[U-Boot] [U-BOOT][PATCH V3] sunxi: Use clrsetbits_le32 instead of multiple instruction
From: Michael Trimarchi michael@amarulasolutions.com
This will improve code readabilty
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- Changelogs: V1->V2: None V2->V3: Fix use of clrsetbits_le32 and setbits_le32 functions --- arch/arm/mach-sunxi/dram_sun8i_a33.c | 7 ++----- 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-sunxi/dram_sun8i_a33.c b/arch/arm/mach-sunxi/dram_sun8i_a33.c index 1da2727f9874..09742cbc2b55 100644 --- a/arch/arm/mach-sunxi/dram_sun8i_a33.c +++ b/arch/arm/mach-sunxi/dram_sun8i_a33.c @@ -148,11 +148,8 @@ static void auto_set_timing_para(struct dram_para *para) reg_val = (tcksrx << 24) | (tcksre << 16) | (tckesr << 8) | (tcke << 0); writel(reg_val, &mctl_ctl->dramtmg5); /* Set two rank timing and exit self-refresh timing */ - reg_val = readl(&mctl_ctl->dramtmg8); - reg_val &= ~(0xff << 8); - reg_val &= ~(0xff << 0); - reg_val |= (0x33 << 8); - reg_val |= (0x8 << 0); + clrsetbits_le32(&mctl_ctl->dramtmg8, (0xff << 8) | (0xff << 0)); + setbits_le32(&mctl_ctl->dramtmg8, (0x33 << 8) | (0x8 << 0)); writel(reg_val, &mctl_ctl->dramtmg8); /* Set phy interface time */ reg_val = (0x2 << 24) | (t_rdata_en << 16) | (0x1 << 8)
Please ignore this patch,
I have sent this patch as a part of original series.
Sorry for the noise.
Thanks and regards, Shyam
On Fri, Mar 15, 2019 at 3:27 PM Shyam Saini shyam.saini@amarulasolutions.com wrote:
-- 2.11.0
Shyam Saini
