0x2E)\n", - "RSN = HAB_OVR_COUNT (0x2B)\n", - "RSN = HAB_OVR_STORAGE (0x2D)\n", - "RSN = HAB_UNS_ALGORITHM (0x12)\n", - "RSN = HAB_UNS_COMMAND (0x03)\n", - "RSN = HAB_UNS_ENGINE (0x0A)\n", - "RSN = HAB_UNS_ITEM (0x24)\n", - "RSN = HAB_UNS_KEY (0x1B)\n", - "RSN = HAB_UNS_PROTOCOL (0x14)\n", - "RSN = HAB_UNS_STATE (0x09)\n", - "RSN = INVALID\n", - NULL}; - -char *sts_str[] = {"STS = HAB_SUCCESS (0xF0)\n", - "STS = HAB_FAILURE (0x33)\n", - "STS = HAB_WARNING (0x69)\n", - "STS = INVALID\n", - NULL}; - -char *eng_str[] = {"ENG = HAB_ENG_ANY (0x00)\n", - "ENG = HAB_ENG_SCC (0x03)\n", - "ENG = HAB_ENG_RTIC (0x05)\n", - "ENG = HAB_ENG_SAHARA (0x06)\n", - "ENG = HAB_ENG_CSU (0x0A)\n", - "ENG = HAB_ENG_SRTC (0x0C)\n", - "ENG = HAB_ENG_DCP (0x1B)\n", - "ENG = HAB_ENG_CAAM (0x1D)\n", - "ENG = HAB_ENG_SNVS (0x1E)\n", - "ENG = HAB_ENG_OCOTP (0x21)\n", - "ENG = HAB_ENG_DTCP (0x22)\n", - "ENG = HAB_ENG_ROM (0x36)\n", - "ENG = HAB_ENG_HDCP (0x24)\n", - "ENG = HAB_ENG_RTL (0x77)\n", - "ENG = HAB_ENG_SW (0xFF)\n", - "ENG = INVALID\n", - NULL}; - -char *ctx_str[] = {"CTX = HAB_CTX_ANY(0x00)\n", - "CTX = HAB_CTX_FAB (0xFF)\n", - "CTX = HAB_CTX_ENTRY (0xE1)\n", - "CTX = HAB_CTX_TARGET (0x33)\n", - "CTX = HAB_CTX_AUTHENTICATE (0x0A)\n", - "CTX = HAB_CTX_DCD (0xDD)\n", - "CTX = HAB_CTX_CSF (0xCF)\n", - "CTX = HAB_CTX_COMMAND (0xC0)\n", - "CTX = HAB_CTX_AUT_DAT (0xDB)\n", - "CTX = HAB_CTX_ASSERT (0xA0)\n", - "CTX = HAB_CTX_EXIT (0xEE)\n", - "CTX = INVALID\n", - NULL}; - -uint8_t hab_statuses[5] = { +static char *rsn_str[] = { + "RSN = HAB_RSN_ANY (0x00)\n", + "RSN = HAB_ENG_FAIL (0x30)\n", + "RSN = HAB_INV_ADDRESS (0x22)\n", + "RSN = HAB_INV_ASSERTION (0x0C)\n", + "RSN = HAB_INV_CALL (0x28)\n", + "RSN = HAB_INV_CERTIFICATE (0x21)\n", + "RSN = HAB_INV_COMMAND (0x06)\n", + "RSN = HAB_INV_CSF (0x11)\n", + "RSN = HAB_INV_DCD (0x27)\n", + "RSN = HAB_INV_INDEX (0x0F)\n", + "RSN = HAB_INV_IVT (0x05)\n", + "RSN = HAB_INV_KEY (0x1D)\n", + "RSN = HAB_INV_RETURN (0x1E)\n", + "RSN = HAB_INV_SIGNATURE (0x18)\n", + "RSN = HAB_INV_SIZE (0x17)\n", + "RSN = HAB_MEM_FAIL (0x2E)\n", + "RSN = HAB_OVR_COUNT (0x2B)\n", + "RSN = HAB_OVR_STORAGE (0x2D)\n", + "RSN = HAB_UNS_ALGORITHM (0x12)\n", + "RSN = HAB_UNS_COMMAND (0x03)\n", + "RSN = HAB_UNS_ENGINE (0x0A)\n", + "RSN = HAB_UNS_ITEM (0x24)\n", + "RSN = HAB_UNS_KEY (0x1B)\n", + "RSN = HAB_UNS_PROTOCOL (0x14)\n", + "RSN = HAB_UNS_STATE (0x09)\n", + "RSN = INVALID\n", + NULL +}; + +static char *sts_str[] = { + "STS = HAB_SUCCESS (0xF0)\n", + "STS = HAB_FAILURE (0x33)\n", + "STS = HAB_WARNING (0x69)\n", + "STS = INVALID\n", + NULL +}; + +static char *eng_str[] = { + "ENG = HAB_ENG_ANY (0x00)\n", + "ENG = HAB_ENG_SCC (0x03)\n", + "ENG = HAB_ENG_RTIC (0x05)\n", + "ENG = HAB_ENG_SAHARA (0x06)\n", + "ENG = HAB_ENG_CSU (0x0A)\n", + "ENG = HAB_ENG_SRTC (0x0C)\n", + "ENG = HAB_ENG_DCP (0x1B)\n", + "ENG = HAB_ENG_CAAM (0x1D)\n", + "ENG = HAB_ENG_SNVS (0x1E)\n", + "ENG = HAB_ENG_OCOTP (0x21)\n", + "ENG = HAB_ENG_DTCP (0x22)\n", + "ENG = HAB_ENG_ROM (0x36)\n", + "ENG = HAB_ENG_HDCP (0x24)\n", + "ENG = HAB_ENG_RTL (0x77)\n", + "ENG = HAB_ENG_SW (0xFF)\n", + "ENG = INVALID\n", + NULL +}; + +static char *ctx_str[] = { + "CTX = HAB_CTX_ANY(0x00)\n", + "CTX = HAB_CTX_FAB (0xFF)\n", + "CTX = HAB_CTX_ENTRY (0xE1)\n", + "CTX = HAB_CTX_TARGET (0x33)\n", + "CTX = HAB_CTX_AUTHENTICATE (0x0A)\n", + "CTX = HAB_CTX_DCD (0xDD)\n", + "CTX = HAB_CTX_CSF (0xCF)\n", + "CTX = HAB_CTX_COMMAND (0xC0)\n", + "CTX = HAB_CTX_AUT_DAT (0xDB)\n", + "CTX = HAB_CTX_ASSERT (0xA0)\n", + "CTX = HAB_CTX_EXIT (0xEE)\n", + "CTX = INVALID\n", + NULL +}; + +static uint8_t hab_statuses[5] = { HAB_STS_ANY, HAB_FAILURE, HAB_WARNING, @@ -209,7 +217,7 @@ uint8_t hab_statuses[5] = { -1 };
-uint8_t hab_reasons[26] = { +static uint8_t hab_reasons[26] = { HAB_RSN_ANY, HAB_ENG_FAIL, HAB_INV_ADDRESS, @@ -238,7 +246,7 @@ uint8_t hab_reasons[26] = { -1 };
-uint8_t hab_contexts[12] = { +static uint8_t hab_contexts[12] = { HAB_CTX_ANY, HAB_CTX_FAB, HAB_CTX_ENTRY, @@ -253,7 +261,7 @@ uint8_t hab_contexts[12] = { -1 };
-uint8_t hab_engines[16] = { +static uint8_t hab_engines[16] = { HAB_ENG_ANY, HAB_ENG_SCC, HAB_ENG_RTIC, @@ -284,7 +292,7 @@ static inline uint8_t get_idx(uint8_t *list, uint8_t tgt) return -1; }
-void process_event_record(uint8_t *event_data, size_t bytes) +static void process_event_record(uint8_t *event_data, size_t bytes) { struct record *rec = (struct record *)event_data;
@@ -294,7 +302,7 @@ void process_event_record(uint8_t *event_data, size_t bytes) printf("%s", eng_str[get_idx(hab_engines, rec->contents[3])]); }
-void display_event(uint8_t *event_data, size_t bytes) +static void display_event(uint8_t *event_data, size_t bytes) { uint32_t i;
@@ -313,7 +321,7 @@ void display_event(uint8_t *event_data, size_t bytes) process_event_record(event_data, bytes); }
-int get_hab_status(void) +static int get_hab_status(void) { uint32_t index = 0; /* Loop index */ uint8_t event_data[128]; /* Event data buffer */ @@ -358,7 +366,8 @@ int get_hab_status(void) return 0; }
-int do_hab_status(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +static int do_hab_status(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) { if ((argc != 1)) { cmd_usage(cmdtp); @@ -371,7 +380,7 @@ int do_hab_status(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) }
static int do_authenticate_image(cmd_tbl_t *cmdtp, int flag, int argc, - char * const argv[]) + char * const argv[]) { ulong addr, length, ivt_offset; int rcode = 0;
