[U-Boot] [PATCH 0/8] rockchip: conver to use ARM arch timer for armv7 SoCs
This patch set can be consider to be split out of previous patch set " rockchip: clean up board file for rockchip SoCs"
This patch set depends on patch set for rk3188 use DM timer.
Kever Yang (8): rockchip: add STIMER_BASE for Rockchip SoCs rockchip: rk322x: sdram: use udelay instead of rockchip_udelay rockchip: rk322x: use ARM arch timer instead of rk_timer rockchip: rk3036: sdram: use udelay instead of rockchip_udelay rockchip: rk3036: use ARM arch timer instead of rk_timer rockchip: rk3288: use ARM arch timer instead of rk_timer rockchip: rk3128: use ARM arch timer instead of rk_timer rockchip: remove unused rk_timer.c
arch/arm/mach-rockchip/Kconfig | 16 ++++++++++ arch/arm/mach-rockchip/Makefile | 6 ---- arch/arm/mach-rockchip/rk3036-board-spl.c | 19 +++++++++-- arch/arm/mach-rockchip/rk3036/sdram_rk3036.c | 19 ++++++----- arch/arm/mach-rockchip/rk3128-board.c | 2 -- arch/arm/mach-rockchip/rk322x-board-spl.c | 19 +++++++++-- arch/arm/mach-rockchip/rk3288-board-spl.c | 18 +++++++++-- arch/arm/mach-rockchip/rk3288-board-tpl.c | 18 +++++++++-- arch/arm/mach-rockchip/rk_timer.c | 48 ---------------------------- drivers/ram/rockchip/sdram_rk322x.c | 29 ++++++++--------- include/configs/rk3036_common.h | 6 ++-- include/configs/rk3128_common.h | 6 ++-- include/configs/rk322x_common.h | 6 ++-- include/configs/rk3288_common.h | 6 ++-- 14 files changed, 116 insertions(+), 102 deletions(-) delete mode 100644 arch/arm/mach-rockchip/rk_timer.c
Most of Rockchip SoCs have ARM arch/generic timer whose clock source is from one of secure timer(if the soc supports Trust environment).
STIMER can only access in secure mode, so it should be init before the proper U-Boot(usually in non-secure mode). Add a MACRO for timer base addr so that we can init with a common function in SPL/TPL.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/mach-rockchip/Kconfig | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 0adaed4..55d3d5c 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -191,6 +191,22 @@ config ROCKCHIP_BOOT_MODE_REG The Soc will enter to different boot mode(defined in asm/arch/boot_mode.h) according to the value from this register.
+config ROCKCHIP_STIMER_BASE + hex "Rockchip Secure timer base address" + default 0x200440a0 if ROCKCHIP_RK3036 + default 0x20018020 if ROCKCHIP_RK3126 + default 0x200440a0 if ROCKCHIP_RK3128 + default 0x110d0020 if ROCKCHIP_RK322X + default 0xff810020 if ROCKCHIP_RK3288 + default 0xff1d0020 if ROCKCHIP_RK3328 + default 0xff830020 if ROCKCHIP_RK3368 + default 0xff8680a0 if ROCKCHIP_RK3399 + default 0x10350020 if ROCKCHIP_RV1108 + default 0 + help + The secure timer inited in SPL/TPL in secure word, ARM generic timer + works after this timer work. + config ROCKCHIP_SPL_RESERVE_IRAM hex "Size of IRAM reserved in SPL" default 0
See below for required changes.
- hex "Rockchip Secure timer base address"
- default 0x200440a0 if ROCKCHIP_RK3036
- default 0x20018020 if ROCKCHIP_RK3126
- default 0x200440a0 if ROCKCHIP_RK3128
- default 0x110d0020 if ROCKCHIP_RK322X
- default 0xff810020 if ROCKCHIP_RK3288
- default 0xff1d0020 if ROCKCHIP_RK3328
- default 0xff830020 if ROCKCHIP_RK3368
- default 0xff8680a0 if ROCKCHIP_RK3399
- default 0x10350020 if ROCKCHIP_RV1108
- default 0
- help
NAK. This is not a user-configurable/selectable option, but rather a function of the chip used. This belongs into a header file in arch/arm/include/asm/arch-rockchip.
