[U-Boot] [PATCH v2 1/3] spi: add support for ARM PL022 SPI controller
This adds support for the ARM PL022 SPI controller for the standard variant (0x00041022) which has a 16bit wide and 8 locations deep TX/RX FIFO.
A few parts were borrowed from the Linux kernel driver.
Cc: Armando Visconti armando.visconti@st.com Cc: Vipin Kumar vipin.kumar@st.com Signed-off-by: Quentin Schulz quentin.schulz@bootlin.com ---
v2: - move header file to include/dm/platform_data, - replace REGA(x) by x + REGA, - surround DT specific code with #define !defined(CONFIG_OF_PLATDATA), - fix tmp speed being stored in a u16 which overflowed and returned the minimum possible rate, - fix speed computation to be the closest to the requested value, not only the closest *below* this value, - init best_* values so that they can safely be used even if no best value is found, - flush FIFO RX queue after the controller is enabled makes more sense to me,
drivers/spi/Kconfig | 8 +- drivers/spi/Makefile | 1 +- drivers/spi/pl022_spi.c | 338 ++++++++++++++++++++++++++++- include/dm/platform_data/pl022_spi.h | 28 ++- 4 files changed, 375 insertions(+) create mode 100644 drivers/spi/pl022_spi.c create mode 100644 include/dm/platform_data/pl022_spi.h
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index dcd719f..7d4d47d 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -125,6 +125,14 @@ config PIC32_SPI to access the SPI NOR flash, MMC-over-SPI on platforms based on Microchip PIC32 family devices.
+config PL022_SPI + bool "ARM AMBA PL022 SSP controller driver" + depends on ARM + help + This selects the ARM(R) AMBA(R) PrimeCell PL022 SSP + controller. If you have an embedded system with an AMBA(R) + bus and a PL022 controller, say Y or M here. + config RENESAS_RPC_SPI bool "Renesas RPC SPI driver" depends on RCAR_GEN3 diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 728e30c..6679987 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -38,6 +38,7 @@ obj-$(CONFIG_MXS_SPI) += mxs_spi.o obj-$(CONFIG_ATCSPI200_SPI) += atcspi200_spi.o obj-$(CONFIG_OMAP3_SPI) += omap3_spi.o obj-$(CONFIG_PIC32_SPI) += pic32_spi.o +obj-$(CONFIG_PL022_SPI) += pl022_spi.o obj-$(CONFIG_RENESAS_RPC_SPI) += renesas_rpc_spi.o obj-$(CONFIG_ROCKCHIP_SPI) += rk_spi.o obj-$(CONFIG_SANDBOX_SPI) += sandbox_spi.o diff --git a/drivers/spi/pl022_spi.c b/drivers/spi/pl022_spi.c new file mode 100644 index 0000000..86b71d2 --- /dev/null +++ b/drivers/spi/pl022_spi.c @@ -0,0 +1,338 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2012 + * Armando Visconti, ST Microelectronics, armando.visconti@st.com. + * + * (C) Copyright 2018 + * Quentin Schulz, Bootlin, quentin.schulz@bootlin.com + * + * Driver for ARM PL022 SPI Controller. + */ + +#include <asm/io.h> +#include <clk.h> +#include <common.h> +#include <dm.h> +#include <dm/platform_data/pl022_spi.h> +#include <fdtdec.h> +#include <linux/bitops.h> +#include <linux/bug.h> +#include <linux/io.h> +#include <linux/kernel.h> +#include <spi.h> + +#define SSP_CR0 0x000 +#define SSP_CR1 0x004 +#define SSP_DR 0x008 +#define SSP_SR 0x00C +#define SSP_CPSR 0x010 +#define SSP_IMSC 0x014 +#define SSP_RIS 0x018 +#define SSP_MIS 0x01C +#define SSP_ICR 0x020 +#define SSP_DMACR 0x024 +#define SSP_CSR 0x030 /* vendor extension */ +#define SSP_ITCR 0x080 +#define SSP_ITIP 0x084 +#define SSP_ITOP 0x088 +#define SSP_TDR 0x08C + +#define SSP_PID0 0xFE0 +#define SSP_PID1 0xFE4 +#define SSP_PID2 0xFE8 +#define SSP_PID3 0xFEC + +#define SSP_CID0 0xFF0 +#define SSP_CID1 0xFF4 +#define SSP_CID2 0xFF8 +#define SSP_CID3 0xFFC + +/* SSP Control Register 0 - SSP_CR0 */ +#define SSP_CR0_SPO (0x1 << 6) +#define SSP_CR0_SPH (0x1 << 7) +#define SSP_CR0_BIT_MODE(x) ((x) - 1) +#define SSP_SCR_MIN (0x00) +#define SSP_SCR_MAX (0xFF) +#define SSP_SCR_SHFT 8 +#define DFLT_CLKRATE 2 + +/* SSP Control Register 1 - SSP_CR1 */ +#define SSP_CR1_MASK_SSE (0x1 << 1) + +#define SSP_CPSR_MIN (0x02) +#define SSP_CPSR_MAX (0xFE) +#define DFLT_PRESCALE (0x40) + +/* SSP Status Register - SSP_SR */ +#define SSP_SR_MASK_TFE (0x1 << 0) /* Transmit FIFO empty */ +#define SSP_SR_MASK_TNF (0x1 << 1) /* Transmit FIFO not full */ +#define SSP_SR_MASK_RNE (0x1 << 2) /* Receive FIFO not empty */ +#define SSP_SR_MASK_RFF (0x1 << 3) /* Receive FIFO full */ +#define SSP_SR_MASK_BSY (0x1 << 4) /* Busy Flag */ + +struct pl022_spi_slave { + void *base; +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + struct clk clk; +#else + unsigned int freq; +#endif +}; + +/* + * ARM PL022 exists in different 'flavors'. + * This drivers currently support the standard variant (0x00041022), that has a + * 16bit wide and 8 locations deep TX/RX FIFO. + */ +static int pl022_is_supported(struct pl022_spi_slave *ps) +{ + /* PL022 version is 0x00041022 */ + if ((readw(ps->base + SSP_PID0) == 0x22) && + (readw(ps->base + SSP_PID1) == 0x10) && + ((readw(ps->base + SSP_PID2) & 0xf) == 0x04) && + (readw(ps->base + SSP_PID3) == 0x00)) + return 1; + + return 0; +} + +#if !CONFIG_IS_ENABLED(OF_PLATDATA) +static int pl022_spi_ofdata_to_platdata(struct udevice *bus) +{ + struct pl022_spi_pdata *plat = bus->platdata; + const void *fdt = gd->fdt_blob; + int node = dev_of_offset(bus); + + plat->addr = fdtdec_get_addr_size(fdt, node, "reg", &plat->size); + + return clk_get_by_index(bus, 0, &plat->clk); +} +#endif + +static int pl022_spi_probe(struct udevice *bus) +{ + struct pl022_spi_pdata *plat = dev_get_platdata(bus); + struct pl022_spi_slave *ps = dev_get_priv(bus); + + ps->base = ioremap(plat->addr, plat->size); +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + ps->clk = plat->clk; +#else + ps->freq = plat->freq; +#endif + + /* Check the PL022 version */ + if (!pl022_is_supported(ps)) + return -ENOTSUPP; + + /* 8 bits per word, high polarity and default clock rate */ + writew(SSP_CR0_BIT_MODE(8), ps->base + SSP_CR0); + writew(DFLT_PRESCALE, ps->base + SSP_CPSR); + + return 0; +} + +static void flush(struct pl022_spi_slave *ps) +{ + do { + while (readw(ps->base + SSP_SR) & SSP_SR_MASK_RNE) + readw(ps->base + SSP_DR); + } while (readw(ps->base + SSP_SR) & SSP_SR_MASK_BSY); +} + +static int pl022_spi_claim_bus(struct udevice *dev) +{ + struct udevice *bus = dev->parent; + struct pl022_spi_slave *ps = dev_get_priv(bus); + u16 reg; + + /* Enable the SPI hardware */ + reg = readw(ps->base + SSP_CR1); + reg |= SSP_CR1_MASK_SSE; + writew(reg, ps->base + SSP_CR1); + + flush(ps); + + return 0; +} + +static int pl022_spi_release_bus(struct udevice *dev) +{ + struct udevice *bus = dev->parent; + struct pl022_spi_slave *ps = dev_get_priv(bus); + u16 reg; + + flush(ps); + + /* Disable the SPI hardware */ + reg = readw(ps->base + SSP_CR1); + reg &= ~SSP_CR1_MASK_SSE; + writew(reg, ps->base + SSP_CR1); + + return 0; +} + +static int pl022_spi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct udevice *bus = dev->parent; + struct pl022_spi_slave *ps = dev_get_priv(bus); + u32 len_tx = 0, len_rx = 0, len; + u32 ret = 0; + const u8 *txp = dout; + u8 *rxp = din, value; + + if (bitlen == 0) + /* Finish any previously submitted transfers */ + return 0; + + /* + * TODO: The controller can do non-multiple-of-8 bit + * transfers, but this driver currently doesn't support it. + * + * It's also not clear how such transfers are supposed to be + * represented as a stream of bytes...this is a limitation of + * the current SPI interface. + */ + if (bitlen % 8) { + /* Errors always terminate an ongoing transfer */ + flags |= SPI_XFER_END; + return -1; + } + + len = bitlen / 8; + + while (len_tx < len) { + if (readw(ps->base + SSP_SR) & SSP_SR_MASK_TNF) { + value = txp ? *txp++ : 0; + writew(value, ps->base + SSP_DR); + len_tx++; + } + + if (readw(ps->base + SSP_SR) & SSP_SR_MASK_RNE) { + value = readw(ps->base + SSP_DR); + if (rxp) + *rxp++ = value; + len_rx++; + } + } + + while (len_rx < len_tx) { + if (readw(ps->base + SSP_SR) & SSP_SR_MASK_RNE) { + value = readw(ps->base + SSP_DR); + if (rxp) + *rxp++ = value; + len_rx++; + } + } + + return ret; +} + +static inline u32 spi_rate(u32 rate, u16 cpsdvsr, u16 scr) +{ + return rate / (cpsdvsr * (1 + scr)); +} + +static int pl022_spi_set_speed(struct udevice *bus, uint speed) +{ + struct pl022_spi_slave *ps = dev_get_priv(bus); + u16 scr = SSP_SCR_MIN, cr0 = 0, cpsr = SSP_CPSR_MIN, best_scr = scr, + best_cpsr = cpsr; + u32 min, max, best_freq = 0, tmp; +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + u32 rate = clk_get_rate(&ps->clk); +#else + u32 rate = ps->freq; +#endif + bool found = false; + + max = spi_rate(rate, SSP_CPSR_MIN, SSP_SCR_MIN); + min = spi_rate(rate, SSP_CPSR_MAX, SSP_SCR_MAX); + + if (speed > max || speed < min) { + pr_err("Tried to set speed to %dHz but min=%d and max=%d\n", + speed, min, max); + return -EINVAL; + } + + while (cpsr <= SSP_CPSR_MAX && !found) { + while (scr <= SSP_SCR_MAX) { + tmp = spi_rate(rate, cpsr, scr); + + if (abs(speed - tmp) < abs(speed - best_freq)) { + best_freq = tmp; + best_cpsr = cpsr; + best_scr = scr; + + if (tmp == speed) { + found = true; + break; + } + } + + scr++; + } + cpsr += 2; + scr = SSP_SCR_MIN; + } + + writew(best_cpsr, ps->base + SSP_CPSR); + cr0 = readw(ps->base + SSP_CR0); + writew(cr0 | (best_scr << SSP_SCR_SHFT), ps->base + SSP_CR0); + + return 0; +} + +static int pl022_spi_set_mode(struct udevice *bus, uint mode) +{ + struct pl022_spi_slave *ps = dev_get_priv(bus); + u16 reg; + + reg = readw(ps->base + SSP_CR0); + reg &= ~(SSP_CR0_SPH | SSP_CR0_SPO); + if (mode & SPI_CPHA) + reg |= SSP_CR0_SPH; + if (mode & SPI_CPOL) + reg |= SSP_CR0_SPO; + writew(reg, ps->base + SSP_CR0); + + return 0; +} + +static int pl022_cs_info(struct udevice *bus, uint cs, + struct spi_cs_info *info) +{ + return 0; +} + +static const struct dm_spi_ops pl022_spi_ops = { + .claim_bus = pl022_spi_claim_bus, + .release_bus = pl022_spi_release_bus, + .xfer = pl022_spi_xfer, + .set_speed = pl022_spi_set_speed, + .set_mode = pl022_spi_set_mode, + .cs_info = pl022_cs_info, +}; + +#if !CONFIG_IS_ENABLED(OF_PLATDATA) +static const struct udevice_id pl022_spi_ids[] = { + { .compatible = "arm,pl022-spi" }, + { } +}; +#endif + +U_BOOT_DRIVER(pl022_spi) = { + .name = "pl022_spi", + .id = UCLASS_SPI, +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + .of_match = pl022_spi_ids, +#endif + .ops = &pl022_spi_ops, +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + .ofdata_to_platdata = pl022_spi_ofdata_to_platdata, +#endif + .platdata_auto_alloc_size = sizeof(struct pl022_spi_pdata), + .priv_auto_alloc_size = sizeof(struct pl022_spi_slave), + .probe = pl022_spi_probe, +}; diff --git a/include/dm/platform_data/pl022_spi.h b/include/dm/platform_data/pl022_spi.h new file mode 100644 index 0000000..77fe6da --- /dev/null +++ b/include/dm/platform_data/pl022_spi.h @@ -0,0 +1,28 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2018 + * Quentin Schulz, Bootlin, quentin.schulz@bootlin.com + * + * Structure for use with U_BOOT_DEVICE for pl022 SPI devices or to use + * in ofdata_to_platdata. + */ + +#ifndef __PL022_SPI_H__ +#define __PL022_SPI_H__ + +#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#include <clk.h> +#endif +#include <fdtdec.h> + +struct pl022_spi_pdata { + fdt_addr_t addr; + fdt_size_t size; +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + struct clk clk; +#else + unsigned int freq; +#endif +}; + +#endif
base-commit: b3e29c65aa7bda80cba063433878ebfcd3bb7601
SPI controllers SSP1, 2 and 3 require to enable their respective clocks. Let's enable them only when the SPI controller driver is built.