Tidy up the HAB namespace a bit by prefixing external functions with imx_hab. All external facing functions past this point will be prefixed in the same way to make the fact we are doing IMX HAB activities clear from reading the code. authenticate_image() could mean anything imx_hab_authenticate_image() is on the other hand very explicit.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/include/asm/mach-imx/hab.h | 4 ++-- arch/arm/mach-imx/hab.c | 6 +++--- arch/arm/mach-imx/spl.c | 5 +++-- 3 files changed, 8 insertions(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/mach-imx/hab.h b/arch/arm/include/asm/mach-imx/hab.h index 14e1220..98bc1bd 100644 --- a/arch/arm/include/asm/mach-imx/hab.h +++ b/arch/arm/include/asm/mach-imx/hab.h @@ -185,7 +185,7 @@ typedef void hapi_clock_init_t(void);
-int authenticate_image(uint32_t ddr_start, uint32_t image_size, - uint32_t ivt_offset); +int imx_hab_authenticate_image(uint32_t ddr_start, uint32_t image_size, + uint32_t ivt_offset);
#endif diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index b2c3875..c72508b 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -392,7 +392,7 @@ static int do_authenticate_image(cmd_tbl_t *cmdtp, int flag, int argc, length = simple_strtoul(argv[2], NULL, 16); ivt_offset = simple_strtoul(argv[3], NULL, 16);
- rcode = authenticate_image(addr, length, ivt_offset); + rcode = imx_hab_authenticate_image(addr, length, ivt_offset); if (rcode == 0) rcode = CMD_RET_SUCCESS; else @@ -435,8 +435,8 @@ static bool is_hab_enabled(void) return (reg & IS_HAB_ENABLED_BIT) == IS_HAB_ENABLED_BIT; }
-int authenticate_image(uint32_t ddr_start, uint32_t image_size, - uint32_t ivt_offset) +int imx_hab_authenticate_image(uint32_t ddr_start, uint32_t image_size, + uint32_t ivt_offset) { uint32_t load_addr = 0; size_t bytes; diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index e5d0c35..a5478ce 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -196,8 +196,9 @@ __weak void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) /* HAB looks for the CSF at the end of the authenticated data therefore, * we need to subtract the size of the CSF from the actual filesize */ offset = spl_image->size - CONFIG_CSF_SIZE; - if (!authenticate_image(spl_image->load_addr, - offset + IVT_SIZE + CSF_PAD_SIZE, offset)) { + if (!imx_hab_authenticate_image(spl_image->load_addr, + offset + IVT_SIZE + CSF_PAD_SIZE, + offset)) { image_entry(); } else { puts("spl: ERROR: image authentication unsuccessful\n");
Understanding if the HAB is enabled is something that we want to interrogate and report on outside of the HAB layer. First step to that is renaming the relevant function to match the previously introduced external naming convention imx_hab_function()
The name imx_hab_is_hab_enabled() is a tautology. A more logical name is imx_hab_is_enabled().