Hi Philipp,
Yes, you are correct in one way, but I think if this goes to header file, it will separate in different header file for different SoCs, or with a lot if MACRO like "#if defined(CONFIG_ROCKCHIP_RK3288) #elif" in one header file.
Make ROCKCHIP_STIMER_BASE in Kconfig and use like ROCKCHIP_BOOT_MODE_REG seems like a better idea to make things simple.
Actually there are many other configs like this: - DEBUG_UART_BASE - IRAM_START - DRAM_START
One more consideration is, I don't think make SoC configs into too much place is a good idea, now we have 3 places for configs: - Kconfig default value - configs/soc_defconfig - include/configs/soc_header.h (this is moving to Kconfig one by one now)
so I would not like to move it into arch/arm/include/asm/arch-rockchip, if you insist this should go to header file instead of Kconfig, I would prefer to use header file in 'include/configs/' folder, how do you think?
Thanks, - Kever
Hi Philipp,
ping... Could you reply this first before I send next patch set?
Thanks, - Kever On 09/03/2018 11:21 AM, Kever Yang wrote:
Hi Philipp,
- DEBUG_UART_BASE
- IRAM_START
- DRAM_START
Thanks,
- Kever
Kever,
[Sorry for the delay, I am switching laptops and this got stuck in my Drafts folder on the old machine — which I noticed only today]
On 3 Sep 2018, at 05:21, Kever Yang kever.yang@rock-chips.com wrote:
Hi Philipp,
- default 0
- help
timer
I don’t care whether we make this different files (my preferred choice in the long run … i.e. after we clean up the header-file directory) or put it into single file: at the moment both variants are common in our asm/arch-rockchip directory …
- DEBUG_UART_BASE
This is an excellent example and really needs to go into Kconfig, as the UART selection is done via this (e.g. we use a different DEBUG_UART on the RK3399-Q7 than on Rockchip’s reference design) and it’s not something the chip designs but rather a selection from a list encoded as an address.
- IRAM_START
- DRAM_START
All of this should eventually go into asm/arch-rockchip, unless it’s a an board-specific overrride/configuration item (include/configs was historically meant for boards and not for SOCs). I believe that include/configs/ will eventually be almost completely replaced by Kconfig entries and that any SOC-related things will need to go into asm/arch-rockchip.
If you could put it into asm/arch-rockchip, I’d prefer this. However, if you want to have it in include/configs, I won’t delay the series because of it and we’ll deal with the clean-up when the time comes.
Thanks, Philipp.
Thanks,
- Kever
Use system api for udelay instead of vendor defined api, and rockchip_udelay() will be removed.
