[U-Boot] [PATCH 1/1] efi_driver: set block size for EFI block device
Copy the block size from the block IO protocol to the U-Boot block device descriptor. This information is used by the ext4 file system driver.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_driver/efi_block_device.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/lib/efi_driver/efi_block_device.c b/lib/efi_driver/efi_block_device.c index cf02341931..9de526a95b 100644 --- a/lib/efi_driver/efi_block_device.c +++ b/lib/efi_driver/efi_block_device.c @@ -137,6 +137,7 @@ static int efi_bl_bind(efi_handle_t handle, void *interface) struct efi_block_io *io = interface; int disks; struct efi_blk_platdata *platdata; + struct blk_desc *desc;
EFI_PRINT("%s: handle %p, interface %p\n", __func__, handle, io);
@@ -174,6 +175,11 @@ static int efi_bl_bind(efi_handle_t handle, void *interface) return ret; EFI_PRINT("%s: block device '%s' created\n", __func__, bdev->name);
+ /* Set block size */ + desc = dev_get_uclass_platdata(bdev); + desc->blksz = io->media->block_size; + desc->log2blksz = LOG2(desc->blksz); + /* Create handles for the partions of the block device */ disks = efi_bl_bind_partitions(handle, bdev); EFI_PRINT("Found %d partitions\n", disks); -- 2.20.1
- /* Set block size */
- desc = dev_get_uclass_platdata(bdev);
- desc->blksz = io->media->block_size;
- desc->log2blksz = LOG2(desc->blksz);
I don't think that this is the best place to put them. Better to initialise log2blksz in blk_create_device().
-Takahiro Akashi
desc->blksz can only be set in the EFI code because it is only here that we know the block size.
log2blksz is currently set in:
common/usb_storage.c:1491 drivers/scsi/scsi.c:548 drivers/mmc/mmc.c:2586 drivers/block/ide.c:485 drivers/block/ide.c:530 drivers/block/ide.c:688 drivers/ata/sata.c:100 drivers/nvme/nvme.c:681 disk/part.c:560 disk/part.c:637
blk_create_device() is only called if a board uses the driver model which unfortunately isn't true for all boards.
Once all boards use CONFIG_DM and CONFIG_BLK we can clean up the code.
Best regards
Heinrich
-Takahiro Akashi
? efi_bl_bind() always calls blk_create_device(). Modifying blk_create_device() should work for EFI.
Yes, there are couple of places to set log2blksz in drivers. But if any of them sets log2blksz to anything but LOG2(desc->blksz), it is a bug. You should clean them up before your patch. (As in the case that you have suggested me before) Don't increase local hacks.
-Takahiro Akashi
Best regards
Heinrich
-Takahiro Akashi
AKASHI Takahiro