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/mach-imx/hab.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index c72508b..f39174d 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -96,7 +96,7 @@ static inline enum hab_status hab_rvt_check_target_new(enum hab_target target, (is_soc_type(MXC_SOC_MX7ULP) ? 0x80000000 : \ (is_soc_type(MXC_SOC_MX7) ? 0x2000000 : 0x2))
-static bool is_hab_enabled(void); +static bool imx_hab_is_enabled(void);
static int ivt_header_error(const char *err_str, struct ivt_header *ivt_hdr) { @@ -334,7 +334,7 @@ static int get_hab_status(void) hab_rvt_report_event = hab_rvt_report_event_p; hab_rvt_report_status = hab_rvt_report_status_p;
- if (is_hab_enabled()) + if (imx_hab_is_enabled()) puts("\nSecure boot enabled\n"); else puts("\nSecure boot disabled\n"); @@ -419,7 +419,7 @@ U_BOOT_CMD(
#endif /* !defined(CONFIG_SPL_BUILD) */
-static bool is_hab_enabled(void) +static bool imx_hab_is_enabled(void) { struct imx_sec_config_fuse_t *fuse = (struct imx_sec_config_fuse_t *)&imx_sec_config_fuse; @@ -456,7 +456,7 @@ int imx_hab_authenticate_image(uint32_t ddr_start, uint32_t image_size, hab_rvt_exit = hab_rvt_exit_p; hab_rvt_check_target = hab_rvt_check_target_p;
- if (!is_hab_enabled()) { + if (!imx_hab_is_enabled()) { puts("hab fuse not enabled\n"); return result; }
It will be helpful to boot commands to know if the HAB is enabled. Export imx_hab_is_enabled() now to facilitate further work with this data-point in a secure-boot context.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/include/asm/mach-imx/hab.h | 1 + arch/arm/mach-imx/hab.c | 4 +--- 2 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/mach-imx/hab.h b/arch/arm/include/asm/mach-imx/hab.h index 98bc1bd..5c13aff 100644 --- a/arch/arm/include/asm/mach-imx/hab.h +++ b/arch/arm/include/asm/mach-imx/hab.h @@ -187,5 +187,6 @@ typedef void hapi_clock_init_t(void);
int imx_hab_authenticate_image(uint32_t ddr_start, uint32_t image_size, uint32_t ivt_offset); +bool imx_hab_is_enabled(void);
#endif diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index f39174d..99834c5 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -96,8 +96,6 @@ static inline enum hab_status hab_rvt_check_target_new(enum hab_target target, (is_soc_type(MXC_SOC_MX7ULP) ? 0x80000000 : \ (is_soc_type(MXC_SOC_MX7) ? 0x2000000 : 0x2))
-static bool imx_hab_is_enabled(void); - static int ivt_header_error(const char *err_str, struct ivt_header *ivt_hdr) { printf("%s magic=0x%x length=0x%02x version=0x%x\n", err_str, @@ -419,7 +417,7 @@ U_BOOT_CMD(
-static bool imx_hab_is_enabled(void) +bool imx_hab_is_enabled(void) { struct imx_sec_config_fuse_t *fuse = (struct imx_sec_config_fuse_t *)&imx_sec_config_fuse;
The hab_rvt_failsafe() callback according to the HABv4 documentation:
"This function provides a safe path when image authentication has failed and all possible boot paths have been exhausted. It is intended for use by post-ROM boot stage components, via the ROM Vector Table."