drivers/ram/rockchip/sdram_rk322x.c | 29 ++++++++++++++--------------- 1 file changed, 14 insertions(+), 15 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk322x.c b/drivers/ram/rockchip/sdram_rk322x.c index a82f993..0a7da95 100644 --- a/drivers/ram/rockchip/sdram_rk322x.c +++ b/drivers/ram/rockchip/sdram_rk322x.c @@ -17,7 +17,6 @@ #include <asm/arch/grf_rk322x.h> #include <asm/arch/hardware.h> #include <asm/arch/sdram_rk322x.h> -#include <asm/arch/timer.h> #include <asm/arch/uart.h> #include <asm/arch/sdram_common.h> #include <asm/types.h> @@ -97,26 +96,26 @@ void phy_pctrl_reset(struct rk322x_cru *cru, 1 << DDRCTRL_PSRST_SHIFT | 1 << DDRCTRL_SRST_SHIFT | 1 << DDRPHY_PSRST_SHIFT | 1 << DDRPHY_SRST_SHIFT);
- rockchip_udelay(10); + udelay(10);
rk_clrreg(&cru->cru_softrst_con[5], 1 << DDRPHY_PSRST_SHIFT | 1 << DDRPHY_SRST_SHIFT); - rockchip_udelay(10); + udelay(10);
rk_clrreg(&cru->cru_softrst_con[5], 1 << DDRCTRL_PSRST_SHIFT | 1 << DDRCTRL_SRST_SHIFT); - rockchip_udelay(10); + udelay(10);
clrbits_le32(&ddr_phy->ddrphy_reg[0], SOFT_RESET_MASK << SOFT_RESET_SHIFT); - rockchip_udelay(10); + udelay(10); setbits_le32(&ddr_phy->ddrphy_reg[0], SOFT_DERESET_ANALOG); - rockchip_udelay(5); + udelay(5); setbits_le32(&ddr_phy->ddrphy_reg[0], SOFT_DERESET_DIGITAL);
- rockchip_udelay(1); + udelay(1); }
void phy_dll_bypass_set(struct rk322x_ddr_phy *ddr_phy, u32 freq) @@ -155,7 +154,7 @@ static void send_command(struct rk322x_ddr_pctl *pctl, u32 rank, u32 cmd, u32 arg) { writel((START_CMD | (rank << 20) | arg | cmd), &pctl->mcmd); - rockchip_udelay(1); + udelay(1); while (readl(&pctl->mcmd) & START_CMD) ; } @@ -168,7 +167,7 @@ static void memory_init(struct chan_info *chan,
if (dramtype == DDR3) { send_command(pctl, 3, DESELECT_CMD, 0); - rockchip_udelay(1); + udelay(1); send_command(pctl, 3, PREA_CMD, 0); send_command(pctl, 3, MRS_CMD, (0x02 & BANK_ADDR_MASK) << BANK_ADDR_SHIFT | @@ -197,17 +196,17 @@ static void memory_init(struct chan_info *chan, (0x63 & LPDDR23_MA_MASK) << LPDDR23_MA_SHIFT | (0 & LPDDR23_OP_MASK) << LPDDR23_OP_SHIFT); - rockchip_udelay(10); + udelay(10); send_command(pctl, 3, MRS_CMD, (0x10 & LPDDR23_MA_MASK) << LPDDR23_MA_SHIFT | (0xff & LPDDR23_OP_MASK) << LPDDR23_OP_SHIFT); - rockchip_udelay(1); + udelay(1); send_command(pctl, 3, MRS_CMD, (0x10 & LPDDR23_MA_MASK) << LPDDR23_MA_SHIFT | (0xff & LPDDR23_OP_MASK) << LPDDR23_OP_SHIFT); - rockchip_udelay(1); + udelay(1); send_command(pctl, 3, MRS_CMD, (1 & LPDDR23_MA_MASK) << LPDDR23_MA_SHIFT | (sdram_params->phy_timing.mr[1] & @@ -244,7 +243,7 @@ static u32 data_training(struct chan_info *chan) DQS_SQU_CAL_SEL_CS0); setbits_le32(&ddr_phy->ddrphy_reg[2], DQS_SQU_CAL_START);
- rockchip_udelay(30); + udelay(30); ret = readl(&ddr_phy->ddrphy_reg[0xff]);
clrbits_le32(&ddr_phy->ddrphy_reg[2], @@ -368,9 +367,9 @@ static void phy_softreset(struct dram_info *dram)
writel(GRF_DDRPHY_BUFFEREN_CORE_EN, &grf->soc_con[0]); clrbits_le32(&ddr_phy->ddrphy_reg[0], 0x3 << 2); - rockchip_udelay(1); + udelay(1); setbits_le32(&ddr_phy->ddrphy_reg[0], 1 << 2); - rockchip_udelay(5); + udelay(5); setbits_le32(&ddr_phy->ddrphy_reg[0], 1 << 3); writel(GRF_DDRPHY_BUFFEREN_CORE_DIS, &grf->soc_con[0]); }
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
We prefer to use ARM arch timer instead of rockchip timer, so that we are using the same timer for SPL, U-Boot and Kernel, which will make things simple and easy to track to boot time.
