Pull request: u-boot-sunxi/master for v2022.10
Hi Tom,
please pull the sunxi/master branch, containing the first part of the 2022.10 changes.
One prominent feature is the restructering of the clock driver, which allows to end up with one actual driver for all variants, although we still only compile in support for one SoC. Also contained are some initial SPI fixes, which should fix some problems, and enable SPI flash support for the F1C100s SoC. Those patches revealed more problems, I will queue fixes later on, but for now it should at least still work. Apart from some smaller fixes (for instance for NAND operation), there is also preparation for the upcoming Allwinner D1 support, in form of the USB PHY driver. There are more driver support patches to come.
The gitlab CI completed successfully, including the build test for all 160 sunxi boards. I also boot tested on a few boards, but didn't have time for more elaborate tests this time.
Thanks, Andre
=========================== The following changes since commit 26f6f7fb5c0651d65afdee6d8ed36063606179a8:
Merge branch '2022-07-14-migrate-wiki-to-sphinx' (2022-07-14 18:43:51 -0400)
https://source.denx.de/u-boot/custodians/u-boot-sunxi.git master
for you to fetch changes up to 25ba5be1c2b6324917254f0c22df1ad9d3d3c9e7:
phy: sun4i-usb: Add D1 variant (2022-07-18 23:48:37 +0100)
---------------------------------------------------------------- Andre Przywara (6): sunxi: configs: streamline include/configs/sun*.h wrappers spi: sunxi: refactor SPI speed/mode programming spi: sunxi: improve SPI clock calculation spi: sunxi: Add support for F1C100s SPI controller sunxi: licheepi_nano: enable SPI flash phy: sun4i-usb: Rework HCI PHY (aka "pmu_unk1") handling
Icenowy Zheng (1): spi: sunxi: use XCH status to detect in-progress transfer
Markus Hoffrogge (1): sunxi-nand: fix the PIO instead of DMA implementation
Michal Suchanek (2): sunxi: lcd: Move range from kconfig description to definition. configs: sunxi: OrangePi Zero: enable Macronix flash support
Samuel Holland (12): clk: sunxi: Store the array sizes in the CCU descriptor clk: sunxi: Prevent out-of-bounds gate array access reset: sunxi: Get the reset count from the CCU descriptor clk: sunxi: Use a single driver for all variants clk: sunxi: Convert driver private data to platform data reset: sunxi: Convert driver private data to platform data reset: sunxi: Reuse the platform data from the clock driver net: sun8i-emac: Downgrade printf during probe to debug net: sun8i-emac: Drop use of arch-specific header sunxi: Move INITIAL_USB_SCAN_DELAY to driver Kconfig phy: sun4i-usb: Drop use of arch-specific headers phy: sun4i-usb: Add D1 variant
arch/arm/mach-sunxi/Kconfig | 12 +-- configs/licheepi_nano_defconfig | 3 + configs/orangepi_zero_defconfig | 1 + drivers/clk/sunxi/clk_a10.c | 27 +----- drivers/clk/sunxi/clk_a10s.c | 27 +----- drivers/clk/sunxi/clk_a23.c | 27 +----- drivers/clk/sunxi/clk_a31.c | 25 +---- drivers/clk/sunxi/clk_a31_r.c | 29 +----- drivers/clk/sunxi/clk_a64.c | 25 +---- drivers/clk/sunxi/clk_a80.c | 36 ++----- drivers/clk/sunxi/clk_a83t.c | 25 +---- drivers/clk/sunxi/clk_f1c100s.c | 25 +---- drivers/clk/sunxi/clk_h3.c | 27 +----- drivers/clk/sunxi/clk_h6.c | 25 +---- drivers/clk/sunxi/clk_h616.c | 25 +---- drivers/clk/sunxi/clk_h6_r.c | 27 +----- drivers/clk/sunxi/clk_r40.c | 25 +---- drivers/clk/sunxi/clk_sunxi.c | 175 ++++++++++++++++++++++++++++++---- drivers/clk/sunxi/clk_v3s.c | 27 +----- drivers/mtd/nand/raw/sunxi_nand_spl.c | 2 +- drivers/net/sun8i_emac.c | 3 +- drivers/phy/allwinner/Kconfig | 10 ++ drivers/phy/allwinner/phy-sun4i-usb.c | 44 +++++---- drivers/reset/reset-sunxi.c | 55 ++--------- drivers/spi/spi-sunxi.c | 123 ++++++++++++++---------- include/clk/sunxi.h | 21 +--- include/configs/sun4i.h | 10 +- include/configs/sun50i.h | 19 +--- include/configs/sun5i.h | 10 +- include/configs/sun6i.h | 7 +- include/configs/sun7i.h | 6 +- include/configs/sun8i.h | 13 +-- include/configs/sun9i.h | 11 +-- include/configs/suniv.h | 7 +- 34 files changed, 345 insertions(+), 589 deletions(-)
On Tue, Jul 19, 2022 at 02:51:02PM +0100, Andre Przywara wrote:
Hi Tom,
Thanks, Andre
Andre Przywara