Once invoked the part will drop down to its BootROM USB recovery mode. Should it be the case that the part is in secure boot mode - only an appropriately signed binary will be accepted by the ROM and subsequently executed.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/include/asm/mach-imx/hab.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/include/asm/mach-imx/hab.h b/arch/arm/include/asm/mach-imx/hab.h index 5c13aff..a0cb19d 100644 --- a/arch/arm/include/asm/mach-imx/hab.h +++ b/arch/arm/include/asm/mach-imx/hab.h @@ -140,6 +140,7 @@ typedef void *hab_rvt_authenticate_image_t(uint8_t, ptrdiff_t, void **, size_t *, hab_loader_callback_f_t); typedef enum hab_status hab_rvt_check_target_t(enum hab_target, const void *, size_t); +typedef void hab_rvt_failsafe_t(void); typedef void hapi_clock_init_t(void);
#define HAB_ENG_ANY 0x00 /* Select first compatible engine */ @@ -170,6 +171,7 @@ typedef void hapi_clock_init_t(void); #define HAB_RVT_AUTHENTICATE_IMAGE (*(uint32_t *)(HAB_RVT_BASE + 0x10)) #define HAB_RVT_REPORT_EVENT (*(uint32_t *)(HAB_RVT_BASE + 0x20)) #define HAB_RVT_REPORT_STATUS (*(uint32_t *)(HAB_RVT_BASE + 0x24)) +#define HAB_RVT_FAILSAFE (*(uint32_t *)(HAB_RVT_BASE + 0x28))
#define HAB_RVT_REPORT_EVENT_NEW (*(uint32_t *)0x000000B8) #define HAB_RVT_REPORT_STATUS_NEW (*(uint32_t *)0x000000BC)
This patch implements the basic callback hooks for hab_rvt_check_failsafe for BootROM code using the older BootROM address layout - in my test case the i.MX7. Code based on new BootROM callbacks will just do nothing and there's definitely a TODO to implement that extra functionality on the alternative BootROM API.
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 99834c5..17dac16 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -70,6 +70,21 @@ ((hab_rvt_exit_t *)HAB_RVT_EXIT) \ )
+static inline void hab_rvt_failsafe_new(void) +{ +} + +#define hab_rvt_failsafe_p \ +( \ + (is_mx6dqp()) ? \ + ((hab_rvt_failsafe_t *)hab_rvt_failsafe_new) : \ + (is_mx6dq() && (soc_rev() >= CHIP_REV_1_5)) ? \ + ((hab_rvt_failsafe_t *)hab_rvt_failsafe_new) : \ + (is_mx6sdl() && (soc_rev() >= CHIP_REV_1_2)) ? \ + ((hab_rvt_failsafe_t *)hab_rvt_failsafe_new) : \ + ((hab_rvt_failsafe_t *)HAB_RVT_FAILSAFE) \ +) + static inline enum hab_status hab_rvt_check_target_new(enum hab_target target, const void *start, size_t bytes)
hab_failsafe when called puts the part into BootROM recovery mode. This will allow u-boot scripts to script the dropping down into recovery mode.
=> hab_failsafe
Shows the i.MX7 appear as "hiddev0,hidraw5: USB HID v1.10 Device [Freescale SemiConductor Inc SP Blank ULT1] " in a Linux dmesg thus allowing download of a new image via the BootROM USB download protocol routine.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Sven Ebenfeld sven.ebenfeld@gmail.com Cc: George McCollister george.mccollister@gmail.com Cc: Breno Matheus Lima brenomatheus@gmail.com --- arch/arm/mach-imx/hab.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 17dac16..79ee4d5 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -414,6 +414,22 @@ static int do_authenticate_image(cmd_tbl_t *cmdtp, int flag, int argc, return rcode; }
+static int do_hab_failsafe(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + hab_rvt_failsafe_t *hab_rvt_failsafe; + + if (argc != 1) { + cmd_usage(cmdtp); + return 1; + } + + hab_rvt_failsafe = hab_rvt_failsafe_p; + hab_rvt_failsafe(); + + return 0; +} + U_BOOT_CMD( hab_status, CONFIG_SYS_MAXARGS, 1, do_hab_status, "display HAB status", @@ -429,6 +445,11 @@ U_BOOT_CMD( "ivt_offset - hex offset of IVT in the image" );
+U_BOOT_CMD( + hab_failsafe, CONFIG_SYS_MAXARGS, 1, do_hab_failsafe, + "run BootROM failsafe routine", + "" + );
Breno Matheus Lima
Bryan O'Donoghue