arch/arm/mach-rockchip/Makefile | 2 +- arch/arm/mach-rockchip/rk322x-board-spl.c | 19 ++++++++++++++++--- include/configs/rk322x_common.h | 6 +++--- 3 files changed, 20 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 096dbac..c1eeefb 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -40,7 +40,7 @@ endif obj-$(CONFIG_$(SPL_TPL_)RAM) += sdram_common.o
ifndef CONFIG_ARM64 -ifndef CONFIG_ROCKCHIP_RK3188 +ifeq ($(CONFIG_ROCKCHIP_RK3188)$(CONFIG_ROCKCHIP_RK322X),) obj-y += rk_timer.o endif endif diff --git a/arch/arm/mach-rockchip/rk322x-board-spl.c b/arch/arm/mach-rockchip/rk322x-board-spl.c index d3d0446..b5b178f 100644 --- a/arch/arm/mach-rockchip/rk322x-board-spl.c +++ b/arch/arm/mach-rockchip/rk322x-board-spl.c @@ -14,7 +14,6 @@ #include <asm/arch/cru_rk322x.h> #include <asm/arch/grf_rk322x.h> #include <asm/arch/hardware.h> -#include <asm/arch/timer.h> #include <asm/arch/uart.h>
u32 spl_boot_device(void) @@ -62,6 +61,17 @@ void board_debug_uart_init(void) CON_IOMUX_UART2SEL_21 << CON_IOMUX_UART2SEL_SHIFT); }
+void rockchip_stimer_init(void) +{ + asm volatile("mcr p15, 0, %0, c14, c0, 0" + : : "r"(COUNTER_FREQUENCY)); + + writel(0, CONFIG_ROCKCHIP_STIMER_BASE + 0x10); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); + writel(1, CONFIG_ROCKCHIP_STIMER_BASE + 0x10); +} + #define SGRF_DDR_CON0 0x10150000 void board_init_f(ulong dummy) { @@ -85,8 +95,11 @@ void board_init_f(ulong dummy) hang(); }
- rockchip_timer_init(); - printf("timer init done\n"); + /* Init secure timer */ + rockchip_stimer_init(); + /* Init ARM arch timer in arch/arm/cpu/armv7/arch_timer.c */ + timer_init(); + ret = uclass_get_device(UCLASS_RAM, 0, &dev); if (ret) { printf("DRAM init failed: %d\n", ret); diff --git a/include/configs/rk322x_common.h b/include/configs/rk322x_common.h index b437b85..8f8a1ef 100644 --- a/include/configs/rk322x_common.h +++ b/include/configs/rk322x_common.h @@ -14,9 +14,9 @@ #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64M */
-#define CONFIG_SYS_TIMER_RATE (24 * 1000 * 1000) -#define CONFIG_SYS_TIMER_BASE 0x110c00a0 /* TIMER5 */ -#define CONFIG_SYS_TIMER_COUNTER (CONFIG_SYS_TIMER_BASE + 8) +#define COUNTER_FREQUENCY 24000000 +#define CONFIG_SYS_ARCH_TIMER +#define CONFIG_SYS_HZ_CLOCK 24000000
#define CONFIG_SYS_NS16550_MEM32 #define CONFIG_SYS_INIT_SP_ADDR 0x60100000
See below for requested changes.
Please have a config-option for the rk_timer and force (i.e. SELECT) it for these chips. I am not keen on a list that grows like this...
- asm volatile("mcr p15, 0, %0, c14, c0, 0"
- writel(0, CONFIG_ROCKCHIP_STIMER_BASE + 0x10);
- writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE);
- writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4);
- writel(1, CONFIG_ROCKCHIP_STIMER_BASE + 0x10);
NAK. See comment on patch #1.
Can we have this as a const uint32_t * ?
