[PATCH 0/3] Updates for omap3-evm
This patch set brings omap3-evm inline with similar boards and improves the ability to boot a 'fitImage' using DEFAULT_FIT_TI_ARGS.
Derald D. Woods (3): ARM: omap3: evm: Power on MMC when setting up PMIC ARM: omap3: evm: Complete DM_I2C migration ARM: omap3: evm: Fix 'fitImage' booting
board/ti/evm/evm.c | 8 +------- configs/omap3_evm_defconfig | 11 +++++++---- 2 files changed, 8 insertions(+), 11 deletions(-)
This commit copies the related code changes from the BeagleBoard.
Reference: - https://source.denx.de/u-boot/u-boot/-/commit/848cfe098f59c47a2542385513fb55...
Signed-off-by: Derald D. Woods woods.technical@gmail.com --- board/ti/evm/evm.c | 8 +------- 1 file changed, 1 insertion(+), 7 deletions(-)
diff --git a/board/ti/evm/evm.c b/board/ti/evm/evm.c index 96434b3ba0..39b5c706a9 100644 --- a/board/ti/evm/evm.c +++ b/board/ti/evm/evm.c @@ -159,6 +159,7 @@ void get_board_mem_timings(struct board_sdrc_timings *timings) int misc_init_r(void) { twl4030_power_init(); + twl4030_power_mmc_init(0);
#if defined(CONFIG_SMC911X) setup_net_chip(); @@ -247,10 +248,3 @@ static void reset_net_chip(void) gpio_set_value(rst_gpio, 1); } #endif /* CONFIG_SMC911X */ - -#if defined(CONFIG_MMC) -void board_mmc_power_init(void) -{ - twl4030_power_mmc_init(0); -} -#endif /* CONFIG_MMC */
Reference:
This commits enables DM_I2C and sets the default bus to 0.
Signed-off-by: Derald D. Woods woods.technical@gmail.com --- configs/omap3_evm_defconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index d451e201c7..2d8e627171 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -56,8 +56,8 @@ CONFIG_SPL_OF_TRANSLATE=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_GPIO_HOG=y -CONFIG_SYS_I2C_LEGACY=y -CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y
This commit sets two additional variables in the default BOOTCOMMAND. Adding 'boot=mmc' and 'addr_fit=0x8b000000' removes the need for a special 'uEnv.txt' to be created. The 'addr_fit' variable is the key piece here. It is normally defined as 0x90000000, in the macro DEFAULT_FIT_TI_ARGS. For this OMAP34XX board, 0x8b000000 works without touching other varibles. This was tested with a 'fitImage' created using the following FIT source:
---------------------------------------------------------------------- /dts-v1/;
/ { description = "Simple image with single Linux kernel and FDT blob"; #address-cells = <1>;
images { kernel { description = "Linux kernel: omap2plus"; data = /incbin/("./zImage"); type = "kernel"; arch = "arm"; os = "linux"; compression = "none"; load = <0x80008000>; entry = <0x80008000>; hash-1 { algo = "sha256"; }; }; fdt-omap3-evm.dtb { description = "FDT: omap3-evm.dtb"; data = /incbin/("./omap3-evm.dtb"); type = "flat_dt"; arch = "arm"; compression = "none"; load = <0x8ff00000>; hash-1 { algo = "sha256"; }; }; };
configurations { default = "conf-omap3-evm.dtb"; conf-omap3-evm.dtb { description = "Boot Linux kernel with FDT blob"; kernel = "kernel"; fdt = "fdt-omap3-evm.dtb"; }; }; }; ----------------------------------------------------------------------
Additionally, the default environment is now stored in "uboot.env" on the FAT partition of MMC '0'.
Fixes: 11e2ab3f0b ("ARM: omap3: evm: Enable booting 'fitImage' with DEFAULT_FIT_TI_ARGS") Signed-off-by: Derald D. Woods woods.technical@gmail.com --- configs/omap3_evm_defconfig | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 2d8e627171..e2e29e2eb6 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -10,7 +10,7 @@ CONFIG_TARGET_OMAP3_EVM=y CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 CONFIG_SPL=y CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run envboot; run distro_bootcmd" +CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then setenv boot mmc; setenv addr_fit 0x8b000000; run update_to_fit; run mmcboot; fi; run envboot; run distro_bootcmd" CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="omap3-evm.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -48,7 +48,10 @@ CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="clocks clock-names interrupt-parent" CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_NAND=y +CONFIG_ENV_IS_IN_FAT=y +CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y
On Sun, May 15, 2022 at 10:25 PM Derald D. Woods woods.technical@gmail.com wrote:
-- 2.36.1
Ping.
Ping.
Now that -next is open, I'll pick these up soon. Unless they need to be in v2022.07? Thanks!
On Sun, May 15, 2022 at 10:25 PM Derald D. Woods <
woods.technical@gmail.com>
Ping.
-- Tom
That's fine. Thanks for the update. Derald
Derald D. Woods
Derald Woods
