[PATCH] ddr: socfpga: Disable the useeccasdata when ECC is enabled
This field allows the FPGA ports to directly access the extra data bits that are normally used to hold the ECC code, so this field must be clear when it's used for ECC data.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Teik Heng Chong teik.heng.chong@intel.com --- drivers/ddr/altera/sdram_gen5.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/ddr/altera/sdram_gen5.c b/drivers/ddr/altera/sdram_gen5.c index 9d69f009e9..085d146179 100644 --- a/drivers/ddr/altera/sdram_gen5.c +++ b/drivers/ddr/altera/sdram_gen5.c @@ -659,6 +659,9 @@ static int altera_gen5_sdram_probe(struct udevice *dev) debug("SDRAM: %ld MiB\n", sdram_size >> 20);
if (sdram_is_ecc_enabled(sdr_ctrl)) { + /* Must set USEECCASDATA to 0 if ECC is enabled */ + clrbits_le32(&sdr_ctrl->static_cfg, + SDR_CTRLGRP_STATICCFG_USEECCASDATA_MASK); sdram_init_ecc_bits(sdram_size); }