- /* Init secure timer */
- rockchip_stimer_init();
- /* Init ARM arch timer in arch/arm/cpu/armv7/arch_timer.c */
- timer_init();
- ret = uclass_get_device(UCLASS_RAM, 0, &dev); if (ret) { printf("DRAM init failed: %d\n", ret);
arch/arm/mach-rockchip/rk3036/sdram_rk3036.c | 19 +++++++++---------- 1 file changed, 9 insertions(+), 10 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3036/sdram_rk3036.c b/arch/arm/mach-rockchip/rk3036/sdram_rk3036.c index e5393ec..ce3f09a 100644 --- a/arch/arm/mach-rockchip/rk3036/sdram_rk3036.c +++ b/arch/arm/mach-rockchip/rk3036/sdram_rk3036.c @@ -10,7 +10,6 @@ #include <asm/arch/grf_rk3036.h> #include <asm/arch/hardware.h> #include <asm/arch/sdram_rk3036.h> -#include <asm/arch/timer.h> #include <asm/arch/uart.h>
/* @@ -346,7 +345,7 @@ static void rkdclk_init(struct rk3036_sdram_priv *priv)
/* waiting for pll lock */ while (readl(&pll->con1) & (1 << PLL_LOCK_STATUS_SHIFT)) - rockchip_udelay(1); + udelay(1);
/* PLL enter normal-mode */ rk_clrsetreg(&priv->cru->cru_mode_con, DPLL_MODE_MASK, @@ -374,25 +373,25 @@ void phy_pctrl_reset(struct rk3036_sdram_priv *priv) 1 << DDRCTRL_PSRST_SHIFT | 1 << DDRCTRL_SRST_SHIFT | 1 << DDRPHY_PSRST_SHIFT | 1 << DDRPHY_SRST_SHIFT);
rk_clrreg(&priv->cru->cru_softrst_con[5], 1 << DDRPHY_PSRST_SHIFT | 1 << DDRPHY_SRST_SHIFT); - rockchip_udelay(10); + udelay(10);
rk_clrreg(&priv->cru->cru_softrst_con[5], 1 << DDRCTRL_PSRST_SHIFT | 1 << DDRCTRL_SRST_SHIFT); - rockchip_udelay(10); + udelay(10);
clrsetbits_le32(&ddr_phy->ddrphy_reg1, SOFT_RESET_MASK << SOFT_RESET_SHIFT, 0 << SOFT_RESET_SHIFT); - rockchip_udelay(10); + udelay(10); clrsetbits_le32(&ddr_phy->ddrphy_reg1, SOFT_RESET_MASK << SOFT_RESET_SHIFT, 3 << SOFT_RESET_SHIFT);
void phy_dll_bypass_set(struct rk3036_sdram_priv *priv, unsigned int freq) @@ -445,7 +444,7 @@ static void send_command(struct rk3036_ddr_pctl *pctl, u32 rank, u32 cmd, u32 arg) { writel((START_CMD | (rank << 20) | arg | cmd), &pctl->mcmd); - rockchip_udelay(1); + udelay(1); while (readl(&pctl->mcmd) & START_CMD) ; } @@ -455,7 +454,7 @@ static void memory_init(struct rk3036_sdram_priv *priv) struct rk3036_ddr_pctl *pctl = priv->pctl;
send_command(pctl, 3, DESELECT_CMD, 0); - rockchip_udelay(1); + udelay(1); send_command(pctl, 3, PREA_CMD, 0); send_command(pctl, 3, MRS_CMD, (0x02 & BANK_ADDR_MASK) << BANK_ADDR_SHIFT | @@ -493,7 +492,7 @@ static void data_training(struct rk3036_sdram_priv *priv) clrsetbits_le32(&ddr_phy->ddrphy_reg2, 0x03, DQS_SQU_CAL_NORMAL_MODE | DQS_SQU_CAL_START);
- rockchip_udelay(1); + udelay(1); while ((readl(&ddr_phy->ddrphy_reg62) & CAL_DONE_MASK) != (HIGH_8BIT_CAL_DONE | LOW_8BIT_CAL_DONE)) { ;
We prefer to use ARM arch timer instead of rockchip timer, so that we are using the same timer for SPL, U-Boot and Kernel, which will make things simple and easy to track the boot time.
