[U-Boot] [PATCH] km/common: remove unused function declarations
Cc: Wolfgang Denk wd@denx.de Cc: Heiko Schocher hs@denx.de Signed-off-by: Holger Brunck holger.brunck@keymile.com --- board/keymile/common/common.h | 9 --------- 1 file changed, 9 deletions(-)
diff --git a/board/keymile/common/common.h b/board/keymile/common/common.h index c74f569a61..81a0af0c3c 100644 --- a/board/keymile/common/common.h +++ b/board/keymile/common/common.h @@ -137,15 +137,6 @@ int toggle_eeprom_spi_bus(void); int get_testpin(void);
int set_km_env(void); -int fdt_set_node_and_value(void *blob, - char *nodename, - char *regname, - void *var, - int size); -int fdt_get_node_and_value(void *blob, - char *nodename, - char *propname, - void **var);
#define DELAY_ABORT_SEQ 62 /* @200kHz 9 clocks = 44us, 62us is ok */ #define DELAY_HALF_PERIOD (500 / (CONFIG_SYS_I2C_SPEED / 1000))
Dear Holger,
Thanks!
Acked-by: Wolfgang Denk wd@denx.de
Holger Brunck