v2: - define and use constants for enabling SSP1/2/3 clocks when the controller is built
arch/arm/cpu/arm926ejs/spear/cpu.c | 3 +++ arch/arm/include/asm/arch-spear/spr_misc.h | 2 ++ 2 files changed, 5 insertions(+)
diff --git a/arch/arm/cpu/arm926ejs/spear/cpu.c b/arch/arm/cpu/arm926ejs/spear/cpu.c index 6fc29e7..c572785 100644 --- a/arch/arm/cpu/arm926ejs/spear/cpu.c +++ b/arch/arm/cpu/arm926ejs/spear/cpu.c @@ -52,6 +52,9 @@ int arch_cpu_init(void) #if defined(CONFIG_SPEAR_GPIO) periph1_clken |= MISC_GPIO3ENB | MISC_GPIO4ENB; #endif +#if defined(CONFIG_PL022_SPI) + periph1_clken |= MISC_SSP1ENB | MISC_SSP2ENB | MISC_SSP3ENB; +#endif
writel(periph1_clken, &misc_p->periph1_clken);
diff --git a/arch/arm/include/asm/arch-spear/spr_misc.h b/arch/arm/include/asm/arch-spear/spr_misc.h index 65063fc..01b4b2b 100644 --- a/arch/arm/include/asm/arch-spear/spr_misc.h +++ b/arch/arm/include/asm/arch-spear/spr_misc.h @@ -146,11 +146,13 @@ struct misc_regs { #define MISC_SMIENB 0x00200000 #define MISC_GPIO3ENB 0x00040000 #define MISC_GPT3ENB 0x00010000 +#define MISC_SSP3ENB 0x00004000 #define MISC_GPIO4ENB 0x00002000 #define MISC_GPT2ENB 0x00000800 #define MISC_FSMCENB 0x00000200 #define MISC_I2CENB 0x00000080 #define MISC_SSP2ENB 0x00000070 +#define MISC_SSP1ENB 0x00000020 #define MISC_UART0ENB 0x00000008
/* PERIPH_CLK_CFG */
The SSP2 clock is at bit 6 in the register, so the value is 0x40 unlike the current 0x70 which enables the clock of UART2, SSP1 and SSP2.
added in v2
@Stefan: I think you'd want to test the FPGA on x600 again as it's using this constant. Having worked on a system close to the x600, I'm guessing that it'll work as fine as on my platform with this patch but better be sure than sorry.
arch/arm/include/asm/arch-spear/spr_misc.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-spear/spr_misc.h b/arch/arm/include/asm/arch-spear/spr_misc.h index 01b4b2b..0171119 100644 --- a/arch/arm/include/asm/arch-spear/spr_misc.h +++ b/arch/arm/include/asm/arch-spear/spr_misc.h @@ -151,7 +151,7 @@ struct misc_regs { #define MISC_GPT2ENB 0x00000800 #define MISC_FSMCENB 0x00000200 #define MISC_I2CENB 0x00000080 -#define MISC_SSP2ENB 0x00000070 +#define MISC_SSP2ENB 0x00000040 #define MISC_SSP1ENB 0x00000020 #define MISC_UART0ENB 0x00000008
added in v2
I don't have easily access to the x600 board right now. Please go ahead with this patch. I'm now informed about this change and will make some tests, if I get this board on my desk again.
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
Signed-off-by: Quentin Schulz quentin.schulz@bootlin.com Acked-by: Stefan Roese sr@denx.de
Quentin Schulz
Stefan Roese