arch/arm/mach-rockchip/Makefile | 2 +- arch/arm/mach-rockchip/rk3036-board-spl.c | 19 +++++++++++++++++-- include/configs/rk3036_common.h | 6 +++--- 3 files changed, 21 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index c1eeefb..02aa58a 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -40,7 +40,7 @@ endif obj-$(CONFIG_$(SPL_TPL_)RAM) += sdram_common.o
ifndef CONFIG_ARM64 -ifeq ($(CONFIG_ROCKCHIP_RK3188)$(CONFIG_ROCKCHIP_RK322X),) +ifeq ($(CONFIG_ROCKCHIP_RK3188)$(CONFIG_ROCKCHIP_RK322X)$(CONFIG_ROCKCHIP_RK3036),) obj-y += rk_timer.o endif endif diff --git a/arch/arm/mach-rockchip/rk3036-board-spl.c b/arch/arm/mach-rockchip/rk3036-board-spl.c index 550e3a1..4b4016b 100644 --- a/arch/arm/mach-rockchip/rk3036-board-spl.c +++ b/arch/arm/mach-rockchip/rk3036-board-spl.c @@ -11,7 +11,6 @@ #include <asm/arch/grf_rk3036.h> #include <asm/arch/hardware.h> #include <asm/arch/sdram_rk3036.h> -#include <asm/arch/timer.h> #include <asm/arch/uart.h>
DECLARE_GLOBAL_DATA_PTR; @@ -20,6 +19,17 @@ DECLARE_GLOBAL_DATA_PTR;
#define DEBUG_UART_BASE 0x20068000
+void rockchip_stimer_init(void) +{ + asm volatile("mcr p15, 0, %0, c14, c0, 0" + : : "r"(COUNTER_FREQUENCY)); + + writel(0, CONFIG_ROCKCHIP_STIMER_BASE + 0x10); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); + writel(1, CONFIG_ROCKCHIP_STIMER_BASE + 0x10); +} + void board_init_f(ulong dummy) { #ifdef EARLY_DEBUG @@ -36,7 +46,12 @@ void board_init_f(ulong dummy) GPIO1C2_UART2_SIN << GPIO1C2_SHIFT); debug_uart_init(); #endif - rockchip_timer_init(); + + /* Init secure timer */ + rockchip_stimer_init(); + /* Init ARM arch timer in arch/arm/cpu/armv7/arch_timer.c */ + timer_init(); + sdram_init();
/* return to maskrom */ diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index f39a272..7d83f81 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -14,9 +14,9 @@ #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SKIP_LOWLEVEL_INIT
-#define CONFIG_SYS_TIMER_RATE (24 * 1000 * 1000) -#define CONFIG_SYS_TIMER_BASE 0x200440a0 /* TIMER5 */ -#define CONFIG_SYS_TIMER_COUNTER (CONFIG_SYS_TIMER_BASE + 8) +#define COUNTER_FREQUENCY 24000000 +#define CONFIG_SYS_ARCH_TIMER +#define CONFIG_SYS_HZ_CLOCK 24000000
#define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_MEM32
Same as for the previous patch. Now it has become apparent, that this list is growing...
Please make this a const uint32_t * ... or even better: use a pointer to a structure representing the peripheral's register layout.
Unless we really want a 0, we should clrbits the specific bits involved via symbolic constants.
This should be a symbolic 'enable' bit that gets written. I'd prefer a setbits on this, as we only want a single bit.
