[U-Boot] i.MX28 u-boot SPL fail
Hi, On a custom i.MX28 board I am using u-boot-2015.01. The debug port DUART is not the same as i.MX28, so I changed these settings in iomux.c:
const iomux_cfg_t iomux_setup[] = { /* DUART */ // MX28_PAD_PWM0__DUART_RX, // MX28_PAD_PWM1__DUART_TX,
/* DUART */ /* Unconfigure BOOT ROM default DUART */ MX28_PAD_PWM0__GPIO_3_16, MX28_PAD_PWM1__GPIO_3_17, /* Configure DUART on alternate pins */ MX28_PAD_I2C0_SCL__DUART_RX, MX28_PAD_I2C0_SDA__DUART_TX,
I enabled #define CONFIG_SPL_SERIAL_SUPPORT and built uboot with : make u-boot.sb At last I can program the board only using MfgTools or 'mxsldr', or it seems working. The problem is that I get no messages on output debug port or some random chars every 5, 10 boots
At this point I have some doubts and questions: - is the u-boot.sb suitable to be run from MfgTools? - should I expect any char on the serial debug port? - do I have to use the 'elftosb' tool to convert my binary? (README says not)
TIA -- Marco
2015-02-12 16:57 GMT+01:00 Marco
I have already studied this useful document http://www.denx.de/wiki/pub/U-Boot/MiniSummitELCE2013/2013-u-boot-mxs-withou...
I do not need any encryption. I did exactly the same as explained here http://www.denx-cs.de/doku/?q=m28evkrunuboot
make u-boot.sb
Then I do not have SD nor other storage so I mus use USB firmware upload http://www.denx-cs.de/doku/?q=m28evkusbdownloader
Load u-boot.sb onto the device: sudo ./mxsldr <path to u-boot.sb>
This procedure works perfectly on the i.MX28evk, but doesn't on my custom board so I supposed that u-boot-2015.01 STL works perfecly on i.MX28 and MfgTools upload.
Differences are: - DUART on alternate pins - DDR different - eMMC instead of NAND
I don't know how i.MX28 ROM boot works so my question are: - should I see something on the serial port BEFORE the DDR settings are done? - if I put some code in mxs_common_spl_init() is this executed immediately BEFORE the DDR (and power) settings are done?
Thank you -- Marco
On Fri, Feb 13, 2015 at 8:16 AM, Marco Cavallini cavallini.koan@gmail.com wrote:
make u-boot.sb
Differences are:
- DDR different
You could try this patch to have debug output from SPL: http://git.denx.de/?p=u-boot.git;a=commitdiff;h=950eaf6230496585e72ebb965c45...
Make sure you have DEBUG and CONFIG_SPL_SERIAL_SUPPORT enabled.
Also, double check the DDR initialization for your board.
Regards,
Fabio Estevam
Hi Marco,
Another thing you should check if is if you need this patch for your board: http://git.denx.de/?p=u-boot/u-boot-imx.git;a=commitdiff;h=7a086037071401ee7...
,and then define CONFIG_SYS_MXS_VDD5V_ONLY on your board config file.
Fabio Estevam
Marco Cavallini
