Re: [U-Boot] [U-Boot, v1, 1/4] mtd: nand: add NAND_BUSWIDTH_AUTO to autodetect bus width
From: Scott Wood [mailto:scottwood@freescale.com] On Tue, Sep 10, 2013 at 06:57:05PM +0530, pekon gupta wrote:
This patch is slightly modified from following linux patch http://lists.infradead.org/pipermail/linux-mtd/2012-
November/044803.html
Which is now commit 64b37b2a63eb2f80b65c7185f0013f8ffc637ae3
So retaining the authorship to Matthieu CASTET
*Modifications from original patch* reset chip->read_byte, chip->read_buf, chip->write_buf before setting
defaults.
Why does U-Boot need this if Linux doesn't?
Yes, I plan to drop this patch. Reason: Though this feature was introduced in linux long back, but hardly any mtd/nand drivers using this. Also there are alternative approaches which do not require any change in individual controller drivers, but just in generic NAND driver. I have proposed them in linux mtd-maillist, I'll propose same in my next version of patch-set.
http://lists.infradead.org/pipermail/linux-mtd/2013-November/049744.html
with regards, pekon
defaults.
Hmm, I don't like the "kill NAND_BUSWIDTH_AUTO" sentiment. The device tree is for describing things that can't be reasonably discovered through hardware interfaces. ONFI identification always being x8 seems designed specifically to allow said discovery.
-Scott
Gupta, Pekon
Scott Wood