Once again (I had this in the comments on the first revision a few weeks back already): the STIMER_BASE is not user-configurable.
timer_init();
sdram_init();
arch/arm/mach-rockchip/Makefile | 2 +- arch/arm/mach-rockchip/rk3288-board-spl.c | 18 ++++++++++++++++-- arch/arm/mach-rockchip/rk3288-board-tpl.c | 18 ++++++++++++++++-- include/configs/rk3288_common.h | 6 +++--- 4 files changed, 36 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 02aa58a..86efd7b 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -40,7 +40,7 @@ endif obj-$(CONFIG_$(SPL_TPL_)RAM) += sdram_common.o
ifndef CONFIG_ARM64 -ifeq ($(CONFIG_ROCKCHIP_RK3188)$(CONFIG_ROCKCHIP_RK322X)$(CONFIG_ROCKCHIP_RK3036),) +ifeq ($(CONFIG_ROCKCHIP_RK3188)$(CONFIG_ROCKCHIP_RK322X)$(CONFIG_ROCKCHIP_RK3036)$(CONFIG_ROCKCHIP_RK3288),) obj-y += rk_timer.o endif endif diff --git a/arch/arm/mach-rockchip/rk3288-board-spl.c b/arch/arm/mach-rockchip/rk3288-board-spl.c index f3ea624..8f22549 100644 --- a/arch/arm/mach-rockchip/rk3288-board-spl.c +++ b/arch/arm/mach-rockchip/rk3288-board-spl.c @@ -23,7 +23,6 @@ #include <asm/arch/sdram.h> #include <asm/arch/sdram_common.h> #include <asm/arch/sys_proto.h> -#include <asm/arch/timer.h> #include <dm/pinctrl.h> #include <dm/root.h> #include <dm/test.h> @@ -143,6 +142,17 @@ static int phycore_init(void) } #endif
+void rockchip_stimer_init(void) +{ + asm volatile("mcr p15, 0, %0, c14, c0, 0" + : : "r"(COUNTER_FREQUENCY)); + + writel(0, CONFIG_ROCKCHIP_STIMER_BASE + 0x10); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); + writel(1, CONFIG_ROCKCHIP_STIMER_BASE + 0x10); +} + void board_init_f(ulong dummy) { struct udevice *pinctrl; @@ -175,7 +185,11 @@ void board_init_f(ulong dummy) hang(); }
- rockchip_timer_init(); + /* Init secure timer */ + rockchip_stimer_init(); + /* Init ARM arch timer in arch/arm/cpu/armv7/arch_timer.c */ + timer_init(); + configure_l2ctlr();
ret = rockchip_get_clk(&dev); diff --git a/arch/arm/mach-rockchip/rk3288-board-tpl.c b/arch/arm/mach-rockchip/rk3288-board-tpl.c index 150beea..e34142c 100644 --- a/arch/arm/mach-rockchip/rk3288-board-tpl.c +++ b/arch/arm/mach-rockchip/rk3288-board-tpl.c @@ -17,10 +17,20 @@ #include <asm/arch/periph.h> #include <asm/arch/pmu_rk3288.h> #include <asm/arch/sys_proto.h> -#include <asm/arch/timer.h>
+void rockchip_stimer_init(void) +{ + asm volatile("mcr p15, 0, %0, c14, c0, 0" + : : "r"(COUNTER_FREQUENCY)); + + writel(0, CONFIG_ROCKCHIP_STIMER_BASE + 0x10); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); + writel(1, CONFIG_ROCKCHIP_STIMER_BASE + 0x10); +} + #define GRF_BASE 0xff770000 void board_init_f(ulong dummy) { @@ -51,7 +61,11 @@ void board_init_f(ulong dummy) hang(); }
ret = rockchip_get_clk(&dev); diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index 78595b8..98cc9be 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -15,9 +15,9 @@ #define CONFIG_SYS_MALLOC_LEN (32 << 20) #define CONFIG_SYS_CBSIZE 1024
-#define CONFIG_SYS_TIMER_RATE (24 * 1000 * 1000) -#define CONFIG_SYS_TIMER_BASE 0xff810020 /* TIMER7 */ -#define CONFIG_SYS_TIMER_COUNTER (CONFIG_SYS_TIMER_BASE + 8) +#define COUNTER_FREQUENCY 24000000 +#define CONFIG_SYS_ARCH_TIMER +#define CONFIG_SYS_HZ_CLOCK 24000000
Same comments as for the other patches apply.
