[U-Boot] [PATCH v2] arm: socfpga: Fix emac1 doesn't work on socdk board
Updated pinmux group MIXED1IO[0-13] for RGMII1. Updated EMAC1 clock.
Signed-off-by: shengjiangwu shengjiangwu@icloud.com Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Dinh Nguyen dinh.linux@gmail.com Cc: Pavel Machek pavel@denx.de Cc: Marek Vasut marex@denx.de Cc: Stefan Roese sr@denx.de --- Changes for v2: - fixed wrong perpll for emac1 --- board/altera/cyclone5-socdk/qts/pll_config.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/altera/cyclone5-socdk/qts/pll_config.h b/board/altera/cyclone5-socdk/qts/pll_config.h index eccc705..5b754ac 100644 --- a/board/altera/cyclone5-socdk/qts/pll_config.h +++ b/board/altera/cyclone5-socdk/qts/pll_config.h @@ -65,7 +65,7 @@ #define CONFIG_HPS_CLK_PERVCO_HZ 1000000000 #define CONFIG_HPS_CLK_SDRVCO_HZ 666666666 #define CONFIG_HPS_CLK_EMAC0_HZ 250000000 -#define CONFIG_HPS_CLK_EMAC1_HZ 50000000 +#define CONFIG_HPS_CLK_EMAC1_HZ 250000000 #define CONFIG_HPS_CLK_USBCLK_HZ 200000000 #define CONFIG_HPS_CLK_NAND_HZ 50000000 #define CONFIG_HPS_CLK_SDMMC_HZ 200000000
Hi Shengjiang,
Changes for v2:
This is good. But I believe you miss the pinmux change here. You just need to take the previous patch and made the change.
Thanks Chin Liang
Chin Liang See
shengjiangwu