Thanks, Philipp.
timer_init();
configure_l2ctlr();
timer_init();
configure_l2ctlr();
arch/arm/mach-rockchip/Makefile | 6 ------ arch/arm/mach-rockchip/rk3128-board.c | 2 -- include/configs/rk3128_common.h | 6 +++--- 3 files changed, 3 insertions(+), 11 deletions(-)
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 86efd7b..e1e2d54 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -39,12 +39,6 @@ endif
-ifndef CONFIG_ARM64 -ifeq ($(CONFIG_ROCKCHIP_RK3188)$(CONFIG_ROCKCHIP_RK322X)$(CONFIG_ROCKCHIP_RK3036)$(CONFIG_ROCKCHIP_RK3288),) -obj-y += rk_timer.o -endif -endif - obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036/ obj-$(CONFIG_ROCKCHIP_RK3128) += rk3128/ ifndef CONFIG_TPL_BUILD diff --git a/arch/arm/mach-rockchip/rk3128-board.c b/arch/arm/mach-rockchip/rk3128-board.c index 2e8393d..85c9288 100644 --- a/arch/arm/mach-rockchip/rk3128-board.c +++ b/arch/arm/mach-rockchip/rk3128-board.c @@ -34,8 +34,6 @@ int board_init(void) { int ret = 0;
- rockchip_timer_init(); - ret = regulators_enable_boot_on(false); if (ret) { debug("%s: Cannot enable boot on regulator\n", __func__); diff --git a/include/configs/rk3128_common.h b/include/configs/rk3128_common.h index bd8019c..e7e137b 100644 --- a/include/configs/rk3128_common.h +++ b/include/configs/rk3128_common.h @@ -15,9 +15,9 @@ #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SKIP_LOWLEVEL_INIT
All other SoCs have conver to use ARM arch timer or Rockchip DM timer, so we can remove rk_timer.c now.
arch/arm/mach-rockchip/rk_timer.c | 48 --------------------------------------- 1 file changed, 48 deletions(-) delete mode 100644 arch/arm/mach-rockchip/rk_timer.c
diff --git a/arch/arm/mach-rockchip/rk_timer.c b/arch/arm/mach-rockchip/rk_timer.c deleted file mode 100644 index 853b986..0000000 --- a/arch/arm/mach-rockchip/rk_timer.c +++ /dev/null @@ -1,48 +0,0 @@ -/* - * (C) Copyright 2015 Rockchip Electronics Co., Ltd - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/arch/timer.h> -#include <asm/io.h> -#include <linux/types.h> - -struct rk_timer * const timer_ptr = (void *)CONFIG_SYS_TIMER_BASE; - -static uint64_t rockchip_get_ticks(void) -{ - uint64_t timebase_h, timebase_l; - - timebase_l = readl(&timer_ptr->timer_curr_value0); - timebase_h = readl(&timer_ptr->timer_curr_value1); - - return timebase_h << 32 | timebase_l; -} - -static uint64_t usec_to_tick(unsigned int usec) -{ - uint64_t tick = usec; - tick *= CONFIG_SYS_TIMER_RATE / (1000 * 1000); - return tick; -} - -void rockchip_udelay(unsigned int usec) -{ - uint64_t tmp; - - /* get timestamp */ - tmp = rockchip_get_ticks() + usec_to_tick(usec); - - /* loop till event */ - while (rockchip_get_ticks() < tmp+1) - ; -} - -void rockchip_timer_init(void) -{ - writel(0xffffffff, &timer_ptr->timer_load_count0); - writel(0xffffffff, &timer_ptr->timer_load_count1); - writel(1, &timer_ptr->timer_ctrl_reg); -}
Dr. Philipp Tomsich
Kever Yang
Philipp Tomsich
